    4. Test Adaper Discovergy v0.4.x
    • Flexer
      Flexer last edited by
      There is nothing more to say…
      • Webranger
        Webranger last edited by
        mal was aus den LOGs heute.
        discovergy.0	2018-12-07 19:56:40.375	info	starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.discovergy, node: v6.13.0
        discovergy.0	2018-12-07 19:56:40.317	info	States connected to redis: 127.0.0.1:6379
        discovergy.0	2018-12-07 19:56:08.690	info	terminating
        discovergy.0	2018-12-07 19:56:08.582	info	Discovergy adapter stopped, cleaning everything up :-)
        discovergy.0	2018-12-07 19:56:08.580	error	at IncomingMessage.g (events.js:292:16)
        discovergy.0	2018-12-07 19:56:08.580	error	at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/request/request.js:1085:12)
        discovergy.0	2018-12-07 19:56:08.580	error	at Request.emit (events.js:188:7)
        discovergy.0	2018-12-07 19:56:08.580	error	at emitOne (events.js:96:13)
        discovergy.0	2018-12-07 19:56:08.580	error	at Request. <anonymous>(/opt/iobroker/node_modules/request/request.js:1163:10)
        discovergy.0	2018-12-07 19:56:08.580	error	at Request.emit (events.js:191:7)
        discovergy.0	2018-12-07 19:56:08.580	error	at emitTwo (events.js:106:13)
        discovergy.0	2018-12-07 19:56:08.580	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
        discovergy.0	2018-12-07 19:56:08.580	error	at Request._callback (/opt/iobroker/node_modules/iobroker.discovergy/main.js:237:16)
        discovergy.0	2018-12-07 19:56:08.580	error	at Object.parse (native)
        discovergy.0	2018-12-07 19:56:08.580	error	SyntaxError: Unexpected token S in JSON at position 4
        discovergy.0	2018-12-07 19:56:08.569	error	uncaught exception: Unexpected token S in JSON at position 4</anonymous></anonymous>
        Kein plan was da los war. lief danach weiter.
        Gruss
        • Dutchman
          Da hat sich die API verschluckt und kurz keine Daten geliefert.. hmm ob sie abgefangen werden
          • Webranger
            Version 0.2.6 läuft bei mir ohne fehler
            • Dutchman
              @ringdingringding:
              Version 0.2.6 läuft bei mir ohne fehler `
              Sehr schön, vermutlich an Wochenende ein Update des Adapter
              • Webranger
                Gibt es Änderungen?
                • Dutchman
                  Jup :
                  • Zugangsdaten verschlüsselt speichern
                  • Nur den jetzigen Verbrauch alle 3 Sekunden abholen
                  • Gesammtverbrauch jede Minute (einstellbar)
                  • Dutchman
                    0.2.9 ist raus
                    • Webranger
                      Update eingespielt.
                      Bei der versionsnummer passt was nicht 😉
                      Läuft soweit wie es aussieht. Daten kommen an.
                      Am Anfang hatte ich 3 errors aber dann nicht wieder.
                      Ich werde das weiter beobachten
                      So wie es aussieht werden die Werte zweimal abgeholt und in die History geschrieben oder sieht das nur so aus?
                      Gruss Danyel
                      • Dutchman
                        Hi Daniel,
                        Danke ! Ja die Version ist mein Fehler musste noch einen schnellen fix nachreichen.
                        Hmm ok das es doppelt kommt hatte ich vermutet wurde gestern Abend zu spät zur Analyse.
                        Danke werde ich heute Mal schauen und korrigieren und Pass Word encryption einbauen
                        • Dutchman
                          so version 0.3.0 ist raus !
                          fuer alle die 0.2.9 hatten bitte ASAP auf 0.3.0 ! In 0.2.9 habe ich eine sehr boese schleife fuer die discovergy API eingebaut darum auch die verbindungsfehleler 0.3 behebt das !!!
                          • Webranger
                            von 0.2.9 auf 0.3.0 gegangen
                            Adapter bleibt rot
                            discovergy.0	2018-12-16 17:50:27.422	info	terminating
                            discovergy.0	2018-12-16 17:50:27.368	info	Discovergy adapter stopped, cleaning everything up :-)
                            discovergy.0	2018-12-16 17:50:27.130	error	Connection_Failed, check your credentials !
                            discovergy.0	2018-12-16 17:50:24.127	error	Connection_Failed, check your credentials !
                            discovergy.0	2018-12-16 17:50:21.124	error	Connection_Failed, check your credentials !
                            discovergy.0	2018-12-16 17:50:18.129	error	Connection_Failed, check your credentials !
                            discovergy.0	2018-12-16 17:50:15.156	error	Connection_Failed, check your credentials !
                            discovergy.0	2018-12-16 17:50:12.128	error	Connection_Failed, check your credentials !
                            discovergy.0	2018-12-16 17:50:09.270	error	Connection_Failed, check your credentials !
                            discovergy.0	2018-12-16 17:50:08.988	debug	client_secret decrypt ready
                            discovergy.0	2018-12-16 17:50:08.935	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v6.13.0
                            discovergy.0	2018-12-16 17:50:08.884	info	States connected to redis: 127.0.0.1:6379
                            discovergy.0	2018-12-16 17:50:08.877	debug	statesDB connected
                            discovergy.0	2018-12-16 17:50:08.841	debug	objectDB connected
                            • Dutchman
                              Du hast die Log Meldung gesehen?
                              Hast du deine Login Daten in den Einstellungen hinterlegt?
                              • Webranger
                                ja waren ja noch von vorher drin.
                                • Webranger
                                  Sorry mein fehler! Tippfehler
                                  Läuft
                                  • Dutchman
                                    @ringdingringding:
                                    Läuft `
                                    Hahaha 🙂 ja der Log sagt es ja nicht zum Spass !
                                    Hast du auch eine PV Anlage also erzeugst du Strom ?
                                    Desweiteren bitte :
                                    • überprüfen ob nur die Power states zum kurzen Intervall und der Rest beim langen gezogen wird
                                    • die states nicht mehr doppelt uodaten.
                                    • sind die states in deinem Admin änderbar (also die Werte ?) Sollte nicht so sein
                                    • keine fehlenden Verbindungen mehr im Log ?
                                    • Password nicht mehr sichtbar ?
                                    Ja das ist eigentlich das wichtigste
                                    • Webranger
                                      PV Anlage habe ich nicht.
                                      Ja macht wie es soll.
                                      Ja auch das läuft nun richtig
                                      Nein kann da nichts ändern.
                                      Log ist sauber. Keine Einträge mehr seit update ausser diese:
                                      discovergy.0 2018-12-16 19:32:02.058 debug system.adapter.admin.0: logging true
                                      discovergy.0 2018-12-16 19:32:02.057 debug redis pmessage io..logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1544985122043,"q":0,"from":"system.adapter.admin.0","lc":1544985122043}
                                      discovergy.0 2018-12-16 19:24:18.309 debug system.adapter.admin.0: logging false
                                      discovergy.0 2018-12-16 19:24:18.294 debug redis pmessage io.
                                      .logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1544984658273,"q":0,"from":"system.adapter.admin.0","lc":1544984658273}
                                      discovergy.0 2018-12-16 18:34:37.171 debug system.adapter.admin.0: logging true
                                      discovergy.0 2018-12-16 18:34:37.170 debug redis pmessage io..logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1544981677168,"q":0,"from":"system.adapter.admin.0","lc":1544981677168}
                                      discovergy.0 2018-12-16 18:34:04.071 debug system.adapter.admin.0: logging false
                                      discovergy.0 2018-12-16 18:34:04.067 debug redis pmessage io.
                                      .logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1544981644054,"q":0,"from":"system.adapter.admin.0","lc":1544981644054}
                                      discovergy.0 2018-12-16 18:32:24.411 debug client_secret decrypt ready
                                      discovergy.0 2018-12-16 18:32:24.366 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v6.13.0
                                      discovergy.0 2018-12-16 18:32:24.311 info States connected to redis: 127.0.0.1:6379
                                      discovergy.0 2018-12-16 18:32:24.304 debug statesDB connected
                                      discovergy.0 2018-12-16 18:32:24.269 debug objectDB connected
                                      - Password nicht mehr sichtbar ?
                                      Das Password ist nicht mehr zu sehen! Deswegen auch mein Tippfehler ;)
                                      So kann es meiner Meinung nach bleiben wenn nicht noch fehler auftauchen.
                                      Aso versionsanzeige hat noch nen fehler drin ;)
                                       ![2958_bildschirmfoto_2018-12-16_um_19.35.09.png](/assets/uploads/files/2958_bildschirmfoto_2018-12-16_um_19.35.09.png)
                                      Danke für deine arbeit
                                      • Dutchman
                                        Super danke dir !
                                        Die Log Einträge sind alle normal und OK.
                                        Ich werde noch bessere Einträge einbauen das man auch wirklich sieht das er läuft irgendwelche Ideen dazu was man im Log sehen möchte ?
                                        Die Version im Admin wird morgen richtig sein die repisitorys werden über Nacht immer aktualisiert und ich habe heute nach NPM gebracht.
                                        Na super, funktionell sieht alles OK aus wen das ne Woche so bei dir (und mindestens 2 anderen) so bleibt kommt er in die stable repro
                                        • O
                                          onkel-ede last edited by
                                          Hallo, sind die einzutragenden Username/Passwort die gleichen wie beim discovergy-Portal oder benötigt die api separate Zugangsdaten?
                                          • Dutchman
                                            Sind genau die gleichen wie auf dem Portal.
                                            Werden nur auf deine Installation verschlüsselt gespeichert und auch per HTTPS verschlüsselt geschickt.
                                            Sollte jemand daran zweifeln gerne Code nachsehen 🙂
                                            Auf github steht auch ein Demo Account, damit geht der Adapter und das Portal
                                            energie
                                            33
                                            294
                                            42446
