    4. [Aufruf] fullyBrowser Adapter
    • metaxa
      metaxa last edited by
      Hi!
      Ich krieg den Adapter nicht auf "grün". Installiert habe ich 0.0.6 und auch auf einem Device mit PLUS License die Remoteeinstellungen lt. Github gesetzt.
      Adapter installiert (Code 0):
      $ ./iobroker url "https://github.com/arteck/ioBroker.fullyBrowser/tarball/master" fullyBrowser --debug
      install https://github.com/arteck/ioBroker.fullyBrowser/tarball/master
      npm install https://github.com/arteck/ioBroker.fullyBrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      iobroker.inst@1.1.2 /opt/iobroker`-- iobroker.fullybrowser@0.0.6
      ! npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none was installed.
      npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none was installed.
      npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none was installed.
      npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none was installed.
      ! ERROR: Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
      process exited with code 0
      Instanz erzeugt (Code 0):
      $ ./iobroker add fullybrowser  --host iobroker-master-tb
      host.iobroker-master-tb install adapter fullybrowser
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullybrowser"
      got /opt/iobroker/node_modules/iobroker.fullybrowser/admin
      upload [3] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/words.js words.js application/javascript
      upload [2] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index_m.html index_m.html text/html
      upload [1] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index.html index.html text/html
      upload [0] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/fully.png fully.png image/png
      host.iobroker-master-tb object system.adapter.fullybrowser created
      host.iobroker-master-tb create instance fullybrowser
      host.iobroker-master-tb object system.adapter.fullybrowser.0.outputCount created
      host.iobroker-master-tb object system.adapter.fullybrowser.0.inputCount created
      host.iobroker-master-tb object system.adapter.fullybrowser.0.uptime created
      host.iobroker-master-tb object system.adapter.fullybrowser.0.memRss created
      host.iobroker-master-tb object system.adapter.fullybrowser.0.memHeapTotal created
      host.iobroker-master-tb object system.adapter.fullybrowser.0.memHeapUsed created
      host.iobroker-master-tb object system.adapter.fullybrowser.0.connected created
      host.iobroker-master-tb object system.adapter.fullybrowser.0.alive created
      host.iobroker-master-tb object system.adapter.fullybrowser.0 created
      Im LOG steht (Cannot find start file of adapter) und der Adapter bleibt rot.
      host.iobroker-master-tb 2018-12-16 11:40:23.461 info Restart adapter system.adapter.fullybrowser.0 because enabled
      host.iobroker-master-tb 2018-12-16 11:40:23.459 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
      host.iobroker-master-tb 2018-12-16 11:40:21.678 info instance system.adapter.fullybrowser.0 started with pid 26447
      host.iobroker-master-tb 2018-12-16 11:39:51.630 info Restart adapter system.adapter.fullybrowser.0 because enabled
      host.iobroker-master-tb 2018-12-16 11:39:51.630 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
      host.iobroker-master-tb 2018-12-16 11:39:49.898 info instance system.adapter.fullybrowser.0 started with pid 26437
      host.iobroker-master-tb 2018-12-16 11:39:49.857 info object change system.adapter.fullybrowser.0
      host.iobroker-master-tb 2018-12-16 11:39:41.442 info Restart adapter system.adapter.fullybrowser.0 because enabled
      host.iobroker-master-tb 2018-12-16 11:39:41.442 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
      host.iobroker-master-tb 2018-12-16 11:39:39.610 info instance system.adapter.fullybrowser.0 started with pid 26426
      host.iobroker-master-tb 2018-12-16 11:39:09.565 info Restart adapter system.adapter.fullybrowser.0 because enabled
      host.iobroker-master-tb 2018-12-16 11:39:09.564 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
      host.iobroker-master-tb 2018-12-16 11:39:08.205 info instance system.adapter.fullybrowser.0 started with pid 26376
      host.iobroker-master-tb 2018-12-16 11:38:38.175 info Restart adapter system.adapter.fullybrowser.0 because enabled
      host.iobroker-master-tb 2018-12-16 11:38:38.175 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
      host.iobroker-master-tb 2018-12-16 11:38:36.313 info instance system.adapter.fullybrowser.0 started with pid 26366
      host.iobroker-master-tb 2018-12-16 11:38:06.276 info Restart adapter system.adapter.fullybrowser.0 because enabled
      host.iobroker-master-tb 2018-12-16 11:38:06.275 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
      host.iobroker-master-tb 2018-12-16 11:38:04.551 info instance system.adapter.fullybrowser.0 started with pid 26316
      host.iobroker-master-tb 2018-12-16 11:37:34.501 info Restart adapter system.adapter.fullybrowser.0 because enabled
      host.iobroker-master-tb 2018-12-16 11:37:34.500 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
      host.iobroker-master-tb 2018-12-16 11:37:33.253 info instance system.adapter.fullybrowser.0 started with pid 26305
      host.iobroker-master-tb 2018-12-16 11:37:03.227 info Restart adapter system.adapter.fullybrowser.0 because enabled
      host.iobroker-master-tb 2018-12-16 11:37:03.226 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
      Neuinstallation des Adapters schon 2x gemacht, leider keine Änderung.
      Passwort auf dem Device für Remote gesetzt, Port unverändert gelassen (finde nicht mal die Einstellung auf dem Device)
      Kann mir bitte irgendwer einen TIp geben?
      LG, mxa
        moment wartmal
        • Chaot
          Chaot last edited by
          Danke.
          Aber welcher Wert muss da rein.
          Bei mir ist die Zeile leer obwohl ich die Helligkeit auf 50% gesetzt habe.
          Dann habe ich noch ein komisches Phänomen:
          Ich habe den Fully derzeit so eingestellt das er über Timer den Screen ab 22:00 Uhr abschaltet und ab 5:30 wieder an.
          Das Abschalten und Einschalten funktioniert, aber er schaltet auch blöderweise genau um Mitternacht wieder den Screen an.
          Kennt das Problem jemand? Oder kann das am Adapter liegen?
            @metaxa:
            Hi!
            LG, mxa `
            neue Version 0.0.7
              @Chaot:
              Danke.
              Kennt das Problem jemand? Oder kann das am Adapter liegen? `
              na klar ist die leer…
              da es sich hier um ein Statement für mehrere Befehle handelt musst du das auch so angeben
              entweder schreibst du das so rein (kannst kopieren und einfügen und enter)
              &key=screenBrightness&value=20
              oder so im Script
              setState('fullyBrowser.0.xxx_xxx_xxx_xxx.Commands.setStringSetting', '&key=screenBrightness&value=20');
              • Webranger
                Webranger last edited by
                Ist screenBrightness nicht nur eine info?
                Wenn das nicht so ist wie kann ich das per blockly ändern?
                Das wäre super
                • metaxa
                  @arteck:
                  neue Version 0.0.7 `
                  Super schnell repariert, ganz lieben Dank!
                  Jetzt liefert der Adapter Daten, jetzt muss ich mir mal ansehen was ich mit den Datenpunkten alles anstellen kann. Die Installationsroutine brachte zwar jede Menge für mich unverständliches Zeugs
                  Adapter über GitHub Upgedated (Katze):
                  • assert-plus@1.0.0 node_modules/iobroker.fullybrowser/node_modules/assert-plus- asynckit@0.4.0 node_modules/iobroker.fullybrowser/node_modules/asynckit
                  • aws-sign2@0.7.0 node_modules/iobroker.fullybrowser/node_modules/aws-sign2
                  • aws4@1.8.0 node_modules/iobroker.fullybrowser/node_modules/aws4
                  • caseless@0.12.0 node_modules/iobroker.fullybrowser/node_modules/caseless
                  • core-util-is@1.0.2 node_modules/iobroker.fullybrowser/node_modules/core-util-is
                  • dashdash@1.14.1 node_modules/iobroker.fullybrowser/node_modules/dashdash
                  • delayed-stream@1.0.0 node_modules/iobroker.fullybrowser/node_modules/delayed-stream
                  • combined-stream@1.0.7 node_modules/iobroker.fullybrowser/node_modules/combined-stream
                  • extend@3.0.2 node_modules/iobroker.fullybrowser/node_modules/extend
                  • extsprintf@1.3.0 node_modules/iobroker.fullybrowser/node_modules/extsprintf
                  • fast-deep-equal@2.0.1 node_modules/iobroker.fullybrowser/node_modules/fast-deep-equal
                  • fast-json-stable-stringify@2.0.0 node_modules/iobroker.fullybrowser/node_modules/fast-json-stable-stringify
                  • forever-agent@0.6.1 node_modules/iobroker.fullybrowser/node_modules/forever-agent
                  • getpass@0.1.7 node_modules/iobroker.fullybrowser/node_modules/getpass
                  • har-schema@2.0.0 node_modules/iobroker.fullybrowser/node_modules/har-schema
                  • is-typedarray@1.0.0 node_modules/iobroker.fullybrowser/node_modules/is-typedarray
                  • isstream@0.1.2 node_modules/iobroker.fullybrowser/node_modules/isstream
                  • jsbn@0.1.1 node_modules/iobroker.fullybrowser/node_modules/jsbn
                  • json-schema@0.2.3 node_modules/iobroker.fullybrowser/node_modules/json-schema
                  • json-schema-traverse@0.4.1 node_modules/iobroker.fullybrowser/node_modules/json-schema-traverse
                  • json-stringify-safe@5.0.1 node_modules/iobroker.fullybrowser/node_modules/json-stringify-safe
                  ! - loglevel@1.6.1 node_modules/iobroker.fullybrowser/node_modules/loglevel- mime-db@1.37.0 node_modules/iobroker.fullybrowser/node_modules/mime-db
                  • mime-types@2.1.21 node_modules/iobroker.fullybrowser/node_modules/mime-types
                  • form-data@2.3.3 node_modules/iobroker.fullybrowser/node_modules/form-data
                  • oauth-sign@0.9.0 node_modules/iobroker.fullybrowser/node_modules/oauth-sign
                  • performance-now@2.1.0 node_modules/iobroker.fullybrowser/node_modules/performance-now
                  • psl@1.1.31 node_modules/iobroker.fullybrowser/node_modules/psl
                  • punycode@2.1.1 node_modules/iobroker.fullybrowser/node_modules/punycode
                  • qs@6.5.2 node_modules/iobroker.fullybrowser/node_modules/qs
                  • safe-buffer@5.1.2 node_modules/iobroker.fullybrowser/node_modules/safe-buffer
                  • safer-buffer@2.1.2 node_modules/iobroker.fullybrowser/node_modules/safer-buffer
                  • asn1@0.2.4 node_modules/iobroker.fullybrowser/node_modules/asn1
                  • ecc-jsbn@0.1.2 node_modules/iobroker.fullybrowser/node_modules/ecc-jsbn
                  • punycode@1.4.1 node_modules/iobroker.fullybrowser/node_modules/tough-cookie/node_modules/punycode
                  • tough-cookie@2.4.3 node_modules/iobroker.fullybrowser/node_modules/tough-cookie
                  • tunnel-agent@0.6.0 node_modules/iobroker.fullybrowser/node_modules/tunnel-agent
                  • tweetnacl@0.14.5 node_modules/iobroker.fullybrowser/node_modules/tweetnacl
                  • bcrypt-pbkdf@1.0.2 node_modules/iobroker.fullybrowser/node_modules/bcrypt-pbkdf
                  • sshpk@1.15.2 node_modules/iobroker.fullybrowser/node_modules/sshpk
                  • uri-js@4.2.2 node_modules/iobroker.fullybrowser/node_modules/uri-js
                  • ajv@6.6.1 node_modules/iobroker.fullybrowser/node_modules/ajv
                  • har-validator@5.1.3 node_modules/iobroker.fullybrowser/node_modules/har-validator
                  • uuid@3.3.2 node_modules/iobroker.fullybrowser/node_modules/uuid
                  • verror@1.10.0 node_modules/iobroker.fullybrowser/node_modules/verror
                  • jsprim@1.4.1 node_modules/iobroker.fullybrowser/node_modules/jsprim
                  • http-signature@1.2.0 node_modules/iobroker.fullybrowser/node_modules/http-signature
                  • request@2.88.0 node_modules/iobroker.fullybrowser/node_modules/request
                  ! iobroker.inst@1.1.2 /opt/iobroker`-- iobroker.fullybrowser@0.0.7
                  ! npm
                  npm
                  npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none was installed.npm
                  npm WARN
                  react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none was installed.npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none was installed.
                  Die LOG Datei schaut aber gleich wesentlch besser aus (Update um 2018-12-16 12:36:29.928 gestartet):
                  host.iobroker-master-tb	2018-12-16 12:38:41.651	info	instance system.adapter.fullybrowser.0 started with pid 30034
                  host.iobroker-master-tb	2018-12-16 12:38:41.584	info	"system.adapter.fullybrowser.0" enabled
                  host.iobroker-master-tb	2018-12-16 12:38:41.583	info	object change system.adapter.fullybrowser.0
                  host.iobroker-master-tb	2018-12-16 12:38:04.953	info	object change system.adapter.fullybrowser.0
                  host.iobroker-master-tb	2018-12-16 12:36:29.928	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                  host.iobroker-master-tb	2018-12-16 12:34:50.683	info	Do not restart adapter system.adapter.fullybrowser.0 because disabled or deleted
                  host.iobroker-master-tb	2018-12-16 12:34:50.682	error	instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                  host.iobroker-master-tb	2018-12-16 12:34:26.100	info	"system.adapter.fullybrowser.0" disabled
                  host.iobroker-master-tb	2018-12-16 12:34:26.100	info	object change system.adapter.fullybrowser.0
                  host.iobroker-master-tb	2018-12-16 12:34:19.465	info	Restart adapter system.adapter.fullybrowser.0 because enabled
                  host.iobroker-master-tb	2018-12-16 12:34:19.465	error	instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                  host.iobroker-master-tb	2018-12-16 12:34:17.630	info	instance system.adapter.fullybrowser.0 started with pid 29790
                  host.iobroker-master-tb	2018-12-16 12:33:47.594	info	Restart adapter system.adapter.fullybrowser.0 because enabled
                  host.iobroker-master-tb	2018-12-16 12:33:47.594	error	instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                  Nach paar MInuten jede Menge Datenpunkte und keinerlei LOG Einträge mehr!
                  Respekt, saubere Arbeit!
                  LG, mxa
                  • Chaot
                    Danke schön.
                    Das werde ich mal ausprobieren und versuchen ein kleines Timerscript dazu zu schreiben.
                    Ich habe gerade versucht über die Katze die letzte Versin zu installieren, aber ich bekomme immer noch die 0.0.6 angezeigt.
                    Dafür gibt das Log diese Fehlermeldung aus:
                    host.haus	2018-12-16 13:37:40.929	info	Restart adapter system.adapter.fullyBrowser.0 because enabled
                    host.haus	2018-12-16 13:37:40.929	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
                    host.haus	2018-12-16 13:37:39.838	info	instance system.adapter.fullyBrowser.0 started with pid 26926
                    pushover.0	2018-12-16 13:37:09.838	info	Send pushover notification: {"message":"iobroker - System Adapter meldet Probleme fullyBrowser.0.alive","title":"ioBroker","priority":"0"}
                    host.haus	2018-12-16 13:37:09.817	info	Restart adapter system.adapter.fullyBrowser.0 because enabled
                    host.haus	2018-12-16 13:37:09.816	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
                    host.haus	2018-12-16 13:37:08.863	info	instance system.adapter.fullyBrowser.0 started with pid 26915
                    Log der Installation:
                    iobroker	2018-12-16 13:35:43.395	info	exit 0
                    iobroker	2018-12-16 13:35:43.379	info	Adapter "system.adapter.fullyBrowser.0" restarted.
                    host.haus	2018-12-16 13:35:43.370	info	instance system.adapter.fullyBrowser.0 started with pid 26864
                    host.haus	2018-12-16 13:35:43.356	info	"system.adapter.fullyBrowser.0" enabled
                    host.haus	2018-12-16 13:35:43.355	info	object change system.adapter.fullyBrowser.0
                    host.haus	2018-12-16 13:35:43.334	info	"system.adapter.fullyBrowser.0" disabled
                    host.haus	2018-12-16 13:35:43.334	info	object change system.adapter.fullyBrowser.0
                    iobroker	2018-12-16 13:35:43.178	info	upload [0] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/fully.png fully.png image/png
                    iobroker	2018-12-16 13:35:43.117	info	upload [1] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index.html index.html text/html
                    iobroker	2018-12-16 13:35:43.055	info	upload [2] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index_m.html index_m.html text/html
                    iobroker	2018-12-16 13:35:42.982	info	upload [3] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/words.js words.js application/javascript
                    iobroker	2018-12-16 13:35:42.955	info	got /opt/iobroker/node_modules/iobroker.fullybrowser/admin
                    iobroker	2018-12-16 13:35:42.876	info	WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                    iobroker	2018-12-16 13:35:42.874	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm
                    iobroker	2018-12-16 13:35:42.873	info	npm
                    iobroker	2018-12-16 13:35:42.871	info	npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
                    iobroker	2018-12-16 13:35:42.870	info	npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
                    host.haus	2018-12-16 13:35:04.486	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                    host.haus	2018-12-16 13:35:00.134	info	instance system.adapter.tvspielfilm.0 started with pid 26845
                    host.haus	2018-12-16 13:35:00.060	info	instance system.adapter.dwd.0 started with pid 26839
                    iobroker	2018-12-16 13:34:27.224	info	npm install https://github.com/arteck/iobroker.fullybrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                    iobroker	2018-12-16 13:34:26.484	info	install https://github.com/arteck/iobroker.fullybrowser/tarball/master
                    iobroker	2018-12-16 13:34:25.917	info	url "https://github.com/arteck/iobroker.fullybrowser.git"
                    • Chaot
                      Keine Chance.
                      Der Adapter ist tot:
                      host.haus	2018-12-16 14:44:36.113	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
                      host.haus	2018-12-16 14:44:35.138	info	instance system.adapter.fullyBrowser.0 started with pid 28594
                      pushover.0	2018-12-16 14:44:05.142	info	Send pushover notification: {"message":"iobroker - System Adapter meldet Probleme fullyBrowser.0.alive","title":"ioBroker","priority":"0"}
                      host.haus	2018-12-16 14:44:05.120	info	Restart adapter system.adapter.fullyBrowser.0 because enabled
                      host.haus	2018-12-16 14:44:05.120	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
                      host.haus	2018-12-16 14:44:04.189	info	instance system.adapter.fullyBrowser.0 started with pid 28583
                      pushover.0	2018-12-16 14:43:34.196	info	Send pushover notification: {"message":"iobroker - System Adapter meldet Probleme fullyBrowser.0.alive","title":"ioBroker","priority":"0"}
                      host.haus	2018-12-16 14:43:34.173	info	Restart adapter system.adapter.fullyBrowser.0 because enabled
                      host.haus	2018-12-16 14:43:34.172	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
                      host.haus	2018-12-16 14:43:33.172	info	instance system.adapter.fullyBrowser.0 started with pid 28573
                      Angezeigte Version 0.0.6
                        kaschperle83 last edited by
                        Was macht der Adapter denn bzw wofür ist er?
                        Gesendet aus Hessen.
                        • Chaot
                          Ich bin wieder auf die alte Versin zurückgekommen.
                          Trotz Fehlermeldung bei der Installation scheint es geklappt zu haben:
                          iobroker	2018-12-16 14:49:10.786	info	exit 0
                          iobroker	2018-12-16 14:49:10.775	info	Adapter "fullyBrowser" updated
                          iobroker	2018-12-16 14:49:10.716	info	upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png
                          iobroker	2018-12-16 14:49:10.656	info	upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html
                          iobroker	2018-12-16 14:49:10.595	info	upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html
                          iobroker	2018-12-16 14:49:10.524	info	upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript
                          iobroker	2018-12-16 14:49:10.509	info	got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin
                          iobroker	2018-12-16 14:49:10.401	info	npm notice created a lockfile as package-lock.json. You should commit this file.
                          iobroker	2018-12-16 14:49:03.908	info	npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                          iobroker	2018-12-16 14:49:03.650	info	WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                          iobroker	2018-12-16 14:49:03.648	info	npm
                          iobroker	2018-12-16 14:49:01.901	info	npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                          iobroker	2018-12-16 14:49:00.162	info	npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                          iobroker	2018-12-16 14:48:58.410	info	npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                          iobroker	2018-12-16 14:48:54.436	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullyBrowser"
                          iobroker	2018-12-16 14:48:54.407	info	npm ERR! /root/.npm/_logs/2018-12-16T13_48_54_389Z-debug.log
                          iobroker	2018-12-16 14:48:54.407	info	npm ERR! A complete log of this run can be found in:
                          iobroker	2018-12-16 14:48:54.386	info	npm ERR! 404 Not Found: iobroker.fullyBrowser@0.0.6
                          iobroker	2018-12-16 14:48:54.383	info	ERR! code E404
                          iobroker	2018-12-16 14:48:54.382	info	npm
                          iobroker	2018-12-16 14:48:37.235	info	npm install iobroker.fullyBrowser@0.0.6 --production --save --prefix "/opt/iobroker" (System call)
                          iobroker	2018-12-16 14:48:36.785	info	NPM version: 6.4.1
                          iobroker	2018-12-16 14:48:36.299	info	Update fullyBrowser from @0.0.6 to @0.0.6
                          iobroker	2018-12-16 14:48:35.115	info	upgrade fullyBrowser@0.0.6
                          • Chaot
                            @kaschperle83:
                            Gesendet aus Hessen. `
                            Wenn du VIS über ein Tablet betreibst wird meist der FullyKiok Browser verwendet um VIS darzustellen.
                            Damit lassen sich aber noch viele andere Aufgaben erledigen:
                            Bildschirmschoner steuern
                            Helligkeit regeln
                            Akkustand auslesen (zum laden).
                            Bisher habe ich den Fully Browser verwendet und zusätzlich den PAW Adapter. In der neuen Variante fällt für mich der PAW Adapter weg.
                            Allerdings ist der Fully Browser nicht kostenfrei. Der Entwickler möchte 5 € dafür haben. Ich persönlich finde das aber angemessen.
                            • eric2905
                              eric2905 last edited by
                              Die 5€ sind es wirklich wert … der Browser ist gut.
                              Vor allen Dingen die Bewegungserkennung über die Frontkamera zum aktivieren der Anzeige.
                              Gruß,
                              Eric
                              Von unterwegs getippert
                              • Chaot
                                Ok,
                                keine Funktion mehr möglich.
                                Das Backup von heute morgen wird gerade zurückgespielt…..
                                  andyb last edited by
                                  Gerade installiert, läuft. Klasse Arbeit. Danke
                                    @Chaot:
                                    Ok,
                                    Das Backup von heute morgen wird gerade zurückgespielt….. `
                                    installiere den Adapter ganz normal der ist jetzt auch in der Version 0.0.7 über npm Verfügbar..
                                      Kueppert last edited by
                                      @arteck:
                                      @Chaot:
                                      Ok,
                                      installiere den Adapter ganz normal der ist jetzt auch in der Version 0.0.7 über npm Verfügbar..Update bricht bei mir mit Fehlermeldung ab… Kann die Meldung nachliefern 😞
                                      anbei die Fehlermeldungen:
                                      ! $ ./iobroker upgrade fullyBrowser Update fullyBrowser from @0.0.6 to @0.0.7 NPM version: 6.1.0 npm install iobroker.fullyBrowser@0.0.7 --production --save --prefix "/opt/iobroker" (System call) npm ERR! code E404 npm ERR! 404 Not Found: iobroker.fullyBrowser@0.0.7 npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-12-17T16_16_17_468Z-debug.log ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullyBrowser" got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript Adapter "system.adapter.fullyBrowser.0" restarted. upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png Adapter "fullyBrowser" updated process exited with code 0
                                        broker100 last edited by
                                        habe jetzt zum Test auch mal den Adapter 0.0.7 installiert.
                                        Hat soweit auch geklappt. Status LED auch grün.
                                        Nur einstellen kann ich nichts, Problem ist wahrscheinlich das "Is Fully Browser Alive? " immer auf false steht.
                                        Ich habe noch nicht die Vollversion, könnte es daran liegen?
                                        erledigt, wer lesen kann ist klar im Vorteil 🙂
                                        • Chaot
                                          Mal ne ganz blöde Frage.
                                          Wie kann ich denn einen Button aus einem script ansteuern?
                                          Irgendwie komme ich mit dem Akku laden nicht mehr nach. Deshalb würde ich gerne die Screen per script schalten.
                                          Aber da klemmts irgendwie. So richtige Hinweise finde ich da auch nirgendwo dazu.
                                            @Chaot:
                                            Aber da klemmts irgendwie. So richtige Hinweise finde ich da auch nirgendwo dazu. `
                                            wofür schreiben wir https://github.com/arteck/iobroker.fullybrowser/wiki
                                            fullybrowser fullybrowser adapter
                                            45
                                            289
                                            43576
