    4. [Aufruf] ZigBee CC253x Adapter
      andy6090 last edited by
      habe das heute im Log gehabt :
      ! zigbee.0
      ! 2018-11-14 09:14:07.603
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 233. MAC no ack.
      ! zigbee.0
      ! 2018-11-14 09:14:07.518
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genLevelCtrl - moveToLevelWithOnOff - {"level":135,"transtime":0} - 3 failed with error Error: AF data request fails, status code: 233. MAC no ack.
      ! zigbee.0
      ! 2018-11-14 09:13:57.014
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genLevelCtrl - moveToLevelWithOnOff - {"level":183,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:57.003
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genOnOff - on - {} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:56.007
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genLevelCtrl - moveToLevelWithOnOff - {"level":150,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:54.275
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', lightingColorCtrl - moveToColorTemp - {"colortemp":274,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:51.586
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', lightingColorCtrl - moveToColorTemp - {"colortemp":223,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:49.415
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', lightingColorCtrl - moveToColorTemp - {"colortemp":382,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:49.127
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', lightingColorCtrl - moveToColorTemp - {"colortemp":379,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:48.005
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', lightingColorCtrl - moveToColorTemp - {"colortemp":295,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:47.108
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', lightingColorCtrl - moveToColorTemp - {"colortemp":295,"transtime":0} - 3 failed with error Error: AF data request fails, status code: 233. MAC no ack.
      ! zigbee.0
      ! 2018-11-14 09:13:43.696
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genLevelCtrl - moveToLevelWithOnOff - {"level":140,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:40.726
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genLevelCtrl - moveToLevelWithOnOff - {"level":51,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:39.729
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genLevelCtrl - moveToLevelWithOnOff - {"level":206,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:38.575
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genLevelCtrl - moveToLevelWithOnOff - {"level":224,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:37.570
      ! error
      ! zigbee.0
      ! 2018-11-14 09:13:36.832
      ! error
      ! zigbee.0
      ! 2018-11-14 09:13:35.885
      ! error
      ! Zigbee publish to '0x7cb03eaa00a93405', genLevelCtrl - moveToLevelWithOnOff - {"level":119,"transtime":0} - 3 failed with error Error: Timed out after 30000 ms
      ! zigbee.0
      ! 2018-11-14 09:13:35.879
      ! error
      ! zigbee.0
      ! 2018-11-14 09:13:35.833
      ! error
      Das ist von der Ceiling 33.
      Sind das noch Sachen die Sie könnte ?
        klausiy123 last edited by
        ich glaub der Fehler ist wieder zwischen Monitor und Stuhllehne,
        Ich hab den Zigbeeadapter aus dem Repo 08..0b instaliert, nur wird der mir in den Instanzen und in den Objekten nicht angezeigt. Unter Adapter steht nur: verfügbare Version 0.7.7, instalierte Version 0.8.0..
        Iobroker hab ich schon neugestartet. Was hab ich falsch gemacht?
        Danke und Gruß
        Stephan
          so muss das aussehen.. zur Zeit wenn ihr vom Git installiert
            hi,
            genau so sah es aus, nur war eben in den Objekten und Instaznen nicht mehr zusehen. Bin jetzt erst mal wieder auf die 0.7.0 zurück da ist dann wieder alles da. Ich würde ja gerne die 0.8.0 nutzen…
            und Gruß Stephan
              @klausiy123:
              hi,
              und Gruß Stephan `
              und was soll ich jetzt mit den sperlichen infos machen ???
              für dich gehts https://forum.iobroker.net/viewtopic.php?f=22&t=18515
                <size size="150">ACHTUNG</size>
                es gibt eine neue Version auf GIT… diese binhaltet eine Queue Abarbeitung..
                leider ist damit zur Zeit eine Verzögerung bei Abarbeitung der einzelnen Zustände verbuden
                also alle die mal Testen wollen ... können die Version 0.8.0b installieren .. für all den Rest wartet bitte...
                  Christian.B last edited by
                  @arteck:
                  @Christian.B:
                  Oh ja….. hatte Brett vorm Kopf.
                  Das ging anfangs irgenwie nicht. Jetzt funktioniert es.
                  Leider wird der Status nicht geändert wenn man die Taste am Gerät betätigt.
                  Das ist nicht so gut. `
                  ohh nicht schon iweder das Thema..
                  soch wird es..welche Adapterersion hast du installiert ?? `
                  Ist das ein Problem, welches nur innerhalb meines Systems auftritt oder ist das ein Bug, welches behoben werden muss, es aber derzeit wichtigere Sachen gibt?
                    @Christian.B:
                    @arteck:
                    @Christian.B:
                    Ist das ein Problem, welches nur innerhalb meines Systems auftritt oder ist das ein Bug, welches behoben werden muss, es aber derzeit wichtigere Sachen gibt? `
                    nix vom beiden … der Status wird jeweils geändert.. ergo es funktioniert
                      Nein, mit 0.8.0a geht es nicht…
                      • Q
                        Querbeet last edited by
                        @Knallix:
                        Hallo Leute,
                        habe mir jetzt eine Innr Bulb zugelegt.
                        Diese ist mit einem CC2530 - Raspberry in IoBroker über den Zigbee-Adapter verbunden.
                        Laut Übersicht verbunden.
                        Es klappt auch die Lampe zu schalten, allerdings nicht immer. 😢
                        Kann das an der Verbindung liegen !!!
                        Habe folgende Fehlermeldung:
                        Error.JPG `
                        ~~![](</s><URL url=)<link_text text="download/file.php?id=36741&t=1">https://forum.iobroker.net/download/file.php?id=36741&t=1</link_text>" />
                        Entschuldigt die leicht Off-Topic Fragen.
                        1. Gibt es zwischen einem Zigbee Router und Zigbee Repeater einen Unterschied. Im oben zitierten Link sind das zwei verschiedene Symbole und Benennung.
                        2. Gibt es eine Liste mit allen Router/Repeater fähigen Geräten?
                        3. Beim CC2530 habe ich explizit gelesen, dass er als Router konfigurierbar ist, aber der CC2531? Es scheint ja ein Hex zu geben: https://github.com/Koenkk/Z-Stack-firmw … ter/CC2531 aber in den einschlägen Videos wird immer nur der CC2530 als Router geflasht und nicht mal im Nebensatz erwähnt, dass es auch mit dem CC2531~~
                        • FredF
                          FredF Most Active Forum Testing last edited by
                          @Querbeet:
                          @Knallix:
                          Hallo Leute,
                          Error.JPG `
                          3. Beim CC2530 habe ich explizit gelesen, dass er als Router konfigurierbar ist, aber der CC2531? Es scheint ja ein Hex zu geben: https://github.com/Koenkk/Z-Stack-firmw … ter/CC2531 aber in den einschlägen Videos wird immer nur der CC2530 als Router geflasht und nicht mal im Nebensatz erwähnt, dass es auch mit dem CC2531~~ ` ~~Das ist bestimmt schon öfters beantwortet worden, aber vielleicht nicht in dieser geballten Form :lol:
                          zu 1.: Router und Repeater ist das gleiche, hier hat Knallix nur die Steckdose Repeater genannt
                          zu 2.: Nein, aber alle zigbee Geräte die mit Netzspannung arbeiten sind Router/Repeater (Steckdosen, Lampen, Schalter). Batteriebetriebene hingegen nicht
                          zu 3.: ja auch der CC2531 kann als Router geflasht werden. Meist wird aber wg. der höheren Reichweite der CC2530 genommen
                            Marniee last edited by
                            ich bin neu hier und ich habe ein Problem 🙂
                            Ich habe versucht das Problem mit mehrstündiger Internet-Recherche zu lösen - ohne Erfolg. Daher hoffe ich jetzt auf euch Experten!
                            Ich habe einen CC2531 erfolgreich im iobroker eingebunden. Auch das Pairen von Schaltern und Lichtern funktioniert einwandfrei.
                            Schalter (Hue, Xiaomi) und Sensoren (Xiaomi) senden auch ein Signal, das von iobroker angezeigt wird.
                            Leider kann ich aber die Lichter (Hue, Ikea) nicht schalten. Für die Objekte werden Eigenschaften(brightness/state/colortemp) angezeigt, wenn ich diese ändere (an-/ausschalten z.B.) werden sie nach kurzer Zeit rot, die Rückmeldung (acknowlegement) funktioniert also wahrscheinlich nicht.
                            Im log treten keine Fehler auf. Ich habe die Lichter schon entkoppelt und wieder neu gekoppelt. Sie werden immer richtig erkannt und wie gewünscht eingebunden. Die zigbee-Netzwerkkarte sieht auch wunderbar (sternförmig) aus. Die Lampen sind zwischen 10 cm und 5 m vom CC2531 entfernt.
                            Das ganze hat bis gestern mit einer hue-bridge funktioniert, dann hab ich alles auseinander genommen 🙂
                            Hat jemand eine Idee wo der Fehler liegen könnte?
                            Viele Grüße Marniee
                            • FredF
                              Meiner Meinung nach sind die Lampen zu weit vom CC2531 entfernt.
                              Ich habe bei mir so max. 4-5m und alles gut.
                              Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
                                Sinalco last edited by
                                @arteck:
                                @Sinalco:
                                Leider lässt sich bei meiner TRADFRI bulb E27 CWS opal 600lm (mit RGB) die Farbtemperatur nicht einstellen.
                                Folgende Fehlermeldung erscheint:
                                zigbee.0	2018-11-03 14:11:49.939	error	No converter available for 'LED1624G9' with key 'colortemp'
                                zigbee.0	2018-11-03 14:11:40.287	info	new dev 0xd0cf5efffe22e689 29351 TRADFRI bulb E27 CWS opal 600lm
                                Dimmen, Ein/Aus und Farben lassen sich einstellen. Bei andren Ikea Tradfri Birnen die kein RGB Licht haben kann man ohne Probleme die Farbtemperatur wechseln. `
                                jo mein Fehler hab es übersehen.
                                in der nächsten Version wird es da sein `
                                Hi arteck leider ist es in der 0.8.0b aus deiner Repo noch nicht behoben.
                                  also Dimmen, Ein/Aus und Farben und temepratur..richtig ??
                                    @arteck:
                                    also Dimmen, Ein/Aus und Farben und temepratur..richtig ?? `
                                    Ja genau.
                                    Temperatur funktioniert nicht.
                                    Dimmen, ein aus und Farbe funktioniert
                                      probier mal mein repo
                                      https://github.com/arteck/ioBroker.zigbee
                                      und gib bescheid
                                        DeeJayDave last edited by
                                        @RichieXX:
                                        Ich habe eine Frage zur "Netzwerkkarte".
                                        Was bedeuten die Zahlen auf den Linien zu den Geräten. Ist das die Verbindungsqualität? Wenn ja, welches Maß ist das?
                                        Hab mir extra einen Plug geholt, der repeaten soll. Er selbst hat eine "1" in der Linie, obwohl der gar nicht soweit weg ist.Netzwerkkarte.png `
                                        Welche Bedeutung haben denn nun die Zahlen?
                                          loi83 last edited by
                                          Servus,
                                          Der tradfri Dimmer wird ja nun auch erkannt. So weit so gut, allerdings kann ich drehen wie ich will. Es wird kein Status in den Objekten verändert, woran könnte das liegen?
                                          Wenn ich den staus manuell verändere kommt eine Fehlermeldung im Log
                                          Gesendet von meinem BLA-L29 mit Tapatalk
                                          ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 99b019.jpg">https://uploads.tapatalk-cdn.com/20181119/ae9c586e649aa89acadda9833499b019.jpg</link_text>" />
                                            @Christian.B:
                                            @arteck:
                                            @Christian.B:
                                            soch wird es..welche Adapterersion hast du installiert ?? ich habe die Version 0.8.0a installiert.
                                            Ich möchte hier nochmal nachfragen. Es geht um den Osram Smart Plug+ . Bei mir wird State unter Objekte nicht geändert, wenn ich den Taster am Plug betätige. Bin ich der einzige, bei dem das nicht funktioniert? Geht das bei euch?
                                            1078
                                            344301
