    4. Node-red Flow zum Steuern von tuya
      rewenode last edited by
      @Zerpmaster:
      aus der Ferne per Flow `
      Über Alexa ?
      Zeig doch mal wie du es mit den sonoff gemacht hast, dann kann man darüber nachdenken ob (und falls ja wie) man die Tuya integrieren kann.
      • Z
        Zerpmaster last edited by
        Über das Alexa App würde es funktionieren aber das möchte ich nicht.
        ! "id": "f1ba0ca2.3047e",
        ! "type": "tab",
        ! "label": "Sonoff Steckdosen",
        ! "disabled": false,
        ! "info": ""
        ! "id": "b840ed68.b196f",
        ! "type": "ui_switch",
        ! "z": "f1ba0ca2.3047e",
        ! "name": "PoolLampe",
        ! "label": "PoolLampe",
        ! "group": "eb2d516a.e00a6",
        ! "order": 0,
        ! "width": 0,
        ! "height": 0,
        ! "passthru": false,
        ! "decouple": "false",
        ! "topic": "",
        ! "style": "",
        ! "onvalue": "ON",
        ! "onvalueType": "str",
        ! "onicon": "",
        ! "oncolor": "",
        ! "offvalue": "OFF",
        ! "offvalueType": "str",
        ! "officon": "",
        ! "offcolor": "",
        ! "x": 730,
        ! "y": 440,
        ! "wires": [
        ! "a6726893.967358",
        ! "496aec37.330274"
        ! "id": "496aec37.330274",
        ! "type": "mqtt out",
        ! "name": "",
        ! "topic": "cmnd/PoolLampe/POWER",
        ! "qos": "",
        ! "retain": "",
        ! "broker": "f3965353.7f1dd",
        ! "x": 940,
        ! "y": 500,
        ! "wires": []
        ! "id": "df79c988.8c9698",
        ! "type": "change",
        ! "name": "Geraet aus",
        ! "rules": [
        ! "to": "OFF",
        ! "pt": "msg",
        ! "tot": "str",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 510,
        ! "y": 500,
        ! "wires": [
        ! "b840ed68.b196f",
        ! "496aec37.330274"
        ! "id": "4430a193.93ecd",
        ! "type": "change",
        ! "name": "Geraet an",
        ! "rules": [
        ! "to": "ON",
        ! "pt": "msg",
        ! "tot": "str",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 510,
        ! "y": 460,
        ! "wires": [
        ! "b840ed68.b196f",
        ! "496aec37.330274"
        ! "id": "d030b811.88f538",
        ! "type": "change",
        ! "rules": [
        ! "to": "true",
        ! "pt": "msg",
        ! "tot": "bool",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 670,
        ! "y": 340,
        ! "wires": [
        ! "472804ce.02fbec"
        ! "id": "c8f5321e.9ad5d",
        ! "type": "rbe",
        ! "name": "",
        ! "func": "rbe",
        ! "gap": "",
        ! "start": "",
        ! "inout": "out",
        ! "property": "payload",
        ! "x": 350,
        ! "y": 360,
        ! "wires": [
        ! "a6726893.967358"
        ! "id": "bd82081b.571a98",
        ! "type": "switch",
        ! "name": "",
        ! "propertyType": "msg",
        ! "rules": [
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "true"
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "false"
        ! "checkall": "true",
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 350,
        ! "y": 480,
        ! "wires": [
        ! "4430a193.93ecd"
        ! "df79c988.8c9698"
        ! "id": "6ce970ee.b8ce8",
        ! "type": "ioBroker in",
        ! "name": "Garten PoolLampe Status",
        ! "topic": "node-red.0.Garten.PoolLampe.Status",
        ! "payloadType": "value",
        ! "onlyack": "",
        ! "func": "all",
        ! "gap": "",
        ! "x": 170,
        ! "y": 480,
        ! "wires": [
        ! "bd82081b.571a98"
        ! "id": "472804ce.02fbec",
        ! "type": "ioBroker out",
        ! "ack": "true",
        ! "autoCreate": "true",
        ! "x": 930,
        ! "y": 360,
        ! "wires": []
        ! "id": "78e9a12d.e70b4",
        ! "type": "mqtt in",
        ! "name": "",
        ! "topic": "stat/PoolLampe/POWER",
        ! "qos": "2",
        ! "x": 170,
        ! "y": 360,
        ! "wires": [
        ! "c8f5321e.9ad5d"
        ! "id": "a6726893.967358",
        ! "type": "switch",
        ! "name": "",
        ! "rules": [
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "ON"
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "OFF"
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 510,
        ! "y": 360,
        ! "wires": [
        ! "d030b811.88f538"
        ! "f1c54d81.741cc"
        ! "id": "f1c54d81.741cc",
        ! "type": "change",
        ! "rules": [
        ! "to": "false",
        ! "pt": "msg",
        ! "tot": "bool",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 670,
        ! "y": 380,
        ! "wires": [
        ! "472804ce.02fbec"
        ! "id": "3e4460f4.8fb6f",
        ! "type": "change",
        ! "rules": [
        ! "to": "false",
        ! "pt": "msg",
        ! "tot": "bool",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 670,
        ! "y": 660,
        ! "wires": [
        ! "b64959c4.466508"
        ! "id": "2553f147.892bae",
        ! "type": "change",
        ! "rules": [
        ! "to": "true",
        ! "pt": "msg",
        ! "tot": "bool",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 670,
        ! "y": 620,
        ! "wires": [
        ! "b64959c4.466508"
        ! "id": "359cd265.82bbfe",
        ! "type": "rbe",
        ! "name": "",
        ! "func": "rbe",
        ! "gap": "",
        ! "start": "",
        ! "inout": "out",
        ! "x": 350,
        ! "y": 640,
        ! "wires": [
        ! "83a93d9c.6fb54"
        ! "id": "53734098.1a1a5",
        ! "name": "",
        ! "topic": "stat/PoolPumpe/POWER",
        ! "qos": "2",
        ! "x": 130,
        ! "y": 640,
        ! "wires": [
        ! "359cd265.82bbfe"
        ! "id": "83a93d9c.6fb54",
        ! "type": "switch",
        ! "name": "",
        ! "rules": [
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "ON"
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "OFF"
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 510,
        ! "y": 640,
        ! "wires": [
        ! "2553f147.892bae"
        ! "3e4460f4.8fb6f"
        ! "id": "b64959c4.466508",
        ! "name": "Garten PoolPumpe Status",
        ! "topic": "node-red.0.Garten.PoolPumpe.Status",
        ! "ack": "true",
        ! "x": 930,
        ! "y": 640,
        ! "wires": []
        ! "id": "d6f7ad9b.e96ba",
        ! "onlyack": "",
        ! "func": "all",
        ! "gap": "",
        ! "x": 170,
        ! "y": 760,
        ! "wires": [
        ! "56922d65.1d2804"
        ! "id": "56922d65.1d2804",
        ! "type": "switch",
        ! "name": "",
        ! "rules": [
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "true"
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "false"
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 350,
        ! "y": 760,
        ! "wires": [
        ! "9023ab67.a9c2f8"
        ! "f3d2bdc7.02da8"
        ! "id": "5225203f.c042e",
        ! "name": "",
        ! "topic": "cmnd/PoolPumpe/POWER",
        ! "qos": "",
        ! "retain": "",
        ! "x": 940,
        ! "y": 780,
        ! "wires": []
        ! "id": "f3d2bdc7.02da8",
        ! "type": "change",
        ! "rules": [
        ! "to": "OFF",
        ! "pt": "msg",
        ! "tot": "str",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 510,
        ! "y": 780,
        ! "wires": [
        ! "5225203f.c042e",
        ! "4f563911.a27008"
        ! "id": "4f563911.a27008",
        ! "name": "PoolPumpe",
        ! "label": "PoolPumpe",
        ! "order": 0,
        ! "width": 0,
        ! "height": 0,
        ! "topic": "",
        ! "style": "",
        ! "onvalue": "ON",
        ! "onicon": "",
        ! "oncolor": "",
        ! "officon": "",
        ! "offcolor": "",
        ! "x": 730,
        ! "y": 720,
        ! "wires": [
        ! "5225203f.c042e",
        ! "83a93d9c.6fb54"
        ! "id": "9023ab67.a9c2f8",
        ! "type": "change",
        ! "rules": [
        ! "to": "ON",
        ! "pt": "msg",
        ! "tot": "str",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 510,
        ! "y": 740,
        ! "wires": [
        ! "5225203f.c042e",
        ! "4f563911.a27008"
        ! "id": "308450ee.e04a3",
        ! "type": "change",
        ! "rules": [
        ! "to": "false",
        ! "pt": "msg",
        ! "tot": "bool",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 690,
        ! "y": 900,
        ! "wires": [
        ! "4e69bcf4.618784"
        ! "id": "7e3b61f2.6e1c",
        ! "type": "change",
        ! "rules": [
        ! "to": "true",
        ! "pt": "msg",
        ! "tot": "bool",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 690,
        ! "y": 860,
        ! "wires": [
        ! "4e69bcf4.618784"
        ! "id": "f9b2a16e.21bbc",
        ! "name": "Garten Weihnachtsbeleuchtung_Aussen Status",
        ! "topic": "node-red.0.Garten.Weihnachtsbeleuchtung_Aussen.Status",
        ! "onlyack": "",
        ! "func": "all",
        ! "gap": "",
        ! "x": 200,
        ! "y": 960,
        ! "wires": [
        ! "85b9a76e.ece228"
        ! "id": "cb325299.ac71a",
        ! "type": "rbe",
        ! "name": "",
        ! "func": "rbe",
        ! "gap": "",
        ! "start": "",
        ! "inout": "out",
        ! "x": 390,
        ! "y": 900,
        ! "wires": [
        ! "e43411c8.15f62"
        ! "id": "85b9a76e.ece228",
        ! "type": "switch",
        ! "name": "",
        ! "rules": [
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "true"
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "false"
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 370,
        ! "y": 1000,
        ! "wires": [
        ! "c7dc5ba7.4cac78"
        ! "1ac2081c.aae238"
        ! "id": "a2bde8a.35ec518",
        ! "name": "",
        ! "topic": "cmnd/Weihnachtsbeleuchtung_Aussen/POWER",
        ! "qos": "",
        ! "retain": "",
        ! "x": 960,
        ! "y": 1040,
        ! "wires": []
        ! "id": "1d0b0f26.155701",
        ! "name": "",
        ! "topic": " stat/Weihnachtsbeleuchtung_Aussen/POWER",
        ! "qos": "2",
        ! "x": 190,
        ! "y": 840,
        ! "wires": [
        ! "cb325299.ac71a"
        ! "id": "1ac2081c.aae238",
        ! "type": "change",
        ! "rules": [
        ! "to": "OFF",
        ! "pt": "msg",
        ! "tot": "str",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 530,
        ! "y": 1020,
        ! "wires": [
        ! "a2bde8a.35ec518",
        ! "f062041d.3862f8"
        ! "id": "e43411c8.15f62",
        ! "type": "switch",
        ! "name": "",
        ! "rules": [
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "ON"
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "OFF"
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 550,
        ! "y": 880,
        ! "wires": [
        ! "7e3b61f2.6e1c"
        ! "308450ee.e04a3"
        ! "id": "f062041d.3862f8",
        ! "name": "Weihnachtsbeleuchtung Garten",
        ! "label": "Weihnachtsbeleuchtung Garten",
        ! "tooltip": "",
        ! "order": 0,
        ! "width": 0,
        ! "height": 0,
        ! "topic": "",
        ! "style": "",
        ! "onvalue": "ON",
        ! "onicon": "",
        ! "oncolor": "",
        ! "officon": "",
        ! "offcolor": "",
        ! "x": 870,
        ! "y": 980,
        ! "wires": [
        ! "e43411c8.15f62"
        ! "id": "c7dc5ba7.4cac78",
        ! "type": "change",
        ! "rules": [
        ! "to": "ON",
        ! "pt": "msg",
        ! "tot": "str",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 530,
        ! "y": 980,
        ! "wires": [
        ! "f062041d.3862f8"
        ! "id": "4e69bcf4.618784",
        ! "name": "Weihnachtsbeleuchtung_Aussen",
        ! "ack": "true",
        ! "x": 980,
        ! "y": 880,
        ! "wires": []
        ! "id": "d1375045.55b3a",
        ! "type": "change",
        ! "rules": [
        ! "to": "ON",
        ! "pt": "msg",
        ! "tot": "str",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 500,
        ! "y": 180,
        ! "wires": [
        ! "9705cc8d.6d55f",
        ! "a96e289d.318318"
        ! "id": "4c6ded0.8b59d14",
        ! "type": "change",
        ! "rules": [
        ! "to": "true",
        ! "pt": "msg",
        ! "tot": "bool",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 670,
        ! "y": 60,
        ! "wires": [
        ! "a02b2763.bd2188"
        ! "id": "f78d9cd9.91e54",
        ! "name": "",
        ! "topic": "stat/Wasserfall/POWER",
        ! "qos": "2",
        ! "x": 160,
        ! "y": 80,
        ! "wires": [
        ! "81a622be.26188"
        ! "id": "cf684af9.daf458",
        ! "type": "change",
        ! "rules": [
        ! "to": "OFF",
        ! "pt": "msg",
        ! "tot": "str",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 510,
        ! "y": 240,
        ! "wires": [
        ! "9705cc8d.6d55f",
        ! "a96e289d.318318"
        ! "id": "17f40c5f.0b9864",
        ! "type": "switch",
        ! "name": "",
        ! "rules": [
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "ON"
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "OFF"
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 510,
        ! "y": 80,
        ! "wires": [
        ! "4c6ded0.8b59d14"
        ! "b03c6f97.c13cc"
        ! "id": "43daa3b1.755f2c",
        ! "type": "switch",
        ! "name": "",
        ! "rules": [
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "true"
        ! "vt": "str",
        ! "t": "eq",
        ! "v": "false"
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 350,
        ! "y": 200,
        ! "wires": [
        ! "d1375045.55b3a"
        ! "cf684af9.daf458"
        ! "id": "b03c6f97.c13cc",
        ! "type": "change",
        ! "rules": [
        ! "to": "false",
        ! "pt": "msg",
        ! "tot": "bool",
        ! "p": "payload",
        ! "t": "set"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 670,
        ! "y": 100,
        ! "wires": [
        ! "a02b2763.bd2188"
        ! "id": "abc7c951.3a6cf8",
        ! "name": "Garten Wasserfall Status",
        ! "topic": "node-red.0.Garten.Wasserfall.Status",
        ! "onlyack": "",
        ! "func": "all",
        ! "gap": "",
        ! "x": 170,
        ! "y": 200,
        ! "wires": [
        ! "43daa3b1.755f2c"
        ! "id": "81a622be.26188",
        ! "type": "rbe",
        ! "name": "",
        ! "func": "rbe",
        ! "gap": "",
        ! "start": "",
        ! "inout": "out",
        ! "x": 350,
        ! "y": 80,
        ! "wires": [
        ! "17f40c5f.0b9864"
        ! "id": "a02b2763.bd2188",
        ! "ack": "true",
        ! "x": 930,
        ! "y": 60,
        ! "wires": []
        ! "id": "a96e289d.318318",
        ! "name": "",
        ! "topic": "cmnd/Wasserfall/POWER",
        ! "qos": "",
        ! "retain": "",
        ! "x": 990,
        ! "y": 200,
        ! "wires": []
        ! "id": "9705cc8d.6d55f",
        ! "name": "Wasserfall",
        ! "label": "Wasserfall",
        ! "order": 0,
        ! "width": 0,
        ! "height": 0,
        ! "topic": "",
        ! "style": "",
        ! "onvalue": "ON",
        ! "onicon": "",
        ! "oncolor": "",
        ! "officon": "",
        ! "offcolor": "",
        ! "x": 730,
        ! "y": 160,
        ! "wires": [
        ! "17f40c5f.0b9864",
        ! "a96e289d.318318"
        ! "id": "eb2d516a.e00a6",
        ! "type": "ui_group",
        ! "z": "",
        ! "name": "Garten",
        ! "tab": "ffe253ce.b2d8d",
        ! "order": 1,
        ! "disp": true,
        ! "width": "6",
        ! "collapse": false
        ! "id": "f3965353.7f1dd",
        ! "type": "mqtt-broker",
        ! "z": "",
        ! "name": "",
        ! "broker": "192.168.178.50",
        ! "port": "1883",
        ! "clientid": "",
        ! "usetls": false,
        ! "compatmode": true,
        ! "keepalive": "60",
        ! "cleansession": true,
        ! "birthTopic": "",
        ! "birthQos": "0",
        ! "birthPayload": "",
        ! "closeTopic": "",
        ! "closePayload": "",
        ! "willTopic": "",
        ! "willQos": "0",
        ! "willPayload": ""
        ! "id": "ffe253ce.b2d8d",
        ! "type": "ui_tab",
        ! "z": "",
        ! "name": "Sonoff Steckdosen",
        ! "icon": "dashboard",
        ! "order": 2
          Sieht ja lustig aus der Flow :lol: Aber alles gut wenn er läuft !
          Was heist "aus der Ferne" für dich?
          Wo soll denn der Schaltbefehl für die Tuya herkommen (mqtt ?, gibt es da bereits einen ioBroker-State?
          OT:
          In deinem Flow ist mir spontan aufgefallen, wie du die nodes reduzieren kannst. Aber wie gesagt, wenns läuft…
          • Z
            Aktuell habe ich hier ein Dashboard von Node-Red wo die Flows von weiter Oben drin sind.
            http://prntscr.com/lwnztj
            und hier würde ich dann gerne noch die anderen Steckdosen mit einbauen, die Steckdosen haben leider keinen MQTT daher nutze ich den Tuya adapter auf Iobroker…
              Ok, habe kapiert.
              Das sollte nun ganz einfach sein. Du brauchst den iobroker-in-node, den dashboard-switch-node und den iobroker-out-node
              Läuft bei mir genauso.
              • Z
                Danke dir für deine hilfe aber leider schaltet er die Steckdose nicht 😞
                ! "id": "8bd0bbda.d50458",
                ! "type": "tab",
                ! "label": "Tuya Steckdosen",
                ! "info": ""
                ! "id": "743fe240.fd441c",
                ! "z": "8bd0bbda.d50458",
                ! "name": "Terrarium",
                ! "topic": "tuya.0.18122702600194bfdf46.1",
                ! "onlyack": "",
                ! "func": "all",
                ! "gap": "",
                ! "x": 260,
                ! "y": 120,
                ! "wires": [
                ! "b514ae96.41fd1"
                ! "id": "b514ae96.41fd1",
                ! "label": "Terrarium",
                ! "tooltip": "",
                ! "group": "432076dd.0d7eb8",
                ! "order": 0,
                ! "width": 0,
                ! "height": 0,
                ! "decouple": "true",
                ! "topic": "",
                ! "style": "",
                ! "onvalue": "true",
                ! "onicon": "",
                ! "oncolor": "",
                ! "offvalue": "false",
                ! "officon": "",
                ! "offcolor": "",
                ! "x": 480,
                ! "y": 120,
                ! "wires": [
                ! "c7d6e80e.33b1d8"
                ! "id": "c7d6e80e.33b1d8",
                ! "ack": "true",
                ! "autoCreate": "false",
                ! "x": 680,
                ! "y": 120,
                ! "wires": []
                ! "id": "432076dd.0d7eb8",
                ! "z": "",
                ! "name": "Wohnzimmer",
                ! "tab": "8885684e.b04d58",
                ! "disp": true,
                ! "width": "6",
                ! "collapse": false
                ! "id": "8885684e.b04d58",
                ! "type": "ui_tab",
                ! "z": "",
                ! "name": "Tuya Steckdosen",
                ! "order": 3
                edit:
                Habe den Fehler gefunden… nun schaltet er sauber 😄 Danke dir recht herzlich
                Andere Frage?
                kann ich mir den Stromverbrauch anzeigen lassen?
                  Klar doch. Vorausgesetzt du hast einen power state deiner Steckdose im tuya-Adapter.
                  Dann geht das wie folgt:
                  ioBroker-in (tuya.0.xxxxx.power) -> change-node payload bei bedarf in deine Anzeige-einheit konvertieren -> dashboard-text-node zum anzeigen
                  • Z
                    Schade da bekomme ich keine Ausgabe angezeigt 😕
                    das habe ich schon mehrmals versucht aber irgendwie habe ich es bis heute nicht verstanden 😞
                      Häng doch mal einen Debug-node an den iobroker-in-Node und poste mal wie das Objekt aussieht was das ausgeben wird.
                      • Z
                        wie mache ich das?
                        http://prntscr.com/lwph5r
                          Oh weh 😉 Wenn du dir da mal nicht zuviel zumutest. Na, wer A sagt…
                          Also, wenn dein power-state Daten produziert, sollten die über den debug-node (1) im debug-panel (2) auflaufen (3). natürlich nur, wenn sich Daten ändern.
                          Falls da Daten einlaufen, kann man sie auch darstellen.
                          • Z
                            Ok,
                            er Zeigt mir im Debug fenstern an was an Watt verbraucht wird, nun muss ich das nur noch im Node-Red Dashboard angezeigt bekommen 😄
                              Poste mal wie die debug Ausgabe aussieht.
                              • Z
                                So ich habe nun die Anzeige hinbekommen das er mir sagt wie der aktuelle Watt Verbrauch ist falls ich mich nicht irre aber nun muss ich das noch in kw/h ausgeben lassen 😞
                                http://prntscr.com/lwq5d7
                                  Na also, geht doch[emoji3]
                                  @Zerpmaster:
                                  So ich habe nun die Anzeige hinbekommen das er mir sagt wie der aktuelle Watt Verbrauch ist falls ich mich nicht irre aber nun muss ich das noch in kw/h ausgeben lassen 😞 `
                                  Da solltest du hier im Forum mal schauen. Ich glaube, das hat grad jemand mit einem Script gebastelt. Vlt kannst du das mit einen Funktion-Node einbinden.
                                  • Z
                                    Ich habe da doch noch eine frage oder ein Problem.
                                    Wenn ich das Terrarium per Kalender Ein schalten lassen Zeigt mir mein Dashboard nicht an das es Eingeschaltet ist.
                                    Bild 1:
                                    In diesen Bild ist der Schalter vom Terrarium aus aber das Terrarium ist an.
                                    http://prntscr.com/lwxova
                                    Hier ist das Node-Red Script.
                                    ! "id": "550e3807.3d7688",
                                    ! "type": "comment",
                                    ! "name": "Tuya SP 22 Steckdosen Wohnzimmer ",
                                    ! "info": "",
                                    ! "x": 337.01734924316406,
                                    ! "y": 55.010414123535156,
                                    ! "wires": []
                                      Da hast du nur ein Kommentar-node gepostete. Das passiert leicht, wenn man beim Export aus "Selected Nodes" stehen hat und nur ein Node markiert ist. Ist mir auch schon öfter passiert.
                                      Entweder noch mal vergewissern, dass man ALLE gewünschten Nodes markiert hat, bevor man exportiert, oder den ganzen flow exportieren,
                                      Exportiere noch mal ganzen flow.
                                      • Z
                                        ! "type": "tab",
                                        ! "info": ""
                                        ! "onlyack": "",
                                        ! "func": "all",
                                        ! "gap": "",
                                        ! "x": 140,
                                        ! "y": 120,
                                        ! "wires": [
                                        ! "b514ae96.41fd1"
                                        ! "tooltip": "",
                                        ! "order": 0,
                                        ! "width": 0,
                                        ! "height": 0,
                                        ! "topic": "",
                                        ! "style": "",
                                        ! "onicon": "",
                                        ! "oncolor": "",
                                        ! "officon": "",
                                        ! "offcolor": "",
                                        ! "x": 480,
                                        ! "y": 100,
                                        ! "wires": [
                                        ! "c7d6e80e.33b1d8"
                                        ! "ack": "false",
                                        ! "x": 680,
                                        ! "y": 120,
                                        ! "wires": []
                                        ! "info": "",
                                        ! "wires": []
                                        ! "id": "40b7a40.9b9135c",
                                        ! "name": "Weihnachtsbaum",
                                        ! "topic": "tuya.0.18122702600194bff221.1",
                                        ! "onlyack": "",
                                        ! "func": "all",
                                        ! "gap": "",
                                        ! "x": 140,
                                        ! "y": 220,
                                        ! "wires": [
                                        ! "40fc8285.63b15c"
                                        ! "id": "40fc8285.63b15c",
                                        ! "label": "Weihnachtsbaum",
                                        ! "tooltip": "",
                                        ! "order": 0,
                                        ! "width": 0,
                                        ! "height": 0,
                                        ! "topic": "",
                                        ! "style": "",
                                        ! "onicon": "",
                                        ! "oncolor": "",
                                        ! "officon": "",
                                        ! "offcolor": "",
                                        ! "x": 510,
                                        ! "y": 220,
                                        ! "wires": [
                                        ! "4f766617.b40318"
                                        ! "id": "4f766617.b40318",
                                        ! "ack": "false",
                                        ! "x": 730,
                                        ! "y": 220,
                                        ! "wires": []
                                        ! "z": "",
                                        ! "disp": true,
                                        ! "width": "6",
                                        ! "collapse": false
                                        ! "type": "ui_tab",
                                        ! "z": "",
                                        ! "name": "Steckdosen Haus",
                                        ! "order": 3
                                        so sorry
                                          Sieht eigentlich alles richtig aus.
                                          Welcher Kalender? Wie schaltet denn der Kalender die Steckdose? Kann mir eigentlich nur denken, dass der state nicht gesetzt wird.
                                          Häng doch mal den debug-node an den iobroker-in-node und lass per Kalender schalten. Dann kannst du sehen, on und wenn ja welches Signal am state anliegt.
                                          2967
