    5. [Frage BLOCKLY ] Klingel Bild per Telegram versenden / Snapshot von Cam per Telegram versenden
    • wendy2702
      wendy2702 last edited by Negalein
      So, Scale mal angepasst:
      root@openmediavault ~ > ffmpeg -y -i rtsp:xxx:xxx_18@192.168.178.210:554/12 -t 5 -f mp4 -vcodec libx264 -pix_fmt yuv420p -an -vf scale=w=2688:h=1538:force_original_aspect_ratio=decrease -r 15 /opt/iobroker/out2.mp4
      ffmpeg version 3.2.10-1~deb9u1~bpo8+1 Copyright (c) 2000-2018 the FFmpeg developers
        built with gcc 4.9.2 (Debian 4.9.2-10)
        configuration: --prefix=/usr --extra-version='1~deb9u1~bpo8+1' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --disable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
        libavutil      55\. 34.101 / 55\. 34.101
        libavcodec     57\. 64.101 / 57\. 64.101
        libavformat    57\. 56.101 / 57\. 56.101
        libavdevice    57\.  1.100 / 57\.  1.100
        libavfilter     6\. 65.100 /  6\. 65.100
        libavresample   3\.  1\.  0 /  3\.  1\.  0
        libswscale      4\.  2.100 /  4\.  2.100
        libswresample   2\.  3.100 /  2\.  3.100
        libpostproc    54\.  1.100 / 54\.  1.100
      [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet
      [rtsp @ 0x5585cee25a00] RTP: missed 113 packets
      [h264 @ 0x5585cee28d00] left block unavailable for requested intra mode
      [h264 @ 0x5585cee28d00] error while decoding MB 0 33, bytestream 17500
      [h264 @ 0x5585cee28d00] concealing 10465 DC, 10465 AC, 10465 MV errors in I frame
      Input #0, rtsp, from 'rtsp:xxx:xxx_18@192.168.178.210:554/12':
        Metadata:
          title           : Media Presentation
        Duration: N/A, start: 0.300000, bitrate: N/A
          Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 2688x1520 [SAR 1:1 DAR 168:95], 20 fps, 20 tbr, 90k tbn, 40 tbc
      [swscaler @ 0x5585cef82520] deprecated pixel format used, make sure you did set range correctly
      [libx264 @ 0x5585ceee9f60] using SAR=1/1
      [libx264 @ 0x5585ceee9f60] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 LZCNT
      [libx264 @ 0x5585ceee9f60] profile High, level 5.0
      [libx264 @ 0x5585ceee9f60] 264 - core 142 r2431 a5831aa - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=3 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=15 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
      Output #0, mp4, to '/opt/iobroker/out2.mp4':
        Metadata:
          encoder         : Lavf57.56.101
          Stream #0:0: Video: h264 (libx264) ([33][0][0][0] / 0x0021), yuv420p, 2688x1520 [SAR 1:1 DAR 168:95], q=-1--1, 15 fps, 15360 tbn, 15 tbc
          Metadata:
            encoder         : Lavc57.64.101 libx264
          Side data:
            cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
      Stream mapping:
        Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))
      Press [q] to stop, [?] for help
      [h264 @ 0x5585ceeda300] left block unavailable for requested intra mode
      [h264 @ 0x5585ceeda300] error while decoding MB 0 33, bytestream 17500
      [h264 @ 0x5585ceeda300] concealing 10465 DC, 10465 AC, 10465 MV errors in I frame
      [rtsp @ 0x5585cee25a00] max delay reached. need to consume packete=N/A dup=0 drop=8 speed=   0x
      [rtsp @ 0x5585cee25a00] RTP: missed 110 packets
      [h264 @ 0x5585ceee1860] error while decoding MB 67 65, bytestream -5
      [h264 @ 0x5585ceee1860] concealing 5022 DC, 5022 AC, 5022 MV errors in P frame
      Past duration 0.749992 too large      0kB time=00:00:00.00 bitrate=N/A dup=4 drop=11 speed=   0x
      [rtsp @ 0x5585cee25a00] RTP: missed 22 packets
      [rtsp @ 0x5585cee25a00] RTP: missed 1 packets
      [h264 @ 0x5585ceeda300] left block unavailable for requested intra4x4 mode -1
      [h264 @ 0x5585ceeda300] error while decoding MB 0 33, bytestream 146621
      [rtsp @ 0x5585cee25a00] RTP: missed 5 packets
      [h264 @ 0x5585ceeda300] error while decoding MB 15 66, bytestream -11
      [h264 @ 0x5585ceeda300] concealing 4906 DC, 4906 AC, 4906 MV errors in P frame
      [rtsp @ 0x5585cee25a00] max delay reached. need to consume packete=N/A dup=4 drop=15 speed=   0x
      [rtsp @ 0x5585cee25a00] RTP: missed 62 packets
      [h264 @ 0x5585cefa1980] error while decoding MB 29 46, bytestream -5
      [h264 @ 0x5585cefa1980] concealing 8252 DC, 8252 AC, 8252 MV errors in P frame
      [rtsp @ 0x5585cee25a00] max delay reached. need to consume packette=81708307.7kbits/s dup=4 drop=16 speed=2.22e-05x
      [rtsp @ 0x5585cee25a00] RTP: missed 25 packets
      [h264 @ 0x5585ceeda300] error while decoding MB 87 7, bytestream -5
      [h264 @ 0x5585ceeda300] concealing 14746 DC, 14746 AC, 14746 MV errors in P frame
      [rtsp @ 0x5585cee25a00] max delay reached. need to consume packette=19895.5kbits/s dup=5 drop=17 speed=0.0947x
      [rtsp @ 0x5585cee25a00] RTP: missed 39 packets
      [h264 @ 0x5585cefa1980] error while decoding MB 32 7, bytestream -5
      [h264 @ 0x5585cefa1980] concealing 14801 DC, 14801 AC, 14801 MV errors in P frame
      [rtsp @ 0x5585cee25a00] max delay reached. need to consume packette=9909.6kbits/s dup=6 drop=17 speed=0.19x
      [rtsp @ 0x5585cee25a00] RTP: missed 447 packets
      [h264 @ 0x5585ceeda300] error while decoding MB 98 64, bytestream -5
      [h264 @ 0x5585ceeda300] concealing 5159 DC, 5159 AC, 5159 MV errors in P frame
      [rtsp @ 0x5585cee25a00] RTP: missed 32 packets
      [h264 @ 0x5585ceee1860] error while decoding MB 86 84, bytestream -9
      [h264 @ 0x5585ceee1860] concealing 1811 DC, 1811 AC, 1811 MV errors in P frame
      [rtsp @ 0x5585cee25a00] RTP: missed 71 packets
      [h264 @ 0x5585cefa1980] error while decoding MB 126 88, bytestream -5
      [h264 @ 0x5585cefa1980] concealing 1099 DC, 1099 AC, 1099 MV errors in P frame
      [rtsp @ 0x5585cee25a00] RTP: missed 15 packets
      [h264 @ 0x5585ceeda300] error while decoding MB 116 89, bytestream -5046.2kbits/s dup=6 drop=17 speed=0.209x
      [h264 @ 0x5585ceeda300] concealing 941 DC, 941 AC, 941 MV errors in P frame
      [rtsp @ 0x5585cee25a00] RTP: missed 45 packets
      [h264 @ 0x5585cefa1980] error while decoding MB 84 57, bytestream -7
      [h264 @ 0x5585cefa1980] concealing 6349 DC, 6349 AC, 6349 MV errors in P frame
      frame=   66 fps=7.0 q=-1.0 Lsize=    2409kB time=00:00:04.20 bitrate=4699.1kbits/s dup=6 drop=17 speed=0.448x
      video:2408kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.069726%
      [libx264 @ 0x5585ceee9f60] frame I:1     Avg QP:19.26  size:429876
      [libx264 @ 0x5585ceee9f60] frame P:17    Avg QP:21.33  size: 90299
      [libx264 @ 0x5585ceee9f60] frame B:48    Avg QP:25.75  size: 10411
      [libx264 @ 0x5585ceee9f60] consecutive B-frames:  1.5%  3.0%  4.5% 90.9%
      [libx264 @ 0x5585ceee9f60] mb I  I16..4: 10.0% 38.4% 51.6%
      [libx264 @ 0x5585ceee9f60] mb P  I16..4:  0.2%  0.5%  0.3%  P16..4: 32.3%  9.9% 15.5%  0.0%  0.0%    skip:41.3%
      [libx264 @ 0x5585ceee9f60] mb B  I16..4:  0.0%  0.0%  0.0%  B16..8: 30.7%  2.7%  0.9%  direct: 1.2%  skip:64.5%  L0:45.6% L1:52.4% BI: 2.0%
      [libx264 @ 0x5585ceee9f60] 8x8 transform intra:39.8% inter:31.6%
      [libx264 @ 0x5585ceee9f60] coded y,uvDC,uvAC intra: 72.1% 32.3% 8.3% inter: 9.9% 1.7% 0.0%
      [libx264 @ 0x5585ceee9f60] i16 v,h,dc,p: 13% 49% 25% 14%
      [libx264 @ 0x5585ceee9f60] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 64% 10% 11%  2%  2%  2%  2%  2%  3%
      [libx264 @ 0x5585ceee9f60] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 31% 20% 15%  5%  4%  7%  4%  8%  5%
      [libx264 @ 0x5585ceee9f60] i8c dc,h,v,p: 65% 13% 20%  3%
      [libx264 @ 0x5585ceee9f60] Weighted P-Frames: Y:0.0% UV:0.0%
      [libx264 @ 0x5585ceee9f60] ref P L0: 72.3%  4.5% 19.6%  3.6%
      [libx264 @ 0x5585ceee9f60] ref B L0: 90.0%  7.7%  2.3%
      [libx264 @ 0x5585ceee9f60] ref B L1: 93.4%  6.6%
      [libx264 @ 0x5585ceee9f60] kb/s:4481.23
      Allerdings immer noch einige ERROR und andere suspekte Einträge im log:
      • Alex1808
        Alex1808 last edited by
        @wendy2702:
        ! root@openmediavault ~ > ffmpeg -y -i rtsp:xxx:xxx_18@192.168.178.210:554/12 -t 5 -f mp4 -vcodec libx264 -pix_fmt yuv420p -an -vf scale=w=2688:h=1538:force_original_aspect_ratio=decrease -r 15 /opt/iobroker/out2.mp4 ffmpeg version 3.2.10-1~deb9u1~bpo8+1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) configuration: --prefix=/usr --extra-version='1~deb9u1~bpo8+1' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --disable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 55\. 34.101 / 55\. 34.101 libavcodec 57\. 64.101 / 57\. 64.101 libavformat 57\. 56.101 / 57\. 56.101 libavdevice 57\. 1.100 / 57\. 1.100 libavfilter 6\. 65.100 / 6\. 65.100 libavresample 3\. 1\. 0 / 3\. 1\. 0 libswscale 4\. 2.100 / 4\. 2.100 libswresample 2\. 3.100 / 2\. 3.100 libpostproc 54\. 1.100 / 54\. 1.100 [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet [rtsp @ 0x5585cee25a00] RTP: missed 113 packets [h264 @ 0x5585cee28d00] left block unavailable for requested intra mode [h264 @ 0x5585cee28d00] error while decoding MB 0 33, bytestream 17500 [h264 @ 0x5585cee28d00] concealing 10465 DC, 10465 AC, 10465 MV errors in I frame Input #0, rtsp, from 'rtsp:xxx:xxx_18@192.168.178.210:554/12': Metadata: title : Media Presentation Duration: N/A, start: 0.300000, bitrate: N/A Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 2688x1520 [SAR 1:1 DAR 168:95], 20 fps, 20 tbr, 90k tbn, 40 tbc [swscaler @ 0x5585cef82520] deprecated pixel format used, make sure you did set range correctly [libx264 @ 0x5585ceee9f60] using SAR=1/1 [libx264 @ 0x5585ceee9f60] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 LZCNT [libx264 @ 0x5585ceee9f60] profile High, level 5.0 [libx264 @ 0x5585ceee9f60] 264 - core 142 r2431 a5831aa - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=3 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=15 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00 Output #0, mp4, to '/opt/iobroker/out2.mp4': Metadata: title : Media Presentation encoder : Lavf57.56.101 Stream #0:0: Video: h264 (libx264) ([33][0][0][0] / 0x0021), yuv420p, 2688x1520 [SAR 1:1 DAR 168:95], q=-1--1, 15 fps, 15360 tbn, 15 tbc Metadata: encoder : Lavc57.64.101 libx264 Side data: cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1 Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Press [q] to stop, [?] for help [h264 @ 0x5585ceeda300] left block unavailable for requested intra mode [h264 @ 0x5585ceeda300] error while decoding MB 0 33, bytestream 17500 [h264 @ 0x5585ceeda300] concealing 10465 DC, 10465 AC, 10465 MV errors in I frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packete=N/A dup=0 drop=8 speed= 0x [rtsp @ 0x5585cee25a00] RTP: missed 110 packets [h264 @ 0x5585ceee1860] error while decoding MB 67 65, bytestream -5 [h264 @ 0x5585ceee1860] concealing 5022 DC, 5022 AC, 5022 MV errors in P frame Past duration 0.749992 too large 0kB time=00:00:00.00 bitrate=N/A dup=4 drop=11 speed= 0x [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet [rtsp @ 0x5585cee25a00] RTP: missed 22 packets [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet [rtsp @ 0x5585cee25a00] RTP: missed 1 packets [h264 @ 0x5585ceeda300] left block unavailable for requested intra4x4 mode -1 [h264 @ 0x5585ceeda300] error while decoding MB 0 33, bytestream 146621 [h264 @ 0x5585ceeda300] concealing 10465 DC, 10465 AC, 10465 MV errors in I frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet [rtsp @ 0x5585cee25a00] RTP: missed 5 packets [h264 @ 0x5585ceeda300] error while decoding MB 15 66, bytestream -11 [h264 @ 0x5585ceeda300] concealing 4906 DC, 4906 AC, 4906 MV errors in P frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packete=N/A dup=4 drop=15 speed= 0x [rtsp @ 0x5585cee25a00] RTP: missed 62 packets [h264 @ 0x5585cefa1980] error while decoding MB 29 46, bytestream -5 [h264 @ 0x5585cefa1980] concealing 8252 DC, 8252 AC, 8252 MV errors in P frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packette=81708307.7kbits/s dup=4 drop=16 speed=2.22e-05x [rtsp @ 0x5585cee25a00] RTP: missed 25 packets [h264 @ 0x5585ceeda300] error while decoding MB 87 7, bytestream -5 [h264 @ 0x5585ceeda300] concealing 14746 DC, 14746 AC, 14746 MV errors in P frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packette=19895.5kbits/s dup=5 drop=17 speed=0.0947x [rtsp @ 0x5585cee25a00] RTP: missed 39 packets [h264 @ 0x5585cefa1980] error while decoding MB 32 7, bytestream -5 [h264 @ 0x5585cefa1980] concealing 14801 DC, 14801 AC, 14801 MV errors in P frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packette=9909.6kbits/s dup=6 drop=17 speed=0.19x [rtsp @ 0x5585cee25a00] RTP: missed 447 packets [h264 @ 0x5585ceeda300] error while decoding MB 98 64, bytestream -5 [h264 @ 0x5585ceeda300] concealing 5159 DC, 5159 AC, 5159 MV errors in P frame Past duration 0.749992 too large [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet [rtsp @ 0x5585cee25a00] RTP: missed 32 packets [h264 @ 0x5585ceee1860] error while decoding MB 86 84, bytestream -9 [h264 @ 0x5585ceee1860] concealing 1811 DC, 1811 AC, 1811 MV errors in P frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet [rtsp @ 0x5585cee25a00] RTP: missed 71 packets [h264 @ 0x5585cefa1980] error while decoding MB 126 88, bytestream -5 [h264 @ 0x5585cefa1980] concealing 1099 DC, 1099 AC, 1099 MV errors in P frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet [rtsp @ 0x5585cee25a00] RTP: missed 15 packets [h264 @ 0x5585ceeda300] error while decoding MB 116 89, bytestream -5046.2kbits/s dup=6 drop=17 speed=0.209x [h264 @ 0x5585ceeda300] concealing 941 DC, 941 AC, 941 MV errors in P frame [rtsp @ 0x5585cee25a00] max delay reached. need to consume packet [rtsp @ 0x5585cee25a00] RTP: missed 45 packets [h264 @ 0x5585cefa1980] error while decoding MB 84 57, bytestream -7 [h264 @ 0x5585cefa1980] concealing 6349 DC, 6349 AC, 6349 MV errors in P frame frame= 66 fps=7.0 q=-1.0 Lsize= 2409kB time=00:00:04.20 bitrate=4699.1kbits/s dup=6 drop=17 speed=0.448x video:2408kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.069726% [libx264 @ 0x5585ceee9f60] frame I:1 Avg QP:19.26 size:429876 [libx264 @ 0x5585ceee9f60] frame P:17 Avg QP:21.33 size: 90299 [libx264 @ 0x5585ceee9f60] frame B:48 Avg QP:25.75 size: 10411 [libx264 @ 0x5585ceee9f60] consecutive B-frames: 1.5% 3.0% 4.5% 90.9% [libx264 @ 0x5585ceee9f60] mb I I16..4: 10.0% 38.4% 51.6% [libx264 @ 0x5585ceee9f60] mb P I16..4: 0.2% 0.5% 0.3% P16..4: 32.3% 9.9% 15.5% 0.0% 0.0% skip:41.3% [libx264 @ 0x5585ceee9f60] mb B I16..4: 0.0% 0.0% 0.0% B16..8: 30.7% 2.7% 0.9% direct: 1.2% skip:64.5% L0:45.6% L1:52.4% BI: 2.0% [libx264 @ 0x5585ceee9f60] 8x8 transform intra:39.8% inter:31.6% [libx264 @ 0x5585ceee9f60] coded y,uvDC,uvAC intra: 72.1% 32.3% 8.3% inter: 9.9% 1.7% 0.0% [libx264 @ 0x5585ceee9f60] i16 v,h,dc,p: 13% 49% 25% 14% [libx264 @ 0x5585ceee9f60] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 64% 10% 11% 2% 2% 2% 2% 2% 3% [libx264 @ 0x5585ceee9f60] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 31% 20% 15% 5% 4% 7% 4% 8% 5% [libx264 @ 0x5585ceee9f60] i8c dc,h,v,p: 65% 13% 20% 3% [libx264 @ 0x5585ceee9f60] Weighted P-Frames: Y:0.0% UV:0.0% [libx264 @ 0x5585ceee9f60] ref P L0: 72.3% 4.5% 19.6% 3.6% [libx264 @ 0x5585ceee9f60] ref B L0: 90.0% 7.7% 2.3% [libx264 @ 0x5585ceee9f60] ref B L1: 93.4% 6.6% [libx264 @ 0x5585ceee9f60] kb/s:4481.23 root@openmediavault ~ > !
        Das sieht schon besser aus, versuche die out2.mp4 abzuspielen
        Errors kannst erstmal ignorieren.
        2688x1538 ziemlich riesig. Es gibt normalerweise eine zweite url mit geringerem Auflösung, wird eventuell besser durch kommen.
        • Alex1808
          @wendy2702:
          EDIT: OK andere Frage. Testen kann ich das ja auf der Commandline aber wie bekomme ich raus mit welchen Einstellungen meine Camera funktioniert? `
          Habe gerade gesehen im log deine richtige Auflösung, FPS und das problem mit Scaling.
          Versuche mal so:
          ffmpeg -y -i rtsp:xxx:xxx_18@192.168.178.210:554/12 -t 5 -f mp4 -vcodec libx264 -pix_fmt yuv420p -an -vf scale=w=1344:h=760:force_original_aspect_ratio=decrease -r 20 /opt/iobroker/out2.mp4
          • wendy2702
            Hey DANKE!
            Das funktioniert schon mal. Jetzt auch mal mit dem Substream probiert das geht nochmal schneller und auf dem Handy Display ist die Qualität auch OK denke ich.
            Mirko
            • Alex1808
              @wendy2702:
              Hey DANKE!
              Mirko `
              Ja, ich denke auch. Habe selbst 640x360 was ca. 120-125kb wiegt und reicht vollkommen.
              • wendy2702
                @stephan61:
                Hallo wendy
                folgende Zeile im script ändern
                // sofort ein Bild senden und nach 10 Sek erneut
                function onEvent() {
                saveImage();
                setTimeout(function() { saveImage(); }, 10 * 1000);
                // sofort ein Bild senden und nach 3 Sek erneut
                saveImage();
                setTimeout(function() { saveImage(); }, 3 * 1000);
                setTimeout(function() { saveImage(); }, 6 * 1000);
                setTimeout(function() { saveImage(); }, 9 * 1000);
                Gruß Stephan `
                Habe es mal so eingetragen und prinzipiell läuft es.
                Hier mein aktuelles Script:
                // Dieses Script überwaht den Zustand eines Bewegungsmelders und speichert bei
                // Aktivierung ein Bild einer Überwachnungskamera in einem Vereichnis und sendet
                // dieses via Telegram.0-Adapter. Nach 10 Sek wird ein weiteres Bild erstellt und
                // gesendet.
                // Die Speicherung der Bilder erfolgt als "Stack", d.h. das aktuellste Bild bekommt
                // immer den Suffix "0" und es werden n Bilder mit den Suffixen 1..n-1 vorgehalten
                // Uhula 2017.11
                // Konfiguration
                      // Objekt-ID des Bewegungsmelders
                const oidLichtBewmelderTuer = "hm-rpc.0.PEQ0390697.1.MOTION";
                      // URL zur Kamera umn ein Image (jpg) zu erhalten
                const cam_url = "http://xxx:xxx@192.168.178.210/Streaming/channels/1/picture";
                      // Pfadangabe für die Speicherung der Bilder, der Pfad muss existieren
                const dest_path = '/opt/iobroker/iobroker-data/files/_temp/';
                      // Anzahl der Bilder, die vorgehalten werden sollen
                const imageCountMax = 8;
                      // Prefix für die Bildnamen
                const imageNamePre = "eingangstuer_";
                // Scriptteil
                var request = require('request');
                var fs      = require('fs');
                // Bild an telegram schicken
                function sendImage (path) {
                    try {
                        var stats = fs.statSync(path);
                        var msg = formatDate(stats.birthtime,"DD.MM.YYYY hh:mm:ss") + " " + path.substring(path.lastIndexOf('/')+1);
                        sendTo('telegram.0', {
                            text:                   path,
                            caption:                msg,
                            disable_notification:   true,
                            user: 'Mirko',
                            text:                   path,
                            caption:                msg,
                            user: 'xxxx',
                    catch(err) { if (err.code != "ENOENT") log(err); }
                // löscht eine Datei synchron (wartet auf das Ergebnis)
                function fsUnlinkSync(path) {
                    try {
                        try { fs.unlinkSync(path); }
                // benennt eine Datei synchron um (wartet auf das Ergebnis)
                function fsRenameSync(oldPath, newPath) {
                    try {
                        var stats = fs.statSync(oldPath);
                        try { fs.renameSync(oldPath, newPath); }
                // Bild speichern und senden
                function saveImage() {
                    // Bild imageCountMax-1 löschen
                    fsUnlinkSync( dest_path + imageNamePre + (imageCountMax-1) + ".jpg" );
                    // Bilder 0..imageCountMax-2 umbenennen
                    for (var i=imageCountMax-4; i >= 0; i-- ) {
                        fsRenameSync(dest_path + imageNamePre + i + ".jpg", dest_path + imageNamePre + (i+1) + ".jpg");
                    // Bild 0 löschen
                    var fname = imageNamePre + "0.jpg";
                    fsUnlinkSync( fname );
                    // Bild holen und speichern
                    request.get({url: cam_url, encoding: 'binary'}, function (err, response, body) {
                        fs.writeFile(dest_path + fname, body, 'binary', function(err) {
                            if (err) {
                                log('Fehler beim Bild speichern: ' + err, 'warn');
                            } else {
                                // dem Filesystem 2 Sek Zeit zum Speichern lassen
                                setTimeout(function() { sendImage(dest_path + fname); }, 4000);
                //function onEvent() {
                //    saveImage();
                //    setTimeout(function() { saveImage(); }, 10 * 300);
                saveImage();
                // Ereignisroutine
                //on({id: oidLichtBewmelderTuer, val: true}, function (obj) {
                //    onEvent( obj );
                on({id: 'hm-rpc.0.PEQ0390697.1.MOTION', change: "ne"}, function (obj) {
                  var value = obj.state.val;
                  if (getState("hm-rpc.0.PEQ0390697.1.MOTION").val === true && getState("hm-rpc.0.NEQ1110202.1.STATE").val === false)
                  onEvent( obj );
                // manuelle Ausführung (Test)
                onEvent();
                Ich erhalte 4 Bilder, davon sind die letzten beiden Bilder aber identisch zu erkennen am exact gleichen Zeitstempel den die Camera einblendet.
                Jemand dazu noch eine Idee?
                Danke und Gruß
                Mirko
                  A Former User last edited by
                  Warum baust du es nicht um auf Blockly? Beispiele sind ja im Beitrag.
                  • wendy2702
                    Ich denke das wenn ich genauso in Blockly umbaue… ich am Ende immer noch das Problem mit dem doppelten Bild habe.
                    Allerdings habe ich gerade einen Wert im Script geändert und die ersten Versuche sehen gut aus.
                    setTimeout(function() { sendImage(dest_path + fname); }, 2000);
                      daniello last edited by
                      @Alex1808:
                      Ich versende stamt Bild eine kleine mp4 Datei die als Gif bei Telegram ankommt. `
                      Hmm .. bei mir kommt leider nur ein Standbild an .. wobei ich zugegebermaßen die Aussage auch nicht ganz begreife. Es soll aus der mp4 ein animated Gif mit 256 Farben gerendert und versendet werden? Erkennt man da nohc was?
                      VG
                      • wendy2702
                        Ja,man erkennt noch sehr gut etwas.
                        Gesendet von iPad mit Tapatalk Pro
                          @wendy2702:
                          Gesendet von iPad mit Tapatalk Pro `
                          stimmt .. hab's jetzt auch hinbekommen .. was doof ist .. ist die Wartezeit die man einstellen muss, damit der Clip zuverlässig zugestellt wird (sonst erhält man den letzten) .. muss mal überlegen ob das irgendwie anders geht.
                            Gib den Befehl auf der Konsole ein und schau wie lange das Speichern dauert. Dann kannst du die Wartezeit so sehr kurz einstellen.
                              @Brainbug:
                              Gib den Befehl auf der Konsole ein und schau wie lange das Speichern dauert. Dann kannst du die Wartezeit so sehr kurz einstellen. `
                              hab ich so gemacht .. schöner wäre ein Erkennen wass die Datei zuende geschrieben ist 🙂
                                A Former User last edited by Negalein
                                Das geht, als Beispiel habe ich ein Objekt unter javascript angelegt mit dem Namen film. Den simpleAPI Adapter musst du installiert haben.
                                Per ssh einlogen und ein bash Script anlegen mit folgendem Inhalt:
                                #!/bin/bash
                                wget -qO- http://iobroker_ip:8087/set/javascript.0.film?value=true &> /dev/null
                                ffmpeg -y -i http://user:passwort@192.255.255.255/Streaming/channels/1/httpPreview -t 10 -f mp4 -vcodec libx264 -pix_fmt yuv420p -an -vf scale=w=640:h=360:force_original_aspect_ratio=decrease -r 20 /opt/iobroker/cam/film.mp4
                                wget -qO- http://iobroker_ip:8087/set/javascript.0.film?value=false &> /dev/null
                                Dieses Script ausführbar machen: chmod +x /pfad/zu_deinem_script
                                Nun solltest du noch dein Script/Blockly abändern damit das bash Script gestartet wird. Somit wird das Objekt film geändert und du könnest darauf triggern. Du musst natürlich die Pfade und IP Adressen im Script anpassen!
                                Ich hoffe ich habe es verständlich erklärt.. :oops:
                                  cool danke .. werde ich asap probieren und "Erfolg" oder "Hilfe' rufen 🙂
                                  Gesendet von meinem BLA-L29 mit Tapatalk
                                    @Brainbug:
                                    *snip `
                                    Sehr cool .. vielen Dank .. eine Frage .. was macht "-qO-"? .. Hab mal nur "-q" draus gemacht .. falsch?
                                      Dann wird eine Datei angelegt anstatt nur die URL aufzurufen. Müsstest sehen in dem Verzeichnis in dem du das Script ausführst.
                                        @Brainbug:
                                        Dann wird eine Datei angelegt anstatt nur die URL aufzurufen. Müsstest sehen in dem Verzeichnis in dem du das Script ausführst. `
                                        Hmm .. URL-Aufruf reicht doch .. also -q scheint ok zu sein. Jetzt überleg ich grad ob das so schon rund ist. Mehrfache Auslösung sollte kein Problem sein aber es Könnte noch ein Problem geben, wenn das Telegram Blockly noch am senden ist und derweil schon ein neuer Stream gerendert wird.
                                          Bei meinem Test hat -q nicht gereicht. Jedesmal beim Aufruf hat er eine Datei in das Verzeichnis abgelegt.
                                          Du hast ja jetzt einen Ansatz den du nach Belieben ausbauen kannst.
                                            @Brainbug:
                                            Du hast ja jetzt einen Ansatz den du nach Belieben ausbauen kannst. `
                                            hatte Dich genau andersrum verstanden .. dann mach ich auch -q0- .. 🙂
                                            Hatte dazu in der Doku nichts gefunden .. aber auch nicht wirklich lange gesucht.
                                            157
                                            45029
