    4. Blockly - Pushover & Attachment
      Kuddel last edited by
      root@ioBroker-TEST:~# npm install pushover-notifications
      npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
      npm WARN root No description
      npm WARN root No repository field.
      npm WARN root No README data
      npm WARN root No license field.
      + pushover-notifications@1.2.0
      updated 1 package and audited 15 packages in 1.176s
      found 0 vulnerabilities
      • Dutchman
        Logisch, du bist nicht im ioBroker Verzeichnis!
        Also erst````
        cd /opt/iobroker
          root@ioBroker-TEST:~# cd /opt/iobroker/
          root@ioBroker-TEST:/opt/iobroker# npm install pushover-notifications
          > bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
          > node-gyp rebuild
          make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird betreten
            CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
          In file included from ../node_modules/nan/nan.h:82:0,
                           from ../src/bufferutil.cc:16:
          ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Int32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
          ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           To<v8::int32>(v8::Handle <v8::integer>i)   { return i->ToInt32(); }
          In file included from ../src/bufferutil.cc:7:0:
          /root/.node-gyp/8.11.3/include/node/v8.h:9796:14: note: declared here
           Local <int32>Value::ToInt32() const {
          ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Uint32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
          ../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local <v8::uint32>v8::Value::ToUint32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           To<v8::uint32>(v8::Handle <v8::integer>i)  { return i->ToUint32(); }
          /root/.node-gyp/8.11.3/include/node/v8.h:9790:15: note: declared here
           Local <uint32>Value::ToUint32() const {
          In file included from ../node_modules/nan/nan_new.h:189:0,
                           from ../node_modules/nan/nan.h:82,
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::booleanobject>::return_t NanIntern::Factory<v8::booleanobject>::New(bool)’:
          ../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local <v8::value>v8::BooleanObject::New(bool)’ is deprecated: Pass an isolate [-Wdeprecated-declarations]
             return v8::BooleanObject::New(value).As<v8::booleanobject>();
          In file included from /root/.node-gyp/8.11.3/include/node/v8.h:26:0,
          /root/.node-gyp/8.11.3/include/node/v8.h:4845:56: note: declared here
             V8_DEPRECATED("Pass an isolate", static Local <value>New(bool value));
          /root/.node-gyp/8.11.3/include/node/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
             declarator __attribute__((deprecated(message)))
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::script>::return_t NanIntern::Factory<v8::script>::New(v8::Local<v8::string>)’:
          ../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local <v8::script>v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
          /root/.node-gyp/8.11.3/include/node/v8.h:1425:21: note: declared here
                 Local</v8::script></v8::string></v8::script></v8::script></value></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></uint32></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></int32></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer>
          • Dutchman
            Geht doch Installation gelungen welche Version steht jetzt bei deinen Adaptern ?
              Rambo79 last edited by
              Hab den selben Fehler gemacht. War auch nicht ioB Verzeichnis
                • Dutchman
                  Sieht soweit OK aus
                    Leider nichts bzgl. Anhang zu erkennen
                    • Dutchman
                      System Neustart könnte auch Mal helfen nach Al dem gefummel und Browser + Cache refresh
                        @Dutchman:
                        Sent from my iPhone using Tapatalk `
                        ioBroker und Browser neu gestartet, leider keine Verbesserung
                        • Dutchman
                          Mit Shift F5 Browser refresh UND cahe gelöscht ?
                            @Dutchman:
                            Hat auch keinen Erfolg gebracht.
                            Was mich auf jeden Fall wundert, ist die Version, die angezeigt.
                            Per Console uwrde ja Version 1.2.0 installiert.
                            In der Adapter-Übersicht steht aber immer noch Version 1.1.0
                            • Dutchman
                              Hmm dann ist doch die ältere Version installiert.
                              Also nochmal per github installieren und dann den Upload Befehl und nicht aus npm (da ist die neuere Version noch nicht bekannt)
                              • FredF
                                FredF Most Active Forum Testing last edited by
                                @Kev0:
                                Issues würden geschlossen und gemerged, sollte jetzt gehen:
                                https://github.com/qbit/node-pushover/b … /README.md
                                Wer ist so nett und adaptiert die blockly Variante? :oops:
                                Kevin ` Diese Repo hat doch nichts mit iobroker zu tun…
                                Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
                                  dtp last edited by
                                  @FredF:
                                  Diese Repo hat doch nichts mit iobroker zu tun… `
                                  Genau. Der Pushover-Adapter 1.1.0 des ioBroker ist etwas anderes, als die npm-Version 1.2.0 der pushover-notifications. Ich befürchte, dass auch die Version 1.1.0 des Pushover-Adapters leider noch nicht mit Attachments umgehen kann.
                                  Würde mich aber auch sehr freuen, wenn das bald mal ginge, damit ich meine mit dem phantomjs-Adapter erstellten Screenshots per Pushover verschicken kann.
                                  • Dutchman
                                    Ist dazu bereits ein issue erstellt für den ioBroker pushover Adapter?
                                      Kev0 last edited by
                                      Ja, darum habe ich ja gefragt ob jemand das dort implementieren kann.
                                      https://github.com/ioBroker/ioBroker.pushover/issues/5
                                      Ist mir schon klar gewesen das die zuvor genannte Repo nicht für iobroker war…
                                      SebastianSchultz created this issue in ioBroker/ioBroker.pushover
                                      closed Implement usage of attachments #5
                                      • Dutchman
                                        Dachte mir bereits dass wir hier von 2 verschiedenen Sachen reden.
                                        Vor 1nem Monat wurde die dependency gelöst im pushover npm Paket, ich habe das in git verlinkt nöste Frage ist wann der Entwickler Zeit hat sich die an zu nehmen 😉
                                          dtp last edited by
                                          Hängt die Änderung in Blockly direkt mit der Änderung des Pushover-Adapters zusammen? Evtl. könnte man das ja getrennt voneinander machen. Im Pushover-Adapter müsste man ja theoretisch nur das aktuelle npm-Repository von pushover-notifications einbinden, oder? Dann könnten zumindest schon mal die mit Attachments arbeiten, die den Pushover-Adapter direkt per Javaskript aufrufen.
                                          Oder geht das sogar schon direkt durch Aufruf von
                                          Gruß,
                                          Thorsten
                                          • Dutchman
                                            Hängt miteinander zusammen
                                            79.9k
                                            5479
