    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
      fuchs1978 last edited by
      Ich bekomme auch einen Fehler:
      <code>2018-11-29 14:13:26.240  - [32minfo[39m: host.iobrokerVM instance system.adapter.homeconnect.0 started with pid 30461
      2018-11-29 14:13:26.745  - [32minfo[39m: homeconnect.0 starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v6.13.0
      2018-11-29 14:13:27.102  - [31merror[39m: homeconnect.0 uncaught exception: Cannot read property 'length' of undefined
      2018-11-29 14:13:27.103  - [31merror[39m: homeconnect.0 TypeError: Cannot read property 'length' of undefined
          at devicesDp (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:621:42)
          at inventorySub (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:587:5)
          at inventory (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:432:13)
          at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.homeconnect/main.js:428:9)
          at emitTwo (events.js:106:13)
          at Adapter.emit (events.js:191:7)
          at Immediate. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3429:38)
          at runCallback (timers.js:672:20)
          at tryOnImmediate (timers.js:645:5)
          at processImmediate [as _immediateCallback] (timers.js:617:5)
      2018-11-29 14:13:27.103  - [32minfo[39m: homeconnect.0 cleaned everything up...
      2018-11-29 14:13:27.107  - [32minfo[39m: homeconnect.0 terminating
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]: TypeError: Cannot read property 'length' of undefined
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at devicesDp (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:621:42)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at inventorySub (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:587:5)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at inventory (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:432:13)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.homeconnect/main.js:428:9)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at emitTwo (events.js:106:13)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at Adapter.emit (events.js:191:7)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at Immediate. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3429:38)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at runCallback (timers.js:672:20)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at tryOnImmediate (timers.js:645:5)
      2018-11-29 14:13:27.114  - [31merror[39m: Caught by controller[0]:     at processImmediate [as _immediateCallback] (timers.js:617:5)
      2018-11-29 14:13:27.114  - [31merror[39m: host.iobrokerVM instance system.adapter.homeconnect.0 terminated with code 0 (OK)[/code]</anonymous></anonymous></anonymous></anonymous></code>
      • Espace0401
        Espace0401 last edited by
        Bei mir läuft der Adapter leider auch nicht und schreibt mit den ganzen Tag das Log mit folgenden Fehlern voll:
        host.ioBroker-RasPi 2018-11-29 10:47:27.030 error instance system.adapter.homeconnect.0 terminated with code 0 (OK)
        Caught 2018-11-29 10:47:27.030 error by controller[0]: at Object.onceWrapper (events.js:313:30)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/request/request.js:1085:12)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at Request.emit (events.js:211:7)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at emitOne (events.js:116:13)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at Request. <anonymous>(/opt/iobroker/node_modules/request/request.js:1163:10)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at Request.emit (events.js:214:7)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at emitTwo (events.js:126:13)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.homeconnect/lib/auth.js:92:30)
        Caught 2018-11-29 10:47:27.029 error by controller[0]: at JSON.parse (<anonymous>)
        Caught 2018-11-29 10:47:27.028 error by controller[0]: SyntaxError: Unexpected token < in JSON at position 0</anonymous></anonymous></anonymous>
        • Z
          z-smoker last edited by
          bin auch dabei 😉
          haut noch nicht hin
          Aber immer mit der Ruhe - wird schon noch werden 8-)
            dna909 last edited by
            Habt ihr alle mindestens Nodejs Version 6 installiert?
            • N
              Nikoxx last edited by
              jep,
              nodejs 6.14.X, weiss ich jetzt aus dem kopf nicht genau hab aber gestern erst noch geguckt.
              Gruß Niko
                Ich schau mir das demnächst mal an. Hab grad nicht soviel Zeit….
                Bei mir läuft es. Liegt aber möglicherweise daran das ich nur ein Gerät habe. Evtl. kommen in dem Stream auch Messages die in der API nicht richtig dokumentiert sind. Musste leider schon feststellen, das da so einiges unstimmig ist.
                Aber ich bleibe am Ball.
                Sobald ich den Fehler eingegrenzt habe, geb ich bescheid.
                Wünsche Euch trotzdem noch ein schönes Wochenende [emoji2]
                  lutzer last edited by
                  Wird schon, wir sind dir sehr dankbar für deine Mühe!
                    Ist auch mein erster Adapter, den ich programmiere. Meine JS/Node-Kenntnisse sind auch noch sehr bescheiden. Denke die Profis hier im Forum würden mich für den Code hauen, aber für mich zählt letztlich nur das was hinten rauskommt. Und vor Allem lerne ich dabei. Vor ein paar Wochen hatte ich z.B. keine Ahnung, was es mit Promises auf sich hat. Ist echt eine feine Sache, um diese ganze Ansynchronität von JS zu überwinden.
                    Ich habe auf jeden Fall noch viel Arbeit vor mir. Bin auch ein Autodidakt, ich frage wirklich erst, wenns garnicht klappen will. Und bisher hab ich alles soweit hinbekommen, auch ohne fremde Hilfe. Und das Problem bekomm ich auch gelöst [emoji3][emoji3][emoji3]
                    dna909
                      Ich finde es super was du machst. Weiter so, wir helfen gerne
                      • Espace0401
                        Alles gut und Danke für das Projekt. ich nutze Node.js: v8.11.3 und NPM: 6.4.1.
                          Bei mir:
                          root@iobrokerVM:~# nodejs -v
                          v6.13.0
                          root@iobrokerVM:~# npm -v
                          3.10.10
                          • AxelF1977
                            AxelF1977 last edited by
                            HI,
                            erstmal danke für die Arbeit an dem Adapter.
                            Ich habe auch das Problem, dass nach dem Bestätigen der Authorization-URL der Adapter rot bleibt.
                            root@ioBroker-Tinker:~# nodejs -v
                            v8.12.0
                            root@ioBroker-Tinker:~# npm -v
                            6.4.1
                            • Z
                              Zeebo last edited by
                              Auch von mir erst einmal vollsten Respekt für deine Mühe! Ich habe es auch mal versucht, aber nicht die Zeit gefunden, mich in die Adapterentwicklung einzuarbeiten.
                              Vor etwa eine Woche habe ich die Version 0.0.4 installiert. Wenn ich das richtig gesehen habe, funktionierte diese auch, zumindest gab es keine Fehlermeldungen. Heute habe ich dann gesehen, dass es Fehler im Log gibt:
                              homeconnect.0 2018-12-01 18:26:27.454 info terminating
                              homeconnect.0 2018-12-01 18:26:27.453 info cleaned everything up...
                              homeconnect.0 2018-12-01 18:26:27.452 error at processImmediate [as _immediateCallback] (timers.js:745:5)
                              homeconnect.0 2018-12-01 18:26:27.452 error at tryOnImmediate (timers.js:768:5)
                              homeconnect.0 2018-12-01 18:26:27.452 error at runCallback (timers.js:810:20)
                              homeconnect.0 2018-12-01 18:26:27.452 error at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3429:38)
                              homeconnect.0 2018-12-01 18:26:27.452 error at Adapter.emit (events.js:214:7)
                              homeconnect.0 2018-12-01 18:26:27.452 error at emitTwo (events.js:126:13)
                              homeconnect.0 2018-12-01 18:26:27.452 error at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.homeconnect/main.js:195:9)
                              homeconnect.0 2018-12-01 18:26:27.452 error at eventSetDp (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:201:34)
                              homeconnect.0 2018-12-01 18:26:27.452 error TypeError: valueVal.split is not a function
                              homeconnect.0 2018-12-01 18:26:27.452 error uncaught exception: valueVal.split is not a function
                              homeconnect.0 2018-12-01 18:25:53.796 info starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v8.12.0</anonymous>
                              Habe dann gesehen, dass es eine neuere Version 0.0.5 gibt, also habe ich aktualisiert, nun, wie andere bereits berichtet haben, wird der Adapter nicht mehr grün:
                              homeconnect.0	2018-12-01 18:34:49.855	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v8.12.0
                              homeconnect.0	2018-12-01 18:34:19.077	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v8.12.0
                              homeconnect.0	2018-12-01 18:33:48.287	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v8.12.0
                              homeconnect.0	2018-12-01 18:33:17.504	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v8.12.0
                              homeconnect.0	2018-12-01 18:32:46.683	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v8.12.0
                              homeconnect.0	2018-12-01 18:32:15.857	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v8.12.0
                              homeconnect.0	2018-12-01 18:31:45.313	error	uncaught exception: Cannot read property 'length' of undefined
                              homeconnect.0	2018-12-01 18:31:45.053	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v8.12.0
                              Node.js: v8.12.0
                              NPM: 4.6.1
                              Ich habe die Logs helfen dir, wenn du weitere Infos brauchst, frag ruhig ;)
                                butsch last edited by
                                Ich konnte den Adaper installieren und einrichten.
                                Allerdings bin ich mir nicht sicher, ob hier alle Datenpunkte da sind:
                                Wenn hier alles ok ist, wo sehe ich den aktuellen Status?
                                  Skydream last edited by
                                  da ich mir grade einen neuen Herd gekauft habe der Home Connect beherrscht kommt dein Adapter genau richtig. 😄
                                  Auf den ersten Blick funktioniert auch alles….nur nach einem Tag kommen bekomme ich keine Updates mehr.
                                  Starte ich den Adapter neu, "sehe" ich wenn z.b die Backofentür auf und zu gemacht wird, bzw. welche Temperatur am Backofen eingestellt ist.
                                  Nur am nächsten Tag werden diese Infos nicht mehr zum ioBroker publiziert.
                                  Unter Ereignisse sehe ich aber "system.adapter.homeconnect.0.connected true" mit einer aktuellen Uhrzeit.
                                  Irgendeine Idee woran das liegen kann?
                                    Habe im Moment nicht soviel Zeit. Aber die Entwicklung geht bald wieder weiter.
                                    Ich halte Euch auf dem laufenden.
                                    dna909
                                      GrillSgt last edited by
                                      @dna909:
                                      Bei mir läuft es. Liegt aber möglicherweise daran das ich nur ein Gerät habe. [emoji2] `
                                      Nope. Tritt auch mit "nur" einem Gerät auf. Auf alle Fälle erst mal schöne Weihnachten.
                                      Michael
                                      • kmxak
                                        Manueller Workarround um den Adapter behelfsmäßig wieder an gang zu bekommen.
                                        Im Verzeichnis die Datei öffnen:
                                        In der Zeile 602-604
                                            case "Hob":
                                            devicesDp(deviceArray.Hob);
                                            break;
                                        entfernen
                                        https://github.com/dna909/ioBroker.home … in.js#L602
                                        Habe die Issue mal aktualisiert und villeicht hilft es dir ja bei der Problemlösung.
                                        Leider bin ich gerade zu blöde mir selber die passende Json rauszusuchen... stehe auf dem schlauch sonst hätte ich da auch mal reingeschaut.
                                        Aber du hast eh mehr Ahnung als ich :roll:
                                          Brookyman last edited by
                                          Habe gerade mal den Adapter zum Test installiert. Bei mir kommen die gleichen Fehler nach dem LogIn.
                                          Das Löschen von:
                                          case "Hob":
                                          break;
                                          brachte bei mir keinen Erfolg.
                                          • kmxak
                                            ich habe es heute auf Github mitbekommen das es sich wohl nicht nur um den einen Gerätetypen handelt.
                                            In meinem Fall war es der Hob (Kochfeld). Seit dem ich es raus genommen habe gehen alle anderen Geräte mit dem Adapter.
                                            Dann wird es bei dir wohl ein anderes Gerät sein.
                                            Siehe Log der Eintrag der auf die Zeile 579 - 623 verweist.
                                            1.2k
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            512370
