    4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
    • SBorg
      Ah, sorry…
      <code>tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"led_switch\",\"name\":\"埀关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"樥埮\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"],\"type\":\"enum\"},\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"bright_value\",\"name\":\"于庌\",\"property\":{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"temp_value\",\"name\":\"冡汖\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彊光樥埮数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":5,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"情景樥埮数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":6,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"flash_scene_1\",\"name\":\"滔光樥埮\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":7,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_2\",\"name\":\"矤纡樥埮\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":8,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_3\",\"name\":\"炍彊樥埮\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":9,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_4\",\"name\":\"斑斓樥埮\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":10,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[]"}[/code]</code>
        Michi68 last edited by
        Danke für den nächsten schönen Adapter 🙂
        2018-11-03 03:47:21.375  - [32minfo[39m: tuya.0 new Shema added for product type 2fISFtnNO1j4GWU4\. Please send next line from logfile on disk to developer!
        2018-11-03 03:47:21.376  - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"led_switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"bright_value\",\"name\":\"亮度\",\"property\":{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_sun\",\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"temp_value\",\"name\":\"冷暖\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_light\",\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光模式数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":5,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"情景模式数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":6,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"flash_scene_1\",\"name\":\"柔光模式\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":7,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_2\",\"name\":\"缤纷模式\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":8,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_3\",\"name\":\"炫彩模式\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":9,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_4\",\"name\":\"斑斓模式\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":10,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[{\"id\":1,\"inputType\":\"plain\"},{\"id\":2,\"inputType\":\" \"},{\"id\":3,\"inputType\":\"percent\"},{\"id\":4,\"inputType\":\" \"}]"}
        Ist ein <url url="https://www.amazon.de/Luminea-Zubehör-Streifen-Alexa-WLAN-Controller/dp/B074SXSB5F/ref=sr_1_4?s=lighting&ie=UTF8&qid=1541271061&sr=1-4&keywords=Luminea">~~[url=https://www.amazon.de/Luminea-Zubeh%C3%B6r-Streifen-Alexa-WLAN-Controller/dp/B074SXSB5F/ref=sr_1_4?s=lighting&ie=UTF8&qid=1541271061&sr=1-4&keywords=Luminea
        ]~~Luminea WLAN-Controller (LED Serie LAC)</url>
        Gruß Michael
          @sigi234:
          Danke apollon77
          für den tollen Adapter,
          na dann fange ich mal an mit folgenden Gerät das funktioniert:
          OxaOxe smart WLAN Steckdose 2 in 1, 16A 3520W, Einzel-/Gruppensteuerung, Überlastschutz, Energieüberwachung, Timer und Zeitpläne, 2-Fach intelligente Steckdose kompatibel mit Alexa Google und IFTTT
          APP: Smart-Life App
          https://www.amazon.de/gp/product/B07G2J … UTF8&psc=1 `
          Hallo apollon77, wie bekomme ich den Wert in total vom Bild unten in den Adapter?
          Könnte das dieser Wert sein?
            apollon77 last edited by
            Keine Ahnung. Es kann auch Gut sein das dieser Wert nur in der tuya Cloud errechnet wird oder so.
            Gesendet vom Handy …
              PerfectAnswer last edited by
              Moin Zusammen,
              ich habe mir bei amazon diesen 4er-Pack WLAN-Steckdosen gekauft (https://www.amazon.de/gp/product/B07B91 … UTF8&psc=1)
              die funktionieren grundsätzlich schon so dass ich auswerten kann.
              Values die ausgegeben werden sind mA, mW, mV, IP, Online?, ein- oder ausgeschaltet. Kumulierte Werte wie in der App gibt es nicht, muss ich auch nicht zwingend haben.
              Da als Werte aktuell nur Guids ausgelesen werden, habe die mit normalen Namen überschrieben (z.B. Trockner oder WaMa) und die einzelnen Values mit (mA),(mW) etc. bezeichnet. blöderweise werden diese Werte dann aber regelmäßig wieder überschrieben (Siehe Screenshot).
              Wie kann ich unterstützen um die Werte dauerhaft zu speichern?
              • Elzershark
                Elzershark last edited by
                Gibt es nicht eine Möglichkeit den Proxy auf ein Android einzustellen? Oder geht das nur mit einem Apple Handy wenn man die Geräte auch mal steuern möchte?
                  @PerfectAnswer:
                  Moin Zusammen,
                  filename="tuya.JPG" index="0">~~ `
                  Namen werden mit dem überschrieben was im Schema definiert ist. Die Einheit sollte soweit schon hinten beim Wert stehen.
                  Mit der App syncen und es stehen mal grob sinnvolle Namen drin. Und ja wird aktuell überschrieben … ich kann mal nachdenken. Bitte lege in GitHub issue als Feature request an. Danke
                  Gesendet vom Handy ...
                    @Elzershark:
                    Gibt es nicht eine Möglichkeit den Proxy auf ein Android einzustellen? Oder geht das nur mit einem Apple Handy wenn man die Geräte auch mal steuern möchte? `
                    Na klar geht das. Wo steht das es nur mit iOS tut? Habe nur kein android device und daher keine Screenshots. Gern machen Screenshots schicken. Dann nehme ich das in die Doku auf.
                    • Elzershark
                      • Elzershark
                        5 min. später hab ich die Einstellungen gefunden.. <emoji seq="1f602">😂</emoji>
                          @Elzershark:
                          filename="Android-Proxy-einrichten-rcm992x0.jpg" index="0">~~ `
                          Darf ich das Bild in die adapter Doku übernehmen?
                          • Elzershark
                            Gerne..
                            Alle Geräte die mit der App "io.e" Installiert werden (Luminea, u.s.w.) funktionieren auch mit deinem Adapter
                            • Elzershark
                              Durch deinen Adapter werden alle billigst Geräte integrierbar in ioBroker…
                              Glückwunsch. Hammer Adapter 🙂
                                Schau mal ins log bitte als du den Sync mit der App gemacht hast nach Schemata Infos und send to developer. Dabke
                                • Elzershark
                                  Weiß nicht genau wo man das hin sendet. Also per Mail oder so? Gibt es da n Button? Oder hier per Nachricht?
                                  Aber Log pack ich hier rein:
                                  tuya.0 2018-11-04 21:55:04.303 info 07652000807d3a1da477: Error from device (0): App still open on your mobile phone? Error: Error from socket
                                  tuya.0 2018-11-04 21:54:29.212 info Discover for local Tuya devices on port 6666
                                  tuya.0 2018-11-04 21:54:29.197 info Existing devices initialized
                                  tuya.0 2018-11-04 21:54:29.195 info 0120000660019448d9fe Init with IP=192.168.178.33, Key=44b3f41b3a451109
                                  tuya.0 2018-11-04 21:54:29.191 info 0120000660019448e30f Init with IP=192.168.178.34, Key=2f489f0430013398
                                  tuya.0 2018-11-04 21:54:29.159 info 07652000807d3a1da477 Init with IP=192.168.178.28, Key=0756207f82130213
                                  tuya.0 2018-11-04 21:54:28.723 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.12.0
                                  host.Elzershark 2018-11-04 21:54:24.867 info instance system.adapter.tuya.0 started with pid 4734
                                  host.Elzershark 2018-11-04 21:54:24.844 info object change system.adapter.tuya.0
                                  host.Elzershark 2018-11-04 21:54:06.852 info Restart adapter system.adapter.tuya.0 because enabled
                                  host.Elzershark 2018-11-04 21:54:06.852 error instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
                                  Caught 2018-11-04 21:54:06.852 error by controller[4]: at process._tickCallback (internal/process/next_tick.js:181:9)
                                  Caught 2018-11-04 21:54:06.851 error by controller[4]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
                                  Caught 2018-11-04 21:54:06.851 error by controller[4]: at emitErrorNT (internal/streams/destroy.js:66:8)
                                  Caught 2018-11-04 21:54:06.851 error by controller[4]: at Socket.emit (events.js:211:7)
                                  Caught 2018-11-04 21:54:06.850 error by controller[4]: at emitOne (events.js:116:13)
                                  Caught 2018-11-04 21:54:06.850 error by controller[4]: at Socket.client.on.err (/opt/iobroker/node_modules/tuyapi/index.js:536:16)
                                  Caught 2018-11-04 21:54:06.850 error by controller[4]: at TuyaDevice.emit (events.js:211:7)
                                  Caught 2018-11-04 21:54:06.849 error by controller[4]: at TuyaDevice.knownDevices.(anonymous function).device.on (/opt/iobroker/node_modules/iobroker.tuya/main.js:325:47)
                                  Caught 2018-11-04 21:54:06.849 error by controller[4]: TypeError: Cannot read property 'disconnect' of null
                                  Caught 2018-11-04 21:54:06.848 error by controller[4]: 1<process.argv.length?process.argv[1].replace( 6666/\/g,"/"):"unknown-program");b.arguments="process.argv.slice(2);"undefined"!==typeof" module&&(module.exports="b);process.on("uncaughtExc" caught/2018-11-04/21:54:06.848/error/by/controller[4]:/opt/iobroker/node_modules/brotli/build/encode.js:3/controller[3]:/at/process._tickcallback/(internal/process/next_tick.js:181:9)/21:54:06.847/_combinedtickcallback/next_tick.js:139:11)/emiterrornt/streams/destroy.js:66:8)/socket.emit/(events.js:211:7)/21:54:06.846/emitone/(events.js:116:13)/socket.client.on.err/(/tuyapi/index.js:536:16)/21:54:06.845/tuyadevice.emit/tuyadevice.knowndevices.(anonymous/function).device.on/iobroker.tuya/main.js:325:47)/21:54:06.844/typeerror:/cannot/read/property/'disconnect'/of/null/controller[2]:/[anyproxy/error][2018-11-04/21:53:48]:/error:/getaddrinfo/enotfound/duvvaoxwm/duvvaoxwm:80/21:54:06.843/vbmhgnvoxyoyvu/vbmhgnvoxyoyvu:80/21:54:06.842/controller[1]:/vhpcnwrt/vhpcnwrt:80/tuya.0/21:54:06.755/info/07652000807d3a1da477:/from/device/(4):/app/still/open/on/your/mobile/phone?/socket/21:54:06.727/(3):/21:54:06.723/(2):/21:54:06.719/0120000660019448d9fe:/21:54:06.718/0120000660019448e30f:/21:54:06.622/21:54:06.618/(1):/21:54:06.582/21:54:05.838/21:54:05.834/(0):/21:54:05.832/21:54:05.724/0120000660019448e30f/init/with/ip="192.168.178.34," key="2f489f0430013398" 21:54:05.722/07652000807d3a1da477/21:54:05.720/21:54:05.718/0120000660019448d9fe/21:54:05.716/21:54:05.714/21:54:05.712/21:54:05.631/21:54:05.619/21:54:05.616/21:54:05.602/21:54:05.579/21:54:05.569/21:54:05.566/21:54:05.562/21:53:43.604/21:53:29.992/anyproxy/ready/to/receive/requests/21:53:08.548/no/local/encryption/available,/get/data/using/polling,/controlling/not/possibe./please/sync/app!/21:53:08.543/21:53:07.816/21:53:07.810/21:53:07.181/21:53:07.165/21:53:05.709/discover/for/tuya/devices/port/21:53:05.687/existing/initialized/21:53:05.630/starting./version/0.1.2/in/iobroker.tuya,/node:/v8.12.0<e=""></process.argv.length?process.argv[1].replace(>
                                  IP=192.168.178.28 = 2 Fach Wlan Steckdose .Gibt viele mit verschiedenen Namen. Alle die so aussehen passen [https://amzn.to/2SL6tzw](https://amzn.to/2SL6tzw)
                                  IP=192.168.178.33 + 34 = Luminea E27 Lampe [https://amzn.to/2D1sCE4](https://amzn.to/2D1sCE4)
                                    @Elzershark:
                                    Weiß nicht genau wo man das hin sendet. Also per Mail oder so? Gibt es da n Button? Oder hier per Nachricht? `
                                    PN geht, GitHub issue geht, hier posten geht 🙂 Choose …
                                      @PerfectAnswer, @All
                                      Auf Github gibt es die 0.1.3 des Adapters.
                                      Changelog:
                                      • Weitere Schemata Info hinzugefügt die automatisch erkannt und ausgefüllt werden für neue User
                                      • (@PerfectAnswer) Es sollten jetzt ausser beim App-Sync die Namen der Objekte erhalten bleiben. Beim Sync mit der App werden Sie aber ggf. überschrieben! Bitte ausprobieren!!
                                      • Einige kleinere Fehler die ich in Logs von Euch gesehen habe sind gefixt. Danke!
                                      ich hoffe auf Euer Feedback ob noch alles tut, dann packe ich es für die anderen auf npm
                                      Ansonsten kurzer Status zu den "Nicht immer online Geräten":
                                      Diese geht wohl aktuell nicht so wirklich weil Sie sich nicht wirklich im Netzwerk melden und der Adapter daher nicht weiss wann Sie online sind. Da ich leider kein solches gerät habe ist es schwierig da was zu debuggen 😞
                                      Die Geräte scheinen sich nur in der Tuya Cloud zu melden, den neuen Wert abzugeben und sind wieder offline.
                                      Theoretisch läuft da was mit MQTT aber das müsste jemand mit Wireshark mitschneiden (@arteck Lust? 🙂 ) weil ich so ein gerät nicht habe …
                                      Mal schauen ...
                                      Ingo
                                      • SBorg
                                        Danke fürs Update 🙂
                                        Kurzes Feedback: Bisher keine Fehler entdeckt und tut was er soll thumbs up
                                        • Elzershark
                                          $ ./iobroker upgrade tuya
                                          Update tuya from @0.1.2 to @0.1.3
                                          NPM version: 6.4.1
                                          npm install iobroker.tuya@0.1.3 --production --save --prefix "/opt/iobroker" (System call)
                                          npm
                                          WARN
                                          deprecated
                                          clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
                                          npm
                                          WARN
                                          svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
                                          npm
                                          WARN optional
                                          SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm
                                          WARN notsup
                                          SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.tuya"
                                          npm
                                          WARN deprecated clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
                                          npm
                                          WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                                          npm
                                          WARN
                                          deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                          npm
                                          WARN
                                          deprecated
                                          minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                          npm
                                          WARN
                                          deprecated
                                          minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                          npm
                                          WARN
                                          deprecated
                                          graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                          npm
                                          notice created a lockfile as package-lock.json. You should commit this file.
                                          npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
                                          ! got /opt/iobroker/node_modules/iobroker.tuya/admin
                                          upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                                          upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                                          upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                                          Adapter "tuya" updated
                                          process exited with code 0
                                          Bei mir Warn Hinweise beim upgraden.
                                          Sonst alles OK.
                                          Eventuell noch den "Warn" Hinweis machen, wenn man den Port im W-Lan eingestellt hat, und die Prozedur ist fertig, das man wieder den Port deaktivieren sollte, da sonst das Internet nicht funktioniert im Handy
                                          • Elzershark
                                            Falls Du möchtest:
                                            31.7k
                                            79.8k
                                            547
                                            149286
