    4. [Projekt] ioGo # Smarthome to go
    • dslraser
      Fensterkontakt
        "type": "state",
        "common": {
          "def": "CLOSED",
          "type": "number",
          "read": true,
          "write": false,
          "min": "CLOSED",
          "max": "OPEN",
          "states": {
            "0": "CLOSED",
            "1": "OPEN"
          "role": "state",
          "name": "Terrassentür.STATE"
        "native": {
          "MIN": "CLOSED",
          "UNIT": "",
          "OPERATIONS": 5,
          "MAX": "OPEN",
          "FLAGS": 1,
          "ID": "STATE",
          "TAB_ORDER": 0,
          "TYPE": "ENUM",
          "DEFAULT": "CLOSED",
          "VALUE_LIST": [
            "CLOSED",
            "OPEN"
          "CONTROL": "DOOR_SENSOR.STATE"
        "from": "system.adapter.hm-rega.0",
        "ts": 1542042783036,
        "_id": "hm-rpc.0.xxx.1.STATE",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.Heiko",
      Fensterdrehgriff
        "type": "state",
        "common": {
          "def": "CLOSED",
          "type": "number",
          "read": true,
          "write": false,
          "min": "CLOSED",
          "max": "OPEN",
          "states": {
            "0": "CLOSED",
            "1": "TILTED",
            "2": "OPEN"
          "role": "state",
          "name": "Saunakellerfenster links.STATE"
        "native": {
          "MIN": "CLOSED",
          "OPERATIONS": 5,
          "MAX": "OPEN",
          "FLAGS": 1,
          "ID": "STATE",
          "TYPE": "ENUM",
          "VALUE_LIST": [
            "CLOSED",
            "TILTED",
            "OPEN"
          "CONTROL": "RHS.STATE"
        "ts": 1542042783319,
        "_id": "hm-rpc.0.xxxxxx.1.STATE",
        "acl": {
          "object": 1636,
          "state": 1636,
        Kueppert last edited by
        @DSL: wie hast du denn manuell die Icons in die App bekommen? Oder zieht die so sich die Icons aus dem ioBroker??
          rudiraz last edited by
          bei mir funktioniert die Anzeige von Loxone-States ebenfalls nicht.
          Max-Werte (von MAX!-Thermostaten) und andere Dinge funktionieren.
          Hab die Temperatur-Role mal auf "level.temperature" umgestellt.
          Wird allerdings trotzdem in der App nicht angezeit …
          • dslraser
            @Kueppert:
            Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk ` die habe ich im ioBoker bei den Aufzählungen eingefügt
              A Former User last edited by
              @dslraser:
              Fensterkontakt
                "type": "state",
                "common": {
                  "def": "CLOSED",
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": "CLOSED",
                  "max": "OPEN",
                  "states": {
                    "0": "CLOSED",
                    "1": "OPEN"
                  "role": "state",
                "native": {
                  "MIN": "CLOSED",
                  "UNIT": "",
                  "OPERATIONS": 5,
                  "MAX": "OPEN",
                  "FLAGS": 1,
                  "ID": "STATE",
                  "TAB_ORDER": 0,
                  "TYPE": "ENUM",
                  "VALUE_LIST": [
                    "CLOSED",
                    "OPEN"
                "acl": {
                  "object": 1636,
                  "state": 1636,
              Fensterdrehgriff
                "type": "state",
                "common": {
                  "def": "CLOSED",
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": "CLOSED",
                  "max": "OPEN",
                  "states": {
                    "0": "CLOSED",
                    "1": "TILTED",
                    "2": "OPEN"
                  "role": "state",
                "native": {
                  "MIN": "CLOSED",
                  "OPERATIONS": 5,
                  "MAX": "OPEN",
                  "FLAGS": 1,
                  "ID": "STATE",
                  "TYPE": "ENUM",
                  "VALUE_LIST": [
                    "CLOSED",
                    "TILTED",
                    "OPEN"
                "acl": {
                  "object": 1636,
                  "state": 1636,
              Die States sind vom Typ NUMBER.
              Das passt nicht zu den Angaben von Min, Max und Def. Alle sind als String angegeben.
              Auch die VALUE_LIST passt nicht zum Typ NUMBER.
              Bitte dazu einen Issue beim Adapter "hm-rpc" aufmachen, bzw mal hier im Forum nachforschen.
              • dslraser
                danke für Deine Erklärung, aber leider weiß ich nicht wie die sein sollten ?
                Bzw. was soll ich denn forschen ?
                Es funktioniert ja alles wie es soll, nur für Deine App leider nicht. (auch TinyMatic zeigt alles korrekt)
                  @dslraser:
                  Es funktioniert ja alles wie es soll, nur für Deine App leider nicht. (auch TinyMatic zeigt alles korrekt) `
                  Die Angabe Type=NUMBER und gleichzeitig MIN/MAX/DEF als String anzugeben macht keinen Sinn.
                  Keine Ahnung wie das an anderen Stellen interpretiert wird.
                  Wenn mir jemand erklären kann wie das zu interpretieren ist (z.b. Verweis auf Doku) dann versuche ich es anzupassen.
                  Bis dahin ist das für mich eine Art von sowas wie "Datenschrott".
                    @rudiraz:
                    Grüße `
                    Poste mal bitte den RAW eines der Loxone States
                    • dslraser
                      @nisio:
                      @dslraser:
                      Bis dahin ist das für mich eine Art von sowas wie "Datenschrott". ` Vielleicht ist eine Erklärung zum Type Numer….?
                      Die Drehgriffe kennen drei Zustände
                      geschlossen
                      gekippt
                      offen
                      "min": "CLOSED",
                      "max": "OPEN",
                      "states": {
                      "0": "CLOSED",
                      "1": "TILTED",
                      "2": "OPEN"
                      Die einfachen haben zwei Zustände
                      geschlossen
                      offen
                      "min": "CLOSED",
                      "max": "OPEN",
                      "states": {
                      "0": "CLOSED",
                      "1": "OPEN"
                      Also nicht einfach nur true oder false
                        @dslraser:
                        @nisio:
                        @dslraser:
                        geschlossen
                        gekippt
                        offen
                        "min": "CLOSED",
                        "max": "OPEN",
                        "states": {
                        "0": "CLOSED",
                        "1": "TILTED",
                        "2": "OPEN"
                        geschlossen
                        offen
                        "min": "CLOSED",
                        "max": "OPEN",
                        "states": {
                        "0": "CLOSED",
                        "1": "OPEN"
                        Also nicht einfach nur true oder false `
                        Ich meinte eher offizielle ioBroker Doku.
                        Mit Type=NUMBER müsste es so aussehen für ein Fenstergriff:
                          "_id": "javascript.0.windowsample",
                          "type": "state",
                          "common": {
                            "name": "whocares",
                            "role": "sensor.window",
                            "type": "number",
                            "min": 0,
                            "max": 2,
                            "def": 0,
                            "read": true,
                            "write": false,
                            "states": {
                              "0": "CLOSED",
                              "1": "TILTED",
                              "2": "OPEN"
                        • dslraser
                          kannst Du die Schriftgrösse anpassen, oder zweizeilig ?
                          PS: Präsenzmelder haben nicht das Symbol (das Männchen). Kommt das Symbol von der App, oder von ioBroker ?
                          ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 003e1b.jpg">https://uploads.tapatalk-cdn.com/20181112/91e84e41dfdfcc602bd87580e8003e1b.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 10567b.jpg">https://uploads.tapatalk-cdn.com/20181112/a60ae9d1c5443cbd9497ed5d6d10567b.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... d67906.jpg">https://uploads.tapatalk-cdn.com/20181112/dd32132a66b32304b76388f01ad67906.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 06dca1.jpg">https://uploads.tapatalk-cdn.com/20181112/f602f75b041b0be9ef3feec04a06dca1.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 93ba6e.jpg">https://uploads.tapatalk-cdn.com/20181112/e6c25283fbdbe7438778cab9cc93ba6e.jpg</link_text>" />~~~~~~~~
                            Schriftgröße ist schon als Wunsch bekannt.
                            https://github.com/nisiode/ioGo/issues/15
                            Welches Smartphone nutzt du?
                            Die Icon kommen von der App.
                            Anhand der common.role Angaben werden die angezeigt.
                            Was haben die Präsenzmelder als common.role?
                            • dslraser
                              @nisio:
                              Was haben die Präsenzmelder als common.role? `
                              ich nutze ein Note8
                              bei den Präsenzmeldern war keine role gesetzt, habe ich jetzt gemacht.
                              Nun ist das Männchen da.
                              Welche role sollte der Datenpunkt für die Helligkeit (Lux Wert) bei den Bewegungsmeldern haben damit ein Symbol angezeigt wird ?
                                @dslraser:
                                @nisio:
                                ich nutze ein Note8
                                Welche role sollte der Datenpunkt für die Helligkeit (Lux Wert) bei den Bewegungsmeldern haben damit ein Symbol angezeigt wird ? ` value.brightness
                                • dslraser
                                  so, bis auf meine Fensterkontakte und die Schriftgröße (oder die Möglichkeit die Geräte um zu benennen und zu sortieren) gefällt es mir super.
                                  anbei die von mir verwendeten Icon in weiss )![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 83c675.jpg">https://uploads.tapatalk-cdn.com/20181112/41dc68462076c1d9095d5200ef83c675.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 0f9eac.jpg">https://uploads.tapatalk-cdn.com/20181112/54622a0c6d3e51c151c50b51d60f9eac.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... d27a92.jpg">https://uploads.tapatalk-cdn.com/20181112/39cb4eb8c8fcf6154d7a9a5065d27a92.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 955813.jpg">https://uploads.tapatalk-cdn.com/20181112/819b7659ec30c7ed2269976a13955813.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 93203e.jpg">https://uploads.tapatalk-cdn.com/20181112/4bf86cc02e577da8df1cf1e30a93203e.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 9a8dd5.jpg">https://uploads.tapatalk-cdn.com/20181112/e0062af58522a428e080c138629a8dd5.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... db996d.jpg">https://uploads.tapatalk-cdn.com/20181112/7d174710666ac882c028d6decadb996d.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 772106.jpg">https://uploads.tapatalk-cdn.com/20181112/47def036a653f2a240a09e8290772106.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 08a28c.jpg">https://uploads.tapatalk-cdn.com/20181112/a7330b1ada960f10a61bed36c408a28c.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 41281a.jpg">https://uploads.tapatalk-cdn.com/20181112/f564d8abdb4c653d7c9c3fef0641281a.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 83a260.jpg">https://uploads.tapatalk-cdn.com/20181112/35e2546030af9d420c0097a61883a260.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... b7254d.jpg">https://uploads.tapatalk-cdn.com/20181112/440f3ceaf5e4dadbf6f37a9436b7254d.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... eb678a.jpg">https://uploads.tapatalk-cdn.com/20181112/9b3a740656244cee3ff494aae1eb678a.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 941cbb.jpg">https://uploads.tapatalk-cdn.com/20181112/84284d64c26c6a64c1f167250f941cbb.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 5a66dd.jpg">https://uploads.tapatalk-cdn.com/20181112/517a7041501f1b116ef31c77a75a66dd.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 28afdd.jpg">https://uploads.tapatalk-cdn.com/20181112/4cb3cc155d8e61023a0a6ad15228afdd.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... fecbb7.jpg">https://uploads.tapatalk-cdn.com/20181112/aed272f1d6b0f0581b1a0edfcbfecbb7.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 402743.jpg">https://uploads.tapatalk-cdn.com/20181112/de514befa0f8258111f5ed3cc0402743.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 9b1dc1.jpg">https://uploads.tapatalk-cdn.com/20181112/df0c0e410f3200e677346e7f2e9b1dc1.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... e26a67.jpg">https://uploads.tapatalk-cdn.com/20181112/042defc9453c9b6b294a51fd20e26a67.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 197797.jpg">https://uploads.tapatalk-cdn.com/20181112/675c02eac77e4196f3ffa31dfd197797.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 914523.jpg">https://uploads.tapatalk-cdn.com/20181112/b1f96f8c1d2add72f2329a4bdf914523.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 2fa65b.jpg">https://uploads.tapatalk-cdn.com/20181112/2ddfcdb97112ef01c278acec582fa65b.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 401845.jpg">https://uploads.tapatalk-cdn.com/20181112/8a4374bc26d3ea8fa42cf3f494401845.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 0fe619.jpg">https://uploads.tapatalk-cdn.com/20181112/fb3677db0cb280262ab30919870fe619.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... c7fbc2.jpg">https://uploads.tapatalk-cdn.com/20181112/5cc0e740f7e10967f6a569e11dc7fbc2.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 39ef2d.jpg">https://uploads.tapatalk-cdn.com/20181112/fa4048644ccaab007030ed737539ef2d.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 1bf45a.jpg">https://uploads.tapatalk-cdn.com/20181112/e4bbd89c69eb84aa45623c3df01bf45a.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... fb75c4.jpg">https://uploads.tapatalk-cdn.com/20181112/6b32b56fea0fe863affacf5ba6fb75c4.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... f4ae54.jpg">https://uploads.tapatalk-cdn.com/20181112/a10450370472b2157b0f3f0ce3f4ae54.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 68e2e8.jpg">https://uploads.tapatalk-cdn.com/20181112/5f33e1826b4ef078dbe7cff49668e2e8.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... b520ba.jpg">https://uploads.tapatalk-cdn.com/20181112/14c82c3b2f2fc8b2084a833ab1b520ba.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 3875a1.jpg">https://uploads.tapatalk-cdn.com/20181112/c3028d29af7a04daca0fa1e16b3875a1.jpg</link_text>" />~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    eMd last edited by
                                    Er synct bei mir 13 Räume und 15 Funktionen, aber nichts weiter… Sehe auch unter den jeweiligen Punkten nichts in der app. Mache ich was falsch?
                                    MfG
                                    eMd
                                      @eMd:
                                      filename="Screenshot_2018-11-16-09-14-13-020_de.nisnagel.iogo.png" index="0">~~
                                      MfG
                                      eMd ` Hast du States zu deinen Räumen/Funktionen zugeordnet?
                                        eMd last edited by
                                        Ich denke ja, so sieht meine Liste aus, ich hoffe das reicht dir als Bild 😄
                                        MfG
                                        eMd
                                        • thexbrain
                                          thexbrain last edited by
                                          Meine Icons sind alle schwarz.
                                          Bekommt man die auch irgendwie in weiß?
                                            @thexbrain:
                                            Bekommt man die auch irgendwie in weiß? `
                                            im ernst?
                                            les mal knapp über deinem post:
                                            viewtopic.php?f=36&t=14919&start=420#p192877
                                            android app iogo
                                            61
                                            1140
                                            358742
