    4. [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testen
      apollon77 last edited by
      Jupp, das homebridge Modul was funds Inder konfig in das Feld für den npm Namen schreibst, heisst nicht Roomba.
      Da muss homebridge_roomba oder welches Modul du auch immer nehmen willst rein
      Gesendet vom Handy …
      • O
        OliTheo last edited by
        Hallo zusammen.
        Ham bei mir installiert sowie homebridge_devolo
        Es geht, bis es einen Fehler gibt und die Instanz neu startet.
        Hier mal das Problem:
        2018-09-24 23:00:26.847 - [32minfo[39m: ham.0 updateState Schalter-Küche.Schalter-Küche-2.Name: value = /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
        2018-09-24 23:00:26.912 - [31merror[39m: ham.0 uncaught exception: Device has no suitable sensor.
        2018-09-24 23:00:26.913 - [31merror[39m: ham.0 Error: Device has no suitable sensor.
        at Relay2Device.Device.getCurrentValue (/home/pi/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloDevice.js:206:19)
        at Array.HBQubinoRelay2Device.getDevoloCurrentConsumption (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/devices/HBQubinoRelay2Device.js:80:44)
        at Characteristic.DevoloCurrentConsumption.emit (events.js:180:13)
        at Characteristic.DevoloCurrentConsumption.Characteristic.getValue (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/Characteristic.js:163:10)
        at registerEventsForCharacteristic (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:128:28)
        at WrapperBridge.addBridgedAccessory (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:138:17)
        at Server. <anonymous>(/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:399:24)
        at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/util/once.js:16:19
        at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/index.js:71:17
        at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/HBDevoloCentralUnit.js:52:13
        2018-09-24 23:00:26.915 - [32minfo[39m: ham.0 cleaned everything up…
        2018-09-24 23:00:26.928 - [33mwarn[39m: ham.0 Exception: Error: Device has no suitable sensor.
        2018-09-24 23:00:29.581 - [31merror[39m: Caught by controller[0]: [2018-9-24 23:00:13] Plugin /home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
        2018-09-24 23:00:29.582 - [31merror[39m: Caught by controller[1]: [2018-9-24 23:00:15] Plugin /home/pi/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
        2018-09-24 23:00:29.583 - [31merror[39m: Caught by controller[2]: [2018-9-24 23:00:15] Warning: skipping plugin found at '/usr/local/lib/node_modules/homebridge-devolo' since we already loaded the same plugin from '/home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo'.
        2018-09-24 23:00:29.584 - [31merror[39m: Caught by controller[3]: Error: Device has no suitable sensor.
        2018-09-24 23:00:29.584 - [31merror[39m: Caught by controller[3]: at Relay2Device.Device.getCurrentValue (/home/pi/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloDevice.js:206:19)
        2018-09-24 23:00:29.585 - [31merror[39m: Caught by controller[3]: at Array.HBQubinoRelay2Device.getDevoloCurrentConsumption (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/devices/HBQubinoRelay2Device.js:80:44)
        2018-09-24 23:00:29.585 - [31merror[39m: Caught by controller[3]: at Characteristic.DevoloCurrentConsumption.emit (events.js:180:13)
        2018-09-24 23:00:29.586 - [31merror[39m: Caught by controller[3]: at Characteristic.DevoloCurrentConsumption.Characteristic.getValue (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/Characteristic.js:163:10)
        2018-09-24 23:00:29.586 - [31merror[39m: Caught by controller[3]: at registerEventsForCharacteristic (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:128:28)
        2018-09-24 23:00:29.587 - [31merror[39m: Caught by controller[3]: at WrapperBridge.addBridgedAccessory (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:138:17)
        2018-09-24 23:00:29.587 - [31merror[39m: Caught by controller[3]: at Server. <anonymous>(/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:399:24)
        2018-09-24 23:00:29.587 - [31merror[39m: Caught by controller[3]: at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/util/once.js:16:19
        2018-09-24 23:00:29.588 - [31merror[39m: Caught by controller[3]: at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/index.js:71:17
        2018-09-24 23:00:29.588 - [31merror[39m: Caught by controller[3]: at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/HBDevoloCentralUnit.js:52:13
        2018-09-24 23:00:29.588 - [31merror[39m: host.raspberrypi instance system.adapter.ham.0 terminated with code 6 (uncaught exception)
        2018-09-24 23:00:29.589 - [32minfo[39m: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
        Hat jemand eine Idee. Evtl. hängt es auch mit der Version von Node ab. Habe Node Version 9.9.0 bekomme kein update hin access Fehler.
        Ausserdem habe ich eine 10 version von nodejs
        danke für eure Hilfe
        Gruss
        OliTheo</anonymous></anonymous>
          Also erst einmal kommt der Fehler wohl eher aus dem Devolo Modul und wäre daher beim Entwickler davon am besten aufgehoben.
          Weiterhin:Was hast Du jetzt node 9.9 oder node 10? Beides ist nicht ideal … 9.9 ist eine Dev-Version die keinen SUpport mehr hat und node 10 hat einiges an Problemen immer noch.
          Also node 8 ist die aktuelle Empfehlung ...
          • O
            so HAM noch einmal installiert und vorher node korrigiert:
            folgende Warungen:
            1. WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
            2. WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
            3. WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
            4. WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
            5. npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
            Hat jemand eine Idee wie ich die updaten kan punkt 2-5 und was mit Punkt 1 ist.
            Zusätzlich habe ich noch 6) npm notice created a lockfile as package-lock.json. You should commit this file.
            Punkt 6 kann ich wohl ignorieren.
            Vielen Dank für die Hilfe
            Gruss
            OliTheo
              Alles ignorieren, sind nur warnungen die du nicht beeinflussen kannst. Irgendeiner deiner Adaoter hat da was drin … das müssen die Entwickler angehen, aber nichts davon ist kritisch
              • O
                Super, dann muss ich mich nur noch um das homebrige-devolo plug in kümmern.
                ich bekomme da leider immer noch dieses Problem / habe mal dem Entwickler geschrieben, mal sehen was der sagt
                am.0 2018-09-26 16:32:16.599 warn Exception: Error: Device has no suitable sensor.
                ham.0 2018-09-26 16:32:16.573 info cleaned everything up…
                ham.0 2018-09-26 16:32:16.570 error at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/index.js:71:17
                ham.0 2018-09-26 16:32:16.570 error at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/util/once.js:16:19
                ham.0 2018-09-26 16:32:16.570 error at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:399:24)
                ham.0 2018-09-26 16:32:16.570 error at WrapperBridge.addBridgedAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:138:17)
                ham.0 2018-09-26 16:32:16.570 error at registerEventsForCharacteristic (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:128:28)
                ham.0 2018-09-26 16:32:16.570 error at Characteristic.DevoloCurrentConsumption.Characteristic.getValue (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/Characteristic.js:163:10)
                ham.0 2018-09-26 16:32:16.570 error at Characteristic.DevoloCurrentConsumption.emit (events.js:217:7)
                ham.0 2018-09-26 16:32:16.570 error at emitThree (events.js:136:13)
                ham.0 2018-09-26 16:32:16.570 error at Array.HBQubinoRelay2Device.getDevoloCurrentConsumption (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/devices/HBQubinoRelay2Device.js:80:44)
                ham.0 2018-09-26 16:32:16.570 error at Relay2Device.Device.getCurrentValue (/opt/iobroker/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloDevice.js:206:19)
                ham.0 2018-09-26 16:32:16.570 error Error: Device has no suitable sensor.
                ham.0 2018-09-26 16:32:16.569 error uncaught exception: Device has no suitable sensor.
                ham.0 2018-09-26 16:32:16.501 info updateState Schalter-Küche.Schalter-Küche-2.Name: value = /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                und auch hier
                host.raspberrypi 2018-09-26 16:50:23.067 info Restart adapter system.adapter.ham.0 because enabled
                host.raspberrypi 2018-09-26 16:50:23.067 error instance system.adapter.ham.0 terminated with code 6 (uncaught exception)
                host.raspberrypi 2018-09-26 16:50:23.067 error Caught by controller[3]: at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/index.js:71:17
                host.raspberrypi 2018-09-26 16:50:23.066 error Caught by controller[3]: at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/util/once.js:16:19
                host.raspberrypi 2018-09-26 16:50:23.066 error Caught by controller[3]: at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:399:24)
                host.raspberrypi 2018-09-26 16:50:23.066 error Caught by controller[3]: at WrapperBridge.addBridgedAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:138:17)
                host.raspberrypi 2018-09-26 16:50:23.066 error Caught by controller[3]: at registerEventsForCharacteristic (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:128:28)
                host.raspberrypi 2018-09-26 16:50:23.066 error Caught by controller[3]: at Characteristic.DevoloCurrentConsumption.Characteristic.getValue (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/Character
                host.raspberrypi 2018-09-26 16:50:23.065 error Caught by controller[3]: at Characteristic.DevoloCurrentConsumption.emit (events.js:217:7)
                host.raspberrypi 2018-09-26 16:50:23.065 error Caught by controller[3]: at emitThree (events.js:136:13)
                host.raspberrypi 2018-09-26 16:50:23.065 error Caught by controller[3]: at Array.HBQubinoRelay2Device.getDevoloCurrentConsumption (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/devices/HBQubinoRelay2Device.js:80:4
                host.raspberrypi 2018-09-26 16:50:23.065 error Caught by controller[3]: at Relay2Device.Device.getCurrentValue (/opt/iobroker/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloDevice.js:206:19)
                host.raspberrypi 2018-09-26 16:50:23.065 error Caught by controller[3]: Error: Device has no suitable sensor.
                host.raspberrypi 2018-09-26 16:50:23.065 error Caught by controller[2]: [2018-9-26 16:50:11] Warning: skipping plugin found at '/usr/local/lib/node_modules/homebridge-devolo' since we already loaded the same plugin from '/opt/iobroker/node_modules
                host.raspberrypi 2018-09-26 16:50:23.064 error Caught by controller[1]: [2018-9-26 16:50:10] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                host.raspberrypi 2018-09-26 16:50:23.063 error Caught by controller[0]: [2018-9-26 16:50:10] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                ham.0 2018-09-26 16:50:09.763 info starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.ham, node: v8.12.0
                Vielen Dank
                • X
                  xADDRx last edited by
                  Hallo zusammen ,
                  ich habe zum testen mal das Devolo Plugin installiert. Konnte soweit auch alles ohne Probleme einrichten.
                  Zum testen habe ich dann einen Devolo Funkschalter eingebunden. Der wurde auch erkannt. Leider wird als Ausgabe unter Objekte nur ein Datensatz eingerichtet der nur eine "0" ausgibt, egal welchen der 4 Tasten ich tätige. Mir ist jedoch aufgefallen, das im Log als Debug folgendes ausgespuckt wird: "[Devolo] HBDevoloWallSwitchDevice (hdm:ZWave:CE9717B0/2 / Wandschalter) > onKeyPressedChanged > KeyPressed is 1"
                  Ich habe mal zwei Bilder hinzugefügt die zeigen eventuell was ich meine.
                  Vielleicht hatt jemand eine Idee?
                  Ben
                    Ich glaube das wurde früher im Thread oder in nem andern Thread schon gemeldet. Es scheint eher am Plugin zu liegen. Also mal dort nachfragen.
                    Mir wäre auch neu das man bei Apple Home irgendwas mit Tastersignalen anfangen kann …
                    • ldittmar
                      ldittmar Developer last edited by
                      Ich habe mal eine Liste aller Plugins generiert. Vielleicht kann jemand das irgendwie nutzen. Vielleicht als Auswahl im Adapter? Keiner Ahnung… ist aber ein haufen Zeug :lol:
                      https://jsfiddle.net/ldittmar/h2z4wgyk/
                        COOL 😄
                          RKBroker last edited by
                          Guten Abend.
                          Funktioniert der HAM auch mit dem homebridge-tuya plugin?
                          host.kn-iob	2018-11-07 00:17:13.470	error	instance system.adapter.ham.0 terminated with code 0 (OK)
                          host.kn-iob	2018-11-07 00:17:13.470	error	Caught by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:27)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:229:35)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:215:17)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at Server.run (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:87:38)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at Server._loadAccessories (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:286:42)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: at API.accessory (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/api.js:64:13)
                          host.kn-iob	2018-11-07 00:17:13.469	error	Caught by controller[1]: Error: The requested accessory 'TuyaPowerStrip' was not registered by any plugin.
                          host.kn-iob	2018-11-07 00:17:13.468	error	Caught by controller[0]: [7.11.2018, 00:17:12] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.</anonymous>
                            1.) hast du such das Modul korrekt installiert bzw angegeben? Scheinbar nicht
                            2.) warum nicht den offiziellen ioBroker.tuya Adapter nehmen? Siehe Tester Forum.
                              Zu 1: Ja, alles nach den Vorgaben gemacht.
                              Zu 2: Der schreibt mir den Log voll….
                                Zu 1.) die Zeile das das accessory nicht registriert ist sagt an sich das entweder die konfig falsch ist oder das homebridge Plugin nicht installiert ist. Meine Annahme war zweiteres weil auch das log nicht zeigt das er es gelesen hätte. Screenshot der ham konfig bitte
                                Zu 2.) und du denkst es ist sinnvoll das nirgends mal zu sagen das das und was genau am logging stört? Höre ich gerade zum allerersten Mal das das logging „so schlimm“ ist das jemand den Adapter nicht nutzen will. Man könnte logging im Adapter ändern oder du könntest einfach das loglevel der Instanz ändern sodass logging was dich stört nicht mehr geloggt wird für dich …
                                sehr irritiert reinschau
                                Gesendet vom Handy ...
                                  PS to 1.) ort your config is simply wrong … see https://www.npmjs.com/package/homebridge-tuya for correct config if you use this module ... There is no acessory TuyaSmartStrip ...
                                    henkb last edited by
                                    ich nutze Homebridge und IoBroker in Docker Containern auf einer Synology NAS.
                                    Ich würde gerne beide mit dem neuen HAM Adapter verbinden. Beide Container sind so konfiguriert, dass sie ihre Daten in einem Verzeichnis auf der NAS speichern. Habe ich eine Chance das System in dieser Konfiguration zum laufen zu bekommen? Ich scheitere aktuell schon an den Pfadangaben der entsprechenden Homebridge Ordner.
                                    VG
                                    Hendrik
                                      Ohne da jetzt viel Ahnung zu haben … Die Daten sind ja nur eins ... Die Logik macht doch der prozess der gestartet wird und der läuft in dem Container wo ioBroker läuft.
                                        Global-Homebridge-Mode würde ich gerne nutzen. Der setzt aber voraus, dass beide Systeme auf dem selben Computer laufen.
                                        Ich arbeite ja mit zwei virtuellen Maschinen und daher ist die Frage, wie ich ioBroker den Zugriff auf die notwendigen Homebridge Ordner geben kann.
                                          Aber auch im "Global Homebridge modus" wird nur die Konfig und Files von einer globalen installation genommen - der Homebridge-Prozess wird dennoch von ioBroker gestartet
                                            Ja, korrekt. Das wäre mein Ziel.
                                            Nur ist mir schleierhaft, welche Pfadangaben ich bei HAM für diese Art von Setup angeben muss.
                                            Die Container sind ja vermutlich abgeschottet voneinander.
                                            Die anfallenden Daten speichern jedoch beide Maschinen im Ordner docker/homebrdige bzw. docker/iobroker auf der Hauptebene der NAS.
                                            Ich bin leider mit Linux nicht so bewandert und weiß nicht, wie ich die Pfade in HAM setzen muss.
                                            Bin mir auch nicht sicher, ob das reicht oder Daten benötigt werden, die direkt im Container liegen. In diesem Fall wäre es wohl nicht möglich, so zumindest meine Vermutung.
                                            Hat jemand Erfahrungen mit HAM in Verbindung mit Synology und zwei Containern?
                                            343
                                            85721
