    4. [Problem] Dream btw. Enigma2 Adapter
      Jan1 last edited by
      Das ist ne gute Frage, da die älteren Versionen mit dem Button Script noch liefen. Jetzt steht das im Log und meine Dream hat alle paar Sekunden Zahnräder eingeblendet und reagiert erst wieder, wenn ich den Adapter ausschalte. Neustart der Instanz ist eh nicht nötig, da die von selbst alle paar Sekunden passend zu den Zahnrädern neus tartet.
      host.raspberrypi	2018-10-29 15:46:57.962	error	instance system.adapter.enigma2.0 terminated with code 6 (uncaught exception)
      Caught	2018-10-29 15:46:57.962	error	by controller[0]: at Timer.listOnTimeout (timers.js:290:5) errno: -24, code: 'EMFILE', syscall: 'uv_resident_set_memory' }
      Caught	2018-10-29 15:46:57.962	error	by controller[0]: at tryOnTimeout (timers.js:323:5)
      Caught	2018-10-29 15:46:57.962	error	by controller[0]: at ontimeout (timers.js:498:11)
      Caught	2018-10-29 15:46:57.962	error	by controller[0]: at Timeout.reportStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5006:27)
      Caught	2018-10-29 15:46:57.961	error	by controller[0]: at process.memoryUsage (internal/process.js:99:5)
      Caught	2018-10-29 15:46:57.960	error	by controller[0]: { Error: EMFILE: too many open files, uv_resident_set_memory
      enigma2.0	2018-10-29 15:46:56.158	info	enigma2 Verbunden!
      enigma2.0	2018-10-29 15:46:55.958	error	at Timer.listOnTimeout (timers.js:290:5)
      enigma2.0	2018-10-29 15:46:55.958	error	at tryOnTimeout (timers.js:323:5)
      enigma2.0	2018-10-29 15:46:55.958	error	at ontimeout (timers.js:498:11)
      enigma2.0	2018-10-29 15:46:55.958	error	at Timeout.reportStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5006:27)
      enigma2.0	2018-10-29 15:46:55.958	error	at process.memoryUsage (internal/process.js:99:5)
      enigma2.0	2018-10-29 15:46:55.958	error	Error: EMFILE: too many open files, uv_resident_set_memory
      enigma2.0	2018-10-29 15:46:55.958	error	uncaught exception: EMFILE: too many open files, uv_resident_set_memory
      Außerdem steht das dann noch im Log und das im Sekundentakt:
      enigma2.0	2018-10-29 15:50:58.161	info	enigma2: 192.168.100.15:84 ist nicht erreichbar!
      enigma2.0	2018-10-29 15:50:58.157	info	enigma2 Verbunden!
      So die Frage ist jetzt immer noch warum lässt sich der Adapter nicht deinstallieren?
      • Matten Matten
        Matten Matten last edited by
        du musst den enigma2 Ordner manuell löschen. wie hoch hast du die Abfrage Intervalle eingestellt? ich würde nicht weniger als 3s pollen lassen.
        Matten Matten
        • Matten Matten
          @Jan1:
          So die Frage ist jetzt immer noch warum lässt sich der Adapter nicht deinstallieren? `
          Dann scheint er warum auch immer keine gute verbindung zum Receiver zu haben…
            FoxMulder last edited by
            Bei mir genauso wie bei Jan1 . Immer Pinguin ( Zahnräder ersatz ) am laufen .
            Nur nach einer Deaktivierung des Adapters , ist ruhe .
            Kann aber auch an der schwachen DM8000 liegen ?
            Gesendet von meinem SM-G950F mit Tapatalk
            • Matten Matten
              @FoxMulder:
              Gesendet von meinem SM-G950F mit Tapatalk `
              dann am besten mal das polling hochsetzen auf alle 8s oder so und dann schauen.
                Jan1 last edited by
                Der Pi hängt im LAN und alles andere hat eine sehr gute Verbindung zur Dream. Polling auf 15s ändert nur das Intervall der Zahnräder an der Dream :lol:
                host.raspberrypi	2018-10-29 16:42:17.221	info	Restart adapter system.adapter.enigma2.0 because enabled
                host.raspberrypi	2018-10-29 16:42:17.221	error	instance system.adapter.enigma2.0 terminated with code 6 (uncaught exception)
                host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at Timer.listOnTimeout (timers.js:290:5) errno: -24, code: 'EMFILE', syscall: 'uv_resident_set_memory' }
                host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at tryOnTimeout (timers.js:323:5)
                host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at ontimeout (timers.js:498:11)
                host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at Timeout.reportStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5006:27)
                host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at process.memoryUsage (internal/process.js:99:5)
                host.raspberrypi	2018-10-29 16:42:17.219	error	Caught by controller[0]: { Error: EMFILE: too many open files, uv_resident_set_memory
                enigma2.0	2018-10-29 16:42:15.452	error	Error: EMFILE: too many open files, uv_resident_set_memory at process.memoryUsage (internal/process.js:99:5) at Timeout.reportStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-con
                enigma2.0	2018-10-29 16:42:15.451	error	uncaught exception: EMFILE: too many open files, uv_resident_set_memory
                enigma2.0	2018-10-29 16:42:14.071	info	enigma2: 192.168.100.15:84 ist nicht erreichbar!
                enigma2.0	2018-10-29 16:42:13.548	info	enigma2 Verbunden!
                enigma2.0	2018-10-29 16:42:10.925	info	enigma2: 192.168.100.15:84 ist nicht erreichbar!
                enigma2.0	2018-10-29 16:42:00.744	info	enigma2 Verbunden!
                enigma2.0	2018-10-29 16:42:00.448	info	starting Timercheck every null ms
                enigma2.0	2018-10-29 16:42:00.441	info	starting Polling every 15000 ms
                enigma2.0	2018-10-29 16:42:00.409	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.enigma2, node: v8.12.0
                • Matten Matten
                  sonst erteinmal auf V 1.0.0 zurück tanzen :roll:
                  viewtopic.php?f=17&t=1739&start=400
                    Jan1 last edited by
                    Wie geschrieben, die alte 0.7… lief eigentlich. Für die neueren Versionen wird da Button Script nicht mehr benötigt, oder?
                    • Matten Matten
                      @Jan1:
                      Vielleicht liegt es auch irgendwie am auslesen der Timer…
                      • Matten Matten
                        @Jan1:
                        Wie geschrieben, die alte 0.7… lief eigentlich. Für die neueren Versionen wird da Button Script nicht mehr benötigt, oder? `
                        ab 1.0.0. benötigt man kein Button Script mehr.
                        Probiere mal bitte die 1.0.0 aus, da ist die Timer geschichte noch nicht mit drin.
                          Jan1 last edited by
                          Wenn ich das zip entpacke und \node_modules kopiere, lässt sich das nicht uploaden und eine Instanz kann ich auch nicht anlegen. Hast bitte ein Github Link dafür?
                          • Matten Matten
                            @Jan1:
                            Wenn ich das zip entpacke und \node_modules kopiere, lässt sich das nicht uploaden und eine Instanz kann ich auch nicht anlegen. Hast bitte ein Github Link dafür? `
                            hast du den Ordner io<u>B</u>roker.enigma2 in io<u>b</u>roker.enigma2 umbenannt?
                              Jan1 last edited by
                              Na das musst erst mal sehen, bringt aber auch nur Fehler im Log. Allerdings bleibt der Adapter dann auch aus und startet nicht dauern neu.
                              host.raspberrypi	2018-10-29 17:21:40.319	info	Restart adapter system.adapter.enigma2.0 because enabled
                              host.raspberrypi	2018-10-29 17:21:40.319	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
                              host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
                              host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                              host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                              host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                              host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
                              host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at Parser.emit (events.js:211:7)
                              host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at emitOne (events.js:116:13)
                              host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at Parser. <anonymous>(/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                              host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:203:21
                              host.raspberrypi	2018-10-29 17:21:40.317	error	Caught by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:322:86)
                              host.raspberrypi	2018-10-29 17:21:40.316	error	Caught by controller[0]: TypeError: Cannot read property '1' of undefined
                              enigma2.0	2018-10-29 17:21:39.858	error	TypeError: Cannot read property '1' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:322:86) at /opt/iobroker/node_modules/iobroker.enigma2/enigm
                              enigma2.0	2018-10-29 17:21:39.857	error	uncaught exception: Cannot read property '1' of undefined</anonymous>
                              • Matten Matten
                                @Jan1:
                                ok da muss ich noch mal schauen…
                                  Jan1 last edited by
                                  Wenn's bei anderen läuft, mach Dir wegen mir keine Mühe. Wollte eh nur was probieren und das hätte mit dem Adapter etwas leichter und zuverlässiger funktionieren können als über den Harmony, da es übers LAN läuft und nicht über IR.
                                  • Matten Matten
                                    @Jan1:
                                    Wenn's bei anderen läuft, mach Dir wegen mir keine Mühe. Wollte eh nur was probieren und das hätte mit dem Adapter etwas leichter und zuverlässiger funktionieren können als über den Harmony, da es übers LAN läuft und nicht über IR. `
                                    3476_iobroker.enigma2-master_v0.4.3.zip
                                    müsste die letzte version mit dem Buttonscript sein. wenn du das damit noch einmal versuchen möchtest
                                    Matten Matten
                                      Jan1 last edited by
                                      OK danke, werd dann nochmal ein Versuch starte 😉
                                      Diese Version läuft bei mir einwandfrei, da verträgt sich wohl was bei der neuen mit dem aktuellen Dream OS was nicht.
                                        A Former User last edited by
                                        Nö, hier drei 525 Combo mit aktuellem DreamOS.
                                        Läuft perfekt.
                                          Turbo last edited by
                                          Ich hatte auch den Fehler mit Code 22 beim deinstallieren. Der Adapter startete bei mir auch laufend und hängte das gesamte System auf…
                                          Habe danach in den Objekten den Ordner enigma2.0 gelöscht, admin neu gestartet und die 1.1.1 nochmal installiert - jetzt läufts.
                                          Das Problem war, dass beim Installieren der 1.1.1 in den Einstellungen immer noch die Festplatten- und die Button-Script Auswahl vorhanden war - erst wenn die weg sind, läuft die 1.1.1
                                            Jan1 last edited by
                                            Kann man den Adapter nicht einfach über Github installieren, damit das sauber läuft?
                                            739
                                            189971
