    4. [Aufruf] Xbox Adapter testen
    • Negalein
      @foxriver76:
      Probier mal bitte
      npm i iobroker.xbox --unsafe-perm --prefix C:\ioBroker
      irgendwie stöbert er da bei dir in den falschen Verzeichnissen rum und prefix ist genau dafür da, nämlich das Verzeichnis zu setzen in dem installiert werden soll, wenn hinter prefix nix steht, kann er damit nix anfangen. `
      Geht leider auch nicht! 😞
      C:\ioBroker>npm i iobroker.xbox --unsafe-perm --prefix C:\ioBroker
      npm ERR! path C:\ioBroker\node_modules\.iobroker.xbox.DELETE\python_modules\Python36\site-packages\_cffi_backend.cp36-win_amd64.pyd
      npm ERR! code EPERM
      npm ERR! errno -4048
      npm ERR! syscall unlink
      npm ERR! Error: EPERM: operation not permitted, unlink 'C:\ioBroker\node_modules\.iobroker.xbox.DELETE\python_modules\Python36\site-packages\_cffi_backend.cp36-win_amd64.pyd'
      npm ERR!  { [Error: EPERM: operation not permitted, unlink 'C:\ioBroker\node_modules\.iobroker.xbox.DELETE\python_modules\Python36\site-packages\_cffi_backend.cp36-win_amd64.pyd']
      npm ERR!   cause:
      npm ERR!    { Error: EPERM: operation not permitted, unlink 'C:\ioBroker\node_modules\.iobroker.xbox.DELETE\python_modules\Python36\site-packages\_cffi_backend.cp36-win_amd64.pyd'
      npm ERR!      errno: -4048,
      npm ERR!      code: 'EPERM',
      npm ERR!      syscall: 'unlink',
      npm ERR!      path:
      npm ERR!       'C:\\ioBroker\\node_modules\\.iobroker.xbox.DELETE\\python_modules\\Python36\\site-packages\\_cffi_backend.cp36-win_amd64.pyd' },
      npm ERR!   stack:
      npm ERR!    "Error: EPERM: operation not permitted, unlink 'C:\\ioBroker\\node_modules\\.iobroker.xbox.DELETE\\python_modules\\Python36\\site-packages\\_cffi_backend.cp36-win_amd64.pyd'",
      npm ERR!   path:
      npm ERR!    'C:\\ioBroker\\node_modules\\.iobroker.xbox.DELETE\\python_modules\\Python36\\site-packages\\_cffi_backend.cp36-win_amd64.pyd',
      npm ERR!   parent: 'iobroker.inst' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It's possible that the file was already in use (by a text editor or antivirus),
      npm ERR! or that you lack permissions to access it.
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR!     C:\Users\chris\AppData\Roaming\npm-cache\_logs\2018-11-13T22_06_00_570Z-debug.log
      C:\ioBroker>npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --production --save --prefix C:\ioBroker
      npm ERR! code EPERM
      npm ERR!   cause:
      npm ERR!      path:
      npm ERR!   stack:
      npm ERR!   path:
      npm ERR!
      npm ERR!
      npm ERR!     C:\Users\chris\AppData\Roaming\npm-cache\_logs\2018-11-13T22_13_07_912Z-debug.log
      • Negalein
        @DKM:
        npm ERR! path C:\ioBroker\node_modules.iobroker.xbox.DELETE\python_modules\Python36\site-packages_cffi_backend.cp36-win_amd64.py
        Will er da bei der Installation nicht löschen? Evtl. sind auch bei Dir Ordner vorhanden, die das Installationsskript nicht löschen kann. `
        Welche Ordner wären das?
        Kann ich die händisch löschen?
          DKM last edited by
          Schau mal im Ordner C:\iobroker\node-modules nach Ordnern die Xbox enthalten.
          Ich vermute, dass durch unsere Installierei Ordnerreste überbleiben. Warte aber sicherheitshalber noch auf die Antwort von foxriver.
          Gesendet von meinem SM-G960F mit Tapatalk
          • Negalein
            @DKM:
            Ich vermute, dass durch unsere Installierei Ordnerreste überbleiben. Warte aber sicherheitshalber noch auf die Antwort von foxriver. `
            Ja, da gibt es 1 Ordner!
            • foxriver76
              @Negalein:
              @DKM:
              Kann ich die händisch löschen? `
              Was gibt denn````
              npm -v
              • Negalein
                @foxriver76:
                [Was gibt denn ~~[code]~~npm -v bei dir? `
                6.4.1
                • foxriver76
                  Führst du die cmd als Admin aus?
                  • Negalein
                    @foxriver76:
                    Führst du die cmd als Admin aus? `
                    Ja
                    • foxriver76
                      Hm dann möchte man fast meinen, dass da irgendwas die Datei in C:\ioBroker\node_modules.iobroker.xbox.DELETE schon nutzt und es deshalb einen Permission error gibt. Wenn du ioB stoppst und es probierst geht es dann? Bzw ist der Ordner existent: C:\ioBroker\node_modules.iobroker.xbox.DELETE weiß nicht ob Windows standardmäßig Ordner mit . Vorne dran anzeigt.
                        DKM last edited by
                        @foxriver76:
                        Hm dann möchte man fast meinen, dass da irgendwas die Datei in C:\ioBroker\node_modules.iobroker.xbox.DELETE schon nutzt und es deshalb einen Permission error gibt. Wenn du ioB stoppst und es probierst geht es dann? Bzw ist der Ordner existent: C:\ioBroker\node_modules.iobroker.xbox.DELETE weiß nicht ob Windows standardmäßig Ordner mit . Vorne dran anzeigt. ` Nein eigentlich ist das eine reine Unix Sache mit dem Punkt. Mir sind nur Sicherungen bekannt, die das auch nutzen
                        • Negalein
                          Ja, der Ordner ".iobroker.xbox.DELETE" scheint genau so auf!
                          Im Ordner sind dann noch:
                          • foxriver76
                            Dann lösch den Ordner mal bitte, dann wird er dir sagen, falls da was in Nutzung ist.
                            • Negalein
                              @foxriver76:
                              Dann lösch den Ordner mal bitte, dann wird er dir sagen, falls da was in Nutzung ist. `
                              Verzeichnis hab ich gelöscht und dann alles nochmal lt. DKM installiert.
                              Dürfte geklappt haben.
                              ABER jetzt komm ich nicht mehr in die Adminoberfläche.
                              Er lädt und lädt und …!
                              iobroker start
                              iobroker stop
                              iobroker restart
                              Hab ich alles schon probiert. Dienst läuft.
                              In den VIS-Editor komm ich ohne Probleme und kann auch die VIS starten.
                              • foxriver76
                                Admin lässt sich mit````
                                iobroker start admin
                                • Negalein
                                  @foxriver76:
                                  Admin lässt sich mitiobroker start adminstarten `
                                  funktioniert auch noch nicht
                                  • foxriver76
                                    Ja die Oberfläche ist da, du bekommst jedoch nur diesen bunten Ladekreis zu sehen?
                                    Und mal ne Frage an euch beiden Win-User. Wird bei euch das Unload Event korrekt ausgeführt, also loggt der Adapter am Ende Rest-Server stopped oder nen Error, dass er ihn nicht stoppen kann. Oder auch in anderen Adaptern wird am Ende häufig was geloggt im Unload und bei meiner Windows Installation, wird da nix ausgeführt.
                                      DKM last edited by
                                      @Negalein
                                      Versuch mal in der Konsole
                                      iobroker add admin –port 8089
                                      Dann versuch ob du mit
                                      http://deineIP:8089 auf die Oberfläche kommst.
                                      @foxriver
                                      Es kommt nur der Start, aber keine Nachricht über das beenden. Kann dir gerade kein Log schicken, da ich noch unterwegs bin.
                                      • Negalein
                                        @foxriver76:
                                        Ja die Oberfläche ist da, du bekommst jedoch nur diesen bunten Ladekreis zu sehen? `
                                        Nein, ich komm garnicht auf die Adminoberfläche.
                                        • foxriver76
                                          @DKM:
                                          @foxriver
                                          Gesendet von meinem SM-G960F mit Tapatalk `
                                          Also ich habe jetzt noch was geaddet, damit sollte der Rest-Server (Python Prozess) beim stoppen des Adapters auch unter Windows erfolgreich beendet werden. Jedoch nur wenn das "Unload" Event auch korrekt getriggert wird. Das Event wird vom js-controller aus gesendet, also liegt nicht im Einflussbereich des Adapters, da ich eben unter Win auch bei anderen Adaptern kein Unload erhalte.
                                          • Negalein
                                            es funktioniert 😄
                                            31.7k
                                            79.8k
                                            adapter xbox
                                            13
                                            205
                                            28599
