    4. Error npm install dateformat
    • 0
      0018 last edited by
      verwende in einen Script "dateformat" und benötige hierzu das dateformatz module.
      Leider bekomme ich bei der Installation folgende Fehlermeldung:
      pi@BrokerPi:/opt/iobroker/node_modules/iobroker.javascript/node_modules $ sudo npm install dateformat
      npm ERR! code ENOLOCAL
      npm ERR! Could not install from "node_modules/dateformat" as it does not contain a package.json file.
      npm ERR!     /root/.npm/_logs/2018-11-13T13_38_26_244Z-debug.log
      Im verweisten Debug-Log steht:
      pi@BrokerPi:/opt/iobroker/node_modules/iobroker.javascript/node_modules $ sudo cat /root/.npm/_logs/2018-11-13T13_38_26_244Z-debug.log
      0 info it worked if it ends with ok
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', 'dateformat' ]
      2 info using npm@6.4.1
      3 info using node@v8.12.0
      4 verbose npm-session ec2ae47108ea1e3e
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 silly fetchPackageMetaData error for dateformat@file:node_modules/dateformat Could not install from "node_modules/dateformat" as it does not contain a package.json file.
      8 timing stage:rollbackFailedOptional Completed in 3ms
      9 timing stage:runTopLevelLifecycles Completed in 967ms
      10 verbose stack Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node_modules/dateformat/package.json'
      11 verbose cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules
      12 verbose Linux 4.14.71-v7+
      13 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "dateformat"
      14 verbose node v8.12.0
      15 verbose npm  v6.4.1
      16 error code ENOLOCAL
      17 error Could not install from "node_modules/dateformat" as it does not contain a package.json file.
      18 verbose exit [ 1, true ]
      Hat jemanden einen Rat woran es scheitert?
        paul53 last edited by
        @0018:
        verwende in einen Script "dateformat" `
        Weshalb verwendest Du nicht die Funktion https://github.com/ioBroker/ioBroker.javascript/blob/master/doc/en/javascript.md#formatdate ?
        NPM-Module für Javascript müssen in der Konfiguration der Javascript-Instanz unter "zusätzliche NPM-Module" eingetragen werden. Sie werden dann automatisch installiert.
        • 0
          0018 last edited by
          Hatte das Script damals hier aus dem Forum, dort war es so implementiert.
          Werde das ganze jetzt auf formatDate umbauen, Danke für den Tipp!
          1.0k
