    4. Yet another HomeKit adapter
      bo0n last edited by
      Mahlzeit!
      Nach Update auf V. 0.8.2 habe ich folgendes im Log!
      host.All-In-One_RasPi	2018-12-10 10:32:14.414	info	Restart adapter system.adapter.yahka.0 because enabled
      host.All-In-One_RasPi	2018-12-10 10:32:14.414	error	instance system.adapter.yahka.0 terminated with code 1 ()
      host.All-In-One_RasPi	2018-12-10 10:32:14.414	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/lib/HAPServer.js:8:15)
      host.All-In-One_RasPi	2018-12-10 10:32:14.413	error	Caught by controller[0]: at require (internal/module.js:11:18)
      host.All-In-One_RasPi	2018-12-10 10:32:14.413	error	Caught by controller[0]: at Module.require (module.js:597:17)
      host.All-In-One_RasPi	2018-12-10 10:32:14.413	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
      host.All-In-One_RasPi	2018-12-10 10:32:14.413	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
      host.All-In-One_RasPi	2018-12-10 10:32:14.412	error	Caught by controller[0]: at Module.load (module.js:566:32)
      host.All-In-One_RasPi	2018-12-10 10:32:14.412	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
      host.All-In-One_RasPi	2018-12-10 10:32:14.412	error	Caught by controller[0]: at Module._compile (module.js:653:30)
      host.All-In-One_RasPi	2018-12-10 10:32:14.412	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/index.js:1:99)
      host.All-In-One_RasPi	2018-12-10 10:32:14.412	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.yahka/node_modules/bindings/bindings.js:96:9)
      host.All-In-One_RasPi	2018-12-10 10:32:14.411	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/compiled/8.14.0/linux/arm/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.411	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/build/default/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.411	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/Release/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.411	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/out/Release/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.410	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/Debug/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.410	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/out/Debug/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.410	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/build/Release/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.410	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/build/Debug/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.409	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/build/ed25519.node
      host.All-In-One_RasPi	2018-12-10 10:32:14.409	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      host.All-In-One_RasPi	2018-12-10 10:32:14.409	error	Caught by controller[0]: ^
      host.All-In-One_RasPi	2018-12-10 10:32:14.409	error	Caught by controller[0]: throw err
      host.All-In-One_RasPi	2018-12-10 10:32:14.408	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/bindings/bindings.js:99</anonymous></anonymous>
      0.8.1 lief problemlos!
      Jemand eine Idee?
      EDIT:
      Habe im Verzeichnis node_modules/iobroker.yahka mal ein „npm rebuild“ ausgeführt…danach ging alles wieder!
      • flugwelle
        flugwelle last edited by
        Bei mir funktioniert auch 0.8.2 ohne neue Besonderheiten ..
          Kugelkopf last edited by
          Ich hätte mal eine Frage:
          Ich nutze auch YAHKA in Kombination mit deConz und habe einige Automationen via Apple "Home" -App hinzugefügt.
          Unter anderem: Wenn ich Heim komme: Schalte das Licht von meiner Tradfri e14 Lampe auf 100% an. Die Lampe wird öfter von mir händisch gedimmt, so das der letzte eingestellte Wert meist eher um die 5% ist.
          Das Problem ist nun: Wenn diese Aktion getriggert wird: Setzt Home erst den Helligkeitswert und dann den Wert für "on" Zumindest entnehme ich das so dem Log.
          Der Helligkeitswert wird ignoriert aufgrund dessen, dass sich die Lampe nicht im "on = true" Status befindet. Der 2. Befehl der gesendet wird ist dann der ON - Befehl. Also schaltet sich die Lampe nur auf die alte Helligkeitsstufe ein.
          Gibt es eine Option diese Sache im Adapter umzudrehen? Also erst einschalten, dann Helligkeitswert ändern?
            peer6969 last edited by
            Ich nutze auch deCONZ und YAHKA in Verbindung und habe ein ähnliches Problem. Habe das nun bisher mit einem Skript gelöst, das mit einer Verzögerung von 500ms nach dem Einschalten die Lampen bzw. eine Gruppe von Lampen auf 100% regelt. Ein "gleichzeitiges" Setzen der Helligkeit und des "on"-Status klappt da übrigens auch nicht. Der Befehl wird nur ausgeführt, wenn ich eine Verzögerung zwischen dem Einschalten und der Helligkeitsänderung einbaue.
            • Dutchman
              @MaxMan23:
              Das ist doch falsch. Es geht sowohl mit dem Lichtschalter als auch mit der Homebrige. `
              https://www.ifun.de/philips-hue-testet- … en-130987/
                @peer6969:
                Ich nutze auch deCONZ und YAHKA in Verbindung und habe ein ähnliches Problem. Habe das nun bisher mit einem Skript gelöst, das mit einer Verzögerung von 500ms nach dem Einschalten die Lampen bzw. eine Gruppe von Lampen auf 100% regelt. Ein "gleichzeitiges" Setzen der Helligkeit und des "on"-Status klappt da übrigens auch nicht. Der Befehl wird nur ausgeführt, wenn ich eine Verzögerung zwischen dem Einschalten und der Helligkeitsänderung einbaue. `
                Tatsächlich werden die Befehle auch in falscher Reihenfolge gesendet:
                2018-12-19 23:49:32.671 - info: deconz.0 setLightState: {"bri": 255} 1 deconz.0.Light_1.bri
                2018-12-19 23:49:32.678 - info: deconz.0 setLightState: {"on": true} 1 deconz.0.Light_1.on
                2018-12-19 23:49:32.682 - info: deconz.0 options: {"url":"http://127.0.0.1:8080/api/AE6BB8XXXX/lights/1/state","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{\"bri\": 255}"}
                2018-12-19 23:49:32.683 - warn: deconz.0 {"address":"/lights/1","description":"parameter, /lights/1/bri, is not modifiable. Device is set to off.","type":201}
                2018-12-19 23:49:32.691 - info: deconz.0 options: {"url":"http://127.0.0.1:8080/api/AE6BBXXXX/lights/1/state","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{\"on\": true}"}
                Erst die Helligkeit und dann der "AN" -Befehl. So wird der Helligkeitsbefehl ignoriert mit der Meldung: "Device is set to off"
                  Magst du damit einen issue für den deconz Adapter erstellen?
                    @peer6969:
                    Magst du damit einen issue für den deconz Adapter erstellen? `
                    Das kann ich tun. Allerdings weiß ich nicht, ob ich dort an der richtigen Stelle bin. Denn der Log beschreibt ja nur was ihm gesendet wurde. Dementsprechend müsste an die Datenpunkte von deconz ja die Befehle in falscher Reihenfolge von YAHKA übergeben worden sein.
                    Oder habe ich hier einen Denkfehler?
                      Gute Frage. Da bin ich mir auch nicht sicher, wo das Problem genau liegt.
                        A Former User last edited by
                        Ich habe seit längerem das Problem, das ich über den HomeKit Adapter nur noch "false" Befehle senden kann.
                        Nutze den Adapter um Sonoff Switches zu steuern. Ob an oder aus aufm iPhone, der Status im ioBroker bleibt false.
                        Wenn der Status true ist und ich die Lampe ausschalte, geht er auf false, andersrum nicht mehr. Seitdem nutze ich diesen eigentlich sehr hilfreichen Adapter nicht mehr. Kann mir da jemand helfen?
                        EDIT:
                        Gelöst. Lag wohl daran, dass der RAM meines Pis zu voll war. Hab ein paar Adapter aussortiert.
                        Wird wohl langsam Zeit für ne größere Maschine
                          Marc_St last edited by
                          Besten Dank für das Update auf v9! Toll ist natürlich die Skript-Möglichkeit.
                          Dazu gleich eine Frage: Ich verstehe, wie ich nun relativ frei Datenpunkte übersetzen kann. Für meine Alarmanlage etwa sieht das so aus:
                           if (value  === false) {
                                  return 3;
                           if (value  === true) {
                                  return 1;
                          Dazu aber auch gleich meine Frage: Ist es innerhalb eines solchen Skripts möglich, auch andere Datenpunkte auszuwerten? Dazu ist die Alarmanlage ein schönes Beispiel: Innerhalb eines HK-Datenpunktes SecuritySystemCurrentState beschreiben die Werte 0 bis 3 den Zustand der Alarmanlage, aber in Eben dem Datenpunkt SecuritySystemCurrentState beschreibt dann der Wert 4 eine ausgelösten Alarm. Ob aber die Alarmanlage scharf oder nicht scharf ist, ist bei mir in ein anderer Datenpunkt als jener zur Beschreibung Alarm ja / ein. Ich müsste also die zwei Datenpunkte aus ioBroker zu einem Datenpunkt in yahka kombinieren. An der Stelle komme ich nicht weiter. Denn im Skript funktioniert so etwas wie var alarm = getState("hm-rpc.2.xyz").val; nicht. Insgesamt benötige ich als Skript also so etwas:
                          if (alarm  === true) {
                                  return 4;
                                  return 3;
                                  return 1;
                          Ist das überhaupt möglich? Danke!
                          Marc
                            danw last edited by
                            @Marc_St:
                                    return 3;
                                    return 1;
                                    return 4;
                                    return 3;
                                    return 1;
                            Marc `
                            Kannst dir in einen virtuelles Objekt (z.B. custom.0.alarmanlage.yahka) die passenden states schreiben (per Javascript/Blockly) und dann diese in Yahka bringen.
                            • flugwelle
                              Was muss ich eigentlich tun, um die v 0.9 zu installieren? Es will mir nicht gelingen ..
                              • Homer.J.
                                Homer.J. last edited by
                                @flugwelle:
                                Was muss ich eigentlich tun, um die v 0.9 zu installieren? Es will mir nicht gelingen .. `
                                Die Katze öffnen und das hier https://github.com/jensweigele/ioBroker.yahka.git eingeben.
                                • flugwelle
                                  Danke!
                                  Ich hatte es vorher mit https://github.com/jensweigele/ioBroker.yahka (also ohne .git) erfolglos probiert.
                                  Aber auch jetzt klappt es leider nicht
                                  $ ./iobroker url "https://github.com/jensweigele/ioBroker.yahka.git"
                                  install https://github.com/jensweigele/ioBroker.yahka/tarball/master
                                  npm install https://github.com/jensweigele/ioBroker.yahka/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                                  npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
                                  npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
                                  npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
                                  npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
                                  npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:42:5
                                  npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/mode.js:8:5
                                  npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:284:29
                                  npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:152:21)
                                  npm WARN addRemoteGit  git+https://github.com/homespun/hap-nodejs-community-types.git resetting remote /root/.npm/_git-remotes/git-https-github-com-homespun-hap-nodejs-community-types-git-63d7748d because of error: { Error: not found: git
                                  npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:152:21) code: 'ENOGIT' }
                                  npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/homespun/hap-nodejs-community-types.git /root/.npm/_git-remotes/git-https-github-com-homespun-hap-nodejs-community-types-git-63d7748d: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/homespun/hap-nodejs-community-types.git /root/.npm/_git-remotes/git-https-github-com-homespun-hap-nodejs-community-types-git-63d7748d: undefined
                                  npm ERR! code ENOGIT
                                  npm ERR! not found: gitnpm ERR!
                                  npm ERR! Failed using git.
                                  npm ERR! This is most likely not a problem with npm itself.
                                  npm ERR! Please check if you have git installed and in your PATH.
                                  npm ERR!     /root/.npm/_logs/2019-01-06T19_32_39_887Z-debug.log
                                  process exited with code 0
                                  • wendy2702
                                    wendy2702 last edited by
                                    Dir fehlt scheinbar GIT in deiner Installation
                                    Musst also GIT installieren und dann den Adapter
                                    • flugwelle
                                      Danke - das hat geklappt!
                                        adrj last edited by
                                        Hallo, versuche nun schon etwas länger eine Klingel mit Push Funktion in HomekIt zu bringen.
                                        Der Gedanke ist sobal jemand meinen HomeMatic HMIP BSM Taster am EIngang drückt ich eine Push Notification auf mein iPhone erhalte.
                                        Hierzu habe ich ein Gerät hinzugefügt und den Service "Doorbell" ausgewählt.
                                        Allerdings bekomme ich das Ding nicht zum laufen - in Homekit siehts dann so aus:
                                        Frage, hat das jemand hier in der Community eventuell schon Ähnlich umgesetzt? Dachte auch schon daran in Yahka einen ContactSensor Service auszuwählen - allerdings funktioniert das bei mir ebenfalls nicht 😞
                                        Vielen Dank für jegliche Tipps und Tricks 🙂
                                          danw last edited by
                                          Eine Doorlock mit zweitem Service DoorBell funktioniert
                                          Wenn du eine Kamera im gleichem (Apple) Raum hast sogar mit Screenshot und Livebild
                                            adrj last edited by
                                            @danw:
                                            Wenn du eine Kamera im gleichem (Apple) Raum hast sogar mit Screenshot und Livebild `
                                            danw! Vielen Dank!
                                            Hab ich direkt versucht: Bei Geräteeigenschaften Door Lock ausgewählt und bei Service so belassen wie oben in den Screenshots… hat allerdings keine Auswirkungen, steht noch immer "Nicht unterstützt" in Homekit.
                                            Meinst Du kannst mir ein Screenshot von deiner Konfig zuschicken? Hab tatsächlich eine Kamera daneben - wäre natürlich der hammer :mrgreen:
                                            Danke Danke!
                                            1764
                                            800246
