    4. [Aufruf] Xbox Adapter testen
      martamstart last edited by
      bei mir will das Ganze noch nicht.
      Ich habe den Xbox Adapter auf einem Tinkerboard installiert.
      Die Instanz verbindet sich erfolgreich mit meiner Xbox, läuft dann aber in einen Fehler…
      xbox.0	2018-11-04 18:21:26.337	info	[START] Starting REST server
      xbox.0	2018-11-04 18:21:26.331	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.xbox, node: v6.14.4
      xbox.0	2018-11-04 18:21:26.175	info	States connected to redis: 127.0.0.1:6379
      xbox.0	2018-11-04 18:20:54.659	info	terminating
      xbox.0	2018-11-04 18:20:54.651	info	[END] cleaned everything up...
      xbox.0	2018-11-04 18:20:54.649	info	[END] REST server stopped
      xbox.0	2018-11-04 18:20:54.623	error	at readableAddChunk (_stream_readable.js:176:18)
      xbox.0	2018-11-04 18:20:54.623	error	at Socket.emit (events.js:188:7)
      xbox.0	2018-11-04 18:20:54.623	error	at emitOne (events.js:96:13)
      xbox.0	2018-11-04 18:20:54.623	error	at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:274:27)
      xbox.0	2018-11-04 18:20:54.623	error	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
      xbox.0	2018-11-04 18:20:54.623	error	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      xbox.0	2018-11-04 18:20:54.623	error	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:824:9)
      xbox.0	2018-11-04 18:20:54.623	error	at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
      xbox.0	2018-11-04 18:20:54.623	error	at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:236:17)
      xbox.0	2018-11-04 18:20:54.623	error	at adapter.getState (/opt/iobroker/node_modules/iobroker.xbox/main.js:141:40)
      xbox.0	2018-11-04 18:20:54.623	error	TypeError: Cannot read property 'val' of null
      xbox.0	2018-11-04 18:20:54.622	error	uncaught exception: Cannot read property 'val' of null
      xbox.0	2018-11-04 18:20:49.308	info	[CONNECT] <=== Successfully connected to [MeineLiveId] ("[MeineXboxIp]")
      xbox.0	2018-11-04 18:20:35.979	info	[START] Starting REST server
      xbox.0	2018-11-04 18:20:35.973	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.xbox, node: v6.14.4
      xbox.0	2018-11-04 18:20:35.822	info	States connected to redis: 127.0.0.1:6379
      ...</anonymous>
      Habt ihr eine Idee woran das liegt?
      Danke und Gruß
      • foxriver76
        @martamstart:
        Danke und Gruß `
        Eigentlich hätte jeder nach dem Update in den Fehler laufen müssen. 😄
        Bei mir war der State schon existent durchs entwickeln.
        Pushe später 0.1.2
        • foxriver76
          Und 0.1.2 ist schon da
            Super, vielen Dank… das hat geholfen 🙂
            • Jey Cee
              Ich hab mir den Adapter jetzt auch mal installiert und bin begeistert, es funktioniert soweit alles.
              Aber ich hab folgendes Problem: Meine Xbox wird vom Strom getrennt wenn ich sie bzw. mein Media Center nicht brauche, danach lässt sie sich nicht mehr mit dem Adapter starten.
              Ich vermute die Xbox ist dann Vollständig aus und fährt nicht wieder hoch in den Standby wenn sie wieder Strom bekommt.
              Ist meine Annahme Korrekt? Hat jemand eine Idee wie man das Problem umgeht, außer Dauerstrom an der Xbox.
              • foxriver76
                @Jey Cee:
                Ist meine Annahme Korrekt? Hat jemand eine Idee wie man das Problem umgeht, außer Dauerstrom an der Xbox. `
                Moin,
                benutzt du eine Fritz!Box? Ich habe das Problem selbst und konnte es bislang nicht lösen, allerdings vermuten wir derzeit, dass es irgendwo in der Fritz!Box steckt.
                Ach so, wobei ich mir nicht ganz sicher bin ob es das gleiche Problem ist, weil es bei mir auch Auftritt, wenn ich sie nicht stromlos gemacht habe – einfach nach längerer Standby-Phase. Ist das bei dir auch so?
                Es gibt für die gängigen Smartphone Betriebssysteme auch eine Xbox App, unter Konsole kann man hier auch die Xbox einschalten. Du könntest testen ob es damit geht, falls es da läuft, liegt es schon mal nicht an der Xbox. Meine lässt sich jedoch auch damit nicht an bekommen und er sagt "Stelle sicher dass deine Xbox für schnelles Hochfahren konfiguriert ist". Falls deine Xbox sowieso nur am Strom ist, wenn du diese nutzt, könntest du ja schnelles Hochfahren mal ausprobieren in den Einstellungen der Xbox, "ohne" dass du einen höheren Verbrauch hast.
                beste Grüße
                fox
                • Jey Cee
                  @foxriver76:
                  einfach nach längerer Standby-Phase. Ist das bei dir auch so? ` Das versuche ich mal zu testen und die App auch.
                  Das schnelle Hochfahren ist schon aktiviert, wird aber wohl nichts nützen wenn die Xbox nicht wieder in den Standby geht.
                  @foxriver76:
                  benutzt du eine Fritz!Box? ` Ja ich hab ne FritzBox.
                  • Jey Cee
                    Ich hab das jetzt mal mit der App getestet, selbes Ergebnis, die Xbox lässt sich nicht starten. Übrigens ist Schnelles Hochfahren dafür immer Notwendig.
                    Damit ist klar die Xbox muss erstmal gestartet worden sein und ist erst danach im Standby. Das ist darauf zurück zu führen das dass BIOS/UEFI gar kein WOL Unterstützt oder eben nicht aktiviert ist. Es gibt einen Standby Modus von Windows (läuft ja auf der Xbox) der WOL ermöglicht. Das konnte ich herausfinden als ich meinen Laptop per WOL wecken wollte, aber genau das gleiche Problem wie bei der Xbox.
                    @foxriver76:
                    Ich habe das Problem selbst und konnte es bislang nicht lösen, allerdings vermuten wir derzeit, dass es irgendwo in der Fritz!Box steckt. ` Ist die Xbox direkt mit der FritzBox verbunden? Die FritzBox hat ja auch ein Energiemanagment und schaltet die LAN Ports ab wenn da nix mehr kommt. Da könnte eventuell ein Switch dazwischen helfen.
                    Ich hab die Xbox mal 1-1,5 Stunden im Standby gelassen und das Starten war kein Problem.
                    • foxriver76
                      @Jey Cee:
                      @foxriver76:
                      Ich habe das Problem selbst und konnte es bislang nicht lösen, allerdings vermuten wir derzeit, dass es irgendwo in der Fritz!Box steckt. Ist die Xbox direkt mit der FritzBox verbunden? Die FritzBox hat ja auch ein Energiemanagment und schaltet die LAN Ports ab wenn da nix mehr kommt. Da könnte eventuell ein Switch dazwischen helfen.
                      Danke, dass du etwas Licht ins dunkel bringst. Ich habe das ganze bei mir getestet im WLAN der Fritz und per LAN an einem DLAN-Adapter. Für mich persönlich ist es nicht relevant, da ich sowieso über den Harmony Hub die Box an und aus mache. Allerdings ist es schön, wenn man als Adapter-Entwickler den Usern im Falle des Problems helfen kann.
                      @Jey Cee:
                      Ich hab die Xbox mal 1-1,5 Stunden im Standby gelassen und das Starten war kein Problem. `
                      Top, dann ist es wohl wie von dir erörtert die fehlende Wake-on-Lan Funktion von Win.
                      • Negalein
                        @foxriver76:
                        Den Adapter kann man testen indem man unter Windows/Mac versucht `
                        Hallo
                        Ich wollte auch soeben den Adapter installieren.
                        Phyton hab ich vorher installiert.
                        Bekomme folgende Fehlermeldung beim installieren.
                        $ ./iobroker url "https://github.com/foxriver76/ioBroker.xbox"
                        install https://github.com/foxriver76/ioBroker.xbox/tarball/master
                        npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --production --save --prefix "C:/ioBroker" (System call)
                        Der Befehl "apt" ist entweder falsch geschrieben oder
                        konnte nicht gefunden werden.
                        Error: No python executable.    at getPythonInfo (C:\ioBroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:52:11)
                            at Promise.then.catch.error (C:\ioBroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:115:14)
                            at <anonymous>
                            at process._tickCallback (internal/process/next_tick.js:189:7)
                        npm
                         ERR! code ELIFECYCLEnpm ERR! errno 1
                        npm
                         ERR! iobroker.xbox@0.1.3 install: `npip install`npm ERR! Exit status 1
                        npm ERR!
                        npm
                        ERR! Failed at the iobroker.xbox@0.1.3 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        npm ERR! A complete log of this run can be found in:npm ERR!     C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-11-10T23_12_05_969Z-debug.log
                        process exited with code 0</anonymous>
                        Kannst du mir bitte weiterhelfen?
                        • foxriver76
                          Was passiert wenn du in der Kommandozeilepythonoderpython3eingibst? Und vermutlich ist es für die erstmalige Installation besser wenn du es über die Konsole machst im ioB Ordner````
                          npm i iobroker.xbox —production —unsafe-perm
                          • Negalein
                            @foxriver76:
                            Was passiert wenn du in der Kommandozeilepythonoderpython3eingibst? Und vermutlich ist es für die erstmalige Installation besser wenn du es über die Konsole machst im ioB Ordnernpm i iobroker.xbox —production —unsafe-perm `
                            Ich hab kein Linux. Hab Win10.
                            • Jey Cee
                              @Negalein:
                              Ich hab kein Linux. Hab Win10. ` Auch windows hat eine Kommandozeile. Gib mal in deiner Win10 Suche "cmd" ein.
                              • Negalein
                                @foxriver76:
                                Hilft dir eventuell der ganze Log?
                                0 info it worked if it ends with ok
                                1 verbose cli [ 'C:\\Program Files\\nodejs\\node.exe',
                                1 verbose cli   'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
                                1 verbose cli   'install',
                                1 verbose cli   'https://github.com/foxriver76/ioBroker.xbox/tarball/master',
                                1 verbose cli   '--production',
                                1 verbose cli   '--save',
                                1 verbose cli   '--prefix',
                                1 verbose cli   'C:/ioBroker' ]
                                2 info using npm@6.4.1
                                3 info using node@v8.12.0
                                4 verbose npm-session 57a6e28b92c3d56a
                                5 silly install loadCurrentTree
                                6 silly install readGlobalPackageData
                                7 http fetch GET 200 https://github.com/foxriver76/ioBroker.xbox/tarball/master 1355ms
                                8 silly pacote remote manifest for undefined@https://github.com/foxriver76/ioBroker.xbox/tarball/master fetched in 1404ms
                                9 timing stage:loadCurrentTree Completed in 1931ms
                                10 silly install loadIdealTree
                                11 silly install cloneCurrentTreeToIdealTree
                                12 timing stage:loadIdealTree:cloneCurrentTree Completed in 0ms
                                13 silly install loadShrinkwrap
                                14 timing stage:loadIdealTree:loadShrinkwrap Completed in 3ms
                                15 silly install loadAllDepsIntoIdealTree
                                16 silly resolveWithNewModule iobroker.xbox@0.1.4 checking installable status
                                17 http fetch GET 304 https://registry.npmjs.org/request 200ms (from cache)
                                18 silly pacote range manifest for request@^2.87.0 fetched in 211ms
                                19 silly resolveWithNewModule request@2.88.0 checking installable status
                                20 http fetch GET 304 https://registry.npmjs.org/ping 230ms (from cache)
                                21 silly pacote range manifest for ping@^0.2.2 fetched in 233ms
                                22 silly resolveWithNewModule ping@0.2.2 checking installable status
                                23 http fetch GET 304 https://registry.npmjs.org/nopy 913ms (from cache)
                                24 silly pacote range manifest for nopy@^0.2.6 fetched in 920ms
                                25 silly resolveWithNewModule nopy@0.2.6 checking installable status
                                26 http fetch GET 304 https://registry.npmjs.org/q 61ms (from cache)
                                27 http fetch GET 304 https://registry.npmjs.org/underscore 64ms (from cache)
                                28 silly pacote range manifest for q@1.x fetched in 66ms
                                29 silly resolveWithNewModule q@1.5.1 checking installable status
                                30 silly pacote range manifest for underscore@^1.8.3 fetched in 69ms
                                31 silly resolveWithNewModule underscore@1.9.1 checking installable status
                                32 http fetch GET 304 https://registry.npmjs.org/caseless 122ms (from cache)
                                33 http fetch GET 304 https://registry.npmjs.org/aws-sign2 125ms (from cache)
                                34 silly pacote range manifest for caseless@~0.12.0 fetched in 125ms
                                35 silly resolveWithNewModule caseless@0.12.0 checking installable status
                                36 silly pacote range manifest for aws-sign2@~0.7.0 fetched in 129ms
                                37 silly resolveWithNewModule aws-sign2@0.7.0 checking installable status
                                38 http fetch GET 304 https://registry.npmjs.org/aws4 130ms (from cache)
                                39 silly pacote range manifest for aws4@^1.8.0 fetched in 135ms
                                40 silly resolveWithNewModule aws4@1.8.0 checking installable status
                                41 http fetch GET 304 https://registry.npmjs.org/http-signature 193ms (from cache)
                                42 http fetch GET 304 https://registry.npmjs.org/extend 195ms (from cache)
                                43 silly pacote range manifest for http-signature@~1.2.0 fetched in 197ms
                                44 silly resolveWithNewModule http-signature@1.2.0 checking installable status
                                45 silly pacote range manifest for extend@~3.0.2 fetched in 200ms
                                46 silly resolveWithNewModule extend@3.0.2 checking installable status
                                47 http fetch GET 304 https://registry.npmjs.org/json-stringify-safe 91ms (from cache)
                                48 silly pacote range manifest for json-stringify-safe@~5.0.1 fetched in 94ms
                                49 silly resolveWithNewModule json-stringify-safe@5.0.1 checking installable status
                                50 http fetch GET 200 https://registry.npmjs.org/har-validator 245ms
                                51 http fetch GET 304 https://registry.npmjs.org/isstream 125ms (from cache)
                                52 silly pacote range manifest for isstream@~0.1.2 fetched in 137ms
                                53 silly resolveWithNewModule isstream@0.1.2 checking installable status
                                54 http fetch GET 304 https://registry.npmjs.org/combined-stream 272ms (from cache)
                                55 http fetch GET 304 https://registry.npmjs.org/mime-types 145ms (from cache)
                                56 silly pacote range manifest for combined-stream@~1.0.6 fetched in 284ms
                                57 silly resolveWithNewModule combined-stream@1.0.7 checking installable status
                                58 silly pacote range manifest for mime-types@~2.1.19 fetched in 152ms
                                59 silly resolveWithNewModule mime-types@2.1.21 checking installable status
                                60 silly pacote range manifest for har-validator@~5.1.0 fetched in 288ms
                                61 silly resolveWithNewModule har-validator@5.1.3 checking installable status
                                62 http fetch GET 304 https://registry.npmjs.org/is-typedarray 296ms (from cache)
                                63 silly pacote range manifest for is-typedarray@~1.0.0 fetched in 308ms
                                64 silly resolveWithNewModule is-typedarray@1.0.0 checking installable status
                                65 http fetch GET 304 https://registry.npmjs.org/forever-agent 312ms (from cache)
                                66 http fetch GET 304 https://registry.npmjs.org/oauth-sign 115ms (from cache)
                                67 http fetch GET 304 https://registry.npmjs.org/performance-now 116ms (from cache)
                                68 http fetch GET 304 https://registry.npmjs.org/form-data 318ms (from cache)
                                69 silly pacote range manifest for oauth-sign@~0.9.0 fetched in 122ms
                                70 silly resolveWithNewModule oauth-sign@0.9.0 checking installable status
                                71 silly pacote range manifest for forever-agent@~0.6.1 fetched in 322ms
                                72 silly resolveWithNewModule forever-agent@0.6.1 checking installable status
                                73 http fetch GET 304 https://registry.npmjs.org/qs 101ms (from cache)
                                74 silly pacote range manifest for form-data@~2.3.2 fetched in 325ms
                                75 silly resolveWithNewModule form-data@2.3.3 checking installable status
                                76 silly pacote range manifest for performance-now@^2.1.0 fetched in 126ms
                                77 silly resolveWithNewModule performance-now@2.1.0 checking installable status
                                78 silly pacote range manifest for qs@~6.5.2 fetched in 108ms
                                79 silly resolveWithNewModule qs@6.5.2 checking installable status
                                80 http fetch GET 304 https://registry.npmjs.org/safe-buffer 82ms (from cache)
                                81 silly pacote range manifest for safe-buffer@^5.1.2 fetched in 87ms
                                82 silly resolveWithNewModule safe-buffer@5.1.2 checking installable status
                                83 http fetch GET 304 https://registry.npmjs.org/tough-cookie 71ms (from cache)
                                84 silly pacote range manifest for tough-cookie@~2.4.3 fetched in 74ms
                                85 silly resolveWithNewModule tough-cookie@2.4.3 checking installable status
                                86 http fetch GET 304 https://registry.npmjs.org/tunnel-agent 71ms (from cache)
                                87 http fetch GET 304 https://registry.npmjs.org/uuid 71ms (from cache)
                                88 silly pacote range manifest for tunnel-agent@^0.6.0 fetched in 75ms
                                89 silly resolveWithNewModule tunnel-agent@0.6.0 checking installable status
                                90 silly pacote range manifest for uuid@^3.3.2 fetched in 75ms
                                91 silly resolveWithNewModule uuid@3.3.2 checking installable status
                                92 http fetch GET 304 https://registry.npmjs.org/delayed-stream 53ms (from cache)
                                93 silly pacote range manifest for delayed-stream@~1.0.0 fetched in 56ms
                                94 silly resolveWithNewModule delayed-stream@1.0.0 checking installable status
                                95 http fetch GET 304 https://registry.npmjs.org/asynckit 108ms (from cache)
                                96 silly pacote range manifest for asynckit@^0.4.0 fetched in 111ms
                                97 silly resolveWithNewModule asynckit@0.4.0 checking installable status
                                98 http fetch GET 304 https://registry.npmjs.org/mime-db 58ms (from cache)
                                99 silly pacote range manifest for mime-db@~1.37.0 fetched in 63ms
                                100 silly resolveWithNewModule mime-db@1.37.0 checking installable status
                                101 http fetch GET 304 https://registry.npmjs.org/ajv 68ms (from cache)
                                102 http fetch GET 304 https://registry.npmjs.org/har-schema 72ms (from cache)
                                103 silly pacote range manifest for har-schema@^2.0.0 fetched in 75ms
                                104 silly resolveWithNewModule har-schema@2.0.0 checking installable status
                                105 silly pacote range manifest for ajv@^6.5.5 fetched in 77ms
                                106 silly resolveWithNewModule ajv@6.5.5 checking installable status
                                107 http fetch GET 304 https://registry.npmjs.org/fast-json-stable-stringify 56ms (from cache)
                                108 silly pacote range manifest for fast-json-stable-stringify@^2.0.0 fetched in 61ms
                                109 silly resolveWithNewModule fast-json-stable-stringify@2.0.0 checking installable status
                                110 http fetch GET 304 https://registry.npmjs.org/fast-deep-equal 70ms (from cache)
                                111 silly pacote range manifest for fast-deep-equal@^2.0.1 fetched in 76ms
                                112 silly resolveWithNewModule fast-deep-equal@2.0.1 checking installable status
                                113 http fetch GET 304 https://registry.npmjs.org/json-schema-traverse 76ms (from cache)
                                114 http fetch GET 304 https://registry.npmjs.org/uri-js 76ms (from cache)
                                115 silly pacote range manifest for json-schema-traverse@^0.4.1 fetched in 82ms
                                116 silly resolveWithNewModule json-schema-traverse@0.4.1 checking installable status
                                117 silly pacote range manifest for uri-js@^4.2.2 fetched in 82ms
                                118 silly resolveWithNewModule uri-js@4.2.2 checking installable status
                                119 http fetch GET 304 https://registry.npmjs.org/punycode 65ms (from cache)
                                120 silly pacote range manifest for punycode@^2.1.0 fetched in 72ms
                                121 silly resolveWithNewModule punycode@2.1.1 checking installable status
                                122 http fetch GET 304 https://registry.npmjs.org/jsprim 60ms (from cache)
                                123 silly pacote range manifest for jsprim@^1.2.2 fetched in 63ms
                                124 silly resolveWithNewModule jsprim@1.4.1 checking installable status
                                125 http fetch GET 304 https://registry.npmjs.org/sshpk 71ms (from cache)
                                126 http fetch GET 304 https://registry.npmjs.org/assert-plus 73ms (from cache)
                                127 silly pacote range manifest for sshpk@^1.7.0 fetched in 76ms
                                128 silly resolveWithNewModule sshpk@1.15.2 checking installable status
                                129 silly pacote range manifest for assert-plus@^1.0.0 fetched in 78ms
                                130 silly resolveWithNewModule assert-plus@1.0.0 checking installable status
                                131 http fetch GET 304 https://registry.npmjs.org/extsprintf 51ms (from cache)
                                132 silly pacote version manifest for extsprintf@1.3.0 fetched in 57ms
                                133 silly resolveWithNewModule extsprintf@1.3.0 checking installable status
                                134 http fetch GET 304 https://registry.npmjs.org/verror 59ms (from cache)
                                135 silly pacote version manifest for verror@1.10.0 fetched in 62ms
                                136 silly resolveWithNewModule verror@1.10.0 checking installable status
                                137 http fetch GET 304 https://registry.npmjs.org/json-schema 67ms (from cache)
                                138 silly pacote version manifest for json-schema@0.2.3 fetched in 69ms
                                139 silly resolveWithNewModule json-schema@0.2.3 checking installable status
                                140 http fetch GET 304 https://registry.npmjs.org/core-util-is 53ms (from cache)
                                141 silly pacote version manifest for core-util-is@1.0.2 fetched in 56ms
                                142 silly resolveWithNewModule core-util-is@1.0.2 checking installable status
                                143 http fetch GET 304 https://registry.npmjs.org/asn1 84ms (from cache)
                                144 http fetch GET 304 https://registry.npmjs.org/getpass 86ms (from cache)
                                145 silly pacote range manifest for asn1@~0.2.3 fetched in 90ms
                                146 silly resolveWithNewModule asn1@0.2.4 checking installable status
                                147 silly pacote range manifest for getpass@^0.1.1 fetched in 91ms
                                148 silly resolveWithNewModule getpass@0.1.7 checking installable status
                                149 http fetch GET 304 https://registry.npmjs.org/tweetnacl 95ms (from cache)
                                150 http fetch GET 304 https://registry.npmjs.org/jsbn 100ms (from cache)
                                151 http fetch GET 304 https://registry.npmjs.org/safer-buffer 100ms (from cache)
                                152 http fetch GET 304 https://registry.npmjs.org/dashdash 101ms (from cache)
                                153 silly pacote range manifest for tweetnacl@~0.14.0 fetched in 102ms
                                154 silly resolveWithNewModule tweetnacl@0.14.5 checking installable status
                                155 silly pacote range manifest for jsbn@~0.1.0 fetched in 104ms
                                156 silly resolveWithNewModule jsbn@0.1.1 checking installable status
                                157 silly pacote range manifest for safer-buffer@^2.0.2 fetched in 105ms
                                158 silly resolveWithNewModule safer-buffer@2.1.2 checking installable status
                                159 http fetch GET 304 https://registry.npmjs.org/ecc-jsbn 105ms (from cache)
                                160 silly pacote range manifest for dashdash@^1.12.0 fetched in 107ms
                                161 silly resolveWithNewModule dashdash@1.14.1 checking installable status
                                162 http fetch GET 304 https://registry.npmjs.org/bcrypt-pbkdf 107ms (from cache)
                                163 silly pacote range manifest for ecc-jsbn@~0.1.1 fetched in 107ms
                                164 silly resolveWithNewModule ecc-jsbn@0.1.2 checking installable status
                                165 silly pacote range manifest for bcrypt-pbkdf@^1.0.0 fetched in 109ms
                                166 silly resolveWithNewModule bcrypt-pbkdf@1.0.2 checking installable status
                                167 silly pacote range manifest for punycode@^1.4.1 fetched in 3ms
                                168 silly resolveWithNewModule punycode@1.4.1 checking installable status
                                169 http fetch GET 304 https://registry.npmjs.org/psl 59ms (from cache)
                                170 silly pacote range manifest for psl@^1.1.24 fetched in 63ms
                                171 silly resolveWithNewModule psl@1.1.29 checking installable status
                                172 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 2279ms
                                173 timing stage:loadIdealTree Completed in 2315ms
                                174 silly currentTree iobroker.inst@1.1.2
                                175 silly idealTree iobroker.inst@1.1.2
                                175 silly idealTree `-- iobroker.xbox@0.1.4
                                175 silly idealTree   +-- ajv@6.5.5
                                175 silly idealTree   +-- asn1@0.2.4
                                175 silly idealTree   +-- assert-plus@1.0.0
                                175 silly idealTree   +-- asynckit@0.4.0
                                175 silly idealTree   +-- aws-sign2@0.7.0
                                175 silly idealTree   +-- aws4@1.8.0
                                175 silly idealTree   +-- bcrypt-pbkdf@1.0.2
                                175 silly idealTree   +-- caseless@0.12.0
                                175 silly idealTree   +-- combined-stream@1.0.7
                                175 silly idealTree   +-- core-util-is@1.0.2
                                175 silly idealTree   +-- dashdash@1.14.1
                                175 silly idealTree   +-- delayed-stream@1.0.0
                                175 silly idealTree   +-- ecc-jsbn@0.1.2
                                175 silly idealTree   +-- extend@3.0.2
                                175 silly idealTree   +-- extsprintf@1.3.0
                                175 silly idealTree   +-- fast-deep-equal@2.0.1
                                175 silly idealTree   +-- fast-json-stable-stringify@2.0.0
                                175 silly idealTree   +-- forever-agent@0.6.1
                                175 silly idealTree   +-- form-data@2.3.3
                                175 silly idealTree   +-- getpass@0.1.7
                                175 silly idealTree   +-- har-schema@2.0.0
                                175 silly idealTree   +-- har-validator@5.1.3
                                175 silly idealTree   +-- http-signature@1.2.0
                                175 silly idealTree   +-- is-typedarray@1.0.0
                                175 silly idealTree   +-- isstream@0.1.2
                                175 silly idealTree   +-- jsbn@0.1.1
                                175 silly idealTree   +-- json-schema-traverse@0.4.1
                                175 silly idealTree   +-- json-schema@0.2.3
                                175 silly idealTree   +-- json-stringify-safe@5.0.1
                                175 silly idealTree   +-- jsprim@1.4.1
                                175 silly idealTree   +-- mime-db@1.37.0
                                175 silly idealTree   +-- mime-types@2.1.21
                                175 silly idealTree   +-- nopy@0.2.6
                                175 silly idealTree   +-- oauth-sign@0.9.0
                                175 silly idealTree   +-- performance-now@2.1.0
                                175 silly idealTree   +-- ping@0.2.2
                                175 silly idealTree   +-- psl@1.1.29
                                175 silly idealTree   +-- punycode@2.1.1
                                175 silly idealTree   +-- q@1.5.1
                                175 silly idealTree   +-- qs@6.5.2
                                175 silly idealTree   +-- request@2.88.0
                                175 silly idealTree   +-- safe-buffer@5.1.2
                                175 silly idealTree   +-- safer-buffer@2.1.2
                                175 silly idealTree   +-- sshpk@1.15.2
                                175 silly idealTree   +-- tough-cookie@2.4.3
                                175 silly idealTree   | `-- punycode@1.4.1
                                175 silly idealTree   +-- tunnel-agent@0.6.0
                                175 silly idealTree   +-- tweetnacl@0.14.5
                                175 silly idealTree   +-- underscore@1.9.1
                                175 silly idealTree   +-- uri-js@4.2.2
                                175 silly idealTree   +-- uuid@3.3.2
                                175 silly idealTree   `-- verror@1.10.0
                                176 silly install generateActionsToTake
                                177 silly diff-trees filtering actions: includeDev false includeProd true includeOpt true
                                178 timing stage:generateActionsToTake Completed in 16ms
                                179 silly diffTrees action count 53
                                180 silly diffTrees add assert-plus@1.0.0
                                181 silly diffTrees add asynckit@0.4.0
                                182 silly diffTrees add aws-sign2@0.7.0
                                183 silly diffTrees add aws4@1.8.0
                                184 silly diffTrees add caseless@0.12.0
                                185 silly diffTrees add core-util-is@1.0.2
                                186 silly diffTrees add dashdash@1.14.1
                                187 silly diffTrees add delayed-stream@1.0.0
                                188 silly diffTrees add combined-stream@1.0.7
                                189 silly diffTrees add extend@3.0.2
                                190 silly diffTrees add extsprintf@1.3.0
                                191 silly diffTrees add fast-deep-equal@2.0.1
                                192 silly diffTrees add fast-json-stable-stringify@2.0.0
                                193 silly diffTrees add forever-agent@0.6.1
                                194 silly diffTrees add getpass@0.1.7
                                195 silly diffTrees add har-schema@2.0.0
                                196 silly diffTrees add is-typedarray@1.0.0
                                197 silly diffTrees add isstream@0.1.2
                                198 silly diffTrees add jsbn@0.1.1
                                199 silly diffTrees add json-schema@0.2.3
                                200 silly diffTrees add json-schema-traverse@0.4.1
                                201 silly diffTrees add json-stringify-safe@5.0.1
                                202 silly diffTrees add mime-db@1.37.0
                                203 silly diffTrees add mime-types@2.1.21
                                204 silly diffTrees add form-data@2.3.3
                                205 silly diffTrees add oauth-sign@0.9.0
                                206 silly diffTrees add performance-now@2.1.0
                                207 silly diffTrees add psl@1.1.29
                                208 silly diffTrees add punycode@2.1.1
                                209 silly diffTrees add q@1.5.1
                                210 silly diffTrees add qs@6.5.2
                                211 silly diffTrees add safe-buffer@5.1.2
                                212 silly diffTrees add safer-buffer@2.1.2
                                213 silly diffTrees add asn1@0.2.4
                                214 silly diffTrees add ecc-jsbn@0.1.2
                                215 silly diffTrees add punycode@1.4.1
                                216 silly diffTrees add tough-cookie@2.4.3
                                217 silly diffTrees add tunnel-agent@0.6.0
                                218 silly diffTrees add tweetnacl@0.14.5
                                219 silly diffTrees add bcrypt-pbkdf@1.0.2
                                220 silly diffTrees add sshpk@1.15.2
                                221 silly diffTrees add underscore@1.9.1
                                222 silly diffTrees add uri-js@4.2.2
                                223 silly diffTrees add ajv@6.5.5
                                224 silly diffTrees add har-validator@5.1.3
                                225 silly diffTrees add uuid@3.3.2
                                226 silly diffTrees add verror@1.10.0
                                227 silly diffTrees add jsprim@1.4.1
                                228 silly diffTrees add http-signature@1.2.0
                                229 silly diffTrees add nopy@0.2.6
                                230 silly diffTrees add ping@0.2.2
                                231 silly diffTrees add request@2.88.0
                                232 silly diffTrees add iobroker.xbox@0.1.4
                                233 silly decomposeActions action count 424
                                234 silly decomposeActions fetch assert-plus@1.0.0
                                235 silly decomposeActions extract assert-plus@1.0.0
                                236 silly decomposeActions preinstall assert-plus@1.0.0
                                237 silly decomposeActions build assert-plus@1.0.0
                                238 silly decomposeActions install assert-plus@1.0.0
                                239 silly decomposeActions postinstall assert-plus@1.0.0
                                240 silly decomposeActions finalize assert-plus@1.0.0
                                241 silly decomposeActions refresh-package-json assert-plus@1.0.0
                                242 silly decomposeActions fetch asynckit@0.4.0
                                243 silly decomposeActions extract asynckit@0.4.0
                                244 silly decomposeActions preinstall asynckit@0.4.0
                                245 silly decomposeActions build asynckit@0.4.0
                                246 silly decomposeActions install asynckit@0.4.0
                                247 silly decomposeActions postinstall asynckit@0.4.0
                                248 silly decomposeActions finalize asynckit@0.4.0
                                249 silly decomposeActions refresh-package-json asynckit@0.4.0
                                250 silly decomposeActions fetch aws-sign2@0.7.0
                                251 silly decomposeActions extract aws-sign2@0.7.0
                                252 silly decomposeActions preinstall aws-sign2@0.7.0
                                253 silly decomposeActions build aws-sign2@0.7.0
                                254 silly decomposeActions install aws-sign2@0.7.0
                                255 silly decomposeActions postinstall aws-sign2@0.7.0
                                256 silly decomposeActions finalize aws-sign2@0.7.0
                                257 silly decomposeActions refresh-package-json aws-sign2@0.7.0
                                258 silly decomposeActions fetch aws4@1.8.0
                                259 silly decomposeActions extract aws4@1.8.0
                                260 silly decomposeActions preinstall aws4@1.8.0
                                261 silly decomposeActions build aws4@1.8.0
                                262 silly decomposeActions install aws4@1.8.0
                                263 silly decomposeActions postinstall aws4@1.8.0
                                264 silly decomposeActions finalize aws4@1.8.0
                                265 silly decomposeActions refresh-package-json aws4@1.8.0
                                266 silly decomposeActions fetch caseless@0.12.0
                                267 silly decomposeActions extract caseless@0.12.0
                                268 silly decomposeActions preinstall caseless@0.12.0
                                269 silly decomposeActions build caseless@0.12.0
                                270 silly decomposeActions install caseless@0.12.0
                                271 silly decomposeActions postinstall caseless@0.12.0
                                272 silly decomposeActions finalize caseless@0.12.0
                                273 silly decomposeActions refresh-package-json caseless@0.12.0
                                274 silly decomposeActions fetch core-util-is@1.0.2
                                275 silly decomposeActions extract core-util-is@1.0.2
                                276 silly decomposeActions preinstall core-util-is@1.0.2
                                277 silly decomposeActions build core-util-is@1.0.2
                                278 silly decomposeActions install core-util-is@1.0.2
                                279 silly decomposeActions postinstall core-util-is@1.0.2
                                280 silly decomposeActions finalize core-util-is@1.0.2
                                281 silly decomposeActions refresh-package-json core-util-is@1.0.2
                                282 silly decomposeActions fetch dashdash@1.14.1
                                283 silly decomposeActions extract dashdash@1.14.1
                                284 silly decomposeActions preinstall dashdash@1.14.1
                                285 silly decomposeActions build dashdash@1.14.1
                                286 silly decomposeActions install dashdash@1.14.1
                                287 silly decomposeActions postinstall dashdash@1.14.1
                                288 silly decomposeActions finalize dashdash@1.14.1
                                289 silly decomposeActions refresh-package-json dashdash@1.14.1
                                290 silly decomposeActions fetch delayed-stream@1.0.0
                                291 silly decomposeActions extract delayed-stream@1.0.0
                                292 silly decomposeActions preinstall delayed-stream@1.0.0
                                293 silly decomposeActions build delayed-stream@1.0.0
                                294 silly decomposeActions install delayed-stream@1.0.0
                                295 silly decomposeActions postinstall delayed-stream@1.0.0
                                296 silly decomposeActions finalize delayed-stream@1.0.0
                                297 silly decomposeActions refresh-package-json delayed-stream@1.0.0
                                298 silly decomposeActions fetch combined-stream@1.0.7
                                299 silly decomposeActions extract combined-stream@1.0.7
                                300 silly decomposeActions preinstall combined-stream@1.0.7
                                301 silly decomposeActions build combined-stream@1.0.7
                                302 silly decomposeActions install combined-stream@1.0.7
                                303 silly decomposeActions postinstall combined-stream@1.0.7
                                304 silly decomposeActions finalize combined-stream@1.0.7
                                305 silly decomposeActions refresh-package-json combined-stream@1.0.7
                                306 silly decomposeActions fetch extend@3.0.2
                                307 silly decomposeActions extract extend@3.0.2
                                308 silly decomposeActions preinstall extend@3.0.2
                                309 silly decomposeActions build extend@3.0.2
                                310 silly decomposeActions install extend@3.0.2
                                311 silly decomposeActions postinstall extend@3.0.2
                                312 silly decomposeActions finalize extend@3.0.2
                                313 silly decomposeActions refresh-package-json extend@3.0.2
                                314 silly decomposeActions fetch extsprintf@1.3.0
                                315 silly decomposeActions extract extsprintf@1.3.0
                                316 silly decomposeActions preinstall extsprintf@1.3.0
                                317 silly decomposeActions build extsprintf@1.3.0
                                318 silly decomposeActions install extsprintf@1.3.0
                                319 silly decomposeActions postinstall extsprintf@1.3.0
                                320 silly decomposeActions finalize extsprintf@1.3.0
                                321 silly decomposeActions refresh-package-json extsprintf@1.3.0
                                322 silly decomposeActions fetch fast-deep-equal@2.0.1
                                323 silly decomposeActions extract fast-deep-equal@2.0.1
                                324 silly decomposeActions preinstall fast-deep-equal@2.0.1
                                325 silly decomposeActions build fast-deep-equal@2.0.1
                                326 silly decomposeActions install fast-deep-equal@2.0.1
                                327 silly decomposeActions postinstall fast-deep-equal@2.0.1
                                328 silly decomposeActions finalize fast-deep-equal@2.0.1
                                329 silly decomposeActions refresh-package-json fast-deep-equal@2.0.1
                                330 silly decomposeActions fetch fast-json-stable-stringify@2.0.0
                                331 silly decomposeActions extract fast-json-stable-stringify@2.0.0
                                332 silly decomposeActions preinstall fast-json-stable-stringify@2.0.0
                                333 silly decomposeActions build fast-json-stable-stringify@2.0.0
                                334 silly decomposeActions install fast-json-stable-stringify@2.0.0
                                335 silly decomposeActions postinstall fast-json-stable-stringify@2.0.0
                                336 silly decomposeActions finalize fast-json-stable-stringify@2.0.0
                                337 silly decomposeActions refresh-package-json fast-json-stable-stringify@2.0.0
                                338 silly decomposeActions fetch forever-agent@0.6.1
                                339 silly decomposeActions extract forever-agent@0.6.1
                                340 silly decomposeActions preinstall forever-agent@0.6.1
                                341 silly decomposeActions build forever-agent@0.6.1
                                342 silly decomposeActions install forever-agent@0.6.1
                                343 silly decomposeActions postinstall forever-agent@0.6.1
                                344 silly decomposeActions finalize forever-agent@0.6.1
                                345 silly decomposeActions refresh-package-json forever-agent@0.6.1
                                346 silly decomposeActions fetch getpass@0.1.7
                                347 silly decomposeActions extract getpass@0.1.7
                                348 silly decomposeActions preinstall getpass@0.1.7
                                349 silly decomposeActions build getpass@0.1.7
                                350 silly decomposeActions install getpass@0.1.7
                                351 silly decomposeActions postinstall getpass@0.1.7
                                352 silly decomposeActions finalize getpass@0.1.7
                                353 silly decomposeActions refresh-package-json getpass@0.1.7
                                354 silly decomposeActions fetch har-schema@2.0.0
                                355 silly decomposeActions extract har-schema@2.0.0
                                356 silly decomposeActions preinstall har-schema@2.0.0
                                357 silly decomposeActions build har-schema@2.0.0
                                358 silly decomposeActions install har-schema@2.0.0
                                359 silly decomposeActions postinstall har-schema@2.0.0
                                360 silly decomposeActions finalize har-schema@2.0.0
                                361 silly decomposeActions refresh-package-json har-schema@2.0.0
                                362 silly decomposeActions fetch is-typedarray@1.0.0
                                363 silly decomposeActions extract is-typedarray@1.0.0
                                364 silly decomposeActions preinstall is-typedarray@1.0.0
                                365 silly decomposeActions build is-typedarray@1.0.0
                                366 silly decomposeActions install is-typedarray@1.0.0
                                367 silly decomposeActions postinstall is-typedarray@1.0.0
                                368 silly decomposeActions finalize is-typedarray@1.0.0
                                369 silly decomposeActions refresh-package-json is-typedarray@1.0.0
                                370 silly decomposeActions fetch isstream@0.1.2
                                371 silly decomposeActions extract isstream@0.1.2
                                372 silly decomposeActions preinstall isstream@0.1.2
                                373 silly decomposeActions build isstream@0.1.2
                                374 silly decomposeActions install isstream@0.1.2
                                375 silly decomposeActions postinstall isstream@0.1.2
                                376 silly decomposeActions finalize isstream@0.1.2
                                377 silly decomposeActions refresh-package-json isstream@0.1.2
                                378 silly decomposeActions fetch jsbn@0.1.1
                                379 silly decomposeActions extract jsbn@0.1.1
                                380 silly decomposeActions preinstall jsbn@0.1.1
                                381 silly decomposeActions build jsbn@0.1.1
                                382 silly decomposeActions install jsbn@0.1.1
                                383 silly decomposeActions postinstall jsbn@0.1.1
                                384 silly decomposeActions finalize jsbn@0.1.1
                                385 silly decomposeActions refresh-package-json jsbn@0.1.1
                                386 silly decomposeActions fetch json-schema@0.2.3
                                387 silly decomposeActions extract json-schema@0.2.3
                                388 silly decomposeActions preinstall json-schema@0.2.3
                                389 silly decomposeActions build json-schema@0.2.3
                                390 silly decomposeActions install json-schema@0.2.3
                                391 silly decomposeActions postinstall json-schema@0.2.3
                                392 silly decomposeActions finalize json-schema@0.2.3
                                393 silly decomposeActions refresh-package-json json-schema@0.2.3
                                394 silly decomposeActions fetch json-schema-traverse@0.4.1
                                395 silly decomposeActions extract json-schema-traverse@0.4.1
                                396 silly decomposeActions preinstall json-schema-traverse@0.4.1
                                397 silly decomposeActions build json-schema-traverse@0.4.1
                                398 silly decomposeActions install json-schema-traverse@0.4.1
                                399 silly decomposeActions postinstall json-schema-traverse@0.4.1
                                400 silly decomposeActions finalize json-schema-traverse@0.4.1
                                401 silly decomposeActions refresh-package-json json-schema-traverse@0.4.1
                                402 silly decomposeActions fetch json-stringify-safe@5.0.1
                                403 silly decomposeActions extract json-stringify-safe@5.0.1
                                404 silly decomposeActions preinstall json-stringify-safe@5.0.1
                                405 silly decomposeActions build json-stringify-safe@5.0.1
                                406 silly decomposeActions install json-stringify-safe@5.0.1
                                407 silly decomposeActions postinstall json-stringify-safe@5.0.1
                                408 silly decomposeActions finalize json-stringify-safe@5.0.1
                                409 silly decomposeActions refresh-package-json json-stringify-safe@5.0.1
                                410 silly decomposeActions fetch mime-db@1.37.0
                                411 silly decomposeActions extract mime-db@1.37.0
                                412 silly decomposeActions preinstall mime-db@1.37.0
                                413 silly decomposeActions build mime-db@1.37.0
                                414 silly decomposeActions install mime-db@1.37.0
                                415 silly decomposeActions postinstall mime-db@1.37.0
                                416 silly decomposeActions finalize mime-db@1.37.0
                                417 silly decomposeActions refresh-package-json mime-db@1.37.0
                                418 silly decomposeActions fetch mime-types@2.1.21
                                419 silly decomposeActions extract mime-types@2.1.21
                                420 silly decomposeActions preinstall mime-types@2.1.21
                                421 silly decomposeActions build mime-types@2.1.21
                                422 silly decomposeActions install mime-types@2.1.21
                                423 silly decomposeActions postinstall mime-types@2.1.21
                                424 silly decomposeActions finalize mime-types@2.1.21
                                425 silly decomposeActions refresh-package-json mime-types@2.1.21
                                426 silly decomposeActions fetch form-data@2.3.3
                                427 silly decomposeActions extract form-data@2.3.3
                                428 silly decomposeActions preinstall form-data@2.3.3
                                429 silly decomposeActions build form-data@2.3.3
                                430 silly decomposeActions install form-data@2.3.3
                                431 silly decomposeActions postinstall form-data@2.3.3
                                432 silly decomposeActions finalize form-data@2.3.3
                                433 silly decomposeActions refresh-package-json form-data@2.3.3
                                434 silly decomposeActions fetch oauth-sign@0.9.0
                                435 silly decomposeActions extract oauth-sign@0.9.0
                                436 silly decomposeActions preinstall oauth-sign@0.9.0
                                437 silly decomposeActions build oauth-sign@0.9.0
                                438 silly decomposeActions install oauth-sign@0.9.0
                                439 silly decomposeActions postinstall oauth-sign@0.9.0
                                440 silly decomposeActions finalize oauth-sign@0.9.0
                                441 silly decomposeActions refresh-package-json oauth-sign@0.9.0
                                442 silly decomposeActions fetch performance-now@2.1.0
                                443 silly decomposeActions extract performance-now@2.1.0
                                444 silly decomposeActions preinstall performance-now@2.1.0
                                445 silly decomposeActions build performance-now@2.1.0
                                446 silly decomposeActions install performance-now@2.1.0
                                447 silly decomposeActions postinstall performance-now@2.1.0
                                448 silly decomposeActions finalize performance-now@2.1.0
                                449 silly decomposeActions refresh-package-json performance-now@2.1.0
                                450 silly decomposeActions fetch psl@1.1.29
                                451 silly decomposeActions extract psl@1.1.29
                                452 silly decomposeActions preinstall psl@1.1.29
                                453 silly decomposeActions build psl@1.1.29
                                454 silly decomposeActions install psl@1.1.29
                                455 silly decomposeActions postinstall psl@1.1.29
                                456 silly decomposeActions finalize psl@1.1.29
                                457 silly decomposeActions refresh-package-json psl@1.1.29
                                458 silly decomposeActions fetch punycode@2.1.1
                                459 silly decomposeActions extract punycode@2.1.1
                                460 silly decomposeActions preinstall punycode@2.1.1
                                461 silly decomposeActions build punycode@2.1.1
                                462 silly decomposeActions install punycode@2.1.1
                                463 silly decomposeActions postinstall punycode@2.1.1
                                464 silly decomposeActions finalize punycode@2.1.1
                                465 silly decomposeActions refresh-package-json punycode@2.1.1
                                466 silly decomposeActions fetch q@1.5.1
                                467 silly decomposeActions extract q@1.5.1
                                468 silly decomposeActions preinstall q@1.5.1
                                469 silly decomposeActions build q@1.5.1
                                470 silly decomposeActions install q@1.5.1
                                471 silly decomposeActions postinstall q@1.5.1
                                472 silly decomposeActions finalize q@1.5.1
                                473 silly decomposeActions refresh-package-json q@1.5.1
                                474 silly decomposeActions fetch qs@6.5.2
                                475 silly decomposeActions extract qs@6.5.2
                                476 silly decomposeActions preinstall qs@6.5.2
                                477 silly decomposeActions build qs@6.5.2
                                478 silly decomposeActions install qs@6.5.2
                                479 silly decomposeActions postinstall qs@6.5.2
                                480 silly decomposeActions finalize qs@6.5.2
                                481 silly decomposeActions refresh-package-json qs@6.5.2
                                482 silly decomposeActions fetch safe-buffer@5.1.2
                                483 silly decomposeActions extract safe-buffer@5.1.2
                                484 silly decomposeActions preinstall safe-buffer@5.1.2
                                485 silly decomposeActions build safe-buffer@5.1.2
                                486 silly decomposeActions install safe-buffer@5.1.2
                                487 silly decomposeActions postinstall safe-buffer@5.1.2
                                488 silly decomposeActions finalize safe-buffer@5.1.2
                                489 silly decomposeActions refresh-package-json safe-buffer@5.1.2
                                490 silly decomposeActions fetch safer-buffer@2.1.2
                                491 silly decomposeActions extract safer-buffer@2.1.2
                                492 silly decomposeActions preinstall safer-buffer@2.1.2
                                493 silly decomposeActions build safer-buffer@2.1.2
                                494 silly decomposeActions install safer-buffer@2.1.2
                                495 silly decomposeActions postinstall safer-buffer@2.1.2
                                496 silly decomposeActions finalize safer-buffer@2.1.2
                                497 silly decomposeActions refresh-package-json safer-buffer@2.1.2
                                498 silly decomposeActions fetch asn1@0.2.4
                                499 silly decomposeActions extract asn1@0.2.4
                                500 silly decomposeActions preinstall asn1@0.2.4
                                501 silly decomposeActions build asn1@0.2.4
                                502 silly decomposeActions install asn1@0.2.4
                                503 silly decomposeActions postinstall asn1@0.2.4
                                504 silly decomposeActions finalize asn1@0.2.4
                                505 silly decomposeActions refresh-package-json asn1@0.2.4
                                506 silly decomposeActions fetch ecc-jsbn@0.1.2
                                507 silly decomposeActions extract ecc-jsbn@0.1.2
                                508 silly decomposeActions preinstall ecc-jsbn@0.1.2
                                509 silly decomposeActions build ecc-jsbn@0.1.2
                                510 silly decomposeActions install ecc-jsbn@0.1.2
                                511 silly decomposeActions postinstall ecc-jsbn@0.1.2
                                512 silly decomposeActions finalize ecc-jsbn@0.1.2
                                513 silly decomposeActions refresh-package-json ecc-jsbn@0.1.2
                                514 silly decomposeActions fetch punycode@1.4.1
                                515 silly decomposeActions extract punycode@1.4.1
                                516 silly decomposeActions preinstall punycode@1.4.1
                                517 silly decomposeActions build punycode@1.4.1
                                518 silly decomposeActions install punycode@1.4.1
                                519 silly decomposeActions postinstall punycode@1.4.1
                                520 silly decomposeActions finalize punycode@1.4.1
                                521 silly decomposeActions refresh-package-json punycode@1.4.1
                                522 silly decomposeActions fetch tough-cookie@2.4.3
                                523 silly decomposeActions extract tough-cookie@2.4.3
                                524 silly decomposeActions preinstall tough-cookie@2.4.3
                                525 silly decomposeActions build tough-cookie@2.4.3
                                526 silly decomposeActions install tough-cookie@2.4.3
                                527 silly decomposeActions postinstall tough-cookie@2.4.3
                                528 silly decomposeActions finalize tough-cookie@2.4.3
                                529 silly decomposeActions refresh-package-json tough-cookie@2.4.3
                                530 silly decomposeActions fetch tunnel-agent@0.6.0
                                531 silly decomposeActions extract tunnel-agent@0.6.0
                                532 silly decomposeActions preinstall tunnel-agent@0.6.0
                                533 silly decomposeActions build tunnel-agent@0.6.0
                                534 silly decomposeActions install tunnel-agent@0.6.0
                                535 silly decomposeActions postinstall tunnel-agent@0.6.0
                                536 silly decomposeActions finalize tunnel-agent@0.6.0
                                537 silly decomposeActions refresh-package-json tunnel-agent@0.6.0
                                538 silly decomposeActions fetch tweetnacl@0.14.5
                                539 silly decomposeActions extract tweetnacl@0.14.5
                                540 silly decomposeActions preinstall tweetnacl@0.14.5
                                541 silly decomposeActions build tweetnacl@0.14.5
                                542 silly decomposeActions install tweetnacl@0.14.5
                                543 silly decomposeActions postinstall tweetnacl@0.14.5
                                544 silly decomposeActions finalize tweetnacl@0.14.5
                                545 silly decomposeActions refresh-package-json tweetnacl@0.14.5
                                546 silly decomposeActions fetch bcrypt-pbkdf@1.0.2
                                547 silly decomposeActions extract bcrypt-pbkdf@1.0.2
                                548 silly decomposeActions preinstall bcrypt-pbkdf@1.0.2
                                549 silly decomposeActions build bcrypt-pbkdf@1.0.2
                                550 silly decomposeActions install bcrypt-pbkdf@1.0.2
                                551 silly decomposeActions postinstall bcrypt-pbkdf@1.0.2
                                552 silly decomposeActions finalize bcrypt-pbkdf@1.0.2
                                553 silly decomposeActions refresh-package-json bcrypt-pbkdf@1.0.2
                                554 silly decomposeActions fetch sshpk@1.15.2
                                555 silly decomposeActions extract sshpk@1.15.2
                                556 silly decomposeActions preinstall sshpk@1.15.2
                                557 silly decomposeActions build sshpk@1.15.2
                                558 silly decomposeActions install sshpk@1.15.2
                                559 silly decomposeActions postinstall sshpk@1.15.2
                                560 silly decomposeActions finalize sshpk@1.15.2
                                561 silly decomposeActions refresh-package-json sshpk@1.15.2
                                562 silly decomposeActions fetch underscore@1.9.1
                                563 silly decomposeActions extract underscore@1.9.1
                                564 silly decomposeActions preinstall underscore@1.9.1
                                565 silly decomposeActions build underscore@1.9.1
                                566 silly decomposeActions install underscore@1.9.1
                                567 silly decomposeActions postinstall underscore@1.9.1
                                568 silly decomposeActions finalize underscore@1.9.1
                                569 silly decomposeActions refresh-package-json underscore@1.9.1
                                570 silly decomposeActions fetch uri-js@4.2.2
                                571 silly decomposeActions extract uri-js@4.2.2
                                572 silly decomposeActions preinstall uri-js@4.2.2
                                573 silly decomposeActions build uri-js@4.2.2
                                574 silly decomposeActions install uri-js@4.2.2
                                575 silly decomposeActions postinstall uri-js@4.2.2
                                576 silly decomposeActions finalize uri-js@4.2.2
                                577 silly decomposeActions refresh-package-json uri-js@4.2.2
                                578 silly decomposeActions fetch ajv@6.5.5
                                579 silly decomposeActions extract ajv@6.5.5
                                580 silly decomposeActions preinstall ajv@6.5.5
                                581 silly decomposeActions build ajv@6.5.5
                                582 silly decomposeActions install ajv@6.5.5
                                583 silly decomposeActions postinstall ajv@6.5.5
                                584 silly decomposeActions finalize ajv@6.5.5
                                585 silly decomposeActions refresh-package-json ajv@6.5.5
                                586 silly decomposeActions fetch har-validator@5.1.3
                                587 silly decomposeActions extract har-validator@5.1.3
                                588 silly decomposeActions preinstall har-validator@5.1.3
                                589 silly decomposeActions build har-validator@5.1.3
                                590 silly decomposeActions install har-validator@5.1.3
                                591 silly decomposeActions postinstall har-validator@5.1.3
                                592 silly decomposeActions finalize har-validator@5.1.3
                                593 silly decomposeActions refresh-package-json har-validator@5.1.3
                                594 silly decomposeActions fetch uuid@3.3.2
                                595 silly decomposeActions extract uuid@3.3.2
                                596 silly decomposeActions preinstall uuid@3.3.2
                                597 silly decomposeActions build uuid@3.3.2
                                598 silly decomposeActions install uuid@3.3.2
                                599 silly decomposeActions postinstall uuid@3.3.2
                                600 silly decomposeActions finalize uuid@3.3.2
                                601 silly decomposeActions refresh-package-json uuid@3.3.2
                                602 silly decomposeActions fetch verror@1.10.0
                                603 silly decomposeActions extract verror@1.10.0
                                604 silly decomposeActions preinstall verror@1.10.0
                                605 silly decomposeActions build verror@1.10.0
                                606 silly decomposeActions install verror@1.10.0
                                607 silly decomposeActions postinstall verror@1.10.0
                                608 silly decomposeActions finalize verror@1.10.0
                                609 silly decomposeActions refresh-package-json verror@1.10.0
                                610 silly decomposeActions fetch jsprim@1.4.1
                                611 silly decomposeActions extract jsprim@1.4.1
                                612 silly decomposeActions preinstall jsprim@1.4.1
                                613 silly decomposeActions build jsprim@1.4.1
                                614 silly decomposeActions install jsprim@1.4.1
                                615 silly decomposeActions postinstall jsprim@1.4.1
                                616 silly decomposeActions finalize jsprim@1.4.1
                                617 silly decomposeActions refresh-package-json jsprim@1.4.1
                                618 silly decomposeActions fetch http-signature@1.2.0
                                619 silly decomposeActions extract http-signature@1.2.0
                                620 silly decomposeActions preinstall http-signature@1.2.0
                                621 silly decomposeActions build http-signature@1.2.0
                                622 silly decomposeActions install http-signature@1.2.0
                                623 silly decomposeActions postinstall http-signature@1.2.0
                                624 silly decomposeActions finalize http-signature@1.2.0
                                625 silly decomposeActions refresh-package-json http-signature@1.2.0
                                626 silly decomposeActions fetch nopy@0.2.6
                                627 silly decomposeActions extract nopy@0.2.6
                                628 silly decomposeActions preinstall nopy@0.2.6
                                629 silly decomposeActions build nopy@0.2.6
                                630 silly decomposeActions install nopy@0.2.6
                                631 silly decomposeActions postinstall nopy@0.2.6
                                632 silly decomposeActions finalize nopy@0.2.6
                                633 silly decomposeActions refresh-package-json nopy@0.2.6
                                634 silly decomposeActions fetch ping@0.2.2
                                635 silly decomposeActions extract ping@0.2.2
                                636 silly decomposeActions preinstall ping@0.2.2
                                637 silly decomposeActions build ping@0.2.2
                                638 silly decomposeActions install ping@0.2.2
                                639 silly decomposeActions postinstall ping@0.2.2
                                640 silly decomposeActions finalize ping@0.2.2
                                641 silly decomposeActions refresh-package-json ping@0.2.2
                                642 silly decomposeActions fetch request@2.88.0
                                643 silly decomposeActions extract request@2.88.0
                                644 silly decomposeActions preinstall request@2.88.0
                                645 silly decomposeActions build request@2.88.0
                                646 silly decomposeActions install request@2.88.0
                                647 silly decomposeActions postinstall request@2.88.0
                                648 silly decomposeActions finalize request@2.88.0
                                649 silly decomposeActions refresh-package-json request@2.88.0
                                650 silly decomposeActions fetch iobroker.xbox@0.1.4
                                651 silly decomposeActions extract iobroker.xbox@0.1.4
                                652 silly decomposeActions preinstall iobroker.xbox@0.1.4
                                653 silly decomposeActions build iobroker.xbox@0.1.4
                                654 silly decomposeActions install iobroker.xbox@0.1.4
                                655 silly decomposeActions postinstall iobroker.xbox@0.1.4
                                656 silly decomposeActions finalize iobroker.xbox@0.1.4
                                657 silly decomposeActions refresh-package-json iobroker.xbox@0.1.4
                                658 silly install executeActions
                                659 silly doSerial global-install 424
                                660 verbose correctMkdir C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_locks correctMkdir not in flight; initializing
                                661 verbose lock using C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_locks\staging-dc72d96e288e3e7c.lock for C:\ioBroker\node_modules\.staging
                                662 silly doParallel extract 53
                                663 silly extract assert-plus@1.0.0
                                664 silly extract asynckit@0.4.0
                                665 silly extract aws-sign2@0.7.0
                                666 silly extract aws4@1.8.0
                                667 silly extract caseless@0.12.0
                                668 silly extract core-util-is@1.0.2
                                669 silly extract dashdash@1.14.1
                                670 silly extract delayed-stream@1.0.0
                                671 silly extract combined-stream@1.0.7
                                672 silly extract extend@3.0.2
                                673 silly extract extsprintf@1.3.0
                                674 silly extract fast-deep-equal@2.0.1
                                675 silly extract fast-json-stable-stringify@2.0.0
                                676 silly extract forever-agent@0.6.1
                                677 silly extract getpass@0.1.7
                                678 silly extract har-schema@2.0.0
                                679 silly extract is-typedarray@1.0.0
                                680 silly extract isstream@0.1.2
                                681 silly extract jsbn@0.1.1
                                682 silly extract json-schema@0.2.3
                                683 silly extract json-schema-traverse@0.4.1
                                684 silly extract json-stringify-safe@5.0.1
                                685 silly extract mime-db@1.37.0
                                686 silly extract mime-types@2.1.21
                                687 silly extract form-data@2.3.3
                                688 silly extract oauth-sign@0.9.0
                                689 silly extract performance-now@2.1.0
                                690 silly extract psl@1.1.29
                                691 silly extract punycode@2.1.1
                                692 silly extract q@1.5.1
                                693 silly extract qs@6.5.2
                                694 silly extract safe-buffer@5.1.2
                                695 silly extract safer-buffer@2.1.2
                                696 silly extract asn1@0.2.4
                                697 silly extract ecc-jsbn@0.1.2
                                698 silly extract punycode@1.4.1
                                699 silly extract tough-cookie@2.4.3
                                700 silly extract tunnel-agent@0.6.0
                                701 silly extract tweetnacl@0.14.5
                                702 silly extract bcrypt-pbkdf@1.0.2
                                703 silly extract sshpk@1.15.2
                                704 silly extract underscore@1.9.1
                                705 silly extract uri-js@4.2.2
                                706 silly extract ajv@6.5.5
                                707 silly extract har-validator@5.1.3
                                708 silly extract uuid@3.3.2
                                709 silly extract verror@1.10.0
                                710 silly extract jsprim@1.4.1
                                711 silly extract http-signature@1.2.0
                                712 silly extract nopy@0.2.6
                                713 silly tarball trying assert-plus@^1.0.0 by hash: sha1-8S4PPF13sLHN2RRpQuTpbB5N1SU=
                                714 silly tarball trying asynckit@^0.4.0 by hash: sha1-x57Zf380y48robyXkLzDZkdLS3k=
                                715 silly tarball trying aws-sign2@~0.7.0 by hash: sha1-tG6JCTSpWR8tL2+G1+ap8bP+dqg=
                                716 silly tarball trying aws4@^1.8.0 by hash: sha512-ReZxvNHIOv88FlT7rxcXIIC0fPt4KZqZbOlivyWtXLt8ESx84zd3kMC6iK5jVeS2qt+g7ftS7ye4fi06X5rtRQ==
                                717 silly tarball trying caseless@~0.12.0 by hash: sha1-G2gcIf+EAzyCZUMJBolCDRhxUdw=
                                718 silly tarball trying core-util-is@1.0.2 by hash: sha1-tf1UIgqivFq1eqtxQMlAdUUDwac=
                                719 silly tarball trying dashdash@^1.12.0 by hash: sha1-hTz6D3y+L+1d4gMmuN1YEDX24vA=
                                720 silly tarball trying delayed-stream@~1.0.0 by hash: sha1-3zrhmayt+31ECqrgsp4icrJOxhk=
                                721 silly tarball trying combined-stream@~1.0.6 by hash: sha512-brWl9y6vOB1xYPZcpZde3N9zDByXTosAeMDo4p1wzo6UMOX4vumB+TP1RZ76sfE6Md68Q0NJSrE/gbezd4Ul+w==
                                722 silly tarball trying extend@~3.0.2 by hash: sha512-fjquC59cD7CyW6urNXK0FBufkZcoiGG80wTuPujX590cB5Ttln20E2UB4S/WARVqhXffZl2LNgS+gQdPIIim/g==
                                723 silly tarball trying extsprintf@1.3.0 by hash: sha1-lpGEQOMEGnpBT4xS48V06zw+HgU=
                                724 silly tarball trying fast-deep-equal@^2.0.1 by hash: sha1-ewUhjd+WZ79/Nwv3/bLLFf3Qqkk=
                                725 silly tarball trying fast-json-stable-stringify@^2.0.0 by hash: sha1-1RQsDK7msRifh9OnYREGT4bIu/I=
                                726 silly tarball trying forever-agent@~0.6.1 by hash: sha1-+8cfDEGt6zf5bFd60e1C2P2sypE=
                                727 silly tarball trying getpass@^0.1.1 by hash: sha1-Xv+OPmhNVprkyysSgmBOi6YhSfo=
                                728 silly tarball trying har-schema@^2.0.0 by hash: sha1-qUwiJOvKwEeCoNkDVSHyRzW37JI=
                                729 silly tarball trying is-typedarray@~1.0.0 by hash: sha1-5HnICFjfDBsR3dppQPlgEfzaSpo=
                                730 silly tarball trying isstream@~0.1.2 by hash: sha1-R+Y/evVa+m+S4VAOaQ64uFKcCZo=
                                731 silly tarball trying jsbn@~0.1.0 by hash: sha1-peZUwuWi3rXyAdls77yoDA7y9RM=
                                732 silly tarball trying json-schema@0.2.3 by hash: sha1-tIDIkuWaLwWVTOcnvT8qTogvnhM=
                                733 silly tarball trying json-schema-traverse@^0.4.1 by hash: sha512-xbbCH5dCYU5T8LcEhhuh7HJ88HXuW3qsI3Y0zOZFKfZEHcpWiHU/Jxzk629Brsab/mMiHQti9wMP+845RPe3Vg==
                                734 silly tarball trying json-stringify-safe@~5.0.1 by hash: sha1-Epai1Y/UXxmg9s4B1lcB4sc1tus=
                                735 silly tarball trying mime-db@~1.37.0 by hash: sha512-R3C4db6bgQhlIhPU48fUtdVmKnflq+hRdad7IyKhtFj06VPNVdk2RhiYL3UjQIlso8L+YxAtFkobT0VK+S/ybg==
                                736 silly tarball trying mime-types@~2.1.19 by hash: sha512-3iL6DbwpyLzjR3xHSFNFeb9Nz/M8WDkX33t1GFQnFOllWk8pOrh/LSrB5OXlnlW5P9LH73X6loW/eogc+F5lJg==
                                737 silly tarball trying form-data@~2.3.2 by hash: sha512-1lLKB2Mu3aGP1Q/2eCOx0fNbRMe7XdwktwOruhfqqd0rIJWwN4Dh+E3hrPSlDCXnSR7UtZ1N38rVXm+6+MEhJQ==
                                738 silly tarball trying oauth-sign@~0.9.0 by hash: sha512-fexhUFFPTGV8ybAtSIGbV6gOkSv8UtRbDBnAyLQw4QPKkgNlsH2ByPGtMUqdWkos6YCRmAqViwgZrJc/mRDzZQ==
                                739 silly tarball trying performance-now@^2.1.0 by hash: sha1-Ywn04OX6kT7BxpMHrjZLSzd8nns=
                                740 silly tarball trying psl@^1.1.24 by hash: sha512-AeUmQ0oLN02flVHXWh9sSJF7mcdFq0ppid/JkErufc3hGIV/AMa8Fo9VgDo/cT2jFdOWoFvHp90qqBH54W+gjQ==
                                741 silly tarball trying punycode@^2.1.0 by hash: sha512-XRsRjdf+j5ml+y/6GKHPZbrF/8p2Yga0JPtdqTIY2Xe5ohJPD9saDJJLPvp9+NSBprVvevdXZybnj2cv8OEd0A==
                                742 silly tarball trying q@1.x by hash: sha1-fjL3W0E4EpHQRhHxvxQQmsAGUdc=
                                743 silly tarball trying qs@~6.5.2 by hash: sha512-N5ZAX4/LxJmF+7wN74pUD6qAh9/wnvdQcjq9TZjevvXzSUo7bfmw91saqMjzGS2xq91/odN2dW/WOl7qQHNDGA==
                                744 silly tarball trying safe-buffer@^5.1.2 by hash: sha512-Gd2UZBJDkXlY7GbJxfsE8/nvKkUEU1G38c1siN6QP6a9PT9MmHB8GnpscSmMJSoF8LOIrt8ud/wPtojys4G6+g==
                                745 silly tarball trying safer-buffer@^2.0.2 by hash: sha512-YZo3K82SD7Riyi0E1EQPojLz7kpepnSQI9IyPbHHg1XXXevb5dJI7tpyN2ADxGcQbHG7vcyRHk0cbwqcQriUtg==
                                746 silly tarball trying asn1@~0.2.3 by hash: sha512-jxwzQpLQjSmWXgwaCZE9Nz+glAG01yF1QnWgbhGwHI5A6FRIEY6IVqtHhIepHqI7/kyEyQEagBC5mBEFlIYvdg==
                                747 silly tarball trying ecc-jsbn@~0.1.1 by hash: sha1-OoOpBOVDUyh4dMVkt1SThoSamMk=
                                748 silly tarball trying punycode@^1.4.1 by hash: sha1-wNWmOycYgArY4esPpSachN1BhF4=
                                749 silly tarball trying tough-cookie@~2.4.3 by hash: sha512-Q5srk/4vDM54WJsJio3XNn6K2sCG+CQ8G5Wz6bZhRZoAe/+TxjWB/GlFAnYEbkYVlON9FMk/fE3h2RLpPXo4lQ==
                                750 silly tarball trying tunnel-agent@^0.6.0 by hash: sha1-J6XeoGs2sEoKmWZ3SykIaPD8QP0=
                                751 silly tarball trying tweetnacl@~0.14.0 by hash: sha1-WuaBd/GS1EViadEIr6k/+HQ/T2Q=
                                752 silly tarball trying bcrypt-pbkdf@^1.0.0 by hash: sha1-pDAdOJtqQ/m2f/PKEaP2Y342Dp4=
                                753 silly tarball trying sshpk@^1.7.0 by hash: sha512-Ra/OXQtuh0/enyl4ETZAfTaeksa6BXks5ZcjpSUNrjBr0DvrJKX+1fsKDPpT9TBXgHAFsa4510aNVgI8g/+SzA==
                                754 silly tarball trying underscore@^1.8.3 by hash: sha512-5/4etnCkd9c8gwgowi5/om/mYO5ajCaOgdzj/oW+0eQV9WxKBDZw5+ycmKmeaTXjInS/W0BzpGLo2xR2aBwZdg==
                                755 silly tarball trying uri-js@^4.2.2 by hash: sha512-KY9Frmirql91X2Qgjry0Wd4Y+YTdrdZheS8TFwvkbLWf/G5KNJDCh6pKL5OZctEW4+0Baa5idK2ZQuELRwPznQ==
                                756 silly tarball trying ajv@^6.5.5 by hash: sha512-7q7gtRQDJSyuEHjuVgHoUa2VuemFiCMrfQc9Tc08XTAc4Zj/5U1buQJ0HU6i7fKjXU09SVgSmxa4sLvuvS8Iyg==
                                757 silly tarball trying har-validator@~5.1.0 by hash: sha512-sNvOCzEQNr/qrvJgc3UG/kD4QtlHycrzwS+6mfTrrSq97BvaYcPZZI1ZSqGSPR73Cxn4LKTD4PttRwfU7jWq5g==
                                758 silly tarball trying uuid@^3.3.2 by hash: sha512-yXJmeNaw3DnnKAOKJE51sL/ZaYfWJRl1pK9dr19YFCu0ObS231AB1/LbqTKRAQ5kw8A90rA6fr4riOUpTZvQZA==
                                759 silly tarball trying verror@1.10.0 by hash: sha1-OhBcoXBTr1XW4nDB+CiGguGNpAA=
                                760 silly tarball trying jsprim@^1.2.2 by hash: sha1-MT5mvB5cwG5Di8G3SZwuXFastqI=
                                761 silly tarball trying http-signature@~1.2.0 by hash: sha1-muzZJRFHcvPZW2WmCruPfBj7rOE=
                                762 silly tarball trying nopy@^0.2.6 by hash: sha512-yQ+H2iYnHfMfR3S6jMEWDvUZgCYTYnBGUipFA/npdjZu8tPpDdwHg4yoPPSO3zLiL968yBGarVZ8CHnEnqkp0Q==
                                763 silly tarball no local data for har-validator@~5.1.0\. Extracting by manifest.
                                764 silly extract oauth-sign@~0.9.0 extracted to C:\ioBroker\node_modules\.staging\oauth-sign-d3881ff9 (300ms)
                                765 silly extract caseless@~0.12.0 extracted to C:\ioBroker\node_modules\.staging\caseless-02594abe (319ms)
                                766 silly extract assert-plus@^1.0.0 extracted to C:\ioBroker\node_modules\.staging\assert-plus-d90adc87 (322ms)
                                767 silly extract aws-sign2@~0.7.0 extracted to C:\ioBroker\node_modules\.staging\aws-sign2-1472df5b (322ms)
                                768 silly extract fast-deep-equal@^2.0.1 extracted to C:\ioBroker\node_modules\.staging\fast-deep-equal-8c832733 (323ms)
                                769 silly extract is-typedarray@~1.0.0 extracted to C:\ioBroker\node_modules\.staging\is-typedarray-0bc8497c (321ms)
                                770 silly extract forever-agent@~0.6.1 extracted to C:\ioBroker\node_modules\.staging\forever-agent-8bfd24af (323ms)
                                771 silly extract iobroker.xbox@0.1.4
                                772 silly tarball trying https://github.com/foxriver76/ioBroker.xbox/tarball/master by hash: sha512-HaM0AwCJlzEU0EX0EiA6dWPHdnW20/E3ZFyU6bNpTzGTfMcpaHXvNUrdv0TnVOyPUifRRxNzi7Ou4m60gLHnFw==
                                773 silly extract tunnel-agent@^0.6.0 extracted to C:\ioBroker\node_modules\.staging\tunnel-agent-2936f2f6 (316ms)
                                774 silly extract request@2.88.0
                                775 silly extract ping@0.2.2
                                776 silly tarball trying request@^2.87.0 by hash: sha512-NAqBSrijGLZdM0WZNsInLJpkJokL72XYjUpnB0iwsRgxh7dB6COrHnTBNwN0E+lHDAJzu7kLAkDeY08z2/A0hg==
                                777 silly tarball trying ping@^0.2.2 by hash: sha1-GA+3UIwdx0eThJvONcgHP5llvOI=
                                778 silly extract mime-types@~2.1.19 extracted to C:\ioBroker\node_modules\.staging\mime-types-fdcd734c (335ms)
                                779 silly extract punycode@^1.4.1 extracted to C:\ioBroker\node_modules\.staging\punycode-d65e6ad2 (329ms)
                                780 silly extract safe-buffer@^5.1.2 extracted to C:\ioBroker\node_modules\.staging\safe-buffer-a5f3087f (343ms)
                                781 silly tarball no local data for https://github.com/foxriver76/ioBroker.xbox/tarball/master. Extracting by manifest.
                                782 silly extract punycode@^2.1.0 extracted to C:\ioBroker\node_modules\.staging\punycode-fbb806b9 (354ms)
                                783 silly extract bcrypt-pbkdf@^1.0.0 extracted to C:\ioBroker\node_modules\.staging\bcrypt-pbkdf-52fb29ac (352ms)
                                784 silly extract aws4@^1.8.0 extracted to C:\ioBroker\node_modules\.staging\aws4-409b41f7 (370ms)
                                785 silly extract delayed-stream@~1.0.0 extracted to C:\ioBroker\node_modules\.staging\delayed-stream-54eb2c4f (374ms)
                                786 silly extract getpass@^0.1.1 extracted to C:\ioBroker\node_modules\.staging\getpass-b1dde682 (371ms)
                                787 silly extract extend@~3.0.2 extracted to C:\ioBroker\node_modules\.staging\extend-32d54fd9 (377ms)
                                788 silly extract isstream@~0.1.2 extracted to C:\ioBroker\node_modules\.staging\isstream-ee9b8fdd (375ms)
                                789 silly extract safer-buffer@^2.0.2 extracted to C:\ioBroker\node_modules\.staging\safer-buffer-ff1dc205 (375ms)
                                790 silly extract jsprim@^1.2.2 extracted to C:\ioBroker\node_modules\.staging\jsprim-ffe58aa6 (370ms)
                                791 silly extract core-util-is@1.0.2 extracted to C:\ioBroker\node_modules\.staging\core-util-is-34f76e76 (390ms)
                                792 silly extract jsbn@~0.1.0 extracted to C:\ioBroker\node_modules\.staging\jsbn-34922606 (386ms)
                                793 silly extract verror@1.10.0 extracted to C:\ioBroker\node_modules\.staging\verror-ebe5ca47 (393ms)
                                794 silly extract extsprintf@1.3.0 extracted to C:\ioBroker\node_modules\.staging\extsprintf-9411786b (411ms)
                                795 silly extract json-stringify-safe@~5.0.1 extracted to C:\ioBroker\node_modules\.staging\json-stringify-safe-54641e50 (407ms)
                                796 silly extract underscore@^1.8.3 extracted to C:\ioBroker\node_modules\.staging\underscore-4e4464ae (404ms)
                                797 silly extract q@1.x extracted to C:\ioBroker\node_modules\.staging\q-02274de7 (413ms)
                                798 silly extract combined-stream@~1.0.6 extracted to C:\ioBroker\node_modules\.staging\combined-stream-2b3b5936 (422ms)
                                799 http fetch GET 200 https://registry.npmjs.org/har-validator/-/har-validator-5.1.3.tgz 213ms
                                800 silly extract mime-db@~1.37.0 extracted to C:\ioBroker\node_modules\.staging\mime-db-2fb00aec (442ms)
                                801 silly extract asn1@~0.2.3 extracted to C:\ioBroker\node_modules\.staging\asn1-010fdce1 (439ms)
                                802 silly extract tough-cookie@~2.4.3 extracted to C:\ioBroker\node_modules\.staging\tough-cookie-e47fc23f (436ms)
                                803 silly extract har-validator@~5.1.0 extracted to C:\ioBroker\node_modules\.staging\har-validator-138df87b (437ms)
                                804 silly extract dashdash@^1.12.0 extracted to C:\ioBroker\node_modules\.staging\dashdash-cf8db266 (455ms)
                                805 silly extract json-schema-traverse@^0.4.1 extracted to C:\ioBroker\node_modules\.staging\json-schema-traverse-a9d91f57 (450ms)
                                806 silly extract form-data@~2.3.2 extracted to C:\ioBroker\node_modules\.staging\form-data-56efbe0c (460ms)
                                807 silly extract ecc-jsbn@~0.1.1 extracted to C:\ioBroker\node_modules\.staging\ecc-jsbn-757a50b1 (456ms)
                                808 silly extract http-signature@~1.2.0 extracted to C:\ioBroker\node_modules\.staging\http-signature-70f33f47 (450ms)
                                809 silly extract asynckit@^0.4.0 extracted to C:\ioBroker\node_modules\.staging\asynckit-06437117 (473ms)
                                810 silly extract tweetnacl@~0.14.0 extracted to C:\ioBroker\node_modules\.staging\tweetnacl-08592135 (475ms)
                                811 silly extract har-schema@^2.0.0 extracted to C:\ioBroker\node_modules\.staging\har-schema-a8400a26 (490ms)
                                812 silly extract fast-json-stable-stringify@^2.0.0 extracted to C:\ioBroker\node_modules\.staging\fast-json-stable-stringify-1dc66bcc (494ms)
                                813 silly extract performance-now@^2.1.0 extracted to C:\ioBroker\node_modules\.staging\performance-now-5c218fa0 (495ms)
                                814 silly extract uuid@^3.3.2 extracted to C:\ioBroker\node_modules\.staging\uuid-a5735537 (486ms)
                                815 silly extract qs@~6.5.2 extracted to C:\ioBroker\node_modules\.staging\qs-58271aa7 (519ms)
                                816 silly extract request@^2.87.0 extracted to C:\ioBroker\node_modules\.staging\request-9e403a4e (223ms)
                                817 silly extract json-schema@0.2.3 extracted to C:\ioBroker\node_modules\.staging\json-schema-b75e6f15 (597ms)
                                818 silly extract psl@^1.1.24 extracted to C:\ioBroker\node_modules\.staging\psl-64c0f672 (597ms)
                                819 silly extract sshpk@^1.7.0 extracted to C:\ioBroker\node_modules\.staging\sshpk-95b607c8 (599ms)
                                820 silly extract ping@^0.2.2 extracted to C:\ioBroker\node_modules\.staging\ping-1a6d01b3 (321ms)
                                821 silly extract nopy@^0.2.6 extracted to C:\ioBroker\node_modules\.staging\nopy-2385b571 (637ms)
                                822 silly extract uri-js@^4.2.2 extracted to C:\ioBroker\node_modules\.staging\uri-js-72941972 (642ms)
                                823 silly extract ajv@^6.5.5 extracted to C:\ioBroker\node_modules\.staging\ajv-db4a3716 (664ms)
                                824 http fetch GET 200 https://github.com/foxriver76/ioBroker.xbox/tarball/master 529ms
                                825 silly extract https://github.com/foxriver76/ioBroker.xbox/tarball/master extracted to C:\ioBroker\node_modules\.staging\iobroker.xbox-831ff231 (556ms)
                                826 timing action:extract Completed in 891ms
                                827 silly doReverseSerial unbuild 424
                                828 silly doSerial remove 424
                                829 silly doSerial move 424
                                830 silly doSerial finalize 424
                                831 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\assert-plus
                                832 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\asynckit
                                833 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\aws-sign2
                                834 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\aws4
                                835 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\caseless
                                836 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\core-util-is
                                837 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\dashdash
                                838 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\delayed-stream
                                839 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\combined-stream
                                840 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\extend
                                841 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\extsprintf
                                842 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\fast-deep-equal
                                843 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\fast-json-stable-stringify
                                844 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\forever-agent
                                845 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\getpass
                                846 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\har-schema
                                847 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\is-typedarray
                                848 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\isstream
                                849 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\jsbn
                                850 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\json-schema
                                851 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\json-schema-traverse
                                852 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\json-stringify-safe
                                853 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\mime-db
                                854 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\mime-types
                                855 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\form-data
                                856 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\oauth-sign
                                857 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\performance-now
                                858 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\psl
                                859 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\punycode
                                860 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\q
                                861 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\qs
                                862 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\safe-buffer
                                863 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\safer-buffer
                                864 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\asn1
                                865 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\ecc-jsbn
                                866 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\tough-cookie\node_modules\punycode
                                867 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\tough-cookie
                                868 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\tunnel-agent
                                869 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\tweetnacl
                                870 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\bcrypt-pbkdf
                                871 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\sshpk
                                872 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\underscore
                                873 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\uri-js
                                874 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\ajv
                                875 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\har-validator
                                876 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\uuid
                                877 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\verror
                                878 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\jsprim
                                879 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\http-signature
                                880 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\nopy
                                881 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\ping
                                882 silly finalize C:\ioBroker\node_modules\iobroker.xbox\node_modules\request
                                883 silly finalize C:\ioBroker\node_modules\iobroker.xbox
                                884 timing action:finalize Completed in 191ms
                                885 silly doParallel refresh-package-json 53
                                886 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\assert-plus
                                887 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\asynckit
                                888 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\aws-sign2
                                889 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\aws4
                                890 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\caseless
                                891 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\core-util-is
                                892 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\dashdash
                                893 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\delayed-stream
                                894 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\combined-stream
                                895 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\extend
                                896 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\extsprintf
                                897 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\fast-deep-equal
                                898 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\fast-json-stable-stringify
                                899 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\forever-agent
                                900 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\getpass
                                901 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\har-schema
                                902 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\is-typedarray
                                903 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\isstream
                                904 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\jsbn
                                905 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\json-schema
                                906 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\json-schema-traverse
                                907 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\json-stringify-safe
                                908 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\mime-db
                                909 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\mime-types
                                910 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\form-data
                                911 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\oauth-sign
                                912 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\performance-now
                                913 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\psl
                                914 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\punycode
                                915 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\q
                                916 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\qs
                                917 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\safe-buffer
                                918 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\safer-buffer
                                919 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\asn1
                                920 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\ecc-jsbn
                                921 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\tough-cookie\node_modules\punycode
                                922 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\tough-cookie
                                923 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\tunnel-agent
                                924 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\tweetnacl
                                925 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\bcrypt-pbkdf
                                926 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\sshpk
                                927 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\underscore
                                928 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\uri-js
                                929 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\ajv
                                930 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\har-validator
                                931 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\uuid
                                932 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\verror
                                933 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\jsprim
                                934 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\http-signature
                                935 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\nopy
                                936 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox
                                937 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\request
                                938 silly refresh-package-json C:\ioBroker\node_modules\iobroker.xbox\node_modules\ping
                                939 timing action:refresh-package-json Completed in 552ms
                                940 silly doParallel preinstall 53
                                941 silly preinstall assert-plus@1.0.0
                                942 info lifecycle assert-plus@1.0.0~preinstall: assert-plus@1.0.0
                                943 silly preinstall asynckit@0.4.0
                                944 info lifecycle asynckit@0.4.0~preinstall: asynckit@0.4.0
                                945 silly preinstall aws-sign2@0.7.0
                                946 info lifecycle aws-sign2@0.7.0~preinstall: aws-sign2@0.7.0
                                947 silly preinstall aws4@1.8.0
                                948 info lifecycle aws4@1.8.0~preinstall: aws4@1.8.0
                                949 silly preinstall caseless@0.12.0
                                950 info lifecycle caseless@0.12.0~preinstall: caseless@0.12.0
                                951 silly preinstall core-util-is@1.0.2
                                952 info lifecycle core-util-is@1.0.2~preinstall: core-util-is@1.0.2
                                953 silly preinstall dashdash@1.14.1
                                954 info lifecycle dashdash@1.14.1~preinstall: dashdash@1.14.1
                                955 silly preinstall delayed-stream@1.0.0
                                956 info lifecycle delayed-stream@1.0.0~preinstall: delayed-stream@1.0.0
                                957 silly preinstall combined-stream@1.0.7
                                958 info lifecycle combined-stream@1.0.7~preinstall: combined-stream@1.0.7
                                959 silly preinstall extend@3.0.2
                                960 info lifecycle extend@3.0.2~preinstall: extend@3.0.2
                                961 silly preinstall extsprintf@1.3.0
                                962 info lifecycle extsprintf@1.3.0~preinstall: extsprintf@1.3.0
                                963 silly preinstall fast-deep-equal@2.0.1
                                964 info lifecycle fast-deep-equal@2.0.1~preinstall: fast-deep-equal@2.0.1
                                965 silly preinstall fast-json-stable-stringify@2.0.0
                                966 info lifecycle fast-json-stable-stringify@2.0.0~preinstall: fast-json-stable-stringify@2.0.0
                                967 silly preinstall forever-agent@0.6.1
                                968 info lifecycle forever-agent@0.6.1~preinstall: forever-agent@0.6.1
                                969 silly preinstall getpass@0.1.7
                                970 info lifecycle getpass@0.1.7~preinstall: getpass@0.1.7
                                971 silly preinstall har-schema@2.0.0
                                972 info lifecycle har-schema@2.0.0~preinstall: har-schema@2.0.0
                                973 silly preinstall is-typedarray@1.0.0
                                974 info lifecycle is-typedarray@1.0.0~preinstall: is-typedarray@1.0.0
                                975 silly preinstall isstream@0.1.2
                                976 info lifecycle isstream@0.1.2~preinstall: isstream@0.1.2
                                977 silly preinstall jsbn@0.1.1
                                978 info lifecycle jsbn@0.1.1~preinstall: jsbn@0.1.1
                                979 silly preinstall json-schema@0.2.3
                                980 info lifecycle json-schema@0.2.3~preinstall: json-schema@0.2.3
                                981 silly preinstall json-schema-traverse@0.4.1
                                982 info lifecycle json-schema-traverse@0.4.1~preinstall: json-schema-traverse@0.4.1
                                983 silly preinstall json-stringify-safe@5.0.1
                                984 info lifecycle json-stringify-safe@5.0.1~preinstall: json-stringify-safe@5.0.1
                                985 silly preinstall mime-db@1.37.0
                                986 info lifecycle mime-db@1.37.0~preinstall: mime-db@1.37.0
                                987 silly preinstall mime-types@2.1.21
                                988 info lifecycle mime-types@2.1.21~preinstall: mime-types@2.1.21
                                989 silly preinstall form-data@2.3.3
                                990 info lifecycle form-data@2.3.3~preinstall: form-data@2.3.3
                                991 silly preinstall oauth-sign@0.9.0
                                992 info lifecycle oauth-sign@0.9.0~preinstall: oauth-sign@0.9.0
                                993 silly preinstall performance-now@2.1.0
                                994 info lifecycle performance-now@2.1.0~preinstall: performance-now@2.1.0
                                995 silly preinstall psl@1.1.29
                                996 info lifecycle psl@1.1.29~preinstall: psl@1.1.29
                                997 silly preinstall punycode@2.1.1
                                998 info lifecycle punycode@2.1.1~preinstall: punycode@2.1.1
                                999 silly preinstall q@1.5.1
                                1000 info lifecycle q@1.5.1~preinstall: q@1.5.1
                                1001 silly preinstall qs@6.5.2
                                1002 info lifecycle qs@6.5.2~preinstall: qs@6.5.2
                                1003 silly preinstall safe-buffer@5.1.2
                                1004 info lifecycle safe-buffer@5.1.2~preinstall: safe-buffer@5.1.2
                                1005 silly preinstall safer-buffer@2.1.2
                                1006 info lifecycle safer-buffer@2.1.2~preinstall: safer-buffer@2.1.2
                                1007 silly preinstall asn1@0.2.4
                                1008 info lifecycle asn1@0.2.4~preinstall: asn1@0.2.4
                                1009 silly preinstall ecc-jsbn@0.1.2
                                1010 info lifecycle ecc-jsbn@0.1.2~preinstall: ecc-jsbn@0.1.2
                                1011 silly preinstall punycode@1.4.1
                                1012 info lifecycle punycode@1.4.1~preinstall: punycode@1.4.1
                                1013 silly preinstall tough-cookie@2.4.3
                                1014 info lifecycle tough-cookie@2.4.3~preinstall: tough-cookie@2.4.3
                                1015 silly preinstall tunnel-agent@0.6.0
                                1016 info lifecycle tunnel-agent@0.6.0~preinstall: tunnel-agent@0.6.0
                                1017 silly preinstall tweetnacl@0.14.5
                                1018 info lifecycle tweetnacl@0.14.5~preinstall: tweetnacl@0.14.5
                                1019 silly preinstall bcrypt-pbkdf@1.0.2
                                1020 info lifecycle bcrypt-pbkdf@1.0.2~preinstall: bcrypt-pbkdf@1.0.2
                                1021 silly preinstall sshpk@1.15.2
                                1022 info lifecycle sshpk@1.15.2~preinstall: sshpk@1.15.2
                                1023 silly preinstall underscore@1.9.1
                                1024 info lifecycle underscore@1.9.1~preinstall: underscore@1.9.1
                                1025 silly preinstall uri-js@4.2.2
                                1026 info lifecycle uri-js@4.2.2~preinstall: uri-js@4.2.2
                                1027 silly preinstall ajv@6.5.5
                                1028 info lifecycle ajv@6.5.5~preinstall: ajv@6.5.5
                                1029 silly preinstall har-validator@5.1.3
                                1030 info lifecycle har-validator@5.1.3~preinstall: har-validator@5.1.3
                                1031 silly preinstall uuid@3.3.2
                                1032 info lifecycle uuid@3.3.2~preinstall: uuid@3.3.2
                                1033 silly preinstall verror@1.10.0
                                1034 info lifecycle verror@1.10.0~preinstall: verror@1.10.0
                                1035 silly preinstall jsprim@1.4.1
                                1036 info lifecycle jsprim@1.4.1~preinstall: jsprim@1.4.1
                                1037 silly preinstall http-signature@1.2.0
                                1038 info lifecycle http-signature@1.2.0~preinstall: http-signature@1.2.0
                                1039 silly preinstall nopy@0.2.6
                                1040 info lifecycle nopy@0.2.6~preinstall: nopy@0.2.6
                                1041 silly preinstall iobroker.xbox@0.1.4
                                1042 info lifecycle iobroker.xbox@0.1.4~preinstall: iobroker.xbox@0.1.4
                                1043 silly preinstall request@2.88.0
                                1044 info lifecycle request@2.88.0~preinstall: request@2.88.0
                                1045 silly preinstall ping@0.2.2
                                1046 info lifecycle ping@0.2.2~preinstall: ping@0.2.2
                                1047 verbose lifecycle iobroker.xbox@0.1.4~preinstall: unsafe-perm in lifecycle true
                                1048 verbose lifecycle iobroker.xbox@0.1.4~preinstall: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\ioBroker\node_modules\iobroker.xbox\node_modules\.bin;C:\ioBroker\node_modules\.bin;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\QuickTime\QTSystem\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\nodejs\;C:\WINDOWS\system32\config\systemprofile\AppData\Local\Microsoft\WindowsApps
                                1049 verbose lifecycle iobroker.xbox@0.1.4~preinstall: CWD: C:\ioBroker\node_modules\iobroker.xbox
                                1050 silly lifecycle iobroker.xbox@0.1.4~preinstall: Args: [ '/d /s /c',
                                1050 silly lifecycle   'apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e \'[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.\'' ]
                                1051 silly lifecycle iobroker.xbox@0.1.4~preinstall: Returned: code: 0  signal: null
                                1052 timing action:preinstall Completed in 41ms
                                1053 silly doSerial build 424
                                1054 silly build assert-plus@1.0.0
                                1055 info linkStuff assert-plus@1.0.0
                                1056 silly linkStuff assert-plus@1.0.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1057 silly linkStuff assert-plus@1.0.0 is part of a global install
                                1058 silly linkStuff assert-plus@1.0.0 is installed into a global node_modules
                                1059 silly build asynckit@0.4.0
                                1060 info linkStuff asynckit@0.4.0
                                1061 silly linkStuff asynckit@0.4.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1062 silly linkStuff asynckit@0.4.0 is part of a global install
                                1063 silly linkStuff asynckit@0.4.0 is installed into a global node_modules
                                1064 silly build aws-sign2@0.7.0
                                1065 info linkStuff aws-sign2@0.7.0
                                1066 silly linkStuff aws-sign2@0.7.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1067 silly linkStuff aws-sign2@0.7.0 is part of a global install
                                1068 silly linkStuff aws-sign2@0.7.0 is installed into a global node_modules
                                1069 silly build aws4@1.8.0
                                1070 info linkStuff aws4@1.8.0
                                1071 silly linkStuff aws4@1.8.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1072 silly linkStuff aws4@1.8.0 is part of a global install
                                1073 silly linkStuff aws4@1.8.0 is installed into a global node_modules
                                1074 silly build caseless@0.12.0
                                1075 info linkStuff caseless@0.12.0
                                1076 silly linkStuff caseless@0.12.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1077 silly linkStuff caseless@0.12.0 is part of a global install
                                1078 silly linkStuff caseless@0.12.0 is installed into a global node_modules
                                1079 silly build core-util-is@1.0.2
                                1080 info linkStuff core-util-is@1.0.2
                                1081 silly linkStuff core-util-is@1.0.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1082 silly linkStuff core-util-is@1.0.2 is part of a global install
                                1083 silly linkStuff core-util-is@1.0.2 is installed into a global node_modules
                                1084 silly build dashdash@1.14.1
                                1085 info linkStuff dashdash@1.14.1
                                1086 silly linkStuff dashdash@1.14.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1087 silly linkStuff dashdash@1.14.1 is part of a global install
                                1088 silly linkStuff dashdash@1.14.1 is installed into a global node_modules
                                1089 silly build delayed-stream@1.0.0
                                1090 info linkStuff delayed-stream@1.0.0
                                1091 silly linkStuff delayed-stream@1.0.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1092 silly linkStuff delayed-stream@1.0.0 is part of a global install
                                1093 silly linkStuff delayed-stream@1.0.0 is installed into a global node_modules
                                1094 silly build combined-stream@1.0.7
                                1095 info linkStuff combined-stream@1.0.7
                                1096 silly linkStuff combined-stream@1.0.7 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1097 silly linkStuff combined-stream@1.0.7 is part of a global install
                                1098 silly linkStuff combined-stream@1.0.7 is installed into a global node_modules
                                1099 silly build extend@3.0.2
                                1100 info linkStuff extend@3.0.2
                                1101 silly linkStuff extend@3.0.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1102 silly linkStuff extend@3.0.2 is part of a global install
                                1103 silly linkStuff extend@3.0.2 is installed into a global node_modules
                                1104 silly build extsprintf@1.3.0
                                1105 info linkStuff extsprintf@1.3.0
                                1106 silly linkStuff extsprintf@1.3.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1107 silly linkStuff extsprintf@1.3.0 is part of a global install
                                1108 silly linkStuff extsprintf@1.3.0 is installed into a global node_modules
                                1109 silly build fast-deep-equal@2.0.1
                                1110 info linkStuff fast-deep-equal@2.0.1
                                1111 silly linkStuff fast-deep-equal@2.0.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1112 silly linkStuff fast-deep-equal@2.0.1 is part of a global install
                                1113 silly linkStuff fast-deep-equal@2.0.1 is installed into a global node_modules
                                1114 silly build fast-json-stable-stringify@2.0.0
                                1115 info linkStuff fast-json-stable-stringify@2.0.0
                                1116 silly linkStuff fast-json-stable-stringify@2.0.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1117 silly linkStuff fast-json-stable-stringify@2.0.0 is part of a global install
                                1118 silly linkStuff fast-json-stable-stringify@2.0.0 is installed into a global node_modules
                                1119 silly build forever-agent@0.6.1
                                1120 info linkStuff forever-agent@0.6.1
                                1121 silly linkStuff forever-agent@0.6.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1122 silly linkStuff forever-agent@0.6.1 is part of a global install
                                1123 silly linkStuff forever-agent@0.6.1 is installed into a global node_modules
                                1124 silly build getpass@0.1.7
                                1125 info linkStuff getpass@0.1.7
                                1126 silly linkStuff getpass@0.1.7 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1127 silly linkStuff getpass@0.1.7 is part of a global install
                                1128 silly linkStuff getpass@0.1.7 is installed into a global node_modules
                                1129 silly build har-schema@2.0.0
                                1130 info linkStuff har-schema@2.0.0
                                1131 silly linkStuff har-schema@2.0.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1132 silly linkStuff har-schema@2.0.0 is part of a global install
                                1133 silly linkStuff har-schema@2.0.0 is installed into a global node_modules
                                1134 silly build is-typedarray@1.0.0
                                1135 info linkStuff is-typedarray@1.0.0
                                1136 silly linkStuff is-typedarray@1.0.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1137 silly linkStuff is-typedarray@1.0.0 is part of a global install
                                1138 silly linkStuff is-typedarray@1.0.0 is installed into a global node_modules
                                1139 silly build isstream@0.1.2
                                1140 info linkStuff isstream@0.1.2
                                1141 silly linkStuff isstream@0.1.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1142 silly linkStuff isstream@0.1.2 is part of a global install
                                1143 silly linkStuff isstream@0.1.2 is installed into a global node_modules
                                1144 silly build jsbn@0.1.1
                                1145 info linkStuff jsbn@0.1.1
                                1146 silly linkStuff jsbn@0.1.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1147 silly linkStuff jsbn@0.1.1 is part of a global install
                                1148 silly linkStuff jsbn@0.1.1 is installed into a global node_modules
                                1149 silly build json-schema@0.2.3
                                1150 info linkStuff json-schema@0.2.3
                                1151 silly linkStuff json-schema@0.2.3 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1152 silly linkStuff json-schema@0.2.3 is part of a global install
                                1153 silly linkStuff json-schema@0.2.3 is installed into a global node_modules
                                1154 silly build json-schema-traverse@0.4.1
                                1155 info linkStuff json-schema-traverse@0.4.1
                                1156 silly linkStuff json-schema-traverse@0.4.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1157 silly linkStuff json-schema-traverse@0.4.1 is part of a global install
                                1158 silly linkStuff json-schema-traverse@0.4.1 is installed into a global node_modules
                                1159 silly build json-stringify-safe@5.0.1
                                1160 info linkStuff json-stringify-safe@5.0.1
                                1161 silly linkStuff json-stringify-safe@5.0.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1162 silly linkStuff json-stringify-safe@5.0.1 is part of a global install
                                1163 silly linkStuff json-stringify-safe@5.0.1 is installed into a global node_modules
                                1164 silly build mime-db@1.37.0
                                1165 info linkStuff mime-db@1.37.0
                                1166 silly linkStuff mime-db@1.37.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1167 silly linkStuff mime-db@1.37.0 is part of a global install
                                1168 silly linkStuff mime-db@1.37.0 is installed into a global node_modules
                                1169 silly build mime-types@2.1.21
                                1170 info linkStuff mime-types@2.1.21
                                1171 silly linkStuff mime-types@2.1.21 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1172 silly linkStuff mime-types@2.1.21 is part of a global install
                                1173 silly linkStuff mime-types@2.1.21 is installed into a global node_modules
                                1174 silly build form-data@2.3.3
                                1175 info linkStuff form-data@2.3.3
                                1176 silly linkStuff form-data@2.3.3 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1177 silly linkStuff form-data@2.3.3 is part of a global install
                                1178 silly linkStuff form-data@2.3.3 is installed into a global node_modules
                                1179 silly build oauth-sign@0.9.0
                                1180 info linkStuff oauth-sign@0.9.0
                                1181 silly linkStuff oauth-sign@0.9.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1182 silly linkStuff oauth-sign@0.9.0 is part of a global install
                                1183 silly linkStuff oauth-sign@0.9.0 is installed into a global node_modules
                                1184 silly build performance-now@2.1.0
                                1185 info linkStuff performance-now@2.1.0
                                1186 silly linkStuff performance-now@2.1.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1187 silly linkStuff performance-now@2.1.0 is part of a global install
                                1188 silly linkStuff performance-now@2.1.0 is installed into a global node_modules
                                1189 silly build psl@1.1.29
                                1190 info linkStuff psl@1.1.29
                                1191 silly linkStuff psl@1.1.29 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1192 silly linkStuff psl@1.1.29 is part of a global install
                                1193 silly linkStuff psl@1.1.29 is installed into a global node_modules
                                1194 silly build punycode@2.1.1
                                1195 info linkStuff punycode@2.1.1
                                1196 silly linkStuff punycode@2.1.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1197 silly linkStuff punycode@2.1.1 is part of a global install
                                1198 silly linkStuff punycode@2.1.1 is installed into a global node_modules
                                1199 silly build q@1.5.1
                                1200 info linkStuff q@1.5.1
                                1201 silly linkStuff q@1.5.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1202 silly linkStuff q@1.5.1 is part of a global install
                                1203 silly linkStuff q@1.5.1 is installed into a global node_modules
                                1204 silly build qs@6.5.2
                                1205 info linkStuff qs@6.5.2
                                1206 silly linkStuff qs@6.5.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1207 silly linkStuff qs@6.5.2 is part of a global install
                                1208 silly linkStuff qs@6.5.2 is installed into a global node_modules
                                1209 silly build safe-buffer@5.1.2
                                1210 info linkStuff safe-buffer@5.1.2
                                1211 silly linkStuff safe-buffer@5.1.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1212 silly linkStuff safe-buffer@5.1.2 is part of a global install
                                1213 silly linkStuff safe-buffer@5.1.2 is installed into a global node_modules
                                1214 silly build safer-buffer@2.1.2
                                1215 info linkStuff safer-buffer@2.1.2
                                1216 silly linkStuff safer-buffer@2.1.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1217 silly linkStuff safer-buffer@2.1.2 is part of a global install
                                1218 silly linkStuff safer-buffer@2.1.2 is installed into a global node_modules
                                1219 silly build asn1@0.2.4
                                1220 info linkStuff asn1@0.2.4
                                1221 silly linkStuff asn1@0.2.4 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1222 silly linkStuff asn1@0.2.4 is part of a global install
                                1223 silly linkStuff asn1@0.2.4 is installed into a global node_modules
                                1224 silly build ecc-jsbn@0.1.2
                                1225 info linkStuff ecc-jsbn@0.1.2
                                1226 silly linkStuff ecc-jsbn@0.1.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1227 silly linkStuff ecc-jsbn@0.1.2 is part of a global install
                                1228 silly linkStuff ecc-jsbn@0.1.2 is installed into a global node_modules
                                1229 silly build punycode@1.4.1
                                1230 info linkStuff punycode@1.4.1
                                1231 silly linkStuff punycode@1.4.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules\tough-cookie\node_modules as its parent node_modules
                                1232 silly linkStuff punycode@1.4.1 is part of a global install
                                1233 silly linkStuff punycode@1.4.1 is installed into a global node_modules
                                1234 silly build tough-cookie@2.4.3
                                1235 info linkStuff tough-cookie@2.4.3
                                1236 silly linkStuff tough-cookie@2.4.3 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1237 silly linkStuff tough-cookie@2.4.3 is part of a global install
                                1238 silly linkStuff tough-cookie@2.4.3 is installed into a global node_modules
                                1239 silly build tunnel-agent@0.6.0
                                1240 info linkStuff tunnel-agent@0.6.0
                                1241 silly linkStuff tunnel-agent@0.6.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1242 silly linkStuff tunnel-agent@0.6.0 is part of a global install
                                1243 silly linkStuff tunnel-agent@0.6.0 is installed into a global node_modules
                                1244 silly build tweetnacl@0.14.5
                                1245 info linkStuff tweetnacl@0.14.5
                                1246 silly linkStuff tweetnacl@0.14.5 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1247 silly linkStuff tweetnacl@0.14.5 is part of a global install
                                1248 silly linkStuff tweetnacl@0.14.5 is installed into a global node_modules
                                1249 silly build bcrypt-pbkdf@1.0.2
                                1250 info linkStuff bcrypt-pbkdf@1.0.2
                                1251 silly linkStuff bcrypt-pbkdf@1.0.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1252 silly linkStuff bcrypt-pbkdf@1.0.2 is part of a global install
                                1253 silly linkStuff bcrypt-pbkdf@1.0.2 is installed into a global node_modules
                                1254 silly build sshpk@1.15.2
                                1255 info linkStuff sshpk@1.15.2
                                1256 silly linkStuff sshpk@1.15.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1257 silly linkStuff sshpk@1.15.2 is part of a global install
                                1258 silly linkStuff sshpk@1.15.2 is installed into a global node_modules
                                1259 verbose linkBins [ { 'sshpk-conv': 'bin/sshpk-conv',
                                1259 verbose linkBins     'sshpk-sign': 'bin/sshpk-sign',
                                1259 verbose linkBins     'sshpk-verify': 'bin/sshpk-verify' },
                                1259 verbose linkBins   'C:\\ioBroker\\node_modules\\iobroker.xbox\\node_modules\\.bin',
                                1259 verbose linkBins   false ]
                                1260 silly build underscore@1.9.1
                                1261 info linkStuff underscore@1.9.1
                                1262 silly linkStuff underscore@1.9.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1263 silly linkStuff underscore@1.9.1 is part of a global install
                                1264 silly linkStuff underscore@1.9.1 is installed into a global node_modules
                                1265 silly build uri-js@4.2.2
                                1266 info linkStuff uri-js@4.2.2
                                1267 silly linkStuff uri-js@4.2.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1268 silly linkStuff uri-js@4.2.2 is part of a global install
                                1269 silly linkStuff uri-js@4.2.2 is installed into a global node_modules
                                1270 silly build ajv@6.5.5
                                1271 info linkStuff ajv@6.5.5
                                1272 silly linkStuff ajv@6.5.5 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1273 silly linkStuff ajv@6.5.5 is part of a global install
                                1274 silly linkStuff ajv@6.5.5 is installed into a global node_modules
                                1275 silly build har-validator@5.1.3
                                1276 info linkStuff har-validator@5.1.3
                                1277 silly linkStuff har-validator@5.1.3 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1278 silly linkStuff har-validator@5.1.3 is part of a global install
                                1279 silly linkStuff har-validator@5.1.3 is installed into a global node_modules
                                1280 silly build uuid@3.3.2
                                1281 info linkStuff uuid@3.3.2
                                1282 silly linkStuff uuid@3.3.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1283 silly linkStuff uuid@3.3.2 is part of a global install
                                1284 silly linkStuff uuid@3.3.2 is installed into a global node_modules
                                1285 verbose linkBins [ { uuid: './bin/uuid' },
                                1285 verbose linkBins   'C:\\ioBroker\\node_modules\\iobroker.xbox\\node_modules\\.bin',
                                1285 verbose linkBins   false ]
                                1286 silly build verror@1.10.0
                                1287 info linkStuff verror@1.10.0
                                1288 silly linkStuff verror@1.10.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1289 silly linkStuff verror@1.10.0 is part of a global install
                                1290 silly linkStuff verror@1.10.0 is installed into a global node_modules
                                1291 silly build jsprim@1.4.1
                                1292 info linkStuff jsprim@1.4.1
                                1293 silly linkStuff jsprim@1.4.1 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1294 silly linkStuff jsprim@1.4.1 is part of a global install
                                1295 silly linkStuff jsprim@1.4.1 is installed into a global node_modules
                                1296 silly build http-signature@1.2.0
                                1297 info linkStuff http-signature@1.2.0
                                1298 silly linkStuff http-signature@1.2.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1299 silly linkStuff http-signature@1.2.0 is part of a global install
                                1300 silly linkStuff http-signature@1.2.0 is installed into a global node_modules
                                1301 silly build nopy@0.2.6
                                1302 info linkStuff nopy@0.2.6
                                1303 silly linkStuff nopy@0.2.6 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1304 silly linkStuff nopy@0.2.6 is part of a global install
                                1305 silly linkStuff nopy@0.2.6 is installed into a global node_modules
                                1306 verbose linkBins [ { nopenv: './src/nopenv.js',
                                1306 verbose linkBins     nopy: './src/nopy.js',
                                1306 verbose linkBins     npip: './src/npip.js' },
                                1306 verbose linkBins   'C:\\ioBroker\\node_modules\\iobroker.xbox\\node_modules\\.bin',
                                1306 verbose linkBins   false ]
                                1307 silly build ping@0.2.2
                                1308 info linkStuff ping@0.2.2
                                1309 silly linkStuff ping@0.2.2 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1310 silly linkStuff ping@0.2.2 is part of a global install
                                1311 silly linkStuff ping@0.2.2 is installed into a global node_modules
                                1312 silly build request@2.88.0
                                1313 info linkStuff request@2.88.0
                                1314 silly linkStuff request@2.88.0 has C:\ioBroker\node_modules\iobroker.xbox\node_modules as its parent node_modules
                                1315 silly linkStuff request@2.88.0 is part of a global install
                                1316 silly linkStuff request@2.88.0 is installed into a global node_modules
                                1317 silly build iobroker.xbox@0.1.4
                                1318 info linkStuff iobroker.xbox@0.1.4
                                1319 silly linkStuff iobroker.xbox@0.1.4 has C:\ioBroker\node_modules as its parent node_modules
                                1320 silly linkStuff iobroker.xbox@0.1.4 is part of a global install
                                1321 silly linkStuff iobroker.xbox@0.1.4 is installed into a global node_modules
                                1322 silly linkStuff iobroker.xbox@0.1.4 is installed into the top-level global node_modules
                                1323 timing action:build Completed in 81ms
                                1324 silly doSerial global-link 424
                                1325 silly doParallel update-linked 0
                                1326 silly doSerial install 424
                                1327 silly install assert-plus@1.0.0
                                1328 info lifecycle assert-plus@1.0.0~install: assert-plus@1.0.0
                                1329 silly install asynckit@0.4.0
                                1330 info lifecycle asynckit@0.4.0~install: asynckit@0.4.0
                                1331 silly install aws-sign2@0.7.0
                                1332 info lifecycle aws-sign2@0.7.0~install: aws-sign2@0.7.0
                                1333 silly install aws4@1.8.0
                                1334 info lifecycle aws4@1.8.0~install: aws4@1.8.0
                                1335 silly install caseless@0.12.0
                                1336 info lifecycle caseless@0.12.0~install: caseless@0.12.0
                                1337 silly install core-util-is@1.0.2
                                1338 info lifecycle core-util-is@1.0.2~install: core-util-is@1.0.2
                                1339 silly install dashdash@1.14.1
                                1340 info lifecycle dashdash@1.14.1~install: dashdash@1.14.1
                                1341 silly install delayed-stream@1.0.0
                                1342 info lifecycle delayed-stream@1.0.0~install: delayed-stream@1.0.0
                                1343 silly install combined-stream@1.0.7
                                1344 info lifecycle combined-stream@1.0.7~install: combined-stream@1.0.7
                                1345 silly install extend@3.0.2
                                1346 info lifecycle extend@3.0.2~install: extend@3.0.2
                                1347 silly install extsprintf@1.3.0
                                1348 info lifecycle extsprintf@1.3.0~install: extsprintf@1.3.0
                                1349 silly install fast-deep-equal@2.0.1
                                1350 info lifecycle fast-deep-equal@2.0.1~install: fast-deep-equal@2.0.1
                                1351 silly install fast-json-stable-stringify@2.0.0
                                1352 info lifecycle fast-json-stable-stringify@2.0.0~install: fast-json-stable-stringify@2.0.0
                                1353 silly install forever-agent@0.6.1
                                1354 info lifecycle forever-agent@0.6.1~install: forever-agent@0.6.1
                                1355 silly install getpass@0.1.7
                                1356 info lifecycle getpass@0.1.7~install: getpass@0.1.7
                                1357 silly install har-schema@2.0.0
                                1358 info lifecycle har-schema@2.0.0~install: har-schema@2.0.0
                                1359 silly install is-typedarray@1.0.0
                                1360 info lifecycle is-typedarray@1.0.0~install: is-typedarray@1.0.0
                                1361 silly install isstream@0.1.2
                                1362 info lifecycle isstream@0.1.2~install: isstream@0.1.2
                                1363 silly install jsbn@0.1.1
                                1364 info lifecycle jsbn@0.1.1~install: jsbn@0.1.1
                                1365 silly install json-schema@0.2.3
                                1366 info lifecycle json-schema@0.2.3~install: json-schema@0.2.3
                                1367 silly install json-schema-traverse@0.4.1
                                1368 info lifecycle json-schema-traverse@0.4.1~install: json-schema-traverse@0.4.1
                                1369 silly install json-stringify-safe@5.0.1
                                1370 info lifecycle json-stringify-safe@5.0.1~install: json-stringify-safe@5.0.1
                                1371 silly install mime-db@1.37.0
                                1372 info lifecycle mime-db@1.37.0~install: mime-db@1.37.0
                                1373 silly install mime-types@2.1.21
                                1374 info lifecycle mime-types@2.1.21~install: mime-types@2.1.21
                                1375 silly install form-data@2.3.3
                                1376 info lifecycle form-data@2.3.3~install: form-data@2.3.3
                                1377 silly install oauth-sign@0.9.0
                                1378 info lifecycle oauth-sign@0.9.0~install: oauth-sign@0.9.0
                                1379 silly install performance-now@2.1.0
                                1380 info lifecycle performance-now@2.1.0~install: performance-now@2.1.0
                                1381 silly install psl@1.1.29
                                1382 info lifecycle psl@1.1.29~install: psl@1.1.29
                                1383 silly install punycode@2.1.1
                                1384 info lifecycle punycode@2.1.1~install: punycode@2.1.1
                                1385 silly install q@1.5.1
                                1386 info lifecycle q@1.5.1~install: q@1.5.1
                                1387 silly install qs@6.5.2
                                1388 info lifecycle qs@6.5.2~install: qs@6.5.2
                                1389 silly install safe-buffer@5.1.2
                                1390 info lifecycle safe-buffer@5.1.2~install: safe-buffer@5.1.2
                                1391 silly install safer-buffer@2.1.2
                                1392 info lifecycle safer-buffer@2.1.2~install: safer-buffer@2.1.2
                                1393 silly install asn1@0.2.4
                                1394 info lifecycle asn1@0.2.4~install: asn1@0.2.4
                                1395 silly install ecc-jsbn@0.1.2
                                1396 info lifecycle ecc-jsbn@0.1.2~install: ecc-jsbn@0.1.2
                                1397 silly install punycode@1.4.1
                                1398 info lifecycle punycode@1.4.1~install: punycode@1.4.1
                                1399 silly install tough-cookie@2.4.3
                                1400 info lifecycle tough-cookie@2.4.3~install: tough-cookie@2.4.3
                                1401 silly install tunnel-agent@0.6.0
                                1402 info lifecycle tunnel-agent@0.6.0~install: tunnel-agent@0.6.0
                                1403 silly install tweetnacl@0.14.5
                                1404 info lifecycle tweetnacl@0.14.5~install: tweetnacl@0.14.5
                                1405 silly install bcrypt-pbkdf@1.0.2
                                1406 info lifecycle bcrypt-pbkdf@1.0.2~install: bcrypt-pbkdf@1.0.2
                                1407 silly install sshpk@1.15.2
                                1408 info lifecycle sshpk@1.15.2~install: sshpk@1.15.2
                                1409 silly install underscore@1.9.1
                                1410 info lifecycle underscore@1.9.1~install: underscore@1.9.1
                                1411 silly install uri-js@4.2.2
                                1412 info lifecycle uri-js@4.2.2~install: uri-js@4.2.2
                                1413 silly install ajv@6.5.5
                                1414 info lifecycle ajv@6.5.5~install: ajv@6.5.5
                                1415 silly install har-validator@5.1.3
                                1416 info lifecycle har-validator@5.1.3~install: har-validator@5.1.3
                                1417 silly install uuid@3.3.2
                                1418 info lifecycle uuid@3.3.2~install: uuid@3.3.2
                                1419 silly install verror@1.10.0
                                1420 info lifecycle verror@1.10.0~install: verror@1.10.0
                                1421 silly install jsprim@1.4.1
                                1422 info lifecycle jsprim@1.4.1~install: jsprim@1.4.1
                                1423 silly install http-signature@1.2.0
                                1424 info lifecycle http-signature@1.2.0~install: http-signature@1.2.0
                                1425 silly install nopy@0.2.6
                                1426 info lifecycle nopy@0.2.6~install: nopy@0.2.6
                                1427 silly install ping@0.2.2
                                1428 info lifecycle ping@0.2.2~install: ping@0.2.2
                                1429 silly install request@2.88.0
                                1430 info lifecycle request@2.88.0~install: request@2.88.0
                                1431 silly install iobroker.xbox@0.1.4
                                1432 info lifecycle iobroker.xbox@0.1.4~install: iobroker.xbox@0.1.4
                                1433 verbose lifecycle iobroker.xbox@0.1.4~install: unsafe-perm in lifecycle true
                                1434 verbose lifecycle iobroker.xbox@0.1.4~install: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\ioBroker\node_modules\iobroker.xbox\node_modules\.bin;C:\ioBroker\node_modules\.bin;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\QuickTime\QTSystem\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\nodejs\;C:\WINDOWS\system32\config\systemprofile\AppData\Local\Microsoft\WindowsApps
                                1435 verbose lifecycle iobroker.xbox@0.1.4~install: CWD: C:\ioBroker\node_modules\iobroker.xbox
                                1436 silly lifecycle iobroker.xbox@0.1.4~install: Args: [ '/d /s /c', 'npip install' ]
                                1437 silly lifecycle iobroker.xbox@0.1.4~install: Returned: code: 1  signal: null
                                1438 info lifecycle iobroker.xbox@0.1.4~install: Failed to exec install script
                                1439 timing action:install Completed in 644ms
                                1440 verbose unlock done using C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_locks\staging-dc72d96e288e3e7c.lock for C:\ioBroker\node_modules\.staging
                                1441 timing stage:rollbackFailedOptional Completed in 263ms
                                1442 timing stage:runTopLevelLifecycles Completed in 6956ms
                                1443 verbose stack Error: iobroker.xbox@0.1.4 install: `npip install`
                                1443 verbose stack Exit status 1
                                1443 verbose stack     at EventEmitter. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:301:16)
                                1443 verbose stack     at emitTwo (events.js:126:13)
                                1443 verbose stack     at EventEmitter.emit (events.js:214:7)
                                1443 verbose stack     at ChildProcess. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
                                1443 verbose stack     at ChildProcess.emit (events.js:214:7)
                                1443 verbose stack     at maybeClose (internal/child_process.js:915:16)
                                1443 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                                1444 verbose pkgid iobroker.xbox@0.1.4
                                1445 verbose cwd C:\ioBroker\node_modules\iobroker
                                1446 verbose Windows_NT 10.0.17134
                                1447 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "https://github.com/foxriver76/ioBroker.xbox/tarball/master" "--production" "--save" "--prefix" "C:/ioBroker"
                                1448 verbose node v8.12.0
                                1449 verbose npm  v6.4.1
                                1450 error code ELIFECYCLE
                                1451 error errno 1
                                1452 error iobroker.xbox@0.1.4 install: `npip install`
                                1452 error Exit status 1
                                1453 error Failed at the iobroker.xbox@0.1.4 install script.
                                1453 error This is probably not a problem with npm. There is likely additional logging output above.
                                1454 verbose exit [ 1, true ]</anonymous></anonymous>
                                • Negalein
                                  @Jey Cee:
                                  @Negalein:
                                  Ich hab kein Linux. Hab Win10. Auch windows hat eine Kommandozeile. Gib mal in deiner Win10 Suche "cmd" ein.
                                  Hab es jetzt in CMD direkt im IOB-Ordner versucht!
                                  Funktioniert auch nicht
                                  Microsoft Windows [Version 10.0.17134.345]
                                  (c) 2018 Microsoft Corporation. Alle Rechte vorbehalten.
                                  C:\WINDOWS\system32>cd..
                                  C:\Windows>cd..
                                  C:\>cd iobroker
                                  C:\ioBroker>python
                                  Der Befehl "python" ist entweder falsch geschrieben oder
                                  konnte nicht gefunden werden.
                                  C:\ioBroker>python3
                                  Der Befehl "python3" ist entweder falsch geschrieben oder
                                  C:\ioBroker>npm i iobroker.xbox -production -unsafe-perm
                                  > iobroker.xbox@0.1.4 preinstall C:\ioBroker\node_modules\iobroker.xbox
                                  > apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.'
                                  Der Befehl "apt" ist entweder falsch geschrieben oder
                                  > unix-dgram@0.2.3 install C:\ioBroker\node_modules\unix-dgram
                                  > node-gyp rebuild
                                  C:\ioBroker\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                                  gyp ERR! configure error
                                  gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
                                  gyp ERR! stack     at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
                                  gyp ERR! stack     at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
                                  gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
                                  gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:152:21)
                                  gyp ERR! System Windows_NT 10.0.17134
                                  gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
                                  gyp ERR! cwd C:\ioBroker\node_modules\unix-dgram
                                  gyp ERR! node -v v8.12.0
                                  gyp ERR! node-gyp -v v3.8.0
                                  gyp ERR! not ok
                                  > usb@1.5.0 install C:\ioBroker\node_modules\usb
                                  > node-pre-gyp install --fallback-to-build
                                  node-pre-gyp WARN Using request for node-pre-gyp https download
                                  [usb] Success: "C:\ioBroker\node_modules\usb\src\binding\usb_bindings.node" is installed via remote
                                  > bluetooth-hci-socket@0.5.1 install C:\ioBroker\node_modules\bluetooth-hci-socket
                                  > node-gyp rebuild
                                  C:\ioBroker\node_modules\bluetooth-hci-socket>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                                  gyp ERR! cwd C:\ioBroker\node_modules\bluetooth-hci-socket
                                  gyp ERR! not ok
                                  > iobroker.xbox@0.1.4 install C:\ioBroker\node_modules\iobroker.xbox
                                  > npip install
                                  No python_modules directory; installing pip locally if needed.
                                  Error: No python executable.
                                      at getPythonInfo (C:\ioBroker\node_modules\nopy\src\api.js:52:11)
                                      at Promise.then.catch.error (C:\ioBroker\node_modules\nopy\src\api.js:115:14)
                                      at <anonymous>
                                      at process._tickCallback (internal/process/next_tick.js:189:7)
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules\xpc-connection):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules\unix-dgram):
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules\bluetooth-hci-socket):
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno 1
                                  npm ERR! iobroker.xbox@0.1.4 install: `npip install`
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the iobroker.xbox@0.1.4 install script.
                                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                  npm ERR!     C:\Users\chris\AppData\Roaming\npm-cache\_logs\2018-11-11T15_03_54_294Z-debug.log
                                  C:\ioBroker></anonymous></anonymous></anonymous>
                                  • foxriver76
                                    Dann ist Python nicht korrekt installiert oder nicht im Pfad. Bist du nach einer Anleitung vorgegangen? Das ist denke ich die einfachste Variante: https://wsvincent.com/install-python3-windows/
                                    • Negalein
                                      @foxriver76:
                                      Dann ist Python nicht korrekt installiert oder nicht im Pfad. Bist du nach einer Anleitung vorgegangen? Das ist denke ich die einfachste Variante: https://wsvincent.com/install-python3-windows/ `
                                      Ich habs von https://www.python.org/downloads/ runtergeladen und ganz normal installiert.
                                      Werde mir deinen Link anschaun.
                                      • Negalein
                                        @foxriver76:
                                        Danke, Python läuft und ich komme mit Python auf in die Konsole!
                                        Aber die Installation vom Xbox-Adapter bringt noch immer Fehler!
                                        C:\Windows>cd..
                                        C:\>cd iobroker
                                        > node-gyp rebuild
                                        gyp ERR! stack Error: Command failed: C:\Users\chris\AppData\Local\Programs\Python\Python37-32\python.EXE -c import sys; print "%s.%s.%s" % sys.version_info[:3];
                                        gyp ERR! stack   File "<string>", line 1
                                        gyp ERR! stack     import sys; print "%s.%s.%s" % sys.version_info[:3];
                                        gyp ERR! stack                                ^
                                        gyp ERR! stack SyntaxError: invalid syntax
                                        gyp ERR! stack
                                        gyp ERR! stack     at ChildProcess.exithandler (child_process.js:276:12)
                                        gyp ERR! stack     at emitTwo (events.js:126:13)
                                        gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                                        gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
                                        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                                        gyp ERR! not ok
                                        > node-gyp rebuild
                                        gyp ERR! stack                                ^
                                        gyp ERR! stack
                                        gyp ERR! not ok
                                        > npip install
                                        Successfully completed pip check.
                                        Collecting xbox-smartglass-rest>=0.9.7
                                          Downloading https://files.pythonhosted.org/packages/05/69/9bc572f4e0b015cf461110212f23301e820c1da4d83e292d81f1b2f23764/xbox_smartglass_rest-0.9.7-py2.py3-none-any.whl
                                        Collecting xbox-smartglass-stump>=0.9.4 (from xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/7e/ea/fae9ae03e3ef0afc3c27638e8872254bf96bd14f06dc1ba5bce08b7916c7/xbox_smartglass_stump-0.9.4-py2.py3-none-any.whl
                                        Collecting Flask (from xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/7f/e7/08578774ed4536d3242b14dacb4696386634607af824ea997202cd0edb4b/Flask-1.0.2-py2.py3-none-any.whl (91kB)
                                            100% |████████████████████████████████| 92kB 1.1MB/s
                                        Collecting xbox-smartglass-core>=1.0.11 (from xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/e2/f2/66046ed3c475722561b20f1787cf5c5d8d2e5ef81d89e9d3279db82f0df6/xbox_smartglass_core-1.0.11-py2.py3-none-any.whl (57kB)
                                            100% |████████████████████████████████| 61kB 2.0MB/s
                                        Collecting marshmallow-objects (from xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/9e/ae/c044161526096617ed2523749ae3187449910b83dae12610f30a42672fae/marshmallow_objects-1.0.17-py2.py3-none-any.whl
                                        Collecting Jinja2>=2.10 (from Flask->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/7f/ff/ae64bacdfc95f27a016a7bed8e8686763ba4d277a78ca76f32659220a731/Jinja2-2.10-py2.py3-none-any.whl (126kB)
                                            100% |████████████████████████████████| 133kB 1.5MB/s
                                        Collecting click>=5.1 (from Flask->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl (81kB)
                                            100% |████████████████████████████████| 81kB 1.4MB/s
                                        Collecting itsdangerous>=0.24 (from Flask->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
                                        Collecting Werkzeug>=0.14 (from Flask->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/20/c4/12e3e56473e52375aa29c4764e70d1b8f3efa6682bef8d0aae04fe335243/Werkzeug-0.14.1-py2.py3-none-any.whl (322kB)
                                            100% |████████████████████████████████| 327kB 1.9MB/s
                                        Collecting construct==2.9.41 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/e6/f5/064be5013506d54212b396e8fc3e9890e60ed6a27df6d52529f0b8361cd5/construct-2.9.41.tar.gz (54kB)
                                        Collecting dpkt==1.9.1 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/bf/a4/8e4622fac4841b5e4a347fa9da4c057a7974258df247031280008d6ac0d0/dpkt-1.9.1.tar.gz (115kB)
                                            100% |████████████████████████████████| 122kB 3.3MB/s
                                        Collecting gevent==1.2.2 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/1b/92/b111f76e54d2be11375b47b213b56687214f258fd9dae703546d30b837be/gevent-1.2.2.tar.gz (3.1MB)
                                            100% |████████████████████████████████| 3.1MB 2.6MB/s
                                        Collecting cryptography==2.3.1 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/da/f6/6b9f031611697cb61d25c884237a8762725df7373a0accd49b39fbbb23cd/cryptography-2.3.1-cp37-cp37m-win32.whl (1.1MB)
                                            100% |████████████████████████████████| 1.1MB 2.0MB/s
                                        Collecting urwid==2.0.1 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/c7/90/415728875c230fafd13d118512bde3184d810d7bf798a631abc05fac09d0/urwid-2.0.1.tar.gz (604kB)
                                            100% |████████████████████████████████| 614kB 2.3MB/s
                                        Collecting appdirs==1.4.3 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
                                        Collecting xbox-webapi>=1.1.2 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl (45kB)
                                            100% |████████████████████████████████| 51kB 1.2MB/s
                                        Collecting marshmallow (from marshmallow-objects->xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/6e/12/2a4239760bc78564434d1daecd9a504e7b6efb4f5722d5388b74407bb3b3/marshmallow-2.16.3-py2.py3-none-any.whl (49kB)
                                            100% |████████████████████████████████| 51kB 1.4MB/s
                                        Collecting MarkupSafe>=0.23 (from Jinja2>=2.10->Flask->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/e9/e9/4e6394de81f28fcd331298110714980ad4978d9d0d6649c54bd88bf1cd43/MarkupSafe-1.1.0-cp37-cp37m-win32.whl
                                        Collecting greenlet>=0.4.10 (from gevent==1.2.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/dc/b5/e5cef57068eb9916d3f3d3117ce4349409742f25323b4671531183c5a1c5/greenlet-0.4.15-cp37-cp37m-win32.whl
                                        Collecting six>=1.4.1 (from cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/67/4b/141a581104b1f6397bfa78ac9d43d8ad29a7ca43ea90a2d863fe3056e86a/six-1.11.0-py2.py3-none-any.whl
                                        Collecting idna>=2.1 (from cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/4b/2a/0276479a4b3caeb8a8c1af2f8e4355746a97fab05a372e4a2c6a6b876165/idna-2.7-py2.py3-none-any.whl (58kB)
                                            100% |████████████████████████████████| 61kB 3.2MB/s
                                        Collecting asn1crypto>=0.21.0 (from cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/ea/cd/35485615f45f30a510576f1a56d1e0a7ad7bd8ab5ed7cdc600ef7cd06222/asn1crypto-0.24.0-py2.py3-none-any.whl (101kB)
                                            100% |████████████████████████████████| 102kB 3.8MB/s
                                        Collecting cffi!=1.11.3,>=1.7 (from cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/2d/9e/9d84a78d4ea3d0fa94f6d0e4bcd88406709312949f48f3853f26f8f52ebe/cffi-1.11.5-cp37-cp37m-win32.whl (154kB)
                                            100% |████████████████████████████████| 163kB 2.3MB/s
                                        Collecting requests (from xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/ff/17/5cbb026005115301a8fb2f9b0e3e8d32313142fe8b617070e7baad20554f/requests-2.20.1-py2.py3-none-any.whl (57kB)
                                        Collecting demjson (from xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/96/67/6db789e2533158963d4af689f961b644ddd9200615b8ce92d6cad695c65a/demjson-2.2.4.tar.gz (131kB)
                                            100% |████████████████████████████████| 133kB 1.3MB/s
                                        Collecting pycparser (from cffi!=1.11.3,>=1.7->cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/68/9e/49196946aee219aead1290e00d1e7fdeab8567783e83e1b9ab5585e6206a/pycparser-2.19.tar.gz (158kB)
                                            100% |████████████████████████████████| 163kB 685kB/s
                                        Collecting urllib3<1.25,>=1.21.1 (from requests->xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/62/00/ee1d7de624db8ba7090d1226aebefab96a2c71cd5cfa7629d6ad3f61b79e/urllib3-1.24.1-py2.py3-none-any.whl (118kB)
                                            100% |████████████████████████████████| 122kB 1.9MB/s
                                        Collecting certifi>=2017.4.17 (from requests->xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/56/9d/1d02dd80bc4cd955f98980f28c5ee2200e1209292d5f9e9cc8d030d18655/certifi-2018.10.15-py2.py3-none-any.whl (146kB)
                                            100% |████████████████████████████████| 153kB 2.0MB/s
                                        Collecting chardet<3.1.0,>=3.0.2 (from requests->xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
                                          Downloading https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl (133kB)
                                            100% |████████████████████████████████| 143kB 3.4MB/s
                                        Building wheels for collected packages: construct, dpkt, gevent, urwid, demjson, pycparser
                                          Running setup.py bdist_wheel for construct ... done
                                          Stored in directory: C:\Users\chris\AppData\Local\pip\Cache\wheels\13\cd\02\acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61
                                          Running setup.py bdist_wheel for dpkt ... done
                                          Stored in directory: C:\Users\chris\AppData\Local\pip\Cache\wheels\0a\5f\3c\e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f
                                          Running setup.py bdist_wheel for gevent ... error
                                          Complete output from command C:\Users\chris\AppData\Local\Programs\Python\Python37-32\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\chris\\AppData\\Local\\Temp\\pip-install-ohq6rdrn\\gevent\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d C:\Users\chris\AppData\Local\Temp\pip-wheel-1umbtm1o --python-tag cp37:
                                          C:\Users\chris\AppData\Local\Programs\Python\Python37-32\lib\distutils\dist.py:274: UserWarning: Unknown distribution option: 'cffi_modules'
                                            warnings.warn(msg)
                                          running bdist_wheel
                                          running build
                                          running build_py
                                          creating build
                                          creating build\lib.win32-3.7
                                          creating build\lib.win32-3.7\gevent
                                          copying src\gevent\backdoor.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\baseserver.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\builtins.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\core.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\event.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\fileobject.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\greenlet.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\hub.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\local.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\lock.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\monkey.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\os.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\pool.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\pywsgi.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\queue.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\resolver_ares.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\resolver_thread.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\select.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\server.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\signal.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\socket.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\ssl.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\subprocess.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\thread.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\threading.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\threadpool.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\timeout.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\util.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\win32util.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\wsgi.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_compat.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_fileobjectcommon.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_fileobjectposix.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_semaphore.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_socket2.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_socket3.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_socketcommon.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_ssl2.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_ssl3.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_sslgte279.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_tblib.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_threading.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_util.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\_util_py2.py -> build\lib.win32-3.7\gevent
                                          copying src\gevent\__init__.py -> build\lib.win32-3.7\gevent
                                          creating build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\corecffi.py -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\_corecffi_build.py -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\__init__.py -> build\lib.win32-3.7\gevent\libev
                                          running egg_info
                                          writing src\gevent.egg-info\PKG-INFO
                                          writing dependency_links to src\gevent.egg-info\dependency_links.txt
                                          writing requirements to src\gevent.egg-info\requires.txt
                                          writing top-level names to src\gevent.egg-info\top_level.txt
                                          reading manifest file 'src\gevent.egg-info\SOURCES.txt'
                                          reading manifest template 'MANIFEST.in'
                                          warning: no files found matching 'changelog.rst'
                                          warning: no files found matching 'known_failures.py'
                                          warning: no files found matching '.pep8'
                                          no previously-included directories found matching '*\__pycache__'
                                          warning: no previously-included files matching '*.so' found anywhere in distribution
                                          warning: no previously-included files matching '*.o' found anywhere in distribution
                                          warning: no previously-included files matching '*.lo' found anywhere in distribution
                                          warning: no previously-included files matching '*.la' found anywhere in distribution
                                          warning: no previously-included files matching 'config.log' found anywhere in distribution
                                          warning: no previously-included files matching 'config.status' found anywhere in distribution
                                          no previously-included directories found matching 'doc\_build'
                                          warning: no previously-included files matching '*.pyc' found anywhere in distribution
                                          warning: no previously-included files matching '.coverage' found under directory 'src\greentest'
                                          no previously-included directories found matching 'src\greentest\htmlcov'
                                          warning: no previously-included files matching 'stamp-h?' found under directory 'deps\c-ares'
                                          warning: no previously-included files matching 'ares_build.h.orig' found under directory 'deps\c-ares'
                                          no previously-included directories found matching 'deps\libev\.deps'
                                          warning: no previously-included files matching 'Makefile' found under directory 'deps\libev'
                                          warning: no previously-included files matching 'libtool' found under directory 'deps\libev'
                                          warning: no previously-included files matching 'stamp-h?' found under directory 'deps\libev'
                                          warning: no previously-included files matching 'config.h' found under directory 'deps\libev'
                                          warning: no previously-included files matching '_corecffi.c' found under directory 'src\gevent'
                                          warning: no previously-included files found matching 'Makefile'
                                          warning: no previously-included files found matching 'configure-output'
                                          writing manifest file 'src\gevent.egg-info\SOURCES.txt'
                                          copying src\gevent\_semaphore.pxd -> build\lib.win32-3.7\gevent
                                          copying src\gevent\ares.pyx -> build\lib.win32-3.7\gevent
                                          copying src\gevent\cares.pxd -> build\lib.win32-3.7\gevent
                                          copying src\gevent\cares_ntop.h -> build\lib.win32-3.7\gevent
                                          copying src\gevent\cares_pton.h -> build\lib.win32-3.7\gevent
                                          copying src\gevent\dnshelper.c -> build\lib.win32-3.7\gevent
                                          copying src\gevent\gevent._semaphore.c -> build\lib.win32-3.7\gevent
                                          copying src\gevent\gevent.ares.c -> build\lib.win32-3.7\gevent
                                          copying src\gevent\gevent.ares.h -> build\lib.win32-3.7\gevent
                                          copying src\gevent\python.pxd -> build\lib.win32-3.7\gevent
                                          copying src\gevent\libev\_corecffi_cdef.c -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\_corecffi_source.c -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\callbacks.c -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\callbacks.h -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\corecext.ppyx -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\corecext.pyx -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\gevent.corecext.c -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\libev.h -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\libev.pxd -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\libev_vfd.h -> build\lib.win32-3.7\gevent\libev
                                          copying src\gevent\libev\stathelper.c -> build\lib.win32-3.7\gevent\libev
                                          running build_ext
                                          building 'gevent.libev.corecext' extension
                                          error: Microsoft Visual C++ 14.0 is required. Get it with "Microsoft Visual C++ Build Tools": http://landinghub.visualstudio.com/visual-cpp-build-tools
                                          Failed building wheel for gevent
                                          Running setup.py clean for gevent
                                          Running setup.py bdist_wheel for urwid ... done
                                          Stored in directory: C:\Users\chris\AppData\Local\pip\Cache\wheels\34\06\50\24011714e101b5ad8518c69175d117a257413e3c15a92983f0
                                          Running setup.py bdist_wheel for demjson ... done
                                          Stored in directory: C:\Users\chris\AppData\Local\pip\Cache\wheels\c5\d2\ab\a54fb5ea53ac3badba098160e8452fa126a51febda80440ded
                                          Running setup.py bdist_wheel for pycparser ... done
                                          Stored in directory: C:\Users\chris\AppData\Local\pip\Cache\wheels\f2\9a\90\de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511
                                        Successfully built construct dpkt urwid demjson pycparser
                                        Failed to build gevent
                                        Installing collected packages: construct, dpkt, greenlet, gevent, six, idna, asn1crypto, pycparser, cffi, cryptography, urwid, appdirs, urllib3, certifi, chardet, requests, demjson, xbox-webapi, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, MarkupSafe, Jinja2, click, itsdangerous, Werkzeug, Flask, xbox-smartglass-rest
                                          Running setup.py install for gevent ... error
                                            Complete output from command C:\Users\chris\AppData\Local\Programs\Python\Python37-32\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\chris\\AppData\\Local\\Temp\\pip-install-ohq6rdrn\\gevent\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\chris\AppData\Local\Temp\pip-record-31g6cg50\install-record.txt --single-version-externally-managed --compile --user --prefix=:
                                              warnings.warn(msg)
                                            running install
                                            running build
                                            running build_py
                                            creating build
                                            running egg_info
                                            running build_ext
                                        Command "C:\Users\chris\AppData\Local\Programs\Python\Python37-32\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\chris\\AppData\\Local\\Temp\\pip-install-ohq6rdrn\\gevent\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\chris\AppData\Local\Temp\pip-record-31g6cg50\install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in C:\Users\chris\AppData\Local\Temp\pip-install-ohq6rdrn\gevent\
                                        npm WARN rollback Rolling back nan@2.3.5 failed (this is probably harmless): EPERM: operation not permitted, lstat 'C:\ioBroker\node_modules\unix-dgram\node_modules'
                                        npm ERR! errno 1
                                        npm ERR!
                                        npm ERR!     C:\Users\chris\AppData\Roaming\npm-cache\_logs\2018-11-11T16_17_15_951Z-debug.log
                                        C:\ioBroker></string></string>
                                        • foxriver76
                                          I’m Forum sieht man es schlecht, jedoch müssen vor den Argumenten wie unsafe-perm zwei Striche — sein und nicht einer -
                                          • Negalein
                                            @foxriver76:
                                            I’m Forum sieht man es schlecht, jedoch müssen vor den Argumenten wie unsafe-perm zwei Striche — sein und nicht einer - `
                                            Also müsste es so aussehen?
                                            npm i iobroker.xbox ——production ——unsafe-perm
                                            31.7k
                                            79.8k
                                            adapter xbox
                                            13
                                            205
                                            28475
