    4. [Aufruf] fullyBrowser Adapter
    • Chaot
      Chaot last edited by
      Installiert ist der ja,
      jetzt in der Version 0.06
      Unter Adapter wird er auch als installiert angezeigt.
      Aber jetzt müsste der doch unter Instanzen auftauchen.
      Das gibt das Log aus:
      iobroker	2018-12-12 18:07:30.529	info	exit 0
      iobroker	2018-12-12 18:07:30.496	error	system.adapter.fullyBrowser does not exist
      iobroker	2018-12-12 18:07:30.432	info	upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png
      iobroker	2018-12-12 18:07:30.375	info	upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html
      iobroker	2018-12-12 18:07:30.315	info	upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html
      iobroker	2018-12-12 18:07:30.081	info	upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript
      iobroker	2018-12-12 18:07:29.736	info	got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin
      iobroker	2018-12-12 18:07:29.006	info	upload fullyBrowser
      iobroker	2018-12-12 18:07:24.079	info	exit 0
      iobroker	2018-12-12 18:07:24.042	error	system.adapter.fullyBrowser does not exist
      iobroker	2018-12-12 18:07:23.974	info	upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png
      iobroker	2018-12-12 18:07:23.913	info	upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html
      iobroker	2018-12-12 18:07:23.854	info	upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html
      iobroker	2018-12-12 18:07:23.729	info	upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript
      iobroker	2018-12-12 18:07:23.702	info	got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin
      iobroker	2018-12-12 18:07:22.962	info	upload fullyBrowser
      host.haus	2018-12-12 18:06:02.414	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
      host.haus	2018-12-12 18:05:15.436	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      iobroker	2018-12-12 18:05:15.124	info	exit 0
      iobroker	2018-12-12 18:05:15.026	info	upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png
      iobroker	2018-12-12 18:05:14.964	info	upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html
      iobroker	2018-12-12 18:05:14.903	info	upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html
      iobroker	2018-12-12 18:05:14.820	info	upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript
      iobroker	2018-12-12 18:05:14.793	info	got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin
      iobroker	2018-12-12 18:05:14.711	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","ar
      iobroker	2018-12-12 18:05:14.708	info	npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm WARN svg-inline-react@1.0.3 requires a peer of react
      host.haus	2018-12-12 18:05:03.690	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
      host.haus	2018-12-12 18:05:00.096	info	instance system.adapter.dwd.0 started with pid 20843
      host.haus	2018-12-12 18:05:00.051	info	instance system.adapter.tvspielfilm.0 started with pid 20842
      iobroker	2018-12-12 18:03:54.694	info	npm install https://github.com/arteck/iobroker.fullyBrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      iobroker	2018-12-12 18:03:53.934	info	install https://github.com/arteck/iobroker.fullyBrowser/tarball/master
      iobroker	2018-12-12 18:03:53.281	info	url "https://github.com/arteck/iobroker.fullyBrowser"
      • Webranger
        Webranger last edited by
        Gerade mal getestet.
        Leider startet der Adapter nicht und in den LOGs finde ich das:
        host.debian-iobroker	2018-12-12 19:14:26.442	error	instance system.adapter.fullyBrowser.0 terminated with code 1 ()
        Caught	2018-12-12 19:14:26.442	error	by controller[0]: at startup (bootstrap_node.js:153:9)
        Caught	2018-12-12 19:14:26.441	error	by controller[0]: at run (bootstrap_node.js:387:7)
        Caught	2018-12-12 19:14:26.441	error	by controller[0]: at Module.runMain (module.js:611:10)
        Caught	2018-12-12 19:14:26.441	error	by controller[0]: at Function.Module._load (module.js:445:3)
        Caught	2018-12-12 19:14:26.441	error	by controller[0]: at tryModuleLoad (module.js:453:12)
        Caught	2018-12-12 19:14:26.440	error	by controller[0]: at Module.load (module.js:494:32)
        Caught	2018-12-12 19:14:26.440	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
        Caught	2018-12-12 19:14:26.440	error	by controller[0]: at Module._compile (module.js:549:28)
        Caught	2018-12-12 19:14:26.440	error	by controller[0]: at Object.runInThisContext (vm.js:97:10)
        Caught	2018-12-12 19:14:26.440	error	by controller[0]: at createScript (vm.js:56:10)
        Caught	2018-12-12 19:14:26.440	error	by controller[0]: SyntaxError: Illegal break statement
        Caught	2018-12-12 19:14:26.439	error	by controller[0]: ^^^^^
        Caught	2018-12-12 19:14:26.439	error	by controller[0]: break;
        Caught	2018-12-12 19:14:26.438	error	by controller[0]: /opt/iobroker/node_modules/iobroker.fullyBrowser/main.js:118
        • Mic
          Mic Developer last edited by
          Danke Arteck.
          Hab Dir schon auf die PM geantwortet mit Auszug aus dem Error-Log.
          • Mic
            @Kueppert:
            Den Port den ich einstellen muß… Finde ich im Kiosk browser? Kannst da zb den Standart Port eintragen? Wäre für Beginner einfacher 😉
            Und Passwort? Was für ein Passwort o.O `
            Findest Du hier in meinem Script-Thread: viewtopic.php?f=21&t=19105
            @Mic:
            Voraussetzung für das Script ist, dass Ihr die "Plus-Version" vom Fully Browser verwendet und in den Settings im Untermenü "Remote Administration (PLUS)" den Punkt "Enable Remote Administration" aktiviert und unter "Remote Admin Password" ein Passwort setzt. "Remote Admin from Local Network" muss ebenso aktiviert sein, dort steht dann auch die URL, die Ihr dann im Browser testen könnt und im Script die IP-Adresse entsprechend einträgt. `
            • Webranger
              @Mic:
              fully5.png `
              Darf ich fragen welche version das ist von Fully?
              Ich hab die 1.21.9 am laufen und bei mir sieht das so aus:
              edit1:
              Mal ein update auf die 1.28.1 gemacht aber macht es nicht besser!
              edit2:
              Das script von mic läuft ohne probleme.
              • Mic
                @ringdingringding:
                Darf ich fragen welche version das ist von Fully? `
                Die aktuelle 1.28.1.
                Der Adapter geht bei mir auch noch nicht aufgrund der besagten Fehlermeldungen.
                • Webranger
                  @Mic:
                  Der Adapter geht bei mir auch noch nicht aufgrund der besagten Fehlermeldungen. `
                  Gleiche Fehlermeldung wie bei mir?
                  • Chaot
                    Bei mir scheitert es nach wie vor schon bei der Installation:
                    iobroker	2018-12-12 21:31:36.077	info	exit 0
                    iobroker	2018-12-12 21:31:35.979	info	upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png
                    iobroker	2018-12-12 21:31:35.920	info	upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html
                    iobroker	2018-12-12 21:31:35.859	info	upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html
                    iobroker	2018-12-12 21:31:35.786	info	upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript
                    iobroker	2018-12-12 21:31:35.759	info	got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin
                    iobroker	2018-12-12 21:31:35.686	info	WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                    iobroker	2018-12-12 21:31:35.684	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm
                    iobroker	2018-12-12 21:31:35.682	info	WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
                    iobroker	2018-12-12 21:31:35.681	info	WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm
                    iobroker	2018-12-12 21:31:35.679	info	npm
                    host.haus	2018-12-12 21:31:02.584	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
                    iobroker	2018-12-12 21:30:25.199	info	npm install https://github.com/arteck/iobroker.fullyBrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                    iobroker	2018-12-12 21:30:24.566	info	install https://github.com/arteck/iobroker.fullyBrowser/tarball/master
                    iobroker	2018-12-12 21:30:24.076	info	url "https://github.com/arteck/iobroker.fullyBrowser"
                    Das klingt irgendwie als müsste ich da was nachinstallieren. Aber ich kann nicht so richtig erkennen was ich da brauche.
                    Dazu kommt noch die Meldung:
                    host.haus	2018-12-12 21:31:36.473	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                    für die ich keine Erklärung finde. Die URL ist ja eingetragen. Also sollte das doch automatisch klappen.
                      Georgius last edited by
                      Das sind nur Infos, keine Errors. Auch ein Exit 0.
                      Sollte alles funktionieren.
                      • Mic
                        @ringdingringding:
                        Gleiche Fehlermeldung wie bei mir? `
                        So sieht es aus, hat arteck aber schon bekommen.
                        2018-12-12 19:08:50.588 - info: host.ctioBroker object change system.adapter.fullyBrowser.0
                        2018-12-12 19:08:51.381 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fullyBrowser/main.js:118
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: break;
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: ^^^^^
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: SyntaxError: Illegal break statement
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at createScript (vm.js:80:10)
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Module._compile (module.js:617:28)
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Module.load (module.js:566:32)
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                        2018-12-12 19:08:51.382 - error: Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                        2018-12-12 19:08:51.383 - error: Caught by controller[0]: at bootstrap_node.js:625:3
                        2018-12-12 19:08:51.383 - error: host.ctioBroker instance system.adapter.fullyBrowser.0 terminated with code 1 ()
                        2018-12-12 19:08:51.383 - info: host.ctioBroker Do not restart adapter system.adapter.fullyBrowser.0 because disabled or deleted
                        2018-12-12 19:08:52.613 - info: host.ctioBroker object change system.adapter.fullyBrowser.0
                        2018-12-12 19:08:52.614 - info: host.ctioBroker "system.adapter.fullyBrowser.0" enabled
                        2018-12-12 19:08:52.627 - info: host.ctioBroker instance system.adapter.fullyBrowser.0 started with pid 768
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fullyBrowser/main.js:118
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: break;
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: ^^^^^
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: SyntaxError: Illegal break statement
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: at createScript (vm.js:80:10)
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: at Module._compile (module.js:617:28)
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                        2018-12-12 19:08:52.775 - error: Caught by controller[0]: at Module.load (module.js:566:32)
                        2018-12-12 19:08:52.776 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                        2018-12-12 19:08:52.776 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
                        2018-12-12 19:08:52.776 - error: Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                        2018-12-12 19:08:52.776 - error: Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                        2018-12-12 19:08:52.776 - error: Caught by controller[0]: at bootstrap_node.js:625:3
                        2018-12-12 19:08:52.776 - error: host.ctioBroker instance system.adapter.fullyBrowser.0 terminated with code 1 ()
                        2018-12-12 19:08:52.776 - info: host.ctioBroker Restart adapter system.adapter.fullyBrowser.0 because enabled
                        2018-12-12 19:08:53.645 - info: host.ctioBroker instance system.adapter.ical.0 terminated with code 0 (OK)
                        • Chaot
                          Ja, exit 0 sehe ich ja auch. Aber dann müsste der Adapter doch in den Instanzen auftauchen oder verstehe ich das falsch?
                            Wenn Du die Kachelansicht hast nochmal so tun als ob Du den Adapter installieren willst. Also die 3 Punkte und dann links unten das + Zeichen. Dann wird eine Instanz angelegt.
                            • Chaot
                              Danke.
                              Jetzt mit Fehlermeldung:
                              host.haus	2018-12-13 06:44:53.758	error	instance system.adapter.fullyBrowser.0 terminated with code 1 ()
                              Caught	2018-12-13 06:44:53.758	error	by controller[0]: at bootstrap_node.js:625:3
                              Caught	2018-12-13 06:44:53.758	error	by controller[0]: at startup (bootstrap_node.js:204:16)
                              Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Function.Module.runMain (module.js:694:10)
                              Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Function.Module._load (module.js:498:3)
                              Caught	2018-12-13 06:44:53.758	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                              Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Module.load (module.js:566:32)
                              Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                              Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Module._compile (module.js:617:28)
                              Caught	2018-12-13 06:44:53.757	error	by controller[0]: at Object.runInThisContext (vm.js:139:10)
                              Caught	2018-12-13 06:44:53.757	error	by controller[0]: at createScript (vm.js:80:10)
                              Caught	2018-12-13 06:44:53.757	error	by controller[0]: SyntaxError: Illegal break statement
                              Caught	2018-12-13 06:44:53.757	error	by controller[0]: ^^^^^
                              Caught	2018-12-13 06:44:53.757	error	by controller[0]: break;
                              Caught	2018-12-13 06:44:53.757	error	by controller[0]: /opt/iobroker/node_modules/iobroker.fullyBrowser/main.js:118
                              host.haus	2018-12-13 06:44:53.559	info	instance system.adapter.fullyBrowser.0 started with pid 8663
                                jaha..schon korrigiert…
                                hab noch auf die schnelle eine Änderung gemacht ..copy...paste.. bäm ..fehler 😉
                                doku fehlt auch noch.. ich weiss
                                • Webranger
                                  Dann werde ich heute Abend noch mal testen
                                  • Chaot
                                    Ich bekomme bei der Installation immer noch die 0.0.6 und den gleichen Fehler
                                      so jetzt die Version ist immer noch die 0.0.6
                                      • Chaot
                                        Ok, läuft bei mir aktuell ohne Fehlermeldung.
                                        Alle Daten scheinen vorhanden.
                                        Allerdings hat sich das jetzt irgendwie mit meinem Ladescript überschnitten. Da frage ich den Akkustand direkt ab und Fully verweigert jetzt scheinbar die Verbindung.
                                        Macht nichts, da ich ja zur Abfrage jetzt den Adapter nutzen kann.
                                        • Chaot
                                          Bei mir läuft der Adapter mittlerweile länger Zeit störungsfrei.
                                          Ich nutze ihn allerdings derzeit nur um den Akku zu laden.
                                          Die restlichen Datenpunkte werde ich mir nach und nach erarbeiten.
                                          Mein Wunsch wäre noch eine Einstellmöglichkeit der Bildschirmhelligkeit.
                                          Ich habe gemerkt das durch diverse Updates jedes mal ein Reload erfolgt wenn der Screensaver abgeschaltet wird.
                                          Deshalb würde ich gerne per Script die Bildschirmhelligkeit steuern.
                                          Unter /?cmd=listSettings&cat=settingsDeviceManagement ist der Punkt aufgeführt.
                                          In den Objekten erscheint er allerdings nur als "Info".
                                          Somit würde ich einfach Fully ständig in der View lassen und nur den Bildschirm verschieden hell bis ganz dunkel steuern (Über Astro Script).
                                          Dadurch umgehe ich den Screensaver und den damit verbundenen lästigen Reload.
                                          • Mic
                                            Werde ich auch gleich noch mal testen.
                                            Wer kann mir denn als quasi "Github"-Newbie erklären, wie ich bei einem Projekt, das nicht von mir ist, die Readme-Datei bearbeiten kann als "Vorschlag"? Denn dann kann ich da gerne schon mal das ganze beschreiben, ähnlich wie bei meinem Fully-Script im Forum-Thread, halt in Englisch.
                                            fullybrowser fullybrowser adapter
                                            45
                                            289
                                            43536
