Test Adaper Discovergy v0.4.x
Das kommt momentan im log bei mir:
2018-12-05 17:20:43.085 - info: discovergy.0 meterId : 928bbbc346c34c1fafc867467396712e
2018-12-05 17:20:43.086 - error: discovergy.0 MeterId_Found
2018-12-05 17:20:43.087 - info: discovergy.0 serialNumber : 60867681
2018-12-05 17:20:43.089 - info: discovergy.0 location : [object Object]
2018-12-05 17:20:43.089 - info: discovergy.0 administrationNumber : DE0002883254700000000102547100000
2018-12-05 17:20:43.089 - info: discovergy.0 type : EASYMETER
2018-12-05 17:20:43.090 - info: discovergy.0 measurementType : ELECTRICITY
2018-12-05 17:20:43.090 - info: discovergy.0 scalingFactor : 1
2018-12-05 17:20:43.090 - info: discovergy.0 currentScalingFactor : 1
2018-12-05 17:20:43.090 - info: discovergy.0 voltageScalingFactor : 1
2018-12-05 17:20:43.090 - info: discovergy.0 internalMeters : 1
2018-12-05 17:20:43.090 - info: discovergy.0 firstMeasurementTime : 1537888127652
2018-12-05 17:20:43.090 - info: discovergy.0 lastMeasurementTime : 1544026883602
2018-12-05 17:20:43.338 - info: history.0 enabled logging of discovergy.0.928bbbc346c34c1fafc867467396712e.Power, Alias=false
2018-12-05 17:20:43.345 - info: history.0 enabled logging of discovergy.0.928bbbc346c34c1fafc867467396712e.Power_Total, Alias=false
2018-12-05 17:20:46.052 - info: discovergy.0 meterId : 928bbbc346c34c1fafc867467396712e
2018-12-05 17:20:46.056 - error: discovergy.0 MeterId_Found
2018-12-05 17:20:46.057 - info: discovergy.0 serialNumber : 60867681
2018-12-05 17:20:46.057 - info: discovergy.0 location : [object Object]
2018-12-05 17:20:46.057 - info: discovergy.0 administrationNumber : DE0002883254700000000102547100000
2018-12-05 17:20:46.057 - info: discovergy.0 type : EASYMETER
2018-12-05 17:20:46.057 - info: discovergy.0 measurementType : ELECTRICITY
2018-12-05 17:20:46.057 - info: discovergy.0 scalingFactor : 1
2018-12-05 17:20:46.058 - info: discovergy.0 currentScalingFactor : 1
2018-12-05 17:20:46.058 - info: discovergy.0 voltageScalingFactor : 1
2018-12-05 17:20:46.058 - info: discovergy.0 internalMeters : 1
2018-12-05 17:20:46.058 - info: discovergy.0 firstMeasurementTime : 1537888127652
2018-12-05 17:20:46.058 - info: discovergy.0 lastMeasurementTime : 1544026886602
2018-12-05 17:20:46.234 - info: history.0 enabled logging of discovergy.0.928bbbc346c34c1fafc867467396712e.Power, Alias=false
2018-12-05 17:20:46.241 - info: history.0 enabled logging of discovergy.0.928bbbc346c34c1fafc867467396712e.Power_Total, Alias=false
2018-12-05 17:20:49.068 - info: discovergy.0 meterId : 928bbbc346c34c1fafc867467396712e
2018-12-05 17:20:49.072 - error: discovergy.0 MeterId_FoundAlle 3 Sekunden```` 2018-12-05 17:20:46.056 - error: discovergy.0 MeterId_Found
Ups hohle ich in Version 0.3.1 raus danke !
Sagst du bescheid wenn es eine neue Version gibt?
Jup, das wird wohl irgendwo zwischen 9 und 10 sein möchte par Sachen verbessern.
version 0.2.0 ist raus.
der adapter ist jetzt auch per NPM verfuegbar, wird demnaest in die ioBroker repository aufgenommen.
Also installation entwerder per github oder per npm :
cd /opt/iobroker npm install iobroker.discovergy
<size size="85">Edit: sudo entfernt (AlCalzone)</size>
` > ### 0.2.0
(Dutchman) reduced logging from every 3 seconds to only error if values are received which cannot be handled
(Dutchman) last time step of syncronisation added, currenlty unix time needs to be converted in next release `
Das sieht nicht gut aus bei mir.
discovergy.0 2018-12-05 21:17:02.678 error Send this information to developer : power226880 discovergy.0 2018-12-05 21:17:02.678 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:17:02.677 error Send this information to developer : power1312370 discovergy.0 2018-12-05 21:17:02.677 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:17:02.676 error Send this information to developer : power333610 discovergy.0 2018-12-05 21:17:02.668 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:17:02.665 error Send this information to developer : voltage3229500 discovergy.0 2018-12-05 21:17:02.665 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:17:02.665 error Send this information to developer : voltage2230100 discovergy.0 2018-12-05 21:17:02.665 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:17:02.664 error Send this information to developer : voltage1229100 discovergy.0 2018-12-05 21:17:02.662 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:17:02.659 info query result of meter : {"time":1544041022095,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":229100,"voltage2":230100,"voltage3":229500,"energyOut1":0,"power":372860,"energyOut2": discovergy.0 2018-12-05 21:16:59.711 error Send this information to developer : power227060 discovergy.0 2018-12-05 21:16:59.711 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:59.710 error Send this information to developer : power1324140 discovergy.0 2018-12-05 21:16:59.709 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:59.709 error Send this information to developer : power333610 discovergy.0 2018-12-05 21:16:59.708 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:59.708 error Send this information to developer : voltage3229400 discovergy.0 2018-12-05 21:16:59.707 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:59.704 error Send this information to developer : voltage2230100 discovergy.0 2018-12-05 21:16:59.704 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:59.703 error Send this information to developer : voltage1228900 discovergy.0 2018-12-05 21:16:59.703 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:59.701 info query result of meter : {"time":1544041019095,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":228900,"voltage2":230100,"voltage3":229400,"energyOut1":0,"power":384810,"energyOut2": discovergy.0 2018-12-05 21:16:56.757 error Send this information to developer : power227000 discovergy.0 2018-12-05 21:16:56.756 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:56.750 error Send this information to developer : power1324430 discovergy.0 2018-12-05 21:16:56.749 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:56.748 error Send this information to developer : power333820 discovergy.0 2018-12-05 21:16:56.745 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:56.744 error Send this information to developer : voltage3229300 discovergy.0 2018-12-05 21:16:56.742 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:56.740 error Send this information to developer : voltage2230100 discovergy.0 2018-12-05 21:16:56.736 error Information received from Discovergy which is not yet part of this adapter discovergy.0 2018-12-05 21:16:56.731 error Send this information to developer : voltage1229100 discovergy.0 2018-12-05 21:16:56.728 error Information received from Discovergy which is not yet part of this adapter
@ringdingringding:Das sieht nicht gut aus bei mir. `
doch danke ! Du hast halt daten welche ich noch nicht kannte
so, du hattest extra werte fuer jede fase die voltage & nog den jetzigen verbrauch
(power 1 & 2)
probier mal bitte version 0.2.2 von github
du solltest unter objecten in iobroker die datenpunkte und werte sehen
Schnell vor der Arbeit 0.2.2 installoert.
Kommt noch das an fehlern.
2018-12-06 06:06:02.710 - info: discovergy.0 query result of meter : {"time":1544072762135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225400,"energyOut1":0,"power":758380,"energyOut2":0,"power3":10380,"power1":396440,"energy":7886260708000,"power2":351560}}
2018-12-06 06:06:02.758 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:02.759 - error: discovergy.0 Send this information to developer : power310380
2018-12-06 06:06:03.851 - info: javascript.0 script.js.common.System.Bei_Störung_E-Mail: trigger für Adapterüberwachung aktiv
2018-12-06 06:06:04.263 - info: discovergy.0 query result of meter : {"time":1544072762135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225400,"energyOut1":0,"power":758380,"energyOut2":0,"power3":10380,"power1":396440,"energy":7886260708000,"power2":351560}}
2018-12-06 06:06:04.307 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:04.308 - error: discovergy.0 Send this information to developer : power310380
2018-12-06 06:06:05.068 - info: host.debian-iobroker instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
2018-12-06 06:06:07.290 - info: discovergy.0 query result of meter : {"time":1544072767135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225400,"energyOut1":0,"power":901230,"energyOut2":0,"power3":10150,"power1":539030,"energy":7886272786000,"power2":352050}}
2018-12-06 06:06:07.317 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:07.317 - error: discovergy.0 Send this information to developer : power310150
2018-12-06 06:06:10.279 - info: discovergy.0 query result of meter : {"time":1544072770135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225800,"voltage3":225300,"energyOut1":0,"power":759150,"energyOut2":0,"power3":10360,"power1":396820,"energy":7886279111000,"power2":351970}}
2018-12-06 06:06:10.305 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:10.306 - error: discovergy.0 Send this information to developer : power310360
2018-12-06 06:06:13.256 - info: discovergy.0 query result of meter : {"time":1544072772135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225800,"voltage3":225200,"energyOut1":0,"power":757840,"energyOut2":0,"power3":10150,"power1":395690,"energy":7886283324000,"power2":352000}}
2018-12-06 06:06:13.276 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:13.277 - error: discovergy.0 Send this information to developer : power310150
2018-12-06 06:06:16.244 - info: discovergy.0 query result of meter : {"time":1544072775136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":664820,"energyOut2":0,"power3":10310,"power1":395450,"energy":7886289386000,"power2":259060}}
2018-12-06 06:06:16.279 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:16.281 - error: discovergy.0 Send this information to developer : power310310
2018-12-06 06:06:19.313 - info: discovergy.0 query result of meter : {"time":1544072779136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":226000,"voltage3":225100,"energyOut1":0,"power":490440,"energyOut2":0,"power3":10130,"power1":394230,"energy":7886294957000,"power2":86080}}
2018-12-06 06:06:19.333 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:19.333 - error: discovergy.0 Send this information to developer : power310130
2018-12-06 06:06:22.263 - info: discovergy.0 query result of meter : {"time":1544072781136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":490630,"energyOut2":0,"power3":10250,"power1":394110,"energy":7886297682000,"power2":86270}}
2018-12-06 06:06:22.288 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:22.289 - error: discovergy.0 Send this information to developer : power310250
2018-12-06 06:06:25.300 - info: discovergy.0 query result of meter : {"time":1544072785136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":490040,"energyOut2":0,"power3":10260,"power1":393640,"energy":7886303129000,"power2":86140}}
2018-12-06 06:06:25.354 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:25.354 - error: discovergy.0 Send this information to developer : power310260
2018-12-06 06:06:28.314 - info: discovergy.0 query result of meter : {"time":1544072788136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":490940,"energyOut2":0,"power3":10400,"power1":394210,"energy":7886307222000,"power2":86330}}
2018-12-06 06:06:28.338 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:28.339 - error: discovergy.0 Send this information to developer : power310400
2018-12-06 06:06:31.283 - info: discovergy.0 query result of meter : {"time":1544072790136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":491540,"energyOut2":0,"power3":10360,"power1":394940,"energy":7886309951000,"power2":86240}}
2018-12-06 06:06:31.303 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:31.303 - error: discovergy.0 Send this information to developer : power310360
2018-12-06 06:06:34.639 - info: discovergy.0 query result of meter : {"time":1544072794136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225000,"voltage2":225800,"voltage3":225000,"energyOut1":0,"power":494190,"energyOut2":0,"power3":10580,"power1":397180,"energy":7886315447000,"power2":86430}}
2018-12-06 06:06:34.659 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:34.660 - error: discovergy.0 Send this information to developer : power310580
2018-12-06 06:06:37.289 - info: discovergy.0 query result of meter : {"time":1544072797137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225100,"energyOut1":0,"power":492690,"energyOut2":0,"power3":10530,"power1":395770,"energy":7886319552000,"power2":86390}}
2018-12-06 06:06:37.308 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:37.308 - error: discovergy.0 Send this information to developer : power310530
2018-12-06 06:06:40.337 - info: discovergy.0 query result of meter : {"time":1544072799137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":491030,"energyOut2":0,"power3":10360,"power1":394600,"energy":7886322286000,"power2":86070}}
2018-12-06 06:06:40.355 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:40.356 - error: discovergy.0 Send this information to developer : power310360
2018-12-06 06:06:43.338 - info: discovergy.0 query result of meter : {"time":1544072802137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225300,"voltage2":225800,"voltage3":225400,"energyOut1":0,"power":611030,"energyOut2":0,"power3":10490,"power1":514390,"energy":7886327820000,"power2":86150}}
2018-12-06 06:06:43.392 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:43.393 - error: discovergy.0 Send this information to developer : power310490
2018-12-06 06:06:46.309 - info: discovergy.0 query result of meter : {"time":1544072806137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":225800,"voltage3":225500,"energyOut1":0,"power":491650,"energyOut2":0,"power3":10260,"power1":395180,"energy":7886333280000,"power2":86210}}
2018-12-06 06:06:46.328 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:46.329 - error: discovergy.0 Send this information to developer : power310260
2018-12-06 06:06:49.304 - info: discovergy.0 query result of meter : {"time":1544072809137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225300,"energyOut1":0,"power":490680,"energyOut2":0,"power3":10310,"power1":394420,"energy":7886337372000,"power2":85950}}
2018-12-06 06:06:49.323 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:49.324 - error: discovergy.0 Send this information to developer : power310310
2018-12-06 06:06:52.308 - info: discovergy.0 query result of meter : {"time":1544072812137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225100,"energyOut1":0,"power":492380,"energyOut2":0,"power3":10200,"power1":395830,"energy":7886341470000,"power2":86350}}
2018-12-06 06:06:52.334 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
2018-12-06 06:06:52.334 - error: discovergy.0 Send this information to developer : power310200Hier mehr log: ![2958_discovergylog.txt](/assets/uploads/files/2958_discovergylog.txt) ![2958_bildschirmfoto_2018-12-06_um_06.10.19.png](/assets/uploads/files/2958_bildschirmfoto_2018-12-06_um_06.10.19.png) evtl auch noch mehr …
@ringdingringding:Schnell vor der Arbeit 0.2.2 installoert.
Kommt noch das an fehlern. `
Danke ! Habe die fehler aus deinem log behoben
@All,
Version 0.2.5 is gerade eben fertiggestellt, es sollte jetzt eigentlich fast alle werte verarbeitet werden.
Da ich abhaenging bin von demo account kan ich nur daten verarbeiten welche ueber diesen demo account anwesend sind.
Also bitte immer log im auge behalten nach adapterstart, fuer circa 20 sekunden, kommt da eine meldung :
` > Information received from Discovergy which is not yet part of this adapter"
"Send this information to developer : xxxxx `
Dan brauche ich diese information um den fehler zu korrigieren, bitte die komplette information aus dem log (log downloaden) und nicht copy/paste aus dem webinterface da fehlen daten !
Wichtig : Der object baum wird jetzt per seriennummer aufgebaut, also vor starten der version 0.2.5 bitte erst den jetzigen object baum loeschen !
changelog :
0.2.5 (Dutchman) Please remove all current objects within tree discoververgy.x, version 0.2.5 introduce device creation by serial number ! (Dutchman) Changed object tree of device from meterId to sererialnumber, please not this means all vallue are now in a different tree (Dutchman) Implemented multiple meter support (Dutchman) implemented "info" object which provides basic information of the device (Dutchman) Implemented all values which are available by demo-account of discovergy (Dutchman) Remark : not all possbile devices are in the demo, if a device cannot be handled you will get an error message i need that information to implement ! (Dutchman) Reduced logging
Wuerde mich freuen ueber jeden feedback, ueberprueft bitte auch ob alle werte richtig reinkommen.
Fuer fehler, ergaenzungen oder vorschlaege bitte issue auf git erstellen : https://github.com/DutchmanNL/ioBroker. … rgy/issues
Have Fun !
Dutch
Moin
Log jetzt Fehlerfrei und Daten kommen an.
Mal weiter beobachten.
Super arbeit.
Gruss Danyel
Nice!
Werden die Datenpunkte bei dir richtig angelegt ?
Stimmen alle Werte und Einheiten ?
Sieht auf den ersten Blick super aus.
Selbst die Angaben unter info werden richtig angezeigt (Adresse und so)
Gruss Danyel
Sehr schön
Jetzt muss nur noch das Script um Stromverbrauch protokollieren funktionieren damit mir die Kosten richtig angezeigt werden.
Hmm…
Das Script geht doch super
Oh Ehm ja Ehm, ich habe mir vorgenommen auch das zu einem Adapter zu Porten wird aber bisl länger dauern erwarte die Beta aber nog im Dezember...
Der Script Bauer hat da wirklich super Arbeit geleistet aber ich schätze Mal für die meisten User ist Script gerade so einen Schritt zu weit und ist ein Adapter wo man nur die Geräte eintragen muss sinnvoller
Oh man ersten Adapter gebaut (Discovergy), macht Spass kommen bestimmt mehr
Das Script läuft seit ne Stunde aber zeigt seit dem kosten von 0,20€?
Ich warte da einfach mal paar Tage ab.
Ein Adapter wäre da bestimmt viel einfacher.
Naja ich warte da mal ab was du da zauberst.
Dein erster Adapter ist schon mal top geworden.
Evtl sind die drei Sekunden zu "aggressiv"
Habe das Gefühl das alles bisl behäbiger läuft mit dem Script zusammen aber kann mich auch täuschen.
Im Script hab ich ja den datenpunkt vom Zählerstand eingetragen, das doch richtig oder?
@ringdingringding:Das Script läuft seit ne Stunde aber zeigt seit dem kosten von 0,20€?
Ich warte da einfach mal paar Tage ab. `
Das script arbeitet standard mit einem kumulierten wert, also scriptstart = 0 linie
Man kan das beinflussen :
script stoppen
adapter welcher die daten einliest stoppen
im baum der werte den wert kumuliert aufsuchen, hier den jetzigen wert eintragen
bei bedarf auch die werte zaehlerstand tages, wochen, monat, kwartal, jahr eintregen
script starten
adapter starten (der die werte auspuckt
sobald sich jetzt ein werte aendert wird alles neu berechnet, je nach dem ob man die anfangsstaende eingetragaen hat auch den tages, wochen, monat usw…
@ringdingringding:Evtl sind die drei Sekunden zu "aggressiv"
Habe das Gefühl das alles bisl behäbiger läuft mit dem Script zusammen aber kann mich auch täuschen. `
Ja das werde ich noch aendern, bin am ueberlegen :
einen fest definierten wert in den adapter einstellungen (polling interva)
eventuell susaetzlich den wert ""momentan verbrauch" alle x sekunden auslesen und den gesamt zaelherstand nur einmal pro 30 sec/minuten
ich denke mal das wuerden raichen fuer die algemein werte, den jetzigen verbrauch moechte man ja dan doch aktuell haben
vorschlaege gerne
script stoppen
script starten
adapter starten `
genau so habe ich das gemacht. Der Zählerstand wird im script auch richtig übermittelt aber der wert steht immer noch bei 0,20€
Ich werde mal morgen abwarten und schauen was da passiert.
Gruß Danyel
There is nothing more to say…
