Adapter: iobroker.backitup (stable Release)
Da wurde nichts geändert … Gib mal die Zeiten neu ein und speichere mal.
Schalte vorher mal die Adapterinstanz auf debug und poste mal die Logausgabe beim speichern. `
Sieht für mich alles gut aus
ackitup.0 2018-11-12 11:18:54.479 info [total] backup was activated at 03:00 every 7 day(s) backitup.0 2018-11-12 11:18:54.479 info [minimal] backup was activated at 02:00 every 3 day(s) backitup.0 2018-11-12 11:18:54.478 info starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v6.14.3 host.iobrokervm 2018-11-12 11:18:53.003 info instance system.adapter.backitup.0 started with pid 13428 host.iobrokervm 2018-11-12 11:18:51.013 info instance system.adapter.backitup.0 terminated with code 0 (OK) backitup.0 2018-11-12 11:18:50.994 info terminating host.iobrokervm 2018-11-12 11:18:50.485 info stopInstance system.adapter.backitup.0 killing pid 13418 host.iobrokervm 2018-11-12 11:18:50.485 info stopInstance system.adapter.backitup.0 host.iobrokervm 2018-11-12 11:18:50.485 info object change system.adapter.backitup.0 backitup.0 2018-11-12 11:18:45.347 info [total] backup was activated at 03:00 every 7 day(s) backitup.0 2018-11-12 11:18:45.303 info [minimal] backup was activated at 02:00 every 3 day(s) backitup.0 2018-11-12 11:18:45.258 info starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v6.14.3 backitup.0 2018-11-12 11:18:45.083 debug statesDB connected backitup.0 2018-11-12 11:18:45.020 debug objectDB connected host.iobrokervm 2018-11-12 11:18:44.109 info instance system.adapter.backitup.0 started with pid 13418 host.iobrokervm 2018-11-12 11:18:42.148 info instance system.adapter.backitup.0 terminated with code 0 (OK) backitup.0 2018-11-12 11:18:42.101 info terminating host.iobrokervm 2018-11-12 11:18:41.593 info stopInstance system.adapter.backitup.0 killing pid 13405 host.iobrokervm 2018-11-12 11:18:41.593 info stopInstance system.adapter.backitup.0 host.iobrokervm 2018-11-12 11:18:41.592 info object change system.adapter.backitup.0Ich lass es mal auf debug und beobachte was passiert
So, ich bin einen Schritt weiter. Hab mir die Logs von letzte Nacht angesehen. Es wird erst ein Backup erstellt und dann wird es wieder gelöscht.
Die neueren Backups werden gelöscht und dafür die uralten Backups behalten. Außerdem sind noch 13 minimal Backups vorhanden, obwohl 10 eingestellt sind. Oder unterscheidet das Löschen zwischen automatischen und manuell angelegten? Bin ich der Einzige bei dem das so ist?
` > backitup.0 2018-11-13 02:00:23.898 debug [minimal] exec: done
backitup.0 2018-11-13 02:00:23.892 debug [minimal/umount] done
backitup.0 2018-11-13 02:00:13.816 debug [minimal/history] backitup.0.history.html
backitup.0 2018-11-13 02:00:13.772 debug [minimal/clean] done
backitup.0 2018-11-13 02:00:13.746 debug [minimal/clean] delete /opt/iobroker/backups/minimal_2018_11_13-02_00_11_backupiobroker.tar.gz
backitup.0 2018-11-13 02:00:13.742 debug [minimal/clean] delete /opt/iobroker/backups/minimal_2018_11_12-09_43_56_backupiobroker.tar.gz
backitup.0 2018-11-13 02:00:13.738 debug [minimal/clean] delete /opt/iobroker/backups/minimal_2018_10_28-02_00_10_backupiobroker.tar.gz
backitup.0 2018-11-13 02:00:13.734 debug [minimal/clean] delete /opt/iobroker/backups/minimal_2018_10_27-02_00_11_backupiobroker.tar.gz
backitup.0 2018-11-13 02:00:13.705 debug [minimal/clean] delete /opt/iobroker/backups/minimal_2018_10_26-02_00_11_backupiobroker.tar.gz
backitup.0 2018-11-13 02:00:13.689 debug [minimal/cifs] done
backitup.0 2018-11-13 02:00:13.679 debug [minimal/minimal] done
backitup.0 2018-11-13 02:00:13.655 debug [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2018_11_13-02_00_11_backupiobroker.tar.gz
backitup.0 2018-11-13 02:00:11.067 debug [minimal/mount] done `
Außerdem sind noch 13 minimal Backups vorhanden, obwohl 10 eingestellt sind. `
Haben deine "uralten" Backups die gleiche Dateinamens-Strucktur wie die neuen. Denn es werden nur Dateien gelöscht die dem Soll-Muster entsprechen? -
Eigentlich schon. Hab jetzt mal alle alten weg verschoben und so den Ordner geleert. Mal sehen was passiert die nächsten Tage mit komplett neuen Backups.
Aber so oder so hätte das neu erstellte ja nicht direkt wieder gelöscht werden dürfen, oder?
Welchen Version nutzt du?
<size size="150">!Solved</size>
Das kommt durch einen älteren Bug.
Lösche mal die Datenpunkt und starte den Adapter danach neu.
Somit werden dann auch die richtigen Datenpunkte angelegt. `
Hallo zusammen nutze Version 0.3.8 und habe unter Objekt nach der Erstellung eines Backups "invalid Date" stehen. :?
Ist das Problem in der Version noch present?
Danke im Voraus
Welchen Version nutzt du? `
Ich benutze die Version 0.3.6
Letzte Nacht wurde das Backup normal erstellt und auch nicht gelöscht. War allerdings jetzt das einzige in dem Ordner. Ich beobachte mal weiter wie es aussieht wenn dann gelöscht werden soll.
So ein ähnliches Verhalten habe ich bei mir auch schon festgestellt. Bei mir waren dann die Backups zwar auf dem FTP Server, nicht aber im lokalen Raspi Verzeichnis. Ich habe dann alle Dateien lokal und auf dem FTP gelöscht, dann lief es wieder. Heute wurde dann mal wieder kein Backup gemacht, weder lokal, noch auf dem Server zu finden. Ich habe dann mal nachgesehen, es lagen jeweils 5 minimal Backups im Verzeichnis.Ich habe jetzt wieder alle gelöscht und werde morgen nachsehen, ob es wieder läuft.
Kommt mir fast so vor, als wenn die Probleme immer dann anfangen, wenn die eingestellte 5 Backups erreicht wurden.
Alle wieviel Tage machst du backups?
Ihr müsst beachten, dass hier mit cronjobs gearbeitet wird.
D.h. Wenn der Adapter gestartet oder nach Updates neugestartet wird, dann wird der cronjob gesetzt.
Habt ihr z.B. alle 3 Tage eingestellt, dann wird das Backup 3 Tage nach setzen des Cronjobs (Neustart des Adapters) ausgeführt.
Gelöscht werden alle backups bis auf die letzten X.
Die backups werden aber nur gelöscht, wenn sie auch der Dateinamenformatierung entsprechen.
Benennt ihr ein backup um, dann wird es nicht berücksichtigt.
Das weiß ich ja alles. Ich habe aber noch nie ein Backup umbenannt. Und wie du in meinem Log Auszug sehen kannst wurde das Backup erstellt und dann sofort wieder gelöscht. Das kann doch so nicht stimmen.
Funktioniert der Adapter auch mit Multihostsystemen?
Gesendet aus Hessen.
Ja er funktioniert auch im Multihostbetrieb.
Dafür muss du aber mehrere Instanzen installiert haben.
Das weiß ich ja alles. Ich habe aber noch nie ein Backup umbenannt. Und wie du in meinem Log Auszug sehen kannst wurde das Backup erstellt und dann sofort wieder gelöscht. Das kann doch so nicht stimmen. `
Ich vermute mal, dass auf deinem NAS irgendwas mit dem Zeitstempel der Dateien nicht korrekt ist.
Habe gerade nochmal durchlaufen lassen. Es werden immer die neusten auf dem NAS belassen und die, die Älter sind gelöscht.
Kann den Fehler leider aktuell nicht rekonstruieren …
backitup.1 2018-11-14 15:28:35.045 debug [minimal] exec: done backitup.1 2018-11-14 15:28:35.044 debug [minimal/umount] done backitup.1 2018-11-14 15:28:24.823 debug redis pmessage io.backitup.1.oneClick.* io.backitup.1.oneClick.minimal {"val":false,"ack":true,"ts":1542205704816,"q":0,"from":"system.adapter.backitup.1","lc":1542205704816} backitup.1 2018-11-14 15:28:24.821 debug [minimal] exec: done backitup.1 2018-11-14 15:28:24.820 debug [minimal/history] done backitup.1 2018-11-14 15:28:24.749 debug [minimal/email] done backitup.1 2018-11-14 15:28:24.748 debug sendTo "send" to system.adapter.email.1 from system.adapter.backitup.1 backitup.1 2018-11-14 15:28:24.748 debug [minimal/email] [minimal] used E-Mail-Instance: email.1 backitup.1 2018-11-14 15:28:24.747 debug [minimal/mysql] MySql File deleted! backitup.1 2018-11-14 15:28:24.747 debug [minimal/redis] done backitup.1 2018-11-14 15:28:24.746 debug [minimal/clean] done backitup.1 2018-11-14 15:28:24.745 debug [minimal/clean] delete /opt/iobroker/backups/mysql_2018_10_03-12_21_14_backupiobroker.tar.gz backitup.1 2018-11-14 15:28:24.745 debug [minimal/clean] delete /opt/iobroker/backups/mysql_2018_10_15-12_51_05_backupiobroker.tar.gz backitup.1 2018-11-14 15:28:24.744 debug [minimal/clean] delete /opt/iobroker/backups/minimal_2018_10_13-14_26_25_test_backupiobroker.tar.gz backitup.1 2018-11-14 15:28:24.744 debug [minimal/clean] delete /opt/iobroker/backups/minimal_2018_10_14-12_21_11_test_backupiobroker.tar.gz backitup.1 2018-11-14 15:28:24.743 debug [minimal/clean] delete /opt/iobroker/backups/minimal_2018_10_15-12_21_11_test_backupiobroker.tar.gz backitup.1 2018-11-14 15:28:21.253 debug [minimal/cifs] done backitup.1 2018-11-14 15:28:21.246 debug [minimal/mysql] done backitup.1 2018-11-14 15:28:21.195 debug [minimal/mysql] done backitup.1 2018-11-14 15:28:21.109 debug [minimal/minimal] done backitup.1 2018-11-14 15:28:20.753 debug [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2018_11_14-15_28_17_test_backupiobroker.tar.gz backitup.1 2018-11-14 15:28:17.058 debug [minimal/mount] done -
Danke jetzt gehts!
ich habe aktuell das Problem, dass das Komplett-Backup nicht mehr funktioniert. Weder automatisch noch manuell.
iobroker wird zwar gestoppt, aber dann passiert irgendwie nichts mehr. Im Backup Ordner wird keine Datei erstellt und auch iobroker startet nicht mehr von allein. Alle anderen Backups funktionieren.
Noch zur Info: iobroker läuft auf einem RPi3 mit Raspbian Stretch light.
Jemand ne Idee?
Chris `
leider kämpfe ich immer noch mit dem Problem.
In der Log wird nichts angezeigt, da iobroker ja bereits gestoppt wurde.
Starte mal iob und auch den PI komplett neu.
Gesendet von iPhone mit Tapatalk `
Habe ich bereits mehrfach gemacht
Habe eingestellt dass 30 Backups aufgehoben werden sollen. Auf der SD Karte des Raspberry sind es auch genau 30, aber in der Dropbox bereits 32. Das Namensschema passt bei allen 32 und sie wurden auch alle vom Adapter erzeugt. Ich beobachte das mal noch paar Tage, aber vermutlich wird es in der Dropbox weiter zunehmen.
Auf meine Frage bzgl SQL Backup hat nie jemand geantwortet:
@Diginix:Ist das SQL Backup für den SQL History Adapter gedacht?
Wenn ja, wie richte ich das ein? Woher bekomme ich die Logindaten und mysqldump gibt es bei mir unter Rasbian nicht.
Auch mysql selbst ist als solches nicht installiert, bzw. gibt es keine bekanntes Kommando. Dennoch funktioniert der History Adapter innerhalb ioBroker bei mir.
Wäre es möglich Dropbox optional pro Backuptyp zu aktivieren? Das Vollbackup hat 300 MB und braucht beim Upload zu lange und würde auf Dauer auch die Dropbox voll laufen lassen. `
Auch mysql selbst ist als solches nicht installiert, bzw. gibt es keine bekanntes Kommando. Dennoch funktioniert der History Adapter innerhalb ioBroker bei mir. `
Du musst den SQL-Adapter installieren und Mysql einrichten wie hier beschrieben:https://github.com/ioBroker/ioBroker.sq … /README.md
Ist derzeit nicht angedacht
