    4. Xiaomi Tischlampe Adapter
      muellerra last edited by
      ich wollte es gerade noch über den yeelight Adapter versuchen, aber bei diesem komme ich gar nicht auf die Seite der Adapterkonfiguration
      Der log sieht folgendermaßen aus:
      mihome-lamp.0	2018-03-27 15:59:19.369	debug	system.adapter.admin.0: logging true
      mihome-lamp.0	2018-03-27 15:59:19.040	debug	check = ffffffffffffffffffffffffffffffff
      mihome-lamp.0	2018-03-27 15:59:19.040	debug	data =
      mihome-lamp.0	2018-03-27 15:59:19.039	debug	lenght = 00b0
      mihome-lamp.0	2018-03-27 15:59:19.039	debug	Token = 00000000000000000000000000000000
      mihome-lamp.0	2018-03-27 15:59:19.038	debug	Receive <<< Helo <<< 213100b000000000039cc73b000002d3ffffffffffffffffffffffffffffffff
      mihome-lamp.0	2018-03-27 15:59:19.026	debug	213100b000000000039cc73b000002d397fb4f2efe747fa8be77f0ebb7b4a8d417f54bbdd1828c0ae0ecd9d306e9d5e2e3b06f3880b35fa7a19c7c84b5e2d2a9e83146fc8ecc5f2002f33a72d373ee9d688fec5711d5619b74fdf8c190df53af941faa3
      mihome-lamp.0	2018-03-27 15:59:19.026	debug	Send >>> {"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]} >>> 213100b000000000039cc73b000002d397fb4f2efe747fa8be77
      mihome-lamp.0	2018-03-27 15:59:19.023	debug	{"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]}
      mihome-lamp.0	2018-03-27 15:59:19.018	info	Connected
      mihome-lamp.0	2018-03-27 15:59:19.018	debug	check = 00000000000000000000000000000000
      mihome-lamp.0	2018-03-27 15:59:19.017	debug	data =
      mihome-lamp.0	2018-03-27 15:59:19.017	debug	lenght = 0020
      mihome-lamp.0	2018-03-27 15:59:19.017	debug	Token = 00000000000000000000000000000000
      mihome-lamp.0	2018-03-27 15:59:19.014	debug	Receive <<< Helo <<< 2131002000000000039cc73b000002d300000000000000000000000000000000
      mihome-lamp.0	2018-03-27 15:59:18.895	debug	server started on 0.0.0.0:53423
      mihome-lamp.0	2018-03-27 15:59:18.853	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.mihome-lamp, node: v6.11.5
      • Meistertr
        @muellerra:
        ok ich hab den fehler gefunden, scheinbar wird der token nicht mehr mit gesendet. ich werde das programm die Tage umschreiben, dass in der config ein token eingegeben werden kann, dieser muss wie auch bei dem Sauger mehr oder weniger aufwendig ermittelt werden.
          Danke für die schnelle Rückmeldung!
            derBonsaii last edited by
            Tach 🙂
            Gibt es hier schon ne Lösung?
            Der Adapter auf github ist ja noch der alte ohne Tokeneingabe
            MfG
            • Meistertr
              @derBonsaii:
              Tach 🙂
              MfG ` Bitte ein issue auf git anlegen, hab es total vergessen.
              Gesendet von meinem Handy
                K~~@Meistertr:~~
                @derBonsaii:
                Tach 🙂
                Gesendet von meinem Handy `
                Kein Problem - wurde angelegt 🙂
                  Ceel last edited by
                  Hallo habe auch diese LED Desk Lamp von Xiaomi:
                  https://www.gearbest.com/table-lamps/pp … GearbestDE
                  habe den Token und die IP eingetragen, bekomme auch einen true bei connected aber leider kann man sie nicht schalten!
                  • Meistertr
                    @Ceel:
                    habe den Token und die IP eingetragen, bekomme auch einen true bei connected aber leider kann man sie nicht schalten! ` Versuch mal den yeelight-2 Adapter, vorher mit der yeelight App den LAN Modus wie in der Adapter readme beschrieben freischalten.
                      Ceel last edited by
                      Welchen Port müsste ich einstellen?
                      • Meistertr
                        @Ceel:
                        Welchen Port müsste ich einstellen? ` Über die suchfunktion sollte die Lampe gefunden werden. Ansonsten
                          Ceel last edited by
                          Hat alles geklappt danke!
                          • V4n1X
                            V4n1X last edited by
                            Huch, da wiederbelebe ich den Thread mal.
                            Also die Lampe habe ich auch, Verbindung im Adapter ist grün, Token ist drin, IP ist drin.
                            Bekomme auch Infos in den Objekten allerdings keine Werte, wie true etc… Nur bei der connection bekomme ich true.
                            Ähnliches hat hier jemand glaube ich schonmal geäußert. Es ist die besagte Philips Lamp, diese lässt sich meines Wissens, (ich habs auch grad nochmal überprüft, nicht in der Yeelight App einbinden)
                            ! mihome-lamp.0 2018-11-13 16:14:31.699 debug check = ffffffffffffffffffffffffffffffff
                            ! mihome-lamp.0 2018-11-13 16:14:31.699 debug data =
                            ! mihome-lamp.0 2018-11-13 16:14:31.699 debug lenght = 00b0
                            ! mihome-lamp.0 2018-11-13 16:14:31.698 debug Token = 00000000000000000000000000000000
                            ! mihome-lamp.0 2018-11-13 16:14:31.697 debug Receive <<< Helo <<< 213100b00000000002c75e670000a8ceffffffffffffffffffffffffffffffff
                            ! mihome-lamp.0 2018-11-13 16:14:31.685 debug 213100b00000000002c75e670000a8cef8ee2a052f78855efb72a16ea030c38f17f54bbdd1828c0ae0ecd9d306e9d5e2e3b06f3880b35fa7a19c7c84b5e2d2a9e83146fc8ecc5f2002f33a72d373ee9d688fec5711d5619b74fdf8c190df53af941faa35
                            ! mihome-lamp.0 2018-11-13 16:14:31.685 debug Send >>> {"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]} >>> 213100b00000000002c75e670000a8cef8ee2a052f78855efb72a
                            ! mihome-lamp.0 2018-11-13 16:14:31.685 debug {"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]}
                            ! mihome-lamp.0 2018-11-13 16:14:31.685 info Connected
                            ! mihome-lamp.0 2018-11-13 16:14:31.685 debug check = 00000000000000000000000000000000
                            ! mihome-lamp.0 2018-11-13 16:14:31.685 debug data =
                            ! mihome-lamp.0 2018-11-13 16:14:31.684 debug lenght = 0020
                            ! mihome-lamp.0 2018-11-13 16:14:31.684 debug Token = 00000000000000000000000000000000
                            ! mihome-lamp.0 2018-11-13 16:14:31.683 debug Receive <<< Helo <<< 213100200000000002c75e670000a8ce00000000000000000000000000000000
                            ! mihome-lamp.0 2018-11-13 16:14:31.657 debug server started on 0.0.0.0:53423
                            ! mihome-lamp.0 2018-11-13 16:14:31.657 info starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.mihome-lamp, node: v8.15.0
                            Wäre cool wenn es hier ein Update oder ein Hinweis gibt, wie man das Ganze doch zum laufen bekommt.
                            MfG
                            • Deanna4711
                              Deanna4711 last edited by
                              Ich hänge mich mal dran. Auch ich habe die Philips Eye Care Lampe. Adapter ist installiert, grün, soweit alles gut. Ich habe auch nach der Staubsauger Anleitung (https://github.com/ioBroker/ioBroker.mi … /README.md) versucht den Token auszulesen, allerdings wird mir im Ausgabefeld keinToken angezeigt.
                              Debug Meldung:
                              mihome-lamp.0	2019-01-15 20:40:10.513	debug	check = ffffffffffffffffffffffffffffffff
                              mihome-lamp.0	2019-01-15 20:40:10.512	debug	data =
                              mihome-lamp.0	2019-01-15 20:40:10.512	debug	lenght = 00b0
                              mihome-lamp.0	2019-01-15 20:40:10.511	debug	Token = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:40:10.509	debug	Receive <<< Helo <<< 213100b00000000006b45778001ad44bffffffffffffffffffffffffffffffff
                              mihome-lamp.0	2019-01-15 20:40:10.491	debug	213100b00000000006b45778001ad44bc4ed06f4810c53cfddccffdb6db1da4417f54bbdd1828c0ae0ecd9d306e9d5e2e3b06f3880b35fa7a19c7c84b5e2d2a9e83146fc8ecc5f2002f33a72d373ee9d688fec5711d5619b74fdf8c190df53af941faa35
                              mihome-lamp.0	2019-01-15 20:40:10.491	debug	Send >>> {"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]} >>> 213100b00000000006b45778001ad44bc4ed06f4810c53cfddccf
                              mihome-lamp.0	2019-01-15 20:40:10.491	debug	{"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]}
                              mihome-lamp.0	2019-01-15 20:40:10.491	debug	check = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:40:10.490	debug	data =
                              mihome-lamp.0	2019-01-15 20:40:10.490	debug	lenght = 0020
                              mihome-lamp.0	2019-01-15 20:40:10.490	debug	Token = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:40:10.489	debug	Receive <<< Helo <<< 213100200000000006b45778001ad44b00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:50.385	debug	check = ffffffffffffffffffffffffffffffff
                              mihome-lamp.0	2019-01-15 20:39:50.385	debug	data =
                              mihome-lamp.0	2019-01-15 20:39:50.385	debug	lenght = 00b0
                              mihome-lamp.0	2019-01-15 20:39:50.385	debug	Token = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:50.383	debug	Receive <<< Helo <<< 213100b00000000006b45778001ad437ffffffffffffffffffffffffffffffff
                              mihome-lamp.0	2019-01-15 20:39:50.368	debug	213100b00000000006b45778001ad4374ed75c7a53372788186f797bb21ab57f17f54bbdd1828c0ae0ecd9d306e9d5e2e3b06f3880b35fa7a19c7c84b5e2d2a9e83146fc8ecc5f2002f33a72d373ee9d688fec5711d5619b74fdf8c190df53af941faa35
                              mihome-lamp.0	2019-01-15 20:39:50.367	debug	Send >>> {"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]} >>> 213100b00000000006b45778001ad4374ed75c7a53372788186f7
                              mihome-lamp.0	2019-01-15 20:39:50.367	debug	{"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]}
                              mihome-lamp.0	2019-01-15 20:39:50.366	debug	check = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:50.366	debug	data =
                              mihome-lamp.0	2019-01-15 20:39:50.365	debug	lenght = 0020
                              mihome-lamp.0	2019-01-15 20:39:50.365	debug	Token = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:50.361	debug	Receive <<< Helo <<< 213100200000000006b45778001ad43700000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:30.410	debug	check = ffffffffffffffffffffffffffffffff
                              mihome-lamp.0	2019-01-15 20:39:30.410	debug	data =
                              mihome-lamp.0	2019-01-15 20:39:30.410	debug	lenght = 00b0
                              mihome-lamp.0	2019-01-15 20:39:30.410	debug	Token = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:30.410	debug	Receive <<< Helo <<< 213100b00000000006b45778001ad423ffffffffffffffffffffffffffffffff
                              mihome-lamp.0	2019-01-15 20:39:30.396	debug	213100b00000000006b45778001ad42306a0d9494aaf3d523c6d21362d439fd217f54bbdd1828c0ae0ecd9d306e9d5e2e3b06f3880b35fa7a19c7c84b5e2d2a9e83146fc8ecc5f2002f33a72d373ee9d688fec5711d5619b74fdf8c190df53af941faa35
                              mihome-lamp.0	2019-01-15 20:39:30.396	debug	Send >>> {"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]} >>> 213100b00000000006b45778001ad42306a0d9494aaf3d523c6d2
                              mihome-lamp.0	2019-01-15 20:39:30.396	debug	{"id":400,"method":"get_prop","params":["power","bright","notifystatus","ambstatus","ambvalue","eyecare","scene_num","bls","dvalue"]}
                              mihome-lamp.0	2019-01-15 20:39:30.396	info	Connected
                              mihome-lamp.0	2019-01-15 20:39:30.396	debug	check = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:30.396	debug	data =
                              mihome-lamp.0	2019-01-15 20:39:30.396	debug	lenght = 0020
                              mihome-lamp.0	2019-01-15 20:39:30.396	debug	Token = 00000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:30.396	debug	Receive <<< Helo <<< 213100200000000006b45778001ad42300000000000000000000000000000000
                              mihome-lamp.0	2019-01-15 20:39:30.306	debug	server started on 0.0.0.0:53423
                              mihome-lamp.0	2019-01-15 20:39:30.306	info	starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.mihome-lamp, node: v8.15.0
                              • janks
                                janks last edited by
                                Ich klinke mich mal hier ein, da ich das oben stehende Problem auch habe.
                                Adapter ist grün und der einzige Wert den Ich erhalte ist der connected "true".
                                (habe auch easybulb versucht, leider derselbe Effekt)
                                Token ist drin und IP ist auch eingetragen, über die Suche findet er nichts.
                                Welcher Port muss eingetragen werden, habe verschiedene Versucht , da ich in anderen Anleitungen gelesen habe, das die Ports nicht ganz klar sind.
                                Ich habe auch die Schreibtischlampe:
                                Schreibtischlampe
                                Viele Grüße und schon mal Danke für die Hilfe!
                                Meistertr 1 Reply Last reply Reply Quote 0
                                • Meistertr
                                  Meistertr Developer @janks last edited by
                                  @janks hast du mal den yeelight adapter probiert ? versuch mal mit deinem Handy die Yeelight app aus ob die lampe da erkannnt wird
                                  • janks
                                    Super, Danke das hat funktioniert. Auch hier muss man den LAN modus in der App aktivieren, dann lief alles! spitze!
                                    Den Namen musste ich auch anpassen, der wurde nicht aus der App übernommen.
                                    Nochmals vielen Dank für die schnelle Hilfe!
                                      Pahan last edited by
                                      gab es hier kürzlich ein Update? Ich habe auch die Desk Lamp 1S und bekomme diese jedoch nicht zum Laufen.
                                      Ich sehe weder den Port, noch den Token, noch kann ich in der Yeelight APP den Lan-Modus aktivieren.
                                      32
                                      7783
