[Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
das ist normal beim installieren vom adapter?
$ ./iobroker url "https://github.com/Apollon77/ioBroker.tuya" install https://github.com/Apollon77/ioBroker.tuya/tarball/master npm install https://github.com/Apollon77/ioBroker.tuya/tarball/master --production --save --prefix "/opt/iobroker" (System call) npm WARN deprecated clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill npm WARN deprecated bcrypt@1.0.3: bcrypt < v2.0.0 is susceptible to bcrypt wrap-around bug. Upgrade to bcrypt >= v2.0.0 for improved support for newer bcrypt hashes node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v64-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.3 and node@10.10.0 (node-v64 ABI) (falling back to source compile with node-gyp) node-pre-gyp ERR! Tried to download(undefined): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v64-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.3 and node@10.10.0 (node-v64 ABI) (falling back to source compile with node-gyp) rm: das Entfernen von './Release/.deps/Release/obj.target/bcrypt_lib/src/blowfish.o.d.raw' ist nicht möglich : Datei oder Verzeichnis nicht gefunden make: *** [Release/obj.target/bcrypt_lib/src/blowfish.o] Fehler 1 gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23) gyp ERR! stack at ChildProcess.emit (events.js:182:13) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12) gyp ERR! System Linux 4.14.71-v7+ gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding" gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt gyp ERR! node -v v10.10.0 gyp ERR! node-gyp -v v3.8.0 gyp ERR! not ok node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding' (1) node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29) node-pre-gyp ERR! stack at ChildProcess.emit (events.js:182:13) node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:962:16) node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5) node-pre-gyp ERR! System Linux 4.14.71-v7+ node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt node-pre-gyp ERR! node -v v10.10.0node-pre-gyp ERR! node-pre-gyp -v v0.6.36 node-pre-gyp ERR! not ok ../src/bcrypt.cc:322:1: fatal error: opening dependency file ./Release/.deps/Release/obj.target/bcrypt_lib/src/bcrypt.o.d.raw: Datei oder Verzeichnis nicht gefunden } ^ compilation terminated. make: *** [Release/obj.target/bcrypt_lib/src/bcrypt.o] Fehler 1 gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack at ChildProcess.emit (events.js:182:13) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12) gyp ERR! System Linux 4.14.71-v7+ gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding" gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt gyp ERR! node -v v10.10.0 gyp ERR! node-gyp -v v3.8.0 gyp ERR! not ok npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/alexa-cookie/package.json'npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself. npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself. npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself. npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself. npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself. npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself. npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@1.0.3 (node_modules/node-red/node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@1.0.3 install: `node-pre-gyp install --fallback-to-build` npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1 process exited with code 0</anonymous> ```` `
Hm … Versuch mal mit sudo. Der bcrypt Fehler ist an sich optional ...
Ich habe es unter node 10 noch nicht genutzt ... daher kann ich nicht sagen ob es vllt daran liegt .... hm ....
Gesendet vom Handy ... `
selbst problem
Genug ram ist auch frei auch dem iobroker Host? Der Proxy braucht wohl eeeeeecht viel ram.
Dann hab ich keine Idee mehr.
Gesendet vom Handy …
Gesendet vom Handy … `
180Mb sind frei….
Liegt an Node 10. Zu hoch.
6.* oder 8.* Node installieren.
Alles lesen was da steht ab" Node installieren.."
Vermutung oder wissen? Was genau macht mit node 10 Probleme?
kann ich zurücksteigen auf eine 8er?
Halbwissen, Wissen, Vermutung.. Alles von allem..
Frage.. Wie kommt man an Node 10?
Upgrade? Danach auch alle Adapter neu geladen? auf Node 10 alle Adapter eingerichtet?
Das machen/wissen die wenigsten und nichts geht mehr.
Daher kann man fast nicht sagen ob es mit Node 10 geht oder nicht.
Außer man "weiß" wie man auf Node 10 ioBroker richtig installiert und dann Testet..
Dann fängt aber alles wieder wie oben an-.. xD
Dann fängt aber alles wieder wie oben an-.. xD `
Funktioniert bei mir nun auch nicht mit der 8er Version. Selber Fehler -
geht auch ohne der Windows App…..
Screenshot (1168)_LI.jpg `
und wie?
Jörg `
<code>tuya.0 new Shema added for product type HPiNfakVX1Z9hWsO. Please send next line from logfile on disk to developer! 2018-11-14 21:43:04.500 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power3\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"延迟\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":500000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"type\":\"obj\",\"desc\":\"上报的为放大100倍之后的值,即上报56,实际值为0.56度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[]"} 2018-11-14 21:43:04.501 - info: tuya.0 new Shema added for product type n8iVBAPLFKAAAszH. Please send next line from logfile on disk to developer! 2018-11-14 21:43:04.501 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time\",\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"}]","schemaExt":"[{\"id\":2,\"inputType\":\"\"}]"} 2018-11-14 21:43:04.502 - info: tuya.0 new Shema added for product type ocNB89IgPygEpdnE. Please send next line from logfile on disk to developer! 2018-11-14 21:43:04.502 - info: tuya.0 {"schema":"[{\"mode\":\"ro\",\"code\":\"switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\",\"desc\":\"上报门窗开关状态\"},{\"mode\":\"ro\",\"code\":\"TamperedAlarm\",\"name\":\"防拆报警\",\"property\":{\"type\":\"bool\"},\"id\":102,\"type\":\"obj\",\"desc\":\"mcu 上报拆除信息\"},{\"mode\":\"ro\",\"code\":\"Battery\",\"name\":\"电池电量\",\"property\":{\"unit\":\"%\",\"min\":0,\"max\":100,\"scale\":0,\"step\":10,\"type\":\"value\"},\"id\":103,\"type\":\"obj\",\"desc\":\"mcu 上报电池电量信息\"},{\"mode\":\"ro\",\"code\":\"state\",\"name\":\"状态\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\",\"desc\":\"上报产品是“休眠”还是“离线”\"}]","schemaExt":"[]"} 2018-11-14 21:43:04.502 - info: tuya.0 new Shema added for product type PUyaDrOGMhJfCExd. Please send next line from logfile on disk to developer! 2018-11-14 21:43:04.503 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"增加电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"trigger\":\"direct\",\"type\":\"obj\",\"desc\":\"上报的为放大1000倍之后的值,即上报56,实际值为0.056度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"当前电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[{\"id\":2,\"inputType\":\"\"},{\"id\":3,\"inputType\":\"\"},{\"id\":4,\"inputType\":\"\"},{\"id\":5,\"inputType\":\"\"},{\"id\":6,\"inputType\":\"\"}]"}</code>
Mal wieder etwas neues:
<code>2018-11-15 23:56:34.240 - [32minfo[39m: tuya.0 new Shema added for product type r15JnoGqWPM4PPtl. Please send next line from logfile on disk to developer! 2018-11-15 23:56:34.240 - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_1\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time2\",\"id\":11,\"type\":\"obj\",\"desc\":\"可根据产品实际倒计时功能修改。\"}]","schemaExt":"[]"}[/code]</code>
und noch einer:
3fach Steckdosenleiste mit 4er USB
https://de.aliexpress.com/item/Smart-Wi … 4c4djD7d7L
<code>2018-11-16 00:28:39.644 - info: tuya.0 new Shema added for product type JtCDjzmKcUNKEBzO. Please send next line from logfile on disk to developer! 2018-11-16 00:28:39.645 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_s1\",\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_s2\",\"name\":\"开关 2\",\"property\":{\"type\":\"bool\"},\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_s3\",\"name\":\"开关 3\",\"property\":{\"type\":\"bool\"},\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_usb1\",\"name\":\"USB\",\"property\":{\"type\":\"bool\"},\"id\":4,\"type\":\"obj\",\"desc\":\"switch_s4修改为switch_usb1\"}]","schemaExt":"[]"}[/code]</code>
Danke, sind jetzt alle in der 1.0.4 drin.
Hallo Apollon77,
Nächste Woche bekomme ich wieder ein Spielzeug für die Weihnachtsbeleuchtung…...
Ich hoffe sie funktioniert mit deinen Adapter.
Heute bekommen, Funktioniert!
Gute Chancen
Die Steckdose funzt. Hab die installiert. Die müsste auch schon integriert sein, da ich kein neues schema bekomme
COOL, mit Verbrauchswerte?
Thr next one….
<code>2018-11-16 21:50:27.144 - [32minfo[39m: tuya.0 new Shema added for product type r15JnoGqWPM4PPtl. Please send next line from logfile on disk to developer! 2018-11-16 21:50:27.145 - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_1\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time2\",\"id\":11,\"type\":\"obj\",\"desc\":\"可根据产品实际倒计时功能修改。\"}]","schemaExt":"[]"}[/code]</code>
Also ich möchte auch mal danke für diesen Adapter sagen…
Bisher hatte ich die Teckin SP22 Steckdosen mit Tasmota geflasht. Nachdem aber nun die neuen SP22 nicht mehr geschraubt sind, das öffnen sch... ist und wenn dann mal offen die Kabel so kurz sind, das man ohne die Platine auslöten nicht an den ESP kommt und dann noch Probleme beim flashen bekommt :x
Wenn man das mal mit dem Proxy geschnallt hat, ist mir der Tuya Adapter doch lieber.
Nur leider bekomme ich keine wh oder kwh aus der Teckin. Wenn das auch noch gehen würde...
