    4. [Aufruf] fullyBrowser Adapter
    • Chaot
      Chaot last edited by
      Danke schön.
      Das werde ich mal ausprobieren und versuchen ein kleines Timerscript dazu zu schreiben.
      Ich habe gerade versucht über die Katze die letzte Versin zu installieren, aber ich bekomme immer noch die 0.0.6 angezeigt.
      Dafür gibt das Log diese Fehlermeldung aus:
      host.haus	2018-12-16 13:37:40.929	info	Restart adapter system.adapter.fullyBrowser.0 because enabled
      host.haus	2018-12-16 13:37:40.929	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
      host.haus	2018-12-16 13:37:39.838	info	instance system.adapter.fullyBrowser.0 started with pid 26926
      pushover.0	2018-12-16 13:37:09.838	info	Send pushover notification: {"message":"iobroker - System Adapter meldet Probleme fullyBrowser.0.alive","title":"ioBroker","priority":"0"}
      host.haus	2018-12-16 13:37:09.817	info	Restart adapter system.adapter.fullyBrowser.0 because enabled
      host.haus	2018-12-16 13:37:09.816	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
      host.haus	2018-12-16 13:37:08.863	info	instance system.adapter.fullyBrowser.0 started with pid 26915
      Log der Installation:
      iobroker	2018-12-16 13:35:43.395	info	exit 0
      iobroker	2018-12-16 13:35:43.379	info	Adapter "system.adapter.fullyBrowser.0" restarted.
      host.haus	2018-12-16 13:35:43.370	info	instance system.adapter.fullyBrowser.0 started with pid 26864
      host.haus	2018-12-16 13:35:43.356	info	"system.adapter.fullyBrowser.0" enabled
      host.haus	2018-12-16 13:35:43.355	info	object change system.adapter.fullyBrowser.0
      host.haus	2018-12-16 13:35:43.334	info	"system.adapter.fullyBrowser.0" disabled
      host.haus	2018-12-16 13:35:43.334	info	object change system.adapter.fullyBrowser.0
      iobroker	2018-12-16 13:35:43.178	info	upload [0] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/fully.png fully.png image/png
      iobroker	2018-12-16 13:35:43.117	info	upload [1] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index.html index.html text/html
      iobroker	2018-12-16 13:35:43.055	info	upload [2] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index_m.html index_m.html text/html
      iobroker	2018-12-16 13:35:42.982	info	upload [3] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/words.js words.js application/javascript
      iobroker	2018-12-16 13:35:42.955	info	got /opt/iobroker/node_modules/iobroker.fullybrowser/admin
      iobroker	2018-12-16 13:35:42.876	info	WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      iobroker	2018-12-16 13:35:42.874	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm
      iobroker	2018-12-16 13:35:42.873	info	npm
      iobroker	2018-12-16 13:35:42.871	info	npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
      iobroker	2018-12-16 13:35:42.870	info	npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
      host.haus	2018-12-16 13:35:04.486	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
      host.haus	2018-12-16 13:35:00.134	info	instance system.adapter.tvspielfilm.0 started with pid 26845
      host.haus	2018-12-16 13:35:00.060	info	instance system.adapter.dwd.0 started with pid 26839
      iobroker	2018-12-16 13:34:27.224	info	npm install https://github.com/arteck/iobroker.fullybrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      iobroker	2018-12-16 13:34:26.484	info	install https://github.com/arteck/iobroker.fullybrowser/tarball/master
      iobroker	2018-12-16 13:34:25.917	info	url "https://github.com/arteck/iobroker.fullybrowser.git"
      • Chaot
        Keine Chance.
        Der Adapter ist tot:
        host.haus	2018-12-16 14:44:36.113	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
        host.haus	2018-12-16 14:44:35.138	info	instance system.adapter.fullyBrowser.0 started with pid 28594
        pushover.0	2018-12-16 14:44:05.142	info	Send pushover notification: {"message":"iobroker - System Adapter meldet Probleme fullyBrowser.0.alive","title":"ioBroker","priority":"0"}
        host.haus	2018-12-16 14:44:05.120	info	Restart adapter system.adapter.fullyBrowser.0 because enabled
        host.haus	2018-12-16 14:44:05.120	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
        host.haus	2018-12-16 14:44:04.189	info	instance system.adapter.fullyBrowser.0 started with pid 28583
        pushover.0	2018-12-16 14:43:34.196	info	Send pushover notification: {"message":"iobroker - System Adapter meldet Probleme fullyBrowser.0.alive","title":"ioBroker","priority":"0"}
        host.haus	2018-12-16 14:43:34.173	info	Restart adapter system.adapter.fullyBrowser.0 because enabled
        host.haus	2018-12-16 14:43:34.172	error	instance system.adapter.fullyBrowser.0 terminated with code 7 (Adapter already running)
        host.haus	2018-12-16 14:43:33.172	info	instance system.adapter.fullyBrowser.0 started with pid 28573
        Angezeigte Version 0.0.6
          kaschperle83 last edited by
          Was macht der Adapter denn bzw wofür ist er?
          Gesendet aus Hessen.
          • Chaot
            Ich bin wieder auf die alte Versin zurückgekommen.
            Trotz Fehlermeldung bei der Installation scheint es geklappt zu haben:
            iobroker	2018-12-16 14:49:10.786	info	exit 0
            iobroker	2018-12-16 14:49:10.775	info	Adapter "fullyBrowser" updated
            iobroker	2018-12-16 14:49:10.716	info	upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png
            iobroker	2018-12-16 14:49:10.656	info	upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html
            iobroker	2018-12-16 14:49:10.595	info	upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html
            iobroker	2018-12-16 14:49:10.524	info	upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript
            iobroker	2018-12-16 14:49:10.509	info	got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin
            iobroker	2018-12-16 14:49:10.401	info	npm notice created a lockfile as package-lock.json. You should commit this file.
            iobroker	2018-12-16 14:49:03.908	info	npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
            iobroker	2018-12-16 14:49:03.650	info	WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
            iobroker	2018-12-16 14:49:03.648	info	npm
            iobroker	2018-12-16 14:49:01.901	info	npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
            iobroker	2018-12-16 14:49:00.162	info	npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
            iobroker	2018-12-16 14:48:58.410	info	npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
            iobroker	2018-12-16 14:48:54.436	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullyBrowser"
            iobroker	2018-12-16 14:48:54.407	info	npm ERR! /root/.npm/_logs/2018-12-16T13_48_54_389Z-debug.log
            iobroker	2018-12-16 14:48:54.407	info	npm ERR! A complete log of this run can be found in:
            iobroker	2018-12-16 14:48:54.386	info	npm ERR! 404 Not Found: iobroker.fullyBrowser@0.0.6
            iobroker	2018-12-16 14:48:54.383	info	ERR! code E404
            iobroker	2018-12-16 14:48:54.382	info	npm
            iobroker	2018-12-16 14:48:37.235	info	npm install iobroker.fullyBrowser@0.0.6 --production --save --prefix "/opt/iobroker" (System call)
            iobroker	2018-12-16 14:48:36.785	info	NPM version: 6.4.1
            iobroker	2018-12-16 14:48:36.299	info	Update fullyBrowser from @0.0.6 to @0.0.6
            iobroker	2018-12-16 14:48:35.115	info	upgrade fullyBrowser@0.0.6
            • Chaot
              @kaschperle83:
              Gesendet aus Hessen. `
              Wenn du VIS über ein Tablet betreibst wird meist der FullyKiok Browser verwendet um VIS darzustellen.
              Damit lassen sich aber noch viele andere Aufgaben erledigen:
              Bildschirmschoner steuern
              Helligkeit regeln
              Akkustand auslesen (zum laden).
              Bisher habe ich den Fully Browser verwendet und zusätzlich den PAW Adapter. In der neuen Variante fällt für mich der PAW Adapter weg.
              Allerdings ist der Fully Browser nicht kostenfrei. Der Entwickler möchte 5 € dafür haben. Ich persönlich finde das aber angemessen.
              • eric2905
                eric2905 last edited by
                Die 5€ sind es wirklich wert … der Browser ist gut.
                Vor allen Dingen die Bewegungserkennung über die Frontkamera zum aktivieren der Anzeige.
                Gruß,
                Eric
                Von unterwegs getippert
                • Chaot
                  Ok,
                  keine Funktion mehr möglich.
                  Das Backup von heute morgen wird gerade zurückgespielt…..
                    andyb last edited by
                    Gerade installiert, läuft. Klasse Arbeit. Danke
                      @Chaot:
                      Ok,
                      Das Backup von heute morgen wird gerade zurückgespielt….. `
                      installiere den Adapter ganz normal der ist jetzt auch in der Version 0.0.7 über npm Verfügbar..
                        Kueppert last edited by
                        @arteck:
                        @Chaot:
                        Ok,
                        installiere den Adapter ganz normal der ist jetzt auch in der Version 0.0.7 über npm Verfügbar..Update bricht bei mir mit Fehlermeldung ab… Kann die Meldung nachliefern 😞
                        anbei die Fehlermeldungen:
                        ! $ ./iobroker upgrade fullyBrowser Update fullyBrowser from @0.0.6 to @0.0.7 NPM version: 6.1.0 npm install iobroker.fullyBrowser@0.0.7 --production --save --prefix "/opt/iobroker" (System call) npm ERR! code E404 npm ERR! 404 Not Found: iobroker.fullyBrowser@0.0.7 npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-12-17T16_16_17_468Z-debug.log ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullyBrowser" got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript Adapter "system.adapter.fullyBrowser.0" restarted. upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png Adapter "fullyBrowser" updated process exited with code 0
                          broker100 last edited by
                          habe jetzt zum Test auch mal den Adapter 0.0.7 installiert.
                          Hat soweit auch geklappt. Status LED auch grün.
                          Nur einstellen kann ich nichts, Problem ist wahrscheinlich das "Is Fully Browser Alive? " immer auf false steht.
                          Ich habe noch nicht die Vollversion, könnte es daran liegen?
                          erledigt, wer lesen kann ist klar im Vorteil 🙂
                          • Chaot
                            Mal ne ganz blöde Frage.
                            Wie kann ich denn einen Button aus einem script ansteuern?
                            Irgendwie komme ich mit dem Akku laden nicht mehr nach. Deshalb würde ich gerne die Screen per script schalten.
                            Aber da klemmts irgendwie. So richtige Hinweise finde ich da auch nirgendwo dazu.
                              @Chaot:
                              Aber da klemmts irgendwie. So richtige Hinweise finde ich da auch nirgendwo dazu. `
                              wofür schreiben wir https://github.com/arteck/iobroker.fullybrowser/wiki
                                @Kueppert:
                                @arteck:
                                @Chaot:
                                Ok,
                                NPM version: 6.1.0
                                npm ERR! code E404
                                ahh ich habs.. im RepoList ist noch ein falschern Namen `  `  `
                                  mctom last edited by
                                  ich habe es so gelöst:
                                  setState('fullybrowser.0.192_168_2_18.Commands.screenOff'/*screenOn*/,true);
                                  Michael
                                    Manolo last edited by
                                    Habe nun das Script auch durch den Adapter entfernt. Große Unterschiede gibt es ja nicht, außer dass keine Fehler mehr im Log angezeigt werden.
                                    Ansonsten läuft alles wie gehabt.
                                    Mit dem Motion Detector komme ich aber leider nicht klar. Egal was ich einstelle, der Bildschirm macht was er will.
                                    @ilovegym:
                                    Cool ist, dass man auch den Bewegungssensor auslesen kann… wenn also mal ein Tablet von der Wand fällt... :roll: :mrgreen: kann ich mir ne TelegramMsg schicken lassen und gleich über Alexa ein neues bestellen lassen.. :lol: :lol: `
                                    Welcher Datenpunkt zeigt denn die Info für Bewegungserkennung? Ich finde nur den Status (motionDetectorState), der zeigt aber nur an ob der Motion Detector in den Einstellungen aktiviert ist. Die Auswertung einer Bewegung konnte ich bisher nirgends finden.
                                    Gibt es eine Möglichkeit den Namen unter Objekte zu ändern? Bei den IP Adressen muss ich immer schauen wo das Tab hängt.
                                    Ansonsten, tolle Arbeit! Vielen Dank für diesen Adapter.
                                    Gruß Manolo
                                    • 0
                                      0018 last edited by
                                      Gibt es irgendwelche Voraussetzungen damit der Daydream funktioniert? Bei mir klappt soweit alles bis auf den Daydream.
                                      • Chaot
                                        @arteck:
                                        @Chaot:
                                        wofür schreiben wir https://github.com/arteck/iobroker.fullybrowser/wiki `
                                        Da habe ich mich scheinbar falsch ausgedrückt.
                                        Die Dokus kenne ich ja alle.
                                        Aber für mich stellt sich die Frage wie ich den Button unter "Objekte" bedienen kann.
                                        Einen Schalter mit Status True/false kann ich ja per JScript schalten, aber ich finde nichts wie ich den Button bedienen kann.
                                        Ich finde da weder in Blockly oder in JS etwas (oder ich bin zu blöd zum Suchen).
                                          @Chaot:
                                          @arteck:
                                          @Chaot:
                                          Ich finde da weder in Blockly oder in JS etwas (oder ich bin zu blöd zum Suchen). `
                                          na genau so.. ein Schalter ist ein Button nur das dieser automatisch auf false zurückspringt
                                          • Chaot
                                            :oops: :oops: :oops:
                                            Ach so!
                                            Und ich habe so kompliziert um die Ecke gedacht 😮
                                            Danke schön.
                                            Ich bin übrigens aktuell noch auf der Version 0.6. Die 0.7 wurde mir mal kurz angeboten und scheint jetzt wieder weg zu sein.
                                            (Verwahrorte: default und latest)
                                            31.7k
                                            79.8k
                                            fullybrowser fullybrowser adapter
                                            45
                                            289
                                            39861
