    4. [Aufruf] fullyBrowser Adapter
    • Chaot
      Chaot last edited by
      Ich bin wieder auf die alte Versin zurückgekommen.
      Trotz Fehlermeldung bei der Installation scheint es geklappt zu haben:
      iobroker	2018-12-16 14:49:10.786	info	exit 0
      iobroker	2018-12-16 14:49:10.775	info	Adapter "fullyBrowser" updated
      iobroker	2018-12-16 14:49:10.716	info	upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png
      iobroker	2018-12-16 14:49:10.656	info	upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html
      iobroker	2018-12-16 14:49:10.595	info	upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html
      iobroker	2018-12-16 14:49:10.524	info	upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript
      iobroker	2018-12-16 14:49:10.509	info	got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin
      iobroker	2018-12-16 14:49:10.401	info	npm notice created a lockfile as package-lock.json. You should commit this file.
      iobroker	2018-12-16 14:49:03.908	info	npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      iobroker	2018-12-16 14:49:03.650	info	WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      iobroker	2018-12-16 14:49:03.648	info	npm
      iobroker	2018-12-16 14:49:01.901	info	npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      iobroker	2018-12-16 14:49:00.162	info	npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      iobroker	2018-12-16 14:48:58.410	info	npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      iobroker	2018-12-16 14:48:54.436	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullyBrowser"
      iobroker	2018-12-16 14:48:54.407	info	npm ERR! /root/.npm/_logs/2018-12-16T13_48_54_389Z-debug.log
      iobroker	2018-12-16 14:48:54.407	info	npm ERR! A complete log of this run can be found in:
      iobroker	2018-12-16 14:48:54.386	info	npm ERR! 404 Not Found: iobroker.fullyBrowser@0.0.6
      iobroker	2018-12-16 14:48:54.383	info	ERR! code E404
      iobroker	2018-12-16 14:48:54.382	info	npm
      iobroker	2018-12-16 14:48:37.235	info	npm install iobroker.fullyBrowser@0.0.6 --production --save --prefix "/opt/iobroker" (System call)
      iobroker	2018-12-16 14:48:36.785	info	NPM version: 6.4.1
      iobroker	2018-12-16 14:48:36.299	info	Update fullyBrowser from @0.0.6 to @0.0.6
      iobroker	2018-12-16 14:48:35.115	info	upgrade fullyBrowser@0.0.6
      • Chaot
        @kaschperle83:
        Was macht der Adapter denn bzw wofür ist er?
        Gesendet aus Hessen. `
        Wenn du VIS über ein Tablet betreibst wird meist der FullyKiok Browser verwendet um VIS darzustellen.
        Damit lassen sich aber noch viele andere Aufgaben erledigen:
        Bildschirmschoner steuern
        Helligkeit regeln
        Akkustand auslesen (zum laden).
        Bisher habe ich den Fully Browser verwendet und zusätzlich den PAW Adapter. In der neuen Variante fällt für mich der PAW Adapter weg.
        Allerdings ist der Fully Browser nicht kostenfrei. Der Entwickler möchte 5 € dafür haben. Ich persönlich finde das aber angemessen.
        • eric2905
          eric2905 last edited by
          Die 5€ sind es wirklich wert … der Browser ist gut.
          Vor allen Dingen die Bewegungserkennung über die Frontkamera zum aktivieren der Anzeige.
          Gruß,
          Eric
          Von unterwegs getippert
          • Chaot
            Ok,
            keine Funktion mehr möglich.
            Das Backup von heute morgen wird gerade zurückgespielt…..
              andyb last edited by
              Gerade installiert, läuft. Klasse Arbeit. Danke
                @Chaot:
                Ok,
                Das Backup von heute morgen wird gerade zurückgespielt….. `
                installiere den Adapter ganz normal der ist jetzt auch in der Version 0.0.7 über npm Verfügbar..
                  Kueppert last edited by
                  @arteck:
                  @Chaot:
                  Ok,
                  installiere den Adapter ganz normal der ist jetzt auch in der Version 0.0.7 über npm Verfügbar..Update bricht bei mir mit Fehlermeldung ab… Kann die Meldung nachliefern 😞
                  anbei die Fehlermeldungen:
                  ! $ ./iobroker upgrade fullyBrowser Update fullyBrowser from @0.0.6 to @0.0.7 NPM version: 6.1.0 npm install iobroker.fullyBrowser@0.0.7 --production --save --prefix "/opt/iobroker" (System call) npm ERR! code E404 npm ERR! 404 Not Found: iobroker.fullyBrowser@0.0.7 npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-12-17T16_16_17_468Z-debug.log ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullyBrowser" got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript Adapter "system.adapter.fullyBrowser.0" restarted. upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png Adapter "fullyBrowser" updated process exited with code 0
                    broker100 last edited by
                    habe jetzt zum Test auch mal den Adapter 0.0.7 installiert.
                    Hat soweit auch geklappt. Status LED auch grün.
                    Nur einstellen kann ich nichts, Problem ist wahrscheinlich das "Is Fully Browser Alive? " immer auf false steht.
                    Ich habe noch nicht die Vollversion, könnte es daran liegen?
                    erledigt, wer lesen kann ist klar im Vorteil 🙂
                    • Chaot
                      Mal ne ganz blöde Frage.
                      Wie kann ich denn einen Button aus einem script ansteuern?
                      Irgendwie komme ich mit dem Akku laden nicht mehr nach. Deshalb würde ich gerne die Screen per script schalten.
                      Aber da klemmts irgendwie. So richtige Hinweise finde ich da auch nirgendwo dazu.
                        @Chaot:
                        Aber da klemmts irgendwie. So richtige Hinweise finde ich da auch nirgendwo dazu. `
                        wofür schreiben wir https://github.com/arteck/iobroker.fullybrowser/wiki
                          @Kueppert:
                          @arteck:
                          @Chaot:
                          Ok,
                          NPM version: 6.1.0
                          npm ERR! code E404
                          ahh ich habs.. im RepoList ist noch ein falschern Namen `  `  `
                            mctom last edited by
                            ich habe es so gelöst:
                            setState('fullybrowser.0.192_168_2_18.Commands.screenOff'/*screenOn*/,true);
                            Michael
                              Manolo last edited by
                              Habe nun das Script auch durch den Adapter entfernt. Große Unterschiede gibt es ja nicht, außer dass keine Fehler mehr im Log angezeigt werden.
                              Ansonsten läuft alles wie gehabt.
                              Mit dem Motion Detector komme ich aber leider nicht klar. Egal was ich einstelle, der Bildschirm macht was er will.
                              @ilovegym:
                              Cool ist, dass man auch den Bewegungssensor auslesen kann… wenn also mal ein Tablet von der Wand fällt... :roll: :mrgreen: kann ich mir ne TelegramMsg schicken lassen und gleich über Alexa ein neues bestellen lassen.. :lol: :lol: `
                              Welcher Datenpunkt zeigt denn die Info für Bewegungserkennung? Ich finde nur den Status (motionDetectorState), der zeigt aber nur an ob der Motion Detector in den Einstellungen aktiviert ist. Die Auswertung einer Bewegung konnte ich bisher nirgends finden.
                              Gibt es eine Möglichkeit den Namen unter Objekte zu ändern? Bei den IP Adressen muss ich immer schauen wo das Tab hängt.
                              Ansonsten, tolle Arbeit! Vielen Dank für diesen Adapter.
                              Gruß Manolo
                              • 0
                                0018 last edited by
                                Gibt es irgendwelche Voraussetzungen damit der Daydream funktioniert? Bei mir klappt soweit alles bis auf den Daydream.
                                • Chaot
                                  @arteck:
                                  @Chaot:
                                  wofür schreiben wir https://github.com/arteck/iobroker.fullybrowser/wiki `
                                  Da habe ich mich scheinbar falsch ausgedrückt.
                                  Die Dokus kenne ich ja alle.
                                  Aber für mich stellt sich die Frage wie ich den Button unter "Objekte" bedienen kann.
                                  Einen Schalter mit Status True/false kann ich ja per JScript schalten, aber ich finde nichts wie ich den Button bedienen kann.
                                  Ich finde da weder in Blockly oder in JS etwas (oder ich bin zu blöd zum Suchen).
                                    @Chaot:
                                    @arteck:
                                    @Chaot:
                                    Ich finde da weder in Blockly oder in JS etwas (oder ich bin zu blöd zum Suchen). `
                                    na genau so.. ein Schalter ist ein Button nur das dieser automatisch auf false zurückspringt
                                    • Chaot
                                      :oops: :oops: :oops:
                                      Ach so!
                                      Und ich habe so kompliziert um die Ecke gedacht 😮
                                      Danke schön.
                                      Ich bin übrigens aktuell noch auf der Version 0.6. Die 0.7 wurde mir mal kurz angeboten und scheint jetzt wieder weg zu sein.
                                      (Verwahrorte: default und latest)
                                        @Chaot:
                                        Ach so!
                                        Danke schön.
                                        (Verwahrorte: default und latest) `
                                        die 0.0.7 müsste über Katze und GIT gehen… ahh ich musste den Namen ändern ... am besten den alten Adapter löschen und neu installieren
                                        der Adapter heisst jetzt fullybrowser und nicht mehr fullyBrowser..
                                        denkt drann die Scripte zu ändern..
                                        • Chaot
                                          alten Adapter deinstalliert, neuen "versucht"
                                          Wie gehabt:
                                          host.haus	2018-12-21 12:51:02.140	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
                                          javascript.0	2018-12-21 12:50:03.136	error	script.js.Wandtablet.Laden2: Fehler request: Error: connect EHOSTUNREACH 192.168.8.225:2323
                                          host.haus	2018-12-21 12:50:03.090	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                                          host.haus	2018-12-21 12:50:00.089	info	instance system.adapter.tvspielfilm.0 started with pid 4299
                                          host.haus	2018-12-21 12:50:00.053	info	instance system.adapter.dwd.0 started with pid 4294
                                          host.haus	2018-12-21 12:49:50.215	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                          iobroker	2018-12-21 12:49:49.929	info	exit 0
                                          iobroker	2018-12-21 12:49:49.906	error	Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                                          iobroker	2018-12-21 12:49:49.808	info
                                          iobroker	2018-12-21 12:49:49.806	info	WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                          iobroker	2018-12-21 12:49:49.804	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm
                                          iobroker	2018-12-21 12:49:49.803	info	svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0
                                          iobroker	2018-12-21 12:49:49.801	info	npm WARN
                                          iobroker	2018-12-21 12:48:30.197	info	npm install https://github.com/arteck/iobroker.fullyBrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                                          iobroker	2018-12-21 12:48:29.584	info	install https://github.com/arteck/iobroker.fullyBrowser/tarball/master
                                          iobroker	2018-12-21 12:48:29.096	info	url "https://github.com/arteck/iobroker.fullyBrowser"
                                          Fehlermeldung bei der Installation:
                                          $ ./iobroker url "https://github.com/arteck/iobroker.fullyBrowser"
                                          npm
                                           WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
                                          npm
                                           WARN
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                          ERROR: Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                                            @Chaot:
                                            Wie gehabt:
                                            npm
                                            npm
                                             WARN
                                            du musst über die Katze gehen… da ist noch ein Fehler in den benamsung..
                                            bei dir ist da B vom Browser gross geschrieben... das ist falsch
                                            fullybrowser fullybrowser adapter
                                            45
                                            289
                                            43565
