    4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
      apollon77 last edited by
      Genauer Fehler bitte.
      Anyproxy global … ja kannst du, hilft aber nix weil der adapter das nicht nutzt weil seinen eigenen mitbringt.
      Gesendet vom Handy ...
        homecineplexx last edited by
        das ist normal beim installieren vom adapter?
        $ ./iobroker url "https://github.com/Apollon77/ioBroker.tuya"
        install https://github.com/Apollon77/ioBroker.tuya/tarball/master
        npm install https://github.com/Apollon77/ioBroker.tuya/tarball/master --production --save --prefix "/opt/iobroker" (System call)
        npm
         WARN deprecated clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
        npm WARN deprecated bcrypt@1.0.3: bcrypt < v2.0.0 is susceptible to bcrypt wrap-around bug. Upgrade to bcrypt >= v2.0.0 for improved support for newer bcrypt hashes
        node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v64-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.3 and node@10.10.0 (node-v64 ABI) (falling back to source compile with node-gyp)
        node-pre-gyp ERR! Tried to download(undefined): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v64-linux-arm.tar.gz
        rm: das Entfernen von './Release/.deps/Release/obj.target/bcrypt_lib/src/blowfish.o.d.raw' ist nicht möglich
        : Datei oder Verzeichnis nicht gefunden
        make: *** [Release/obj.target/bcrypt_lib/src/blowfish.o] Fehler 1
        gyp
         ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
        gyp ERR! System Linux 4.14.71-v7+
        gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding"
        gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt
        gyp ERR! node -v v10.10.0
        gyp ERR! node-gyp -v v3.8.0
        gyp ERR! not ok
        node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding' (1)
        node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:962:16)
        node-pre-gyp
        ERR! stack
             at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
        node-pre-gyp ERR! System Linux 4.14.71-v7+
        node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt
        node-pre-gyp ERR! node -v v10.10.0node-pre-gyp ERR! node-pre-gyp -v v0.6.36
        node-pre-gyp ERR! not ok
        ../src/bcrypt.cc:322:1: fatal error: opening dependency file ./Release/.deps/Release/obj.target/bcrypt_lib/src/bcrypt.o.d.raw: Datei oder Verzeichnis nicht gefunden }
        compilation terminated.
        make: *** [Release/obj.target/bcrypt_lib/src/bcrypt.o] Fehler 1
        gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR!
        stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
        gyp ERR! not ok
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/alexa-cookie/package.json'npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
        npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
        npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@1.0.3 (node_modules/node-red/node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@1.0.3 install: `node-pre-gyp install --fallback-to-build`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        process exited with code 0</anonymous>
          @apollon77:
          Gesendet vom Handy ... `
          genauer kann ichs nicht sagen, denn das ist ein kleines fenster am handy, welches sagt netzwerkfehler
            @homecineplexx:
            npm
            gyp
            gyp ERR! not ok
            node-pre-gyp
            ERR! stack
            gyp ERR!
            gyp ERR! not ok
            Hm … Versuch mal mit sudo. Der bcrypt Fehler ist an sich optional ...
            Ich habe es unter node 10 noch nicht genutzt ... daher kann ich nicht sagen ob es vllt daran liegt .... hm ....
              @apollon77:
              @homecineplexx:
              npm
              gyp
              gyp ERR! not ok
              node-pre-gyp
              ERR! stack
              gyp ERR!
              gyp ERR! not ok
              selbst problem
                Genug ram ist auch frei auch dem iobroker Host? Der Proxy braucht wohl eeeeeecht viel ram.
                Dann hab ich keine Idee mehr.
                Gesendet vom Handy …
                  @apollon77:
                  Gesendet vom Handy … `
                  180Mb sind frei….
                  • Elzershark
                    Elzershark last edited by
                    Liegt an Node 10. Zu hoch.
                    6.* oder 8.* Node installieren.
                    Alles lesen was da steht ab" Node installieren.."
                    http://www.iobroker.net/docu/?page_id=5106&lang=de
                      Vermutung oder wissen? Was genau macht mit node 10 Probleme?
                        @Elzershark:
                        http://www.iobroker.net/docu/?page_id=5106&lang=de `
                        kann ich zurücksteigen auf eine 8er?
                        • Elzershark
                          Halbwissen, Wissen, Vermutung.. Alles von allem..
                          Frage.. Wie kommt man an Node 10?
                          Upgrade? Danach auch alle Adapter neu geladen? auf Node 10 alle Adapter eingerichtet?
                          Das machen/wissen die wenigsten und nichts geht mehr.
                          Daher kann man fast nicht sagen ob es mit Node 10 geht oder nicht.
                          Außer man "weiß" wie man auf Node 10 ioBroker richtig installiert und dann Testet..
                          Dann fängt aber alles wieder wie oben an-.. xD
                            thor1967 last edited by
                            @sigi234:
                            geht auch ohne der Windows App…..
                            Screenshot (1168)_LI.jpg `
                            und wie?
                            Jörg
                              @Elzershark:
                              Dann fängt aber alles wieder wie oben an-.. xD `
                              Funktioniert bei mir nun auch nicht mit der 8er Version. Selber Fehler 😞
                                @thor1967:
                                @sigi234:
                                und wie?
                                Jörg `
                                https://github.com/Apollon77/ioBroker.t … r/PROXY.md
                                  madd268hotmail.de last edited by
                                  <code>tuya.0 new Shema added for product type HPiNfakVX1Z9hWsO. Please send next line from logfile on disk to developer!
                                  2018-11-14 21:43:04.500 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power3\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"延迟\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":500000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"type\":\"obj\",\"desc\":\"上报的为放大100倍之后的值,即上报56,实际值为0.56度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[]"}
                                  2018-11-14 21:43:04.501 - info: tuya.0 new Shema added for product type n8iVBAPLFKAAAszH. Please send next line from logfile on disk to developer!
                                  2018-11-14 21:43:04.501 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time\",\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"}]","schemaExt":"[{\"id\":2,\"inputType\":\"\"}]"}
                                  2018-11-14 21:43:04.502 - info: tuya.0 new Shema added for product type ocNB89IgPygEpdnE. Please send next line from logfile on disk to developer!
                                  2018-11-14 21:43:04.502 - info: tuya.0 {"schema":"[{\"mode\":\"ro\",\"code\":\"switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\",\"desc\":\"上报门窗开关状态\"},{\"mode\":\"ro\",\"code\":\"TamperedAlarm\",\"name\":\"防拆报警\",\"property\":{\"type\":\"bool\"},\"id\":102,\"type\":\"obj\",\"desc\":\"mcu 上报拆除信息\"},{\"mode\":\"ro\",\"code\":\"Battery\",\"name\":\"电池电量\",\"property\":{\"unit\":\"%\",\"min\":0,\"max\":100,\"scale\":0,\"step\":10,\"type\":\"value\"},\"id\":103,\"type\":\"obj\",\"desc\":\"mcu 上报电池电量信息\"},{\"mode\":\"ro\",\"code\":\"state\",\"name\":\"状态\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\",\"desc\":\"上报产品是“休眠”还是“离线”\"}]","schemaExt":"[]"}
                                  2018-11-14 21:43:04.502 - info: tuya.0 new Shema added for product type PUyaDrOGMhJfCExd. Please send next line from logfile on disk to developer!
                                  2018-11-14 21:43:04.503 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"增加电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"trigger\":\"direct\",\"type\":\"obj\",\"desc\":\"上报的为放大1000倍之后的值,即上报56,实际值为0.056度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"当前电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[{\"id\":2,\"inputType\":\"\"},{\"id\":3,\"inputType\":\"\"},{\"id\":4,\"inputType\":\"\"},{\"id\":5,\"inputType\":\"\"},{\"id\":6,\"inputType\":\"\"}]"}</code>
                                    RKBroker last edited by
                                    Mal wieder etwas neues:
                                    <code>2018-11-15 23:56:34.240  - [32minfo[39m: tuya.0 new Shema added for product type r15JnoGqWPM4PPtl. Please send next line from logfile on disk to developer!
                                    2018-11-15 23:56:34.240  - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_1\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time2\",\"id\":11,\"type\":\"obj\",\"desc\":\"可根据产品实际倒计时功能修改。\"}]","schemaExt":"[]"}[/code]</code>
                                      rewenode last edited by
                                      und noch einer:
                                      3fach Steckdosenleiste mit 4er USB
                                      https://de.aliexpress.com/item/Smart-Wi … 4c4djD7d7L
                                      <code>2018-11-16 00:28:39.644 - info: tuya.0 new Shema added for product type JtCDjzmKcUNKEBzO. Please send next line from logfile on disk to developer!
                                      2018-11-16 00:28:39.645 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_s1\",\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_s2\",\"name\":\"开关 2\",\"property\":{\"type\":\"bool\"},\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_s3\",\"name\":\"开关 3\",\"property\":{\"type\":\"bool\"},\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_usb1\",\"name\":\"USB\",\"property\":{\"type\":\"bool\"},\"id\":4,\"type\":\"obj\",\"desc\":\"switch_s4修改为switch_usb1\"}]","schemaExt":"[]"}[/code]</code>
                                        Danke, sind jetzt alle in der 1.0.4 drin.
                                          Hallo Apollon77,
                                          Nächste Woche bekomme ich wieder ein Spielzeug für die Weihnachtsbeleuchtung…...
                                          Ich hoffe sie funktioniert mit deinen Adapter. 🙂
                                          Heute bekommen, Funktioniert!
                                            Gute Chancen 😉
                                            31.7k
                                            79.9k
                                            547
                                            149380
