    4. Netatmo?
    Netatmo?
      rascal last edited by
      ich habe seit neuestem ein Problem mit dem Adapter, er hat bis jetzt monatelang problemlos funktioniert.
      hier die Fehlermeldung im iobroker Log:
      host.Mastermind	2018-11-20 16:05:05.054	info	Restart adapter system.adapter.netatmo.0 because enabled
      host.Mastermind	2018-11-20 16:05:05.054	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
      host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
      host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
      host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
      host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
      host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
      host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
      host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:43)
      host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: TypeError: Cannot read property 'WindStrength' of undefined
      netatmo.0	2018-11-20 16:05:04.090	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v8.10.0
      host.Mastermind	2018-11-20 16:05:01.976	info	instance system.adapter.netatmo.0 started with pid 14763
      host.Mastermind	2018-11-20 16:04:31.958	info	Restart adapter system.adapter.netatmo.0 because enabled</anonymous></anonymous></anonymous>
      ist das schon bekannt?
      • integer63
        integer63 last edited by
        Hab ich seit 15:30 auch 😞
        <code>2018-11-20 15:30:48.167  - [31merror[39m: netatmo.0 uncaught exception: Cannot read property 'WindStrength' of undefined
        2018-11-20 15:30:48.167  - [31merror[39m: netatmo.0 TypeError: Cannot read property 'WindStrength' of undefined
            at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
        2018-11-20 15:30:48.168  - [32minfo[39m: netatmo.0 cleaned everything up...
        2018-11-20 15:30:48.173  - [32minfo[39m: netatmo.0 terminating[/code]</anonymous></anonymous></anonymous></code>
          ich habe über github die version 1.3.1 installiert, selber Fehler 😞
          • integer63
            … mal gaaaaanz vorsichtig - scheint wieder zu gehen :?
              Hier auch…. weiß der Teufel....
                Rate mal… selbes Problem wie gestern
                netatmo.0	2018-11-21 16:20:49.445	info	terminating
                netatmo.0	2018-11-21 16:20:49.410	info	cleaned everything up...
                netatmo.0	2018-11-21 16:20:49.409	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                netatmo.0	2018-11-21 16:20:49.409	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                netatmo.0	2018-11-21 16:20:49.409	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                netatmo.0	2018-11-21 16:20:49.409	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                netatmo.0	2018-11-21 16:20:49.409	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                netatmo.0	2018-11-21 16:20:49.409	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
                netatmo.0	2018-11-21 16:20:49.409	error	at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
                netatmo.0	2018-11-21 16:20:49.409	error	at Array.forEach (<anonymous>)
                netatmo.0	2018-11-21 16:20:49.409	error	at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
                netatmo.0	2018-11-21 16:20:49.409	error	at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:43)
                netatmo.0	2018-11-21 16:20:49.409	error	TypeError: Cannot read property 'WindStrength' of undefined
                netatmo.0	2018-11-21 16:20:49.409	error	uncaught exception: Cannot read property 'WindStrength' of undefined
                netatmo.0	2018-11-21 16:20:48.572	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v8.10.0
                netatmo.0	2018-11-21 16:20:48.430	info	States connected to redis: 0.0.0.0:6379
                host.Mastermind	2018-11-21 16:20:46.409	info	instance system.adapter.netatmo.0 started with pid 16245
                hue.0	2018-11-21 16:20:21.759	info	final lightState for Philips_hue_1.Stehlampe_Wohnzimmer:{"bri":0,"on":false,"level":0}
                host.Mastermind	2018-11-21 16:20:16.392	info	Restart adapter system.adapter.netatmo.0 because enabled
                host.Mastermind	2018-11-21 16:20:16.391	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Array.forEach (<anonymous>)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:43)
                Caught	2018-11-21 16:20:16.391	error	by controller[0]: TypeError: Cannot read property 'WindStrength' of undefined
                netatmo.0	2018-11-21 16:20:16.340	info	cleaned everything up...</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                • integer63
                  Jup, ich auch 😞
                  Kann ja eigentlich nur am Netatmo Service/Server selbst liegen, oder?
                    Möglich, ich kann mich aber bei Netatmo in meinen Account einloggen und es sieht soweit alles normal aus
                    • integer63
                      Ja, bei mir auch, aber ich glaube für die ioBroker Abfragen wird eine anderer Service (API) angesprochen.
                      • integer63
                        Momentan wieder keine Fehlermeldungen mehr und Instanz wieder "grün" … echt nervig
                          hier das gleiche, auch gut im Moment
                          • N
                            Nanouk last edited by
                            Moin,
                            hier auch das Problem.
                            Ging gestern mal kurzzeitig, aber seit gestern Abend wieder rot.
                            Gruß Nanouk
                            • Schubi
                              Schubi last edited by
                              Gibts schon Neuigkeiten - hab seit kurzem auch den Fehler!
                              netatmo.0	2018-12-03 19:49:00.565	info	terminating
                              netatmo.0	2018-12-03 19:49:00.528	info	cleaned everything up...
                              netatmo.0	2018-12-03 19:49:00.526	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                              netatmo.0	2018-12-03 19:49:00.526	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                              netatmo.0	2018-12-03 19:49:00.526	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
                              netatmo.0	2018-12-03 19:49:00.526	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                              netatmo.0	2018-12-03 19:49:00.526	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                              netatmo.0	2018-12-03 19:49:00.526	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
                              netatmo.0	2018-12-03 19:49:00.526	error	at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
                              netatmo.0	2018-12-03 19:49:00.526	error	at Array.forEach (native)
                              netatmo.0	2018-12-03 19:49:00.526	error	at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
                              netatmo.0	2018-12-03 19:49:00.526	error	at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:42)
                              netatmo.0	2018-12-03 19:49:00.526	error	TypeError: Cannot read property 'WindStrength' of undefined
                              netatmo.0	2018-12-03 19:49:00.524	error	uncaught exception: Cannot read property 'WindStrength' of undefined
                              netatmo.0	2018-12-03 19:48:59.157	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v6.13.1</anonymous></anonymous>
                                bei mir scheint der Fehler nicht mehr aufzutreten
                                • Schubi
                                  Was hast du geändert?
                                  Hast du einen Windsensor? (Ich hab keinen)
                                    ich habe die Version von Github direkt installiert, jetzt läuft Version 1.3.1
                                    Ich habe einen Windsensor, Regensensor und Außentemp Sensor.
                                    • Schubi
                                      Ich Probier auch mal direkt von GitHub.
                                      Hab aber jetzt auch schon die 1.3.1
                                      Nach der Fehlermeldung könnte ein Problem der nicht vorhandene Wert des Windmessers sein :roll:
                                      • Schubi
                                        Also bringt auch nix geht noch immer nicht 😞
                                        Mir kommt vor allem diese Meldung komisch vor:
                                          ich hatte die selbe Meldung, warte ein bisschen, vielleicht verschwindet es bei dir auch von alleine
                                          • Schubi
                                            :lol: Es läuft :lol:
                                            Habe folgendes gemacht:
                                            Ein Freund hat ebenfalls eine Netatmo Station - und hatte darauf Zugriff - die Datenpunkte meiner und seiner Station wurden immer angezeigt.
                                            Er hat das Teil aber schon länger nicht mehr in Betrieb - un die Werte blieben immer leer (- mich hat das nicht weiters gekümmert)
                                            Bei dieser Station gab es auch einen Windmesser
                                            :idea: Nun hab ich auf der Netatmo Hompage den Zugang zu seiner Station in meinem Konto glöscht - und siehe da - es geht wieder!
                                            Vielleicht wärs jetzt auch ohne dieser Maßnahme gegangen - einen Versuch is es wert.
                                            Hoffe die Info kann noch jemand brauchen.
                                            LG Schubi
                                            140
                                            35503
