    4. Javascript Errors im Log
    • Negalein
      Hallo
      Seit kurzem hab ich im log sehr viele JS-Fehler!
      Version ist 4.0.11
      Glaube es ist seitdem ich den Alexa auf 2.2.0 upgedatet habe.
      javascript.0	2019-01-18 22:45:05.931	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:05.931	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:05.931	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:05.931	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:05.931	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:05.931	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:05.931	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:05.930	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:05.930	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:05.930	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:05.930	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:05.929	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:05.929	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:05.925	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:05.925	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:05.925	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:05.924	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:05.924	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:05.924	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:05.924	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:05.924	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:05.924	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:05.924	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:05.923	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:05.922	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:05.922	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:05.360	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:05.360	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:05.360	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:05.360	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:05.360	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:05.360	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:05.360	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:05.360	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:05.360	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:05.360	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:05.359	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:05.358	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:05.358	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:05.353	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:05.353	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:05.353	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:05.352	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:05.352	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:05.352	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:05.352	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:05.352	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:05.352	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:05.352	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:05.352	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:05.351	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:05.351	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:04.735	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.735	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:04.735	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:04.735	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:04.735	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.734	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:04.734	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:04.734	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:04.734	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:04.734	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:04.734	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:04.733	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:04.733	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:04.728	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.728	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:04.728	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:04.728	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:04.727	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.727	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:04.727	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:04.727	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:04.727	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:04.727	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:04.727	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:04.726	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:04.726	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:04.085	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.085	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:04.085	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:04.085	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:04.085	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.085	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:04.085	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:04.085	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:04.085	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:04.085	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:04.084	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:04.084	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:04.084	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:04.077	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.077	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:04.077	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:04.077	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:04.077	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.077	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:04.077	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:04.077	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:04.077	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:04.077	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:04.077	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:04.076	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:04.076	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:04.009	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.008	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:04.008	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:04.008	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:04.008	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.008	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:04.008	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:04.008	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:04.008	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:04.008	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:04.008	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:04.007	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:04.007	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:04.001	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.001	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:04.001	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:04.001	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:04.001	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:04.001	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:04.001	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:04.000	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:04.000	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:04.000	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
      javascript.0	2019-01-18 22:45:04.000	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:03.999	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:03.999	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:03.927	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:03.927	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-01-18 22:45:03.927	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-01-18 22:45:03.926	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-01-18 22:45:03.926	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:03.926	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-01-18 22:45:03.926	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-18 22:45:03.926	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-18 22:45:03.926	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:755:38)
      javascript.0	2019-01-18 22:45:03.926	error	at Object. <anonymous>(script.js.common.Wetter_3:18:204)
      javascript.0	2019-01-18 22:45:03.926	error	Error in callback: TypeError: Cannot read property 'val' of undefined
      javascript.0	2019-01-18 22:45:03.925	error	script.js.common.Wetter_3: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_1.symbol_value", (err, state) => { ... });
      javascript.0	2019-01-18 22:45:03.925	error	script.js.common.Wetter_3: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      javascript.0	2019-01-18 22:45:03.919	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-01-18 22:45:03.919	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
      Auch bekomme ich beim starten mancher Scripte im Scripteditor unterhalb Fehler angezeigt.
      Müllscript:
      22:54:16.431	error	javascript.0 script.js.common.Muell: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      22:54:16.432	error	javascript.0 script.js.common.Muell: Please disable that setting or use "getState" with a callback, e.g.: getState("ical.2.events.0.today.Restabfall", (err, state) => { ... });
      22:54:16.432	error	javascript.0 at Object.keys.forEach.eintrag (script.js.common.Muell:61:53)
      22:54:16.432	error	javascript.0 at Object.check (script.js.common.Muell:57:28)
      Alexa:
      22:55:04.450	error	javascript.0 script.js.common.Alexa: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      22:55:04.450	error	javascript.0 script.js.common.Alexa: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.AlexaLogon.csrf", (err, state) => { ... });
      22:55:04.451	error	javascript.0 script.js.common.Alexa: script.js.common.Alexa:80
      22:55:04.451	error	javascript.0 at script.js.common.Alexa:80:30
      Alexa Logon:
      22:56:17.286	error	javascript.0 script.js.common.Alexa_Logon: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      22:56:17.286	error	javascript.0 script.js.common.Alexa_Logon: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.productive.alexalogon.cookie", (err, state) => { ... });
      22:56:17.287	error	javascript.0 at Object.main (script.js.common.Alexa_Logon:121:57)
      Fronius:
      22:57:10.353	warn	javascript.0 at script.js.common.Fronius-Max:85:13
      22:57:10.353	warn	javascript.0 at Request._callback (script.js.common.Fronius-Max:63:13)
      22:57:10.355	warn	javascript.0 at script.js.common.Fronius-Max:86:13
      22:57:10.355	warn	javascript.0 at Request._callback (script.js.common.Fronius-Max:63:13)
      An was könnte das liegen?
      Was hat es mit diesem "getState" zu tun?
      Kenne mich in JS und Programmierung 0 aus.
      Funktionseinschränkungen sind mir noch nicht aufgefallen. Kann aber auch daran liegen, dass der ioBroker noch im Aufbau ist.
        apollon77 last edited by
        JavaScript Adapter Downgraden bitte.
        Gesendet vom Handy …
        • Negalein
          @apollon77:
          JavaScript Adapter Downgraden bitte. `
          Hätt ich gerade versucht.
          ioBroker ist auf einer Synology installiert.
          wenn ich
          cd /opt/iobroker
          iobroker stop
          npm i iobroker.js-controller@1.2.3
          iobroker start
          mache kommt folgende Fehlermeldung.
          0 info it worked if it ends with ok
          1 verbose cli [ '/usr/bin/node',
          1 verbose cli   '/usr/bin/npm',
          1 verbose cli   'i',
          1 verbose cli   'iobroker.js-controller@4.0.7' ]
          2 info using npm@3.10.10
          3 info using node@v6.14.4
          4 silly loadCurrentTree Starting
          5 silly install loadCurrentTree
          6 silly install readLocalPackageData
          7 silly fetchPackageMetaData iobroker.js-controller@4.0.7
          8 silly fetchNamedPackageData iobroker.js-controller
          9 silly mapToRegistry name iobroker.js-controller
          10 silly mapToRegistry using default registry
          11 silly mapToRegistry registry https://registry.npmjs.org/
          12 silly mapToRegistry data Result {
          12 silly mapToRegistry   raw: 'iobroker.js-controller',
          12 silly mapToRegistry   scope: null,
          12 silly mapToRegistry   escapedName: 'iobroker.js-controller',
          12 silly mapToRegistry   name: 'iobroker.js-controller',
          12 silly mapToRegistry   rawSpec: '',
          12 silly mapToRegistry   spec: 'latest',
          12 silly mapToRegistry   type: 'tag' }
          13 silly mapToRegistry uri https://registry.npmjs.org/iobroker.js-controller
          14 verbose request uri https://registry.npmjs.org/iobroker.js-controller
          15 verbose request no auth needed
          16 info attempt registry request try #1 at 23:53:38
          17 verbose request id ab80bb131a2e6833
          18 verbose etag W/"2018f80f4eb109e6b43e42fed56fb16f"
          19 verbose lastModified Fri, 04 Jan 2019 05:20:58 GMT
          20 http request GET https://registry.npmjs.org/iobroker.js-controller
          21 http 304 https://registry.npmjs.org/iobroker.js-controller
          22 verbose headers { date: 'Fri, 18 Jan 2019 22:53:38 GMT',
          22 verbose headers   connection: 'keep-alive',
          22 verbose headers   'set-cookie': [ '__cfduid=dfb26b5b097ede89e65fcb58c14cb563f1547852018; expires=Sat, 18-Jan-20 22:53:38 GMT; path=/; domain=.registry.npmjs.org; HttpOnly' ],
          22 verbose headers   'cf-cache-status': 'HIT',
          22 verbose headers   'cache-control': 'max-age=300',
          22 verbose headers   'cf-ray': '49b4a389db625a0e-VIE',
          22 verbose headers   etag: '"2018f80f4eb109e6b43e42fed56fb16f"',
          22 verbose headers   'expect-ct': 'max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"',
          22 verbose headers   'last-modified': 'Fri, 04 Jan 2019 05:20:58 GMT',
          22 verbose headers   vary: 'accept-encoding, accept',
          22 verbose headers   'x-amz-meta-rev': '157-0e19454dbb979a8e57c7d2790da42713',
          22 verbose headers   server: 'cloudflare' }
          23 silly get cb [ 304,
          23 silly get   { date: 'Fri, 18 Jan 2019 22:53:38 GMT',
          23 silly get     connection: 'keep-alive',
          23 silly get     'set-cookie': [ '__cfduid=dfb26b5b097ede89e65fcb58c14cb563f1547852018; expires=Sat, 18-Jan-20 22:53:38 GMT; path=/; domain=.registry.npmjs.org; HttpOnly' ],
          23 silly get     'cf-cache-status': 'HIT',
          23 silly get     'cache-control': 'max-age=300',
          23 silly get     'cf-ray': '49b4a389db625a0e-VIE',
          23 silly get     etag: '"2018f80f4eb109e6b43e42fed56fb16f"',
          23 silly get     'expect-ct': 'max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"',
          23 silly get     'last-modified': 'Fri, 04 Jan 2019 05:20:58 GMT',
          23 silly get     vary: 'accept-encoding, accept',
          23 silly get     'x-amz-meta-rev': '157-0e19454dbb979a8e57c7d2790da42713',
          23 silly get     server: 'cloudflare' } ]
          24 verbose etag https://registry.npmjs.org/iobroker.js-controller from cache
          25 verbose get saving iobroker.js-controller to /root/.npm/registry.npmjs.org/iobroker.js-controller/.cache.json
          26 verbose correctMkdir /root/.npm correctMkdir not in flight; initializing
          27 silly fetchNamedPackageData No valid target from cache, forcing network
          28 verbose request uri https://registry.npmjs.org/iobroker.js-controller
          29 verbose request no auth needed
          30 info attempt registry request try #1 at 23:53:38
          31 http request GET https://registry.npmjs.org/iobroker.js-controller
          32 http 200 https://registry.npmjs.org/iobroker.js-controller
          33 verbose headers { date: 'Fri, 18 Jan 2019 22:53:38 GMT',
          33 verbose headers   'content-type': 'application/json',
          33 verbose headers   'transfer-encoding': 'chunked',
          33 verbose headers   connection: 'keep-alive',
          33 verbose headers   'set-cookie': [ '__cfduid=dfb26b5b097ede89e65fcb58c14cb563f1547852018; expires=Sat, 18-Jan-20 22:53:38 GMT; path=/; domain=.registry.npmjs.org; HttpOnly' ],
          33 verbose headers   'cf-cache-status': 'HIT',
          33 verbose headers   'cache-control': 'max-age=300',
          33 verbose headers   'cf-ray': '49b4a38a8be55a0e-VIE',
          33 verbose headers   etag: 'W/"2018f80f4eb109e6b43e42fed56fb16f"',
          33 verbose headers   'expect-ct': 'max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"',
          33 verbose headers   'last-modified': 'Fri, 04 Jan 2019 05:20:58 GMT',
          33 verbose headers   vary: 'accept-encoding, accept',
          33 verbose headers   'x-amz-meta-rev': '157-0e19454dbb979a8e57c7d2790da42713',
          33 verbose headers   server: 'cloudflare',
          33 verbose headers   'content-encoding': 'gzip' }
          34 silly get cb [ 200,
          34 silly get   { date: 'Fri, 18 Jan 2019 22:53:38 GMT',
          34 silly get     'content-type': 'application/json',
          34 silly get     'transfer-encoding': 'chunked',
          34 silly get     connection: 'keep-alive',
          34 silly get     'set-cookie': [ '__cfduid=dfb26b5b097ede89e65fcb58c14cb563f1547852018; expires=Sat, 18-Jan-20 22:53:38 GMT; path=/; domain=.registry.npmjs.org; HttpOnly' ],
          34 silly get     'cf-cache-status': 'HIT',
          34 silly get     'cache-control': 'max-age=300',
          34 silly get     'cf-ray': '49b4a38a8be55a0e-VIE',
          34 silly get     etag: 'W/"2018f80f4eb109e6b43e42fed56fb16f"',
          34 silly get     'expect-ct': 'max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"',
          34 silly get     'last-modified': 'Fri, 04 Jan 2019 05:20:58 GMT',
          34 silly get     vary: 'accept-encoding, accept',
          34 silly get     'x-amz-meta-rev': '157-0e19454dbb979a8e57c7d2790da42713',
          34 silly get     server: 'cloudflare',
          34 silly get     'content-encoding': 'gzip' } ]
          35 verbose get saving iobroker.js-controller to /root/.npm/registry.npmjs.org/iobroker.js-controller/.cache.json
          36 verbose correctMkdir /root/.npm correctMkdir not in flight; initializing
          37 silly fetchPackageMetaData Error: No compatible version found: iobroker.js-controller@4.0.7
          37 silly fetchPackageMetaData Valid install targets:
          37 silly fetchPackageMetaData 1.5.3, 1.5.2, 1.5.1, 1.5.0, 1.4.2, 1.4.0, 1.3.0, 1.2.7, 1.2.6, 1.2.5, 1.2.3, 1.2.2, 1.2.1, 1.2.0, 1.1.3, 1.1.2, 1.1.1, 1.0.3, 1.0.0, 0.17.2, 0.16.2, 0.16.1, 0.15.3, 0.15.2, 0.15.1, 0.14.0, 0.13.2, 0.13.1, 0.12.2, 0.11.3, 0.11.2, 0.11.1, 0.11.0, 0.10.1, 0.9.0, 0.8.10, 0.8.9, 0.8.7, 0.8.6, 0.8.5, 0.8.4, 0.8.2, 0.8.1, 0.7.15, 0.7.14, 0.7.13, 0.7.12, 0.7.11, 0.7.10, 0.7.9, 0.7.7, 0.7.5, 0.7.4, 0.7.3, 0.7.2, 0.7.1, 0.6.6, 0.6.4, 0.6.3, 0.5.15, 0.5.14, 0.5.12, 0.5.11, 0.5.9, 0.5.8, 0.5.7, 0.5.6, 0.5.5, 0.5.4, 0.5.3, 0.5.2, 0.5.0, 0.4.6, 0.4.5, 0.4.4, 0.4.3, 0.4.2, 0.4.1, 0.4.0, 0.3.17, 0.3.16, 0.3.15, 0.3.14, 0.3.13, 0.3.12, 0.3.11, 0.3.10, 0.3.9, 0.3.8, 0.3.7, 0.3.6, 0.3.5, 0.3.4, 0.3.3, 0.3.2, 0.3.1
          37 silly fetchPackageMetaData     at pickVersionFromRegistryDocument (/usr/lib/node_modules/npm/lib/fetch-package-metadata.js:178:16)
          37 silly fetchPackageMetaData     at /usr/lib/node_modules/npm/node_modules/iferr/index.js:13:50
          37 silly fetchPackageMetaData     at /usr/lib/node_modules/npm/lib/utils/pulse-till-done.js:20:8
          37 silly fetchPackageMetaData     at saved (/usr/lib/node_modules/npm/lib/cache/caching-client.js:174:7)
          37 silly fetchPackageMetaData     at /usr/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:241:18
          37 silly fetchPackageMetaData     at FSReqWrap.oncomplete (fs.js:123:15)
          37 silly fetchPackageMetaData  error for iobroker.js-controller@4.0.7 { Error: No compatible version found: iobroker.js-controller@4.0.7
          37 silly fetchPackageMetaData     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ETARGET' }
          38 silly rollbackFailedOptional Starting
          39 silly rollbackFailedOptional Finishing
          40 silly runTopLevelLifecycles Finishing
          41 silly install printInstalled
          42 verbose stack Error: No compatible version found: iobroker.js-controller@4.0.7
          42 verbose stack Valid install targets:
          42 verbose stack 1.5.3, 1.5.2, 1.5.1, 1.5.0, 1.4.2, 1.4.0, 1.3.0, 1.2.7, 1.2.6, 1.2.5, 1.2.3, 1.2.2, 1.2.1, 1.2.0, 1.1.3, 1.1.2, 1.1.1, 1.0.3, 1.0.0, 0.17.2, 0.16.2, 0.16.1, 0.15.3, 0.15.2, 0.15.1, 0.14.0, 0.13.2, 0.13.1, 0.12.2, 0.11.3, 0.11.2, 0.11.1, 0.11.0, 0.10.1, 0.9.0, 0.8.10, 0.8.9, 0.8.7, 0.8.6, 0.8.5, 0.8.4, 0.8.2, 0.8.1, 0.7.15, 0.7.14, 0.7.13, 0.7.12, 0.7.11, 0.7.10, 0.7.9, 0.7.7, 0.7.5, 0.7.4, 0.7.3, 0.7.2, 0.7.1, 0.6.6, 0.6.4, 0.6.3, 0.5.15, 0.5.14, 0.5.12, 0.5.11, 0.5.9, 0.5.8, 0.5.7, 0.5.6, 0.5.5, 0.5.4, 0.5.3, 0.5.2, 0.5.0, 0.4.6, 0.4.5, 0.4.4, 0.4.3, 0.4.2, 0.4.1, 0.4.0, 0.3.17, 0.3.16, 0.3.15, 0.3.14, 0.3.13, 0.3.12, 0.3.11, 0.3.10, 0.3.9, 0.3.8, 0.3.7, 0.3.6, 0.3.5, 0.3.4, 0.3.3, 0.3.2, 0.3.1
          42 verbose stack
          42 verbose stack     at pickVersionFromRegistryDocument (/usr/lib/node_modules/npm/lib/fetch-package-metadata.js:178:16)
          42 verbose stack     at /usr/lib/node_modules/npm/node_modules/iferr/index.js:13:50
          42 verbose stack     at /usr/lib/node_modules/npm/lib/utils/pulse-till-done.js:20:8
          42 verbose stack     at saved (/usr/lib/node_modules/npm/lib/cache/caching-client.js:174:7)
          42 verbose stack     at /usr/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:241:18
          42 verbose stack     at FSReqWrap.oncomplete (fs.js:123:15)
          43 verbose cwd /opt/iobroker
          44 error Linux 4.4.59+
          45 error argv "/usr/bin/node" "/usr/bin/npm" "i" "iobroker.js-controller@4.0.7"
          46 error node v6.14.4
          47 error npm  v3.10.10
          48 error code ETARGET
          49 error notarget No compatible version found: iobroker.js-controller@4.0.7
          49 error notarget Valid install targets:
          49 error notarget 1.5.3, 1.5.2, 1.5.1, 1.5.0, 1.4.2, 1.4.0, 1.3.0, 1.2.7, 1.2.6, 1.2.5, 1.2.3, 1.2.2, 1.2.1, 1.2.0, 1.1.3, 1.1.2, 1.1.1, 1.0.3, 1.0.0, 0.17.2, 0.16.2, 0.16.1, 0.15.3, 0.15.2, 0.15.1, 0.14.0, 0.13.2, 0.13.1, 0.12.2, 0.11.3, 0.11.2, 0.11.1, 0.11.0, 0.10.1, 0.9.0, 0.8.10, 0.8.9, 0.8.7, 0.8.6, 0.8.5, 0.8.4, 0.8.2, 0.8.1, 0.7.15, 0.7.14, 0.7.13, 0.7.12, 0.7.11, 0.7.10, 0.7.9, 0.7.7, 0.7.5, 0.7.4, 0.7.3, 0.7.2, 0.7.1, 0.6.6, 0.6.4, 0.6.3, 0.5.15, 0.5.14, 0.5.12, 0.5.11, 0.5.9, 0.5.8, 0.5.7, 0.5.6, 0.5.5, 0.5.4, 0.5.3, 0.5.2, 0.5.0, 0.4.6, 0.4.5, 0.4.4, 0.4.3, 0.4.2, 0.4.1, 0.4.0, 0.3.17, 0.3.16, 0.3.15, 0.3.14, 0.3.13, 0.3.12, 0.3.11, 0.3.10, 0.3.9, 0.3.8, 0.3.7, 0.3.6, 0.3.5, 0.3.4, 0.3.3, 0.3.2, 0.3.1
          50 error notarget This is most likely not a problem with npm itself.
          50 error notarget In most cases you or one of your dependencies are requesting
          50 error notarget a package version that doesn't exist.
          51 verbose exit [ 1, true ]
            Du solltest den JavaScript Adapter downgraden und nicht den js-Controller!!
            • Negalein
              @apollon77:
              Du solltest den JavaScript Adapter downgraden und nicht den js-Controller!! `
              Danke, hat funktioniert!
              Fehler sind schon um einiges weniger, aber zT noch vorhanden!
              javascript.0	2019-01-19 17:08:21.765	error	at ContextifyScript.Script.runInContext (vm.js:35:29)
              javascript.0	2019-01-19 17:08:21.765	error	at script.js.common.Alexa:80:30
              javascript.0	2019-01-19 17:08:21.764	error	TypeError: Cannot read property 'val' of undefined
              javascript.0	2019-01-19 17:08:21.764	error	^
              javascript.0	2019-01-19 17:08:21.764	error	var csrf = getState(idCsrf).val;
              javascript.0	2019-01-19 17:08:21.763	error	script.js.common.Alexa: script.js.common.Alexa:80
              javascript.0	2019-01-19 17:08:21.755	error	script.js.common.Alexa: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.AlexaLogon.csrf", (err, state) => { ... });
              javascript.0	2019-01-19 17:08:21.754	error	script.js.common.Alexa: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
              javascript.0	2019-01-19 17:08:22.820	error	at Timer.listOnTimeout (timers.js:214:5)
              javascript.0	2019-01-19 17:08:22.820	error	at tryOnTimeout (timers.js:250:5)
              javascript.0	2019-01-19 17:08:22.820	error	at ontimeout (timers.js:399:34)
              javascript.0	2019-01-19 17:08:22.820	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1794:34)
              javascript.0	2019-01-19 17:08:22.820	error	at Object.main (script.js.common.Alexa_Logon:121:57)
              javascript.0	2019-01-19 17:08:22.819	error	Error in callback: TypeError: Cannot read property 'val' of undefined
              javascript.0	2019-01-19 17:08:22.817	error	script.js.common.Alexa_Logon: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.productive.alexalogon.cookie", (err, state) => { ... });
              javascript.0	2019-01-19 17:08:22.817	error	script.js.common.Alexa_Logon: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
              javascript.0	2019-01-19 17:08:26.908	error	at Timer.listOnTimeout (timers.js:214:5)
              javascript.0	2019-01-19 17:08:26.908	error	at tryOnTimeout (timers.js:250:5)
              javascript.0	2019-01-19 17:08:26.907	error	at ontimeout (timers.js:399:34)
              javascript.0	2019-01-19 17:08:26.907	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1794:34)
              javascript.0	2019-01-19 17:08:26.907	error	at Object.check (script.js.common.Muell:57:28)
              javascript.0	2019-01-19 17:08:26.907	error	at Array.forEach (native)
              javascript.0	2019-01-19 17:08:26.907	error	at Object.keys.forEach.eintrag (script.js.common.Muell:61:53)
              javascript.0	2019-01-19 17:08:26.907	error	Error in callback: TypeError: Cannot read property 'val' of undefined
              javascript.0	2019-01-19 17:08:26.907	error	script.js.common.Muell: Please disable that setting or use "getState" with a callback, e.g.: getState("ical.2.events.0.today.Restabfall", (err, state) => { ... });
              javascript.0	2019-01-19 17:08:26.906	error	script.js.common.Muell: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
              Liest du hier vielleicht noch was raus?
                Ja na klar und wenn du genau ließt du auch
                Can not read Val of undefined. Da ist irgendetwas undefined und kein Objekt. Finde raus warum und fixe es
                  Happyuser20 last edited by
                  Hallo
                  Muss den Thread hier wieder aufgreifen.
                  ich möchte mit diesem Script meinen Stromverbrauch Stündlic/Täglich/Woche/Jahr loggen
                  Script
                  Wenn ich es starte bekomme ich im Log die gleichen Fehler wir "Negalein"
                  14890) at processTimers (internal/timers.js:497:7)
                  javascript.0	2020-12-30 08:00:00.030	error	(14890) at listOnTimeout (internal/timers.js:554:17)
                  javascript.0	2020-12-30 08:00:00.030	error	(14890) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
                  javascript.0	2020-12-30 08:00:00.030	error	(14890) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
                  javascript.0	2020-12-30 08:00:00.029	error	(14890) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
                  javascript.0	2020-12-30 08:00:00.018	error	(14890) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1273:34)
                  javascript.0	2020-12-30 08:00:00.018	error	(14890) at Object.<anonymous> (script.js.Strom_berechnen:44:5)
                  javascript.0	2020-12-30 08:00:00.018	error	(14890) at haupt (script.js.Strom_berechnen:31:35)
                  javascript.0	2020-12-30 08:00:00.017	error	(14890) Error in callback: TypeError: Cannot read property 'val' of undefined
                  javascript.0	2020-12-30 08:00:00.006	error	(14890) script.js.Strom_berechnen: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.Stromzähler.tmp.Total-h", (err, state) => { ... });
                  host.iobroker	2020-12-30 08:00:00.028	info	instance system.adapter.dwd.0 started with pid 8655
                  javascript.0	2020-12-30 08:00:00.006	error	(14890) script.js.Strom_berechnen: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
                  Ich Nutze den Adapter JS Script Engine in der Version 4.8.4
                  Downgraden kann ich über admin nur bis 4.6.26
                  Muss ich noch weiter downgraden um den Fehler zu beheben, wenn ja wie, oder mache ich einen anderen Fehler?
                  Danke schon mal im Voraus für eure hilfe!
                  HappyUser20
                  • Asgothian
                    Asgothian Developer @Happyuser20 last edited by
                    @Happyuser20 sagte in Javascript Errors im Log:
                    Moin,
                    hast du den Haken bei
                    in der Config des Adapters gesetzt ?
                      Happyuser20 @Asgothian last edited by Happyuser20
                      @Asgothian
                      Habe da überall einen Haken drin 🤔
                      • Asgothian
                        @Happyuser20
                        das genau ist der fehler
                          Happyuser20
                          1543
