    4. FHEM Adapter
    FHEM Adapter
      Kyocera007 last edited by
      Hallo, ich habe endlich mal den Fhem-Adapter auf die neueste Version aus Git-Hub aktualisiert, bekomme aber folgende Meldungen.
      fhem.0	2018-11-25 13:33:46.008	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:33:45.855	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:33:45.698	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:33:45.549	info	Create channel fhem.0.Unknown | Unknown
      fhem.0	2018-11-25 13:33:45.546	info	check channel Unknown > jsonlist2 Unknown
      fhem.0	2018-11-25 13:33:45.545	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:32:53.004	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:32:52.850	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:32:52.696	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:32:52.542	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:32:52.389	info	check channel Unknown > jsonlist2 Unknown
      fhem.0	2018-11-25 13:32:52.389	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:32:18.423	info	check channel Stromzaehler > jsonlist2 Stromzaehler
      fhem.0	2018-11-25 13:32:18.423	warn	unhandled event FHEM "ESA2000 Stromzaehler CNT: 42- CUM: 3107.267 CUR: 0.331 TICKS: 75 LR" > jsonlist2
      fhem.0	2018-11-25 13:32:00.002	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:31:59.848	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:31:59.694	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:31:59.541	info	check channel Unknown > jsonlist2 Unknown
      fhem.0	2018-11-25 13:31:59.541	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E8615594480" > jsonlist2
      fhem.0	2018-11-25 13:31:07.037	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      fhem.0	2018-11-25 13:31:06.875	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      fhem.0	2018-11-25 13:31:06.716	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      fhem.0	2018-11-25 13:31:06.557	info	check channel Unknown > jsonlist2 Unknown
      fhem.0	2018-11-25 13:31:06.557	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      fhem.0	2018-11-25 13:30:14.033	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      fhem.0	2018-11-25 13:30:13.873	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      fhem.0	2018-11-25 13:30:13.714	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      fhem.0	2018-11-25 13:30:13.554	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      fhem.0	2018-11-25 13:30:13.395	info	check channel Unknown > jsonlist2 Unknown
      fhem.0	2018-11-25 13:30:13.395	warn	unhandled event FHEM "CUL_TCM97001 Unknown Code: 3E85D5594580" > jsonlist2
      Was kann oder muss ich machen um diese Meldungen nicht mehr zu bekommen ??
      Danke und Gruß Werner
      • LausiD
        LausiD last edited by
        Hallo Werner,
        vielen Dank für Deine Rückmeldung 🙂
        = Ein Event/Ereignis "CUL_TCM97001 Unknown Code: 3E85D5594580" aus FHEM konnte nicht verarbeitet werden.
        Im Event monitor FHEM taucht dieser Eintrag bestimmt in gleicher Anzahl auf, oder?
        Ziel wäre es diesen Eintrag in FHEM aus der Welt zu schafen 🙂
        Alternativ: Unter Objekte fhem.1.info.Settings.logUnhandledEventFHEM auf false setzen.
        Damit werden die Meldungen unterdrückt, aber das eigentliche Problem bleibt.
        Hast du in FHEM ein Gerät mit dem Namen "Unknown" ?
        FHEM Befehlszeile "list Unknown"
        LausiD
        • LausiD
          zum Thema FS20
          viewtopic.php?f=20&t=9286&p=196762&hilit=FS20#p196762
          Habe mal folgendes geändert:
          Objekte on,off,dim06 usw von FS20 werden jetzt als Button in ioBroker angelegt.
          Dazu Update FHEM Adapter von github, FS20 Objekt in ioBroker löschen oder fhem.1.info.Configurations.autoRole auf "true" setzen.
          LausiD
            jupzup last edited by
            Habe heute ein Update von 0.50 aud 1.11 gemacht und bekomme nun im Log
            detect SONOSPLAYER "attr Sonos_Partyraum generateVolumeEvent 1" or "fhem.info.Configuration.autoConfigFhem" = true | more info README.md
            für alle meine vorhandenen Sonos Player. Habe mal die fhem.cfg gecheckt und da wird das Attribut "generateVolumeEvent" nicht gesetzt und "autoConfigFhem" steht auf false.
            • LausiD
              Korrekt so 😉
              Ohne das Attribut generateVolumeEvent 1 wird in FHEM kein Event für Lautstärke erzeugt und somit auch nicht in ioBroker übertragen.
              Die Meldung soll auf die 2 Möglichkeiten zur Abhilfe hinweisen: (Gerne Verbesserungsvorschläge für den Text )
              1. Attribut manuell in FHEM anlegen
              Oder viel einfacher und falls in Zukunft noch ähnliche Änderungen notwendig sind…
              2.autoConfigFHEM auf true setzen, dadurch Resync Adapter und Atrribut wird automatisch ifür jeden Sonos Player n FHEM angelegt 🙂
              Auszug aus READ.md;
              (Auch hier gerne Verbesserungsvorschläge zum Text)
              autoConfigFHEM
              Erlaubt folgende Änderungen in FHEM 1.Für TYPE=SONOSPLAYER attr xxx generateVolumeEvent 1 damit Lautstärke übertragen wird. Am Ende der Synchronisation save zum Speichern der Änderungen. (default=false)
              Sonst hat alles gepasst?
              Nachtrag:
              So wäre die Meldung besser, oder?
              detect SONOSPLAYER missing "attr ..........
              30.11.18 geändert auf github
              detect SONOSPLAYER: missing "attr xxx generateVolumeEvent 1" > set manuelly in FHEM or automatically with "fhem.x.info.Configurations.autoConfigFhem" = true | more info README.md
              LausiD
                Hi und vielen Dank für die ausführliche Erklärung. Dann hatte ich tatsächlich den Log Eintrag nur falsch verstanden.
                Also soweit scheint alles bei mir nach wie vor zu funktionieren kann aber noch noch nicht viel dazu sagen, da der Adapter ja erst seit ein paar Stunden läuft.
                Vielen Dank für deine Hilfe bzw. den tollen Adapter.
                EDIT: Nachdem ich soeben FHEM mal wieder neugestartet habe, bekomme ich nun weitere Warnings im Log ähnlich wie weiter oben von Werner beschrieben.
                • LausiD
                  @jupzup:
                  EDIT: Nachdem ich soeben FHEM mal wieder neugestartet habe, bekomme ich nun weitere Warnings im Log ähnlich wie weiter oben von Werner beschrieben. `
                  Vielen Dank für Deine Rückmeldung 🙂
                  Die Warnmeldung unhandled event habe ich eingebaut um nicht verarbeite Events aus FHEM im Log anzeigen zu können. In deinem Fall wird nur das Sonos Model aktualisiert….kannst unter fhem.0.info.Settings.logUnhandledEventFHEM auf false setzen.
                  Unter fhem.0.info.Configuration.autoConfigFHEM auf true und du hast keine warn Meldungen mehr
                  LausiD
                  • LausiD
                    Morgähn zusammen,
                    hat noch jemand diese Aqara Sensoren über CC2531 am Start und kann mir mal ein jsonlist2 davon zukommen lassen?
                    @Sedonion:
                    Keinen, bzw. FHEM Adapter.
                    In FHEM sind die Aqara Sensoren (Temperatur und Fensterkontakt) über einen Cc2531 USB Stick angebunden. `
                    viewtopic.php?f=8&t=18789&p=197720&hilit=fhem#p197720
                    jsonlist2 erledigt 🙂
                    Vielen Dank und Gruß
                    LausiD
                      @LausiD:
                      Hallo Werner,
                      LausiD `
                      Sooooo, sorry das ich mich erst jetzt melde, aber das Geld verdienen geht vor 🙂
                      ich habe jetzt einen Raum "IOBroker" in Fhem angelegt, den Devices die in Iobroker angezeigt werden sollen den Raum zugeordnet.
                      Thermometer, Steckdosen,HM-Fenster/Türkontakte,HM-Heizkörper-Thermostate und Energieverbrauch
                      Habe jetzt nur noch eine Meldung im Log
                      fhem.0	2018-12-01 13:42:26.710	warn	unhandled event FHEM "ESA2000 Stromzaehler CNT: 127- CUM: 3125.853 CUR: 0.353 TICKS: 75 LR" > jsonlist2
                      fhem.0	2018-12-01 13:40:10.663	info	check channel Stromzaehler > jsonlist2 Stromzaehler
                      fhem.0	2018-12-01 13:40:10.663	warn	unhandled event FHEM "ESA2000 Stromzaehler CNT: 126- CUM: 3125.840 CUR: 0.152 TICKS: 75 LR" > jsonlist2
                      welche Daten benötigst du ??
                      Gruß Werner
                      • LausiD
                        @Kyocera007:
                        Code: Alles auswählen
                        fhem.0 2018-12-01 13:40:10.663 warn unhandled event FHEM "ESA2000 Stromzaehler CNT: 126- CUM: 3125.840 CUR: 0.152 TICKS: 75 LR" > jsonlist2 `
                        Hallo Werner,
                        mit dem Geld verdienen geht mir auch…mehr Geld = weniger Freizeit 🙂
                        Vermutlich ist das der state-Wert von Stromzaehler. Die : werden noch nicht richtig auflösen, deshalb wird Stromzeahler neu eingelesen.
                        Also unkritisch 🙂
                        Du kannst "fhem.0.info.Settings.logUnhandledEventFHEM" auf false setzen und Ruhe ist.
                        Grundsätzlich können unter "fhem.0.info.Settings" Meldungen fürs Log mit true/false ausgewählt werden.
                        edit 17.12.18
                        states mit : sollten jetzt auch richtig aufgelöst werden
                        Gruß und viel Spaß mit ioBroker,FHEM usw
                        LausiD
                        • LausiD
                          auf github kann der Adapter mit folgenden Änderungen aktualisiert werden
                          Da state eines FHEM Device unterschiedliche Zustände/Funktionen haben kann, werden bei Bedarf im ioBroker automatisch zusätzliche Objekte angelegt.
                          1. fhem.x.Device.state enthält den Wert aus FHEM 1:1 als String
                          a. fhem.x.Device.state_switch true/false als Boolean, wenn state on oder off ist oder Possible Sets on und off enthalten.
                          Dadurch kann zB auch ein dummy als Schalter verwendet werden.
                          b. fhem.x.Device.state_boolean true/false , wenn state open/ooened/close/closed/present/absent ist.
                          c. fhem.x.Device.state_value 0/2 für die Werte von state_boolean
                          Damit sollte es in VIS viel einfacher werden 🙂
                          2. Objekte mit nummerischen Inhalt werden als number angelegt
                          LausiD
                          • LausiD
                            was habe ich mich schon mit den HUEGroup´s in FHEM rumgeärgert….keine Readings, kein state nichts.
                            Dabei ist es so einfach...zur HUEBridge Atrribute createGroupReadings 1 hinzufügen 🙂
                            https://forum.fhem.de/index.php/topic,81711.0.html
                            Wer fhem.x.info.Configurations.autoConfigFHEM auf true stehen hat bekommt das Attribut automatisch in FHEM gesetzt und somit auch die entsprechenden Objekte im ioBroker.
                            (Adapter über github aktualisieren)
                            LausiD
                            • LausiD
                              wer Zeit und Lust hat darf gerne mal den FHEM Adapter von github aktualisieren 🙂
                              Folgende Änderungen:
                              1. fhem.x.device.Atrributes.alias wird jetzt für jedes Objekt channel angelegt (alias nicht vorhanden alias=Name Device) und für folgende Funktionen verwendet:
                              a. Objekt channel als Name
                              b. Bei Instanz fhem.0 als SmartName für Adapter Cloud
                              Nach der ersten Synchronisation aus FHEM sind alle steuerbaren Objekte im Cloud Adapter mit dem "alias" Namen unter Smart Geräte angelegt.
                              c. Für Adapter Material UI als Name "Kachel"
                              d. alias enthält Tür,door bei einem Sensor role=sensor.door
                              e. alias enthält Fenster,window bei einem Sensor role=sensor.window
                              2. Zusätzlich zu open/opened/close/closed/present/absent im state aus FHEM wird motion/nomotion erkannt
                              a. open/opened/close/closed in Abhängigkeit von alias role=sensor.door oder sensor.window (fhem.x.Device.state_boolean)
                              Wird von Material UI erkannt und angezeigt
                              b. motion/nomotion role=sensor.motion (fhem.x.Device.state_boolean)
                              c. present/absent role=indicator.presence (fhem.x.Device.state_boolean)
                              Role ist nicht gut gewählt, wird noch nicht von Material UI erkannt 😞 Wer eine besseren Idee hat nur her damit 🙂
                              Kann jemand ein jsonlist2 von Rollladen/blind hier einstellen? Danke
                              Gruß und ein schönes Wochenende
                              LausiD
                              • LausiD
                                zur Info
                                Device MAX in Verbindung mit Heizungsthermostatsteuerung 2.0 - Script
                                viewtopic.php?f=21&t=10096&start=760
                                LausiD
                                • LausiD
                                  Morgähn,
                                  Adapter von github aktualisieren und neue Funktion testen 🙂
                                  1. In FHEM wird automatisch ein dummy send2ioB im Raum ioB_System angelegt.
                                  2. Mit "set send2ioB [Objekt in ioBroker] [Wert]" können states im ioBroker gesetzt werden.
                                  zB set send2ioB alexa2.0.Echo-Devices.[deine id].Commands.speak FHEM lässt Alexa sprechen
                                  3. Es erfolgt eine Prüfung ob Objekt vorhanden und Write=true ist
                                  Somit sind jetzt alle Möglichkeiten im FHEM Adapter gegeben:
                                  1. fhem.x.info.Commands.sendFHEM entspricht der Befehlszeile in FHEM
                                  2. Unter fhem.x.info.Configurations.allowedIOBin können Objekte/States aus ioBroker zur Übertragung an FHEM definiert werden.
                                  Wer möchte kann jetzt zB seine gesamte Steuerung weiterhin in FHEM/Perl umsetzen 🙂
                                  Nicht vergessen: Eure Rückmeldungen helfen den Adapter zu verbessern…Danke
                                  LausiD
                                  • LausiD
                                    zur Info:
                                    Viele Meldungen "check channel [Device Name] > jsonlist2 [Device Name]"
                                    viewtopic.php?f=20&t=19613&p=205333#p205333
                                    LausiD
                                    • LausiD
                                      zur Info:
                                      Absturz FHEM Adapter bei Verwendung \n in readings
                                      viewtopic.php?f=22&t=20105&start=40
                                      • LausiD
                                        Morgähn,
                                        Adapter von github aktualisieren und folgende Funktionen sind neu:
                                        1. fhem.x.info.Configurations.deleteUnusedObjects
                                        true=Automatisches Löschen nicht synchronisierter Objekte aus FHEM (default wie bisher)
                                        false=keine automatische Löschung
                                        2. fhem.x.info.Debug.activate
                                        Für Device Namen aus FHEM mit Komma getrennt werden im admin Log Einträge für Anlage Objekte bei Synchro aus FHEM, Events aus FHEM und löschen nicht benutzer Objekte in ioBroker erzeugt.
                                        Danke für Rückmeldungen 🙂
                                        LausiD
                                        • LausiD
                                          Nabend zusammen,
                                          gerade noch den aktuellen Stand FHEM Adapter auf github geschoben…
                                          Keine neuen Funktionen, aber einige Verbesserungen 🙂
                                          Wer mal testen kann bitte um Rückmeldung.
                                          Falls keine Probleme kann neue Version generiert werden.
                                          LausiD
                                            Einklaus last edited by
                                            Hallo Lausi,
                                            scheint alles i.O. zu sein. Ist seit gestern Abend am laufen.
                                            Habe aber Fhem auch nur mit bisschen Hardware am laufen (FS20 und FloureonThermostate).
                                            Gruss
                                            Klaus
                                            81.1k
                                            adapter fhem
                                            82
                                            676
                                            194115
