    4. [Aufruf] ZigBee CC253x Adapter
      dimaiv last edited by
      @dimaiv:
      @arteck:
      @dimaiv:
      Hi Arteck,
      ich habe neue Fehler entdeckt:
      No state available for '4052899926110' with key 'transition_time'
      Vor paar Tagen hat noch funktioniert.
      Danke. `
      bissel mehr infos muss du mir schon geben.. was ist das für ein Device ?? Adapter Version ?? `
      Device: LIGHTIFY Indoor Flex RGBW
      7cb03eaa00adea74
      Adapter: 0.8.0b, aktuelste aus deinem repo.
      P.S.: habe gerade über dein repo aktualisiert, und ist ganz kaputt gegangen:
      ! 018-11-28 21:25:08.084 info Restart adapter system.adapter.zigbee.0 because enabled
      ! host.raspberrypi 2018-11-28 21:25:08.084 error instance system.adapter.zigbee.0 terminated with code 6 (uncaught exception)
      ! Caught 2018-11-28 21:25:08.084 error by controller[7]: 2018-11-28T20:25:07.084Z zigbee:controller info zigbee-shepherd stopped undefined
      ! Caught 2018-11-28 21:25:08.084 error by controller[6]: Wed, 28 Nov 2018 20:25:07 GMT zigbee-shepherd zigbee-shepherd is stopped.
      ! Caught 2018-11-28 21:25:08.084 error by controller[5]: Wed, 28 Nov 2018 20:25:07 GMT cc-znp The serialport /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000E896DEE-if00 is closed.
      ! Caught 2018-11-28 21:25:08.083 error by controller[4]: Wed, 28 Nov 2018 20:25:07 GMT cc-znp:SREQ –> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
      ! Caught 2018-11-28 21:25:08.083 error by controller[3]: Wed, 28 Nov 2018 20:25:07 GMT zigbee-shepherd:request REQ –> ZDO:mgmtPermitJoinReq
      ! Caught 2018-11-28 21:25:08.083 error by controller[2]: Wed, 28 Nov 2018 20:25:07 GMT zigbee-shepherd zigbee-shepherd is stopping.
      ! Caught 2018-11-28 21:25:08.083 error by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! Caught 2018-11-28 21:25:08.083 error by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! Caught 2018-11-28 21:25:08.083 error by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      ! Caught 2018-11-28 21:25:08.082 error by controller[1]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      ! Caught 2018-11-28 21:25:08.082 error by controller[1]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:727:17)
      ! Caught 2018-11-28 21:25:08.082 error by controller[1]: at options (/opt/iobroker/node_modules/iobroker.zigbee/main.js:87:21)
      ! Caught 2018-11-28 21:25:08.082 error by controller[1]: at publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:576:15)
      ! Caught 2018-11-28 21:25:08.082 error by controller[1]: at Array.forEach (<anonymous>)
      ! Caught 2018-11-28 21:25:08.082 error by controller[1]: at stateList.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:593:35)
      ! Caught 2018-11-28 21:25:08.081 error by controller[1]: at Object.convert (/opt/iobroker/node_modules/zigbee-shepherd-converters/converters/toZigbee.js:65:27)
      ! Caught 2018-11-28 21:25:08.081 error by controller[1]: TypeError: value.includes is not a function
      ! zigbee.0 2018-11-28 21:25:07.085 info zigbee-shepherd stopped
      ! zigbee.0 2018-11-28 21:25:07.050 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! zigbee.0 2018-11-28 21:25:07.050 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! zigbee.0 2018-11-28 21:25:07.050 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      ! zigbee.0 2018-11-28 21:25:07.050 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      ! zigbee.0 2018-11-28 21:25:07.050 error at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:727:17)
      ! zigbee.0 2018-11-28 21:25:07.050 error at options (/opt/iobroker/node_modules/iobroker.zigbee/main.js:87:21)
      ! zigbee.0 2018-11-28 21:25:07.050 error at publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:576:15)
      ! zigbee.0 2018-11-28 21:25:07.050 error at Array.forEach (<anonymous>)
      ! zigbee.0 2018-11-28 21:25:07.050 error at stateList.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:593:35)
      ! zigbee.0 2018-11-28 21:25:07.050 error at Object.convert (/opt/iobroker/node_modules/zigbee-shepherd-converters/converters/toZigbee.js:65:27)
      ! zigbee.0 2018-11-28 21:25:07.050 error TypeError: value.includes is not a function
      ! zigbee.0 2018-11-28 21:25:07.048 error uncaught exception: value.includes is not a function</anonymous></anonymous></anonymous></anonymous> `
      ich habe gerade iobroker komplett neue installiert und neueste Adapter 0.8.0 von Iliy genommen.
      Transition Time fehlt auch da.
      und dazu kommen sehr viele Fehler beim Adapter neue starten, beim Geräte anlernen und zwischen durch.
      ! host.ioBroker-RasPi 2018-11-29 17:32:44.628 info instance system.adapter.zigbee.0 started with pid 7389
      ! host.ioBroker-RasPi 2018-11-29 17:32:42.174 info instance system.adapter.zigbee.0 terminated with code 0 (OK)
      ! Caught 2018-11-29 17:32:42.174 error by controller[3]: Thu, 29 Nov 2018 16:32:42 GMT cc-znp:SREQ –> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
      ! Caught 2018-11-29 17:32:42.174 error by controller[2]: Thu, 29 Nov 2018 16:32:42 GMT zigbee-shepherd:request REQ –> ZDO:mgmtPermitJoinReq
      ! Caught 2018-11-29 17:32:42.173 error by controller[1]: Thu, 29 Nov 2018 16:32:42 GMT zigbee-shepherd zigbee-shepherd is stopping.
      ! host.ioBroker-RasPi 2018-11-29 17:32:42.100 info stopInstance system.adapter.zigbee.0 killing pid 6303
      ! host.ioBroker-RasPi 2018-11-29 17:32:42.099 info stopInstance system.adapter.zigbee.0
      ! 2018-11-29 17:11:30.227 - info: zigbee.0 List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyACM0"}]
      ! 2018-11-29 17:12:01.182 - info: host.ioBroker-RasPi object change system.adapter.zigbee.0
      ! 2018-11-29 17:12:01.183 - info: host.ioBroker-RasPi stopInstance system.adapter.zigbee.0
      ! 2018-11-29 17:12:01.184 - info: host.ioBroker-RasPi stopInstance system.adapter.zigbee.0 killing pid 4388
      ! 2018-11-29 17:12:01.256 - error: Caught by controller[1]: Thu, 29 Nov 2018 16:11:31 GMT cc-znp:AREQ <– ZDO:mgmtLqiRsp, { srcaddr: 50604, status: 0, neighbortableentries: 3, startindex: 0, neighborlqilistcount: 3, neighborlqilist: [ { extPandId: '0xdddddddddddddddd', extAddr: '0x00124b000e896dee', nwkAddr: 0, deviceType: 0, rxOnWhenIdle: 1, relationship: 0, permitJoin: 1, depth: 1, lqi: 40 }, { extPandId: '0xdddddddddddddddd', extAddr: '0x84182600000c9d11', nwkAddr: 32839, deviceType: 1, rxOnWhenIdle: 1, relationship: 2, permitJoin: 1, depth: 1, lqi: 34 }, { extPandId: '0xdddddddddddddddd', extAddr: '0x7cb03eaa00adf023', nwkAddr: 14811, deviceType: 1, rxOnWhenIdle: 1, relationship: 2, permitJoin: 1, depth: 1, lqi: 46 } ] }
      ! 2018-11-29 17:12:01.257 - error: Caught by controller[2]: Thu, 29 Nov 2018 16:11:31 GMT zigbee-shepherd:msgHdlr IND <– ZDO:mgmtLqiRsp
      ! 2018-11-29 17:12:01.257 - error: Caught by controller[3]: Thu, 29 Nov 2018 16:11:31 GMT zigbee-shepherd:request REQ –> ZDO:mgmtLqiReq
      ! 2018-11-29 17:12:01.258 - error: Caught by controller[4]: Thu, 29 Nov 2018 16:11:31 GMT cc-znp:SREQ –> ZDO:mgmtLqiReq, { dstaddr: 14811, scanchannels: undefined, scanduration: undefined, startindex: 0 }
      ! 2018-11-29 17:12:01.258 - error: Caught by controller[5]: Thu, 29 Nov 2018 16:11:31 GMT cc-znp:SRSP <– ZDO:mgmtLqiReq, { status: 0 }
      ! 2018-11-29 17:12:01.258 - error: Caught by controller[6]: Thu, 29 Nov 2018 16:11:31 GMT cc-znp:AREQ <– ZDO:mgmtLqiRsp, { srcaddr: 14811, status: 0, neighbortableentries: 3, startindex: 0, neighborlqilistcount: 3, neighborlqilist: [ { extPandId: '0xdddddddddddddddd', extAddr: '0x00124b000e896dee', nwkAddr: 0, deviceType: 0, rxOnWhenIdle: 1, relationship: 0, permitJoin: 1, depth: 1, lqi: 38 }, { extPandId: '0xdddddddddddddddd', extAddr: '0x84182600000c9d11', nwkAddr: 32839, deviceType: 1, rxOnWhenIdle: 1, relationship: 2, permitJoin: 1, depth: 1, lqi: 12 }, { extPandId: '0xdddddddddddddddd', extAddr: '0x7cb03eaa00adea74', nwkAddr: 50604, deviceType: 1, rxOnWhenIdle: 1, relationship: 2, permitJoin: 1, depth: 1, lqi: 46 } ] }
      ! 2018-11-29 17:12:01.259 - error: Caught by controller[7]: Thu, 29 Nov 2018 16:11:31 GMT zigbee-shepherd:msgHdlr IND <– ZDO:mgmtLqiRsp
      ! 2018-11-29 17:12:01.259 - error: Caught by controller[8]: 2018-11-29T16:11:31.727Z zigbee:controller debug lqiScan result: [ { ieeeAddr: '0x84182600000c9d11',
      ! 2018-11-29 17:12:01.259 - error: Caught by controller[8]: nwkAddr: 32839,
      ! 2018-11-29 17:12:01.259 - error: Caught by controller[8]: lqi: 12,
      ! 2018-11-29 17:12:01.260 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.260 - error: Caught by controller[8]: deviceType: 1,
      ! 2018-11-29 17:12:01.260 - error: Caught by controller[8]: parent: '0x7cb03eaa00adf023',
      ! 2018-11-29 17:12:01.261 - error: Caught by controller[8]: status: 'online' },
      ! 2018-11-29 17:12:01.261 - error: Caught by controller[8]: { ieeeAddr: '0x7cb03eaa00adea74',
      ! 2018-11-29 17:12:01.261 - error: Caught by controller[8]: nwkAddr: 50604,
      ! 2018-11-29 17:12:01.261 - error: Caught by controller[8]: lqi: 46,
      ! 2018-11-29 17:12:01.262 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.262 - error: Caught by controller[8]: deviceType: 1,
      ! 2018-11-29 17:12:01.262 - error: Caught by controller[8]: parent: '0x7cb03eaa00adf023',
      ! 2018-11-29 17:12:01.262 - error: Caught by controller[8]: status: 'offline' },
      ! 2018-11-29 17:12:01.263 - error: Caught by controller[8]: { ieeeAddr: '0x7cb03eaa00adf023',
      ! 2018-11-29 17:12:01.263 - error: Caught by controller[8]: nwkAddr: 14811,
      ! 2018-11-29 17:12:01.263 - error: Caught by controller[8]: lqi: 46,
      ! 2018-11-29 17:12:01.264 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.264 - error: Caught by controller[8]: deviceType: 1,
      ! 2018-11-29 17:12:01.264 - error: Caught by controller[8]: parent: '0x7cb03eaa00adea74',
      ! 2018-11-29 17:12:01.264 - error: Caught by controller[8]: status: 'offline' },
      ! 2018-11-29 17:12:01.265 - error: Caught by controller[8]: { ieeeAddr: '0x00158d0001f532ce',
      ! 2018-11-29 17:12:01.265 - error: Caught by controller[8]: nwkAddr: 34624,
      ! 2018-11-29 17:12:01.265 - error: Caught by controller[8]: lqi: 27,
      ! 2018-11-29 17:12:01.265 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.266 - error: Caught by controller[8]: deviceType: 2,
      ! 2018-11-29 17:12:01.266 - error: Caught by controller[8]: parent: '0x00124b000e896dee',
      ! 2018-11-29 17:12:01.266 - error: Caught by controller[8]: status: 'online' },
      ! 2018-11-29 17:12:01.267 - error: Caught by controller[8]: { ieeeAddr: '0x00158d0001df05e1',
      ! 2018-11-29 17:12:01.267 - error: Caught by controller[8]: nwkAddr: 38613,
      ! 2018-11-29 17:12:01.267 - error: Caught by controller[8]: lqi: 18,
      ! 2018-11-29 17:12:01.267 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.268 - error: Caught by controller[8]: deviceType: 2,
      ! 2018-11-29 17:12:01.268 - error: Caught by controller[8]: parent: '0x00124b000e896dee',
      ! 2018-11-29 17:12:01.268 - error: Caught by controller[8]: status: 'online' },
      ! 2018-11-29 17:12:01.268 - error: Caught by controller[8]: { ieeeAddr: '0x00158d00028f6b16',
      ! 2018-11-29 17:12:01.269 - error: Caught by controller[8]: nwkAddr: 59431,
      ! 2018-11-29 17:12:01.269 - error: Caught by controller[8]: lqi: 90,
      ! 2018-11-29 17:12:01.269 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.270 - error: Caught by controller[8]: deviceType: 2,
      ! 2018-11-29 17:12:01.270 - error: Caught by controller[8]: parent: '0x84182600000c9d11',
      ! 2018-11-29 17:12:01.270 - error: Caught by controller[8]: status: 'online' },
      ! 2018-11-29 17:12:01.270 - error: Caught by controller[8]: { ieeeAddr: '0x00158d0002a91e86',
      ! 2018-11-29 17:12:01.271 - error: Caught by controller[8]: nwkAddr: 57350,
      ! 2018-11-29 17:12:01.271 - error: Caught by controller[8]: lqi: 100,
      ! 2018-11-29 17:12:01.271 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.271 - error: Caught by controller[8]: deviceType: 2,
      ! 2018-11-29 17:12:01.272 - error: Caught by controller[8]: parent: '0x84182600000c9d11',
      ! 2018-11-29 17:12:01.272 - error: Caught by controller[8]: status: 'online' },
      ! 2018-11-29 17:12:01.272 - error: Caught by controller[8]: { ieeeAddr: '0x00158d000255ef1b',
      ! 2018-11-29 17:12:01.273 - error: Caught by controller[8]: nwkAddr: 13082,
      ! 2018-11-29 17:12:01.273 - error: Caught by controller[8]: lqi: 38,
      ! 2018-11-29 17:12:01.273 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.273 - error: Caught by controller[8]: deviceType: 2,
      ! 2018-11-29 17:12:01.274 - error: Caught by controller[8]: parent: '0x84182600000c9d11',
      ! 2018-11-29 17:12:01.274 - error: Caught by controller[8]: status: 'online' },
      ! 2018-11-29 17:12:01.274 - error: Caught by controller[8]: { ieeeAddr: '0x00124b000e896dee',
      ! 2018-11-29 17:12:01.274 - error: Caught by controller[8]: nwkAddr: 0,
      ! 2018-11-29 17:12:01.275 - error: Caught by controller[8]: lqi: 38,
      ! 2018-11-29 17:12:01.275 - error: Caught by controller[8]: depth: 1,
      ! 2018-11-29 17:12:01.275 - error: Caught by controller[8]: deviceType: 0,
      ! 2018-11-29 17:12:01.276 - error: Caught by controller[8]: parent: '0x7cb03eaa00adf023',
      ! 2018-11-29 17:12:01.276 - error: Caught by controller[8]: status: 'online' } ]
      ! 2018-11-29 17:12:01.276 - error: Caught by controller[9]: Thu, 29 Nov 2018 16:11:32 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 78 }
      ! 2018-11-29 17:12:01.276 - error: Caught by controller[10]: Thu, 29 Nov 2018 16:11:32 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.277 - error: Caught by controller[10]: Thu, 29 Nov 2018 16:11:32 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 78
      ! 2018-11-29 17:12:01.277 - error: Caught by controller[11]: Thu, 29 Nov 2018 16:11:32 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 5, srcaddr: 13082, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 115, securityuse: 0, timestamp: 3218896, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.277 - error: Caught by controller[12]: Thu, 29 Nov 2018 16:11:32 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.277 - error: Caught by controller[13]: Thu, 29 Nov 2018 16:11:32 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.277 - error: Caught by controller[14]: 2018-11-29T16:11:32.029Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.277 - error: Caught by controller[14]: clusterid: 5,
      ! 2018-11-29 17:12:01.278 - error: Caught by controller[14]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.278 - error: Caught by controller[14]: srcendpoint: 1,
      ! 2018-11-29 17:12:01.278 - error: Caught by controller[14]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.278 - error: Caught by controller[14]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.278 - error: Caught by controller[14]: linkquality: 115,
      ! 2018-11-29 17:12:01.278 - error: Caught by controller[14]: securityuse: 0,
      ! 2018-11-29 17:12:01.278 - error: Caught by controller[14]: timestamp: 3218896,
      ! 2018-11-29 17:12:01.279 - error: Caught by controller[14]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.279 - error: Caught by controller[14]: len: 5,
      ! 2018-11-29 17:12:01.279 - error: Caught by controller[14]: data: { '0': 24, '1': 78, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.279 - error: Caught by controller[14]: zclMsg:
      ! 2018-11-29 17:12:01.279 - error: Caught by controller[14]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.279 - error: Caught by controller[14]: manufCode: 0,
      ! 2018-11-29 17:12:01.279 - error: Caught by controller[14]: seqNum: 78,
      ! 2018-11-29 17:12:01.280 - error: Caught by controller[14]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.280 - error: Caught by controller[14]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.280 - error: Caught by controller[15]: Thu, 29 Nov 2018 16:11:32 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.280 - error: Caught by controller[16]: 2018-11-29T16:11:32.032Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.280 - error: Caught by controller[16]: status: { endpoint: { current: 1, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.280 - error: Caught by controller[16]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.281 - error: Caught by controller[17]: 2018-11-29T16:11:32.033Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.281 - error: Caught by controller[17]: status: { endpoint: { current: 1, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.281 - error: Caught by controller[17]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 1, progress: 57 }
      ! 2018-11-29 17:12:01.281 - error: Caught by controller[18]: Thu, 29 Nov 2018 16:11:32 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 79
      ! 2018-11-29 17:12:01.281 - error: Caught by controller[19]: Thu, 29 Nov 2018 16:11:32 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 1, srcendpoint: 1, clusterid: 18, transid: 79, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.281 - error: Caught by controller[20]: Thu, 29 Nov 2018 16:11:32 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.282 - error: Caught by controller[21]: Thu, 29 Nov 2018 16:11:32 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.282 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 79 }
      ! 2018-11-29 17:12:01.282 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.282 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 79
      ! 2018-11-29 17:12:01.282 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 18, srcaddr: 13082, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 118, securityuse: 0, timestamp: 3229008, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.282 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.282 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.283 - error: Caught by controller[22]: 2018-11-29T16:11:35.258Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.283 - error: Caught by controller[22]: clusterid: 18,
      ! 2018-11-29 17:12:01.283 - error: Caught by controller[22]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.283 - error: Caught by controller[22]: srcendpoint: 1,
      ! 2018-11-29 17:12:01.283 - error: Caught by controller[22]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.283 - error: Caught by controller[22]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.284 - error: Caught by controller[22]: linkquality: 118,
      ! 2018-11-29 17:12:01.284 - error: Caught by controller[22]: securityuse: 0,
      ! 2018-11-29 17:12:01.284 - error: Caught by controller[22]: timestamp: 3229008,
      ! 2018-11-29 17:12:01.284 - error: Caught by controller[22]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.284 - error: Caught by controller[22]: len: 5,
      ! 2018-11-29 17:12:01.284 - error: Caught by controller[22]: data: { '0': 24, '1': 79, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.284 - error: Caught by controller[22]: zclMsg:
      ! 2018-11-29 17:12:01.285 - error: Caught by controller[22]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.285 - error: Caught by controller[22]: manufCode: 0,
      ! 2018-11-29 17:12:01.285 - error: Caught by controller[22]: seqNum: 79,
      ! 2018-11-29 17:12:01.285 - error: Caught by controller[22]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.285 - error: Caught by controller[22]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.285 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.285 - error: Caught by controller[22]: 2018-11-29T16:11:35.264Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.286 - error: Caught by controller[22]: status: { endpoint: { current: 1, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.286 - error: Caught by controller[22]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.286 - error: Caught by controller[22]: 2018-11-29T16:11:35.265Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.286 - error: Caught by controller[22]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 1, progress: 71 }
      ! 2018-11-29 17:12:01.286 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 80
      ! 2018-11-29 17:12:01.286 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 1, srcendpoint: 1, clusterid: 25, transid: 80, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.286 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.287 - error: Caught by controller[22]: Thu, 29 Nov 2018 16:11:35 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.287 - error: Caught by controller[23]: Thu, 29 Nov 2018 16:11:37 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 257, srcaddr: 57350, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 102, securityuse: 0, timestamp: 3235810, transseqnumber: 0, len: 10, data: }
      ! 2018-11-29 17:12:01.287 - error: Caught by controller[23]: Thu, 29 Nov 2018 16:11:37 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.287 - error: Caught by controller[23]: Thu, 29 Nov 2018 16:11:37 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.287 - error: Caught by controller[23]: 2018-11-29T16:11:37.432Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.287 - error: Caught by controller[23]: clusterid: 257,
      ! 2018-11-29 17:12:01.288 - error: Caught by controller[23]: srcaddr: 57350,
      ! 2018-11-29 17:12:01.288 - error: Caught by controller[23]: srcendpoint: 1,
      ! 2018-11-29 17:12:01.288 - error: Caught by controller[23]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.288 - error: Caught by controller[23]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.288 - error: Caught by controller[23]: linkquality: 102,
      ! 2018-11-29 17:12:01.288 - error: Caught by controller[23]: securityuse: 0,
      ! 2018-11-29 17:12:01.288 - error: Caught by controller[23]: timestamp: 3235810,
      ! 2018-11-29 17:12:01.289 - error: Caught by controller[23]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.289 - error: Caught by controller[23]: len: 10,
      ! 2018-11-29 17:12:01.289 - error: Caught by controller[23]: data:
      ! 2018-11-29 17:12:01.289 - error: Caught by controller[23]: { '0': 24,
      ! 2018-11-29 17:12:01.289 - error: Caught by controller[23]: '1': 44,
      ! 2018-11-29 17:12:01.289 - error: Caught by controller[23]: '2': 10,
      ! 2018-11-29 17:12:01.289 - error: Caught by controller[23]: '3': 5,
      ! 2018-11-29 17:12:01.289 - error: Caught by controller[23]: '4': 5,
      ! 2018-11-29 17:12:01.290 - error: Caught by controller[23]: '5': 35,
      ! 2018-11-29 17:12:01.290 - error: Caught by controller[23]: '6': 0,
      ! 2018-11-29 17:12:01.290 - error: Caught by controller[23]: '7': 0,
      ! 2018-11-29 17:12:01.290 - error: Caught by controller[23]: '8': 120,
      ! 2018-11-29 17:12:01.290 - error: Caught by controller[23]: '9': 0 },
      ! 2018-11-29 17:12:01.290 - error: Caught by controller[23]: zclMsg:
      ! 2018-11-29 17:12:01.290 - error: Caught by controller[23]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.291 - error: Caught by controller[23]: manufCode: 0,
      ! 2018-11-29 17:12:01.291 - error: Caught by controller[23]: seqNum: 44,
      ! 2018-11-29 17:12:01.291 - error: Caught by controller[23]: cmdId: 'report',
      ! 2018-11-29 17:12:01.291 - error: Caught by controller[23]: payload: [ [Object] ] } } { modelId: 'lumi.vibration.aq1' }
      ! 2018-11-29 17:12:01.291 - error: Caught by controller[23]: Thu, 29 Nov 2018 16:11:37 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.291 - error: Caught by controller[23]: 2018-11-29T16:11:37.437Z zigbee:controller debug handleMessage { type: 'attReport',
      ! 2018-11-29 17:12:01.291 - error: Caught by controller[23]: endpoints:
      ! 2018-11-29 17:12:01.292 - error: Caught by controller[23]: [ Endpoint {
      ! 2018-11-29 17:12:01.292 - error: Caught by controller[23]: isLocal: [Function],
      ! 2018-11-29 17:12:01.292 - error: Caught by controller[23]: device: [Object],
      ! 2018-11-29 17:12:01.292 - error: Caught by controller[23]: profId: 260,
      ! 2018-11-29 17:12:01.292 - error: Caught by controller[23]: epId: 1,
      ! 2018-11-29 17:12:01.292 - error: Caught by controller[23]: devId: 10,
      ! 2018-11-29 17:12:01.292 - error: Caught by controller[23]: inClusterList: [Array],
      ! 2018-11-29 17:12:01.293 - error: Caught by controller[23]: outClusterList: [Array],
      ! 2018-11-29 17:12:01.293 - error: Caught by controller[23]: clusters: [Object],
      ! 2018-11-29 17:12:01.293 - error: Caught by controller[23]: onAfDataConfirm: null,
      ! 2018-11-29 17:12:01.293 - error: Caught by controller[23]: onAfReflectError: null,
      ! 2018-11-29 17:12:01.293 - error: Caught by controller[23]: onAfIncomingMsg: null,
      ! 2018-11-29 17:12:01.293 - error: Caught by controller[23]: onAfIncomingMsgExt: null,
      ! 2018-11-29 17:12:01.293 - error: Caught by controller[23]: onZclFoundation: null,
      ! 2018-11-29 17:12:01.294 - error: Caught by controller[23]: onZclFunctional: null,
      ! 2018-11-29 17:12:01.294 - error: Caught by controller[23]: foundation: [Function],
      ! 2018-11-29 17:12:01.294 - error: Caught by controller[23]: functional: [Function],
      ! 2018-11-29 17:12:01.294 - error: Caught by controller[23]: bind: [Function],
      ! 2018-11-29 17:12:01.294 - error: Caught by controller[23]: unbind: [Function],
      ! 2018-11-29 17:12:01.294 - error: Caught by controller[23]: read: [Function],
      ! 2018-11-29 17:12:01.294 - error: Caught by controller[23]: write: [Function],
      ! 2018-11-29 17:12:01.295 - error: Caught by controller[23]: report: [Function] } ],
      ! 2018-11-29 17:12:01.295 - error: Caught by controller[23]: data: { cid: 'closuresDoorLock', data: { '1285': 7864320 } },
      ! 2018-11-29 17:12:01.295 - error: Caught by controller[23]: linkquality: 102 }
      ! 2018-11-29 17:12:01.295 - error: Caught by controller[23]: 2018-11-29T16:11:37.440Z zigbee:controller event attReport { type: 'attReport',
      ! 2018-11-29 17:12:01.295 - error: Caught by controller[23]: endpoints:
      ! 2018-11-29 17:12:01.295 - error: Caught by controller[23]: [ Endpoint {
      ! 2018-11-29 17:12:01.296 - error: Caught by controller[23]: isLocal: [Function],
      ! 2018-11-29 17:12:01.296 - error: Caught by controller[23]: device: [Object],
      ! 2018-11-29 17:12:01.296 - error: Caught by controller[23]: profId: 260,
      ! 2018-11-29 17:12:01.296 - error: Caught by controller[23]: epId: 1,
      ! 2018-11-29 17:12:01.296 - error: Caught by controller[23]: devId: 10,
      ! 2018-11-29 17:12:01.296 - error: Caught by controller[23]: inClusterList: [Array],
      ! 2018-11-29 17:12:01.296 - error: Caught by controller[23]: outClusterList: [Array],
      ! 2018-11-29 17:12:01.297 - error: Caught by controller[23]: clusters: [Object],
      ! 2018-11-29 17:12:01.297 - error: Caught by controller[23]: onAfDataConfirm: null,
      ! 2018-11-29 17:12:01.297 - error: Caught by controller[23]: onAfReflectError: null,
      ! 2018-11-29 17:12:01.297 - error: Caught by controller[23]: onAfIncomingMsg: null,
      ! 2018-11-29 17:12:01.297 - error: Caught by controller[23]: onAfIncomingMsgExt: null,
      ! 2018-11-29 17:12:01.297 - error: Caught by controller[23]: onZclFoundation: null,
      ! 2018-11-29 17:12:01.297 - error: Caught by controller[23]: onZclFunctional: null,
      ! 2018-11-29 17:12:01.297 - error: Caught by controller[23]: foundation: [Function],
      ! 2018-11-29 17:12:01.298 - error: Caught by controller[23]: functional: [Function],
      ! 2018-11-29 17:12:01.298 - error: Caught by controller[23]: bind: [Function],
      ! 2018-11-29 17:12:01.298 - error: Caught by controller[23]: unbind: [Function],
      ! 2018-11-29 17:12:01.298 - error: Caught by controller[23]: read: [Function],
      ! 2018-11-29 17:12:01.298 - error: Caught by controller[23]: write: [Function],
      ! 2018-11-29 17:12:01.298 - error: Caught by controller[23]: report: [Function] } ],
      ! 2018-11-29 17:12:01.298 - error: Caught by controller[23]: data: { cid: 'closuresDoorLock', data: { '1285': 7864320 } },
      ! 2018-11-29 17:12:01.299 - error: Caught by controller[23]: linkquality: 102 } { cid: 'closuresDoorLock', modelId: 'lumi.vibration.aq1' }
      ! 2018-11-29 17:12:01.299 - error: Caught by controller[23]: 2018-11-29T16:11:37.444Z zigbee:controller debug handleMessage { type: 'devChange',
      ! 2018-11-29 17:12:01.299 - error: Caught by controller[23]: endpoints:
      ! 2018-11-29 17:12:01.299 - error: Caught by controller[23]: [ Endpoint {
      ! 2018-11-29 17:12:01.299 - error: Caught by controller[23]: isLocal: [Function],
      ! 2018-11-29 17:12:01.299 - error: Caught by controller[23]: device: [Object],
      ! 2018-11-29 17:12:01.299 - error: Caught by controller[23]: profId: 260,
      ! 2018-11-29 17:12:01.300 - error: Caught by controller[23]: epId: 1,
      ! 2018-11-29 17:12:01.300 - error: Caught by controller[23]: devId: 10,
      ! 2018-11-29 17:12:01.300 - error: Caught by controller[23]: inClusterList: [Array],
      ! 2018-11-29 17:12:01.300 - error: Caught by controller[23]: outClusterList: [Array],
      ! 2018-11-29 17:12:01.300 - error: Caught by controller[23]: clusters: [Object],
      ! 2018-11-29 17:12:01.300 - error: Caught by controller[23]: onAfDataConfirm: null,
      ! 2018-11-29 17:12:01.300 - error: Caught by controller[23]: onAfReflectError: null,
      ! 2018-11-29 17:12:01.301 - error: Caught by controller[23]: onAfIncomingMsg: null,
      ! 2018-11-29 17:12:01.301 - error: Caught by controller[23]: onAfIncomingMsgExt: null,
      ! 2018-11-29 17:12:01.301 - error: Caught by controller[23]: onZclFoundation: null,
      ! 2018-11-29 17:12:01.301 - error: Caught by controller[23]: onZclFunctional: null,
      ! 2018-11-29 17:12:01.301 - error: Caught by controller[23]: foundation: [Function],
      ! 2018-11-29 17:12:01.301 - error: Caught by controller[23]: functional: [Function],
      ! 2018-11-29 17:12:01.301 - error: Caught by controller[23]: bind: [Function],
      ! 2018-11-29 17:12:01.301 - error: Caught by controller[23]: unbind: [Function],
      ! 2018-11-29 17:12:01.302 - error: Caught by controller[23]: read: [Function],
      ! 2018-11-29 17:12:01.302 - error: Caught by controller[23]: write: [Function],
      ! 2018-11-29 17:12:01.302 - error: Caught by controller[23]: report: [Function] } ],
      ! 2018-11-29 17:12:01.302 - error: Caught by controller[23]: data: { cid: 'closuresDoorLock', data: { '1285': 7864320 } } }
      ! 2018-11-29 17:12:01.302 - error: Caught by controller[23]: 2018-11-29T16:11:37.447Z zigbee:controller event devChange { type: 'devChange',
      ! 2018-11-29 17:12:01.302 - error: Caught by controller[23]: endpoints:
      ! 2018-11-29 17:12:01.302 - error: Caught by controller[23]: [ Endpoint {
      ! 2018-11-29 17:12:01.303 - error: Caught by controller[23]: isLocal: [Function],
      ! 2018-11-29 17:12:01.303 - error: Caught by controller[23]: device: [Object],
      ! 2018-11-29 17:12:01.303 - error: Caught by controller[23]: profId: 260,
      ! 2018-11-29 17:12:01.303 - error: Caught by controller[23]: epId: 1,
      ! 2018-11-29 17:12:01.303 - error: Caught by controller[23]: devId: 10,
      ! 2018-11-29 17:12:01.303 - error: Caught by controller[23]: inClusterList: [Array],
      ! 2018-11-29 17:12:01.303 - error: Caught by controller[23]: outClusterList: [Array],
      ! 2018-11-29 17:12:01.304 - error: Caught by controller[23]: clusters: [Object],
      ! 2018-11-29 17:12:01.304 - error: Caught by controller[23]: onAfDataConfirm: null,
      ! 2018-11-29 17:12:01.304 - error: Caught by controller[23]: onAfReflectError: null,
      ! 2018-11-29 17:12:01.304 - error: Caught by controller[23]: onAfIncomingMsg: null,
      ! 2018-11-29 17:12:01.304 - error: Caught by controller[23]: onAfIncomingMsgExt: null,
      ! 2018-11-29 17:12:01.304 - error: Caught by controller[23]: onZclFoundation: null,
      ! 2018-11-29 17:12:01.304 - error: Caught by controller[23]: onZclFunctional: null,
      ! 2018-11-29 17:12:01.304 - error: Caught by controller[23]: foundation: [Function],
      ! 2018-11-29 17:12:01.305 - error: Caught by controller[23]: functional: [Function],
      ! 2018-11-29 17:12:01.305 - error: Caught by controller[23]: bind: [Function],
      ! 2018-11-29 17:12:01.305 - error: Caught by controller[23]: unbind: [Function],
      ! 2018-11-29 17:12:01.305 - error: Caught by controller[23]: read: [Function],
      ! 2018-11-29 17:12:01.305 - error: Caught by controller[23]: write: [Function],
      ! 2018-11-29 17:12:01.305 - error: Caught by controller[23]: report: [Function] } ],
      ! 2018-11-29 17:12:01.305 - error: Caught by controller[23]: data: { cid: 'closuresDoorLock', data: { '1285': 7864320 } } } { cid: 'closuresDoorLock', modelId: 'lumi.vibration.aq1' }
      ! 2018-11-29 17:12:01.306 - error: Caught by controller[24]: Thu, 29 Nov 2018 16:11:38 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 80 }
      ! 2018-11-29 17:12:01.306 - error: Caught by controller[25]: Thu, 29 Nov 2018 16:11:38 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.306 - error: Caught by controller[25]: Thu, 29 Nov 2018 16:11:38 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 80
      ! 2018-11-29 17:12:01.306 - error: Caught by controller[26]: Thu, 29 Nov 2018 16:11:38 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 25, srcaddr: 13082, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 118, securityuse: 0, timestamp: 3239108, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.306 - error: Caught by controller[27]: Thu, 29 Nov 2018 16:11:38 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.306 - error: Caught by controller[28]: Thu, 29 Nov 2018 16:11:38 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.307 - error: Caught by controller[29]: 2018-11-29T16:11:38.505Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.307 - error: Caught by controller[29]: clusterid: 25,
      ! 2018-11-29 17:12:01.307 - error: Caught by controller[29]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.307 - error: Caught by controller[29]: srcendpoint: 1,
      ! 2018-11-29 17:12:01.307 - error: Caught by controller[29]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.307 - error: Caught by controller[29]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.307 - error: Caught by controller[29]: linkquality: 118,
      ! 2018-11-29 17:12:01.307 - error: Caught by controller[29]: securityuse: 0,
      ! 2018-11-29 17:12:01.308 - error: Caught by controller[29]: timestamp: 3239108,
      ! 2018-11-29 17:12:01.308 - error: Caught by controller[29]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.308 - error: Caught by controller[29]: len: 5,
      ! 2018-11-29 17:12:01.308 - error: Caught by controller[29]: data: { '0': 24, '1': 80, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.308 - error: Caught by controller[29]: zclMsg:
      ! 2018-11-29 17:12:01.308 - error: Caught by controller[29]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.308 - error: Caught by controller[29]: manufCode: 0,
      ! 2018-11-29 17:12:01.309 - error: Caught by controller[29]: seqNum: 80,
      ! 2018-11-29 17:12:01.309 - error: Caught by controller[29]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.309 - error: Caught by controller[29]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.309 - error: Caught by controller[30]: Thu, 29 Nov 2018 16:11:38 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.309 - error: Caught by controller[31]: 2018-11-29T16:11:38.509Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.309 - error: Caught by controller[31]: status: { endpoint: { current: 1, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.309 - error: Caught by controller[31]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.310 - error: Caught by controller[31]: 2018-11-29T16:11:38.509Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.310 - error: Caught by controller[31]: status: { endpoint: { current: 1, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.310 - error: Caught by controller[31]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 1, progress: 86 }
      ! 2018-11-29 17:12:01.310 - error: Caught by controller[32]: Thu, 29 Nov 2018 16:11:38 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 81
      ! 2018-11-29 17:12:01.310 - error: Caught by controller[33]: Thu, 29 Nov 2018 16:11:38 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 1, srcendpoint: 1, clusterid: 65535, transid: 81, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.310 - error: Caught by controller[34]: Thu, 29 Nov 2018 16:11:38 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.310 - error: Caught by controller[35]: Thu, 29 Nov 2018 16:11:38 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.311 - error: Caught by controller[36]: Thu, 29 Nov 2018 16:11:41 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 81 }
      ! 2018-11-29 17:12:01.311 - error: Caught by controller[37]: Thu, 29 Nov 2018 16:11:41 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.311 - error: Caught by controller[38]: Thu, 29 Nov 2018 16:11:41 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 81
      ! 2018-11-29 17:12:01.311 - error: Caught by controller[39]: Thu, 29 Nov 2018 16:11:41 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 65535, srcaddr: 13082, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 115, securityuse: 0, timestamp: 3249209, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.311 - error: Caught by controller[40]: Thu, 29 Nov 2018 16:11:41 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.311 - error: Caught by controller[41]: Thu, 29 Nov 2018 16:11:41 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.311 - error: Caught by controller[42]: 2018-11-29T16:11:41.733Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.312 - error: Caught by controller[42]: clusterid: 65535,
      ! 2018-11-29 17:12:01.312 - error: Caught by controller[42]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.312 - error: Caught by controller[42]: srcendpoint: 1,
      ! 2018-11-29 17:12:01.312 - error: Caught by controller[42]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.312 - error: Caught by controller[42]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.312 - error: Caught by controller[42]: linkquality: 115,
      ! 2018-11-29 17:12:01.312 - error: Caught by controller[42]: securityuse: 0,
      ! 2018-11-29 17:12:01.313 - error: Caught by controller[42]: timestamp: 3249209,
      ! 2018-11-29 17:12:01.313 - error: Caught by controller[42]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.313 - error: Caught by controller[42]: len: 5,
      ! 2018-11-29 17:12:01.313 - error: Caught by controller[42]: data: { '0': 24, '1': 81, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.313 - error: Caught by controller[42]: zclMsg:
      ! 2018-11-29 17:12:01.313 - error: Caught by controller[42]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.313 - error: Caught by controller[42]: manufCode: 0,
      ! 2018-11-29 17:12:01.314 - error: Caught by controller[42]: seqNum: 81,
      ! 2018-11-29 17:12:01.314 - error: Caught by controller[42]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.314 - error: Caught by controller[42]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.314 - error: Caught by controller[43]: Thu, 29 Nov 2018 16:11:41 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.314 - error: Caught by controller[44]: 2018-11-29T16:11:41.741Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.314 - error: Caught by controller[44]: status: { endpoint: { current: 1, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.314 - error: Caught by controller[44]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.315 - error: Caught by controller[45]: 2018-11-29T16:11:41.743Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.315 - error: Caught by controller[45]: status: { endpoint: { current: 1, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.315 - error: Caught by controller[45]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 1, progress: 100 }
      ! 2018-11-29 17:12:01.315 - error: Caught by controller[46]: Thu, 29 Nov 2018 16:11:41 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 82
      ! 2018-11-29 17:12:01.315 - error: Caught by controller[47]: Thu, 29 Nov 2018 16:11:41 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 2, srcendpoint: 1, clusterid: 3, transid: 82, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.315 - error: Caught by controller[48]: Thu, 29 Nov 2018 16:11:41 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.315 - error: Caught by controller[49]: Thu, 29 Nov 2018 16:11:41 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.316 - error: Caught by controller[50]: Thu, 29 Nov 2018 16:11:44 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 82 }
      ! 2018-11-29 17:12:01.316 - error: Caught by controller[51]: Thu, 29 Nov 2018 16:11:44 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.316 - error: Caught by controller[51]: Thu, 29 Nov 2018 16:11:44 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 82
      ! 2018-11-29 17:12:01.316 - error: Caught by controller[52]: Thu, 29 Nov 2018 16:11:44 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 3, srcaddr: 13082, srcendpoint: 2, dstendpoint: 1, wasbroadcast: 0, linkquality: 118, securityuse: 0, timestamp: 3259326, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.316 - error: Caught by controller[53]: Thu, 29 Nov 2018 16:11:44 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.316 - error: Caught by controller[54]: Thu, 29 Nov 2018 16:11:44 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.317 - error: Caught by controller[55]: 2018-11-29T16:11:44.965Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.317 - error: Caught by controller[55]: clusterid: 3,
      ! 2018-11-29 17:12:01.317 - error: Caught by controller[55]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.317 - error: Caught by controller[55]: srcendpoint: 2,
      ! 2018-11-29 17:12:01.317 - error: Caught by controller[55]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.317 - error: Caught by controller[55]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.317 - error: Caught by controller[55]: linkquality: 118,
      ! 2018-11-29 17:12:01.317 - error: Caught by controller[55]: securityuse: 0,
      ! 2018-11-29 17:12:01.318 - error: Caught by controller[55]: timestamp: 3259326,
      ! 2018-11-29 17:12:01.318 - error: Caught by controller[55]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.318 - error: Caught by controller[55]: len: 5,
      ! 2018-11-29 17:12:01.318 - error: Caught by controller[55]: data: { '0': 24, '1': 82, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.318 - error: Caught by controller[55]: zclMsg:
      ! 2018-11-29 17:12:01.318 - error: Caught by controller[55]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.318 - error: Caught by controller[55]: manufCode: 0,
      ! 2018-11-29 17:12:01.319 - error: Caught by controller[55]: seqNum: 82,
      ! 2018-11-29 17:12:01.319 - error: Caught by controller[55]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.319 - error: Caught by controller[55]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.319 - error: Caught by controller[56]: Thu, 29 Nov 2018 16:11:44 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.319 - error: Caught by controller[57]: 2018-11-29T16:11:44.968Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.319 - error: Caught by controller[57]: status: { endpoint: { current: 2, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.319 - error: Caught by controller[57]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.320 - error: Caught by controller[58]: 2018-11-29T16:11:44.969Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.320 - error: Caught by controller[58]: status: { endpoint: { current: 2, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.320 - error: Caught by controller[58]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 2, progress: 25 }
      ! 2018-11-29 17:12:01.320 - error: Caught by controller[59]: Thu, 29 Nov 2018 16:11:44 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 83
      ! 2018-11-29 17:12:01.320 - error: Caught by controller[60]: Thu, 29 Nov 2018 16:11:44 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 2, srcendpoint: 1, clusterid: 4, transid: 83, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.320 - error: Caught by controller[61]: Thu, 29 Nov 2018 16:11:44 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.320 - error: Caught by controller[62]: Thu, 29 Nov 2018 16:11:44 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.321 - error: Caught by controller[63]: Thu, 29 Nov 2018 16:11:48 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 83 }
      ! 2018-11-29 17:12:01.321 - error: Caught by controller[64]: Thu, 29 Nov 2018 16:11:48 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.321 - error: Caught by controller[65]: Thu, 29 Nov 2018 16:11:48 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 83
      ! 2018-11-29 17:12:01.321 - error: Caught by controller[66]: Thu, 29 Nov 2018 16:11:48 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 4, srcaddr: 13082, srcendpoint: 2, dstendpoint: 1, wasbroadcast: 0, linkquality: 118, securityuse: 0, timestamp: 3269453, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.321 - error: Caught by controller[67]: Thu, 29 Nov 2018 16:11:48 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.321 - error: Caught by controller[68]: Thu, 29 Nov 2018 16:11:48 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.321 - error: Caught by controller[69]: 2018-11-29T16:11:48.222Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.322 - error: Caught by controller[69]: clusterid: 4,
      ! 2018-11-29 17:12:01.322 - error: Caught by controller[69]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.322 - error: Caught by controller[69]: srcendpoint: 2,
      ! 2018-11-29 17:12:01.322 - error: Caught by controller[69]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.322 - error: Caught by controller[69]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.322 - error: Caught by controller[69]: linkquality: 118,
      ! 2018-11-29 17:12:01.322 - error: Caught by controller[69]: securityuse: 0,
      ! 2018-11-29 17:12:01.323 - error: Caught by controller[69]: timestamp: 3269453,
      ! 2018-11-29 17:12:01.323 - error: Caught by controller[69]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.323 - error: Caught by controller[69]: len: 5,
      ! 2018-11-29 17:12:01.323 - error: Caught by controller[69]: data: { '0': 24, '1': 83, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.323 - error: Caught by controller[69]: zclMsg:
      ! 2018-11-29 17:12:01.323 - error: Caught by controller[69]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.323 - error: Caught by controller[69]: manufCode: 0,
      ! 2018-11-29 17:12:01.324 - error: Caught by controller[69]: seqNum: 83,
      ! 2018-11-29 17:12:01.324 - error: Caught by controller[69]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.324 - error: Caught by controller[69]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.324 - error: Caught by controller[70]: Thu, 29 Nov 2018 16:11:48 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.324 - error: Caught by controller[71]: 2018-11-29T16:11:48.241Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.324 - error: Caught by controller[71]: status: { endpoint: { current: 2, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.324 - error: Caught by controller[71]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.325 - error: Caught by controller[72]: 2018-11-29T16:11:48.243Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.325 - error: Caught by controller[72]: status: { endpoint: { current: 2, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.325 - error: Caught by controller[72]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 2, progress: 50 }
      ! 2018-11-29 17:12:01.325 - error: Caught by controller[73]: Thu, 29 Nov 2018 16:11:48 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 84
      ! 2018-11-29 17:12:01.325 - error: Caught by controller[74]: Thu, 29 Nov 2018 16:11:48 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 2, srcendpoint: 1, clusterid: 5, transid: 84, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.325 - error: Caught by controller[75]: Thu, 29 Nov 2018 16:11:48 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.325 - error: Caught by controller[76]: Thu, 29 Nov 2018 16:11:48 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.326 - error: Caught by controller[77]: Thu, 29 Nov 2018 16:11:51 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 84 }
      ! 2018-11-29 17:12:01.326 - error: Caught by controller[78]: Thu, 29 Nov 2018 16:11:51 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.326 - error: Caught by controller[78]: Thu, 29 Nov 2018 16:11:51 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 84
      ! 2018-11-29 17:12:01.326 - error: Caught by controller[79]: Thu, 29 Nov 2018 16:11:51 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 5, srcaddr: 13082, srcendpoint: 2, dstendpoint: 1, wasbroadcast: 0, linkquality: 118, securityuse: 0, timestamp: 3279563, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.326 - error: Caught by controller[80]: Thu, 29 Nov 2018 16:11:51 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.326 - error: Caught by controller[81]: Thu, 29 Nov 2018 16:11:51 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.327 - error: Caught by controller[82]: 2018-11-29T16:11:51.439Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.327 - error: Caught by controller[82]: clusterid: 5,
      ! 2018-11-29 17:12:01.327 - error: Caught by controller[82]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.327 - error: Caught by controller[82]: srcendpoint: 2,
      ! 2018-11-29 17:12:01.327 - error: Caught by controller[82]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.327 - error: Caught by controller[82]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.327 - error: Caught by controller[82]: linkquality: 118,
      ! 2018-11-29 17:12:01.328 - error: Caught by controller[82]: securityuse: 0,
      ! 2018-11-29 17:12:01.328 - error: Caught by controller[82]: timestamp: 3279563,
      ! 2018-11-29 17:12:01.328 - error: Caught by controller[82]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.328 - error: Caught by controller[82]: len: 5,
      ! 2018-11-29 17:12:01.328 - error: Caught by controller[82]: data: { '0': 24, '1': 84, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.328 - error: Caught by controller[82]: zclMsg:
      ! 2018-11-29 17:12:01.328 - error: Caught by controller[82]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.328 - error: Caught by controller[82]: manufCode: 0,
      ! 2018-11-29 17:12:01.329 - error: Caught by controller[82]: seqNum: 84,
      ! 2018-11-29 17:12:01.329 - error: Caught by controller[82]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.329 - error: Caught by controller[82]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.329 - error: Caught by controller[83]: Thu, 29 Nov 2018 16:11:51 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.329 - error: Caught by controller[84]: 2018-11-29T16:11:51.442Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.329 - error: Caught by controller[84]: status: { endpoint: { current: 2, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.329 - error: Caught by controller[84]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.330 - error: Caught by controller[85]: 2018-11-29T16:11:51.443Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.330 - error: Caught by controller[85]: status: { endpoint: { current: 2, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.330 - error: Caught by controller[85]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 2, progress: 75 }
      ! 2018-11-29 17:12:01.330 - error: Caught by controller[86]: Thu, 29 Nov 2018 16:11:51 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 85
      ! 2018-11-29 17:12:01.330 - error: Caught by controller[87]: Thu, 29 Nov 2018 16:11:51 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 2, srcendpoint: 1, clusterid: 18, transid: 85, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.330 - error: Caught by controller[88]: Thu, 29 Nov 2018 16:11:51 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.330 - error: Caught by controller[89]: Thu, 29 Nov 2018 16:11:51 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.331 - error: Caught by controller[90]: Thu, 29 Nov 2018 16:11:54 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 85 }
      ! 2018-11-29 17:12:01.331 - error: Caught by controller[91]: Thu, 29 Nov 2018 16:11:54 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.331 - error: Caught by controller[91]: Thu, 29 Nov 2018 16:11:54 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 85
      ! 2018-11-29 17:12:01.331 - error: Caught by controller[92]: Thu, 29 Nov 2018 16:11:54 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 18, srcaddr: 13082, srcendpoint: 2, dstendpoint: 1, wasbroadcast: 0, linkquality: 118, securityuse: 0, timestamp: 3289667, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.331 - error: Caught by controller[93]: Thu, 29 Nov 2018 16:11:54 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.331 - error: Caught by controller[94]: Thu, 29 Nov 2018 16:11:54 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.332 - error: Caught by controller[95]: 2018-11-29T16:11:54.672Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.332 - error: Caught by controller[95]: clusterid: 18,
      ! 2018-11-29 17:12:01.332 - error: Caught by controller[95]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.332 - error: Caught by controller[95]: srcendpoint: 2,
      ! 2018-11-29 17:12:01.332 - error: Caught by controller[95]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.332 - error: Caught by controller[95]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.332 - error: Caught by controller[95]: linkquality: 118,
      ! 2018-11-29 17:12:01.332 - error: Caught by controller[95]: securityuse: 0,
      ! 2018-11-29 17:12:01.333 - error: Caught by controller[95]: timestamp: 3289667,
      ! 2018-11-29 17:12:01.333 - error: Caught by controller[95]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.333 - error: Caught by controller[95]: len: 5,
      ! 2018-11-29 17:12:01.333 - error: Caught by controller[95]: data: { '0': 24, '1': 85, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.333 - error: Caught by controller[95]: zclMsg:
      ! 2018-11-29 17:12:01.333 - error: Caught by controller[95]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.333 - error: Caught by controller[95]: manufCode: 0,
      ! 2018-11-29 17:12:01.334 - error: Caught by controller[95]: seqNum: 85,
      ! 2018-11-29 17:12:01.334 - error: Caught by controller[95]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.334 - error: Caught by controller[95]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.334 - error: Caught by controller[96]: Thu, 29 Nov 2018 16:11:54 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.334 - error: Caught by controller[97]: 2018-11-29T16:11:54.676Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.334 - error: Caught by controller[97]: status: { endpoint: { current: 2, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.334 - error: Caught by controller[97]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.335 - error: Caught by controller[98]: 2018-11-29T16:11:54.677Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.335 - error: Caught by controller[98]: status: { endpoint: { current: 2, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.335 - error: Caught by controller[98]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 2, progress: 100 }
      ! 2018-11-29 17:12:01.335 - error: Caught by controller[99]: Thu, 29 Nov 2018 16:11:54 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 86
      ! 2018-11-29 17:12:01.335 - error: Caught by controller[100]: Thu, 29 Nov 2018 16:11:54 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 3, srcendpoint: 1, clusterid: 3, transid: 86, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.335 - error: Caught by controller[101]: Thu, 29 Nov 2018 16:11:54 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.335 - error: Caught by controller[102]: Thu, 29 Nov 2018 16:11:54 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.336 - error: Caught by controller[103]: Thu, 29 Nov 2018 16:11:57 GMT cc-znp:AREQ <– AF:dataConfirm, { status: 0, endpoint: 1, transid: 86 }
      ! 2018-11-29 17:12:01.336 - error: Caught by controller[104]: Thu, 29 Nov 2018 16:11:57 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object]
      ! 2018-11-29 17:12:01.336 - error: Caught by controller[104]: Thu, 29 Nov 2018 16:11:57 GMT zigbee-shepherd:msgHdlr IND <– AF:dataConfirm, transId: 86
      ! 2018-11-29 17:12:01.336 - error: Caught by controller[105]: Thu, 29 Nov 2018 16:11:57 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 3, srcaddr: 13082, srcendpoint: 3, dstendpoint: 1, wasbroadcast: 0, linkquality: 115, securityuse: 0, timestamp: 3299768, transseqnumber: 0, len: 5, data: }
      ! 2018-11-29 17:12:01.336 - error: Caught by controller[106]: Thu, 29 Nov 2018 16:11:57 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.336 - error: Caught by controller[107]: Thu, 29 Nov 2018 16:11:57 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
      ! 2018-11-29 17:12:01.337 - error: Caught by controller[108]: 2018-11-29T16:11:57.904Z zigbee:controller event msg { groupid: 0,
      ! 2018-11-29 17:12:01.337 - error: Caught by controller[108]: clusterid: 3,
      ! 2018-11-29 17:12:01.337 - error: Caught by controller[108]: srcaddr: 13082,
      ! 2018-11-29 17:12:01.337 - error: Caught by controller[108]: srcendpoint: 3,
      ! 2018-11-29 17:12:01.337 - error: Caught by controller[108]: dstendpoint: 1,
      ! 2018-11-29 17:12:01.337 - error: Caught by controller[108]: wasbroadcast: 0,
      ! 2018-11-29 17:12:01.337 - error: Caught by controller[108]: linkquality: 115,
      ! 2018-11-29 17:12:01.337 - error: Caught by controller[108]: securityuse: 0,
      ! 2018-11-29 17:12:01.338 - error: Caught by controller[108]: timestamp: 3299768,
      ! 2018-11-29 17:12:01.338 - error: Caught by controller[108]: transseqnumber: 0,
      ! 2018-11-29 17:12:01.338 - error: Caught by controller[108]: len: 5,
      ! 2018-11-29 17:12:01.338 - error: Caught by controller[108]: data: { '0': 24, '1': 86, '2': 11, '3': 12, '4': 130 },
      ! 2018-11-29 17:12:01.338 - error: Caught by controller[108]: zclMsg:
      ! 2018-11-29 17:12:01.338 - error: Caught by controller[108]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
      ! 2018-11-29 17:12:01.338 - error: Caught by controller[108]: manufCode: 0,
      ! 2018-11-29 17:12:01.339 - error: Caught by controller[108]: seqNum: 86,
      ! 2018-11-29 17:12:01.339 - error: Caught by controller[108]: cmdId: 'defaultRsp',
      ! 2018-11-29 17:12:01.339 - error: Caught by controller[108]: payload: { cmdId: 12, statusCode: 130 } } } { modelId: 'lumi.sensor_86sw2\u0000Un' }
      ! 2018-11-29 17:12:01.339 - error: Caught by controller[109]: Thu, 29 Nov 2018 16:11:57 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
      ! 2018-11-29 17:12:01.339 - error: Caught by controller[110]: 2018-11-29T16:11:57.918Z zigbee:controller debug handleMessage { type: 'devInterview',
      ! 2018-11-29 17:12:01.339 - error: Caught by controller[110]: status: { endpoint: { current: 3, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.339 - error: Caught by controller[110]: data: '0x00158d000255ef1b' }
      ! 2018-11-29 17:12:01.340 - error: Caught by controller[111]: 2018-11-29T16:11:57.919Z zigbee:controller event interview { type: 'devInterview',
      ! 2018-11-29 17:12:01.340 - error: Caught by controller[111]: status: { endpoint: { current: 3, cluster: [Object], total: 3 } },
      ! 2018-11-29 17:12:01.340 - error: Caught by controller[111]: data: '0x00158d000255ef1b' } { totalEp: 3, currentEp: 3, progress: 25 }
      ! 2018-11-29 17:12:01.340 - error: Caught by controller[112]: Thu, 29 Nov 2018 16:11:57 GMT zigbee-shepherd:request REQ –> AF:dataRequest, transId: 87
      ! 2018-11-29 17:12:01.340 - error: Caught by controller[113]: Thu, 29 Nov 2018 16:11:57 GMT cc-znp:SREQ –> AF:dataRequest, { dstaddr: 13082, destendpoint: 3, srcendpoint: 1, clusterid: 4, transid: 87, options: 48, radius: 30, len: 6, data: }
      ! 2018-11-29 17:12:01.340 - error: Caught by controller[114]: Thu, 29 Nov 2018 16:11:57 GMT cc-znp:SRSP <– AF:dataRequest, { status: 0 }
      ! 2018-11-29 17:12:01.340 - error: Caught by controller[115]: Thu, 29 Nov 2018 16:11:57 GMT zigbee-shepherd:request RSP <– AF:dataRequest, status: 0
      ! 2018-11-29 17:12:01.341 - error: Caught by controller[116]: Thu, 29 Nov 2018 16:12:01 GMT zigbee-shepherd zigbee-shepherd is stopping.
      ! 2018-11-29 17:12:01.341 - error: Caught by controller[117]: Thu, 29 Nov 2018 16:12:01 GMT zigbee-shepherd:request REQ –> ZDO:mgmtPermitJoinReq
      ! 2018-11-29 17:12:01.341 - error: Caught by controller[118]: Thu, 29 Nov 2018 16:12:01 GMT cc-znp:SREQ –> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
      ! 2018-11-29 17:12:01.341 - info: host.ioBroker-RasPi instance system.adapter.zigbee.0 terminated with code 0 (OK)
      ! 2018-11-29 17:12:03.712 - info: host.ioBroker-RasPi instance system.adapter.zigbee.0 started with pid 6303
      ! 2018-11-29 17:12:05.685 - info: zigbee.0 States connected to redis: 127.0.0.1:6379
      ! 2018-11-29 17:12:05.884 - info: zigbee.0 starting. Version 0.8.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.14.0
      ! 2018-11-29 17:12:05.893 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000E896DEE-if00 with panID 6754 channel 11
      ! 2018-11-29 17:12:06.856 - info: zigbee.0 zigbee-shepherd started!
      ! 2018-11-29 17:12:06.875 - info: zigbee.0 zigbee-shepherd ready. version: 2.6.3 rev 20180815
        Kueppert last edited by
        Hast du ein Upload gemacht nachdem du von git installiert hast? Nur eine Idee…
          dimaiv last edited by
          @Kueppert:
          Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk `
          Ich habe ganz normal über Admin installiert, der macht alles automatisch.
            Sinalco last edited by
            @dimaiv:
            ich habe gerade iobroker komplett neue installiert und neueste Adapter 0.8.0 von Iliy genommen.
            Transition Time fehlt auch da.
            und dazu kommen sehr viele Fehler beim Adapter neue starten, beim Geräte anlernen und zwischen durch. `
            Kann ich bestätigen, ich hab auch gerade eine komplette Neuinstallation ganz normal gemacht und bei meinem Flex RGBW
            7cb03eaa000024ef fehlt auch die Transition Time. Bei allen meinen Tradfri Lampen ist sie vorhanden und funktioniert.
            Auch die Fehler kommen bei mir beim neustarten:
            ! Caught 2018-11-29 22:22:49.212 error by controller[115]: 2018-11-29T21:22:49.113Z zigbee:controller info zigbee-shepherd stopped undefined
            ! Caught 2018-11-29 22:22:49.212 error by controller[115]: Thu, 29 Nov 2018 21:22:49 GMT zigbee-shepherd zigbee-shepherd is stopped.
            ! Caught 2018-11-29 22:22:49.211 error by controller[115]: Thu, 29 Nov 2018 21:22:49 GMT cc-znp The serialport /dev/ttyACM0 is closed.
            ! Caught 2018-11-29 22:22:49.211 error by controller[114]: Thu, 29 Nov 2018 21:22:49 GMT cc-znp:SREQ –> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
            ! Caught 2018-11-29 22:22:49.211 error by controller[114]: Thu, 29 Nov 2018 21:22:49 GMT zigbee-shepherd:request RSP <– UTIL:ledControl, status: 0
            ! Caught 2018-11-29 22:22:49.211 error by controller[114]: Thu, 29 Nov 2018 21:22:49 GMT cc-znp:SRSP <– UTIL:ledControl, { status: 0 }
            ! Caught 2018-11-29 22:22:49.206 error by controller[113]: Thu, 29 Nov 2018 21:22:49 GMT zigbee-shepherd:request REQ –> ZDO:mgmtPermitJoinReq
            ! Caught 2018-11-29 22:22:49.206 error by controller[113]: Thu, 29 Nov 2018 21:22:49 GMT zigbee-shepherd zigbee-shepherd is stopping.
            ! Caught 2018-11-29 22:22:49.206 error by controller[112]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> UTIL:ledControl, { ledid: 3, mode: 0 }
            ! Caught 2018-11-29 22:22:49.205 error by controller[112]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> UTIL:ledControl
            ! Caught 2018-11-29 22:22:49.205 error by controller[111]: 2018-11-29T21:22:48.911Z zigbee:controller info zigbee-shepherd ready. version: 2.6.3 rev 20180507 undefined
            ! Caught 2018-11-29 22:22:49.205 error by controller[110]: 2018-11-29T21:22:48.871Z zigbee:controller info zigbee-shepherd started! undefined
            ! Caught 2018-11-29 22:22:49.205 error by controller[109]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd zigbee-shepherd is _ready and _enabled
            ! Caught 2018-11-29 22:22:49.205 error by controller[108]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:init Loading devices from database done.
            ! Caught 2018-11-29 22:22:49.204 error by controller[107]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:mgmtPermitJoinRsp
            ! Caught 2018-11-29 22:22:49.204 error by controller[106]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:mgmtPermitJoinRsp, { srcaddr: 0, status: 0 }
            ! Caught 2018-11-29 22:22:49.204 error by controller[105]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:mgmtPermitJoinReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.204 error by controller[104]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:mgmtPermitJoinReq, { addrmode: 2, dstaddr: 0, duration: 0, tcsignificance: 0 }
            ! Caught 2018-11-29 22:22:49.204 error by controller[103]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:mgmtPermitJoinReq
            ! Caught 2018-11-29 22:22:49.204 error by controller[102]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:activeEpRsp
            ! Caught 2018-11-29 22:22:49.203 error by controller[101]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:activeEpRsp, { srcaddr: 0, status: 0, nwkaddr: 0, activeepcount: 6, activeeplist: <buffer 06/05/04/03/02/01="">}
            ! Caught 2018-11-29 22:22:49.203 error by controller[100]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:activeEpReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.203 error by controller[99]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:activeEpReq, { dstaddr: 0, nwkaddrofinterest: 0 }
            ! Caught 2018-11-29 22:22:49.202 error by controller[98]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:activeEpReq
            ! Caught 2018-11-29 22:22:49.202 error by controller[97]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:nodeDescRsp
            ! Caught 2018-11-29 22:22:49.202 error by controller[96]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:nodeDescRsp, { srcaddr: 0, status: 0, nwkaddr: 0, logicaltype_cmplxdescavai_userdescavai: 0, apsflags_freqband: 64, maccapflags: 1
            ! Caught 2018-11-29 22:22:49.202 error by controller[95]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:nodeDescReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.201 error by controller[94]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:nodeDescReq, { dstaddr: 0, nwkaddrofinterest: 0 }
            ! Caught 2018-11-29 22:22:49.201 error by controller[93]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:nodeDescReq
            ! Caught 2018-11-29 22:22:49.201 error by controller[92]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:simpleDescRsp
            ! Caught 2018-11-29 22:22:49.201 error by controller[91]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:simpleDescRsp, { srcaddr: 0, status: 0, nwkaddr: 0, len: 8, endpoint: 6, profileid: 265, deviceid: 5, deviceversion: 0, numinclust
            ! Caught 2018-11-29 22:22:49.201 error by controller[90]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:simpleDescReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.200 error by controller[89]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:simpleDescReq, { dstaddr: 0, nwkaddrofinterest: 0, endpoint: 6 }
            ! Caught 2018-11-29 22:22:49.200 error by controller[88]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:simpleDescReq
            ! Caught 2018-11-29 22:22:49.200 error by controller[87]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:simpleDescRsp
            ! Caught 2018-11-29 22:22:49.200 error by controller[86]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:simpleDescRsp, { srcaddr: 0, status: 0, nwkaddr: 0, len: 8, endpoint: 5, profileid: 264, deviceid: 5, deviceversion: 0, numinclust
            ! Caught 2018-11-29 22:22:49.200 error by controller[85]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:simpleDescReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.200 error by controller[84]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:simpleDescReq, { dstaddr: 0, nwkaddrofinterest: 0, endpoint: 5 }
            ! Caught 2018-11-29 22:22:49.199 error by controller[83]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:simpleDescReq
            ! Caught 2018-11-29 22:22:49.199 error by controller[82]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:simpleDescRsp
            ! Caught 2018-11-29 22:22:49.199 error by controller[81]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:simpleDescRsp, { srcaddr: 0, status: 0, nwkaddr: 0, len: 8, endpoint: 4, profileid: 263, deviceid: 5, deviceversion: 0, numinclust
            ! Caught 2018-11-29 22:22:49.198 error by controller[80]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:simpleDescReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.197 error by controller[79]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:simpleDescReq, { dstaddr: 0, nwkaddrofinterest: 0, endpoint: 4 }
            ! Caught 2018-11-29 22:22:49.197 error by controller[78]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:simpleDescReq
            ! Caught 2018-11-29 22:22:49.197 error by controller[77]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:simpleDescRsp
            ! Caught 2018-11-29 22:22:49.197 error by controller[76]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:simpleDescRsp, { srcaddr: 0, status: 0, nwkaddr: 0, len: 8, endpoint: 3, profileid: 261, deviceid: 5, deviceversion: 0, numinclust
            ! Caught 2018-11-29 22:22:49.196 error by controller[75]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:simpleDescReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.196 error by controller[74]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:simpleDescReq, { dstaddr: 0, nwkaddrofinterest: 0, endpoint: 3 }
            ! Caught 2018-11-29 22:22:49.196 error by controller[73]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:simpleDescReq
            ! Caught 2018-11-29 22:22:49.196 error by controller[72]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:simpleDescRsp
            ! Caught 2018-11-29 22:22:49.195 error by controller[72]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:simpleDescRsp, { srcaddr: 0, status: 0, nwkaddr: 0, len: 8, endpoint: 2, profileid: 257, deviceid: 5, deviceversion: 0, numinclust
            ! Caught 2018-11-29 22:22:49.195 error by controller[72]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:simpleDescReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.195 error by controller[71]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:simpleDescReq, { dstaddr: 0, nwkaddrofinterest: 0, endpoint: 2 }
            ! Caught 2018-11-29 22:22:49.195 error by controller[70]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:simpleDescReq
            ! Caught 2018-11-29 22:22:49.194 error by controller[69]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:simpleDescRsp
            ! Caught 2018-11-29 22:22:49.194 error by controller[68]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:simpleDescRsp, { srcaddr: 0, status: 0, nwkaddr: 0, len: 8, endpoint: 1, profileid: 260, deviceid: 5, deviceversion: 0, numinclust
            ! Caught 2018-11-29 22:22:49.194 error by controller[67]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:simpleDescReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.193 error by controller[66]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:simpleDescReq, { dstaddr: 0, nwkaddrofinterest: 0, endpoint: 1 }
            ! Caught 2018-11-29 22:22:49.193 error by controller[65]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:simpleDescReq
            ! Caught 2018-11-29 22:22:49.192 error by controller[64]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:activeEpRsp
            ! Caught 2018-11-29 22:22:49.192 error by controller[63]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:activeEpRsp, { srcaddr: 0, status: 0, nwkaddr: 0, activeepcount: 6, activeeplist: <buffer 06/05/04/03/02/01="">}
            ! Caught 2018-11-29 22:22:49.192 error by controller[62]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:activeEpReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.191 error by controller[61]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:activeEpReq, { dstaddr: 0, nwkaddrofinterest: 0 }
            ! Caught 2018-11-29 22:22:49.191 error by controller[60]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:activeEpReq
            ! Caught 2018-11-29 22:22:49.191 error by controller[59]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:msgHdlr IND <– ZDO:nodeDescRsp
            ! Caught 2018-11-29 22:22:49.191 error by controller[58]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:AREQ <– ZDO:nodeDescRsp, { srcaddr: 0, status: 0, nwkaddr: 0, logicaltype_cmplxdescavai_userdescavai: 0, apsflags_freqband: 64, maccapflags: 1
            ! Caught 2018-11-29 22:22:49.190 error by controller[57]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– ZDO:nodeDescReq, { status: 0 }
            ! Caught 2018-11-29 22:22:49.190 error by controller[56]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> ZDO:nodeDescReq, { dstaddr: 0, nwkaddrofinterest: 0 }
            ! Caught 2018-11-29 22:22:49.190 error by controller[55]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> ZDO:nodeDescReq
            ! Caught 2018-11-29 22:22:49.190 error by controller[54]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.189 error by controller[53]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SAPI:getDeviceInfo, { param: 7, value: <buffer dd="">}
            ! Caught 2018-11-29 22:22:49.189 error by controller[52]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> SAPI:getDeviceInfo, { param: 7 }
            ! Caught 2018-11-29 22:22:49.189 error by controller[51]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.188 error by controller[50]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.188 error by controller[49]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SAPI:getDeviceInfo, { param: 6, value: <buffer 12/62/1a/02/00/4b="">}
            ! Caught 2018-11-29 22:22:49.188 error by controller[48]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> SAPI:getDeviceInfo, { param: 6 }
            ! Caught 2018-11-29 22:22:49.187 error by controller[47]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.187 error by controller[46]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.186 error by controller[45]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SAPI:getDeviceInfo, { param: 5, value: <buffer 12/0b/00/02/4b="">}
            ! Caught 2018-11-29 22:22:49.186 error by controller[44]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> SAPI:getDeviceInfo, { param: 5 }
            ! Caught 2018-11-29 22:22:49.186 error by controller[43]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.186 error by controller[42]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.185 error by controller[41]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SAPI:getDeviceInfo, { param: 2, value: <buffer 12/00/02/4b="">}
            ! Caught 2018-11-29 22:22:49.185 error by controller[40]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> SAPI:getDeviceInfo, { param: 2 }
            ! Caught 2018-11-29 22:22:49.185 error by controller[39]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.185 error by controller[38]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.184 error by controller[37]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SAPI:getDeviceInfo, { param: 1, value: <buffer 12/35/45/02/00/4b="">}
            ! Caught 2018-11-29 22:22:49.184 error by controller[36]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> SAPI:getDeviceInfo, { param: 1 }
            ! Caught 2018-11-29 22:22:49.184 error by controller[35]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.184 error by controller[34]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.183 error by controller[33]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SAPI:getDeviceInfo, { param: 0, value: <buffer 09/01/00="">}
            ! Caught 2018-11-29 22:22:49.183 error by controller[32]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> SAPI:getDeviceInfo, { param: 0 }
            ! Caught 2018-11-29 22:22:49.183 error by controller[31]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.182 error by controller[30]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SYS:version
            ! Caught 2018-11-29 22:22:49.182 error by controller[29]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SYS:version, { transportrev: 2, product: 0, majorrel: 2, minorrel: 6, maintrel: 3, revision: 20180507 }
            ! Caught 2018-11-29 22:22:49.181 error by controller[28]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> SYS:version, {}
            ! Caught 2018-11-29 22:22:49.181 error by controller[27]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> SYS:version
            ! Caught 2018-11-29 22:22:49.181 error by controller[26]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:init Now the ZNP is a coordinator.
            ! Caught 2018-11-29 22:22:49.181 error by controller[25]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.180 error by controller[24]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SAPI:getDeviceInfo, { param: 0, value: <buffer 09/01/00="">}
            ! Caught 2018-11-29 22:22:49.180 error by controller[23]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SREQ –> SAPI:getDeviceInfo, { param: 0 }
            ! Caught 2018-11-29 22:22:49.180 error by controller[22]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request REQ –> SAPI:getDeviceInfo
            ! Caught 2018-11-29 22:22:49.180 error by controller[21]: Thu, 29 Nov 2018 21:22:48 GMT zigbee-shepherd:request RSP <– SAPI:readConfiguration, status: 0
            ! Caught 2018-11-29 22:22:49.179 error by controller[20]: Thu, 29 Nov 2018 21:22:48 GMT cc-znp:SRSP <– SAPI:readConfiguration, { status: 0, configid: 99, len: 1, value: <buffer 00="">}
            ! Caught 2018-11-29 22:22:49.179 error by controller[19]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SREQ –> SAPI:readConfiguration, { configid: 99, len: 1, value: [ 0 ] }
            ! Caught 2018-11-29 22:22:49.179 error by controller[18]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request REQ –> SAPI:readConfiguration
            ! Caught 2018-11-29 22:22:49.178 error by controller[17]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request RSP <– SAPI:readConfiguration, status: 0
            ! Caught 2018-11-29 22:22:49.178 error by controller[16]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SRSP <– SAPI:readConfiguration, { status: 0, configid: 98, len: 16, value: <buffer 01/03/05/07/09/0b/0d/0f/00/02/04/06/08/0a/0c="">}
            ! Caught 2018-11-29 22:22:49.178 error by controller[15]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SREQ –> SAPI:readConfiguration, { configid: 98, len: 16, value: [ 1, 3, 5, 7, 9, 11, 13, 15, 0, 2, 4, 6, 8, 10, 12, 13 ] }
            ! Caught 2018-11-29 22:22:49.177 error by controller[14]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request REQ –> SAPI:readConfiguration
            ! Caught 2018-11-29 22:22:49.177 error by controller[13]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request RSP <– SAPI:readConfiguration, status: 0
            ! Caught 2018-11-29 22:22:49.176 error by controller[12]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SRSP <– SAPI:readConfiguration, { status: 0, configid: 132, len: 4, value: <buffer 00/08="">}
            ! Caught 2018-11-29 22:22:49.176 error by controller[11]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SREQ –> SAPI:readConfiguration, { configid: 132, len: 4, value: [ 0, 8, 0, 0 ] }
            ! Caught 2018-11-29 22:22:49.176 error by controller[10]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request REQ –> SAPI:readConfiguration
            ! Caught 2018-11-29 22:22:49.175 error by controller[9]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request RSP <– SAPI:readConfiguration, status: 0
            ! Caught 2018-11-29 22:22:49.175 error by controller[8]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SRSP <– SAPI:readConfiguration, { status: 0, configid: 131, len: 2, value: <buffer 62/1a="">}
            ! Caught 2018-11-29 22:22:49.175 error by controller[7]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SREQ –> SAPI:readConfiguration, { configid: 131, len: 2, value: [ 98, 26 ] }
            ! Caught 2018-11-29 22:22:49.175 error by controller[6]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request REQ –> SAPI:readConfiguration
            ! Caught 2018-11-29 22:22:49.174 error by controller[5]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request RSP <– SYS:osalNvRead, status: 0
            ! Caught 2018-11-29 22:22:49.174 error by controller[4]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SRSP <– SYS:osalNvRead, { status: 0, len: 1, value: <buffer 55="">}
            ! Caught 2018-11-29 22:22:49.174 error by controller[3]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp:SREQ –> SYS:osalNvRead, { id: 3840, offset: 0, len: 1, value: [ 85 ] }
            ! Caught 2018-11-29 22:22:49.173 error by controller[2]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:request REQ –> SYS:osalNvRead
            ! Caught 2018-11-29 22:22:49.173 error by controller[1]: Thu, 29 Nov 2018 21:22:47 GMT cc-znp The serialport /dev/ttyACM0 is opened.
            ! Caught 2018-11-29 22:22:49.172 error by controller[0]: Thu, 29 Nov 2018 21:22:47 GMT zigbee-shepherd:init zigbee-shepherd booting…</buffer></buffer></buffer></buffer></buffer></buffer></buffer></buffer></buffer></buffer></buffer></buffer></buffer></buffer>
            Der zweite Fehler liegt immer noch an der Farbigen Tradfri Lampe (TRADFRI bulb E27 CWS opal 600lm
            d0cf5efffe22e689). Jetzt lässt sich "color" ändern, aber leider nicht mehr die "colortemp", also genau andersrum wie vorher :lol:
            @Sinalco:
            @arteck:
            @Sinalco:
            Leider lässt sich bei meiner TRADFRI bulb E27 CWS opal 600lm (mit RGB) die Farbtemperatur nicht einstellen.
            Folgende Fehlermeldung erscheint:
            zigbee.0	2018-11-03 14:11:49.939	error	No converter available for 'LED1624G9' with key 'colortemp'
            zigbee.0	2018-11-03 14:11:40.287	info	new dev 0xd0cf5efffe22e689 29351 TRADFRI bulb E27 CWS opal 600lm
            Dimmen, Ein/Aus und Farben lassen sich einstellen. Bei andren Ikea Tradfri Birnen die kein RGB Licht haben kann man ohne Probleme die Farbtemperatur wechseln. `
            jo mein Fehler hab es übersehen.
            in der nächsten Version wird es da sein `
            Hi arteck leider ist es in der 0.8.0b aus deiner Repo noch nicht behoben. `
            Hier der Auszug aus der Log im debug (Hab colortemp auf 370 gesetzt, in der log steht {"colorTemperature":null}):
            ! zigbee.0 2018-11-29 22:02:38.584 debug system.adapter.admin.0: logging true
            ! zigbee.0 2018-11-29 22:02:33.024 debug Publish {}
            ! zigbee.0 2018-11-29 22:02:33.016 debug Device 0xd0cf5efffe22e689 emit event devChange with data:{"cid":"lightingColorCtrl","data":{"colorTemperature":null}}
            ! zigbee.0 2018-11-29 22:02:33.016 debug 2018-11-29T21:02:33.014Z zigbee:controller event devChange { type: 'devChange', endpoints: [ Endpoint { isLocal: [Function], device: [Object], profId: 49246, epId: 1,
            ! zigbee.0 2018-11-29 22:02:33.013 debug handleMessage. {"type":"devChange","endpoints":[{"device":{"_id":8,"type":"Router","ieeeAddr":"0xd0cf5efffe22e689","nwkAddr":29351,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Mains (si
            ! zigbee.0 2018-11-29 22:02:33.010 debug 2018-11-29T21:02:33.008Z zigbee:controller debug handleMessage { type: 'devChange', endpoints: [ Endpoint { isLocal: [Function], device: [Object], profId: 49246, epId: 1,
            ! zigbee.0 2018-11-29 22:02:33.005 debug Thu, 29 Nov 2018 21:02:33 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
              schau ich mir mal heute Abend an .. wenn ihr lust habt können wir das in TS bequatschen.. ab 20 Uhr währ ich da
                Lars89 last edited by
                ich habe da ein Problem mit dem Gledopto RGBW Controller dieser sollte ja jetzt eigentlich auch unterstützt werden oder ?!
                Mir ist aufgefallen das in der Liste der Unterstützten Geräte was von "GL-C-008" steht auf meinem Karton steht "GL-C-007" wird dieser nicht unterstützt bzw wo ist da der Unterschied ?!
                Anlernen konnte ich das Teil aber er wird halt nur als "undefined" angezeigt.
                @arteck wenn dieser noch nicht vorhanden ist könnten man diesen vielleicht auch hinzufügen ?!
                Gruß Lars
                  Arnulf last edited by
                  @Sinalco:
                  Hab auch eine FritzBox und hab das gestern Abend genau so gemacht. Zuerst war mein WLAN auf Kanal 4 (sollte man sowieso nicht machen, 1,6,11 Regel) und Zigbee auf 11 was zu Überlappungen führte und so zigbee schlechter funktionierte.
                  In unserer Nachbarschaft gibt es auf WLAN Kanal 1 wenige und nur sehr schwache Netze. Hab jetzt mein WLAN auf Kanal 11 und zigbee auf 11.
                  Seit dem funktioniert es wieder viel besser `
                  Ich habe gestern auch etwas herum getestet. tatsächlich ist bei mir WLAN 1 auch die bessere Wahl. Jetzt fungiert sogar eine Hue-Lampe als Router. War vorher undenkbar
                    hmanfred last edited by
                    Error im Log trotz erfolgreichem Schalten.
                    Eine Osram Plug über VIS-Button ein- und nach ein paar Sekunden wieder ausgeschaltet. Folgende Meldungen im Log:
                    Erstes ein/aus:
                    2018-11-30 08:01:32.666 - error: zigbee.0 Zigbee publish to '0x84182600000fb1c7', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
                    2018-11-30 08:01:32.679 - error: zigbee.0 Zigbee publish to '0x84182600000fb1c7', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
                    2018-11-30 08:01:47.887 - error: zigbee.0 Zigbee publish to '0x84182600000fb1c7', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
                    Zweites ein/aus:
                    2018-11-30 08:55:29.558 - error: zigbee.0 Zigbee publish to '0x84182600000fb1c7', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
                    2018-11-30 08:55:49.918 - error: zigbee.0 Zigbee publish to '0x84182600000fb1c7', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
                    2018-11-30 08:55:50.055 - error: zigbee.0 Zigbee publish to '0x84182600000fb1c7', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
                    Schalte ich eine andere gleichen Typs, erfolgen keine Logeinträge.
                    Verbindungsqualität lat Datenpunkt 39, laut Karte 0.
                      @hmanfred:
                      Erstes ein/aus:
                      Zweites ein/aus:
                      Verbindungsqualität lat Datenpunkt 39, laut Karte 0. `
                      ich habe 4 Plugs hier im einsatz.. und ich gebe dir recht irgendwas stimmt da nicht.. die werden zwar geschaltet ober die ack(bestätigung) kommt mit Log im eintrag rein… vor allem wenn man direk on/off/on schaltet.
                      es liegt aber mnicht am adapter.. ich tippe eher es hat sich an der dependecies was geändert... da schau ich selten rein.. hab mal ilya informiert vielleicht schaut er sich das an..
                        @Lars89:
                        Gruß Lars `
                        das sind 2 unterschiedliche Geräte .. funktiniert die 007 wie die 008 ??
                          alexalex last edited by
                          Das wäre super. Stört mich auch. Auch wenn es trotzdem funktioniert - mir ist immer unwohl, wenn in meinem Logfile mit Level warn was drin steht 😉
                          Gesendet von meinem Redmi 5 Plus mit Tapatalk
                            @arteck:
                            @Lars89:
                            Gruß Lars `
                            das sind 2 unterschiedliche Geräte .. funktiniert die 007 wie die 008 ?? `
                            Leider funktioniert die 007 nicht eine 008 ist noch unterwegs habe beim vorringen kauf nicht drauf geachtet ob 007 oder 008.
                            Im Adapter wird das Gerät nur als "undefined" angezeigt.
                              @Sinalco:
                              0xd0cf5efffe22e689 TRADFRI bulb E27 CWS opal 600lm `
                              ist wie es soll drin.. mach mal folgendes ..stope den adapter lösche das Objekt 0xd0cf5efffe22e689 starte den wieder…
                              das Gerät nicht enfernen nur das Objekt löschen
                                Ich habe immer noch Probleme mit meiner Installation. Ich kann mir einfach nicht vorstellen, dass eine so alte und weit verbreitete Technik so unzuverlässig sein soll. Aber vielleicht kommen wir ja mit den folgenden Angaben auf die Spur.
                                Ausgangspunkt ist folgende Map:
                                Es geht um die rot umrandete Steckdose. Der klaren Identifizierbarkeit halber habe ich dem Namen die letzten zwei STellen der Seriennummer angehängt. So wird die Zuordnung von Logeinträgen klarer.
                                Alle unten beschriebenen Vorgänge sind kurz (<1Min) nach Erstellen der Map geschehen.
                                Ausgangsstatus der Steckdose:
                                • Physikalischer Schaltzustand "Ein", vor ca. 1 Stunde manuell geschaltet
                                • Datenpunkt state ist "false"
                                • Datenpunkt link_quality ist 47, Zeitstempel jedoch von gestern vor ca. 17 Stunden
                                Dann folgende Vorgänge ausgeführt:
                                1. um 08:45:30 eingeschaltet (war in VIS ja als AUS dargestellt)
                                2. um 08:45:45 ausgeschaltet
                                Die Steckdose veränderte ihren Zustand nicht.
                                Hier der Log dazu:
                                ! 2018-12-01 08:45:30.391 - debug: zigbee.0 User stateChange zigbee.0.84182600000fa3fa.state {"val":true,"ack":false,"ts":1543650330388,"q":0,"from":"system.adapter.web.0","lc":1543650330388} 2018-12-01 08:45:30.407 - debug: zigbee.0 2018-12-01T07:45:30.407Z zigbee:controller debug Zigbee publish to '0x84182600000fa3fa', genOnOff - cmd on - payload {} - endpoint 3 undefined 2018-12-01 08:45:30.408 - debug: zigbee.0 Zigbee publish to '0x84182600000fa3fa', genOnOff - cmd on - payload {} - endpoint 3 2018-12-01 08:45:30.409 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT zigbee-shepherd:request REQ --> AF:dataRequest, transId: 23 2018-12-01 08:45:30.410 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT cc-znp:SREQ --> AF:dataRequest, { dstaddr: 48141, destendpoint: 3, srcendpoint: 1, clusterid: 6, transid: 23, options: 48, radius: 30, len: 3, data: } 2018-12-01 08:45:30.411 - debug: zigbee.0 Read timeout for cmd 'on' is 0 2018-12-01 08:45:30.413 - debug: zigbee.0 read message: {"cid":"genOnOff","cmd":"read","cmdType":"foundation","zclData":[{"attrId":0}],"cfg":{"manufSpec":0,"disDefaultRsp":0}} 2018-12-01 08:45:30.419 - debug: zigbee.0 2018-12-01T07:45:30.419Z zigbee:controller debug Zigbee publish to '0x84182600000fa3fa', genOnOff - cmd read - payload [{"attrId":0}] - endpoint 3 undefined 2018-12-01 08:45:30.420 - debug: zigbee.0 Zigbee publish to '0x84182600000fa3fa', genOnOff - cmd read - payload [{"attrId":0}] - endpoint 3 2018-12-01 08:45:30.421 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT zigbee-shepherd:request REQ --> AF:dataRequest, transId: 24 2018-12-01 08:45:30.438 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT cc-znp:SRSP <-- AF:dataRequest, { status: 0 } 2018-12-01 08:45:30.438 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT zigbee-shepherd:request RSP <-- AF:dataRequest, status: 0 2018-12-01 08:45:30.441 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT cc-znp:SREQ --> AF:dataRequest, { dstaddr: 48141, destendpoint: 3, srcendpoint: 1, clusterid: 6, transid: 24, options: 48, radius: 30, len: 5, data: } 2018-12-01 08:45:30.451 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT cc-znp:SRSP <-- AF:dataRequest, { status: 0 } 2018-12-01 08:45:30.451 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT zigbee-shepherd:request RSP <-- AF:dataRequest, status: 0 2018-12-01 08:45:30.969 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT cc-znp:AREQ <-- AF:dataConfirm, { status: 205, endpoint: 1, transid: 24 } 2018-12-01 08:45:30.970 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object] 2018-12-01 08:45:30.971 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT zigbee-shepherd:msgHdlr IND <-- AF:dataConfirm, transId: 24 2018-12-01 08:45:30.972 - debug: zigbee.0 2018-12-01T07:45:30.971Z zigbee:controller error Zigbee publish to '0x84182600000fa3fa', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205\. No network route. Please confirm that the device has (re)joined the network. undefined 2018-12-01 08:45:30.972 - error: zigbee.0 Zigbee publish to '0x84182600000fa3fa', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205\. No network route. Please confirm that the device has (re)joined the network. 2018-12-01 08:45:30.982 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT cc-znp:AREQ <-- AF:dataConfirm, { status: 205, endpoint: 1, transid: 23 } 2018-12-01 08:45:30.984 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object] 2018-12-01 08:45:30.987 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:30 GMT zigbee-shepherd:msgHdlr IND <-- AF:dataConfirm, transId: 23 2018-12-01 08:45:30.988 - debug: zigbee.0 2018-12-01T07:45:30.988Z zigbee:controller error Zigbee publish to '0x84182600000fa3fa', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 205\. No network route. Please confirm that the device has (re)joined the network. undefined 2018-12-01 08:45:30.988 - error: zigbee.0 Zigbee publish to '0x84182600000fa3fa', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 205\. No network route. Please confirm that the device has (re)joined the network. 2018-12-01 08:45:45.521 - debug: zigbee.0 User stateChange zigbee.0.84182600000fa3fa.state {"val":false,"ack":false,"ts":1543650345519,"q":0,"from":"system.adapter.web.0","lc":1543650345519} 2018-12-01 08:45:45.537 - debug: zigbee.0 2018-12-01T07:45:45.537Z zigbee:controller debug Zigbee publish to '0x84182600000fa3fa', genOnOff - cmd off - payload {} - endpoint 3 undefined 2018-12-01 08:45:45.538 - debug: zigbee.0 Zigbee publish to '0x84182600000fa3fa', genOnOff - cmd off - payload {} - endpoint 3 2018-12-01 08:45:45.539 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT zigbee-shepherd:request REQ --> AF:dataRequest, transId: 25 2018-12-01 08:45:45.540 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT cc-znp:SREQ --> AF:dataRequest, { dstaddr: 48141, destendpoint: 3, srcendpoint: 1, clusterid: 6, transid: 25, options: 48, radius: 30, len: 3, data: } 2018-12-01 08:45:45.541 - debug: zigbee.0 Read timeout for cmd 'off' is 0 2018-12-01 08:45:45.541 - debug: zigbee.0 read message: {"cid":"genOnOff","cmd":"read","cmdType":"foundation","zclData":[{"attrId":0}],"cfg":{"manufSpec":0,"disDefaultRsp":0}} 2018-12-01 08:45:45.544 - debug: zigbee.0 2018-12-01T07:45:45.544Z zigbee:controller debug Zigbee publish to '0x84182600000fa3fa', genOnOff - cmd read - payload [{"attrId":0}] - endpoint 3 undefined 2018-12-01 08:45:45.544 - debug: zigbee.0 Zigbee publish to '0x84182600000fa3fa', genOnOff - cmd read - payload [{"attrId":0}] - endpoint 3 2018-12-01 08:45:45.545 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT zigbee-shepherd:request REQ --> AF:dataRequest, transId: 26 2018-12-01 08:45:45.558 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT cc-znp:SRSP <-- AF:dataRequest, { status: 0 } 2018-12-01 08:45:45.559 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT zigbee-shepherd:request RSP <-- AF:dataRequest, status: 0 2018-12-01 08:45:45.561 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT cc-znp:SREQ --> AF:dataRequest, { dstaddr: 48141, destendpoint: 3, srcendpoint: 1, clusterid: 6, transid: 26, options: 48, radius: 30, len: 5, data: } 2018-12-01 08:45:45.572 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT cc-znp:SRSP <-- AF:dataRequest, { status: 0 } 2018-12-01 08:45:45.573 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT zigbee-shepherd:request RSP <-- AF:dataRequest, status: 0 2018-12-01 08:45:45.964 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT cc-znp:AREQ <-- AF:dataConfirm, { status: 205, endpoint: 1, transid: 26 } 2018-12-01 08:45:45.965 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object] 2018-12-01 08:45:45.966 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:45 GMT zigbee-shepherd:msgHdlr IND <-- AF:dataConfirm, transId: 26 2018-12-01 08:45:45.966 - debug: zigbee.0 2018-12-01T07:45:45.966Z zigbee:controller error Zigbee publish to '0x84182600000fa3fa', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205\. No network route. Please confirm that the device has (re)joined the network. undefined 2018-12-01 08:45:45.967 - error: zigbee.0 Zigbee publish to '0x84182600000fa3fa', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205\. No network route. Please confirm that the device has (re)joined the network. 2018-12-01 08:45:46.166 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:46 GMT cc-znp:AREQ <-- AF:dataConfirm, { status: 205, endpoint: 1, transid: 25 } 2018-12-01 08:45:46.166 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:46 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: dataConfirm, msg: [object Object] 2018-12-01 08:45:46.169 - debug: zigbee.0 Sat, 01 Dec 2018 07:45:46 GMT zigbee-shepherd:msgHdlr IND <-- AF:dataConfirm, transId: 25 2018-12-01 08:45:46.169 - debug: zigbee.0 2018-12-01T07:45:46.169Z zigbee:controller error Zigbee publish to '0x84182600000fa3fa', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 205\. No network route. Please confirm that the device has (re)joined the network. undefined 2018-12-01 08:45:46.170 - error: zigbee.0 Zigbee publish to '0x84182600000fa3fa', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 205\. No network route. Please confirm that the device has (re)joined the network. !
                                Es scheint mit dem Gerät keinerlei Kommunikation stattzufinden. Dabei geht aber offensichtlich die Abfrage zum Aufbau der Map.
                                Interessant in diesem Zusammenhang:
                                • die beiden anderen Steckdosen lassen sich problemlos schalten
                                • der Bewegungsmelder ist seit gestern auch stumm. Wird aber in der Map als verbunden und bei jedem Neuaufbau mit marginal unterschiedlichen Werten der Verbindungsqualität dargestellt.
                                  saschkoer last edited by
                                  @arteck:
                                  @Sinalco:
                                  das Gerät nicht enfernen nur das Objekt löschen `
                                  Kann mich hier leider anschließen, habe das selbe Problem.
                                  Die Farbe lässt sich ohne Probleme ändern aber eine Änderung der Farbtemperatur nimmt er - auch nach Stoppen, löschen, starten des Adapters - nicht an 😞
                                    LJSven last edited by
                                    Nachdem Umzug vom Raspberry Pi zum Banana Pi macht mein Zigbee Stick / Adapter Probleme (Version 0.8.0) / hat jemand eine Idee?
                                    ! bananapimaster 2018-12-01 20:12:10.318 info instance system.adapter.zigbee.0 terminated with code 0 (OK)
                                    ! Caught 2018-12-01 20:12:10.318 error by controller[7]: 2018-12-01T19:12:10.232Z zigbee:controller info zigbee-shepherd stopped undefined
                                    ! Caught 2018-12-01 20:12:10.318 error by controller[7]: Sat, 01 Dec 2018 19:12:10 GMT zigbee-shepherd zigbee-shepherd is stopped.
                                    ! Caught 2018-12-01 20:12:10.317 error by controller[7]: Sat, 01 Dec 2018 19:12:10 GMT zigbee-shepherd zigbee-shepherd is stopping.
                                    ! Caught 2018-12-01 20:12:10.317 error by controller[6]: Sat, 01 Dec 2018 19:11:57 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
                                    ! Caught 2018-12-01 20:12:10.316 error by controller[5]: Sat, 01 Dec 2018 19:11:57 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 1024, srcaddr: 51628, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 5, securit
                                    ! Caught 2018-12-01 20:12:10.316 error by controller[4]: Sat, 01 Dec 2018 19:11:46 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
                                    ! Caught 2018-12-01 20:12:10.315 error by controller[3]: Sat, 01 Dec 2018 19:11:46 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 6, srcaddr: 55124, srcendpoint: 3, dstendpoint: 1, wasbroadcast: 0, linkquality: 10, securityu
                                    ! Caught 2018-12-01 20:12:10.315 error by controller[2]: Sat, 01 Dec 2018 19:11:44 GMT zigbee-shepherd:msgHdlr IND <– AF:incomingMsg, transId: 0
                                    ! Caught 2018-12-01 20:12:10.314 error by controller[1]: Sat, 01 Dec 2018 19:11:44 GMT cc-znp:AREQ <– AF:incomingMsg, { groupid: 0, clusterid: 6, srcaddr: 16779, srcendpoint: 3, dstendpoint: 1, wasbroadcast: 0, linkquality: 0, securityus
                                    ! zigbee.0 2018-12-01 20:12:10.233 info zigbee-shepherd stopped
                                    ! host.bananapimaster 2018-12-
                                      welche node version ??
                                        @arteck:
                                        welche node version ?? `
                                        root@bananapimaster:~# node -v
                                        v8.14.0
                                          hmm ok müsste ich mir mal live anschauen..
                                          wann hast du mal Zeit ??
                                            @saschkoer:
                                            @arteck:
                                            @Sinalco:
                                            Die Farbe lässt sich ohne Probleme ändern aber eine Änderung der Farbtemperatur nimmt er - auch nach Stoppen, löschen, starten des Adapters - nicht an 😞 `
                                            Ja, leider Funktioniert das so auch nicht
                                            1078
                                            344606
