    4. HomematicRPC 1.8 + REGA 2.0 testen
    • foxriver76
      @RolfFrie:
      In CCU Authentifizierung eingeschaltte un Firewall/Sicheheit alles offen. Beide obigen Adapter installiert:
      Bleibt ROT
      im LOG
      hm-rega.0 2018-12-02 16:00:38.408 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      hm-rega.0 2018-12-02 16:00:38.408 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      hm-rega.0 2018-12-02 16:00:38.408 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      hm-rega.0 2018-12-02 16:00:38.408 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      hm-rega.0 2018-12-02 16:00:38.408 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      hm-rega.0 2018-12-02 16:00:38.408 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      hm-rega.0 2018-12-02 16:00:38.408 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      hm-rega.0 2018-12-02 16:00:38.408 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      hm-rega.0 2018-12-02 16:00:38.408 error at Socket.adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:98:50)
      hm-rega.0 2018-12-02 16:00:38.408 error at Object.decrypt (/opt/iobroker/node_modules/iobroker.hm-rega/lib/crypto.js:29:30)
      hm-rega.0 2018-12-02 16:00:38.408 error TypeError: Cannot read property 'length' of undefined
      hm-rega.0 2018-12-02 16:00:38.406 error uncaught exception: Cannot read property 'length' of undefined
      hm-rega.0 2018-12-02 16:00:38.289 info starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.15.0
      CUXD scheint alles OK: GRÜN
      HM wireless
      Wahll von https, Nutzername/Passwort deaktiviert: Ergebnis GELB
      im LOG
      hm-rpc.1 2018-12-02 16:08:38.428 error init error: Error: response timeout
      HMIP
      Wahll von https, Nutzername/Passwort erledigt: Ergebnis GELB
      Keine Fehler im LOG
      Weiß jemand was hier passiert?</anonymous></anonymous> `
      Bezüglich dem cannot read prop length of udnefined error: Hast du ein Upload des Adapters durchgeführt?
      @RolfFrie:
      HM wireless
      Wahll von https, Nutzername/Passwort deaktiviert: Ergebnis GELB `
      Wenn du in der CCU Authentifizierung eingeschaltet hast musst du auch ein Nutzername PW angeben. Ansonsten kann sich der Adapter ja nicht authentifizieren. Zudem muss das Protokoll auf XML-RPC stehen.
        RolfFrie last edited by
        Ein Upload hat REGA repariert: GRÜN:
        CUXD: Sowieso GRÜN
        Aber WIRELESS unD HMIP auch mit xml und Passwort weiterhin GELB, obwohl im LOG kein Fehler
        habe auch schon verschiedene Nutzer einschließlich root verwendet: Kein Unterschied.
        wirelss
        hm-rpc.1 2018-12-02 18:41:55.504 info xmlrpc client is trying to connect to 192.168.178.32:2001/ with ["https://192.168.178.61:12001","hm-rpc.1"]
        hm-rpc.1 2018-12-02 18:41:55.502 info xmlrpc server is trying to listen on 192.168.178.61:12001
        hm-rpc.1 2018-12-02 18:41:55.149 info starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.15.0
        hm-rpc.1 2018-12-02 18:41:53.599 info xmlrpc -> 192.168.178.32:2001/ init ["https://192.168.178.61:12001",""]
        hm-rpc.1 2018-12-02 18:41:51.596 info xmlrpc -> 192.168.178.32:2001/ init ["https://192.168.178.61:12001",""]
        HMIP
        hm-rpc.2 2018-12-02 18:41:48.608 info xmlrpc client is trying to connect to 192.168.178.32:2010/ with ["https://192.168.178.61:12010","hm-rpc.2"]
        hm-rpc.2 2018-12-02 18:41:48.604 info xmlrpc server is trying to listen on 192.168.178.61:12010
        hm-rpc.2 2018-12-02 18:41:48.199 info starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.15.0
        hm-rpc.2 2018-12-02 18:41:46.578 info xmlrpc -> 192.168.178.32:2010/ init ["https://192.168.178.61:12010",""]
        hm-rpc.2 2018-12-02 18:41:44.583 info xmlrpc -> 192.168.178.32:2010/ init ["https://192.168.178.61:12010",""]
        • foxriver76
          Hast du die Ports geändert? Statt den 12001 sollte es 42001 sein und statt 12010 => 42010
          Und bei den Nutzerdaten, sind die gemeint, mit denen du dich an der CCU anmeldest. Per Default gibts da den User Admin.
            Ports von Wireless und HMIP sind jetzt auf 4…. geändert
            Admin-Passwort für CCU genutzt
            Leider gleiches Ergebnis
            • foxriver76
              Kannst du evtl mal ein Screenshot von CCU Firewall und der Instanzconfig hochladen (sensible Daten bitte unkenntlich).
                IstanzConfig ? Meinst DU das:
                • system.adapter.hm-rega.0 : hm-rega - enabled
                • system.adapter.hm-rpc.0 : hm-rpc - enabled, port: 18701
                • system.adapter.hm-rpc.1 : hm-rpc - enabled, port: 42001
                • system.adapter.hm-rpc.2 : hm-rpc - enabled, port: 42010
                CCU Firewall: 7396_ccu_firewall_2018-12-03_200424.jpg
                  eve11 last edited by
                  Hallo zusammen, bei mir ist das Problem komplett dito wie bei RolfFrie.
                  Im LOG keinerlei Fehlermeldungen.
                  eve11
                  • foxriver76
                    @RolfFrie:
                    CCU Firewall:CCU Firewall 2018-12-03 200424.jpg `
                    Gib mal bitte explizit die Vierer Ports frei in der CCU FW. Auf welcher Raspmatic Version bist du. Die vom 26.11? Ich bin mit den FW Settings noch nicht so 100 % warm geworden, anscheinend gab es auch einen kleinen bug in der vom 24.11.
                    Und nach ändern der FW Einstellungen ist ein CCU Neustart erforderlich.
                    • foxriver76
                      Anbei mal Minimal Settings die bei mir funktionieren (und Auth ist an unter dem Pubkt Sicherheit). 6392_b3a37806-c8ad-4fee-8062-41b0c153b41f.jpeg
                      Wenn HM-IP genutzt wird, sollte der Port 42010 noch ergänzt werden.
                        Hi again
                        Meine CCU Version ist 3.41.11.20181126
                        Habe jetzt so wie bei Dir alle Port-Freigane manuell eingetragen. Und es sowohl mit Ports blockiert als auch offen versucht:
                        Ergebnis:
                        Mit Ports blockiert CUXD,Wireless UND HMIP alle GELB
                        MIt Ports offen: CUXD GRÜN, aber weiterhin Wireless UND HMIP GELB
                        • foxriver76
                          Und der Log sagt nach wie vor response timeout?
                          Am besten ein Screenshot der Instanz Config und sensible Sachen wie Nutzername einfach abändern oder schwärzen.
                          Also wenn der Port jetzt explizit geöffnet ist und das auch geklappt hat sollte zumindest kein response Timeouts mehr kommen.
                            Der log ist schon länger fehlerfrei. Aber es ist halt immer ich GELB und nicht Grün.
                            Was meinst du mit Instanz konfig?
                            • foxriver76
                              Die Konfigurationsseite (Instanzen - hm-rpc.X und auf das Tool dahinter geklickt) im ioB und irgendwas sollte im Log stehen, response Timeout dauert gerne etwas. Hast du die Ports der CCU irgendwie geändert/ bei dir läuft ja CuxD auch unter einem anderen als default?
                                Tatsächlich jrtzt gibt bei beiden nur noch Fehler :
                                Init error: socket hang up
                                Also bewusst habe ich keine ports angepasst
                                • foxriver76
                                  @RolfFrie:
                                  Also bewusst habe ich keine ports angepasst `
                                  Das könnte daran liegen, wenn nutze https nicht angehakt ist in den zusätzlichen Einstellungen der Instanz. Dann versucht er ohne https zu verbinden und das geht an diesem Port nicht.
                                    Hier alle Seiten der Konfiguration
                                    • foxriver76
                                      Ports stimmen nicht. Habe da nochmal was gepusht, dass die Ports auf jeden Fall korrekt ausgefüllt werden in der GUI: muss 42010 und 42001 sein.
                                        Aber bei mir steht doch 42001 und 42010. Was muss ich anpassen?
                                          Flauschi last edited by
                                          nicht adapter, die müssen auf homematic so sein 🙂
                                          • foxriver76
                                            Flauschi hat’s schon geschrieben.
                                            Der Homematic Port muss angepasst werden.
                                            31.7k
                                            79.8k
                                            83
                                            11680
