    4. [Problem] Dream btw. Enigma2 Adapter
      Jan1 last edited by
      Wie geschrieben, die alte 0.7… lief eigentlich. Für die neueren Versionen wird da Button Script nicht mehr benötigt, oder?
      • Matten Matten
        Matten Matten last edited by
        @Jan1:
        Der Pi hängt im LAN und alles andere hat eine sehr gute Verbindung zur Dream. Polling auf 15s ändert nur das Intervall der Zahnräder an der Dream :lol:
        host.raspberrypi	2018-10-29 16:42:17.221	info	Restart adapter system.adapter.enigma2.0 because enabled
        host.raspberrypi	2018-10-29 16:42:17.221	error	instance system.adapter.enigma2.0 terminated with code 6 (uncaught exception)
        host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at Timer.listOnTimeout (timers.js:290:5) errno: -24, code: 'EMFILE', syscall: 'uv_resident_set_memory' }
        host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at tryOnTimeout (timers.js:323:5)
        host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at ontimeout (timers.js:498:11)
        host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at Timeout.reportStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5006:27)
        host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at process.memoryUsage (internal/process.js:99:5)
        host.raspberrypi	2018-10-29 16:42:17.219	error	Caught by controller[0]: { Error: EMFILE: too many open files, uv_resident_set_memory
        enigma2.0	2018-10-29 16:42:15.452	error	Error: EMFILE: too many open files, uv_resident_set_memory at process.memoryUsage (internal/process.js:99:5) at Timeout.reportStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-con
        enigma2.0	2018-10-29 16:42:15.451	error	uncaught exception: EMFILE: too many open files, uv_resident_set_memory
        enigma2.0	2018-10-29 16:42:14.071	info	enigma2: 192.168.100.15:84 ist nicht erreichbar!
        enigma2.0	2018-10-29 16:42:13.548	info	enigma2 Verbunden!
        enigma2.0	2018-10-29 16:42:10.925	info	enigma2: 192.168.100.15:84 ist nicht erreichbar!
        enigma2.0	2018-10-29 16:42:00.744	info	enigma2 Verbunden!
        enigma2.0	2018-10-29 16:42:00.448	info	starting Timercheck every null ms
        enigma2.0	2018-10-29 16:42:00.441	info	starting Polling every 15000 ms
        enigma2.0	2018-10-29 16:42:00.409	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.enigma2, node: v8.12.0
        Vielleicht liegt es auch irgendwie am auslesen der Timer…
        • Matten Matten
          @Jan1:
          Wie geschrieben, die alte 0.7… lief eigentlich. Für die neueren Versionen wird da Button Script nicht mehr benötigt, oder? `
          ab 1.0.0. benötigt man kein Button Script mehr.
          Probiere mal bitte die 1.0.0 aus, da ist die Timer geschichte noch nicht mit drin.
            Jan1 last edited by
            Wenn ich das zip entpacke und \node_modules kopiere, lässt sich das nicht uploaden und eine Instanz kann ich auch nicht anlegen. Hast bitte ein Github Link dafür?
            • Matten Matten
              @Jan1:
              Wenn ich das zip entpacke und \node_modules kopiere, lässt sich das nicht uploaden und eine Instanz kann ich auch nicht anlegen. Hast bitte ein Github Link dafür? `
              hast du den Ordner io<u>B</u>roker.enigma2 in io<u>b</u>roker.enigma2 umbenannt?
                Jan1 last edited by
                Na das musst erst mal sehen, bringt aber auch nur Fehler im Log. Allerdings bleibt der Adapter dann auch aus und startet nicht dauern neu.
                host.raspberrypi	2018-10-29 17:21:40.319	info	Restart adapter system.adapter.enigma2.0 because enabled
                host.raspberrypi	2018-10-29 17:21:40.319	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
                host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
                host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
                host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at Parser.emit (events.js:211:7)
                host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at emitOne (events.js:116:13)
                host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at Parser. <anonymous>(/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:203:21
                host.raspberrypi	2018-10-29 17:21:40.317	error	Caught by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:322:86)
                host.raspberrypi	2018-10-29 17:21:40.316	error	Caught by controller[0]: TypeError: Cannot read property '1' of undefined
                enigma2.0	2018-10-29 17:21:39.858	error	TypeError: Cannot read property '1' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:322:86) at /opt/iobroker/node_modules/iobroker.enigma2/enigm
                enigma2.0	2018-10-29 17:21:39.857	error	uncaught exception: Cannot read property '1' of undefined</anonymous>
                • Matten Matten
                  @Jan1:
                  ok da muss ich noch mal schauen…
                    Jan1 last edited by
                    Wenn's bei anderen läuft, mach Dir wegen mir keine Mühe. Wollte eh nur was probieren und das hätte mit dem Adapter etwas leichter und zuverlässiger funktionieren können als über den Harmony, da es übers LAN läuft und nicht über IR.
                    • Matten Matten
                      @Jan1:
                      Wenn's bei anderen läuft, mach Dir wegen mir keine Mühe. Wollte eh nur was probieren und das hätte mit dem Adapter etwas leichter und zuverlässiger funktionieren können als über den Harmony, da es übers LAN läuft und nicht über IR. `
                      3476_iobroker.enigma2-master_v0.4.3.zip
                      müsste die letzte version mit dem Buttonscript sein. wenn du das damit noch einmal versuchen möchtest
                      Matten Matten
                        Jan1 last edited by
                        OK danke, werd dann nochmal ein Versuch starte 😉
                        Diese Version läuft bei mir einwandfrei, da verträgt sich wohl was bei der neuen mit dem aktuellen Dream OS was nicht.
                          A Former User last edited by
                          Nö, hier drei 525 Combo mit aktuellem DreamOS.
                          Läuft perfekt.
                            Turbo last edited by
                            Ich hatte auch den Fehler mit Code 22 beim deinstallieren. Der Adapter startete bei mir auch laufend und hängte das gesamte System auf…
                            Habe danach in den Objekten den Ordner enigma2.0 gelöscht, admin neu gestartet und die 1.1.1 nochmal installiert - jetzt läufts.
                            Das Problem war, dass beim Installieren der 1.1.1 in den Einstellungen immer noch die Festplatten- und die Button-Script Auswahl vorhanden war - erst wenn die weg sind, läuft die 1.1.1
                              Jan1 last edited by
                              Kann man den Adapter nicht einfach über Github installieren, damit das sauber läuft?
                              • BBTown
                                BBTown last edited by
                                Ich habe die 1.0.0 und die die letzte Version ausprobiert und habe auch die Probleme, dass:
                                • permanemte Log-Einträge, dass angeblich keine Verbindung besteht (default Poll 5 sek.)
                                • der Adapter sich innerhalb kürzester Zeit mit 400 - 600 MB Speicher vollsaugt
                                • bei mir ist es eine DM8000
                                • alle Komponenten sind per LAN-Kable (mindesten 100 MBit) miteinander verbunden.
                                • der WebClient über PC/Browser funktioniert seit jeher einwandfrei
                                Was mir aufgefallen ist:
                                ganz gleich was ich bei den Einstellungen für ein root Passwort eintrage, es wird immer eine Verbindung akzeptiert.
                                Wird das LogIn nicht verifiziert?
                                Oder wird jedes Passwort akzeptiert wenn für den Zugang über das WebInterface bzw. root gar kein Passwort vergeben wurde??
                                • N
                                  NightWatcher last edited by
                                  Habe eben wieder einen neuen Pull Request gesetzt. Einiges an Code bereinigt und das Senderlogo steht jetzt als Base64 Image in einem Objekt zur Verfügung.
                                    Vielen Dank für Eure unermüdliche Arbeit an diesem Adapter.
                                    @ NightWatcher
                                    Was wirklich noch interessant wäre, ist das auslesen der Bouquets und speichern in Datenpunkte.
                                    Am besten auswählbar im Adapter welche Bouquets benutzt werden sollen.
                                    Vielleicht ist das ja eine Herausforderung für Dich 🙂
                                    • N
                                      Sollen die nur als Visuelle Datenpunkte dargestellt werden? Also dass du deine kompletten Sender visualisieren kannst?
                                        Das habe ich bereits mal vor einem Jahr gemacht.
                                        Allerdings war ich da noch etwas unbedarfter als heute bezüglich iobroker.
                                        Ich hatte das seinerzeit mal mit Scripten und Datenpunkten angelegt.
                                        Das funktioniert perfekt auf einer Box so wie ich das will.
                                        ABER, ich habe hier 5 Dreamboxen im Haus und dann ist das ne Mörder Arbeit.
                                        Also, lange Rede kurzer Sinn.
                                        Ja, ich möchte das auch für die anderen Boxen visualisieren.
                                        Schön wäre es wenn in jedem Datenpunkt der jeweilige Sender aus den Bouquets abelegt werden.
                                        Noch besser wäre es wenn die IP aus dem Adapter gleich mit dem jeweiligen WebIf Befehl zum umschalten verknüpft wäre.
                                        Also für SAT 1 HD z.B. so:
                                        http://192.168.123.5/web/zap?sRef=1:0:1 … 0000:0:0:0:
                                        Ich benutze hier das Originale WebIf der Dreambox.
                                        Da es noch ein OpenWebIf gibt denke ich aber das dort die Befehle zum umschalten gleich sind.
                                        Hier hatte @ mikiline schon mal etwas angemerkt.
                                        > [viewtopic.php?f=17&amp;t=1739&amp;start=380#p186819](https://forum.iobroker.net/viewtopic.php?f=17&amp;t=1739&amp;start=380#p186819)
                                        Du kannst ja mal schauen was möglich ist.
                                        So sieht das mit meiner Visualisierung auf der Wohnzimmerbox derzeit aus.
                                        Damit kann ich dann jeden Sender umschalten.
                                          Jan1 last edited by
                                          @BBTown:
                                          Oder wird jedes Passwort akzeptiert wenn für den Zugang über das WebInterface bzw. root gar kein Passwort vergeben wurde?? `
                                          Wenn kein Passwort vergeben, dann ist es wie immer egal was da steht. Außerdem ist es auch abhängig davon, ob Du im Webinterface überhaupt die Autorisierung für lokale Clients aktiviert hast. Ist das nicht aktiviert, wird auch kein Passwort abgefragt.
                                            mikiline last edited by
                                            @Pocky:
                                            @ NightWatcher
                                            Vielleicht ist das ja eine Herausforderung für Dich 🙂 `
                                            Dann könnte es so aussehen (falls möglich auch die Senderlogos als Base64 abzuspeichern)
                                            Hab ich moemntan noch mit externer Webseite realisiert
                                            739
                                            189972
