    4. JSON.stringify zerlegen
    • Lenny.CB
      Lenny.CB Most Active last edited by
      komme grad nicht weiter und bräuchte mal einen Tipp.
      ich mache einen "request.get" und bekomme mit JSON.stringify(body) folgendes Ergebnis.
      body: {"000147619644":{"ident":{"type":{"key_localized":"Devicetype","value_raw":1,"value_localized":"Washing Machine"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000147619644","fabIndex":"11","techType":"WMV963","matNumber":"10499100","swids":["3814","25105","25117","20163","3627","20242","25042","25043","25026","2971","20166"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.45"}},"state":{"status":{"value_raw":1,"value_localized":"Off","key_localized":"State"},"programType":{"value_raw":0,"value_localized":"","key_localized":"Programme"},"programPhase":{"value_raw":256,"value_localized":"","key_localized":"Phase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":true},"light":0,"elapsedTime":[0,0],"spinningSpeed":0,"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Drying level"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Power Level"}}}}
      Hier will ich nun nach einzelnen Schlüsselwörtern suchen und die Keys dazu speichern.
      Komme hier grad nicht mehr klar.
        paul53 last edited by
        Normalerweise wird in body ein JSON-String geliefert, den man per JSON.parse(body) in ein Objekt wandeln muss.
        Den http://jsonviewer.stack.hu/ kennst Du ?
          apollon77 last edited by
          Wenn aber das Stringify so aussieht wie oben dann ist das schon ein in ein Objekt geparstes JSON, kann also direkt verwendet werden …
          • Lenny.CB
            @paul53:
            Den http://jsonviewer.stack.hu/ kennst Du ? ` Das ist nen bissel komisch…
            Das ist son ein "3er-ping-pong"
            1. Code per request.post abfragen. Was ich brauche hole ich mit: JSON.stringify(response.header)
            2. Token per request.post holen.
            Was ich brauche hole ich mit: JSON.parse(body)
            3. Divices holen
            Was ich brauche hole ich mit: JSON.stringify(body)
            Den link schaue ich mir mal an.
            • Lenny.CB
              @apollon77:
              Wenn aber das Stringify so aussieht wie oben dann ist das schon ein in ein Objekt geparstes JSON, kann also direkt verwendet werden … ` Und genau da fehlts mir… schon viel gelesen und probiert, nix geklappt.
                @Lenny.CB:
                3. Divices holen
                Was ich brauche hole ich mit: JSON.stringify(body) `
                Was nun ? Einfach testen mit
                log('Typ body: ' + typeof body);
                • Lenny.CB
                  @paul53:
                  @Lenny.CB:
                  3. Divices holen
                  genau wie ich geschrieben habe.
                  Beim Token (request.post) kommt ein "Typ body Token: string" zurück,
                  Beim Device (request.get) kommt ein "Typ body Device: object" zurück. Warum auch immer.
                  Mit der Token-Antwort komme ich zurecht. Da hole ich das raus mit:
                  let obj = JSON.parse(body);
                  access_token = obj.access_token;
                  Nur wenn halt ein Objekt zurück kommt, komme ich nicht klar. Schaut auch irgendwie "verschachtelt" aus.
                    @Lenny.CB:
                    Nur wenn halt ein Objekt zurück kommt, komme ich nicht klar. Schaut auch irgendwie "verschachtelt" aus. `
                    Ist es das Objekt aus dem ersten Beitrag ? Im JSON-Viewer sieht es so aus (ohne "body: "):
                    Der Zugriff auf z.B. state.status.value_raw würde so erfolgen:
                    var status_value_raw = obj["000147619644"].state.status.value_raw;
                    • Lenny.CB
                      @paul53:
                      Ist es das Objekt aus dem ersten Beitrag ? ` ja korrekt
                      @paul53:
                      dabei bekomme ich folgenden Fehler:
                      javascript.2 TypeError: Cannot read property 'status' of undefined at Request._callback (script.js.Testscripte.Miele_Abfrage:94:57) at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:185:22) at emitTwo (events.js:106:13) at Request.emit (events.js:191:7) at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1161:10) at emitOne (events.js:96:13) at Request.emit (events.js:188:7) at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1083:12) at IncomingMessage.g (events.js:292:16) at emitNone (events.js:91:20)
                      Caught by controller[0]: at Request._callback (script.js.Testscripte.Miele_Abfrage:94:57)
                        @Lenny.CB:
                        dabei bekomme ich folgenden Fehler: `
                        • Lenny.CB
                          wenn ich das so aufbaue:var obj = {"000147619644":{"ident":{"type":{"key_localized":"Devicetype","value_raw":1,"value_localized":"Washing Machine"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000147619644","fabIndex":"11","techType":"WMV963","matNumber":"10499100","swids":["3814","25105","25117","20163","3627","20242","25042","25043","25026","2971","20166"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.45"}},"state":{"status":{"value_raw":1,"value_localized":"Off","key_localized":"State"},"programType":{"value_raw":0,"value_localized":"","key_localized":"Programme"},"programPhase":{"value_raw":256,"value_localized":"","key_localized":"Phase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":true},"light":0,"elapsedTime":[0,0],"spinningSpeed":0,"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Drying level"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Power Level"}}}}; log(obj["000147619644"].state.status.value_raw);klappte es bei mir auch.````
                          16:07:36.884 [info] javascript.2 script.js.Testscripte.Miele_device_test: 1
                          Habe heut Morgen noch etwas versucht und wieder mal gesehen, dass ich mir selbst ins Knie geschossen habe. Is halt so wenn man nicht wirklich weiß was im kopierten Code passiert (Quasi wie immer :shock: ) Muss hier noch weiter lernen. :ugeek:
                          hier mal der Code:````
                          function Device_Abfrage () {
                                  request.get    ({
                                                  url: 'https://api.mcs3.miele.com/v1/devices/',
                                                  // json: true,
                                                  headers: {'Authorization': 'Bearer xxxxxxxx86816993400b8b44xxxxxxxx'}
                                                  function (error, response, body) {
                                                  log('Device_statusCode: ' + response.statusCode);
                                                  log('body: ' + body);
                                                  log('Device_error: ' + error);
                                                  log('Typ body Device: ' + typeof body);
                                                  var obj = JSON.parse(body);
                          Device_Abfrage ();
                          ich hatte "json: true" mitgegeben. Antwort kam das als Objekt zurück. Konnte es aber nicht mit JSON.stringify verarbeiten.
                          "json: true" auskommentiert, schon kam ein String zurück den ich mit JSON.parse bearbeiten konnte.
                          @paul53, danke für den Denkanstoß!
                          2512
