    4. [Problem] Dream btw. Enigma2 Adapter
      Stefan-G last edited by
      Hi zusammen,
      Code für das Bouquet/Sender-Auslesen und wechseln hatte ich mal weiter oben gepostet. Hoffe, dass man das halbwegs einfach in den Adapter einbauen könnte.
      Viele Grüße
      Stefan
      @Stefan-G:
      habe mal eine Funktion zur Anzeige aller Bouquets und Kanäle und zum Umschalten implementiert:
      ! var parseString = require('xml2js').parseString;
      ! var request = require('request');
      ! var urlVUplus = 'http://192.168.1.101:82';
      ! var instanz = 'javascript.0'; instanz = instanz + '.';
      ! var pfad = 'XMLParsing'; pfad = pfad + '.'; // Pfad innerhalb der Instanz
      ! var debug = true;
      ! // VU+ Power-Status
      ! createState(pfad + 'VUplus.BouquetNames', 'init', {type: "string", name: "Names of Enigma bouquets", write:true, read:true});
      ! createState(pfad + 'VUplus.BouquetNumbers', 'init', {type: "string", name: "References of Enigma bouquets", write:true, read:true});
      ! createState(pfad + 'VUplus.NumberOfBouquets', 0, {type: "number", name: "How many bouquets are defined in Enigma", write:false, read:true});
      ! createState(pfad + 'VUplus.BouquetNumberCurrent', 0, {type: "number", name: "Number of selected Enigma bouquet", write:true, read:true});
      ! createState(pfad + 'VUplus.BouquetCurrentlySelected.BouquetName', 'init',{type: "string", name: "Name of currently selected Enigma bouquet", write:true, read:true});
      ! createState(pfad + 'VUplus.BouquetCurrentlySelected.BouquetReference', 'init',{type: "string", name: "Reference of currently selected Enigma bouquet", write:true, read:true});
      ! createState(pfad + 'VUplus.BouquetCurrentlySelected.ChannelNames', 'init',{type: "string", name: "Channel names of currently selected Enigma bouquet", write:true, read:true});
      ! createState(pfad + 'VUplus.BouquetCurrentlySelected.ChannelReferences', 'init',{type: "string", name: "Channel references of currently selected Enigma bouquet", write:true, read:true});
      ! createState(pfad + 'VUplus.ChannelReferenceCurrent', 'init', {type: "string", name: "Reference of selected channel", write:true, read:true});
      ! //example HHTP requests to obtain bouquet and channel list:
      ! //http://192.168.1.101:82/web/getservices
      ! //Favourites (TV):
      ! //http://192.168.1.101:82/web/getservices … %20bouquet
      ! //German Free SD
      ! //http://192.168.1.101:82/web/getservices ... %20bouquet
      ! //German Free HD
      ! //German HD+
      ! // This function collects all channel names (TV stations) and the respective
      ! // channel references and writes them into the respective states created before
      ! // (in calling function GetVUplusChannels()
      ! function GetVUplusBouquetChannels(strBouquetReference, iBouquetNumber) {
      ! var strAllChannelNames = '';
      ! var strAllChannelReferences = '';
      ! request(urlVUplus + '/web/getservices?sRef=' + strBouquetReference, function (error, response, body) {
      ! if (!error && response.statusCode == 200) {
      ! //if(debug){log("Body: " + body);}
      ! parseString(body, {
      ! explicitArray: false,
      ! mergeAttrs: true
      ! function (err, result) {
      ! if (err) {
      ! log("Fehler: " + err);
      ! } else {
      ! for (var j = 0; j < result.e2servicelist.e2service.length; j++) {
      ! var strSender = result.e2servicelist.e2service[j].e2servicename;
      ! var strService = result.e2servicelist.e2service[j].e2servicereference;
      ! if(debug){ log("Sender Nr. " + j + ": " + strSender + ", Service: " + strService);}
      ! strAllChannelNames = strAllChannelNames + strSender + ';';
      ! strAllChannelReferences = strAllChannelReferences + strService + ';';
      ! strAllChannelNames = strAllChannelNames.slice(0,strAllChannelNames.length-1); // cut away last ";"
      ! strAllChannelReferences = strAllChannelReferences.slice(0,strAllChannelReferences.length-1); // cut away last ";"
      ! if(debug){ log('All channels for Bouquet ' + iBouquetNumber +': ' + strAllChannelNames);}
      ! if(debug){ log('All channel references for Bouquet ' + iBouquetNumber + ': ' + strAllChannelReferences);}
      ! setState(instanz + pfad + 'VUplus.Bouquet' + iBouquetNumber + '.ChannelNames', strAllChannelNames);
      ! setState(instanz + pfad + 'VUplus.Bouquet' + iBouquetNumber + '.ChannelReferences', strAllChannelReferences);
      ! } else {
      ! if(debug){log(error);}
      ! // This function creates states for all bouquets with all info about the bouquet
      ! // e.g. channels (TV station) names and respective service references
      ! function CreateBouquetStates(NrOfBouquets) {
      ! for (var i = 0; i < NrOfBouquets; i++) {
      ! createState(pfad + 'VUplus.Bouquet' + i + '.BouquetName', 'init',{type: "string", name: "Name of Enigma bouquets number "+ i, write:true, read:true});
      ! createState(pfad + 'VUplus.Bouquet' + i + '.BouquetReference', 'init',{type: "string", name: "Reference of Enigma bouquets number "+ i, write:true, read:true});
      ! createState(pfad + 'VUplus.Bouquet' + i + '.ChannelNames', 'init',{type: "string", name: "Channel names of Enigma bouquets number "+ i, write:true, read:true});
      ! createState(pfad + 'VUplus.Bouquet' + i + '.ChannelReferences', 'init',{type: "string", name: "Channel references of Enigma bouquets number "+ i, write:true, read:true});
      ! // TODO: here code could be added which deletes states if more bouquet states have already been created befor than bouquets exit presently, e.g. this can happen if an bouquet has been deleted on the ENIGMA system
      ! // This function all available bouquets (TV station lists) for an ENIGMA system
      ! // and creates states for all bouquets filled with channel (TV station) and
      ! // respective service references for bouquets and channels
      ! function GetVUplusChannels() {
      ! request(urlVUplus + '/web/getservices', function (error, response, body) {
      ! mergeAttrs: true
      ! if (err) {
      ! } else {
      ! if(debug){ log("Anzahl Bouquets: " + result.e2servicelist.e2service.length);}
      ! var strBouquetName = '';
      ! var strBouquetReference = '';
      ! var strAllBouquetNames = '';
      ! var strAllBouquetNumbers = '';
      ! // create as many states as bouquets exist
      ! setState(instanz + pfad + 'VUplus.NumberOfBouquets', result.e2servicelist.e2service.length);
      ! CreateBouquetStates(result.e2servicelist.e2service.length);
      ! for (i = 0; i < result.e2servicelist.e2service.length; i++) {
      ! strBouquetName = result.e2servicelist.e2service__.e2servicename;
      ! strBouquetReference = result.e2servicelist.e2service__.e2servicereference.replace(/ /g, "%20").replace(/"/g, "%22");
      ! strAllBouquetNames = strAllBouquetNames + strBouquetName + ';';
      ! strAllBouquetNumbers = strAllBouquetNumbers + i + ';';
      ! if(debug){ log("Bouquet Nr. " + i + ": " + strBouquetName + ", Bouquet References: " + strBouquetReference);}
      ! setState(instanz + pfad + 'VUplus.Bouquet' + i + '.BouquetName', strBouquetName);
      ! setState(instanz + pfad + 'VUplus.Bouquet' + i + '.BouquetReference', strBouquetReference);
      ! GetVUplusBouquetChannels(strBouquetReference, i);
      ! strAllBouquetNames = strAllBouquetNames.slice(0,strAllBouquetNames.length-1); // cut away last ";"
      ! strAllBouquetNumbers = strAllBouquetNumbers.slice(0,strAllBouquetNumbers.length-1); // cut away last ";"
      ! if(debug){ log("All Bouquets: " + strAllBouquetNames);}
      ! if(debug){ log("All Bouquet numbers: " + strAllBouquetNumbers);}
      ! setState(instanz + pfad + 'VUplus.BouquetNames', strAllBouquetNames);
      ! setState(instanz + pfad + 'VUplus.BouquetNumbers', strAllBouquetNumbers);
      ! } else {
      ! on(instanz + pfad + 'VUplus.BouquetNumberCurrent', function(obj) {
      ! var ChannelNamesOfNewCurrentBouquet = getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.ChannelNames').val;
      ! var ChannelReferencesOfNewCurrentBouquet = getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.ChannelReferences').val;
      ! var FirstChannelReferenceOFNewBouquet = ChannelReferencesOfNewCurrentBouquet.slice(0, ChannelReferencesOfNewCurrentBouquet.indexOf(';'));
      ! if(debug){ log('Current bouquet number changed to: ' + obj.newState.val );}
      ! if(debug){ log('First channel in urrent bouquet: ' + ChannelNamesOfNewCurrentBouquet.slice(0, ChannelNamesOfNewCurrentBouquet.indexOf(';')) );}
      ! if(debug){ log('First channel reference in urrent bouquet: ' + FirstChannelReferenceOFNewBouquet);}
      ! // serch if the currently selected TC channel exists in the new selected bouquet
      ! if(ChannelReferencesOfNewCurrentBouquet.indexOf(getState(instanz + pfad + 'VUplus.ChannelReferenceCurrent').val) == -1) {
      ! if(debug){ log('Currently selected TC channel not found in previous bouquet, switching channel.');}
      ! setState(instanz + pfad + 'VUplus.ChannelReferenceCurrent', FirstChannelReferenceOFNewBouquet);
      ! // set new values for selected bouquet
      ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.BouquetName', getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.BouquetName').val);
      ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.BouquetReference', getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.BouquetReference').val);
      ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.ChannelNames', ChannelNamesOfNewCurrentBouquet);
      ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.ChannelReferences', ChannelReferencesOfNewCurrentBouquet);
      ! on(instanz + pfad + 'VUplus.ChannelReferenceCurrent', function(obj) {
      ! if(debug){ log('Chosen current channel reference: ' + obj.newState.val );}
      ! request(urlVUplus + '/api/zap?sRef=' + obj.newState.val, function (error, response, body) {
      ! //log("Body: " + body);
      ! mergeAttrs: true
      ! if (err) {
      ! } else {
      ! if(debug){ log(result);}
      ! } else {
      ! log(error);
      ! // create and fill all states for bouquets and station names
      ! GetVUplusChannels();____ ____Code mag natürlich noch optimierbar sein. Ich fände es cool, wenn es diese Funktion gleich im Adapter gäbe, oder gibt es einen Grund, das dort nicht zu implementieren? Kann dann so aussehen (roter Kasten):
      Die Widgets dafür sind dann wie folgt:__
      ! [{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.XMLParsing.VUplus.BouquetNumberCurrent","values":"{javascript.0.XMLParsing.VUplus.BouquetNumbers}","texts":"{javascript.0.XMLParsing.VUplus.BouquetNames}","height":"170","open":false,"gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"g_fixed":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"213px","width":"214px","height":"29px"},"widgetSet":"jqui"},{"tpl":"tplValueString","data":{"oid":"","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"Bouquet:","html_append":"","test_html":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"376px","top":"184px","color":"#ffffff","width":"186px","height":"20px","text-shadow":"rgba(0, 0, 0, 0.9) 3px 3px 4px","font-family":"Tahoma, Geneva, sans-serif"},"widgetSet":"basic"},{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.XMLParsing.VUplus.ChannelReferenceCurrent","values":"{javascript.0.XMLParsing.VUplus.BouquetCurrentlySelected.ChannelReferences}","texts":"{javascript.0.XMLParsing.VUplus.BouquetCurrentlySelected.ChannelNames}","height":"170","open":false,"gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"g_fixed":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"605px","top":"212px","width":"217px","height":"29px"},"widgetSet":"jqui"},{"tpl":"tplValueString","data":{"oid":"","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"Sender:","html_append":"","test_html":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"{javascript.0.XMLParsing.VUplus.Bouquet3.ChannelReferences}","texts":"{javascript.0.XMLParsing.VUplus.Bouquet3.ChannelNames}"},"style":{"left":"607px","top":"181px","color":"#ffffff","width":"186px","height":"20px","text-shadow":"rgba(0, 0, 0, 0.9) 3px 3px 4px","font-family":"Tahoma, Geneva, sans-serif"},"widgetSet":"basic"}] __Vielleicht mag das ja jemand einbauen (meine Git-/Adapter- Kenntnisse sind leider nicht gut genug).
      Ne Timer-Liste wäre auch cool. Vielleicht schafft das ja auch jemand schneller als ich… ;)____ `
      • Matten Matten
        Matten Matten last edited by
        @Stefan-G:
        Ne Timer-Liste wäre auch cool. Vielleicht schafft das ja auch jemand schneller als ich… 😉 `
        an der Timer Liste bin ich dran,
        so wie das automatische erkennen der HDD.
        Wie soll denn so Die Timerliste aussehen?
        dachte so:
        oder wollt ihr mehr Infos vom jeweiligen Timer?
        Matten Matten
          A Former User last edited by
          Datum und Uhrzeit wäre doch noch schön.
            Wiederholungsart für Timer (einmalig, wöchentlich, …) fänd ich auch cool, dann kann man sehen, ob's für ne Serie eine "Serientimer" ist oder nur einmalig aufgenommen wird. Dafür wäre dann auch die "Timer löschen" Funktion gut. Sonst sieht das doch schon super aus.
            • Matten Matten
              So Freunde der Sonne
              enigma2 Adapter V 1.1.0
              ist raus. Viel Spaß damit.
              1.1.0 (2018-10-26)
              (Matten-Matten) add Timer, max 8 Timer
              (Matten-Matten) add manually updating Timer states
              (Matten-Matten) optimizations
              (Matten-Matten) auto Check HDD (max.2 HDD)
              (Matten-Matten) add manually updating Enigma2 states
              (Matten-Matten) read the device information only at the adapter start
              (Matten-Matten) fixed hard disk (HDD) update Time every 30 sec.
              https://github.com/Matten-Matten/ioBroker.enigma2
              Matten Matten
                mikiline last edited by
                läuft 😉 sehr gut
                • N
                  NightWatcher last edited by
                  Hat den Adapter jemand unter Windows am laufen? Bei mir bringt er das System innerhalb kürzester Zeit zum Absturz (CPU geht auf 100%)
                  Ich habe dann mal kurz in den Quellcode schauen wollen… leider ist der noch sehr dürftig geschrieben.
                  @Matten-Matten: Wird der noch irgendwann optimiert? Ich meine, ich könnte das ja theoretisch machen, aber ich musste Ihn nach 5min sofort wieder deaktivieren, wegen o.g. Problem.
                  • Matten Matten
                    @NightWatcher:
                    @Matten-Matten: Wird der noch irgendwann optimiert? Ich meine, ich könnte das ja theoretisch machen, aber ich musste Ihn nach 5min sofort wieder deaktivieren, wegen o.g. Problem. `
                    ich teste den Adpter die ganze Zeit an meinem Rechner auch Win 10 ohne Probleme ?
                    das ist ja sehr eigenartig.
                    hast du ein anderen PC schon getestet?
                    Und ja meine Programierung ist geschuldet durch fehlende Kenntnisse schlecht. :oops: :oops: :oops:
                    die RAM Nutzung war bisher bei max 70% vom Adapter
                    Matten Matten
                    • N
                      70% ist schon extrem viel. Das kann schon erklären, wieso er bei mir in die komplette Auslastung geht, da dort noch ein SQL Server und diverse andere Größere Sachen laufen.
                      Ich würde vorschlagen, dass ich mal anfange, alles ein wenig in Schleifen zu bauen. Ich forke mir mal dein Repo und bin es dann bei mir an. Ich pushe dann später an dein gitrepo. Dann hast du auch keine Beschränkung (z.B. auf die Timerliste) und ich kann den Fehler eher finden.
                      • Matten Matten
                        sorry 70 mb meine ich
                        • Matten Matten
                          @NightWatcher:
                          Ich würde vorschlagen, dass ich mal anfange, alles ein wenig in Schleifen zu bauen. Ich forke mir mal dein Repo und bin es dann bei mir an. Ich pushe dann später an dein gitrepo. Dann hast du auch keine Beschränkung (z.B. auf die Timerliste) und ich kann den Fehler eher finden. `
                          Das hört sich Super an!
                          Schon mal riesen Dank dafür :!:
                          das mit den Schleifen hatte ich auch schon im sinn, aber keine Ahnung wie man das in java umsetzt :oops:
                          und hab mich eben so beholfen. Sry.
                          Matten Matten
                          • wendy2702
                            wendy2702 last edited by
                            habe und hatte aus diversen Gründen aktuell nur wenig Zeit deshalb schnell die Frage.
                            Habe noch eine Uralt Version 0.2.0 des Adapter laufen.
                            Kann ich die neue einfach drüber installieren oder besser löschen und neu installieren?
                            Danke und Gruß
                            Mirko
                            • Matten Matten
                              @wendy2702:
                              Danke und Gruß
                              Mirko `
                              kannst du drüber installieren, kann sein das aber ein SetObjekt Fehler kommt. besser den Adapter löschen dann von git aktualisieren und den Adapter neu erstellen und einrichten.
                              Matten Matten
                              • Matten Matten
                                wer mit der version 1.1.0 probleme hat hier noch mal die V 1.0.0
                                3476_iobroker.enigma2-master_v1.0.0.zip
                                Matten Matten
                                • N
                                  Habe mal auf die schnelle den Code "etwas" aufgeräumt.
                                  Aus 2400 Zeilen sind nun 1200 Zeilen geworden.
                                  https://github.com/Bjoern3003/ioBroker.enigma2
                                  Nun läuft er auch bei mir mit nur noch 30MB Speicher.
                                  PS: Die Timerliste Heisst im Objektbaum nun nicht Timer.TimerX Sondern Timer.X (So kann man später ggfl. das Array besser durchlaufen, da es nen sauberer Index ist).
                                  Bitte testet doch mal meine Version. Habe bis auf CodeCleaning noch nichts weiter gemacht mit dem Adapter 😉
                                  • rantanplan
                                    rantanplan last edited by
                                    @NightWatcher:
                                    PS: Die Timerliste Heisst im Objektbaum nun nicht Timer.TimerX Sondern Timer.X (So kann man später ggfl. das Array besser durchlaufen, da es nen sauberer Index ist). `
                                    Kann das nicht zu Problemen führen?
                                    "Bezeichnung.x" scheint in ioBroker besonders behandelt zu werden.
                                    Z.B. Adaptername.0
                                    • N
                                      Es heisst ja Adaptername.X.Timer.X.
                                      • hg6806
                                        hg6806 Most Active last edited by
                                        Moin!
                                        Habe auch die 1.1.0 installiert und das Button Script deaktiviert.
                                        Leider funktioniert der Paus/Play Button wieder nicht.
                                        Und wenn ich bei Remote Control den Code 207 einsetze, passiert auch nichts.
                                        Wahrscheinlich muss da noch irgendwie das RCU Advanced da rein.
                                        Dann noch einmal die Frage welches Widget ihr für die Buttons benutzt, da bei mir mit dem hqwidget On/Off als Taster oft ein Longpress erkannt wird.
                                        Danke!
                                          Bei mir ist das Objekt STANDBY nicht richtig. Receiver läuft und es wird true angezeigt. Sollte doch eigentlich false sein wenn ich Fernseh schaue?
                                          • O
                                            oetti last edited by
                                            bei mir "schmeisst" der Adapter aktuell folgende Fehlermeldungen. Ich habe die letzte Version aus dem Git installiert und einen Vu+ Duo2 Receiver.
                                            Muss ich noch irgendwelche Module nachinstallieren?
                                            host.iobroker	2018-10-27 18:04:24.354	info	Restart adapter system.adapter.enigma2.0 because enabled
                                            host.iobroker	2018-10-27 18:04:24.354	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
                                            Caught	2018-10-27 18:04:24.354	error	by controller[0]: at Timer.listOnTimeout (timers.js:290:5)
                                            Caught	2018-10-27 18:04:24.354	error	by controller[0]: at tryOnTimeout (timers.js:323:5)
                                            Caught	2018-10-27 18:04:24.354	error	by controller[0]: at ontimeout (timers.js:498:11)
                                            Caught	2018-10-27 18:04:24.354	error	by controller[0]: at Timeout.checkStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:742:14)
                                            Caught	2018-10-27 18:04:24.354	error	by controller[0]: at Object.probe (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/ping/lib/ping-sys.js:38:17)
                                            Caught	2018-10-27 18:04:24.354	error	by controller[0]: at Object.probe (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/ping/lib/ping-promise.js:66:17)
                                            Caught	2018-10-27 18:04:24.353	error	by controller[0]: TypeError: Cannot read property 'on' of undefined
                                            enigma2.0	2018-10-27 18:04:24.280	info	terminating
                                            enigma2.0	2018-10-27 18:04:23.778	error	at Timer.listOnTimeout (timers.js:290:5)
                                            enigma2.0	2018-10-27 18:04:23.778	error	at tryOnTimeout (timers.js:323:5)
                                            enigma2.0	2018-10-27 18:04:23.778	error	at ontimeout (timers.js:498:11)
                                            enigma2.0	2018-10-27 18:04:23.778	error	at Timeout.checkStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:742:14)
                                            enigma2.0	2018-10-27 18:04:23.778	error	at Object.probe (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/ping/lib/ping-sys.js:38:17)
                                            enigma2.0	2018-10-27 18:04:23.778	error	at Object.probe (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/ping/lib/ping-promise.js:66:17)
                                            enigma2.0	2018-10-27 18:04:23.778	error	TypeError: Cannot read property 'on' of undefined
                                            enigma2.0	2018-10-27 18:04:23.778	error	uncaught exception: Cannot read property 'on' of undefined
                                            oetti
                                            739
                                            190331
