    3. Cloud Dienste
    4. Alexa2 v1.1.2/1.1.3 (damit der Cookie hoffentlich wieder tut vorläufig)
      apollon77 last edited by
      Doppelposts sind blöd. Bitte meine Antwort im anderen Thread checken und dann selbst hier updaten.
      Gesendet vom Handy …
        pedro last edited by
        Yep, sorry, mein Fehler..
        Antwort aus anderem Thread:
        Bitte Ggf mal manuell
        iobroker upload alexa2
        Ausführen und in jedem Fall Instanz neu starten.
          Da ändert sich leider gar nichts .. folgendes gemacht:
          -> installieren aus eigener URL wie vorher beschrieben:
          $ ./iobroker url "https://github.com/Apollon77/ioBroker.alexa2/tarball/master" alexa2
          install https://github.com/Apollon77/ioBroker.alexa2/tarball/master
          npm install https://github.com/Apollon77/ioBroker.alexa2/tarball/master --production --save --prefix "/opt/iobroker" (System call)
          npm
           ERR! code EAI_AGAINnpm
           ERR! errno EAI_AGAIN
          npm
           ERR!
           request to https://github.com/Apollon77/ioBroker.alexa2/tarball/master failed, reason: getaddrinfo EAI_AGAIN github.com:443
          npm
           ERR! A complete log of this run can be found in:
          npm ERR!
               /root/.npm/_logs/2018-11-18T15_18_01_549Z-debug.log
          got /opt/iobroker/node_modules/iobroker.alexa2/admin
          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index.html index.html text/html
          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
          -> dann "iobroker upload alexa2":
          $ ./iobroker upload alexa2
          process exited with code 0
          -> dann restart von instanz:
          Version bleibt bei 1.1.0
          any other hint ….?
            Fehlermeldung lesen?
            request to https://github.com/Apollon77/ioBroker.a … all/master failed, reason: getaddrinfo EAI_AGAIN github.com:443
            was könnte das heissen?
            Scheinbar kann der Host die IP von "github.com" nicht auflösen. Checke mal deine Netzwerk und DNS Einstellungen und so.
            Ansonsten: machs doch bitte per Admin ... jeder baut sich andere "komische" Kommandozeilenbefehle zusammen .. unnötig
            Aber bevor das NamensauflöseThema nicht geklärt ist sollte da der gleiche Fehler kommen, also löse das vorher bitte
              Secrenz last edited by
              @apollon77:
              Was genau hastenden vorher nicht geklappt? Details wären cool gewesen weil es sollte direkt gehen.
              Gesendet vom Handy … `
              Er sich nicht mehr mit Amazon verbunden.
              Der Adapter blieb gelb.
              So musste ich neu einloggen. Doch im log kam nicht der link dass ich auf der lokalen IP einloggen kann.
              Nach der neu Installation kam der log dann.
                @apollon77:
                Aber bevor das NamensauflöseThema nicht geklärt ist sollte da der gleiche Fehler kommen, also löse das vorher bitte `
                Ok .. ich gebe zu, wer lesen kann ist klar im Vorteil .. hat funktioniert. Danke!
                • padrino
                  padrino Most Active last edited by
                  hab jetzt mal geupdated…
                  Bei der Installaton steht
                  ` > npm
                  WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) `
                  Hat das etwas zu sagen?
                  CU,
                  padrino
                    Ja, das heisst das Du offensichtlich keinen MacOS hast 🙂 In dem Fall ignore
                    • padrino
                      :oops: Alles klar, danke! :lol:
                        P-A-L-A-D-I-N last edited by
                        Ich habe es geschafft, auf meinem Windows-Server, per manuellem Github-Link, die neue Version 1.1.3 des Adapters zu installieren. Allerdings bleibt das Problem mit dem gelben Status bei mir bestehen.
                        Wenn ich das Einstellungsfenster des Adapters richtig verstanden habe, kann man doch entweder mit E-Mail und Paßwort ODER mit diesem Cookie das Konto verlinken. Da der Cookie bei mir immer wieder Probleme macht und dann händisch erneuert werden muß, würde ich gerne die simple Lösung mit E-Mail und Paßwort verwenden (die ändern sich schließlich nicht). Allerdings bleibt der Adapter dann, jetzt zumindest, gelb.
                        Habe ich da etwas falsch verstanden? Braucht man diesen Cookie doch immer? Oder liegt der Fehler ganz woanders?
                        Ich bitte um etwas Nachsicht - habe von der ganzen Sache wirklich null Ahnung und bastle hier meistens nur, recht stupide, irgendwelche Youtube-Anleitungen von Leuten nach, die davon weitaus mehr verstehen… 😉
                          Wenn du den Adapter startest. Gehe in den log und dort ist dann ein link mit seiner ip Adresse vom Server. Die rufst du in einem extra Tab auf. Und gibst dort erneut deine Amazon Daten ein.
                            @Secrenz:
                            Wenn du den Adapter startest. Gehe in den log und dort ist dann ein link mit seiner ip Adresse vom Server. Die rufst du in einem extra Tab auf. Und gibst dort erneut deine Amazon Daten ein. `
                            Danke, jetzt klappt es wieder! Ich hoffe nur, daß ich das nicht immer wieder händisch machen muß. Ich weiß nämlich in aller Regel nicht, wann der Adapter wieder gelb wird, sodaß ich das eher zufällig mitbekomme.
                              Doch weisst Du, aktuell nach ziemlich EXAKT 14 Tagen. DU kannst aber auch mit einem Skript den "alexa2.0.info.connection" ENdpunkt überwachen. Wenn der auf false geht eine Notification senden.
                              Eine Lösung ist hoffentlich bald in Sicht … stay Tuned
                                Ok, das mit den 14 Tagen ist schon mal gut zu wissen! Die Lösung der Adapter-Überwachung habe ich mir auch schon so gedacht, als ich dieses interessante Youtube-Video dazu gesehen habe: https://www.youtube.com/watch?v=EiAGMmAwm1o
                                Mein Gedanke war der, daß man doch per Skript bestimmt erreichen könnte, daß automatisch ALLE Adapter, die nicht grün sind, neu gestartet werden. Das Ganze am besten kombiniert mit einem "Schalter", um die Funktion bei Wartungsarbeiten o.ä. kurzfristig auszustellen.
                                Leider reichen meine rudimentären Kenntnisse nicht aus, um so etwas selbst umzusetzen. Daher werde ich wohl oder übel warten müssen, bis hier eine Lösung speziell für den Alexa-Adapter gefunden wird oder irgendein netter Mensch sich mal des "Alle-Adapter-überwachen-Skripts" annimmt. 😉
                                Auf alle Fälle an dieser Stelle mal noch ein abschließendes großes Dankeschön für Deine Arbeit!
                                • Dr. Bakterius
                                  Dr. Bakterius Most Active last edited by
                                  Ein Neustart des Alexa-Adapters würde in diesem Fall aber nichts bringen weil du dich erneut bei Amazon anmelden musst. Er wurde sich also in einer Schleife ständig neu starten.
                                  Lass dir eine Email oder eine Nachricht (Telegram oder Pushover) zusenden damit du weißt wann du dich erneut anmelden musst.
                                  Z.B. so:
                                    Geniale Sache! 🙂 Danke!
                                    Ich habe mich eben bei pushover registriert, mein Telefon als Gerät angemeldet, den Adapter bei iobroker installiert und eingerichtet und auch schon das Blockly-Skript nachgebaut. Das Einzige, was ich noch nicht geschafft habe, ist das Einrichten der Wahr-unwahr-Bedingung. Du hast da einen Datenpunkt (?) drin stehen. Kannst Du mir bitte noch sagen, wie man den erstellt?
                                      Also diese "Objekt-ID" meine ich…
                                        Hat sich erledigt! Habe den Eintrag im Adapter gefunden!
                                        Vielen Dank für die tolle Hilfe!! Das werde ich mir direkt noch für die anderen Adapter "klonen"!
                                          Jan1 last edited by
                                          Wenn man schon den DP "If communication with alexa works" hat, ist es sinnvoller auf den zu triggern, als blind das Ding alle Minute zu erledigen.
                                            SO?
                                            113
                                            14884
