    4. [Aufruf] Neuer Adaper Google-Sharedlocations
      andyb last edited by
      @x4tlaoguo:
      Nein, alter Fehler, Google verbietet den login, ich arbeite an einem Workaround
      Gesendet von meinem SM-G950F mit Tapatalk `
      Also bei mir das gleiche wie bei Schweiz.
      Der Google Account verzeichnet aber keinerlei Loginversuch in den Aktivitäten.
      Dachte versuch mal den Adapter neu zu installieren, dabei…..
      iobroker 2018-10-29 19:21:27.419 info exit 0
      iobroker 2018-10-29 19:21:27.351 error system.adapter.google-sharedlocations does not exist
      iobroker 2018-10-29 19:21:27.259 info upload [0] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/google-sharedlocations.png google-sharedlocations.png image/png
      iobroker 2018-10-29 19:21:27.190 info upload [1] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/index_m.html index_m.html text/html
      iobroker 2018-10-29 19:21:27.074 info upload [2] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/words.js words.js application/javascript
      iobroker 2018-10-29 19:21:27.045 info got /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin
      iobroker 2018-10-29 19:21:25.236 info upload google-sharedlocations
      host.orangepiplus2e 2018-10-29 19:19:42.739 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      iobroker 2018-10-29 19:19:40.962 info exit 0
      iobroker 2018-10-29 19:19:40.368 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      iobroker 2018-10-29 19:19:40.366 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
      iobroker 2018-10-29 19:19:40.366 info optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/winston-syslog/node_modules/unix-dgram):
      iobroker 2018-10-29 19:19:40.363 info WARN
      iobroker 2018-10-29 19:19:40.358 info npm
      iobroker 2018-10-29 19:19:40.358 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 install: prebuild-install || node-gyp rebuild
      iobroker 2018-10-29 19:19:40.358 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 (node_modules/iobroker.discovery/node_modules/serialport):
      iobroker 2018-10-29 19:19:40.358 info npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/unix-dgram/package.json'
      iobroker 2018-10-29 19:19:40.358 info npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/serialport/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/termina
      iobroker 2018-10-29 19:19:40.350 info npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-radio/package.json'
      iobroker 2018-10-29 19:19:40.350 info npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-question/package.json'
      iobroker 2018-10-29 19:19:40.350 info npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-choices/package.json'
      iobroker 2018-10-29 19:19:40.350 info npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-checkbox/package.json'
      iobroker 2018-10-29 19:19:40.350 info WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/authenticate-pam/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prom
      iobroker 2018-10-29 19:19:40.343 info npm
      iobroker 2018-10-29 19:19:07.635 info gyp ERR! not ok
      iobroker 2018-10-29 19:19:07.635 info gyp ERR! node-gyp -v v3.6.0
      iobroker 2018-10-29 19:19:07.635 info gyp ERR! node -v v8.12.0
      iobroker 2018-10-29 19:19:07.635 info gyp ERR! cwd /opt/iobroker/node_modules/winston-syslog/node_modules/unix-dgram
      iobroker 2018-10-29 19:19:07.635 info gyp ERR! System Linux 4.14.70-sunxigyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      iobroker 2018-10-29 19:19:07.620 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
      iobroker 2018-10-29 19:19:07.620 info gyp ERR! stack at ChildProcess.emit (events.js:214:7)
      iobroker 2018-10-29 19:19:07.620 info gyp ERR! stack at emitTwo (events.js:126:13)
      iobroker 2018-10-29 19:19:07.620 info gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:336:16)
      iobroker 2018-10-29 19:19:07.620 info gyp ERR! configure error gyp ERR! stack Error: gyp failed with exit code: 1
      iobroker 2018-10-29 19:19:07.587 info ImportError: No module named compiler.ast
      iobroker 2018-10-29 19:19:07.587 info from compiler.ast import Const
      iobroker 2018-10-29 19:19:07.587 info File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>
      iobroker 2018-10-29 19:19:07.587 info import gyp.input
      iobroker 2018-10-29 19:19:07.587 info import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 8, in <module>
      iobroker 2018-10-29 19:19:07.584 info Traceback (most recent call last): File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>
      iobroker 2018-10-29 19:19:05.270 info gyp ERR! not ok
      iobroker 2018-10-29 19:19:05.267 info gyp ERR! node-gyp -v v3.6.0
      iobroker 2018-10-29 19:19:05.267 info gyp ERR! node -v v8.12.0
      iobroker 2018-10-29 19:19:05.267 info "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
      iobroker 2018-10-29 19:19:05.263 info ERR! System Linux 4.14.70-sunxigyp ERR! command
      iobroker 2018-10-29 19:19:05.260 info gyp
      iobroker 2018-10-29 19:19:05.260 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
      iobroker 2018-10-29 19:19:05.260 info ERR! stack at emitTwo (events.js:126:13)gyp ERR! stack at ChildProcess.emit (events.js:214:7)
      iobroker 2018-10-29 19:19:05.257 info gyp
      iobroker 2018-10-29 19:19:05.257 info gyp ERR! stack Error: gyp failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:336:16)
      iobroker 2018-10-29 19:19:05.253 info
      iobroker 2018-10-29 19:19:05.251 info ERR! configure error
      iobroker 2018-10-29 19:19:05.248 info gyp
      iobroker 2018-10-29 19:19:05.230 info ImportError: No module named compiler.ast
      iobroker 2018-10-29 19:19:05.230 info from compiler.ast import Const
      iobroker 2018-10-29 19:19:05.230 info File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>
      iobroker 2018-10-29 19:19:05.230 info import gyp.input
      iobroker 2018-10-29 19:19:05.230 info import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 8, in <module>
      iobroker 2018-10-29 19:19:05.226 info Traceback (most recent call last): File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>
      iobroker 2018-10-29 19:19:02.855 info WARN install No prebuilt binaries found (target=8.12.0 runtime=node arch=arm platform=linux)
      iobroker 2018-10-29 19:19:02.852 info prebuild-install
      iobroker 2018-10-29 19:16:51.071 info npm install https://github.com/t4qjXH8N/ioBroker.google-sharedlocations/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      iobroker 2018-10-29 19:16:49.488 info install https://github.com/t4qjXH8N/ioBroker.google-sharedlocations/tarball/master
      iobroker 2018-10-29 19:16:48.209 info url "https://github.com/t4qjXH8N/ioBroker.google-sharedlocations"</module></module></module></module></module></module>
      • X
        Xyolyp last edited by
        Google scheint momentan den Login weiter abzuschotten. Darauf deutet hin, dass zum Beispiel jetzt Javascript für den Login zwingend erforderlich ist.
        Es könnte also leider dem Adapter an den Kragen gehen 😞
        https://www.heise.de/newsticker/meldung … 08557.html
        • X
          x4tlaoguo last edited by
          Ja, das habe ich auch schon gesehen, es wird eng. Habe mir schon ein paar Alternativen angeschaut. Eines scheint sicher, Google will keine API bereit stellen.
            Mitch last edited by
            google-sharedlocations.0	2018-11-07 19:52:16.871	error	An error occurred during polling the locations!
            google-sharedlocations.0	2018-11-07 19:52:16.871	error	An error occurred during getSharedLocation!
            google-sharedlocations.0	2018-11-07 19:52:16.870	info	Could not connect to google, please login manually!
            google-sharedlocations.0	2018-11-07 19:52:16.870	error	Connection works, but authorization failure, please login manually!
            Kann ich dagegen irgendwas selbst tun, oder muss ich warten?
              AntiDim last edited by
              Hiiilfe, ich will so umledigt den Adapter zum laufen bekommen ….
              Leider, leider kriege ich immer nur "First connection failed."
              Nutzername habe ich schon ohne @ und mit .....@gmail.com probiert.
              Genau so mit und ohne den "Email zur Kontowiederherstellung" ich habe kein Ahnung mehr was ich noch machen soll damit es läuft.
              Übrigens "Konto mit der Bestätigung in zwei Schritten schützen" hab ich auch aus ... also theoretisch steht doch nichts im Wege.
              Eventuell sag das hier jemanden was:
              debug sendTo "checkConnection" to system.adapter.admin.0 from system.adapter.google-sharedlocations.0: false
              debug sendTo "getUsersFromDB" to system.adapter.admin.0 from system.adapter.google-sharedlocations.0
                @Mitch:
                Kann ich dagegen irgendwas selbst tun, oder muss ich warten? `
                Es geht wieder google macht mich fertisch!
                • X
                  Mich auch!
                    Morrio last edited by
                    seit paar Tagen habe ich auch wieder Probleme mit den Adapter.
                    Besteht noch Hoffnung?
                    • X
                      Bei mir funktioniert es noch. Mehr kann ich leider nicht dazu sagen. Wenn ich Zeit habe baue ich den Adapter so um, dass man den Cookie abgreifen kann. Mal schauen ob Google das zulässt.
                        seit kurz vor Mittag funktioniert jetzt zumindest wieder das einloggen.
                        Ohne das ich etwas geändert hätte, da ich nicht zu Hause war.
                        Bekomme jetzt aber Fehlermeldungen vom Host.
                        host.raspberrypi	2018-11-21 13:58:52.423	info	Restart adapter system.adapter.google-sharedlocations.0 because enabled
                        host.raspberrypi	2018-11-21 13:58:52.421	error	instance system.adapter.google-sharedlocations.0 terminated with code 7 (Adapter already running)
                          Marty56 last edited by
                          Habe gerade den Adapter ausprobiert und kann mich nicht einloggen.
                          Besteht noch Hoffnung, oder ist der Adapter gestorben?
                          • dslraser
                            Das Problem mit dem einloggen ist dem Entwickler ja bekannt.(steht weiter oben)
                            Bei mir läuft der Adapter nun schon Monate ohne ein Problem.
                            Wenn er einmal läuft, dann scheint es dieses Problem nicht zu geben…
                            Jedenfalls lebt der Adapter noch.
                            • X
                              Das kann ich bestätigen. Bei mir läuft der Adapter auch ohne Probleme. Leider unterliegt der Adapter der Willkür von Google, daher habe ich den Adapter auch aus dem offiziellen Repo herausgenommen. Er bleibt ein Bastelstück.
                              • siggi85
                                siggi85 last edited by
                                Ich wollte den Adapter gerade einrichten, aber kann mich auch nicht initial einloggen. 😞
                                Aber jetzt steht erst Mal Weihnachten vor der Tür, also schöne und erholsame Feiertage, vielleicht hat der Entwickler ja nach den Feiertagen Zeit sich das Mal anzuschauen. 🙂
                                  Finnimeister last edited by
                                  Hallo,ich bin erst ganz neu im Bereich Iobroker,aber Respekt was ihr da alles mit macht….
                                  Vielleicht könnt ihr mir mit der Konfiguration des places Adapters und des Google sharedlocations Adapters helfen!!!
                                  Den ich möchte das was "dslracer" mit der Amwesenheitserkennung gemacht hat gerne auch haben...
                                  Hoffe auf eure unterstütztung. .....
                                    weimaraner last edited by
                                    Auch ich möchte mich dem Wunsch der Nutzung des Adapters anschließen. Ich habe von den loggin Problemen gelesen und weiß, daß der Entwickler ihn deshlab aus dem repo genommen hat.
                                    Dennoch eine Frage zu meinem Log
                                    google-sharedlocations.0	2018-12-28 19:37:51.904	debug	stateChange google-sharedlocations.0.info.connection {"val":false,"ack":false,"ts":1546022271897,"q":0,"from":"system.adapter.google-sharedlocations.0","lc":1546022009661}
                                    google-sharedlocations.0	2018-12-28 19:37:51.899	error	First connection failed.
                                    google-sharedlocations.0	2018-12-28 19:37:51.899	debug	[google auth] Connection third stage failed due to an additional verification that could not be identified!
                                    google-sharedlocations.0	2018-12-28 19:37:51.899	debug	[google auth] connectEnterVerificationEmail failed, error:Error: options.uri is a required argument
                                    google-sharedlocations.0	2018-12-28 19:37:51.897	debug	[google auth] connectEnterVerificationEmail
                                    google-sharedlocations.0	2018-12-28 19:37:51.714	debug	[google auth] Connection third stage additional verification needed.
                                    google-sharedlocations.0	2018-12-28 19:37:51.565	debug	[google auth] Connection third stage
                                    google-sharedlocations.0	2018-12-28 19:37:51.565	debug	[google auth] Connection second stage successful
                                    google-sharedlocations.0	2018-12-28 19:37:51.331	debug	[google auth] Connection second State
                                    google-sharedlocations.0	2018-12-28 19:37:51.330	debug	[google auth] Connection first stage successfull
                                    google-sharedlocations.0	2018-12-28 19:37:50.736	debug	[google auth] Connection First State
                                    google-sharedlocations.0	2018-12-28 19:37:50.736	info	Starting google shared locations adapter
                                    Was heißt das? Ich habe jetzt drei Stunden alle möglichen Einstellungen probiert und dieser log-Inhalt ist nun neu. Bin ich auf dem richtigen Weg?
                                    Grüße Andreas
                                    • dslraser
                                      Zum Log kann ich Dir nichts sagen, aber ist denn der Adapter grün ?
                                        Leider nein. Er ist gelb.
                                        • X
                                          Hey, gib doch mal eine Recovery-Adresse ein? Also bei dem Iobroker-Account eine Recovery-Adresse eingeben und die im Adapter einstellen. Dann bei Meldungen an die Recovery-Adresse immer Google mitteilen, dass alles ok ist.
                                            Meinst du in den Adaptereinstellungen die Wiederherstellungs-Mail? Die habe ich richtig eingetragen. Da kam aber bisher keine Anfrage von Google.
                                            Grüße Andreas
                                            (ich habe dort meine richtige Mail eingetragen 😉 )
                                            51
                                            496
                                            110393
