    4. [gelöst] sql.0 History zeigt keine negativen Werte
      Bluestar last edited by
      andlich wieder negative Werte und ich sehe was im Log:
      sql.0 2018-10-31 06:11:55.005 info Do not store value "-1.500000 Grad Celsius" for viessmann.0.get.TempKol because no number
      sql.0 2018-10-31 06:11:51.537 info Do not store value "-0.200000 Grad Celsius" for viessmann.0.get.TempA because no number
      sql.0 2018-10-31 06:09:54.978 info Do not store value "-1.500000 Grad Celsius" for viessmann.0.get.TempKol because no number
      sql.0 2018-10-31 06:09:51.529 info Do not store value "-0.300000 Grad Celsius" for viessmann.0.get.TempA because no number
      sql.0 2018-10-31 06:07:54.970 info Do not store value "-1.500000 Grad Celsius" for viessmann.0.get.TempKol because no number
      sql.0 2018-10-31 06:07:51.518 info Do not store value "-0.300000 Grad Celsius" for viessmann.0.get.TempA because no number
      sql.0 2018-10-31 06:05:54.903 info Do not store value "-1.500000 Grad Celsius" for viessmann.0.get.TempKol because no number
      sql.0 2018-10-31 06:05:51.515 info Do not store value "-0.400000 Grad Celsius" for viessmann.0.get.TempA because no number
      sql.0 2018-10-31 06:03:54.906 info Do not store value "-1.500000 Grad Celsius" for viessmann.0.get.TempKol because no number
      sql.0 2018-10-31 06:03:51.504 info Do not store value "-0.500000 Grad Celsius" for viessmann.0.get.TempA because no number
      sql.0 2018-10-31 06:01:54.942 info Do not store value "-1.600000 Grad Celsius" for viessmann.0.get.TempKol because no number
      sql.0 2018-10-31 06:01:51.506 info Do not store value "-0.500000 Grad Celsius" for viessmann.0.get.TempA because no number
      sql.0 2018-10-31 05:59:54.907 info Do not store value "-1.600000 Grad Celsius" for viessmann.0.get.TempKol because no number
      sql.0 2018-10-31 05:59:51.497 info Do not store value "-0.500000 Grad Celsius" for viessmann.0.get.TempA because no number
      im Debug Mode steht dann dazu:
      sql.0 2018-10-31 06:17:55.095 info Do not store value "-1.400000 Grad Celsius" for viessmann.0.get.TempKol because no number
      sql.0 2018-10-31 06:17:55.095 debug Do Automatic Datatype conversion for viessmann.0.get.TempKol
      sql.0 2018-10-31 06:17:55.095 debug Datatype viessmann.0.get.TempKol: Currently: string, StorageType: Number
      sql.0 2018-10-31 06:17:55.093 debug new value received for viessmann.0.get.TempKol, new-value=-1.400000 Grad Celsius, ts=1540963075084, relog=false
      Das hat wohl was mit der automatischen Datentyp Definition zu tun.
        apollon77 last edited by
        Ne das hat damit zu tun das das ein String mit „ Grad Celsius“ ist … bei positiven werten ist das nicht da? Dann sind die Werte schuld.
        Wäre ein issue beim Adapter das es da gefixt wird.
        Gesendet vom Handy ...
          Hallo, genauso sieht es wohl aus. Sobald positive (inkl. 0) Werte erreichrt werden steht das "Grad Celsius" nicht mehr dahinter.
          Ich schau mal nach dem viessmann Adapter…
            Kannste ja ins Issue packen: Denke das hier ist das Problem:
            https://github.com/misanorot/ioBroker.v … in.js#L372
            Das erwartet eine Zahl am Anfang, "-" ist wohl keine Zahl 🙂
            • blauholsten
              blauholsten Developer last edited by
              @apollon77:
              Das erwartet eine Zahl am Anfang, "-" ist wohl keine Zahl 🙂 `
              hi,
              dem ist wohl so :lol: , leider habe ich wenig Ahnung von RegExp :? , das war damals selbst ein PR.
              Wenn mir dort jemand helfen könnte, würde es schneller gehen!
              EDIT:
              Habe mir das gerade nochmal angeschaut und getestet, ich denke der Werte sollte gehen.
              • blauholsten
                @Bluestar:
                Das hat wohl was mit der automatischen Datentyp Definition zu tun. `
                Benutzt du in der Admin Konfig den Punkt: Datenpunktwerte kürzen???
                  @blauholsten:
                  @apollon77:
                  hi,
                  EDIT:
                  Habe mir das gerade nochmal angeschaut und getestet, ich denke der Werte sollte gehen. `
                  Hey, für regex ausprobieren ist https://regex101.com super
                  Gesendet vom Handy …
                    ja der Punkt Datenpunktwerte kürzen ist aktiv. Ist das die Ursache ? Was bewirkt diese Einstellung ?
                      Hbe es eben mal probiert, aber das Ergebnis wird nicht besser, im Gegenteil:
                      sql.0 2018-11-04 11:33:13.237 info Do not store value "0.000000 %" for viessmann.0.get.PumpeDrehzahlSolar because no number
                      sql.0 2018-11-04 11:33:12.917 info Do not store value "0.000000 %" for viessmann.0.get.PumpeDrehzahlIntern because no number
                      sql.0 2018-11-04 11:33:12.790 info Do not store value "0.000000 %" for viessmann.0.get.PumpeDrehzahlM2 because no number
                      sql.0 2018-11-04 11:33:12.644 info Do not store value "0.000000 %" for viessmann.0.get.PumpeStatusM1 because no number
                      sql.0 2018-11-04 11:33:11.621 info Do not store value "0.000000 %" for viessmann.0.get.LeistungIst because no number
                      sql.0 2018-11-04 11:33:11.333 info Do not store value "0.000000 %" for viessmann.0.get.BrennerStatus because no number
                      sql.0 2018-11-04 11:31:13.063 info Do not store value "0.000000 %" for viessmann.0.get.PumpeDrehzahlSolar because no number
                      sql.0 2018-11-04 11:31:12.810 info Do not store value "0.000000 %" for viessmann.0.get.PumpeDrehzahlIntern because no number
                      sql.0 2018-11-04 11:31:12.615 info Do not store value "0.000000 %" for viessmann.0.get.PumpeDrehzahlM2 because no number
                      sql.0 2018-11-04 11:31:12.487 info Do not store value "0.000000 %" for viessmann.0.get.PumpeStatusM1 because no number
                      sql.0 2018-11-04 11:31:11.559 info Do not store value "0.000000 %" for viessmann.0.get.LeistungIst because no number
                      sql.0 2018-11-04 11:31:11.364 info Do not store value "0.000000 %" for viessmann.0.get.BrennerStatus because no number
                      Die Werte waren vorher (mit der Option) in Ordnung und wurden gespeichert.
                      • blauholsten
                        @Bluestar:
                        ja der Punkt Datenpunktwerte kürzen ist aktiv. Ist das die Ursache ? Was bewirkt diese Einstellung ? `
                        Da kann man auswählen ob die Werde die von der Steuerung reinkommen, so bleiben sollen, oder versucht werden soll sie zu kürzen.
                        • blauholsten
                          @Bluestar:
                          Die Werte waren vorher (mit der Option) in Ordnung und wurden gespeichert. `
                          Bitte auch die Option an lassen.
                          Bitte mal von Github installieren, testen und dann Feedback geben.
                          Hoffe es klappt jetzt.
                            Vielen Dank, ich habe jetzt die 0.7.0 installiert. Nun heisst es mal wieder bissl abwarten bis es kalt wird 🙂
                              Wenn sicher ist das nie ein + vorn dran steht ist die neue Regex valide 🙂 Sollte tun
                              • blauholsten
                                @Bluestar:
                                Vielen Dank, ich habe jetzt die 0.7.0 installiert. Nun heisst es mal wieder bissl abwarten bis es kalt wird 🙂 `
                                Nein bitte direkt von GitHub
                                  Ich habe über den Admin von github installiert. Das müsste dann doch die richtige Version sein, oder?
                                  • blauholsten
                                    @Bluestar:
                                    Ich habe über den Admin von github installiert. Das müsste dann doch die richtige Version sein, oder? `
                                    Ja,
                                    Wenn du mir dann ein positives Feedback gibst, mache ich eine neue Version
                                      Endlich hatten wir mal wieder Frost in der Nacht und ja, es funktioniert nun. Vielen Dank!
                                        schreibst Du dann bitte ein "gelöst" in das Subject des threads?! Danke (ersten beitrag editieren dazu)
                                        81.1k
                                        4640
