    4. Installation ioBroker auf Cubietruck
      aktueller Stand nach update und git pull:
      system.adapter.admin.0 steigt weiter mit Code 8 aus, der Rest (hm-Rega.0 und .1 und hm-rpc.0 und.1 laufen) anscheinend.
      neue adapter sind eingespielt, nur ohne admin kann ich es nicht überprüfen 😞
      Habe nochmals npm install –production durchlaufen lassen, diesmal mit folgender Fehlermeldung:
      root@cubie:/opt/iobroker# npm install --production
      npm WARN package.json daemonize2@0.4.2 No repository field.
      npm http GET https://registry.npmjs.org/node-windows
      npm http GET https://registry.npmjs.org/hiredis
      npm http GET https://github.com/hobbyquaker/node-schedule/tarball/master
      npm http 304 https://registry.npmjs.org/node-windows
      npm http 304 https://registry.npmjs.org/hiredis
      npm http 200 https://github.com/hobbyquaker/node-schedule/tarball/master
      npm WARN optional dep failed, continuing node-windows@0.1.5
      npm http GET https://registry.npmjs.org/nan
      npm http GET https://registry.npmjs.org/bindings
      npm http 304 https://registry.npmjs.org/nan
      npm http 304 https://registry.npmjs.org/bindings
      > hiredis@0.1.17 install /opt/iobroker/node_modules/hiredis
      > node-gyp rebuild
      make: Entering directory `/opt/iobroker/node_modules/hiredis/build'
        CC(target) Release/obj.target/hiredis/deps/hiredis/hiredis.o
      make: cc: Command not found
      make: *** [Release/obj.target/hiredis/deps/hiredis/hiredis.o] Error 127
      make: Leaving directory `/opt/iobroker/node_modules/hiredis/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
      gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
      gyp ERR! System Linux 3.4.101-sun7i+
      gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/hiredis
      gyp ERR! node -v v0.10.22
      gyp ERR! node-gyp -v v0.11.0
      gyp ERR! not ok
      npm WARN optional dep failed, continuing hiredis@0.1.17
      Viel Glück
      Rainer
      EDIT:
      Habe den admin-Adapter gelöscht mit ./iobroker del admin.
      kamen folgende Fehlermeldungen:
      root@cubie:/opt/iobroker# ./iobroker del admin
      { [Error: missing]
        scope: 'couch',
        status_code: 404,
        'status-code': 404,
        request:
         { method: 'GET',
           headers:
            { 'content-type': 'application/json',
              accept: 'application/json' },
           uri: 'http://localhost:5984/iobroker/_design/admin/_view/state',
           jar: false },
        headers:
         { date: 'Fri, 22 Aug 2014 18:44:03 GMT',
           'cache-control': 'must-revalidate',
           'status-code': 404,
           uri: 'http://localhost:5984/iobroker/_design/admin/_view/state' },
        errid: 'non_200',
        error: 'not_found',
        reason: 'missing',
        description: 'missing',
        stacktrace:
         [ 'Error: missing',
           '    at Request._callback (/opt/iobroker/node_modules/nano/nano.js:319:39)',
           '    at Request.self.callback (/opt/iobroker/node_modules/nano/node_modules/request/request.js:122:22)',
           '    at Request.EventEmitter.emit (events.js:98:17)',
           '    at Request. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:888:14)',
           '    at Request.EventEmitter.emit (events.js:117:20)',
           '    at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:839:12)',
           '    at IncomingMessage.EventEmitter.emit (events.js:117:20)',
           '    at _stream_readable.js:920:16',
           '    at process._tickCallback (node.js:415:13)' ] }
      deleted 5 instances of admin
      delete /opt/iobroker/adapter/admin
      deleted 11 adapters for admin
      deleted 2 system.states of admin</anonymous></anonymous>
      Nach Neuinstallation ./iobroker add admin läuft jetzt das WebUI wieder!!
        Trident last edited by
        Auch bei mir nun kein Code 8 mehr.
        Im Log steht auch, dass variable und räume etc. Gesynct wurden!
        Jedoch sehe ich im Web-Admin noch keine States !
        Viele Grüße
        Trident
        • Bluefox
          Bluefox last edited by
          gyp ERR! not ok
          Das hier ist nicht schlimm. Es gibt zwei Nöglichkeiten, wie man aus redis die Daten liest:
          • Über RestAPI (http://127.0.0.1/redis/get/system.admin) oder
          • Über Native C Kode - Redis API.
          Hiredis ist RedisAPI und ist nicht zwingend erforderlich für die Kommunikation mit Redis. Es sollte schneller sein, als RestFULL, aber für unsere Applikation ist nicht erforderlich.
          Unter Windows gibt es auch keine Möglichkeit Hiredis zu übersetzen.
          { [Error: missing]
            scope: 'couch',
            status_code: 404,
            'status-code': 404,
            request:
             { method: 'GET',
               headers:
               jar: false },
            headers:
               'status-code': 404,
            errid: 'non_200',
            error: 'not_found',
            reason: 'missing',
            stacktrace:
             [ 'Error: missing',
          Diese Fehlermeldung ist auch gefixt. Danke ans Melden. Da war Fehler drin.
          • Bluefox
            @Trident:
            Viele Grüße
            Trident `
            Läuft bei dir DashUI? Will nur ausschließen, das es nicht grundsätzliches Problem mit WebSockets ist.
              Hi Bluefox,
              auf meinem Cubietruck habe das bisher noch nicht getestet. Kann ich gerne heute Abend machen und Feedback geben. Ich gehe davon aus, dass die Installation mit "./iobroker add adapter …" funktioniert?
              Meine derzeitige "operative" CCU.IO Installation liegt nicht auf dem Cubie sondern auf meinem "alten" Raspi - daher kann ich das spontan nicht beantworten.
              Ich werde heute Abend ein bisschen testen und mich nochmal melden!
              Viele Grüße
              Trident
                leider habe ich mit meinem testen wohl die Installation nachhaltig zerschossen. Es kommt jetzt Immer ein Code 1 beim Start der Adapter. Eine einfache Neuinstallation hat das Problem nicht behoben.
                ` > 2014-08-26 21:00:29.274 - error: controller instance system.adapter.admin.0 terminated with code 1
                2014-08-26 21:00:58.098 - info: controller instance system.adapter.hm-rpc.0 started with pid 6524
                2014-08-26 21:00:59.301 - info: controller instance system.adapter.admin.0 started with pid 6528
                2014-08-26 21:01:04.256 - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                2014-08-26 21:01:07.238 - error: controller instance system.adapter.admin.0 terminated with code 1
                2014-08-26 21:01:34.275 - info: controller instance system.adapter.hm-rpc.0 started with pid 6547
                2014-08-26 21:01:37.254 - info: controller instance system.adapter.admin.0 started with pid 6549
                2014-08-26 21:01:37.598 - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                2014-08-26 21:01:43.317 - error: controller instance system.adapter.admin.0 terminated with code 1
                2014-08-26 21:01:48.506 - info: controller object change system.adapter.admin.0 `
                Ich werde die Tage in Ruhe nochmal ganz von vorne anfangen 😉
                Viele Grüße
                Trident
                  Kurze Ergänzung: Bei der Neuinstallation und dem Command "npm install –production" kam der folgende Auszug (Teil mit der Warnung):
                  npm http 304 https://registry.npmjs.org/oauth-sign
                  npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
                  npm http GET https://registry.npmjs.org/combined-stream
                  npm http 304 https://registry.npmjs.org/combined-stream
                  npm http GET https://registry.npmjs.org/delayed-stream/0.0.5
                  npm http 304 https://registry.npmjs.org/delayed-stream/0.0.5
                  npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
                  npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
                  npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
                  npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
                  Der Rest lief (zumindest was die Anzeigen angeht) gut durch. Vielleicht ist es ja interessant…
                  Viele Grüße
                  Trident
                  Edit: Nach der Installation wieder das "Code 8" Problem...
                  Edit 2: Scheinbar habe ich noch "Reste" der alten Installation ... Er gibt nun folgende Meldung im Log:
                  2014-08-26 21:52:32.704  - warn: controller stopInstance system.adapter.hm-rpc.0 not running
                  2014-08-26 21:52:42.716  - info: controller force terminated after 10s
                  2014-08-26 21:52:49.019  - info: ioBroker.nodejs version 0.0.16 io.controller starting
                  2014-08-26 21:52:49.036  - info: Copyright (c) 2014 hobbyquaker, bluefox
                  2014-08-26 21:52:49.038  - info: controller hostname: cubie
                  2014-08-26 21:52:49.038  - info: controller ip addresses: xxx.xxx.xxx.xx yyy
                  2014-08-26 21:52:51.743  - info: controller 3 instances found
                  2014-08-26 21:52:51.747  - info: controller starting 3 instances
                  2014-08-26 21:52:51.783  - info: controller instance system.adapter.admin.0 started with pid 3005
                  2014-08-26 21:52:52.449  - error: controller instance system.adapter.admin.0 terminated with code 8
                  2014-08-26 21:52:55.778  - info: controller instance system.adapter.admin.1 started with pid 3008
                  2014-08-26 21:52:56.282  - error: controller instance system.adapter.admin.1 terminated with code 8
                  2014-08-26 21:52:59.773  - info: controller instance system.adapter.hm-rpc.0 started with pid 3010
                  2014-08-26 21:53:00.199  - error: controller instance system.adapter.hm-rpc.0 terminated with code 8
                  2014-08-26 21:53:22.474  - info: controller instance system.adapter.admin.0 started with pid 3013
                  2014-08-26 21:53:22.985  - error: controller instance system.adapter.admin.0 terminated with code 8
                  2014-08-26 21:53:26.308  - info: controller instance system.adapter.admin.1 started with pid 3015
                  2014-08-26 21:53:26.798  - error: controller instance system.adapter.admin.1 terminated with code 8
                  2014-08-26 21:53:30.229  - info: controller instance system.adapter.hm-rpc.0 started with pid 3017
                  Und das nachdem ich das Verzeichnis gelöscht und genau nach Anleitung neuinstalliert habe (bis inklusive des Punkts "Install admin Adapter" –> Aber nicht weiter). Trotzdem kennt Er scheinbar noch den "alten" HM-RPC Adapter. Wahrscheinlich reicht es nicht das Verzeichnis zu löschen... Da werde noch "Reste" in der CouchDB hängen...:)
                  Das soweit von mir.
                  Schönen Abend noch!
                    Hallo Trident,
                    ich denke die Warnungen sind nicht so wild.
                    Es wird hier aufgrund des Sortieralgorithmus die Version v0.1xxxxx einfach fälschlicherweise als kleiner v0.8xxxx angesehen.
                    Die korrekte Versionierung für diese Sortierung hätte sein müssen v0.08.xxxx damit diese als kleiner als 0.10.22 erkannt wird.
                    Rainer
                      N'Abend,
                      nachdem ich die couchDB geleert habe und neuinstalliert habe nun der folgende Stand:
                      1. Das Aktivieren der Instanzen ist (zumindest in Firefox und Safari) etwas "buggy". Habe noch kein Muster erkannt, aber ich muss immer mehrfach in die Einstellungen (Bleistift links unten) und mit save bestätigen. Irgendwann startet die Instanz dann… Ausserdem bekomme ich im Firefox folgenden Fehler in der Konsole angezeigt:
                      `Error: Syntax error, unrecognized expression: [id="object_hm-rpc.meta.VALUES.HM-CC-RT-DN.CLIMATECONTROL_RECEIVER.19"[/code]`
                      2) Nach der Installation des HM-RPC Adapters läuft dieser stabil und gut durch. Aktiviere ich nun auch den HM-REGA Adapter sieht es zunächst gut aus. Das Log zeigt folgende Warnungen:
                      `~~[code]~~-08-27 21:38:56.589  - info: hm-rega.0 got 0 variables
                      2014-08-27 21:38:56.684  - warn: hm-rega.0 setObject 40 (type=state) property common.role missing!
                      2014-08-27 21:38:56.695  - warn: hm-rega.0 setObject 41 (type=state) property common.role missing!
                      2014-08-27 21:38:56.702  - warn: hm-rega.0 setObject 950 (type=state) property common.role missing!
                      2014-08-27 21:38:56.708  - warn: hm-rega.0 setObject 1233 (type=state) property common.role missing!
                      2014-08-27 21:38:56.714  - warn: hm-rega.0 setObject 1580 (type=state) property common.role missing!
                      2014-08-27 21:38:56.720  - warn: hm-rega.0 setObject 1581 (type=state) property common.role missing!
                      2014-08-27 21:38:56.729  - warn: hm-rega.0 setObject 1582 (type=state) property common.role missing!
                      2014-08-27 21:38:56.735  - warn: hm-rega.0 setObject 1914 (type=state) property common.role missing!
                      2014-08-27 21:38:56.741  - warn: hm-rega.0 setObject 2383 (type=state) property common.role missing!
                      2014-08-27 21:38:56.746  - warn: hm-rega.0 setObject 2384 (type=state) property common.role missing!
                      2014-08-27 21:38:56.752  - warn: hm-rega.0 setObject 2385 (type=state) property common.role missing!
                      2014-08-27 21:38:56.758  - warn: hm-rega.0 setObject 2434 (type=state) property common.role missing!
                      2014-08-27 21:38:56.763  - warn: hm-rega.0 setObject 2435 (type=state) property common.role missing!
                      2014-08-27 21:38:56.769  - warn: hm-rega.0 setObject 2436 (type=state) property common.role missing!
                      2014-08-27 21:38:56.774  - warn: hm-rega.0 setObject 2437 (type=state) property common.role missing!
                      2014-08-27 21:38:56.780  - warn: hm-rega.0 setObject 2438 (type=state) property common.role missing!
                      2014-08-27 21:38:56.785  - warn: hm-rega.0 setObject 2439 (type=state) property common.role missing!
                      2014-08-27 21:38:56.791  - warn: hm-rega.0 setObject 2516 (type=state) property common.role missing!
                      2014-08-27 21:38:56.796  - warn: hm-rega.0 setObject 2517 (type=state) property common.role missing!
                      2014-08-27 21:38:56.803  - warn: hm-rega.0 setObject 2594 (type=state) property common.role missing!
                      2014-08-27 21:38:56.810  - warn: hm-rega.0 setObject 2753 (type=state) property common.role missing!
                      2014-08-27 21:38:56.818  - info: hm-rega.0 added/updated 21 variables
                      2014-08-27 21:38:56.819  - info: hm-rega.0 deleted 0 variables[/code]`
                      Danach dann folgendes:
                      `~~[code]~~2014-08-27 21:40:00.044  - info: controller instance system.adapter.hm-rpc.0 started with pid 6717
                      2014-08-27 21:40:03.384  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                      2014-08-27 21:40:33.410  - info: controller instance system.adapter.hm-rpc.0 started with pid 6724
                      2014-08-27 21:40:36.869  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                      2014-08-27 21:41:06.898  - info: controller instance system.adapter.hm-rpc.0 started with pid 6730
                      2014-08-27 21:41:10.242  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                      2014-08-27 21:41:40.268  - info: controller instance system.adapter.hm-rpc.0 started with pid 6737
                      2014-08-27 21:41:43.716  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                      [/code]`
                      Der HM-RPC Adapter "verabschiedet" sich nun periodisch!
                      Vielleicht helfen euch die Infos ja!
                      Schönen Abend noch!
                      Trident
                        Hast du denn den rpc-adapter richtig konfiguriert?
                        IP deiner ccu eingetragen?
                        Rainer
                          ja, habe ich alles konfiguriert…
                          Viele Grüße
                          Trident
                            ich habe bei der rpc Instance mal den "debug" log-modus aktiviert. Hier die Ausgabe des Logs:
                            2014-08-28 21:15:31.939  - info: controller instance system.adapter.hm-rpc.0 started with pid 10076
                            2014-08-28 21:15:35.020  - debug: 4m7le3 [{"method":"GET","headers":{"content-type":"application/json","accept":"application/json"},"uri":"http://127.0.0.1:5984/iobroker"}]
                            2014-08-28 21:15:35.402  - debug: redis get system.adapter.hm-rpc.0.alive {"val":true,"ack":true,"ts":1409253335,"lc":1409253305}
                            2014-08-28 21:15:35.424  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                            Obwohl auf der Admin-Website alles richtig konfiguriert ist, scheint sich hier eine falsche IP eingeschlichen zu haben… Ich habe zumindest nirgendwo die 127.0.0.1 eingegeben.
                            Keine Ahnung, ob das so sein muss ....
                            Viele Grüße
                            Trident
                              Inzwischen hat sich wieder etwas auf der UI getan.
                              Die Update-Funktion wird angezeigt:
                              beim anklicken geht kurz ein "Terminal-Fenster" auf.
                              Wenn ich es recht gesehen habe steht da immer etwas drin was jetzt passieren soll und dann "todo" 😉
                              apropos "todo";
                              gibt es irgendetwas, wo wir euch helfen können?
                              z.B. so wie bei ccu.io: Übersetzen von Menüstrukturen; Hilfetexten (Readme=Todo)
                              Rainer
                                kleines Update von meiner Seite: Ist echt toll zuzusehen wie immer mehr Funktionen in die Web-Oberfläche einfließen. Ich habe heute eine komplette Neuinstallation gemacht (inkl. Löschung der alten CouchDB-Daten).
                                Das Admin Interface funktioniert nun unter Chrome echt gut. Ich bekomme nur leider von meinem HM-RPC Adapter immer noch diese Meldungen:
                                ` > 2014-08-31 15:37:39.725 - info: admin.0 requesting all objects
                                2014-08-31 15:37:39.767 - info: admin.0 http server listening on port 8081
                                2014-08-31 15:37:40.197 - info: admin.0 received all objects
                                2014-08-31 15:37:40.241 - info: admin.0 received all states
                                2014-08-31 15:38:43.679 - info: controller object change system.adapter.hm-rpc.0
                                2014-08-31 15:39:28.636 - info: controller object change system.adapter.hm-rpc.0
                                2014-08-31 15:39:28.661 - info: controller instance system.adapter.hm-rpc.0 started with pid 21720
                                2014-08-31 15:39:31.876 - debug: a36cn5 [{"method":"GET","headers":{"content-type":"application/json","accept":"application/json"},"uri":"http://127.0.0.1:5984/iobroker"}]
                                2014-08-31 15:39:32.264 - debug: redis get system.adapter.hm-rpc.0.alive {"val":true,"ack":true,"ts":1409492369,"lc":1409490793}
                                2014-08-31 15:39:32.292 - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                                2014-08-31 15:40:02.328 - info: controller instance system.adapter.hm-rpc.0 started with pid 21728
                                2014-08-31 15:40:05.674 - debug: gb0eca [{"method":"GET","headers":{"content-type":"application/json","accept":"application/json"},"uri":"http://127.0.0.1:5984/iobroker"}]
                                2014-08-31 15:40:06.050 - debug: redis get system.adapter.hm-rpc.0.alive {"val":true,"ack":true,"ts":1409492399,"lc":1409492384}
                                2014-08-31 15:40:06.073 - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                                2014-08-31 15:40:36.104 - info: controller instance system.adapter.hm-rpc.0 started with pid 21734
                                2014-08-31 15:40:39.205 - debug: 13e4my [{"method":"GET","headers":{"content-type":"application/json","accept":"application/json"},"uri":"http://127.0.0.1:5984/iobroker"}]
                                2014-08-31 15:40:39.493 - debug: 13e4my [{"err":null,"body":{"db_name":"iobroker","doc_count":91,"doc_del_count":0,"update_seq":162,"purge_seq":0,"compact_running":false,"disk_size":417896,"data_size":61147,"instance_start_time":"1409492099019712","disk_format_version":6,"committed_update_seq":162},"headers":{"date":"Sun, 31 Aug 2014 13:40:39 GMT","content-type":"application/json","cache-control":"must-revalidate","status-code":200,"uri":"http://127.0.0.1:5984/iobroker"}}]
                                2014-08-31 15:40:39.504 - debug: couchdb using db iobroker
                                2014-08-31 15:40:39.512 - debug: hm-rpc.0 couchdb connected
                                2014-08-31 15:40:39.537 - debug: hm-rpc.0 redis connected
                                2014-08-31 15:40:39.613 - error: controller instance system.adapter.hm-rpc.0 terminated with code 1 `
                                Vielleicht liegt es doch noch ein meiner Installation …
                                Das nur zur Info für euch!
                                Viele Grüße
                                Trident
                                  Habe gerade mal wieder etwas mit ioBroker gespielt.
                                  Updates liefen gut durch und jetzt funktionieren auch die Updatebuttons im webUI.
                                  Im parallel laufenden log habe ich folgende Meldung:
                                   2014-09-03 20:54:55.132  - info: admin.0 iobroker delete /opt/iobroker/tmp/hm-rega.zip
                                  2014-09-03 20:54:55.136  - info: admin.0 iobroker delete /opt/iobroker/tmp/ioBroker.hm-rega-master
                                  2014-09-03 20:54:55.152  - info: admin.0 iobroker copying /opt/iobroker/tmp/ioBroker.hm-rega-master to /opt/iobroker/adapter/hm-rega
                                  2014-09-03 20:54:55.240  - info: admin.0 iobroker delete /opt/iobroker/tmp/hm-rega.zip
                                  2014-09-03 20:54:55.246  - error: admin.0 iobroker
                                  2014-09-03 20:54:55.251  - error: admin.0 iobroker fs.js:760
                                  2014-09-03 20:54:55.256  - error: admin.0 iobroker   return binding.unlink(pathModule._makeLong(path));                 ^
                                  2014-09-03 20:54:55.278  - error: admin.0 iobroker Error: ENOENT, no such file or directory '/opt/iobroker/tmp/hm-rega.zip'    at Object.fs.unlinkSync (fs.js:760:18)
                                      at /opt/iobroker/setup.js:617:16
                                      at WriteStream.cb (/opt/iobroker/node_modules/ncp/lib/ncp.js:233:37)
                                      at WriteStream.g (events.js:175:14)
                                      at WriteStream.EventEmitter.emit (events.js:117:20)
                                      at finishMaybe (_stream_writable.js:354:12)
                                      at afterWrite (_stream_writable.js:274:5)
                                      at onwrite (_stream_writable.js:264:7)
                                      at WritableState.onwrite (_stream_writable.js:97:5)
                                      at fs.js:1681:5
                                  2014-09-03 20:54:55.297  - info: admin.0 iobroker exit 8
                                  2014-09-03 20:54:57.707  - info: admin.0 iobroker got /opt/iobroker/adapter/hm-rega/admin
                                  2014-09-03 20:54:57.751  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/index.html index.html text/html
                                  2014-09-03 20:54:57.933  - info: admin.0 iobroker Adapter "hm-rega" updated
                                  Rainer
                                  PS vielleicht war da noch mehr, aber mit juicessh sehe ich nicht alles
                                  Gesendet von meinem LIFETAB_E10320 mit Tapatalk
                                    Habe heute festgestellt, dass ich gestern iobroker gar nicht mehr gestartet habe.
                                    Nachdem ich dies heute gemacht habe, scheint er sich aufzuhängen:
                                    root@cubie:/opt/iobroker# ./iobroker start
                                    Starting ioBroker controller daemon...
                                    ioBroker controller daemon started. PID: 2430
                                    root@cubie:/opt/iobroker# tail -f log/iobroker.log
                                    2014-09-04 14:48:50.612  - info: hm-rpc.1 xmlrpc server listening on undefined:2001
                                    2014-09-04 14:48:50.615  - info: hm-rpc.1 xmlrpc -> undefined:undefined init ["http://undefined:2001","hm-rpc.1"]
                                    2014-09-04 14:52:20.301  - info: ioBroker.nodejs version 0.0.16 io.controller starting
                                    2014-09-04 14:52:20.317  - info: Copyright (c) 2014 hobbyquaker, bluefox
                                    2014-09-04 14:52:20.319  - info: controller hostname: cubie
                                    2014-09-04 14:52:20.319  - info: controller ip addresses: 192.168.xxx.yyy fe12::f:3ff:fe45:67b8
                                    2014-09-04 14:52:22.961  - info: controller couchdb connected
                                    2014-09-04 14:52:23.286  - info: controller 5 instances found
                                    2014-09-04 14:52:23.291  - info: controller starting 5 instances
                                    2014-09-04 14:52:23.336  - info: controller instance system.adapter.admin.0 started with pid 2436
                                    2014-09-04 14:52:27.328  - info: controller instance system.adapter.hm-rega.0 started with pid 2439
                                    2014-09-04 14:52:31.319  - info: controller instance system.adapter.hm-rega.1 started with pid 2445
                                    2014-09-04 14:52:31.522  - info: admin.0 starting
                                    2014-09-04 14:52:31.962  - info: admin.0 requesting all states
                                    2014-09-04 14:52:31.991  - info: admin.0 requesting all objects
                                    2014-09-04 14:52:32.078  - info: admin.0 http server listening on port 8081
                                    2014-09-04 14:52:31.006  - info: hm-rega.0 starting
                                    2014-09-04 14:52:31.025  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                                    2014-09-04 14:52:35.323  - info: controller instance system.adapter.hm-rpc.0 started with pid 2453
                                    2014-09-04 14:52:38.251  - info: admin.0 received all states
                                    2014-09-04 14:52:39.323  - info: controller instance system.adapter.hm-rpc.1 started with pid 2459
                                    2014-09-04 14:52:38.714  - info: hm-rega.1 starting
                                    2014-09-04 14:52:38.764  - info: hm-rega.1 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                                    2014-09-04 14:52:43.652  - info: admin.0 received all objects
                                    2014-09-04 14:52:44.033  - info: hm-rpc.0 starting
                                    2014-09-04 14:52:44.872  - info: hm-rpc.0 xmlrpc server listening on undefined:2000
                                    2014-09-04 14:52:44.877  - info: hm-rpc.0 xmlrpc -> undefined:undefined init ["http://undefined:2000","hm-rpc.0"]
                                    2014-09-04 14:52:46.106  - info: hm-rpc.1 starting
                                    2014-09-04 14:52:46.683  - info: hm-rpc.1 xmlrpc server listening on undefined:2001
                                    2014-09-04 14:52:46.688  - info: hm-rpc.1 xmlrpc -> undefined:undefined init ["http://undefined:2001","hm-rpc.1"]
                                    Die Einstellungen in der Couchdb für die IPs der beiden lxccu sind korrekt.
                                    undefined sollte da nichts sein und beim rpc.0 sollte der port eigentlich auch 2001 sein, oder?
                                    Rainer
                                      bei einer erneuten Installation kommt es nun zu einem Code8-Fehler.
                                      download https://github.com/ioBroker/ioBroker.hm-rpc/archive/master.zip
                                      unzip /opt/iobroker/tmp/hm-rpc.zip
                                      copying /opt/iobroker/tmp/ioBroker.hm-rpc-master to /opt/iobroker/adapter/hm-rpc
                                      delete /opt/iobroker/tmp/hm-rpc.zip
                                      delete /opt/iobroker/tmp/ioBroker.hm-rpc-master
                                      install adapter hm-rpc
                                      npm install "/opt/iobroker/adapter/hm-rpc" --production --prefix "/opt/iobroker/adapter/hm-rpc"
                                      npm ERR! install Couldn't read dependencies
                                      npm ERR! Failed to parse json
                                      npm ERR! Unexpected token }
                                      npm ERR! File: /opt/iobroker/adapter/hm-rpc/package.json
                                      npm ERR! Failed to parse package.json data.
                                      npm ERR! package.json must be actual JSON, not just JavaScript.
                                      npm ERR!
                                      npm ERR! This is not a bug in npm.
                                      npm ERR! Tell the package author to fix their package.json file. JSON.parse
                                      npm ERR! System Linux 3.4.101-sun7i+
                                      npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "/opt/iobroker/adapter/hm-rpc" "--production" "--prefix" "/opt/iobroker/adapter/hm-rpc"
                                      npm ERR! cwd /opt/iobroker
                                      npm ERR! node -v v0.10.22
                                      npm ERR! npm -v 1.3.14
                                      npm ERR! file /opt/iobroker/adapter/hm-rpc/package.json
                                      npm ERR! code EJSONPARSE
                                      npm ERR!
                                      npm ERR! Additional logging details can be found in:
                                      npm ERR!     /opt/iobroker/npm-debug.log
                                      npm ERR! not ok code 0
                                      got /opt/iobroker/adapter/hm-rpc/admin
                                      upload hm-rpc.admin /opt/iobroker/adapter/hm-rpc/admin/index.html index.html text/html
                                      object system.adapter.hm-rpc created
                                      Ich tippe es liegt an den Errors im Rahmen der Installation.
                                      Vielleicht hilft es ja 🙂
                                      Viele Grüße
                                      Trident
                                        hobbyquaker last edited by
                                        @Trident:
                                        npm ERR! Failed to parse package.json data. `
                                        Danke für den Hinweis - ist gefixt.
                                          Habe seit einigen Tagen Probleme (s.o.)
                                          Hatte auch nach einem update npm-install gemacht und bekomme folgende Fehlermeldung:
                                          npm http GET https://github.com/hobbyquaker/node-schedule/tarball/masternpm http 304 https://registry.npmjs.org/hiredis
                                          npm http 200 https://github.com/hobbyquaker/node-schedule/tarball/masternpm http 304 https://registry.npmjs.org/node-windows
                                          > node-gyp rebuild
                                            CC(target) Release/obj.target/hiredis/deps/hiredis/net.o
                                            CC(target) Release/obj.target/hiredis/deps/hiredis/sds.o
                                            CC(target) Release/obj.target/hiredis/deps/hiredis/async.o
                                            AR(target) Release/obj.target/deps/hiredis.a
                                            COPY Release/hiredis.a
                                            CXX(target) Release/obj.target/hiredis/src/hiredis.o
                                          make: g++: Command not found
                                          make: *** [Release/obj.target/hiredis/src/hiredis.o] Error 127
                                          gyp ERR! not ok
                                          Notfalls bau ich es auch nochmal komplett neu auf [emoji4]
                                          Rainer
                                          Gesendet von meinem Cynus T7 mit Tapatalk
                                            wenn das Bauen von hiredis und/oder node-windows fehlschlägt sollte das kein Problem sein, die Pakete sind optional.
                                            Node-Windows wird (logischerweise) auf einem Linux-System immer zu einer Fehlermeldung führen, die Hiredis Fehler kannst Du vermutlich loswerden indem Du mal````
                                            sudo apt-get install gcc g++ make
                                            176
                                            39514
