    4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
      apollon77 last edited by
      Thanks!
      @madd268@hotmail.de:
      Mein Tuya klappt auch endlich….Zertifikat ,manuell in den W-Lan Verbindungen installieren....
      2018-11-12 18:24:08.134 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power3\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"延迟\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":500000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"type\":\"obj\",\"desc\":\"上报的为放大100倍之后的值,即上报56,实际值为0.56度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[]"}
      Bei dem ersten fehlt die Zeile davor mit der productid … hast Du die noch?
        @homecineplexx:
        Adapter Version: 1.0.3
        tuya.0	2018-11-12 21:47:36.111	debug	stateChange tuya.0.07200068dc4f223ec823.6 {"val":2251,"ack":true,"ts":1542055656104,"q":0,"from":"system.adapter.tuya.0","lc":1542055656104}
        tuya.0	2018-11-12 21:47:36.111	debug	stateChange tuya.0.07200068dc4f223ec823.5 {"val":0,"ack":true,"ts":1542055656103,"q":0,"from":"system.adapter.tuya.0","lc":1542054029043}
        tuya.0	2018-11-12 21:47:36.111	debug	stateChange tuya.0.07200068dc4f223ec823.4 {"val":0,"ack":true,"ts":1542055656103,"q":0,"from":"system.adapter.tuya.0","lc":1542054029027}
        tuya.0	2018-11-12 21:47:36.111	debug	stateChange tuya.0.07200068dc4f223ec823.2 {"val":0,"ack":true,"ts":1542055656102,"q":0,"from":"system.adapter.tuya.0","lc":1542054029016}
        tuya.0	2018-11-12 21:47:36.111	debug	stateChange tuya.0.07200068dc4f223ec823.1 {"val":false,"ack":true,"ts":1542055656100,"q":0,"from":"system.adapter.tuya.0","lc":1542054029005}
        tuya.0	2018-11-12 21:47:36.111	debug	stateChange tuya.0.0720006884f3eb84ad80.6 {"val":2260,"ack":true,"ts":1542055656095,"q":0,"from":"system.adapter.tuya.0","lc":1542055656095}
        tuya.0	2018-11-12 21:47:36.111	debug	stateChange tuya.0.0720006884f3eb84ad80.5 {"val":0,"ack":true,"ts":1542055656095,"q":0,"from":"system.adapter.tuya.0","lc":1542054026979}
        tuya.0	2018-11-12 21:47:36.111	debug	stateChange tuya.0.0720006884f3eb84ad80.4 {"val":0,"ack":true,"ts":1542055656093,"q":0,"from":"system.adapter.tuya.0","lc":1542054026964}
        tuya.0	2018-11-12 21:47:36.110	debug	stateChange tuya.0.0720006884f3eb84ad80.2 {"val":0,"ack":true,"ts":1542055656092,"q":0,"from":"system.adapter.tuya.0","lc":1542054026949}
        tuya.0	2018-11-12 21:47:36.110	debug	stateChange tuya.0.0720006884f3eb84ad80.1 {"val":false,"ack":true,"ts":1542055656090,"q":0,"from":"system.adapter.tuya.0","lc":1542054026936}
        tuya.0	2018-11-12 21:47:36.109	debug	07200068dc4f223ec823: Received data: {"1":false,"2":0,"4":0,"5":0,"6":2251}
        tuya.0	2018-11-12 21:47:36.090	debug	0720006884f3eb84ad80: Received data: {"1":false,"2":0,"4":0,"5":0,"6":2260}
        tuya.0	2018-11-12 21:47:16.791	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
        tuya.0	2018-11-12 21:47:16.790	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":55,"ack":false,"time":1542055636781},"_id":62252746}
        tuya.0	2018-11-12 21:46:36.129	debug	stateChange tuya.0.07200068dc4f223ec823.6 {"val":2267,"ack":true,"ts":1542055596116,"q":0,"from":"system.adapter.tuya.0","lc":1542055596116}
        tuya.0	2018-11-12 21:46:36.128	debug	stateChange tuya.0.07200068dc4f223ec823.5 {"val":0,"ack":true,"ts":1542055596115,"q":0,"from":"system.adapter.tuya.0","lc":1542054029043}
        tuya.0	2018-11-12 21:46:36.128	debug	stateChange tuya.0.07200068dc4f223ec823.4 {"val":0,"ack":true,"ts":1542055596114,"q":0,"from":"system.adapter.tuya.0","lc":1542054029027}
        tuya.0	2018-11-12 21:46:36.128	debug	stateChange tuya.0.07200068dc4f223ec823.2 {"val":0,"ack":true,"ts":1542055596112,"q":0,"from":"system.adapter.tuya.0","lc":1542054029016}
        tuya.0	2018-11-12 21:46:36.128	debug	stateChange tuya.0.07200068dc4f223ec823.1 {"val":false,"ack":true,"ts":1542055596110,"q":0,"from":"system.adapter.tuya.0","lc":1542054029005}
        tuya.0	2018-11-12 21:46:36.127	debug	stateChange tuya.0.0720006884f3eb84ad80.6 {"val":2282,"ack":true,"ts":1542055596103,"q":0,"from":"system.adapter.tuya.0","lc":1542055596103}
        tuya.0	2018-11-12 21:46:36.127	debug	stateChange tuya.0.0720006884f3eb84ad80.5 {"val":0,"ack":true,"ts":1542055596102,"q":0,"from":"system.adapter.tuya.0","lc":1542054026979}
        tuya.0	2018-11-12 21:46:36.127	debug	stateChange tuya.0.0720006884f3eb84ad80.4 {"val":0,"ack":true,"ts":1542055596100,"q":0,"from":"system.adapter.tuya.0","lc":1542054026964}
        tuya.0	2018-11-12 21:46:36.127	debug	stateChange tuya.0.0720006884f3eb84ad80.2 {"val":0,"ack":true,"ts":1542055596098,"q":0,"from":"system.adapter.tuya.0","lc":1542054026949}
        tuya.0	2018-11-12 21:46:36.126	debug	stateChange tuya.0.0720006884f3eb84ad80.1 {"val":false,"ack":true,"ts":1542055596096,"q":0,"from":"system.adapter.tuya.0","lc":1542054026936}
        tuya.0	2018-11-12 21:46:36.126	debug	07200068dc4f223ec823: Received data: {"1":false,"2":0,"4":0,"5":0,"6":2267}
        tuya.0	2018-11-12 21:46:36.125	debug	0720006884f3eb84ad80: Received data: {"1":false,"2":0,"4":0,"5":0,"6":2282}
        tuya.0	2018-11-12 21:46:23.791	debug	Message: {"command":"getProxyResult","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":54,"ack":false,"time":1542055583787},"_id":62252745}
        tuya.0	2018-11-12 21:46:23.245	debug	sendTo "startProxy" to system.adapter.admin.0 from system.adapter.tuya.0
        tuya.0	2018-11-12 21:46:23.233	info	Anyproxy ready to receive requests
        tuya.0	2018-11-12 21:46:23.233	debug	init anyproxy rule
        tuya.0	2018-11-12 21:46:23.233	debug	Use first network interface (192.168.1.21)
        tuya.0	2018-11-12 21:46:23.232	debug	Message: {"command":"startProxy","message":{"proxyPort":"8888","proxyWebPort":"8889"},"from":"system.adapter.admin.0","callback":{"message":{"proxyPort":"8888","proxyWebPort":"8889"},"id":53,"ack":fal
        tuya.0	2018-11-12 21:46:16.632	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
        tuya.0	2018-11-12 21:46:16.631	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":52,"ack":false,"time":1542055576622},"_id":62252741}
        Was möchtest DU mit dem Post sagen? Alles ok oder stimmt was nicht?
          homecineplexx last edited by
          @apollon77:
          @homecineplexx:
          Was möchtest DU mit dem Post sagen? Alles ok oder stimmt was nicht? `
          Du hast ja gesagt ich soll dir nochmals alle logs schicken weil es eben nicht geht
            Also in dem log sehe ich das der Adapter Daten empfängt. In deinem proxy Screenshot ist außer dem letzten Eintrag alles andere Dinge als tuya. Das letzte ist ein connect zum tuya Server.
            Also was genau tut nicht und was hast du alles versucht? Geht der Sync nicht? Das Zertifikat ist korrekt im Handy installiert? App mal gekillt und mit aktiviertem Proxy frisch geöffnet? Mal bissl länger gewartet?
            Gesendet vom Handy …
              ja genau…er versucht sich glaub ich zu tuya zu connecten und das wars...da kommt dann nur ein netzwerk-error am handy angezeigt und nix geht.
                @apollon77:
                Gesendet vom Handy … `
                genau der sync funktioniert absolut nicht..ich hab alles gekillt.
                hab sogar tuya nochmals komplett deinstalliert.
                neu installiert.
                dann in der console ein neues zertifikat mit anyproxy-ca ausgestellt.
                im tuya adapter auf start proxy geklickt.
                qr code gescannt, zertifikat runter geladen
                installiert (name: iobroker verbindung: wlan)
                unter meiner wlan verbindung den proxy mit dem port 8888 eingestellt.
                dann smart life geöffnet…..und das wars....da kommt dann der fehler, von weiter oben, den ich dir schon mal gepostet habe
                smart life gekillt
                tuya geschlossen, reloaded, geöffnet.....keine veränderung
                host.raspberrypi	2018-11-10 20:06:40.194	info	Restart adapter system.adapter.tuya.0 because enabled
                host.raspberrypi	2018-11-10 20:06:40.194	error	instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
                host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: at TCP.onStreamRead (internal/stream_base_commons.js:111:27)
                host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: Error: read ECONNRESET
                host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: 1<process.argv.length?process.argv[1].replace( \\/g,"/"):"unknown-program");b.arguments="process.argv.slice(2);&quot;undefined&quot;!==typeof" module&&(module.exports="b);process.on(&quot;uncau" host.raspberrypi/2018-11-10/20:06:40.194/error/caught/by/controller[2]:/opt/iobroker/node_modules/brotli/build/encode.js:3/20:06:40.193/controller[1]:/at/tcp.onstreamread/(internal/stream_base_commons.js:111:27)/errno:/'econnreset',/code:/syscall:/'read'/}/{/error:/read/econnreset/<e=""></process.argv.length?process.argv[1].replace(>
                  neues Zertifikat? Und du bist sicher das dein Handy jetzt das aktuelle und korrekte Zertifikat hat? Weil wenn das nicht passt kommen ggf Fehler.
                  Welche Fehler genau sagt denn die App oder Dein Handy?
                  Bei vielen anderen tut es … ich kann Dir nicht sagen was bei Dir anders ist ... 😞
                    madd268hotmail.de last edited by
                    Bei meinem Phone habe ich die Einstellungen gemacht und unten rechts gibts einen Schalter mit "mehr" dort rein und da gibts Zertifikat installieren.Dort so machen wie beschrieben und schon klappt es auch mit dem Sync
                      @apollon77:
                      Thanks!
                      Bei dem ersten fehlt die Zeile davor mit der productid … hast Du die noch? `
                      2018-11-12 18:31:48.025 - info: tuya.0 new Shema added for product type HPiNfakVX1Z9hWsO. Please send next line from logfile on disk to developer!
                        @apollon77:
                        Bei vielen anderen tut es … ich kann Dir nicht sagen was bei Dir anders ist ... 😞 `
                        Handy hat zumindest gesagt dass das neue Zertifikat installiert wurde. Sobald ich mit den Proxy Einstellungen die Smart Life app öffne bekomme ich einen Netzwerkfehler.
                        Ich werde alles mal deinstallieren und neu installieren und schauen ob es einen error gibt.
                        Sollte ich den anyproxy mit npm I anyproxy - G auch installieren? (sudo)?
                          Genauer Fehler bitte.
                          Anyproxy global … ja kannst du, hilft aber nix weil der adapter das nicht nutzt weil seinen eigenen mitbringt.
                          Gesendet vom Handy ...
                            das ist normal beim installieren vom adapter?
                            $ ./iobroker url "https://github.com/Apollon77/ioBroker.tuya"
                            install https://github.com/Apollon77/ioBroker.tuya/tarball/master
                            npm install https://github.com/Apollon77/ioBroker.tuya/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                            npm
                             WARN deprecated clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
                            npm WARN deprecated bcrypt@1.0.3: bcrypt < v2.0.0 is susceptible to bcrypt wrap-around bug. Upgrade to bcrypt >= v2.0.0 for improved support for newer bcrypt hashes
                            node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v64-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.3 and node@10.10.0 (node-v64 ABI) (falling back to source compile with node-gyp)
                            node-pre-gyp ERR! Tried to download(undefined): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v64-linux-arm.tar.gz
                            rm: das Entfernen von './Release/.deps/Release/obj.target/bcrypt_lib/src/blowfish.o.d.raw' ist nicht möglich
                            : Datei oder Verzeichnis nicht gefunden
                            make: *** [Release/obj.target/bcrypt_lib/src/blowfish.o] Fehler 1
                            gyp
                             ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
                            gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                            gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
                            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
                            gyp ERR! System Linux 4.14.71-v7+
                            gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding"
                            gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt
                            gyp ERR! node -v v10.10.0
                            gyp ERR! node-gyp -v v3.8.0
                            gyp ERR! not ok
                            node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding' (1)
                            node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                            node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
                            node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:962:16)
                            node-pre-gyp
                            ERR! stack
                                 at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
                            node-pre-gyp ERR! System Linux 4.14.71-v7+
                            node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt
                            node-pre-gyp ERR! node -v v10.10.0node-pre-gyp ERR! node-pre-gyp -v v0.6.36
                            node-pre-gyp ERR! not ok
                            ../src/bcrypt.cc:322:1: fatal error: opening dependency file ./Release/.deps/Release/obj.target/bcrypt_lib/src/bcrypt.o.d.raw: Datei oder Verzeichnis nicht gefunden }
                            compilation terminated.
                            make: *** [Release/obj.target/bcrypt_lib/src/bcrypt.o] Fehler 1
                            gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
                            gyp ERR!
                            stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
                            gyp ERR! not ok
                            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/alexa-cookie/package.json'npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
                            npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
                            npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
                            npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@1.0.3 (node_modules/node-red/node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@1.0.3 install: `node-pre-gyp install --fallback-to-build`
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                            process exited with code 0</anonymous>
                              @apollon77:
                              Gesendet vom Handy ... `
                              genauer kann ichs nicht sagen, denn das ist ein kleines fenster am handy, welches sagt netzwerkfehler
                                @homecineplexx:
                                npm
                                gyp
                                gyp ERR! not ok
                                node-pre-gyp
                                ERR! stack
                                gyp ERR!
                                gyp ERR! not ok
                                Hm … Versuch mal mit sudo. Der bcrypt Fehler ist an sich optional ...
                                Ich habe es unter node 10 noch nicht genutzt ... daher kann ich nicht sagen ob es vllt daran liegt .... hm ....
                                  @apollon77:
                                  @homecineplexx:
                                  npm
                                  gyp
                                  gyp ERR! not ok
                                  node-pre-gyp
                                  ERR! stack
                                  gyp ERR!
                                  gyp ERR! not ok
                                  selbst problem
                                    Genug ram ist auch frei auch dem iobroker Host? Der Proxy braucht wohl eeeeeecht viel ram.
                                    Dann hab ich keine Idee mehr.
                                      @apollon77:
                                      180Mb sind frei….
                                      • Elzershark
                                        Elzershark last edited by
                                        Liegt an Node 10. Zu hoch.
                                        6.* oder 8.* Node installieren.
                                        Alles lesen was da steht ab" Node installieren.."
                                        http://www.iobroker.net/docu/?page_id=5106&lang=de
                                          Vermutung oder wissen? Was genau macht mit node 10 Probleme?
                                            @Elzershark:
                                            http://www.iobroker.net/docu/?page_id=5106&lang=de `
                                            kann ich zurücksteigen auf eine 8er?
                                            31.7k
                                            79.9k
                                            547
                                            149381
