Bekomme Noble nicht richtig installiert.
Aktuelle Fehlermeldung beim starten des Zigbee Adapters:
host.ioBroker-Pi3 2018-10-26 14:02:38.958 info Restart adapter system.adapter.zigbee.0 because enabled host.ioBroker-Pi3 2018-10-26 14:02:38.958 error instance system.adapter.zigbee.0 terminated with code 1 () Caught 2018-10-26 14:02:38.958 error by controller[0]: at Object.Module._extensions..js (module.js:664:10) Caught 2018-10-26 14:02:38.958 error by controller[0]: at Module._compile (module.js:653:30) Caught 2018-10-26 14:02:38.958 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36) Caught 2018-10-26 14:02:38.958 error by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44) Caught 2018-10-26 14:02:38.957 error by controller[0]: at require (internal/module.js:11:18) Caught 2018-10-26 14:02:38.957 error by controller[0]: at Module.require (module.js:597:17) Caught 2018-10-26 14:02:38.957 error by controller[0]: at Function.Module._load (module.js:498:3) Caught 2018-10-26 14:02:38.957 error by controller[0]: at tryModuleLoad (module.js:506:12) Caught 2018-10-26 14:02:38.957 error by controller[0]: at Module.load (module.js:566:32) Caught 2018-10-26 14:02:38.957 error by controller[0]: at Object.Module._extensions..node (module.js:682:18) Caught 2018-10-26 14:02:38.956 error by controller[0]: the module (for instance, using `npm rebuild` or `npm install`). Caught 2018-10-26 14:02:38.956 error by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing Caught 2018-10-26 14:02:38.956 error by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires Caught 2018-10-26 14:02:38.956 error by controller[0]: was compiled against a different Node.js version using Caught 2018-10-26 14:02:38.956 error by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node' Caught 2018-10-26 14:02:38.956 error by controller[0]: ^ Caught 2018-10-26 14:02:38.955 error by controller[0]: throw e Caught 2018-10-26 14:02:38.955 error by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88 host.ioBroker-Pi3 2018-10-26 14:02:37.949 info instance system.adapter.zigbee.0 started with pid 929</anonymous>npm im Zigbee Ordner Ergebniss:
pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.zigbee $ npm rebuild debug@3.2.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/debug ms@2.1.1 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/msnpm im /opt/iobroker/node_modules/serialport/node_modules/bindings
keine Reaktionnpm rebuild im /opt/iobroker/node_modules/serialport/build/Release
pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport/build/Release $ npm rebuild bindings@1.3.0 /opt/iobroker/node_modules/serialport/node_modules/bindings debug@3.2.5 /opt/iobroker/node_modules/serialport/node_modules/debug ms@2.1.1 /opt/iobroker/node_modules/serialport/node_modules/ms nan@2.11.0 /opt/iobroker/node_modules/serialport/node_modules/nan prebuild-install@4.0.0 /opt/iobroker/node_modules/serialport/node_modules/prebuild-install minimist@1.2.0 /opt/iobroker/node_modules/serialport/node_modules/minimist prompt-list@3.2.0 /opt/iobroker/node_modules/serialport/node_modules/prompt-list safe-buffer@5.1.2 /opt/iobroker/node_modules/serialport/node_modules/safe-bufferIm Zigbee Adapter ist nicht der USB anschluss zur auswahl vorhanden somit bleibt der Bursche rot
Fürhre das rebuild mal eher in
aus
Dann kommt
pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport $ npm rebuild bindings@1.3.0 /opt/iobroker/node_modules/serialport/node_modules/bindings debug@3.2.5 /opt/iobroker/node_modules/serialport/node_modules/debug ms@2.1.1 /opt/iobroker/node_modules/serialport/node_modules/ms nan@2.11.0 /opt/iobroker/node_modules/serialport/node_modules/nan prebuild-install@4.0.0 /opt/iobroker/node_modules/serialport/node_modules/prebuild-install minimist@1.2.0 /opt/iobroker/node_modules/serialport/node_modules/minimist prompt-list@3.2.0 /opt/iobroker/node_modules/serialport/node_modules/prompt-list safe-buffer@5.1.2 /opt/iobroker/node_modules/serialport/node_modules/safe-bufferAber der Fehler im Log ist immer noch da und adapter bleibt rot!
dann such mal ob in node_modules des Adapters selbst ggf nochmal ein serialport drin ist
Nichts zu finden. Nur debug und ms
Auch eine neuinstallation von zigbee hat nix gebracht.
ich meine in /opt/iobroker/node_modules
Da gibts nur ein serialport
Dann kann ich nur sagen: lösch den serialport malund installiere adapter nochmal. Dann wäre ich am Ende der Ideen
öhmm also den Ordner Serialport löschen und dann zigbee adapter neuinstallieren?
installiert der dan den serialport wieder mit?
Gleich fliegt das Ding aus dem Fenster... Jetzt geht wieder gar nix... nach folgender Aktion:
sudo apt-get update sudo apt-get install build-essential gitcd /opt/iobroker npm install iobroker.Zigbeehttp://www.iobroker.net/docu/?page_id=5510&lang=de
Jetzt startet io nicht mehr….
pi@ioBroker-Pi3:~ $ iobroker start module.js:550 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (module.js:548:15) at Function.Module._load (module.js:475:25) at Function.Module.runMain (module.js:694:10) at startup (bootstrap_node.js:204:16) at bootstrap_node.js:625:3 -
Ich habe ein Backup eingespielt, und die ganzen rebuilds nochmal gemacht, diesmal immer den betreffenden adapter vorher ausgeschaltet.
Jetzt läuft es wieder und siehe da:
RADAR erkennt endlich auch meine beiden BT Anhänger und auch diverse Unknown Devices
Noble wird auch als aktiv angezeigt und ich bin auf
Node.js: v8.12.0
NPM: 6.4.1
Sind die Versionen OK?
PUH was ein Krampf wird Zeit für eine Virtuelle Umgebung um mal eben was zu testen :lol:
Danke an apollon77
Komischer Tag heute
Ja die Versionen sind perfekt so
