    4. [Aufruf] ZigBee CC253x Adapter
      hast du nur den Stick stecken oder noch was am USB..
        DeeJayDave last edited by
        Nur den Stick
          die Fehlermeldung besagt das der Stick keine verbindung mit der Lib zigbee-shepherd herstellen konnte..
          trag bitte als Device````
          /dev/ttyAMA0
          und starte den adapter neu
            Klappt leider auch nicht. LED bleibt gelb und folgender Log:
            ! zigbee.02018-10-31 14:11:31.002infoStart on port: /dev/ttyAMA0 with panID 6754 channel 11zigbee.02018-10-31 14:11:30.993infostarting. Version 0.7.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.12.0zigbee.02018-10-31 14:11:30.815infoStates connected to redis: 127.0.0.1:6379host.Raspberry2018-10-31 14:11:28.869infoinstance system.adapter.zigbee.0 started with pid 18736host.Raspberry2018-10-31 14:11:28.850infoobject change system.adapter.zigbee.0host.Raspberry2018-10-31 14:11:27.730infoobject change system.adapter.zigbee.0host.Raspberry2018-10-31 14:11:27.720infoRestart adapter system.adapter.zigbee.0 because enabledhost.Raspberry2018-10-31 14:11:27.719errorinstance system.adapter.zigbee.0 terminated with code 0 (OK)host.Raspberry2018-10-31 14:11:04.647infoinstance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)Caught2018-10-31 14:11:04.646errorby controller[9]: 2018-10-31T13:10:59.868Z zigbee:controller debug Error while starting zigbee-shepherd, attemping to fix… (takes 60 seconds) undefinedCaught2018-10-31 14:11:04.646errorby controller[8]: at Timer.listOnTimeout (timers.js:290:5)Caught2018-10-31 14:11:04.646errorby controller[8]: at tryOnTimeout (timers.js:323:5)Caught2018-10-31 14:11:04.646errorby controller[8]: at ontimeout (timers.js:498:11)Caught2018-10-31 14:11:04.646error (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:233:18)" style="overflow: hidden; padding-left: 5px !important; padding-right: 0px !important; box-sizing: border-box; border: 1px solid rgb(224, 224, 224); text-align: left !important;">by controller[8]: at Timeout. <anonymous>(/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:233:18)Caught2018-10-31 14:11:04.646errorby controller[8]: at CcZnp.emit (events.js:211:7)Caught2018-10-31 14:11:04.646errorby controller[8]: at emitOne (events.js:116:13)Caught2018-10-31 14:11:04.645errorby controller[8]: at Object.onceWrapper (events.js:315:30)Caught2018-10-31 14:11:04.645error (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:254:22)" style="overflow: hidden; padding-left: 5px !important; padding-right: 0px !important; box-sizing: border-box; border: 1px solid rgb(224, 224, 224); text-align: left !important;">by controller[8]: at CcZnp. <anonymous>(/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:254:22)Caught2018-10-31 14:11:04.645errorby controller[8]: Wed, 31 Oct 2018 13:10:59 GMT zigbee-shepherd:init Coordinator initialize had an error: Error: request timeoutCaught2018-10-31 14:11:04.645errorby controller[7]: Wed, 31 Oct 2018 13:10:59 GMT zigbee-shepherd:request RSP <– SYS:osalNvReadCaught2018-10-31 14:11:04.645errorby controller[6]: Wed, 31 Oct 2018 13:10:59 GMT cc-znp:SRSP <– SYS:osalNvRead, __timeout__Caught2018-10-31 14:11:04.645error SYS:osalNvRead, { id: 3840, offset: 0, len: 1, value: [ 85 ] }" style="overflow: hidden; padding-left: 5px !important; padding-right: 0px !important; box-sizing: border-box; border: 1px solid rgb(224, 224, 224); text-align: left !important;">by controller[5]: Wed, 31 Oct 2018 13:10:56 GMT cc-znp:SREQ –> SYS:osalNvRead, { id: 3840, offset: 0, len: 1, value: [ 85 ] }Caught2018-10-31 14:11:04.644error SYS:osalNvRead" style="overflow: hidden; padding-left: 5px !important; padding-right: 0px !important; box-sizing: border-box; border: 1px solid rgb(224, 224, 224); text-align: left !important;">by controller[4]: Wed, 31 Oct 2018 13:10:56 GMT zigbee-shepherd:request REQ –> SYS:osalNvReadCaught2018-10-31 14:11:04.644errorby controller[3]: Wed, 31 Oct 2018 13:10:56 GMT cc-znp The serialport /dev/ttyAMA0 is opened.Caught2018-10-31 14:11:04.644errorby controller[2]: Wed, 31 Oct 2018 13:10:56 GMT zigbee-shepherd:init zigbee-shepherd booting…Caught2018-10-31 14:11:04.644errorby controller[1]: 2018-10-31T13:10:52.380Z zigbee:controller info zigbee-shepherd stopped undefinedCaught2018-10-31 14:11:04.643errorby controller[1]: Wed, 31 Oct 2018 13:10:52 GMT zigbee-shepherd zigbee-shepherd is stopped.Caught2018-10-31 14:11:04.643errorby controller[1]: Wed, 31 Oct 2018 13:10:52 GMT zigbee-shepherd zigbee-shepherd is stopping.host</anonymous></anonymous>
            • modmax
              modmax last edited by
              Und schon mal
              /dev/ttyACM0
              Versucht?
              • a200
                a200 last edited by
                @DeeJayDaveq
                wenn du raspi benutzt, dann gib mal
                sudo dmesg
                ein und poste mal die Ausgabe
                  @modmax:
                  Und schon mal
                  /dev/ttyACM0
                  Versucht? `
                    @a200:
                    @DeeJayDaveq
                    sudo dmesg
                    ein und poste mal die Ausgabe `
                    Es kommt folgendes raus:
                    ! pi@Raspberry:~ $ [64775.045577] [ 664] 0 664 1769 0 7 0 76 0 bluetoothd
                    ! -bash: [64775.045577]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045583] [ 727] 0 727 36507 6251 92 0 1451 0 iobroker.js-con
                    ! -bash: [64775.045583]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045589] [ 852] 0 852 34115 5846 94 0 2032 0 io.cloud.0
                    ! -bash: [64775.045589]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045596] [ 862] 0 862 32342 5703 85 0 1214 0 io.history.0
                    ! -bash: [64775.045596]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045602] [ 877] 0 877 39568 6949 118 0 7302 0 io.javascript.0
                    ! -bash: [64775.045602]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045608] [ 883] 0 883 34246 6201 99 0 2186 0 io.alexa2.0
                    ! -bash: [64775.045608]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045614] [ 893] 0 893 35363 7126 104 0 2190 0 io.admin.0
                    ! -bash: [64775.045614]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045620] [ 903] 0 903 35329 8093 107 0 1709 0 io.fritzdect.0
                    ! -bash: [64775.045620]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045626] [ 909] 0 909 31684 5200 87 0 1220 0 io.discovery.0
                    ! -bash: [64775.045626]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045632] [ 919] 0 919 33364 3543 69 0 719 0 io.web.0
                    ! -bash: [64775.045632]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045638] [ 925] 0 925 35069 6699 80 0 220 0 io.hs100.0
                    ! -bash: [64775.045638]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045644] [ 939] 0 939 32939 6054 80 0 493 0 io.rpi2.0
                    ! -bash: [64775.045644]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045650] [ 949] 0 949 31706 5327 84 0 1253 0 io.yeelight-2.0
                    ! -bash: [64775.045650]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045656] [ 973] 0 973 32459 6916 90 0 275 0 io.socketio.0
                    ! -bash: [64775.045656]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045662] [ 983] 0 983 33045 7255 90 0 489 0 io.terminal.0
                    ! -bash: [64775.045662]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045668] [ 1037] 0 1037 31794 6148 83 0 460 0 io.node-red.0
                    ! -bash: [64775.045668]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045674] [ 1052] 0 1052 39401 13493 137 0 304 0 node-red
                    ! -bash: [64775.045674]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045682] [23488] 0 23488 102734 77736 457 0 0 0 io.zigbee.0
                    ! -bash: [64775.045682]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045687] [23543] 0 23543 58798 32935 247 0 0 0 io.zigbee.0
                    ! -bash: [64775.045687]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64775.045691] Out of memory: Kill process 23488 (io.zigbee.0) score 288 or sacr ifice child
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64775.045734] Killed process 23488 (io.zigbee.0) total-vm:410936kB, anon-rss:31 0932kB, file-rss:12kB, shmem-rss:0kB ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64775.185092] oom_reaper: reaped process 23488 (io.zigbee.0), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903006] io.zigbee.0 invoked oom-killer: gfp_mask=0x14080c0(GFP_KERNEL|__G FP_ZERO), nodemask=(null), order=0, oom_score_adj=0 ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64846.903020] io.zigbee.0 cpuset=/ mems_allowed=0
                    ! -bash: [64846.903020]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64846.903035] CPU: 3 PID: 23543 Comm: io.zigbee.0 Tainted: G C 4.1 4.71-v7+ #1145
                    ! -bash: [64846.903035]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64846.903038] Hardware name: BCM2835
                    ! -bash: [64846.903038]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64846.903059] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x2 0/0x24)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903069] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x11 8) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64846.903079] [<80787f24>] (dump_stack) from [<80224574>] (dump_header+0xac/0x2 08)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903089] [<80224574>] (dump_header) from [<802238dc>] (oom_kill_process+0x 478/0x584) ! -bash: Syntaxfehler beim unerwarteten Wort 80224574'
                    ! pi@Raspberry:~ $ [64846.903097] [<802238dc>] (oom_kill_process) from [<8022423c>] (out_of_memory+ 0x124/0x334)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903107] [<8022423c>] (out_of_memory) from [<80229cf8>] (__alloc_pages_nod emask+0x1060/0x11d8) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64846.903118] [<80229cf8>] (__alloc_pages_nodemask) from [<80256168>] (__pte_al loc+0x34/0x19c)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903127] [<80256168>] (__pte_alloc) from [<80259e34>] (handle_mm_fault+0xb 98/0xc20) ! -bash: Syntaxfehler beim unerwarteten Wort 80256168'
                    ! pi@Raspberry:~ $ [64846.903136] [<80259e34>] (handle_mm_fault) from [<807a458c>] (do_page_fault+0 x330/0x3a4)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903143] [<807a458c>] (do_page_fault) from [<807a46bc>] (do_translation_fa ult+0xbc/0xc0) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64846.903152] [<807a46bc>] (do_translation_fault) from [<801011e0>] (do_DataAbo rt+0x48/0xc4)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903160] [<801011e0>] (do_DataAbort) from [<807a3da4>] (__dabt_usr+0x44/0x 60) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64846.903164] Exception stack(0xaa703fb0 to 0xaa703ff8)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903169] 3fa0: 018ceb08 68580000 00080 000 68504100 ! -bash: [64846.903169]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903175] 3fc0: 68500000 00000000 0007bf00 68500000 0007bf00 68504100 018ce af8 7ee68a34 ! -bash: [64846.903175]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903181] 3fe0: 0197855b 7ee68a18 00a266a8 00a1d464 20000010 ffffffff ! -bash: [64846.903181]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903184] Mem-Info: ! -bash: [64846.903184]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903195] active_anon:110685 inactive_anon:110740 isolated_anon:0 ! -bash: [64846.903195]: Kommando nicht gefunden. ! pi@Raspberry:~ $ active_file:243 inactive_file:1516 isolated_file:0 ! -bash: active_file:243: Kommando nicht gefunden. ! pi@Raspberry:~ $ unevictable:0 dirty:0 writeback:0 unstable:0 ! -bash: unevictable:0: Kommando nicht gefunden. ! pi@Raspberry:~ $ slab_reclaimable:1572 slab_unreclaimable:2839 ! -bash: slab_reclaimable:1572: Kommando nicht gefunden. ! pi@Raspberry:~ $ mapped:1314 shmem:2188 pagetables:2349 bounce:0 ! -bash: mapped:1314: Kommando nicht gefunden. ! pi@Raspberry:~ $ free:4663 free_pcp:0 free_cma:1312 ! -bash: free:4663: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903204] Node 0 active_anon:442740kB inactive_anon:442960kB active_file:97 2kB inactive_file:6064kB unevictable:0kB isolated(anon):0kB isolated(file):0kB m apped:5256kB dirty:0kB writeback:0kB shmem:8752kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64846.903216] Normal free:18652kB min:16384kB low:20480kB high:24576kB active_a non:442740kB inactive_anon:442960kB active_file:972kB inactive_file:6064kB unevi ctable:0kB writepending:0kB present:970752kB managed:949448kB mlocked:0kB kernel _stack:2200kB pagetables:9396kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:5 248kB
                    ! -bash: [64846.903216]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64846.903218] lowmem_reserve[]: 0 0
                    ! -bash: [64846.903218]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64846.903226] Normal: 2184kB (MEH) 1118kB (UMEHC) 16016kB (UMEHC) 8932kB (U EHC) 4864kB (UHC) 24128kB (UHC) 9256kB (UHC) 6512kB (UHC) 01024kB 02048kB 04096kB = 18688kB
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64846.903270] 4062 total pagecache pages ! -bash: [64846.903270]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903273] 98 pages in swap cache ! -bash: [64846.903273]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903277] Swap cache stats: add 47004, delete 46906, find 24884/35954 ! -bash: [64846.903277]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903279] Free swap = 0kB ! -bash: [64846.903279]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903282] Total swap = 102396kB ! -bash: [64846.903282]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903284] 242688 pages RAM ! -bash: [64846.903284]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903287] 0 pages HighMem/MovableOnly ! -bash: [64846.903287]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903289] 5326 pages reserved ! -bash: [64846.903289]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903291] 2048 pages cma reserved ! -bash: [64846.903291]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903294] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oo m_score_adj name ! -bash: [64846.903294]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903313] [ 100] 0 100 6731 181 12 0 51 0 systemd-journal ! -bash: [64846.903313]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903319] [ 127] 0 127 3585 37 8 0 128 -1000 systemd-udevd ! -bash: [64846.903319]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903326] [ 255] 100 255 4320 15 9 0 95 0 systemd-timesyn ! -bash: [64846.903326]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903333] [ 292] 0 292 1728 20 7 0 70 0 systemd-logind ! -bash: [64846.903333]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903339] [ 293] 0 293 1425 15 7 0 39 0 cron ! -bash: [64846.903339]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903345] [ 297] 105 297 1625 46 8 0 59 -900 dbus-daemon ! -bash: [64846.903345]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903352] [ 319] 108 319 1633 40 7 0 53 0 avahi-daemon ! -bash: [64846.903352]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903358] [ 320] 65534 320 1324 4 7 0 56 0 thd ! -bash: [64846.903358]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903364] [ 321] 0 321 5937 116 13 0 88 0 rsyslogd ! -bash: [64846.903364]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903370] [ 333] 108 333 1601 3 7 0 74 0 avahi-daemon ! -bash: [64846.903370]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903376] [ 381] 0 381 2533 44 9 0 94 0 wpa_supplicant ! -bash: [64846.903376]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903382] [ 495] 0 495 737 57 6 0 46 0 dhcpcd ! -bash: [64846.903382]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903388] [ 511] 0 511 1150 0 7 0 35 0 agetty ! -bash: [64846.903388]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903394] [ 517] 0 517 2552 0 8 0 138 -1000 sshd ! -bash: [64846.903394]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903401] [ 525] 109 525 8546 253 11 0 89 0 redis-server ! -bash: [64846.903401]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903407] [ 657] 0 657 524 0 4 0 34 0 hciattach ! -bash: [64846.903407]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903413] [ 664] 0 664 1769 0 7 0 76 0 bluetoothd ! -bash: [64846.903413]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903420] [ 727] 0 727 36635 6273 92 0 1448 0 iobroker.js-con ! -bash: [64846.903420]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903425] [ 852] 0 852 34115 5914 94 0 2032 0 io.cloud.0 ! -bash: [64846.903425]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903431] [ 862] 0 862 32342 5775 85 0 1214 0 io.history.0 ! -bash: [64846.903431]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903438] [ 877] 0 877 39568 6831 118 0 7304 0 io.javascript.0 ! -bash: [64846.903438]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903444] [ 883] 0 883 34246 6264 99 0 2186 0 io.alexa2.0 ! -bash: [64846.903444]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903451] [ 893] 0 893 35363 7193 104 0 2190 0 io.admin.0 ! -bash: [64846.903451]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903457] [ 903] 0 903 35329 7938 107 0 1698 0 io.fritzdect.0 ! -bash: [64846.903457]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903463] [ 909] 0 909 31684 5264 87 0 1220 0 io.discovery.0 ! -bash: [64846.903463]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903469] [ 919] 0 919 33364 3522 69 0 719 0 io.web.0 ! -bash: [64846.903469]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903475] [ 925] 0 925 35069 6565 80 0 217 0 io.hs100.0 ! -bash: [64846.903475]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903481] [ 939] 0 939 32939 6229 82 0 493 0 io.rpi2.0 ! -bash: [64846.903481]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903487] [ 949] 0 949 31557 5034 84 0 1254 0 io.yeelight-2.0 ! -bash: [64846.903487]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903493] [ 973] 0 973 32459 6742 90 0 278 0 io.socketio.0 ! -bash: [64846.903493]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903499] [ 983] 0 983 33045 7319 90 0 489 0 io.terminal.0 ! -bash: [64846.903499]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903505] [ 1037] 0 1037 31794 6211 83 0 464 0 io.node-red.0 ! -bash: [64846.903505]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903511] [ 1052] 0 1052 39401 13536 137 0 305 0 node-red ! -bash: [64846.903511]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903519] [23543] 0 23543 105134 80757 466 0 0 0 io.zigbee.0 ! -bash: [64846.903519]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903525] [23598] 0 23598 56238 31353 235 0 0 0 io.zigbee.0 ! -bash: [64846.903525]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64846.903528] Out of memory: Kill process 23543 (io.zigbee.0) score 299 or sacr ifice child ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64846.903569] Killed process 23543 (io.zigbee.0) total-vm:420536kB, anon-rss:31 9932kB, file-rss:3096kB, shmem-rss:0kB
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.109860] io.zigbee.0 invoked oom-killer: gfp_mask=0x14080c0(GFP_KERNEL|__G FP_ZERO), nodemask=(null), order=0, oom_score_adj=0 ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64915.109875] io.zigbee.0 cpuset=/ mems_allowed=0
                    ! -bash: [64915.109875]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64915.109891] CPU: 2 PID: 23700 Comm: io.zigbee.0 Tainted: G C 4.1 4.71-v7+ #1145
                    ! -bash: [64915.109891]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64915.109893] Hardware name: BCM2835
                    ! -bash: [64915.109893]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64915.109919] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x2 0/0x24)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.109930] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x11 8) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64915.109942] [<80787f24>] (dump_stack) from [<80224574>] (dump_header+0xac/0x2 08)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.109952] [<80224574>] (dump_header) from [<802238dc>] (oom_kill_process+0x 478/0x584) ! -bash: Syntaxfehler beim unerwarteten Wort 80224574'
                    ! pi@Raspberry:~ $ [64915.109961] [<802238dc>] (oom_kill_process) from [<8022423c>] (out_of_memory+ 0x124/0x334)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.109970] [<8022423c>] (out_of_memory) from [<80229cf8>] (__alloc_pages_nod emask+0x1060/0x11d8) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64915.109982] [<80229cf8>] (__alloc_pages_nodemask) from [<80256168>] (__pte_al loc+0x34/0x19c)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.109992] [<80256168>] (__pte_alloc) from [<80259e34>] (handle_mm_fault+0xb 98/0xc20) ! -bash: Syntaxfehler beim unerwarteten Wort 80256168'
                    ! pi@Raspberry:~ $ [64915.110001] [<80259e34>] (handle_mm_fault) from [<807a458c>] (do_page_fault+0 x330/0x3a4)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.110009] [<807a458c>] (do_page_fault) from [<807a46bc>] (do_translation_fa ult+0xbc/0xc0) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64915.110016] [<807a46bc>] (do_translation_fault) from [<801011e0>] (do_DataAbo rt+0x48/0xc4)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.110024] [<801011e0>] (do_DataAbort) from [<807a3da4>] (__dabt_usr+0x44/0x 60) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64915.110029] Exception stack(0x93063fb0 to 0x93063ff8)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.110035] 3fa0: 025acb08 49780000 00080 000 49704100 ! -bash: [64915.110035]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110041] 3fc0: 49700000 00000000 0007bf00 49700000 0007bf00 49704100 025ac af8 7e87cd14 ! -bash: [64915.110041]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110047] 3fe0: 02667453 7e87ccf8 00a266a8 00a1d464 20000010 ffffffff ! -bash: [64915.110047]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110050] Mem-Info: ! -bash: [64915.110050]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110063] active_anon:111057 inactive_anon:111068 isolated_anon:0 ! -bash: [64915.110063]: Kommando nicht gefunden. ! pi@Raspberry:~ $ active_file:398 inactive_file:410 isolated_file:32 ! -bash: active_file:398: Kommando nicht gefunden. ! pi@Raspberry:~ $ unevictable:0 dirty:0 writeback:0 unstable:0 ! -bash: unevictable:0: Kommando nicht gefunden. ! pi@Raspberry:~ $ slab_reclaimable:1580 slab_unreclaimable:2867 ! -bash: slab_reclaimable:1580: Kommando nicht gefunden. ! pi@Raspberry:~ $ mapped:953 shmem:2190 pagetables:2356 bounce:0 ! -bash: mapped:953: Kommando nicht gefunden. ! pi@Raspberry:~ $ free:4685 free_pcp:27 free_cma:1018 ! -bash: free:4685: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110072] Node 0 active_anon:444228kB inactive_anon:444272kB active_file:15 92kB inactive_file:1640kB unevictable:0kB isolated(anon):0kB isolated(file):128k B mapped:3812kB dirty:0kB writeback:0kB shmem:8760kB writeback_tmp:0kB unstable: 0kB all_unreclaimable? no ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64915.110084] Normal free:18740kB min:16384kB low:20480kB high:24576kB active_a non:444388kB inactive_anon:443972kB active_file:1852kB inactive_file:2204kB unev ictable:0kB writepending:0kB present:970752kB managed:949448kB mlocked:0kB kerne l_stack:2200kB pagetables:9424kB bounce:0kB free_pcp:108kB local_pcp:0kB free_cm a:4072kB
                    ! -bash: [64915.110084]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64915.110086] lowmem_reserve[]: 0 0
                    ! -bash: [64915.110086]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64915.110094] Normal: 364
                    4kB (UMEHC) 1758kB (UMEHC) 14016kB (UMEHC) 8032kB (UMEHC) 4864kB (UEHC) 24128kB (UEHC) 9256kB (UEHC) 6512kB (UEHC) 01024kB 0* 2048kB 04096kB = 19176kB
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.110138] 3167 total pagecache pages ! -bash: [64915.110138]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110142] 95 pages in swap cache ! -bash: [64915.110142]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110146] Swap cache stats: add 47026, delete 46931, find 25095/36177 ! -bash: [64915.110146]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110148] Free swap = 0kB ! -bash: [64915.110148]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110151] Total swap = 102396kB ! -bash: [64915.110151]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110154] 242688 pages RAM ! -bash: [64915.110154]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110156] 0 pages HighMem/MovableOnly ! -bash: [64915.110156]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110159] 5326 pages reserved ! -bash: [64915.110159]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110161] 2048 pages cma reserved ! -bash: [64915.110161]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110164] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oo m_score_adj name ! -bash: [64915.110164]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110185] [ 100] 0 100 6731 193 12 0 51 0 systemd-journal ! -bash: [64915.110185]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110193] [ 127] 0 127 3585 37 8 0 128 -1000 systemd-udevd ! -bash: [64915.110193]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110200] [ 255] 100 255 4320 15 9 0 95 0 systemd-timesyn ! -bash: [64915.110200]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110206] [ 292] 0 292 1728 20 7 0 70 0 systemd-logind ! -bash: [64915.110206]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110213] [ 293] 0 293 1425 15 7 0 39 0 cron ! -bash: [64915.110213]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110220] [ 297] 105 297 1625 46 8 0 59 -900 dbus-daemon ! -bash: [64915.110220]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110227] [ 319] 108 319 1633 40 7 0 53 0 avahi-daemon ! -bash: [64915.110227]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110233] [ 320] 65534 320 1324 4 7 0 56 0 thd ! -bash: [64915.110233]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110240] [ 321] 0 321 5937 116 13 0 88 0 rsyslogd ! -bash: [64915.110240]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110246] [ 333] 108 333 1601 3 7 0 74 0 avahi-daemon ! -bash: [64915.110246]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110253] [ 381] 0 381 2533 44 9 0 94 0 wpa_supplicant ! -bash: [64915.110253]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110259] [ 495] 0 495 737 57 6 0 46 0 dhcpcd ! -bash: [64915.110259]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110266] [ 511] 0 511 1150 0 7 0 35 0 agetty ! -bash: [64915.110266]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110272] [ 517] 0 517 2552 0 8 0 138 -1000 sshd ! -bash: [64915.110272]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110281] [ 525] 109 525 8546 196 11 0 89 0 redis-server ! -bash: [64915.110281]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110288] [ 657] 0 657 524 0 4 0 34 0 hciattach ! -bash: [64915.110288]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110295] [ 664] 0 664 1769 0 7 0 76 0 bluetoothd ! -bash: [64915.110295]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110301] [ 727] 0 727 36635 6254 93 0 1446 0 iobroker.js-con ! -bash: [64915.110301]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110308] [ 852] 0 852 34115 5971 94 0 2032 0 io.cloud.0 ! -bash: [64915.110308]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110314] [ 862] 0 862 32342 5599 85 0 1214 0 io.history.0 ! -bash: [64915.110314]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110322] [ 877] 0 877 39568 6946 118 0 7305 0 io.javascript.0 ! -bash: [64915.110322]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110329] [ 883] 0 883 34246 6323 99 0 2187 0 io.alexa2.0 ! -bash: [64915.110329]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110335] [ 893] 0 893 35363 7259 104 0 2190 0 io.admin.0 ! -bash: [64915.110335]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110342] [ 903] 0 903 35329 8082 107 0 1694 0 io.fritzdect.0 ! -bash: [64915.110342]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110350] [ 909] 0 909 31684 5319 87 0 1220 0 io.discovery.0 ! -bash: [64915.110350]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110356] [ 919] 0 919 33364 3567 69 0 719 0 io.web.0 ! -bash: [64915.110356]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110363] [ 925] 0 925 35069 6674 80 0 217 0 io.hs100.0 ! -bash: [64915.110363]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110369] [ 939] 0 939 32939 6364 82 0 493 0 io.rpi2.0 ! -bash: [64915.110369]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110375] [ 949] 0 949 31557 5097 84 0 1254 0 io.yeelight-2.0 ! -bash: [64915.110375]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110382] [ 973] 0 973 32459 6794 90 0 278 0 io.socketio.0 ! -bash: [64915.110382]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110388] [ 983] 0 983 33045 7372 90 0 490 0 io.terminal.0 ! -bash: [64915.110388]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110395] [ 1037] 0 1037 31794 6036 83 0 464 0 io.node-red.0 ! -bash: [64915.110395]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110401] [ 1052] 0 1052 39401 13575 137 0 306 0 node-red ! -bash: [64915.110401]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110410] [23598] 0 23598 102062 77078 455 0 0 0 io.zigbee.0 ! -bash: [64915.110410]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110416] [23700] 0 23700 59182 34103 252 0 0 0 io.zigbee.0 ! -bash: [64915.110416]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64915.110420] Out of memory: Kill process 23598 (io.zigbee.0) score 286 or sacr ifice child ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64915.110477] Killed process 23598 (io.zigbee.0) total-vm:408248kB, anon-rss:30 8312kB, file-rss:0kB, shmem-rss:0kB
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64915.206490] oom_reaper: reaped process 23598 (io.zigbee.0), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604440] io.zigbee.0 invoked oom-killer: gfp_mask=0x14080c0(GFP_KERNEL|__G FP_ZERO), nodemask=(null), order=0, oom_score_adj=0
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64986.604454] io.zigbee.0 cpuset=/ mems_allowed=0 ! -bash: [64986.604454]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64986.604470] CPU: 3 PID: 23755 Comm: io.zigbee.0 Tainted: G C 4.1 4.71-v7+ #1145 ! -bash: [64986.604470]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64986.604473] Hardware name: BCM2835 ! -bash: [64986.604473]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64986.604497] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x2 0/0x24) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604506] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x11 😎
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64986.604518] [<80787f24>] (dump_stack) from [<80224574>] (dump_header+0xac/0x2 08) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604527] [<80224574>] (dump_header) from [<802238dc>] (oom_kill_process+0x 478/0x584)
                    ! -bash: Syntaxfehler beim unerwarteten Wort 80224574' ! pi@Raspberry:~ $ [64986.604535] [<802238dc>] (oom_kill_process) from [<8022423c>] (out_of_memory+ 0x124/0x334) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604545] [<8022423c>] (out_of_memory) from [<80229cf8>] (__alloc_pages_nod emask+0x1060/0x11d8)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64986.604555] [<80229cf8>] (__alloc_pages_nodemask) from [<80256168>] (__pte_al loc+0x34/0x19c) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604565] [<80256168>] (__pte_alloc) from [<80259e34>] (handle_mm_fault+0xb 98/0xc20)
                    ! -bash: Syntaxfehler beim unerwarteten Wort 80256168' ! pi@Raspberry:~ $ [64986.604574] [<80259e34>] (handle_mm_fault) from [<807a458c>] (do_page_fault+0 x330/0x3a4) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604582] [<807a458c>] (do_page_fault) from [<807a46bc>] (do_translation_fa ult+0xbc/0xc0)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64986.604589] [<807a46bc>] (do_translation_fault) from [<801011e0>] (do_DataAbo rt+0x48/0xc4) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604597] [<801011e0>] (do_DataAbort) from [<807a3da4>] (__dabt_usr+0x44/0x 60)
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64986.604601] Exception stack(0x93029fb0 to 0x93029ff8) ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604606] 9fa0: 01f91b08 25d00000 00080 000 25c84100
                    ! -bash: [64986.604606]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64986.604612] 9fc0: 25c80000 00000000 0007bf00 25c80000 0007bf00 25c84100 01f91 af8 7e842d14
                    ! -bash: [64986.604612]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64986.604618] 9fe0: 0203825b 7e842cf8 00a266a8 00a1d464 20000010 ffffffff
                    ! -bash: [64986.604618]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64986.604621] Mem-Info:
                    ! -bash: [64986.604621]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64986.604634] active_anon:110866 inactive_anon:110925 isolated_anon:0
                    ! -bash: [64986.604634]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ active_file:220 inactive_file:504 isolated_file:32
                    ! -bash: active_file:220: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ slab_reclaimable:1567 slab_unreclaimable:2894
                    ! -bash: slab_reclaimable:1567: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ mapped:701 shmem:2189 pagetables:2341 bounce:0
                    ! -bash: mapped:701: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ free:5154 free_pcp:48 free_cma:1187
                    ! -bash: free:5154: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64986.604644] Node 0 active_anon:443464kB inactive_anon:443700kB active_file:88 0kB inactive_file:2016kB unevictable:0kB isolated(anon):0kB isolated(file):128kB mapped:2804kB dirty:0kB writeback:0kB shmem:8756kB writeback_tmp:0kB unstable:0 kB all_unreclaimable? no
                    ! -bash: Syntaxfehler beim unerwarteten Wort (' ! pi@Raspberry:~ $ [64986.604656] Normal free:20616kB min:16384kB low:20480kB high:24576kB active_a non:443492kB inactive_anon:443600kB active_file:680kB inactive_file:2016kB unevi ctable:0kB writepending:0kB present:970752kB managed:949448kB mlocked:0kB kernel _stack:2208kB pagetables:9364kB bounce:0kB free_pcp:192kB local_pcp:0kB free_cma :4748kB ! -bash: [64986.604656]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64986.604658] lowmem_reserve[]: 0 0 ! -bash: [64986.604658]: Kommando nicht gefunden. ! pi@Raspberry:~ $ [64986.604666] Normal: 136*4kB (MEHC) 117*8kB (UMEHC) 130*16kB (UMEHC) 75*32kB ( UEHC) 49*64kB (UMEHC) 47*128kB (UMEHC) 10*256kB (UMEHC) 6*512kB (UEHC) 0*1024kB 0*2048kB 0*4096kB = 20744kB ! -bash: Syntaxfehler beim unerwarteten Wort ('
                    ! pi@Raspberry:~ $ [64986.604710] 3077 total pagecache pages
                    ! -bash: [64986.604710]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64986.604714] 87 pages in swap cache
                    ! -bash: [64986.604714]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ [64986.604718] Swap cache stats: add 47067, delete 46980, find 25324/36420
                    ! -bash: [64986.604718]: Kommando nicht gefunden.
                    ! pi@Raspberry:~ $ sudo dmesg
                    ! [64364.219582] lowmem_reserve[]: 0 0
                    ! [64364.219590] Normal: 306
                    4kB (UMEC) 1588kB (UMEC) 13116kB (UMEC) 7132kB (UMEC) 4364kB (UEC) 23128kB (UEC) 9256kB (UEC) 6512kB (UEC) 01024kB 02048kB 04096kB = 17928kB
                    ! [64364.219636] 3061 total pagecache pages
                    ! [64364.219640] 0 pages in swap cache
                    ! [64364.219644] Swap cache stats: add 46161, delete 46161, find 23115/33799
                    ! [64364.219646] Free swap = 4kB
                    ! [64364.219648] Total swap = 102396kB
                    ! [64364.219651] 242688 pages RAM
                    ! [64364.219653] 0 pages HighMem/MovableOnly
                    ! [64364.219656] 5326 pages reserved
                    ! [64364.219658] 2048 pages cma reserved
                    ! [64364.595165] io.discovery.0: page allocation stalls for 20020ms, order:0, mode:0x14140c0(GFP_KERNEL|__GFP_COMP|__GFP_NOMEMALLOC), nodemask=(null)
                    ! [64364.595194] io.discovery.0 cpuset=/ mems_allowed=0
                    ! [64364.595210] CPU: 0 PID: 909 Comm: io.discovery.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64364.595212] Hardware name: BCM2835
                    ! [64364.595239] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64364.595250] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64364.595263] [<80787f24>] (dump_stack) from [<80228b34>] (warn_alloc+0xcc/0x17c)
                    ! [64364.595274] [<80228b34>] (warn_alloc) from [<80229928>] (__alloc_pages_nodemask+0xc90/0x11d8)
                    ! [64364.595284] [<80229928>] (__alloc_pages_nodemask) from [<802752d0>] (new_slab+0x454/0x558)
                    ! [64364.595293] [<802752d0>] (new_slab) from [<80277114>] (___slab_alloc.constprop.11+0x228/0x2c0)
                    ! [64364.595302] [<80277114>] (___slab_alloc.constprop.11) from [<802771f0>] (__slab_alloc.constprop.10+0x44/0x90)
                    ! [64364.595310] [<802771f0>] (__slab_alloc.constprop.10) from [<8027a4f0>] (__kmalloc_track_caller+0x244/0x278)
                    ! [64364.595320] [<8027a4f0>] (__kmalloc_track_caller) from [<80676a0c>] (__kmalloc_reserve+0x34/0x80)
                    ! [64364.595330] [<80676a0c>] (__kmalloc_reserve) from [<80676ad4>] (__alloc_skb+0x7c/0x144)
                    ! [64364.595338] [<80676ad4>] (__alloc_skb) from [<806e8d08>] (sk_stream_alloc_skb+0x5c/0x1d0)
                    ! [64364.595347] [<806e8d08>] (sk_stream_alloc_skb) from [<806e9c20>] (tcp_sendmsg_locked+0x6bc/0xe14)
                    ! [64364.595354] [<806e9c20>] (tcp_sendmsg_locked) from [<806ea3b0>] (tcp_sendmsg+0x38/0x4c)
                    ! [64364.595364] [<806ea3b0>] (tcp_sendmsg) from [<80716dc4>] (inet_sendmsg+0x48/0xe4)
                    ! [64364.595375] [<80716dc4>] (inet_sendmsg) from [<8066f464>] (sock_sendmsg+0x24/0x34)
                    ! [64364.595384] [<8066f464>] (sock_sendmsg) from [<8066f50c>] (sock_write_iter+0x98/0xcc)
                    ! [64364.595394] [<8066f50c>] (sock_write_iter) from [<8028b3a8>] (__vfs_write+0xe0/0x138)
                    ! [64364.595404] [<8028b3a8>] (__vfs_write) from [<8028b5c8>] (vfs_write+0xb4/0x1bc)
                    ! [64364.595411] [<8028b5c8>] (vfs_write) from [<8028b818>] (SyS_write+0x54/0xb0)
                    ! [64364.595422] [<8028b818>] (SyS_write) from [<80108060>] (ret_fast_syscall+0x0/0x28)
                    ! [64364.606029] io.socketio.0: page allocation stalls for 20030ms, order:0, mode:0x14140c0(GFP_KERNEL|__GFP_COMP|__GFP_NOMEMALLOC), nodemask=(null)
                    ! [64364.606055] io.socketio.0 cpuset=/ mems_allowed=0
                    ! [64364.606070] CPU: 2 PID: 973 Comm: io.socketio.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64364.606073] Hardware name: BCM2835
                    ! [64364.606097] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64364.606108] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64364.606123] [<80787f24>] (dump_stack) from [<80228b34>] (warn_alloc+0xcc/0x17c)
                    ! [64364.606134] [<80228b34>] (warn_alloc) from [<80229928>] (__alloc_pages_nodemask+0xc90/0x11d8)
                    ! [64364.606144] [<80229928>] (__alloc_pages_nodemask) from [<802752d0>] (new_slab+0x454/0x558)
                    ! [64364.606153] [<802752d0>] (new_slab) from [<80277114>] (___slab_alloc.constprop.11+0x228/0x2c0)
                    ! [64364.606162] [<80277114>] (___slab_alloc.constprop.11) from [<802771f0>] (__slab_alloc.constprop.10+0x44/0x90)
                    ! [64364.606170] [<802771f0>] (__slab_alloc.constprop.10) from [<8027a4f0>] (__kmalloc_track_caller+0x244/0x278)
                    ! [64364.606181] [<8027a4f0>] (__kmalloc_track_caller) from [<80676a0c>] (__kmalloc_reserve+0x34/0x80)
                    ! [64364.606190] [<80676a0c>] (__kmalloc_reserve) from [<80676ad4>] (__alloc_skb+0x7c/0x144)
                    ! [64364.606199] [<80676ad4>] (__alloc_skb) from [<806e8d08>] (sk_stream_alloc_skb+0x5c/0x1d0)
                    ! [64364.606207] [<806e8d08>] (sk_stream_alloc_skb) from [<806e9c20>] (tcp_sendmsg_locked+0x6bc/0xe14)
                    ! [64364.606214] [<806e9c20>] (tcp_sendmsg_locked) from [<806ea3b0>] (tcp_sendmsg+0x38/0x4c)
                    ! [64364.606222] [<806ea3b0>] (tcp_sendmsg) from [<80716dc4>] (inet_sendmsg+0x48/0xe4)
                    ! [64364.606235] [<80716dc4>] (inet_sendmsg) from [<8066f464>] (sock_sendmsg+0x24/0x34)
                    ! [64364.606244] [<8066f464>] (sock_sendmsg) from [<8066f50c>] (sock_write_iter+0x98/0xcc)
                    ! [64364.606254] [<8066f50c>] (sock_write_iter) from [<8028b3a8>] (__vfs_write+0xe0/0x138)
                    ! [64364.606262] [<8028b3a8>] (__vfs_write) from [<8028b5c8>] (vfs_write+0xb4/0x1bc)
                    ! [64364.606270] [<8028b5c8>] (vfs_write) from [<8028b818>] (SyS_write+0x54/0xb0)
                    ! [64364.606281] [<8028b818>] (SyS_write) from [<80108060>] (ret_fast_syscall+0x0/0x28)
                    ! [64364.650096] io.terminal.0: page allocation stalls for 20070ms, order:0, mode:0x14140c0(GFP_KERNEL|__GFP_COMP|__GFP_NOMEMALLOC), nodemask=(null)
                    ! [64364.650124] io.terminal.0 cpuset=/ mems_allowed=0
                    ! [64364.650140] CPU: 3 PID: 983 Comm: io.terminal.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64364.650143] Hardware name: BCM2835
                    ! [64364.650170] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64364.650180] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64364.650193] [<80787f24>] (dump_stack) from [<80228b34>] (warn_alloc+0xcc/0x17c)
                    ! [64364.650204] [<80228b34>] (warn_alloc) from [<80229928>] (__alloc_pages_nodemask+0xc90/0x11d8)
                    ! [64364.650214] [<80229928>] (__alloc_pages_nodemask) from [<802752d0>] (new_slab+0x454/0x558)
                    ! [64364.650223] [<802752d0>] (new_slab) from [<80277114>] (___slab_alloc.constprop.11+0x228/0x2c0)
                    ! [64364.650232] [<80277114>] (___slab_alloc.constprop.11) from [<802771f0>] (__slab_alloc.constprop.10+0x44/0x90)
                    ! [64364.650240] [<802771f0>] (__slab_alloc.constprop.10) from [<8027a4f0>] (__kmalloc_track_caller+0x244/0x278)
                    ! [64364.650250] [<8027a4f0>] (__kmalloc_track_caller) from [<80676a0c>] (__kmalloc_reserve+0x34/0x80)
                    ! [64364.650259] [<80676a0c>] (__kmalloc_reserve) from [<80676ad4>] (__alloc_skb+0x7c/0x144)
                    ! [64364.650267] [<80676ad4>] (__alloc_skb) from [<806e8d08>] (sk_stream_alloc_skb+0x5c/0x1d0)
                    ! [64364.650275] [<806e8d08>] (sk_stream_alloc_skb) from [<806e9c20>] (tcp_sendmsg_locked+0x6bc/0xe14)
                    ! [64364.650283] [<806e9c20>] (tcp_sendmsg_locked) from [<806ea3b0>] (tcp_sendmsg+0x38/0x4c)
                    ! [64364.650291] [<806ea3b0>] (tcp_sendmsg) from [<80716dc4>] (inet_sendmsg+0x48/0xe4)
                    ! [64364.650302] [<80716dc4>] (inet_sendmsg) from [<8066f464>] (sock_sendmsg+0x24/0x34)
                    ! [64364.650311] [<8066f464>] (sock_sendmsg) from [<8066f50c>] (sock_write_iter+0x98/0xcc)
                    ! [64364.650322] [<8066f50c>] (sock_write_iter) from [<8028b3a8>] (__vfs_write+0xe0/0x138)
                    ! [64364.650331] [<8028b3a8>] (__vfs_write) from [<8028b5c8>] (vfs_write+0xb4/0x1bc)
                    ! [64364.650339] [<8028b5c8>] (vfs_write) from [<8028b818>] (SyS_write+0x54/0xb0)
                    ! [64364.650349] [<8028b818>] (SyS_write) from [<80108060>] (ret_fast_syscall+0x0/0x28)
                    ! [64364.746079] io.alexa2.0: page allocation stalls for 20170ms, order:0, mode:0x14140c0(GFP_KERNEL|__GFP_COMP|__GFP_NOMEMALLOC), nodemask=(null)
                    ! [64364.746107] io.alexa2.0 cpuset=/ mems_allowed=0
                    ! [64364.746123] CPU: 3 PID: 883 Comm: io.alexa2.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64364.746126] Hardware name: BCM2835
                    ! [64364.746150] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64364.746160] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64364.746172] [<80787f24>] (dump_stack) from [<80228b34>] (warn_alloc+0xcc/0x17c)
                    ! [64364.746183] [<80228b34>] (warn_alloc) from [<80229928>] (__alloc_pages_nodemask+0xc90/0x11d8)
                    ! [64364.746192] [<80229928>] (__alloc_pages_nodemask) from [<802752d0>] (new_slab+0x454/0x558)
                    ! [64364.746201] [<802752d0>] (new_slab) from [<80277114>] (___slab_alloc.constprop.11+0x228/0x2c0)
                    ! [64364.746209] [<80277114>] (___slab_alloc.constprop.11) from [<802771f0>] (__slab_alloc.constprop.10+0x44/0x90)
                    ! [64364.746217] [<802771f0>] (__slab_alloc.constprop.10) from [<8027a4f0>] (__kmalloc_track_caller+0x244/0x278)
                    ! [64364.746227] [<8027a4f0>] (__kmalloc_track_caller) from [<80676a0c>] (__kmalloc_reserve+0x34/0x80)
                    ! [64364.746237] [<80676a0c>] (__kmalloc_reserve) from [<80676ad4>] (__alloc_skb+0x7c/0x144)
                    ! [64364.746246] [<80676ad4>] (__alloc_skb) from [<806e8d08>] (sk_stream_alloc_skb+0x5c/0x1d0)
                    ! [64364.746254] [<806e8d08>] (sk_stream_alloc_skb) from [<806e9c20>] (tcp_sendmsg_locked+0x6bc/0xe14)
                    ! [64364.746262] [<806e9c20>] (tcp_sendmsg_locked) from [<806ea3b0>] (tcp_sendmsg+0x38/0x4c)
                    ! [64364.746270] [<806ea3b0>] (tcp_sendmsg) from [<80716dc4>] (inet_sendmsg+0x48/0xe4)
                    ! [64364.746280] [<80716dc4>] (inet_sendmsg) from [<8066f464>] (sock_sendmsg+0x24/0x34)
                    ! [64364.746289] [<8066f464>] (sock_sendmsg) from [<8066f50c>] (sock_write_iter+0x98/0xcc)
                    ! [64364.746299] [<8066f50c>] (sock_write_iter) from [<8028b3a8>] (__vfs_write+0xe0/0x138)
                    ! [64364.746308] [<8028b3a8>] (__vfs_write) from [<8028b5c8>] (vfs_write+0xb4/0x1bc)
                    ! [64364.746316] [<8028b5c8>] (vfs_write) from [<8028b818>] (SyS_write+0x54/0xb0)
                    ! [64364.746326] [<8028b818>] (SyS_write) from [<80108060>] (ret_fast_syscall+0x0/0x28)
                    ! [64364.934988] io.history.0: page allocation stalls for 20360ms, order:0, mode:0x14140c0(GFP_KERNEL|__GFP_COMP|__GFP_NOMEMALLOC), nodemask=(null)
                    ! [64364.935017] io.history.0 cpuset=/ mems_allowed=0
                    ! [64364.935032] CPU: 2 PID: 862 Comm: io.history.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64364.935034] Hardware name: BCM2835
                    ! [64364.935055] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64364.935065] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64364.935077] [<80787f24>] (dump_stack) from [<80228b34>] (warn_alloc+0xcc/0x17c)
                    ! [64364.935087] [<80228b34>] (warn_alloc) from [<80229928>] (__alloc_pages_nodemask+0xc90/0x11d8)
                    ! [64364.935097] [<80229928>] (__alloc_pages_nodemask) from [<802752d0>] (new_slab+0x454/0x558)
                    ! [64364.935105] [<802752d0>] (new_slab) from [<80277114>] (___slab_alloc.constprop.11+0x228/0x2c0)
                    ! [64364.935114] [<80277114>] (___slab_alloc.constprop.11) from [<802771f0>] (__slab_alloc.constprop.10+0x44/0x90)
                    ! [64364.935122] [<802771f0>] (__slab_alloc.constprop.10) from [<8027a4f0>] (__kmalloc_track_caller+0x244/0x278)
                    ! [64364.935133] [<8027a4f0>] (__kmalloc_track_caller) from [<80676a0c>] (__kmalloc_reserve+0x34/0x80)
                    ! [64364.935142] [<80676a0c>] (__kmalloc_reserve) from [<80676ad4>] (__alloc_skb+0x7c/0x144)
                    ! [64364.935150] [<80676ad4>] (__alloc_skb) from [<806e8d08>] (sk_stream_alloc_skb+0x5c/0x1d0)
                    ! [64364.935158] [<806e8d08>] (sk_stream_alloc_skb) from [<806e9c20>] (tcp_sendmsg_locked+0x6bc/0xe14)
                    ! [64364.935165] [<806e9c20>] (tcp_sendmsg_locked) from [<806ea3b0>] (tcp_sendmsg+0x38/0x4c)
                    ! [64364.935173] [<806ea3b0>] (tcp_sendmsg) from [<80716dc4>] (inet_sendmsg+0x48/0xe4)
                    ! [64364.935183] [<80716dc4>] (inet_sendmsg) from [<8066f464>] (sock_sendmsg+0x24/0x34)
                    ! [64364.935192] [<8066f464>] (sock_sendmsg) from [<8066f50c>] (sock_write_iter+0x98/0xcc)
                    ! [64364.935201] [<8066f50c>] (sock_write_iter) from [<8028b3a8>] (__vfs_write+0xe0/0x138)
                    ! [64364.935210] [<8028b3a8>] (__vfs_write) from [<8028b5c8>] (vfs_write+0xb4/0x1bc)
                    ! [64364.935218] [<8028b5c8>] (vfs_write) from [<8028b818>] (SyS_write+0x54/0xb0)
                    ! [64364.935227] [<8028b818>] (SyS_write) from [<80108060>] (ret_fast_syscall+0x0/0x28)
                    ! [64365.189085] io.socketio.0 invoked oom-killer: gfp_mask=0x14142c0(GFP_KERNEL|__GFP_NOWARN|__GFP_COMP|__GFP_NOMEMALLOC), nodemask=(null), order=0, oom_score_adj=0
                    ! [64365.189100] io.socketio.0 cpuset=/ mems_allowed=0
                    ! [64365.189116] CPU: 2 PID: 973 Comm: io.socketio.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64365.189118] Hardware name: BCM2835
                    ! [64365.189139] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64365.189148] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64365.189159] [<80787f24>] (dump_stack) from [<80224574>] (dump_header+0xac/0x208)
                    ! [64365.189169] [<80224574>] (dump_header) from [<802238dc>] (oom_kill_process+0x478/0x584)
                    ! [64365.189177] [<802238dc>] (oom_kill_process) from [<8022423c>] (out_of_memory+0x124/0x334)
                    ! [64365.189186] [<8022423c>] (out_of_memory) from [<80229cf8>] (__alloc_pages_nodemask+0x1060/0x11d8)
                    ! [64365.189196] [<80229cf8>] (__alloc_pages_nodemask) from [<802752d0>] (new_slab+0x454/0x558)
                    ! [64365.189205] [<802752d0>] (new_slab) from [<80277114>] (___slab_alloc.constprop.11+0x228/0x2c0)
                    ! [64365.189212] [<80277114>] (___slab_alloc.constprop.11) from [<802771f0>] (__slab_alloc.constprop.10+0x44/0x90)
                    ! [64365.189221] [<802771f0>] (__slab_alloc.constprop.10) from [<8027a4f0>] (__kmalloc_track_caller+0x244/0x278)
                    ! [64365.189231] [<8027a4f0>] (__kmalloc_track_caller) from [<80676a0c>] (__kmalloc_reserve+0x34/0x80)
                    ! [64365.189239] [<80676a0c>] (__kmalloc_reserve) from [<80676ad4>] (__alloc_skb+0x7c/0x144)
                    ! [64365.189247] [<80676ad4>] (__alloc_skb) from [<806e8d08>] (sk_stream_alloc_skb+0x5c/0x1d0)
                    ! [64365.189255] [<806e8d08>] (sk_stream_alloc_skb) from [<806e9c20>] (tcp_sendmsg_locked+0x6bc/0xe14)
                    ! [64365.189263] [<806e9c20>] (tcp_sendmsg_locked) from [<806ea3b0>] (tcp_sendmsg+0x38/0x4c)
                    ! [64365.189270] [<806ea3b0>] (tcp_sendmsg) from [<80716dc4>] (inet_sendmsg+0x48/0xe4)
                    ! [64365.189280] [<80716dc4>] (inet_sendmsg) from [<8066f464>] (sock_sendmsg+0x24/0x34)
                    ! [64365.189289] [<8066f464>] (sock_sendmsg) from [<8066f50c>] (sock_write_iter+0x98/0xcc)
                    ! [64365.189298] [<8066f50c>] (sock_write_iter) from [<8028b3a8>] (__vfs_write+0xe0/0x138)
                    ! [64365.189307] [<8028b3a8>] (__vfs_write) from [<8028b5c8>] (vfs_write+0xb4/0x1bc)
                    ! [64365.189315] [<8028b5c8>] (vfs_write) from [<8028b818>] (SyS_write+0x54/0xb0)
                    ! [64365.189324] [<8028b818>] (SyS_write) from [<80108060>] (ret_fast_syscall+0x0/0x28)
                    ! [64365.189328] Mem-Info:
                    ! [64365.189340] active_anon:111123 inactive_anon:111175 isolated_anon:0
                    ! active_file:167 inactive_file:315 isolated_file:0
                    ! unevictable:0 dirty:0 writeback:0 unstable:0
                    ! slab_reclaimable:1604 slab_unreclaimable:2903
                    ! mapped:212 shmem:2206 pagetables:2356 bounce:0
                    ! free:4840 free_pcp:0 free_cma:1072
                    ! [64365.189348] Node 0 active_anon:444492kB inactive_anon:444700kB active_file:668kB inactive_file:1260kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:848kB dirty:0kB writeback:0kB shmem:8824kB writeback_tmp:0kB unstable:0kB all_unreclaimable? yes
                    ! [64365.189360] Normal free:19360kB min:16384kB low:20480kB high:24576kB active_anon:444492kB inactive_anon:444700kB active_file:368kB inactive_file:1316kB unevictable:0kB writepending:0kB present:970752kB managed:949448kB mlocked:0kB kernel_stack:2224kB pagetables:9424kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:4288kB
                    ! [64365.189362] lowmem_reserve[]: 0 0
                    ! [64365.189370] Normal: 6034kB (UMEC) 2208kB (UMEC) 13916kB (UMEC) 7132kB (UMEC) 4364kB (UEC) 23128kB (UEC) 9256kB (UEC) 6512kB (UEC) 01024kB 02048kB 04096kB = 19740kB
                    ! [64365.189413] 2744 total pagecache pages
                    ! [64365.189417] 3 pages in swap cache
                    ! [64365.189421] Swap cache stats: add 46167, delete 46164, find 23116/33802
                    ! [64365.189423] Free swap = 0kB
                    ! [64365.189425] Total swap = 102396kB
                    ! [64365.189428] 242688 pages RAM
                    ! [64365.189430] 0 pages HighMem/MovableOnly
                    ! [64365.189433] 5326 pages reserved
                    ! [64365.189435] 2048 pages cma reserved
                    ! [64365.189438] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
                    ! [64365.189458] [ 100] 0 100 6731 52 12 0 50 0 systemd-journal
                    ! [64365.189465] [ 127] 0 127 3585 37 8 0 128 -1000 systemd-udevd
                    ! [64365.189472] [ 255] 100 255 4320 15 9 0 95 0 systemd-timesyn
                    ! [64365.189478] [ 292] 0 292 1728 20 7 0 70 0 systemd-logind
                    ! [64365.189484] [ 293] 0 293 1425 15 7 0 39 0 cron
                    ! [64365.189491] [ 297] 105 297 1625 46 8 0 59 -900 dbus-daemon
                    ! [64365.189497] [ 319] 108 319 1633 40 7 0 53 0 avahi-daemon
                    ! [64365.189503] [ 320] 65534 320 1324 4 7 0 56 0 thd
                    ! [64365.189509] [ 321] 0 321 5937 116 13 0 88 0 rsyslogd
                    ! [64365.189516] [ 333] 108 333 1601 3 7 0 74 0 avahi-daemon
                    ! [64365.189522] [ 381] 0 381 2533 44 9 0 94 0 wpa_supplicant
                    ! [64365.189528] [ 495] 0 495 737 57 6 0 46 0 dhcpcd
                    ! [64365.189534] [ 511] 0 511 1150 0 7 0 35 0 agetty
                    ! [64365.189540] [ 517] 0 517 2552 0 8 0 138 -1000 sshd
                    ! [64365.189546] [ 525] 109 525 8546 194 11 0 89 0 redis-server
                    ! [64365.189553] [ 657] 0 657 524 0 4 0 34 0 hciattach
                    ! [64365.189559] [ 664] 0 664 1769 0 7 0 76 0 bluetoothd
                    ! [64365.189565] [ 727] 0 727 37152 7102 93 0 1460 0 iobroker.js-con
                    ! [64365.189571] [ 852] 0 852 34115 5991 94 0 2017 0 io.cloud.0
                    ! [64365.189577] [ 862] 0 862 32342 5729 85 0 1209 0 io.history.0
                    ! [64365.189584] [ 877] 0 877 39440 6980 117 0 7286 0 io.javascript.0
                    ! [64365.189590] [ 883] 0 883 34246 6332 99 0 2267 0 io.alexa2.0
                    ! [64365.189595] [ 893] 0 893 35363 6640 101 0 2189 0 io.admin.0
                    ! [64365.189601] [ 903] 0 903 35329 7980 107 0 1788 0 io.fritzdect.0
                    ! [64365.189607] [ 909] 0 909 31684 5358 87 0 1203 0 io.discovery.0
                    ! [64365.189614] [ 919] 0 919 33364 3744 69 0 722 0 io.web.0
                    ! [64365.189620] [ 925] 0 925 35069 9029 109 0 222 0 io.hs100.0
                    ! [64365.189626] [ 939] 0 939 32939 5030 73 0 500 0 io.rpi2.0
                    ! [64365.189632] [ 949] 0 949 31655 5266 84 0 1253 0 io.yeelight-2.0
                    ! [64365.189638] [ 973] 0 973 32459 6852 90 0 246 0 io.socketio.0
                    ! [64365.189644] [ 983] 0 983 32917 7404 89 0 457 0 io.terminal.0
                    ! [64365.189650] [ 1037] 0 1037 31794 6044 83 0 438 0 io.node-red.0
                    ! [64365.189656] [ 1052] 0 1052 39273 13715 136 0 257 0 node-red
                    ! [64365.189664] [23126] 0 23126 102438 77490 447 0 0 0 io.zigbee.0
                    ! [64365.189670] [23182] 0 23182 56912 31729 246 0 0 0 io.zigbee.0
                    ! [64365.189674] Out of memory: Kill process 23126 (io.zigbee.0) score 287 or sacrifice child
                    ! [64365.189715] Killed process 23126 (io.zigbee.0) total-vm:409752kB, anon-rss:309960kB, file-rss:0kB, shmem-rss:0kB
                    ! [64365.292344] oom_reaper: reaped process 23126 (io.zigbee.0), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                    ! [64567.089171] io.rpi2.0 invoked oom-killer: gfp_mask=0x15080c0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), nodemask=(null), order=1, oom_score_adj=0
                    ! [64567.089185] io.rpi2.0 cpuset=/ mems_allowed=0
                    ! [64567.089199] CPU: 3 PID: 939 Comm: io.rpi2.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64567.089202] Hardware name: BCM2835
                    ! [64567.089223] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64567.089233] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64567.089243] [<80787f24>] (dump_stack) from [<80224574>] (dump_header+0xac/0x208)
                    ! [64567.089253] [<80224574>] (dump_header) from [<802238dc>] (oom_kill_process+0x478/0x584)
                    ! [64567.089261] [<802238dc>] (oom_kill_process) from [<8022423c>] (out_of_memory+0x124/0x334)
                    ! [64567.089271] [<8022423c>] (out_of_memory) from [<80229cf8>] (__alloc_pages_nodemask+0x1060/0x11d8)
                    ! [64567.089283] [<80229cf8>] (__alloc_pages_nodemask) from [<8011b11c>] (copy_process.part.5+0xec/0x1858)
                    ! [64567.089292] [<8011b11c>] (copy_process.part.5) from [<8011ca18>] (_do_fork+0xc8/0x408)
                    ! [64567.089301] [<8011ca18>] (_do_fork) from [<8011ce7c>] (SyS_clone+0x34/0x3c)
                    ! [64567.089310] [<8011ce7c>] (SyS_clone) from [<80108060>] (ret_fast_syscall+0x0/0x28)
                    ! [64567.089314] Mem-Info:
                    ! [64567.089326] active_anon:111046 inactive_anon:111103 isolated_anon:0
                    ! active_file:301 inactive_file:335 isolated_file:0
                    ! unevictable:0 dirty:1 writeback:0 unstable:0
                    ! slab_reclaimable:1578 slab_unreclaimable:2870
                    ! mapped:357 shmem:2198 pagetables:2390 bounce:0
                    ! free:4977 free_pcp:0 free_cma:1179
                    ! [64567.089335] Node 0 active_anon:444184kB inactive_anon:444412kB active_file:1204kB inactive_file:1340kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:1428kB dirty:4kB writeback:0kB shmem:8792kB writeback_tmp:0kB unstable:0kB all_unreclaimable? yes
                    ! [64567.089348] Normal free:19908kB min:16384kB low:20480kB high:24576kB active_anon:444184kB inactive_anon:444412kB active_file:1204kB inactive_file:1368kB unevictable:0kB writepending:4kB present:970752kB managed:949448kB mlocked:0kB kernel_stack:2224kB pagetables:9560kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:4716kB
                    ! [64567.089350] lowmem_reserve[]: 0 0
                    ! [64567.089358] Normal: 517
                    4kB (UMEC) 1808kB (UMEC) 16116kB (UMEC) 7432kB (UMEC) 4764kB (UEC) 24128kB (UEC) 9256kB (UEC) 6512kB (UEC) 01024kB 02048kB 04096kB = 19908kB
                    ! [64567.089402] 2910 total pagecache pages
                    ! [64567.089405] 60 pages in swap cache
                    ! [64567.089409] Swap cache stats: add 46430, delete 46370, find 23597/34443
                    ! [64567.089411] Free swap = 0kB
                    ! [64567.089414] Total swap = 102396kB
                    ! [64567.089416] 242688 pages RAM
                    ! [64567.089419] 0 pages HighMem/MovableOnly
                    ! [64567.089421] 5326 pages reserved
                    ! [64567.089423] 2048 pages cma reserved
                    ! [64567.089426] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
                    ! [64567.089453] [ 100] 0 100 6731 156 12 0 50 0 systemd-journal
                    ! [64567.089461] [ 127] 0 127 3585 37 8 0 128 -1000 systemd-udevd
                    ! [64567.089477] [ 255] 100 255 4320 15 9 0 95 0 systemd-timesyn
                    ! [64567.089486] [ 292] 0 292 1728 20 7 0 70 0 systemd-logind
                    ! [64567.089499] [ 293] 0 293 1425 15 7 0 39 0 cron
                    ! [64567.089510] [ 297] 105 297 1625 46 8 0 59 -900 dbus-daemon
                    ! [64567.089517] [ 319] 108 319 1633 40 7 0 53 0 avahi-daemon
                    ! [64567.089523] [ 320] 65534 320 1324 4 7 0 56 0 thd
                    ! [64567.089529] [ 321] 0 321 5937 116 13 0 88 0 rsyslogd
                    ! [64567.089536] [ 333] 108 333 1601 3 7 0 74 0 avahi-daemon
                    ! [64567.089542] [ 381] 0 381 2533 44 9 0 94 0 wpa_supplicant
                    ! [64567.089548] [ 495] 0 495 737 57 6 0 46 0 dhcpcd
                    ! [64567.089554] [ 511] 0 511 1150 0 7 0 35 0 agetty
                    ! [64567.089560] [ 517] 0 517 2552 0 8 0 138 -1000 sshd
                    ! [64567.089567] [ 525] 109 525 8546 196 11 0 89 0 redis-server
                    ! [64567.089574] [ 657] 0 657 524 0 4 0 34 0 hciattach
                    ! [64567.089580] [ 664] 0 664 1769 0 7 0 76 0 bluetoothd
                    ! [64567.089587] [ 727] 0 727 36763 6248 92 0 1461 0 iobroker.js-con
                    ! [64567.089593] [ 852] 0 852 34115 5959 94 0 2019 0 io.cloud.0
                    ! [64567.089600] [ 862] 0 862 32342 5640 85 0 1210 0 io.history.0
                    ! [64567.089607] [ 877] 0 877 39440 6802 117 0 7286 0 io.javascript.0
                    ! [64567.089616] [ 883] 0 883 34246 6215 99 0 2268 0 io.alexa2.0
                    ! [64567.089630] [ 893] 0 893 35363 6874 102 0 2195 0 io.admin.0
                    ! [64567.089646] [ 903] 0 903 35329 8116 107 0 1717 0 io.fritzdect.0
                    ! [64567.089661] [ 909] 0 909 31684 5234 87 0 1209 0 io.discovery.0
                    ! [64567.089669] [ 919] 0 919 33364 3521 68 0 719 0 io.web.0
                    ! [64567.089675] [ 925] 0 925 35069 9143 109 0 225 0 io.hs100.0
                    ! [64567.089691] [ 939] 0 939 32939 5449 77 0 503 0 io.rpi2.0
                    ! [64567.089703] [ 949] 0 949 31655 5374 84 0 1260 0 io.yeelight-2.0
                    ! [64567.089709] [ 973] 0 973 32459 6732 90 0 253 0 io.socketio.0
                    ! [64567.089715] [ 983] 0 983 33045 7310 90 0 463 0 io.terminal.0
                    ! [64567.089722] [ 1037] 0 1037 31794 6182 83 0 442 0 io.node-red.0
                    ! [64567.089728] [ 1052] 0 1052 39401 13597 137 0 272 0 node-red
                    ! [64567.089737] [23182] 0 23182 106832 78698 469 0 2 0 io.zigbee.0
                    ! [64567.089744] [23283] 0 23283 59566 31183 253 0 0 0 io.zigbee.0
                    ! [64567.089748] Out of memory: Kill process 23182 (io.zigbee.0) score 292 or sacrifice child
                    ! [64567.089784] Killed process 23182 (io.zigbee.0) total-vm:427328kB, anon-rss:314792kB, file-rss:0kB, shmem-rss:0kB
                    ! [64567.189451] oom_reaper: reaped process 23182 (io.zigbee.0), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                    ! [64633.642658] io.zigbee.0 invoked oom-killer: gfp_mask=0x14080c0(GFP_KERNEL|__GFP_ZERO), nodemask=(null), order=0, oom_score_adj=0
                    ! [64633.642673] io.zigbee.0 cpuset=/ mems_allowed=0
                    ! [64633.642690] CPU: 3 PID: 23433 Comm: io.zigbee.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64633.642693] Hardware name: BCM2835
                    ! [64633.642715] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64633.642725] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64633.642736] [<80787f24>] (dump_stack) from [<80224574>] (dump_header+0xac/0x208)
                    ! [64633.642746] [<80224574>] (dump_header) from [<802238dc>] (oom_kill_process+0x478/0x584)
                    ! [64633.642755] [<802238dc>] (oom_kill_process) from [<8022423c>] (out_of_memory+0x124/0x334)
                    ! [64633.642764] [<8022423c>] (out_of_memory) from [<80229cf8>] (__alloc_pages_nodemask+0x1060/0x11d8)
                    ! [64633.642776] [<80229cf8>] (__alloc_pages_nodemask) from [<80256168>] (__pte_alloc+0x34/0x19c)
                    ! [64633.642785] [<80256168>] (__pte_alloc) from [<80259e34>] (handle_mm_fault+0xb98/0xc20)
                    ! [64633.642794] [<80259e34>] (handle_mm_fault) from [<807a458c>] (do_page_fault+0x330/0x3a4)
                    ! [64633.642802] [<807a458c>] (do_page_fault) from [<807a46bc>] (do_translation_fault+0xbc/0xc0)
                    ! [64633.642811] [<807a46bc>] (do_translation_fault) from [<801011e0>] (do_DataAbort+0x48/0xc4)
                    ! [64633.642818] [<801011e0>] (do_DataAbort) from [<807a3da4>] (__dabt_usr+0x44/0x60)
                    ! [64633.642823] Exception stack(0x9e005fb0 to 0x9e005ff8)
                    ! [64633.642828] 5fa0: 02989b08 56e80000 00080000 56e04100
                    ! [64633.642834] 5fc0: 56e00000 00000000 0007bf00 56e00000 0007bf00 56e04100 02989af8 7e8bdd14
                    ! [64633.642840] 5fe0: 02a02c1b 7e8bdcf8 00a266a8 00a1d464 20000010 ffffffff
                    ! [64633.642843] Mem-Info:
                    ! [64633.642855] active_anon:110626 inactive_anon:110673 isolated_anon:0
                    ! active_file:284 inactive_file:889 isolated_file:32
                    ! slab_reclaimable:1561 slab_unreclaimable:2847
                    ! mapped:942 shmem:2190 pagetables:2353 bounce:0
                    ! free:5119 free_pcp:22 free_cma:1430
                    ! [64633.642864] Node 0 active_anon:442504kB inactive_anon:442692kB active_file:1136kB inactive_file:3556kB unevictable:0kB isolated(anon):0kB isolated(file):128kB mapped:3768kB dirty:0kB writeback:0kB shmem:8760kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
                    ! [64633.642877] Normal free:20476kB min:16384kB low:20480kB high:24576kB active_anon:442760kB inactive_anon:442492kB active_file:384kB inactive_file:4032kB unevictable:0kB writepending:0kB present:970752kB managed:949448kB mlocked:0kB kernel_stack:2224kB pagetables:9412kB bounce:0kB free_pcp:88kB local_pcp:0kB free_cma:5720kB
                    ! [64633.642879] lowmem_reserve[]: 0 0
                    ! [64633.642887] Normal: 1894kB (UMEHC) 1748kB (UMEHC) 15716kB (UMEHC) 8232kB (UMEHC) 6064kB (UMHC) 35128kB (UMHC) 9256kB (UHC) 6512kB (UHC) 01024kB 02048kB 04096kB = 20980kB
                    ! [64633.642930] 3519 total pagecache pages
                    ! [64633.642934] 83 pages in swap cache
                    ! [64633.642938] Swap cache stats: add 46886, delete 46803, find 24208/35234
                    ! [64633.642940] Free swap = 0kB
                    ! [64633.642943] Total swap = 102396kB
                    ! [64633.642945] 242688 pages RAM
                    ! [64633.642948] 0 pages HighMem/MovableOnly
                    ! [64633.642950] 5326 pages reserved
                    ! [64633.642952] 2048 pages cma reserved
                    ! [64633.642956] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
                    ! [64633.642975] [ 100] 0 100 6731 157 12 0 51 0 systemd-journal
                    ! [64633.642982] [ 127] 0 127 3585 37 8 0 128 -1000 systemd-udevd
                    ! [64633.642989] [ 255] 100 255 4320 15 9 0 95 0 systemd-timesyn
                    ! [64633.642996] [ 292] 0 292 1728 20 7 0 70 0 systemd-logind
                    ! [64633.643003] [ 293] 0 293 1425 15 7 0 39 0 cron
                    ! [64633.643010] [ 297] 105 297 1625 46 8 0 59 -900 dbus-daemon
                    ! [64633.643016] [ 319] 108 319 1633 40 7 0 53 0 avahi-daemon
                    ! [64633.643022] [ 320] 65534 320 1324 4 7 0 56 0 thd
                    ! [64633.643028] [ 321] 0 321 5937 116 13 0 88 0 rsyslogd
                    ! [64633.643034] [ 333] 108 333 1601 3 7 0 74 0 avahi-daemon
                    ! [64633.643040] [ 381] 0 381 2533 44 9 0 94 0 wpa_supplicant
                    ! [64633.643046] [ 495] 0 495 737 59 6 0 46 0 dhcpcd
                    ! [64633.643052] [ 511] 0 511 1150 0 7 0 35 0 agetty
                    ! [64633.643058] [ 517] 0 517 2552 0 8 0 138 -1000 sshd
                    ! [64633.643064] [ 525] 109 525 8546 195 11 0 89 0 redis-server
                    ! [64633.643071] [ 657] 0 657 524 0 4 0 34 0 hciattach
                    ! [64633.643077] [ 664] 0 664 1769 0 7 0 76 0 bluetoothd
                    ! [64633.643083] [ 727] 0 727 36763 6459 91 0 1459 0 iobroker.js-con
                    ! [64633.643090] [ 852] 0 852 34115 5955 94 0 2030 0 io.cloud.0
                    ! [64633.643096] [ 862] 0 862 32342 5792 85 0 1211 0 io.history.0
                    ! [64633.643103] [ 877] 0 877 39568 6998 118 0 7300 0 io.javascript.0
                    ! [64633.643109] [ 883] 0 883 34246 6310 99 0 2183 0 io.alexa2.0
                    ! [64633.643115] [ 893] 0 893 35363 6980 102 0 2186 0 io.admin.0
                    ! [64633.643121] [ 903] 0 903 35329 8017 107 0 1730 0 io.fritzdect.0
                    ! [64633.643128] [ 909] 0 909 31684 5307 87 0 1219 0 io.discovery.0
                    ! [64633.643134] [ 919] 0 919 33364 3617 68 0 720 0 io.web.0
                    ! [64633.643139] [ 925] 0 925 35069 9053 109 0 236 0 io.hs100.0
                    ! [64633.643146] [ 939] 0 939 32939 5701 78 0 493 0 io.rpi2.0
                    ! [64633.643151] [ 949] 0 949 31706 5203 84 0 1252 0 io.yeelight-2.0
                    ! [64633.643157] [ 973] 0 973 32459 6795 90 0 272 0 io.socketio.0
                    ! [64633.643164] [ 983] 0 983 33045 7376 90 0 481 0 io.terminal.0
                    ! [64633.643170] [ 1037] 0 1037 31794 6033 83 0 454 0 io.node-red.0
                    ! [64633.643175] [ 1052] 0 1052 39401 13684 137 0 300 0 node-red
                    ! [64633.643184] [23283] 0 23283 103086 75901 435 0 0 0 io.zigbee.0
                    ! [64633.643191] [23433] 0 23433 57149 32211 249 0 0 0 io.zigbee.0
                    ! [64633.643194] Out of memory: Kill process 23283 (io.zigbee.0) score 281 or sacrifice child
                    ! [64633.643235] Killed process 23283 (io.zigbee.0) total-vm:412344kB, anon-rss:303604kB, file-rss:0kB, shmem-rss:0kB
                    ! [64633.735530] oom_reaper: reaped process 23283 (io.zigbee.0), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                    ! [64701.583354] io.zigbee.0 invoked oom-killer: gfp_mask=0x14080c0(GFP_KERNEL|__GFP_ZERO), nodemask=(null), order=0, oom_score_adj=0
                    ! [64701.583368] io.zigbee.0 cpuset=/ mems_allowed=0
                    ! [64701.583385] CPU: 2 PID: 23488 Comm: io.zigbee.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64701.583388] Hardware name: BCM2835
                    ! [64701.583411] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64701.583420] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64701.583431] [<80787f24>] (dump_stack) from [<80224574>] (dump_header+0xac/0x208)
                    ! [64701.583440] [<80224574>] (dump_header) from [<802238dc>] (oom_kill_process+0x478/0x584)
                    ! [64701.583449] [<802238dc>] (oom_kill_process) from [<8022423c>] (out_of_memory+0x124/0x334)
                    ! [64701.583459] [<8022423c>] (out_of_memory) from [<80229cf8>] (__alloc_pages_nodemask+0x1060/0x11d8)
                    ! [64701.583469] [<80229cf8>] (__alloc_pages_nodemask) from [<80256168>] (__pte_alloc+0x34/0x19c)
                    ! [64701.583478] [<80256168>] (__pte_alloc) from [<80259e34>] (handle_mm_fault+0xb98/0xc20)
                    ! [64701.583487] [<80259e34>] (handle_mm_fault) from [<807a458c>] (do_page_fault+0x330/0x3a4)
                    ! [64701.583494] [<807a458c>] (do_page_fault) from [<807a46bc>] (do_translation_fault+0xbc/0xc0)
                    ! [64701.583502] [<807a46bc>] (do_translation_fault) from [<801011e0>] (do_DataAbort+0x48/0xc4)
                    ! [64701.583510] [<801011e0>] (do_DataAbort) from [<807a3da4>] (__dabt_usr+0x44/0x60)
                    ! [64701.583514] Exception stack(0x93119fb0 to 0x93119ff8)
                    ! [64701.583519] 9fa0: 02423b08 5ec00000 00080000 5eb84100
                    ! [64701.583525] 9fc0: 5eb80000 00000000 0007bf00 5eb80000 0007bf00 5eb84100 02423af8 7ecbad64
                    ! [64701.583531] 9fe0: 02462b5b 7ecbad48 00a266a8 00a1d464 20000010 ffffffff
                    ! [64701.583534] Mem-Info:
                    ! [64701.583546] active_anon:110659 inactive_anon:110709 isolated_anon:0
                    ! active_file:288 inactive_file:794 isolated_file:0
                    ! slab_reclaimable:1588 slab_unreclaimable:2855
                    ! mapped:801 shmem:2190 pagetables:2339 bounce:0
                    ! free:5391 free_pcp:0 free_cma:1479
                    ! [64701.583555] Node 0 active_anon:442636kB inactive_anon:442836kB active_file:1152kB inactive_file:3176kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:3204kB dirty:0kB writeback:0kB shmem:8760kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
                    ! [64701.583567] Normal free:21564kB min:16384kB low:20480kB high:24576kB active_anon:442636kB inactive_anon:442836kB active_file:1152kB inactive_file:3176kB unevictable:0kB writepending:0kB present:970752kB managed:949448kB mlocked:0kB kernel_stack:2216kB pagetables:9356kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:5916kB
                    ! [64701.583569] lowmem_reserve[]: 0 0
                    ! [64701.583577] Normal: 369
                    4kB (UMEHC) 1678kB (UMEHC) 18616kB (UMEHC) 8332kB (UMHC) 5164kB (UMHC) 33128kB (UMHC) 10256kB (UMHC) 6512kB (UHC) 01024kB 02048kB 04096kB = 21564kB
                    ! [64701.583620] 3401 total pagecache pages
                    ! [64701.583624] 122 pages in swap cache
                    ! [64701.583628] Swap cache stats: add 46962, delete 46840, find 24459/35515
                    ! [64701.583630] Free swap = 0kB
                    ! [64701.583632] Total swap = 102396kB
                    ! [64701.583635] 242688 pages RAM
                    ! [64701.583637] 0 pages HighMem/MovableOnly
                    ! [64701.583640] 5326 pages reserved
                    ! [64701.583642] 2048 pages cma reserved
                    ! [64701.583645] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
                    ! [64701.583663] [ 100] 0 100 6731 163 12 0 51 0 systemd-journal
                    ! [64701.583670] [ 127] 0 127 3585 37 8 0 128 -1000 systemd-udevd
                    ! [64701.583677] [ 255] 100 255 4320 15 9 0 95 0 systemd-timesyn
                    ! [64701.583683] [ 292] 0 292 1728 20 7 0 70 0 systemd-logind
                    ! [64701.583689] [ 293] 0 293 1425 15 7 0 39 0 cron
                    ! [64701.583695] [ 297] 105 297 1625 46 8 0 59 -900 dbus-daemon
                    ! [64701.583702] [ 319] 108 319 1633 40 7 0 53 0 avahi-daemon
                    ! [64701.583708] [ 320] 65534 320 1324 4 7 0 56 0 thd
                    ! [64701.583714] [ 321] 0 321 5937 116 13 0 88 0 rsyslogd
                    ! [64701.583720] [ 333] 108 333 1601 3 7 0 74 0 avahi-daemon
                    ! [64701.583726] [ 381] 0 381 2533 44 9 0 94 0 wpa_supplicant
                    ! [64701.583732] [ 495] 0 495 737 57 6 0 46 0 dhcpcd
                    ! [64701.583737] [ 511] 0 511 1150 0 7 0 35 0 agetty
                    ! [64701.583743] [ 517] 0 517 2552 0 8 0 138 -1000 sshd
                    ! [64701.583749] [ 525] 109 525 8546 196 11 0 89 0 redis-server
                    ! [64701.583756] [ 657] 0 657 524 0 4 0 34 0 hciattach
                    ! [64701.583762] [ 664] 0 664 1769 0 7 0 76 0 bluetoothd
                    ! [64701.583768] [ 727] 0 727 38795 8620 99 0 1451 0 iobroker.js-con
                    ! [64701.583774] [ 852] 0 852 34115 5779 94 0 2032 0 io.cloud.0
                    ! [64701.583780] [ 862] 0 862 32342 5628 85 0 1214 0 io.history.0
                    ! [64701.583786] [ 877] 0 877 39568 6827 118 0 7302 0 io.javascript.0
                    ! [64701.583792] [ 883] 0 883 34246 6137 99 0 2186 0 io.alexa2.0
                    ! [64701.583798] [ 893] 0 893 35363 7036 102 0 2188 0 io.admin.0
                    ! [64701.583805] [ 903] 0 903 35329 7955 107 0 1709 0 io.fritzdect.0
                    ! [64701.583811] [ 909] 0 909 31684 5136 87 0 1220 0 io.discovery.0
                    ! [64701.583817] [ 919] 0 919 33364 3667 68 0 722 0 io.web.0
                    ! [64701.583824] [ 925] 0 925 35069 6776 82 0 221 0 io.hs100.0
                    ! [64701.583830] [ 939] 0 939 32939 5880 78 0 493 0 io.rpi2.0
                    ! [64701.583836] [ 949] 0 949 31706 5263 84 0 1253 0 io.yeelight-2.0
                    ! [64701.583842] [ 973] 0 973 32459 6852 90 0 275 0 io.socketio.0
                    ! [64701.583849] [ 983] 0 983 33045 7422 90 0 489 0 io.terminal.0
                    ! [64701.583854] [ 1037] 0 1037 31794 6083 83 0 459 0 io.node-red.0
                    ! [64701.583860] [ 1052] 0 1052 39401 13694 137 0 303 0 node-red
                    ! [64701.583868] [23433] 0 23433 104253 79303 461 0 0 0 io.zigbee.0
                    ! [64701.583873] [23488] 0 23488 54862 29458 228 0 0 0 io.zigbee.0
                    ! [64701.583877] Out of memory: Kill process 23433 (io.zigbee.0) score 294 or sacrifice child
                    ! [64701.583923] Killed process 23433 (io.zigbee.0) total-vm:417012kB, anon-rss:316404kB, file-rss:808kB, shmem-rss:0kB
                    ! [64701.723208] oom_reaper: reaped process 23433 (io.zigbee.0), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                    ! [64775.045170] io.zigbee.0 invoked oom-killer: gfp_mask=0x14080c0(GFP_KERNEL|__GFP_ZERO), nodemask=(null), order=0, oom_score_adj=0
                    ! [64775.045184] io.zigbee.0 cpuset=/ mems_allowed=0
                    ! [64775.045199] CPU: 3 PID: 23543 Comm: io.zigbee.0 Tainted: G C 4.14.71-v7+ #1145
                    ! [64775.045202] Hardware name: BCM2835
                    ! [64775.045225] [<8010ffd4>] (unwind_backtrace) from [<8010c240>] (show_stack+0x20/0x24)
                    ! [64775.045235] [<8010c240>] (show_stack) from [<80787f24>] (dump_stack+0xd4/0x118)
                    ! [64775.045246] [<80787f24>] (dump_stack) from [<80224574>] (dump_header+0xac/0x208)
                    ! [64775.045255] [<80224574>] (dump_header) from [<802238dc>] (oom_kill_process+0x478/0x584)
                    ! [64775.045263] [<802238dc>] (oom_kill_process) from [<8022423c>] (out_of_memory+0x124/0x334)
                    ! [64775.045273] [<8022423c>] (out_of_memory) from [<80229cf8>] (__alloc_pages_nodemask+0x1060/0x11d8)
                    ! [64775.045285] [<80229cf8>] (__alloc_pages_nodemask) from [<80256168>] (__pte_alloc+0x34/0x19c)
                    ! [64775.045294] [<80256168>] (__pte_alloc) from [<80259e34>] (handle_mm_fault+0xb98/0xc20)
                    ! [64775.045302] [<80259e34>] (handle_mm_fault) from [<807a458c>] (do_page_fault+0x330/0x3a4)
                    ! [64775.045310] [<807a458c>] (do_page_fault) from [<807a46bc>] (do_translation_fault+0xbc/0xc0)
                    ! [64775.045317] [<807a46bc>] (do_translation_fault) from [<801011e0>] (do_DataAbort+0x48/0xc4)
                    ! [64775.045325] [<801011e0>] (do_DataAbort) from [<807a3da4>] (__dabt_usr+0x44/0x60)
                    ! [64775.045329] Exception stack(0xaa703fb0 to 0xaa703ff8)
                    ! [64775.045334] 3fa0: 018ceb08 57e00000 00080000 57d84100
                    ! [64775.045340] 3fc0: 57d80000 00000000 0007bf00 57d80000 0007bf00 57d84100 018ceaf8 7ee68d64
                    ! [64775.045346] 3fe0: 0198a973 7ee68d48 00a266a8 00a1d464 20000010 ffffffff
                    ! [64775.045349] Mem-Info:
                    ! [64775.045361] active_anon:110740 inactive_anon:110747 isolated_anon:0
                    ! active_file:162 inactive_file:1001 isolated_file:0
                    ! slab_reclaimable:1580 slab_unreclaimable:2834
                    ! mapped:808 shmem:2190 pagetables:2349 bounce:0
                    ! free:5168 free_pcp:0 free_cma:1371
                    • a200
                      a200 last edited by
                      ok, das ist eindeutig zu viel. leider habe ich nichts mit usb gefunden. ich würde deinen Raspi rebooten (das macht die Sache übersichtlicher, geht aber auch ohne) und danach:
                      sudo dmesg | grep -i usb
                      eingeben. Dort muss u.a. irgendwas wie sowas geben:
                      [    3.685113] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
                      [    3.855178] usb 1-1.4: New USB device found, idVendor=0451, idProduct=16a8
                      [    3.857812] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                      [    3.860448] usb 1-1.4: Product: TI CC2531 USB CDC
                      [    3.863017] usb 1-1.4: Manufacturer: Texas Instruments
                      [    3.865568] usb 1-1.4: SerialNumber: __0X00124B0023D9DE7D
                      [   14.927148] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
                      [   14.929257] usbcore: registered new interface driver cdc_acm
                      [   14.929266] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                      [   16.225431] usbcore: registered new interface driver usbserial
                      [   16.225512] usbcore: registered new interface driver usbserial_generic
                      [   16.225586] usbserial: USB Serial support registered for generic
                      [   16.254110] usbcore: registered new interface driver pl2303
                      [   16.254204] usbserial: USB Serial support registered for pl2303
                      Hier sieht man, dass ein TI CC2531 USB erkannt wurde (1-1.4 <- hängt vom USB Port ab, an dem der Stick steckt) und bekam ttyACM0 zugewiesen.
                      Poste mal deine Ausgabe
                        DeeJayDave last edited by
                        Ok, Raspi neu gestartet, Befehl eingegeben und folgendes erhalten:
                        ! [ 0.063552] usbcore: registered new interface driver usbfs
                        ! [ 0.063622] usbcore: registered new interface driver hub
                        ! [ 0.063723] usbcore: registered new device driver usb
                        ! [ 0.238264] usbcore: registered new interface driver lan78xx
                        ! [ 0.240589] usbcore: registered new interface driver smsc95xx
                        ! [ 0.272836] dwc_otg 3f980000.usb: base=0xf0980000
                        ! [ 0.710982] dwc_otg 3f980000.usb: DWC OTG Controller
                        ! [ 0.713169] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
                        ! [ 0.715490] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
                        ! [ 0.722457] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
                        ! [ 0.724768] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
                        ! [ 0.727068] usb usb1: Product: DWC OTG Controller
                        ! [ 0.729311] usb usb1: Manufacturer: Linux 4.14.71-v7+ dwc_otg_hcd
                        ! [ 0.731609] usb usb1: SerialNumber: 3f980000.usb
                        ! [ 0.734470] hub 1-0:1.0: USB hub found
                        ! [ 0.739515] usbcore: registered new interface driver usb-storage
                        ! [ 0.786088] usbcore: registered new interface driver usbhid
                        ! [ 0.788394] usbhid: USB HID core driver
                        ! [ 1.161428] usb 1-1: new high-speed USB device number 2 using dwc_otg
                        ! [ 1.401687] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
                        ! [ 1.403964] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                        ! [ 1.406761] hub 1-1:1.0: USB hub found
                        ! [ 1.731436] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
                        ! [ 1.871694] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
                        ! [ 1.873868] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
                        ! [ 1.876642] hub 1-1.1:1.0: USB hub found
                        ! [ 1.981461] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
                        ! [ 2.128201] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8
                        ! [ 2.130844] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber =3
                        ! [ 2.133536] usb 1-1.3: Product: TI CC2531 USB CDC
                        ! [ 2.136103] usb 1-1.3: Manufacturer: Texas Instruments
                        ! [ 2.138687] usb 1-1.3: SerialNumber: __0XD0B5C2ED66BDFFFF
                        ! [ 2.651467] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
                        ! [ 2.782090] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
                        ! [ 2.784811] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumb er=0
                        ! [ 3.918028] usbcore: registered new interface driver brcmfmac
                        ! [ 4.006887] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                        ! [ 4.010423] usbcore: registered new interface driver cdc_acm
                        ! [ 4.010434] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
                          piscator83 last edited by
                          @arteck:
                          @piscator83:
                          Hallo alle zusammen!
                          Neu hier, also bitte nicht beißen! 🙂
                          Vllt. bin ich auch zu blöd, aber könnte es sein, dass diese LED noch nicht funktioniert?
                          An/Aus; Farben; Warm/Kalt, Dimmen kann das Ding laut Verpackung.
                          lg `
                          installier mal Repo.. danach sollte es gehen `
                          Repo installiert inkl. Upload…kein Erfolg.
                          Mit adapter aus, objekt löschen, adapter ein. Kein erfolg.
                          Instanz und adapter deinstalliert und neu installiert. Kein erfolg.
                          Bleibt bei ? in der Instanz und eine Zeile bei den Objekten
                          Mache ich noch was falsch?
                            Im Log scheint aber ein Eintrag über Osram Smart+ GU10 auf. Das wäre das richtige Gerät
                            • a200
                              a200 last edited by
                              @DeeJayDave:
                              ! [ 4.010434] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters `
                              Das sind die wichtigen Infos. Du musst den ZigBee Adapter auf /dev/ttyACM0 einstellen.
                              danach schau mal, was im log zu zigbee steht. Gut testen kann man den Stick, in dem du die LED ein- und ausschaltest. Also den Status ändern z.B. auf aus und dann speichern und verlassen. Die LED auf dem Stick müsste dann ausgehen. Gleichzeitig solltest du Infos im Log haben.
                                @a200:
                                @DeeJayDave:
                                danach schau mal, was im log zu zigbee steht. Gut testen kann man den Stick, in dem du die LED ein- und ausschaltest. Also den Status ändern z.B. auf aus und dann speichern und verlassen. Die LED auf dem Stick müsste dann ausgehen. Gleichzeitig solltest du Infos im Log haben. `
                                Es verhält sich bei mir so, dass wenn ich den Stick einstecke, die LED für 45 Sekunden leuchtet und dann aus geht (ohne was zu machen). Selbst wenn ich in diesen 45 Sekunden die LED ausschalte, leuchtet sie am Stick weiter.
                                ! host.Raspberry 2018-10-31 21:41:47.797 info instance system.adapter.zigbee.0 started with pid 1102
                                ! host.Raspberry 2018-10-31 21:41:47.776 info object change system.adapter.zigbee.0
                                ! host.Raspberry 2018-10-31 21:41:38.291 info instance system.adapter.zigbee.0 terminated with code 0 (OK)
                                ! Caught 2018-10-31 21:41:38.290 error by controller[4]: Wed, 31 Oct 2018 20:41:35 GMT zigbee-shepherd:init zigbee-shepherd booting…
                                ! Caught 2018-10-31 21:41:38.290 error by controller[3]: 2018-10-31T20:41:30.822Z zigbee:controller info zigbee-shepherd stopped undefined
                                ! Caught 2018-10-31 21:41:38.290 error by controller[2]: Wed, 31 Oct 2018 20:41:30 GMT zigbee-shepherd zigbee-shepherd is stopped.
                                ! Caught 2018-10-31 21:41:38.289 error by controller[1]: Wed, 31 Oct 2018 20:41:30 GMT zigbee-shepherd zigbee-shepherd is stopping.
                                ! Caught 2018-10-31 21:41:38.288 error by controller[0]: Wed, 31 Oct 2018 20:41:30 GMT zigbee-shepherd:init zigbee-shepherd booting…
                                ! zigbee.0 2018-10-31 21:41:35.235 info Start on port: /dev/ttyACM0 with panID 6754 channel 11
                                ! zigbee.0 2018-10-31 21:41:35.228 info starting. Version 0.7.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.12.0
                                ! zigbee.0 2018-10-31 21:41:35.121 info States connected to redis: 127.0.0.1:6379
                                  installiere den adapter mal neu
                                  • a200
                                    a200 last edited by
                                    @DeeJayDave:
                                    @a200:
                                    ! zigbee.0 2018-10-31 21:41:35.121 info States connected to redis: 127.0.0.1:6379 `
                                    ok, da kann ich leider nicht mehr helfen. könnte an deinen Stick liegen, aber da sollten Profis wie @arteck ran. Du solltest für den Adapter den Loglevel auf debug stellen. Dann wird man mehr sehen können.
                                      @arteck:
                                      installiere den adapter mal neu `
                                      Den Adapter habe ich gefühlt 50 neu installiert 😕
                                        @piscator83:
                                        @arteck:
                                        @piscator83:
                                        lg `
                                        Mache ich noch was falsch? `
                                        2. Birne liefert selbes Ergebnis 😞
                                          @DeeJayDave:
                                          @arteck:
                                          Den Adapter habe ich gefühlt 50 neu installiert 😕 `
                                          wo ist jetzt das Problem ???
                                            Micky79 last edited by
                                            Hallo an Alle,
                                            ich habe gerade eben, weil mein Lightify Gateway den Geist aufgegeben hab, den CC2531 geflasht und in Betrieb genommen.
                                            Ich habe zwei Lightify Devices. Eine RGB Color Einschraub-Glühbirne und eine Surface Deckenlampe.
                                            Wie ich schon vermutet habe, wurde die RGB Glühbirne einwandfrei gefunden.
                                            Die Surface Deckenlampe jedoch kann nicht konfiguriert werden.
                                            Ich habe ein Screenshot beigefügt. Es wäre wirklich super, wenn man diese auch zum laufen bekommen würde.
                                            Die Deckenlampe kann nur Ein/Aus und dimmen. Mehr nicht.
                                            Viele Grüße Micky
                                            1078
                                            345471
