Adapter: iobroker.backitup (stable Release)
Ich habe ein merkwürdiges Problem, wenn ich beim Totalbackup nicht die Option "ioBroker stoppen" aktiviere.
Das Backup startet und dann kommt in Abständen die Meldung
[DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.200.156","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"bu/iobroker/Odroid_XU4/complete","dirMinimal":"bu/iobroker/Odroid_XU4/Standard","dirTotal":"bu/iobroker/Odroid_XU4/complete","user":"iobroker","pass":"****"} [DEBUG] [mount] - done [DEBUG] [total] start with {"type":"creator","time":"03:00","debugging":true,"everyXDays":"1","nameSuffix":"XOU4","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.200.156","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/bu/iobroker/Odroid_XU4/complete","dirMinimal":"bu/iobroker/Odroid_XU4/Standard","dirTotal":"bu/iobroker/Odroid_XU4/complete","user":"iobroker","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.2","SilentNotice":true,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","systemLang":"de"},"dir":"/opt/iobroker","redis":{"enabled":true,"ftp":{"enabled":false,"type":"storage","source":"Local","host":"192.168.200.156","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"iobroker","pass":"iobroker.Pty92","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.200.156","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"bu/iobroker/Odroid_XU4/complete","dirMinimal":"bu/iobroker/Odroid_XU4/Standard","dirTotal":"bu/iobroker/Odroid_XU4/complete","user":"iobroker","pass":"iobroker.Pty92"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","dirTotal":""},"path":"/opt/iobroker/iobroker-data/states.rdb"},"stopIoB":false,"backupDir":"/opt/iobroker/backups"} [DEBUG] [total] - TAR started... [DEBUG] [total] - Ignore dir: /opt/iobroker/backups [DEBUG] [total] - Packed 4MB so far... ... [DEBUG] [total] - Packed 4MB so far... ... [DEBUG] [total] - Packed 4MB so far... ...Aber letzten Endes wird das Backup nie fertig, der Prozess läuft ewig, die Streams sind geöffnet
io.backit 7250 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz node 7250 7259 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz V8 7250 7260 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz V8 7250 7261 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz V8 7250 7262 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz V8 7250 7263 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz node 7250 7271 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz node 7250 7272 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz node 7250 7273 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gz node 7250 7274 iobroker 16w REG 0,30 4249591 45777001 /opt/iobroker/backups/total_2018_12_13-15_33_23_XOU4_backupiobroker.tar.gzaber es passiert nichts weiter. Immerhin wird beim Beenden des Adapters alles geschlossen (bis auf umount).
Es sieht so aus, als ob der Adapter immer ungefähr an derselben Stelle hängen bleibt. Wie kann ich das herausbekommen?
Jede Nacht einen Adapter mehr beenden ist nicht unbedingt die Lösung.
ich habe heute meine Rasberry neu aufgesetzt, alles aktualisisert was aktualisiert werden kann und danach das Minimal-Backup zurückgespielt. Alles super geklappt - vielen DANK!!
Jetzt ist mir ist aber aufgefallen, das ich keine neuen Backups mehr auf das NAS schieben kann:
….. gelöscht
EDIT:
Hat sich erledigt. Ich musste noch SMB 1 einstellen. Ist die Einstellung neu?
Na egal, jetzt geht es wieder - juchu!
Salti
filename="13-12-_2018_16-08-36.jpg" index="0">~~
Jede Nacht einen Adapter mehr beenden ist nicht unbedingt die Lösung. `
Du benutzt sicher keinen Redis-Server oder?
Da kann es sein, dass iob gerade Zustände schreibt und du deshalb auf die Datei gerade nicht zugreifen kannst.
Für alle die keinen Redis-Server nutzen, wäre generell zu empfehlen, iob beim total zu stoppen.
….. gelöscht
EDIT:
Salti `
Ja die smb Auswahl war ein Userwunsch und ist neu.
Update bleibt hängen
Doch, der ioBroker läuft zusammen mit Redis und Redis-Backup ist aktiviert.
Anbei eine Liste der aktiven Adapter:
Adapter "admin" : 3.5.10 , installed 3.5.10 Adapter "backitup" : 0.4.2 , installed 0.4.2 Adapter "dwd" : 2.4.3 , installed 2.4.3 Adapter "email" : 1.0.4 , installed 1.0.4 Adapter "flot" : 1.9.2 , installed 1.9.2 Adapter "fullcalendar" : 0.2.4 , installed 0.2.4 Adapter "history" : 1.8.5 , installed 1.8.5 Adapter "hm-rega" : 2.0.0 , installed 2.0.0 Adapter "hm-rpc" : 1.8.0 , installed 1.8.0 Adapter "hs100" : 1.0.8 , installed 1.0.8 Adapter "influxdb" : 1.6.2 , installed 1.6.2 Adapter "info" : 1.0.2 , installed 1.0.2 Adapter "javascript" : 4.0.5 , installed 4.0.5 Controller "js-controller" : 1.4.2 , installed 1.5.3 Adapter "js2fs" : 0.1.5 , installed 0.1.5 Adapter "mqtt" : 2.0.4 , installed 2.0.4 Adapter "openweathermap": 0.1.0 , installed 0.1.0 Adapter "ping" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.0.0 , installed 2.0.0 Adapter "systeminfo" : 0.2.2 , installed 0.2.2 Adapter "tankerkoenig" : 1.0.4 , installed 1.0.4 Adapter "telegram" : 1.3.6 , installed 1.3.6 Adapter "tr-064" : 0.4.18 , installed 0.4.18 Adapter "tvspielfilm" : 1.0.4 , installed 1.0.4 Adapter "vis" : 1.1.8 , installed 1.1.7 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 0.1.5 , installed 0.1.5 Adapter "vis-colorpicker": 1.1.1 , installed 1.1.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 0.1.0 , installed 0.1.0 Adapter "vis-history" : 0.2.7 , installed 0.2.7 Adapter "vis-hqwidgets" : 1.1.2 , installed 1.1.2 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 1.0.0 , installed 1.0.0 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-lcars" : 1.0.4 , installed 1.0.4 Adapter "vis-map" : 1.0.2 , installed 1.0.2 Adapter "vis-metro" : 1.1.2 , installed 1.1.2 Adapter "vis-players" : 0.1.5 , installed 0.1.5 Adapter "vis-plumb" : 1.0.1 , installed 1.0.1 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7 Adapter "vis-weather" : 2.2.0 , installed 2.2.0 Adapter "weatherunderground": 2.0.4 , installed 2.0.4 Adapter "web" : 2.4.1 , installed 2.4.1 Adapter "yr" : 2.0.3 , installed 2.0.3zu SMB-Einstellung
Die "Anforderung" die SMB-Version einstellen zu können (und ob sudo oder nicht) ist von mir. SMBv1 ist ein Auslaufmodell, es sollte mind. SMBv2 genutzt werden. Im eigenen einbruchsicheren LAN kann natürlich gemacht werden, was man möchte.
Hallo Simatec,
habe den Fehler bei mir gefunden. Wenn ich Redis-Status-Sicherin einschalte, klappt das Backup auf die NAS. Ist es abgeschaltet. Klappt es nicht. Vielleicht ist es Absicht. vielleicht ein Fehler. Das kannst du eher wissen.
Danke Für euere Hilfe.
Rainer
Hallo Simatec,
Rainer `
Nein der mount hat nix mit redis zu tun.
Poste bitte nochmal dein Log mit und ohne Redis.
Die "Anforderung" die SMB-Version einstellen zu können (und ob sudo oder nicht) ist von mir. SMBv1 ist ein Auslaufmodell, es sollte mind. SMBv2 genutzt werden. Im eigenen einbruchsicheren LAN kann natürlich gemacht werden, was man möchte. `
Dann wird irgendeine Datei von iob blockiert und das backup bleibt hängen.
Wie gesagt, genau für solche Anwendungsfälle gibt es die Funktion iob stop.
Was spricht bei dir dagegen? Sichere doch einfach nachts, wenn iob eh kaum gebraucht wird.
Andernfalls bleibt dir nur die Möglichkeit jeden Adapter einzeln zu deaktivieren, um rauszubekommen, was da das Backup blockiert.
Ich habe hier 4 Testsysteme, mal mit und mal ohne Redis.
Ich muss nix stoppen. Aber wie gesagt, Nadel im Heuhaufen suchen
Gesendet von iPhone mit Tapatalk `
Hi SImatec,
Verrückt. irgend was hat sich geändert.
Jetzt geht es in beiden Fällen. Egal ob mit oder ohne Redis status Sicherung.
Ich hab keine Ahnung was sich geändert hat.
Egal was es ist.
Vielen Lieben Dank
Rainer
Hab den Fehler wieder. Ich hab nun gesehen warum es durch ging. Die Anbindung an die NAS war abgeschaltet.
Wenn diese an ist. Geht es weder mit noch ohne REDIS.
Fehler ist also noch vorhanden (Leider) ;-(
Unterstützt dein NAS auch nfs? Dann würde ich das mal probieren.
Falls nicht, probiere mal den mount über Konsole, damit man mal sieht, wo dein System Probleme hat.
sudo mount -t cifs -o user=hm-iob,password=password,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.7.200/TMBackup/IOB /opt/iobroker/backups
Falls dein Passwort Sonderzeichen haben sollte, verwende entweder eins ohne Sonderzeichen oder schreibe es in der Config von backitup mal in Anführungszeichen.
Ich muss nix stoppen. Aber wie gesagt, Nadel im Heuhaufen suchen `
Na ja, bei mir dauert das Speichern via NAS der 1,7 GB ungefähr 18 min., in der Zeit kann viel passieren - gut das ich da keine Alarmanlage drüber laufen habe. Über die 1,7 GB wundere ich mich ein wenig, muss ich mir auch noch anschauen, werde das System wohl mit node 8 sowieso neu aufsetzen.
Also 1,7 GB scheint mir recht viel …
Hab auf meinem Produktiv ca. 25 Adapter laufen und etliche Scripts ... aber das ist alles nicht wirklich so groß
Hab ca. 300 MB.
Also ich habe eben mal verglichen, ich hatte früher so ca 450 MB und seit dem ich alles neu gemacht habe 176MB.
Schuld war bei mir der SonosCache, das waren die 274 MB mehr.
Das Problem ist "schöner" als gedacht:
Habe bis auf Admin und backitup alle Instanzen beendet.
Redis läuft
Dann das Komplett-Backup über "Jetzt Sichern" gestartet" - bleibt wieder bei ca. 5 MB stehen.
Dann den Host via Tab Hosts neu gestartet, Backup neu gestartet –> Backup läuft
Habe nun etliche Tests durchgeführt, der "Neustart-Trick" funktioniert leider auch nicht immer.
Wenn ich das Backup auf Console ausführe: tar cvzf iobroker-oxu4-2018-12-14.tgz /opt/iobroker/ dann läuft es durch.
Kann ich in backitup eine Option setzen, ggf. "einbauen", damit das Backup im verbose-Mode läuft und ich sehe, wo es hängen bleibt?
Hast du mal einen kompletten Restart deines Systems probiert?
Vielleicht hängt da irgendwo etwas anderes.
Lief das Backup bei dir bereits schonmal durch oder hast du das Problem seit der Installation?
Was hast du für eine node, nodejs, npm und js-controller Version?
Was hast du für eine node, nodejs, npm und js-controller Version? `
Ja, restart habe ich mehrfach gemacht, das Backup läuft, wenn die Checkbox "ioBroker stoppen" aktiv ist.
Selber habe ich sonst auf der Shell mit tar gesichert, beim Umstieg auf den Adapter habe ich dann wegen der Datenkonsistenz ioBroker beenden lassen.
Wegen der langen Downtime des ioBroker bei mir (18 min.) kam dann von euch die Empfehlung, den ioBroker einfach laufen zu lassen und das klappt bei mir nicht.
node: 6.13.1
nodejs ???
npm: 3.10.10
js-controller: 1.5.3
Eine Besonderheit bei mir ist, dass ioBroker nicht mit root-Rechten läuft, aber ich habe wie gesagt auch kein Problem als ioBroker-User via Shell ein tar-Archiv zu machen.
Hast du einen Link zu dem node-Modul, welches ihr da verwendet, wir mir da ggf. selber die verbose-Option einbauen.
Also da sehe ich schon das erste Problem mit dem js-Controller.
1.5.3 würde ich aktuell noch nicht unbedingt laufen lassen und erst recht nicht mit npm 3 in Kombi.
Mach mal ein Upgrade von node und npm und ggfs. ein downgrade des js-Controllers …
Hi Simatec,
-bash: ****Password****,rw,file_mode=0777,dir_mode=0777,vers=1.0: Kommando nicht gefunden.anscheinend ist mit dem Adapter irgend was nicht mit installiert worden ;(
Rainer
Befehle über Konsole haben nix mit dem Adapter zu tun.
Was hast du in der Konsole genau eingegeben
ich hab es. ein Passwort mit 21 Zeichen ist dem Adapter wohl zu lang. Jetzt habe ich eins mit 12 Zeichen und alles ist gut.
