Test Adaper Discovergy v0.4.x
mal was aus den LOGs heute.
discovergy.0 2018-12-07 19:56:40.375 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.discovergy, node: v6.13.0 discovergy.0 2018-12-07 19:56:40.317 info States connected to redis: 127.0.0.1:6379 discovergy.0 2018-12-07 19:56:08.690 info terminating discovergy.0 2018-12-07 19:56:08.582 info Discovergy adapter stopped, cleaning everything up :-) discovergy.0 2018-12-07 19:56:08.580 error at IncomingMessage.g (events.js:292:16) discovergy.0 2018-12-07 19:56:08.580 error at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/request/request.js:1085:12) discovergy.0 2018-12-07 19:56:08.580 error at Request.emit (events.js:188:7) discovergy.0 2018-12-07 19:56:08.580 error at emitOne (events.js:96:13) discovergy.0 2018-12-07 19:56:08.580 error at Request. <anonymous>(/opt/iobroker/node_modules/request/request.js:1163:10) discovergy.0 2018-12-07 19:56:08.580 error at Request.emit (events.js:191:7) discovergy.0 2018-12-07 19:56:08.580 error at emitTwo (events.js:106:13) discovergy.0 2018-12-07 19:56:08.580 error at Request.self.callback (/opt/iobroker/node_modules/request/request.js:186:22) discovergy.0 2018-12-07 19:56:08.580 error at Request._callback (/opt/iobroker/node_modules/iobroker.discovergy/main.js:237:16) discovergy.0 2018-12-07 19:56:08.580 error at Object.parse (native) discovergy.0 2018-12-07 19:56:08.580 error SyntaxError: Unexpected token S in JSON at position 4 discovergy.0 2018-12-07 19:56:08.569 error uncaught exception: Unexpected token S in JSON at position 4</anonymous></anonymous>
Kein plan was da los war. lief danach weiter.
Gruss
Da hat sich die API verschluckt und kurz keine Daten geliefert.. hmm ob sie abgefangen werden
Version 0.2.6 läuft bei mir ohne fehler
@ringdingringding:Version 0.2.6 läuft bei mir ohne fehler `
Sehr schön, vermutlich an Wochenende ein Update des Adapter
Gibt es Änderungen?
Jup :
Zugangsdaten verschlüsselt speichern
Nur den jetzigen Verbrauch alle 3 Sekunden abholen
Gesammtverbrauch jede Minute (einstellbar)
0.2.9 ist raus
Update eingespielt.
Bei der versionsnummer passt was nicht
Läuft soweit wie es aussieht. Daten kommen an.
Am Anfang hatte ich 3 errors aber dann nicht wieder.
Ich werde das weiter beobachten
So wie es aussieht werden die Werte zweimal abgeholt und in die History geschrieben oder sieht das nur so aus?
Gruss Danyel
Hi Daniel,
Danke ! Ja die Version ist mein Fehler musste noch einen schnellen fix nachreichen.
Hmm ok das es doppelt kommt hatte ich vermutet wurde gestern Abend zu spät zur Analyse.
Danke werde ich heute Mal schauen und korrigieren und Pass Word encryption einbauen
so version 0.3.0 ist raus !
fuer alle die 0.2.9 hatten bitte ASAP auf 0.3.0 ! In 0.2.9 habe ich eine sehr boese schleife fuer die discovergy API eingebaut darum auch die verbindungsfehleler 0.3 behebt das !!!
von 0.2.9 auf 0.3.0 gegangen
Adapter bleibt rot
discovergy.0 2018-12-16 17:50:27.422 info terminating discovergy.0 2018-12-16 17:50:27.368 info Discovergy adapter stopped, cleaning everything up :-) discovergy.0 2018-12-16 17:50:27.130 error Connection_Failed, check your credentials ! discovergy.0 2018-12-16 17:50:24.127 error Connection_Failed, check your credentials ! discovergy.0 2018-12-16 17:50:21.124 error Connection_Failed, check your credentials ! discovergy.0 2018-12-16 17:50:18.129 error Connection_Failed, check your credentials ! discovergy.0 2018-12-16 17:50:15.156 error Connection_Failed, check your credentials ! discovergy.0 2018-12-16 17:50:12.128 error Connection_Failed, check your credentials ! discovergy.0 2018-12-16 17:50:09.270 error Connection_Failed, check your credentials ! discovergy.0 2018-12-16 17:50:08.988 debug client_secret decrypt ready discovergy.0 2018-12-16 17:50:08.935 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v6.13.0 discovergy.0 2018-12-16 17:50:08.884 info States connected to redis: 127.0.0.1:6379 discovergy.0 2018-12-16 17:50:08.877 debug statesDB connected discovergy.0 2018-12-16 17:50:08.841 debug objectDB connected
Du hast die Log Meldung gesehen?
Hast du deine Login Daten in den Einstellungen hinterlegt?
ja waren ja noch von vorher drin.
Sorry mein fehler! Tippfehler
Läuft
@ringdingringding:Sorry mein fehler! Tippfehler
Läuft `
Hahaha
ja der Log sagt es ja nicht zum Spass !
Hast du auch eine PV Anlage also erzeugst du Strom ?
Desweiteren bitte :
überprüfen ob nur die Power states zum kurzen Intervall und der Rest beim langen gezogen wird
die states nicht mehr doppelt uodaten.
sind die states in deinem Admin änderbar (also die Werte ?) Sollte nicht so sein
keine fehlenden Verbindungen mehr im Log ?
Password nicht mehr sichtbar ?
Ja das ist eigentlich das wichtigste
PV Anlage habe ich nicht.
- überprüfen ob nur die Power states zum kurzen Intervall und der Rest beim langen gezogen wird
Ja macht wie es soll.
- die states nicht mehr doppelt uodaten.
Ja auch das läuft nun richtig
- sind die states in deinem Admin änderbar (also die Werte ?) Sollte nicht so sein
Nein kann da nichts ändern.
- keine fehlenden Verbindungen mehr im Log ?
Log ist sauber. Keine Einträge mehr seit update ausser diese:
discovergy.0 2018-12-16 19:32:02.058 debug system.adapter.admin.0: logging true
discovergy.0 2018-12-16 19:32:02.057 debug redis pmessage io..logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1544985122043,"q":0,"from":"system.adapter.admin.0","lc":1544985122043}
discovergy.0 2018-12-16 19:24:18.309 debug system.adapter.admin.0: logging false
discovergy.0 2018-12-16 19:24:18.294 debug redis pmessage io..logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1544984658273,"q":0,"from":"system.adapter.admin.0","lc":1544984658273}
discovergy.0 2018-12-16 18:34:37.171 debug system.adapter.admin.0: logging true
discovergy.0 2018-12-16 18:34:37.170 debug redis pmessage io..logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1544981677168,"q":0,"from":"system.adapter.admin.0","lc":1544981677168}
discovergy.0 2018-12-16 18:34:04.071 debug system.adapter.admin.0: logging false
discovergy.0 2018-12-16 18:34:04.067 debug redis pmessage io..logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1544981644054,"q":0,"from":"system.adapter.admin.0","lc":1544981644054}
discovergy.0 2018-12-16 18:32:24.411 debug client_secret decrypt ready
discovergy.0 2018-12-16 18:32:24.366 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v6.13.0
discovergy.0 2018-12-16 18:32:24.311 info States connected to redis: 127.0.0.1:6379
discovergy.0 2018-12-16 18:32:24.304 debug statesDB connected
discovergy.0 2018-12-16 18:32:24.269 debug objectDB connected- Password nicht mehr sichtbar ? Das Password ist nicht mehr zu sehen! Deswegen auch mein Tippfehler ;) So kann es meiner Meinung nach bleiben wenn nicht noch fehler auftauchen. Aso versionsanzeige hat noch nen fehler drin ;)  Danke für deine arbeit
Super danke dir !
Die Log Einträge sind alle normal und OK.
Ich werde noch bessere Einträge einbauen das man auch wirklich sieht das er läuft irgendwelche Ideen dazu was man im Log sehen möchte ?
Die Version im Admin wird morgen richtig sein die repisitorys werden über Nacht immer aktualisiert und ich habe heute nach NPM gebracht.
Na super, funktionell sieht alles OK aus wen das ne Woche so bei dir (und mindestens 2 anderen) so bleibt kommt er in die stable repro
Hallo, sind die einzutragenden Username/Passwort die gleichen wie beim discovergy-Portal oder benötigt die api separate Zugangsdaten?
12613_discovergy-iobroker.jpg -
Sind genau die gleichen wie auf dem Portal.
Werden nur auf deine Installation verschlüsselt gespeichert und auch per HTTPS verschlüsselt geschickt.
Sollte jemand daran zweifeln gerne Code nachsehen
Auf github steht auch ein Demo Account, damit geht der Adapter und das Portal
Welchen Grund kann es noch geben, weshalb ich keine Verbindung bekomme, außer den Zugangsdaten?
