    4. Test Adaper Discovergy v0.4.x
    • Dutchman
      version 0.2.0 ist raus.
      der adapter ist jetzt auch per NPM verfuegbar, wird demnaest in die ioBroker repository aufgenommen.
      Also installation entwerder per github oder per npm :
      cd /opt/iobroker
      npm install iobroker.discovergy
      <size size="85">Edit: sudo entfernt (AlCalzone)</size>
      ` > ### 0.2.0
      • (Dutchman) reduced logging from every 3 seconds to only error if values are received which cannot be handled
      • (Dutchman) last time step of syncronisation added, currenlty unix time needs to be converted in next release `
      • Webranger
        Webranger last edited by
        Das sieht nicht gut aus bei mir.
        discovergy.0	2018-12-05 21:17:02.678	error	Send this information to developer : power226880
        discovergy.0	2018-12-05 21:17:02.678	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:17:02.677	error	Send this information to developer : power1312370
        discovergy.0	2018-12-05 21:17:02.677	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:17:02.676	error	Send this information to developer : power333610
        discovergy.0	2018-12-05 21:17:02.668	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:17:02.665	error	Send this information to developer : voltage3229500
        discovergy.0	2018-12-05 21:17:02.665	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:17:02.665	error	Send this information to developer : voltage2230100
        discovergy.0	2018-12-05 21:17:02.664	error	Send this information to developer : voltage1229100
        discovergy.0	2018-12-05 21:17:02.662	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:17:02.659	info	query result of meter : {"time":1544041022095,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":229100,"voltage2":230100,"voltage3":229500,"energyOut1":0,"power":372860,"energyOut2":
        discovergy.0	2018-12-05 21:16:59.711	error	Send this information to developer : power227060
        discovergy.0	2018-12-05 21:16:59.711	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:59.710	error	Send this information to developer : power1324140
        discovergy.0	2018-12-05 21:16:59.709	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:59.709	error	Send this information to developer : power333610
        discovergy.0	2018-12-05 21:16:59.708	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:59.708	error	Send this information to developer : voltage3229400
        discovergy.0	2018-12-05 21:16:59.707	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:59.704	error	Send this information to developer : voltage2230100
        discovergy.0	2018-12-05 21:16:59.704	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:59.703	error	Send this information to developer : voltage1228900
        discovergy.0	2018-12-05 21:16:59.703	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:59.701	info	query result of meter : {"time":1544041019095,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":228900,"voltage2":230100,"voltage3":229400,"energyOut1":0,"power":384810,"energyOut2":
        discovergy.0	2018-12-05 21:16:56.757	error	Send this information to developer : power227000
        discovergy.0	2018-12-05 21:16:56.756	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:56.750	error	Send this information to developer : power1324430
        discovergy.0	2018-12-05 21:16:56.749	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:56.748	error	Send this information to developer : power333820
        discovergy.0	2018-12-05 21:16:56.745	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:56.744	error	Send this information to developer : voltage3229300
        discovergy.0	2018-12-05 21:16:56.742	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:56.740	error	Send this information to developer : voltage2230100
        discovergy.0	2018-12-05 21:16:56.736	error	Information received from Discovergy which is not yet part of this adapter
        discovergy.0	2018-12-05 21:16:56.731	error	Send this information to developer : voltage1229100
        discovergy.0	2018-12-05 21:16:56.728	error	Information received from Discovergy which is not yet part of this adapter
        • Dutchman
          @ringdingringding:
          Das sieht nicht gut aus bei mir. `
          doch danke ! Du hast halt daten welche ich noch nicht kannte 😉
          https://github.com/DutchmanNL/ioBroker. … /issues/10
          • Dutchman
            so, du hattest extra werte fuer jede fase die voltage & nog den jetzigen verbrauch 🙂 (power 1 & 2)
            probier mal bitte version 0.2.2 von github
            du solltest unter objecten in iobroker die datenpunkte und werte sehen
            • Webranger
              Schnell vor der Arbeit 0.2.2 installoert.
              Kommt noch das an fehlern.
              2018-12-06 06:06:02.710 - info: discovergy.0 query result of meter : {"time":1544072762135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225400,"energyOut1":0,"power":758380,"energyOut2":0,"power3":10380,"power1":396440,"energy":7886260708000,"power2":351560}}
              2018-12-06 06:06:02.758 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:02.759 - error: discovergy.0 Send this information to developer : power310380
              2018-12-06 06:06:03.851 - info: javascript.0 script.js.common.System.Bei_Störung_E-Mail: trigger für Adapterüberwachung aktiv
              2018-12-06 06:06:04.263 - info: discovergy.0 query result of meter : {"time":1544072762135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225400,"energyOut1":0,"power":758380,"energyOut2":0,"power3":10380,"power1":396440,"energy":7886260708000,"power2":351560}}
              2018-12-06 06:06:04.307 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:04.308 - error: discovergy.0 Send this information to developer : power310380
              2018-12-06 06:06:05.068 - info: host.debian-iobroker instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
              2018-12-06 06:06:07.290 - info: discovergy.0 query result of meter : {"time":1544072767135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225400,"energyOut1":0,"power":901230,"energyOut2":0,"power3":10150,"power1":539030,"energy":7886272786000,"power2":352050}}
              2018-12-06 06:06:07.317 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:07.317 - error: discovergy.0 Send this information to developer : power310150
              2018-12-06 06:06:10.279 - info: discovergy.0 query result of meter : {"time":1544072770135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225800,"voltage3":225300,"energyOut1":0,"power":759150,"energyOut2":0,"power3":10360,"power1":396820,"energy":7886279111000,"power2":351970}}
              2018-12-06 06:06:10.305 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:10.306 - error: discovergy.0 Send this information to developer : power310360
              2018-12-06 06:06:13.256 - info: discovergy.0 query result of meter : {"time":1544072772135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225800,"voltage3":225200,"energyOut1":0,"power":757840,"energyOut2":0,"power3":10150,"power1":395690,"energy":7886283324000,"power2":352000}}
              2018-12-06 06:06:13.276 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:13.277 - error: discovergy.0 Send this information to developer : power310150
              2018-12-06 06:06:16.244 - info: discovergy.0 query result of meter : {"time":1544072775136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":664820,"energyOut2":0,"power3":10310,"power1":395450,"energy":7886289386000,"power2":259060}}
              2018-12-06 06:06:16.279 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:16.281 - error: discovergy.0 Send this information to developer : power310310
              2018-12-06 06:06:19.313 - info: discovergy.0 query result of meter : {"time":1544072779136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":226000,"voltage3":225100,"energyOut1":0,"power":490440,"energyOut2":0,"power3":10130,"power1":394230,"energy":7886294957000,"power2":86080}}
              2018-12-06 06:06:19.333 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:19.333 - error: discovergy.0 Send this information to developer : power310130
              2018-12-06 06:06:22.263 - info: discovergy.0 query result of meter : {"time":1544072781136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":490630,"energyOut2":0,"power3":10250,"power1":394110,"energy":7886297682000,"power2":86270}}
              2018-12-06 06:06:22.288 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:22.289 - error: discovergy.0 Send this information to developer : power310250
              2018-12-06 06:06:25.300 - info: discovergy.0 query result of meter : {"time":1544072785136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":490040,"energyOut2":0,"power3":10260,"power1":393640,"energy":7886303129000,"power2":86140}}
              2018-12-06 06:06:25.354 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:25.354 - error: discovergy.0 Send this information to developer : power310260
              2018-12-06 06:06:28.314 - info: discovergy.0 query result of meter : {"time":1544072788136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":490940,"energyOut2":0,"power3":10400,"power1":394210,"energy":7886307222000,"power2":86330}}
              2018-12-06 06:06:28.338 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:28.339 - error: discovergy.0 Send this information to developer : power310400
              2018-12-06 06:06:31.283 - info: discovergy.0 query result of meter : {"time":1544072790136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":491540,"energyOut2":0,"power3":10360,"power1":394940,"energy":7886309951000,"power2":86240}}
              2018-12-06 06:06:31.303 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:31.303 - error: discovergy.0 Send this information to developer : power310360
              2018-12-06 06:06:34.639 - info: discovergy.0 query result of meter : {"time":1544072794136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225000,"voltage2":225800,"voltage3":225000,"energyOut1":0,"power":494190,"energyOut2":0,"power3":10580,"power1":397180,"energy":7886315447000,"power2":86430}}
              2018-12-06 06:06:34.659 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:34.660 - error: discovergy.0 Send this information to developer : power310580
              2018-12-06 06:06:37.289 - info: discovergy.0 query result of meter : {"time":1544072797137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225100,"energyOut1":0,"power":492690,"energyOut2":0,"power3":10530,"power1":395770,"energy":7886319552000,"power2":86390}}
              2018-12-06 06:06:37.308 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:37.308 - error: discovergy.0 Send this information to developer : power310530
              2018-12-06 06:06:40.337 - info: discovergy.0 query result of meter : {"time":1544072799137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":491030,"energyOut2":0,"power3":10360,"power1":394600,"energy":7886322286000,"power2":86070}}
              2018-12-06 06:06:40.355 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:40.356 - error: discovergy.0 Send this information to developer : power310360
              2018-12-06 06:06:43.338 - info: discovergy.0 query result of meter : {"time":1544072802137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225300,"voltage2":225800,"voltage3":225400,"energyOut1":0,"power":611030,"energyOut2":0,"power3":10490,"power1":514390,"energy":7886327820000,"power2":86150}}
              2018-12-06 06:06:43.392 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:43.393 - error: discovergy.0 Send this information to developer : power310490
              2018-12-06 06:06:46.309 - info: discovergy.0 query result of meter : {"time":1544072806137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":225800,"voltage3":225500,"energyOut1":0,"power":491650,"energyOut2":0,"power3":10260,"power1":395180,"energy":7886333280000,"power2":86210}}
              2018-12-06 06:06:46.328 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:46.329 - error: discovergy.0 Send this information to developer : power310260
              2018-12-06 06:06:49.304 - info: discovergy.0 query result of meter : {"time":1544072809137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225300,"energyOut1":0,"power":490680,"energyOut2":0,"power3":10310,"power1":394420,"energy":7886337372000,"power2":85950}}
              2018-12-06 06:06:49.323 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:49.324 - error: discovergy.0 Send this information to developer : power310310
              2018-12-06 06:06:52.308 - info: discovergy.0 query result of meter : {"time":1544072812137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225100,"energyOut1":0,"power":492380,"energyOut2":0,"power3":10200,"power1":395830,"energy":7886341470000,"power2":86350}}
              2018-12-06 06:06:52.334 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
              2018-12-06 06:06:52.334 - error: discovergy.0 Send this information to developer : power310200
              Hier mehr log:  ![2958_discovergylog.txt](/assets/uploads/files/2958_discovergylog.txt)
               ![2958_bildschirmfoto_2018-12-06_um_06.10.19.png](/assets/uploads/files/2958_bildschirmfoto_2018-12-06_um_06.10.19.png)
              evtl auch noch mehr …
              • Dutchman
                @ringdingringding:
                Kommt noch das an fehlern. `
                Danke ! Habe die fehler aus deinem log behoben 🙂
                @All,
                Version 0.2.5 is gerade eben fertiggestellt, es sollte jetzt eigentlich fast alle werte verarbeitet werden.
                Da ich abhaenging bin von demo account kan ich nur daten verarbeiten welche ueber diesen demo account anwesend sind.
                Also bitte immer log im auge behalten nach adapterstart, fuer circa 20 sekunden, kommt da eine meldung :
                ` > Information received from Discovergy which is not yet part of this adapter"
                "Send this information to developer : xxxxx `
                Dan brauche ich diese information um den fehler zu korrigieren, bitte die komplette information aus dem log (log downloaden) und nicht copy/paste aus dem webinterface da fehlen daten !
                Wichtig : Der object baum wird jetzt per seriennummer aufgebaut, also vor starten der version 0.2.5 bitte erst den jetzigen object baum loeschen !
                changelog :
                0.2.5
                (Dutchman) Please remove all current objects within tree discoververgy.x, version 0.2.5 introduce device creation by serial number !
                (Dutchman) Changed object tree of device from meterId to sererialnumber, please not this means all vallue are now in a different tree
                (Dutchman) Implemented multiple meter support
                (Dutchman) implemented "info" object which provides basic information of the device
                (Dutchman) Implemented all values which are available by demo-account of discovergy
                (Dutchman) Remark : not all possbile devices are in the demo, if a device cannot be handled you will get an error message i need that information to implement !
                (Dutchman) Reduced logging
                Wuerde mich freuen ueber jeden feedback, ueberprueft bitte auch ob alle werte richtig reinkommen.
                Fuer fehler, ergaenzungen oder vorschlaege bitte issue auf git erstellen : https://github.com/DutchmanNL/ioBroker. … rgy/issues
                Have Fun !
                Dutch
                • Webranger
                  Moin
                  Log jetzt Fehlerfrei und Daten kommen an.
                  Mal weiter beobachten.
                  Super arbeit.
                  Gruss Danyel
                  • Dutchman
                    Nice!
                    Werden die Datenpunkte bei dir richtig angelegt ?
                    Stimmen alle Werte und Einheiten ?
                    • Webranger
                      Sieht auf den ersten Blick super aus.
                      Selbst die Angaben unter info werden richtig angezeigt (Adresse und so)
                      Gruss Danyel
                      • Dutchman
                        Sehr schön 😄
                        • Webranger
                          Jetzt muss nur noch das Script um Stromverbrauch protokollieren funktionieren damit mir die Kosten richtig angezeigt werden.
                          • Dutchman
                            Hmm…
                            Das Script geht doch super 🙂
                            Oh Ehm ja Ehm, ich habe mir vorgenommen auch das zu einem Adapter zu Porten wird aber bisl länger dauern erwarte die Beta aber nog im Dezember...
                            Der Script Bauer hat da wirklich super Arbeit geleistet aber ich schätze Mal für die meisten User ist Script gerade so einen Schritt zu weit und ist ein Adapter wo man nur die Geräte eintragen muss sinnvoller
                            Oh man ersten Adapter gebaut (Discovergy), macht Spass kommen bestimmt mehr
                            • Webranger
                              Das Script läuft seit ne Stunde aber zeigt seit dem kosten von 0,20€?
                              Ich warte da einfach mal paar Tage ab.
                              Ein Adapter wäre da bestimmt viel einfacher.
                              Naja ich warte da mal ab was du da zauberst.
                              Dein erster Adapter ist schon mal top geworden.
                              Evtl sind die drei Sekunden zu "aggressiv"
                              Habe das Gefühl das alles bisl behäbiger läuft mit dem Script zusammen aber kann mich auch täuschen.
                              Im Script hab ich ja den datenpunkt vom Zählerstand eingetragen, das doch richtig oder?
                              • Dutchman
                                @ringdingringding:
                                Ich warte da einfach mal paar Tage ab. `
                                Das script arbeitet standard mit einem kumulierten wert, also scriptstart = 0 linie
                                Man kan das beinflussen :
                                1. script stoppen
                                2. adapter welcher die daten einliest stoppen
                                3. im baum der werte den wert kumuliert aufsuchen, hier den jetzigen wert eintragen
                                4. bei bedarf auch die werte zaehlerstand tages, wochen, monat, kwartal, jahr eintregen
                                5. script starten
                                6. adapter starten (der die werte auspuckt
                                sobald sich jetzt ein werte aendert wird alles neu berechnet, je nach dem ob man die anfangsstaende eingetragaen hat auch den tages, wochen, monat usw…
                                @ringdingringding:
                                Habe das Gefühl das alles bisl behäbiger läuft mit dem Script zusammen aber kann mich auch täuschen. `
                                Ja das werde ich noch aendern, bin am ueberlegen :
                                1. einen fest definierten wert in den adapter einstellungen (polling interva)
                                2. eventuell susaetzlich den wert ""momentan verbrauch" alle x sekunden auslesen und den gesamt zaelherstand nur einmal pro 30 sec/minuten
                                ich denke mal das wuerden raichen fuer die algemein werte, den jetzigen verbrauch moechte man ja dan doch aktuell haben
                                vorschlaege gerne 🙂
                                • Webranger
                                  @Dutchman:
                                  1. script stoppen
                                  5. script starten
                                  6. adapter starten `
                                  genau so habe ich das gemacht. Der Zählerstand wird im script auch richtig übermittelt aber der wert steht immer noch bei 0,20€
                                  Ich werde mal morgen abwarten und schauen was da passiert.
                                  Gruß Danyel
                                  • Flexer
                                    Flexer last edited by
                                    There is nothing more to say…
                                    • Webranger
                                      mal was aus den LOGs heute.
                                      discovergy.0	2018-12-07 19:56:40.375	info	starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.discovergy, node: v6.13.0
                                      discovergy.0	2018-12-07 19:56:40.317	info	States connected to redis: 127.0.0.1:6379
                                      discovergy.0	2018-12-07 19:56:08.690	info	terminating
                                      discovergy.0	2018-12-07 19:56:08.582	info	Discovergy adapter stopped, cleaning everything up :-)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at IncomingMessage.g (events.js:292:16)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/request/request.js:1085:12)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at Request.emit (events.js:188:7)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at emitOne (events.js:96:13)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at Request. <anonymous>(/opt/iobroker/node_modules/request/request.js:1163:10)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at Request.emit (events.js:191:7)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at emitTwo (events.js:106:13)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at Request._callback (/opt/iobroker/node_modules/iobroker.discovergy/main.js:237:16)
                                      discovergy.0	2018-12-07 19:56:08.580	error	at Object.parse (native)
                                      discovergy.0	2018-12-07 19:56:08.580	error	SyntaxError: Unexpected token S in JSON at position 4
                                      discovergy.0	2018-12-07 19:56:08.569	error	uncaught exception: Unexpected token S in JSON at position 4</anonymous></anonymous>
                                      Kein plan was da los war. lief danach weiter.
                                      Gruss
                                      • Dutchman
                                        Da hat sich die API verschluckt und kurz keine Daten geliefert.. hmm ob sie abgefangen werden
                                        • Webranger
                                          Version 0.2.6 läuft bei mir ohne fehler
                                          • Dutchman
                                            @ringdingringding:
                                            Version 0.2.6 läuft bei mir ohne fehler `
                                            Sehr schön, vermutlich an Wochenende ein Update des Adapter
                                            energie
                                            33
                                            294
                                            42425
