    4. Stalltür zu Licht an
    • Amnesia1211
      Amnesia1211 last edited by
      Wenn der schalter in der Visu auf AN/true ist und die Helligkeit unter 68 ist soll das Programm ablaufen.
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="ORNQv.joaPZbA5:;ghep" x="88" y="88"><mutation items="1"></mutation>
          <value name="OID0"><shadow type="field_oid" id="k(0TzR6@*h1t7.|lBmjT"><field name="oid">hm-rpc.0.MEQ1423569.1.BRIGHTNESS</field></shadow></value>
          <statement name="STATEMENT"><block type="controls_if" id="3v{Hbuj23FRj/)3B`,g1"><mutation else="1"></mutation>
              <value name="IF0"><block type="logic_operation" id="=(BUP}@X{zZd^x5vIU}R" inline="false"><field name="OP">AND</field>
                  <value name="A"><block type="logic_compare" id="MZ0,Iu+z]zc4dpLt1ekC"><field name="OP">EQ</field>
                      <value name="A"><block type="get_value" id="y{qiG5][odrL?A]EyK=*"><field name="ATTR">val</field>
                          <field name="OID">Schalter.0.Stall.AutoStallTuerZU</field></block></value>
                      <value name="B"><block type="logic_boolean" id="@i}LD?wd^uSs![i`qeAn"><field name="BOOL">TRUE</field></block></value></block></value>
                  <value name="B"><block type="logic_compare" id="T~@~^gO?!Y,9[6%+ohb4"><field name="OP">LTE</field>
                      <value name="A"><block type="get_value" id="UDS]Yjvab)]y1FGG*X[!"><field name="ATTR">val</field>
                          <field name="OID">hm-rpc.0.MEQ1423569.1.BRIGHTNESS</field></block></value>
                      <value name="B"><block type="math_number" id="_JFkb-+A^rB5k^PE?AY:"><field name="NUM">68</field></block></value></block></value></block></value>
              <statement name="DO0"><block type="comment" id="{-e)J8j;7HJiF9eQ56k@"><field name="COMMENT">Stalltür</field>
                  <next><block type="control" id="yY,cL/o9-Kb6NHI#:MS]"><mutation delay_input="false"></mutation>
                      <field name="OID">hm-rpc.0.PEQ0095942.1.LEVEL</field>
                      <value name="VALUE"><block type="math_number" id="O`{I^#GR(30ba)VB!7zf"><field name="NUM">100</field></block></value>
                      <next><block type="control" id="{_Km|iHD`F(YYpw_ELS~"><mutation delay_input="true"></mutation>
                          <field name="OID">sonoff.0.Licht_Huehnerstall.POWER</field>
                          <field name="DELAY_MS">2</field>
                          <value name="VALUE"><block type="logic_boolean" id="3hgW8Qt{r3etFphYLII."><field name="BOOL">TRUE</field></block></value>
                          <next><block type="control" id="2~dNDSf-:~3/5ll]J;eX"><mutation delay_input="true"></mutation>
                              <field name="DELAY_MS">180</field>
                              <value name="VALUE"><block type="logic_boolean" id="8*Dwh3n%91SycVOW{TPV"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></next></block></statement>
              <statement name="ELSE"><block type="control" id="LB|e;s/@3D*uQ(EW=B(l"><mutation delay_input="false"></mutation>
                  <value name="VALUE"><block type="logic_boolean" id="XxR0V@MWf0rv4EUH{pdU"><field name="BOOL">FALSE</field></block></value></block></statement></block></statement></block>
        <block type="comment" id="I)mUByoHyN2M`IiW25-C" x="387" y="138"><field name="COMMENT">Button AN/AUS in Visu</field></block>
        <block type="comment" id="tPmqsEOR0V.4ISJcqe6j" x="813" y="188"><field name="COMMENT">Helligkeit Bewegungsmelder</field></block></xml>
        Jan1 last edited by
        Ersetzte Dein Trigger DP "Helligkeit" durch den DP aus VIS und mach das "=wahr" weg. Dann läuft das, wie ich gestern schon geschrieben habe 😉
        Der Auslöser ist Dein Schalter in VIS und Trigger bedeutet nichts anderes als Auslöser, warum dann auf die Helligkeit triggern? Helligkeit ist ne falls Abfrage.
        • Amnesia1211
          Muss dann nicht der Schalter immer ein mal auf AN oder AUS geschaltet werden damit das Programm wieder läuft ?
          Die UND Verknüpfung weiß doch gar nicht den wert vom Button AN/AUS oder sehe ich das auch falsch?
            Jan1 last edited by
            Das ist richtig, nur dachte ich Du schaltest das auch immer an und aus.
            Beim Trigger oben auch nichts anhängen, sondern das vordefinierte Feld verwenden, oder den anderen Trigger, der eh nur ein Objekt erlaubt verwenden. Alternativ kannst ein Zeitplan als Trigger nehmen. Da stellst im CRON einfach den ungefähren Zeitraum ein, wann die ganzen Aktionen überhaupt in Betracht kommen. Der wiederholt dann im vordefinierten Abstand das Script und führt auch alles aus.
            Mit der Helligkeit als Trigger und Helligkeit als Falls ist eben blöd, wenn das durch Wolken oder sonst was mal true oder false sein kann, dann macht Dein Stalllicht eben auch an/aus und die Hühner haben Dico :lol:
            Was noch gut wäre, eine zusätzliche Helligkeitsabfrage auf nicht größer als. So kannst Helligkeitsschwankungen ausgleichen. Welche Werte dafür in Frage kommen, muss testen.
            • Amnesia1211
              Wenn einer zuhause ist der die Tür zu machen kann ist das Programm auch ausgeschaltet aber wenn nicht dann soll es so ablaufen.
              Der Zeitplan ist ne gute Idee aber geht dann nicht auch jede Std das licht an und aus wegen dem Zeitplan ?
              Das mit dem UND verstehe ich nicht so ganz, der WERT vom Schalter True/False (AN/AUS) muss doch auch verglichen werden.
              Wenn das UND nur den WERT hat True/False woher weis er dann das es richtig ist?
              Ich breche mir einen ab für so einen kleinen scheiß tut mir echt leid für den ganzen Stress, herzlichen dank noch mal für deine tolle Hilfe !!!!!!
                Jan1 last edited by
                Dadurch lernst aber auch die Zusammenhänge zu verstehen.
                Also zum "falls" Block, der prüft immer auf "true", deshalb ist es nicht nötig das nochmal extra als "= wahr" zu fragen, da doppelt abgefragt. Kann man machen, ist aber überflüssig. Du darfst nicht das eingetragene Objekt bei der Betrachtung in den Vordergrund stellen, sondern dessen Wert und da steht ja in der Regel true oder false.
                Das Licht wird nur an und ausgehen, wenn die UND Bedingung dementsprechend erfüllt oder eben nicht erfüllt ist. Hier liegt auch die Schwierigkeit in dem Scriptz, da die Helligkeit und deren eingestellte Grenzen eben so ihre Tücken hat.
                Da hilft einfach, wenn man sich selber die Frage stellt kann das Licht bei einer bestimmten Konstellation ungewollt an oder aus gehen und das Szenario durchspielt. Bei Dir ist eben die Helligkeit die Variable und hier kann es hilfreich sein, wenn man eine ober und unter Grenze einfügt um etwas mehr Ruhe rein zu bekommen.
                • Amnesia1211
                  Ok, dann muss das ja komplett das Problem beheben.
                  • Amnesia1211
                    Ok das klappt auch nicht jetzt ist iobroker abgeschmiert :?
                      Jan1 last edited by
                      Da haste auch ne schöne Endlosschleife gebastelt :lol:
                      Das wiederhole ist ne böse Geschichte, wenn man das falsch verwendet. In der Fünktion gefört wenn überhaupt 1 rein und nicht 100, wobei das doch überflüssig ist. Die Tür geht doch zu, wenn man sie direkt auf 100 setzt, oder nicht?
                      • Amnesia1211
                        Ich glaube das Licht einschalten lasse ich raus, dass wird nichts wenn ich das so umsetzte geht wenn man das licht normal einschaltet immer aus. 😐
                        Danke noch mal für alles !!
                          Jan1 last edited by
                          Nicht aufgeben, so kompliziert ist das nicht.
                          Für mich ist es nur bisschen schwerer mit der Hilfe da ich Deine DPs dazu nicht wirklich kenne, wie die gesetzt und gesteuert werden. Die Tür z.B., warum hat die ein Level, was steckt da für eine HW dahinter, wie ist die in IOBroker überhaupt eingebunden. Das gleiche dann auch noch mit dem Licht.
                          Bei mir ist es egal, wie ich meine Lichter Schalte, wenn ich den Wandschalter betätige, dann toggelt er den aktuellen Zustand.
                          • Amnesia1211
                            Guten Morgen, habe es nicht schneller geschafft das zusammen zu stellen liege mit einer Grippe im bett 😞
                            Also hier mal Bilder wie das aufgebaut ist.
                            Zu der Tür, sie wird mit einem Rollladenmotor auf und zu gefahren, gesteuert wird es von HM-LC-Bl1PBU-FM deswegen das Level.
                            Wenn du noch mehr Infos Brauchst sag das, eine Lösung würde natürlich toll sein. Meine Frau ist von der ganzen Sache schon genervt :roll:
                            als wir das Projekt angefangen haben dachte ich das ist doch kein Problem naja war es wie man sieht doch.
                              Jan1 last edited by
                              Warum Du noch ein DP für "Stalltür auto auf" hast erschließt sich mir nicht, da das in dem Script nicht abgefragt wird.
                              Ichj hab das noch mal bisschen angepasst und das Licht nun in Abhängigkeit von der geschlossenen Stalltür eingebaut. den DP muss in der 2. falls noch einfügen.
                               <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="iKu7PN9]2@mo1QWA}wC{" x="-112.23333358764751" y="-237.5"><field name="SCHEDULE">* 17-22 * * *</field>
                                <statement name="STATEMENT"><block type="controls_if" id="3v{Hbuj23FRj/)3B`,g1"><value name="IF0"><block type="logic_operation" id="=(BUP}@X{zZd^x5vIU}R" inline="false"><field name="OP">AND</field>
                                    <statement name="DO0"><block type="control" id="yY,cL/o9-Kb6NHI#:MS]"><mutation delay_input="false"></mutation>
                                        <next><block type="controls_if" id="6%5NI0R1.LllcLUtnY,?"><value name="IF0"><block type="logic_compare" id="_(}JN4EiA}27P.eOVNmZ"><field name="OP">EQ</field>
                                                <value name="A"><block type="get_value" id="@/6u:`g4USwgjx2Q+Spl"><field name="ATTR">val</field>
                                                    <field name="OID">ID auswählen</field></block></value>
                                                <value name="B"><block type="math_number" id="iP70DCq7mZp@x9M0/}]h"><field name="NUM">100</field></block></value></block></value>
                                            <statement name="DO0"><block type="control" id="{_Km|iHD`F(YYpw_ELS~"><mutation delay_input="true"></mutation>
                                                <field name="DELAY_MS">1</field>
                                                    <field name="DELAY_MS">179</field>
                                                    <value name="VALUE"><block type="logic_boolean" id="8*Dwh3n%91SycVOW{TPV"><field name="BOOL">FALSE</field></block></value></block></next></block></statement></block></next></block></statement></block></statement></block>
                              • Amnesia1211
                                Oh danke das ist aber nett, der zweite DP ist für das andere Script für Stall Tür morgens auf da brauch auch kein Licht an gehen und alles ging ohne Probleme. Werde ich mal morgen Abend testen und Info geben ob alles geklappt hat.
                                • Amnesia1211
                                  Hat alles geklappt danke
                                  1051
