    4. Adapter: iobroker.backitup (stable Release)
    • greyhound
      greyhound last edited by
      Update bleibt hängen
      Doch, der ioBroker läuft zusammen mit Redis und Redis-Backup ist aktiviert.
      Anbei eine Liste der aktiven Adapter:
      Adapter    "admin"         : 3.5.10   , installed 3.5.10
      Adapter    "backitup"      : 0.4.2    , installed 0.4.2
      Adapter    "dwd"           : 2.4.3    , installed 2.4.3
      Adapter    "email"         : 1.0.4    , installed 1.0.4
      Adapter    "flot"          : 1.9.2    , installed 1.9.2
      Adapter    "fullcalendar"  : 0.2.4    , installed 0.2.4
      Adapter    "history"       : 1.8.5    , installed 1.8.5
      Adapter    "hm-rega"       : 2.0.0    , installed 2.0.0
      Adapter    "hm-rpc"        : 1.8.0    , installed 1.8.0
      Adapter    "hs100"         : 1.0.8    , installed 1.0.8
      Adapter    "influxdb"      : 1.6.2    , installed 1.6.2
      Adapter    "info"          : 1.0.2    , installed 1.0.2
      Adapter    "javascript"    : 4.0.5    , installed 4.0.5
      Controller "js-controller" : 1.4.2    , installed 1.5.3
      Adapter    "js2fs"         : 0.1.5    , installed 0.1.5
      Adapter    "mqtt"          : 2.0.4    , installed 2.0.4
      Adapter    "openweathermap": 0.1.0    , installed 0.1.0
      Adapter    "ping"          : 1.3.2    , installed 1.3.2
      Adapter    "simple-api"    : 2.0.0    , installed 2.0.0
      Adapter    "systeminfo"    : 0.2.2    , installed 0.2.2
      Adapter    "tankerkoenig"  : 1.0.4    , installed 1.0.4
      Adapter    "telegram"      : 1.3.6    , installed 1.3.6
      Adapter    "tr-064"        : 0.4.18   , installed 0.4.18
      Adapter    "tvspielfilm"   : 1.0.4    , installed 1.0.4
      Adapter    "vis"           : 1.1.8    , installed 1.1.7
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-colorpicker": 1.1.1   , installed 1.1.1
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
      Adapter    "vis-history"   : 0.2.7    , installed 0.2.7
      Adapter    "vis-hqwidgets" : 1.1.2    , installed 1.1.2
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.0    , installed 1.0.0
      Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"       : 1.0.2    , installed 1.0.2
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-players"   : 0.1.5    , installed 0.1.5
      Adapter    "vis-plumb"     : 1.0.1    , installed 1.0.1
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "vis-weather"   : 2.2.0    , installed 2.2.0
      Adapter    "weatherunderground": 2.0.4   , installed 2.0.4
      Adapter    "web"           : 2.4.1    , installed 2.4.1
      Adapter    "yr"            : 2.0.3    , installed 2.0.3
      zu SMB-Einstellung
      Die "Anforderung" die SMB-Version einstellen zu können (und ob sudo oder nicht) ist von mir. SMBv1 ist ein Auslaufmodell, es sollte mind. SMBv2 genutzt werden. Im eigenen einbruchsicheren LAN kann natürlich gemacht werden, was man möchte.
        Hightower1976 last edited by
        Hallo Simatec,
        habe den Fehler bei mir gefunden. Wenn ich Redis-Status-Sicherin einschalte, klappt das Backup auf die NAS. Ist es abgeschaltet. Klappt es nicht. Vielleicht ist es Absicht. vielleicht ein Fehler. Das kannst du eher wissen.
        Danke Für euere Hilfe.
        Rainer
        • simatec
          @Hightower1976:
          Hallo Simatec,
          Rainer `
          Nein der mount hat nix mit redis zu tun.
          Poste bitte nochmal dein Log mit und ohne Redis.
          • simatec
            @greyhound:
            zu SMB-Einstellung
            Die "Anforderung" die SMB-Version einstellen zu können (und ob sudo oder nicht) ist von mir. SMBv1 ist ein Auslaufmodell, es sollte mind. SMBv2 genutzt werden. Im eigenen einbruchsicheren LAN kann natürlich gemacht werden, was man möchte. `
            Dann wird irgendeine Datei von iob blockiert und das backup bleibt hängen.
            Wie gesagt, genau für solche Anwendungsfälle gibt es die Funktion iob stop.
            Was spricht bei dir dagegen? Sichere doch einfach nachts, wenn iob eh kaum gebraucht wird.
            Andernfalls bleibt dir nur die Möglichkeit jeden Adapter einzeln zu deaktivieren, um rauszubekommen, was da das Backup blockiert.
            Ich habe hier 4 Testsysteme, mal mit und mal ohne Redis.
            Ich muss nix stoppen. Aber wie gesagt, Nadel im Heuhaufen suchen
              @simatec:
              Gesendet von iPhone mit Tapatalk `
              Hi SImatec,
              Verrückt. irgend was hat sich geändert.
              Jetzt geht es in beiden Fällen. Egal ob mit oder ohne Redis status Sicherung.
              Ich hab keine Ahnung was sich geändert hat.
              Egal was es ist.
              Vielen Lieben Dank
              Rainer
              Hab den Fehler wieder. Ich hab nun gesehen warum es durch ging. Die Anbindung an die NAS war abgeschaltet.
              Wenn diese an ist. Geht es weder mit noch ohne REDIS.
              Fehler ist also noch vorhanden (Leider) ;-(
              • simatec
                Unterstützt dein NAS auch nfs? Dann würde ich das mal probieren.
                Falls nicht, probiere mal den mount über Konsole, damit man mal sieht, wo dein System Probleme hat.
                sudo mount -t cifs -o user=hm-iob,password=password,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.7.200/TMBackup/IOB /opt/iobroker/backups
                Falls dein Passwort Sonderzeichen haben sollte, verwende entweder eins ohne Sonderzeichen oder schreibe es in der Config von backitup mal in Anführungszeichen.
                • greyhound
                  @simatec:
                  Ich muss nix stoppen. Aber wie gesagt, Nadel im Heuhaufen suchen `
                  Na ja, bei mir dauert das Speichern via NAS der 1,7 GB ungefähr 18 min., in der Zeit kann viel passieren - gut das ich da keine Alarmanlage drüber laufen habe. Über die 1,7 GB wundere ich mich ein wenig, muss ich mir auch noch anschauen, werde das System wohl mit node 8 sowieso neu aufsetzen.
                  • simatec
                    Also 1,7 GB scheint mir recht viel …
                    Hab auf meinem Produktiv ca. 25 Adapter laufen und etliche Scripts ... aber das ist alles nicht wirklich so groß
                    Hab ca. 300 MB.
                    • Peoples
                      Peoples last edited by
                      Also ich habe eben mal verglichen, ich hatte früher so ca 450 MB und seit dem ich alles neu gemacht habe 176MB.
                      Schuld war bei mir der SonosCache, das waren die 274 MB mehr.
                      • greyhound
                        Das Problem ist "schöner" als gedacht:
                        Habe bis auf Admin und backitup alle Instanzen beendet.
                        Redis läuft
                        Dann das Komplett-Backup über "Jetzt Sichern" gestartet" - bleibt wieder bei ca. 5 MB stehen.
                        Dann den Host via Tab Hosts neu gestartet, Backup neu gestartet –> Backup läuft
                        Habe nun etliche Tests durchgeführt, der "Neustart-Trick" funktioniert leider auch nicht immer.
                        Wenn ich das Backup auf Console ausführe: tar cvzf iobroker-oxu4-2018-12-14.tgz /opt/iobroker/ dann läuft es durch.
                        Kann ich in backitup eine Option setzen, ggf. "einbauen", damit das Backup im verbose-Mode läuft und ich sehe, wo es hängen bleibt?
                        • simatec
                          Hast du mal einen kompletten Restart deines Systems probiert?
                          Vielleicht hängt da irgendwo etwas anderes.
                          Lief das Backup bei dir bereits schonmal durch oder hast du das Problem seit der Installation?
                          Was hast du für eine node, nodejs, npm und js-controller Version?
                          • greyhound
                            @simatec:
                            Was hast du für eine node, nodejs, npm und js-controller Version? `
                            Ja, restart habe ich mehrfach gemacht, das Backup läuft, wenn die Checkbox "ioBroker stoppen" aktiv ist.
                            Selber habe ich sonst auf der Shell mit tar gesichert, beim Umstieg auf den Adapter habe ich dann wegen der Datenkonsistenz ioBroker beenden lassen.
                            Wegen der langen Downtime des ioBroker bei mir (18 min.) kam dann von euch die Empfehlung, den ioBroker einfach laufen zu lassen und das klappt bei mir nicht.
                            node: 6.13.1
                            nodejs ???
                            npm: 3.10.10
                            js-controller: 1.5.3
                            Eine Besonderheit bei mir ist, dass ioBroker nicht mit root-Rechten läuft, aber ich habe wie gesagt auch kein Problem als ioBroker-User via Shell ein tar-Archiv zu machen.
                            Hast du einen Link zu dem node-Modul, welches ihr da verwendet, wir mir da ggf. selber die verbose-Option einbauen.
                            • simatec
                              Also da sehe ich schon das erste Problem mit dem js-Controller.
                              1.5.3 würde ich aktuell noch nicht unbedingt laufen lassen und erst recht nicht mit npm 3 in Kombi.
                              Mach mal ein Upgrade von node und npm und ggfs. ein downgrade des js-Controllers …
                                @simatec:
                                Hi Simatec,
                                -bash: ****Password****,rw,file_mode=0777,dir_mode=0777,vers=1.0: Kommando nicht gefunden.
                                anscheinend ist mit dem Adapter irgend was nicht mit installiert worden ;(
                                Rainer
                                • simatec
                                  Befehle über Konsole haben nix mit dem Adapter zu tun.
                                  Was hast du in der Konsole genau eingegeben
                                    @simatec:
                                    ich hab es. ein Passwort mit 21 Zeichen ist dem Adapter wohl zu lang. Jetzt habe ich eins mit 12 Zeichen und alles ist gut.
                                    • TomT
                                      TomT last edited by
                                      Gibt es eigentlich Pläne für den Adapter bei der Pushover Benachrichtigung nur 1 GeräteID eintragen zu können?
                                      Momentan bekomme ich die Backup Nachricht auf alle Pushover GeräteIDs
                                      Tom
                                      • simatec
                                        Können wir einbauen.
                                        Da ich aber selber Pushover nicht nutze, wäre gut zu wissen, wie die Id ausschaut.
                                        • TomT
                                          TomT last edited by
                                          Ja 😄
                                          Das müsste das hier sein :
                                          https://pushover.net/api
                                          Some optional parameters may be included:
                                          device - your user's device name to send the message directly to that device, rather than all of the user's devices (multiple devices may be separated by a comma)
                                          Kommt bei dem Pushover Adapter unter Gerät ID als Text (Name den man selbst dem Gerät bei Pushover eingetragen hat)
                                          Tom
                                          • simatec
                                            OK ich schaue mir mal den Pushover Adapter an.
                                            Eventuell kann ich die User wie bei Telegram von backitup auslesen lassen und ein Auswahlmenü darstellen.
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1190737
