    4. Installation ioBroker auf Cubietruck
      Trident last edited by
      Kurze Ergänzung: Bei der Neuinstallation und dem Command "npm install –production" kam der folgende Auszug (Teil mit der Warnung):
      npm http 304 https://registry.npmjs.org/oauth-sign
      npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm http GET https://registry.npmjs.org/combined-stream
      npm http 304 https://registry.npmjs.org/combined-stream
      npm http GET https://registry.npmjs.org/delayed-stream/0.0.5
      npm http 304 https://registry.npmjs.org/delayed-stream/0.0.5
      npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      Der Rest lief (zumindest was die Anzeigen angeht) gut durch. Vielleicht ist es ja interessant…
      Viele Grüße
      Trident
      Edit: Nach der Installation wieder das "Code 8" Problem...
      Edit 2: Scheinbar habe ich noch "Reste" der alten Installation ... Er gibt nun folgende Meldung im Log:
      2014-08-26 21:52:32.704  - warn: controller stopInstance system.adapter.hm-rpc.0 not running
      2014-08-26 21:52:42.716  - info: controller force terminated after 10s
      2014-08-26 21:52:49.019  - info: ioBroker.nodejs version 0.0.16 io.controller starting
      2014-08-26 21:52:49.036  - info: Copyright (c) 2014 hobbyquaker, bluefox
      2014-08-26 21:52:49.038  - info: controller hostname: cubie
      2014-08-26 21:52:49.038  - info: controller ip addresses: xxx.xxx.xxx.xx yyy
      2014-08-26 21:52:51.743  - info: controller 3 instances found
      2014-08-26 21:52:51.747  - info: controller starting 3 instances
      2014-08-26 21:52:51.783  - info: controller instance system.adapter.admin.0 started with pid 3005
      2014-08-26 21:52:52.449  - error: controller instance system.adapter.admin.0 terminated with code 8
      2014-08-26 21:52:55.778  - info: controller instance system.adapter.admin.1 started with pid 3008
      2014-08-26 21:52:56.282  - error: controller instance system.adapter.admin.1 terminated with code 8
      2014-08-26 21:52:59.773  - info: controller instance system.adapter.hm-rpc.0 started with pid 3010
      2014-08-26 21:53:00.199  - error: controller instance system.adapter.hm-rpc.0 terminated with code 8
      2014-08-26 21:53:22.474  - info: controller instance system.adapter.admin.0 started with pid 3013
      2014-08-26 21:53:22.985  - error: controller instance system.adapter.admin.0 terminated with code 8
      2014-08-26 21:53:26.308  - info: controller instance system.adapter.admin.1 started with pid 3015
      2014-08-26 21:53:26.798  - error: controller instance system.adapter.admin.1 terminated with code 8
      2014-08-26 21:53:30.229  - info: controller instance system.adapter.hm-rpc.0 started with pid 3017
      Und das nachdem ich das Verzeichnis gelöscht und genau nach Anleitung neuinstalliert habe (bis inklusive des Punkts "Install admin Adapter" –> Aber nicht weiter). Trotzdem kennt Er scheinbar noch den "alten" HM-RPC Adapter. Wahrscheinlich reicht es nicht das Verzeichnis zu löschen... Da werde noch "Reste" in der CouchDB hängen...:)
      Das soweit von mir.
      Schönen Abend noch!
        Hallo Trident,
        ich denke die Warnungen sind nicht so wild.
        Es wird hier aufgrund des Sortieralgorithmus die Version v0.1xxxxx einfach fälschlicherweise als kleiner v0.8xxxx angesehen.
        Die korrekte Versionierung für diese Sortierung hätte sein müssen v0.08.xxxx damit diese als kleiner als 0.10.22 erkannt wird.
        Rainer
          N'Abend,
          nachdem ich die couchDB geleert habe und neuinstalliert habe nun der folgende Stand:
          1. Das Aktivieren der Instanzen ist (zumindest in Firefox und Safari) etwas "buggy". Habe noch kein Muster erkannt, aber ich muss immer mehrfach in die Einstellungen (Bleistift links unten) und mit save bestätigen. Irgendwann startet die Instanz dann… Ausserdem bekomme ich im Firefox folgenden Fehler in der Konsole angezeigt:
          `Error: Syntax error, unrecognized expression: [id="object_hm-rpc.meta.VALUES.HM-CC-RT-DN.CLIMATECONTROL_RECEIVER.19"[/code]`
          2) Nach der Installation des HM-RPC Adapters läuft dieser stabil und gut durch. Aktiviere ich nun auch den HM-REGA Adapter sieht es zunächst gut aus. Das Log zeigt folgende Warnungen:
          `~~[code]~~-08-27 21:38:56.589  - info: hm-rega.0 got 0 variables
          2014-08-27 21:38:56.684  - warn: hm-rega.0 setObject 40 (type=state) property common.role missing!
          2014-08-27 21:38:56.695  - warn: hm-rega.0 setObject 41 (type=state) property common.role missing!
          2014-08-27 21:38:56.702  - warn: hm-rega.0 setObject 950 (type=state) property common.role missing!
          2014-08-27 21:38:56.708  - warn: hm-rega.0 setObject 1233 (type=state) property common.role missing!
          2014-08-27 21:38:56.714  - warn: hm-rega.0 setObject 1580 (type=state) property common.role missing!
          2014-08-27 21:38:56.720  - warn: hm-rega.0 setObject 1581 (type=state) property common.role missing!
          2014-08-27 21:38:56.729  - warn: hm-rega.0 setObject 1582 (type=state) property common.role missing!
          2014-08-27 21:38:56.735  - warn: hm-rega.0 setObject 1914 (type=state) property common.role missing!
          2014-08-27 21:38:56.741  - warn: hm-rega.0 setObject 2383 (type=state) property common.role missing!
          2014-08-27 21:38:56.746  - warn: hm-rega.0 setObject 2384 (type=state) property common.role missing!
          2014-08-27 21:38:56.752  - warn: hm-rega.0 setObject 2385 (type=state) property common.role missing!
          2014-08-27 21:38:56.758  - warn: hm-rega.0 setObject 2434 (type=state) property common.role missing!
          2014-08-27 21:38:56.763  - warn: hm-rega.0 setObject 2435 (type=state) property common.role missing!
          2014-08-27 21:38:56.769  - warn: hm-rega.0 setObject 2436 (type=state) property common.role missing!
          2014-08-27 21:38:56.774  - warn: hm-rega.0 setObject 2437 (type=state) property common.role missing!
          2014-08-27 21:38:56.780  - warn: hm-rega.0 setObject 2438 (type=state) property common.role missing!
          2014-08-27 21:38:56.785  - warn: hm-rega.0 setObject 2439 (type=state) property common.role missing!
          2014-08-27 21:38:56.791  - warn: hm-rega.0 setObject 2516 (type=state) property common.role missing!
          2014-08-27 21:38:56.796  - warn: hm-rega.0 setObject 2517 (type=state) property common.role missing!
          2014-08-27 21:38:56.803  - warn: hm-rega.0 setObject 2594 (type=state) property common.role missing!
          2014-08-27 21:38:56.810  - warn: hm-rega.0 setObject 2753 (type=state) property common.role missing!
          2014-08-27 21:38:56.818  - info: hm-rega.0 added/updated 21 variables
          2014-08-27 21:38:56.819  - info: hm-rega.0 deleted 0 variables[/code]`
          Danach dann folgendes:
          `~~[code]~~2014-08-27 21:40:00.044  - info: controller instance system.adapter.hm-rpc.0 started with pid 6717
          2014-08-27 21:40:03.384  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
          2014-08-27 21:40:33.410  - info: controller instance system.adapter.hm-rpc.0 started with pid 6724
          2014-08-27 21:40:36.869  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
          2014-08-27 21:41:06.898  - info: controller instance system.adapter.hm-rpc.0 started with pid 6730
          2014-08-27 21:41:10.242  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
          2014-08-27 21:41:40.268  - info: controller instance system.adapter.hm-rpc.0 started with pid 6737
          2014-08-27 21:41:43.716  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
          [/code]`
          Der HM-RPC Adapter "verabschiedet" sich nun periodisch!
          Vielleicht helfen euch die Infos ja!
          Schönen Abend noch!
          Trident
            Hast du denn den rpc-adapter richtig konfiguriert?
            IP deiner ccu eingetragen?
            Rainer
              ja, habe ich alles konfiguriert…
              Viele Grüße
              Trident
                ich habe bei der rpc Instance mal den "debug" log-modus aktiviert. Hier die Ausgabe des Logs:
                2014-08-28 21:15:31.939  - info: controller instance system.adapter.hm-rpc.0 started with pid 10076
                2014-08-28 21:15:35.020  - debug: 4m7le3 [{"method":"GET","headers":{"content-type":"application/json","accept":"application/json"},"uri":"http://127.0.0.1:5984/iobroker"}]
                2014-08-28 21:15:35.402  - debug: redis get system.adapter.hm-rpc.0.alive {"val":true,"ack":true,"ts":1409253335,"lc":1409253305}
                2014-08-28 21:15:35.424  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                Obwohl auf der Admin-Website alles richtig konfiguriert ist, scheint sich hier eine falsche IP eingeschlichen zu haben… Ich habe zumindest nirgendwo die 127.0.0.1 eingegeben.
                Keine Ahnung, ob das so sein muss ....
                Viele Grüße
                Trident
                  Inzwischen hat sich wieder etwas auf der UI getan.
                  Die Update-Funktion wird angezeigt:
                  beim anklicken geht kurz ein "Terminal-Fenster" auf.
                  Wenn ich es recht gesehen habe steht da immer etwas drin was jetzt passieren soll und dann "todo" 😉
                  apropos "todo";
                  gibt es irgendetwas, wo wir euch helfen können?
                  z.B. so wie bei ccu.io: Übersetzen von Menüstrukturen; Hilfetexten (Readme=Todo)
                  Rainer
                    kleines Update von meiner Seite: Ist echt toll zuzusehen wie immer mehr Funktionen in die Web-Oberfläche einfließen. Ich habe heute eine komplette Neuinstallation gemacht (inkl. Löschung der alten CouchDB-Daten).
                    Das Admin Interface funktioniert nun unter Chrome echt gut. Ich bekomme nur leider von meinem HM-RPC Adapter immer noch diese Meldungen:
                    ` > 2014-08-31 15:37:39.725 - info: admin.0 requesting all objects
                    2014-08-31 15:37:39.767 - info: admin.0 http server listening on port 8081
                    2014-08-31 15:37:40.197 - info: admin.0 received all objects
                    2014-08-31 15:37:40.241 - info: admin.0 received all states
                    2014-08-31 15:38:43.679 - info: controller object change system.adapter.hm-rpc.0
                    2014-08-31 15:39:28.636 - info: controller object change system.adapter.hm-rpc.0
                    2014-08-31 15:39:28.661 - info: controller instance system.adapter.hm-rpc.0 started with pid 21720
                    2014-08-31 15:39:31.876 - debug: a36cn5 [{"method":"GET","headers":{"content-type":"application/json","accept":"application/json"},"uri":"http://127.0.0.1:5984/iobroker"}]
                    2014-08-31 15:39:32.264 - debug: redis get system.adapter.hm-rpc.0.alive {"val":true,"ack":true,"ts":1409492369,"lc":1409490793}
                    2014-08-31 15:39:32.292 - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                    2014-08-31 15:40:02.328 - info: controller instance system.adapter.hm-rpc.0 started with pid 21728
                    2014-08-31 15:40:05.674 - debug: gb0eca [{"method":"GET","headers":{"content-type":"application/json","accept":"application/json"},"uri":"http://127.0.0.1:5984/iobroker"}]
                    2014-08-31 15:40:06.050 - debug: redis get system.adapter.hm-rpc.0.alive {"val":true,"ack":true,"ts":1409492399,"lc":1409492384}
                    2014-08-31 15:40:06.073 - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                    2014-08-31 15:40:36.104 - info: controller instance system.adapter.hm-rpc.0 started with pid 21734
                    2014-08-31 15:40:39.205 - debug: 13e4my [{"method":"GET","headers":{"content-type":"application/json","accept":"application/json"},"uri":"http://127.0.0.1:5984/iobroker"}]
                    2014-08-31 15:40:39.493 - debug: 13e4my [{"err":null,"body":{"db_name":"iobroker","doc_count":91,"doc_del_count":0,"update_seq":162,"purge_seq":0,"compact_running":false,"disk_size":417896,"data_size":61147,"instance_start_time":"1409492099019712","disk_format_version":6,"committed_update_seq":162},"headers":{"date":"Sun, 31 Aug 2014 13:40:39 GMT","content-type":"application/json","cache-control":"must-revalidate","status-code":200,"uri":"http://127.0.0.1:5984/iobroker"}}]
                    2014-08-31 15:40:39.504 - debug: couchdb using db iobroker
                    2014-08-31 15:40:39.512 - debug: hm-rpc.0 couchdb connected
                    2014-08-31 15:40:39.537 - debug: hm-rpc.0 redis connected
                    2014-08-31 15:40:39.613 - error: controller instance system.adapter.hm-rpc.0 terminated with code 1 `
                    Vielleicht liegt es doch noch ein meiner Installation …
                    Das nur zur Info für euch!
                    Viele Grüße
                    Trident
                      Habe gerade mal wieder etwas mit ioBroker gespielt.
                      Updates liefen gut durch und jetzt funktionieren auch die Updatebuttons im webUI.
                      Im parallel laufenden log habe ich folgende Meldung:
                       2014-09-03 20:54:55.132  - info: admin.0 iobroker delete /opt/iobroker/tmp/hm-rega.zip
                      2014-09-03 20:54:55.136  - info: admin.0 iobroker delete /opt/iobroker/tmp/ioBroker.hm-rega-master
                      2014-09-03 20:54:55.152  - info: admin.0 iobroker copying /opt/iobroker/tmp/ioBroker.hm-rega-master to /opt/iobroker/adapter/hm-rega
                      2014-09-03 20:54:55.240  - info: admin.0 iobroker delete /opt/iobroker/tmp/hm-rega.zip
                      2014-09-03 20:54:55.246  - error: admin.0 iobroker
                      2014-09-03 20:54:55.251  - error: admin.0 iobroker fs.js:760
                      2014-09-03 20:54:55.256  - error: admin.0 iobroker   return binding.unlink(pathModule._makeLong(path));                 ^
                      2014-09-03 20:54:55.278  - error: admin.0 iobroker Error: ENOENT, no such file or directory '/opt/iobroker/tmp/hm-rega.zip'    at Object.fs.unlinkSync (fs.js:760:18)
                          at /opt/iobroker/setup.js:617:16
                          at WriteStream.cb (/opt/iobroker/node_modules/ncp/lib/ncp.js:233:37)
                          at WriteStream.g (events.js:175:14)
                          at WriteStream.EventEmitter.emit (events.js:117:20)
                          at finishMaybe (_stream_writable.js:354:12)
                          at afterWrite (_stream_writable.js:274:5)
                          at onwrite (_stream_writable.js:264:7)
                          at WritableState.onwrite (_stream_writable.js:97:5)
                          at fs.js:1681:5
                      2014-09-03 20:54:55.297  - info: admin.0 iobroker exit 8
                      2014-09-03 20:54:57.707  - info: admin.0 iobroker got /opt/iobroker/adapter/hm-rega/admin
                      2014-09-03 20:54:57.751  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/index.html index.html text/html
                      2014-09-03 20:54:57.933  - info: admin.0 iobroker Adapter "hm-rega" updated
                      Rainer
                      PS vielleicht war da noch mehr, aber mit juicessh sehe ich nicht alles
                      Gesendet von meinem LIFETAB_E10320 mit Tapatalk
                        Habe heute festgestellt, dass ich gestern iobroker gar nicht mehr gestartet habe.
                        Nachdem ich dies heute gemacht habe, scheint er sich aufzuhängen:
                        root@cubie:/opt/iobroker# ./iobroker start
                        Starting ioBroker controller daemon...
                        ioBroker controller daemon started. PID: 2430
                        root@cubie:/opt/iobroker# tail -f log/iobroker.log
                        2014-09-04 14:48:50.612  - info: hm-rpc.1 xmlrpc server listening on undefined:2001
                        2014-09-04 14:48:50.615  - info: hm-rpc.1 xmlrpc -> undefined:undefined init ["http://undefined:2001","hm-rpc.1"]
                        2014-09-04 14:52:20.301  - info: ioBroker.nodejs version 0.0.16 io.controller starting
                        2014-09-04 14:52:20.317  - info: Copyright (c) 2014 hobbyquaker, bluefox
                        2014-09-04 14:52:20.319  - info: controller hostname: cubie
                        2014-09-04 14:52:20.319  - info: controller ip addresses: 192.168.xxx.yyy fe12::f:3ff:fe45:67b8
                        2014-09-04 14:52:22.961  - info: controller couchdb connected
                        2014-09-04 14:52:23.286  - info: controller 5 instances found
                        2014-09-04 14:52:23.291  - info: controller starting 5 instances
                        2014-09-04 14:52:23.336  - info: controller instance system.adapter.admin.0 started with pid 2436
                        2014-09-04 14:52:27.328  - info: controller instance system.adapter.hm-rega.0 started with pid 2439
                        2014-09-04 14:52:31.319  - info: controller instance system.adapter.hm-rega.1 started with pid 2445
                        2014-09-04 14:52:31.522  - info: admin.0 starting
                        2014-09-04 14:52:31.962  - info: admin.0 requesting all states
                        2014-09-04 14:52:31.991  - info: admin.0 requesting all objects
                        2014-09-04 14:52:32.078  - info: admin.0 http server listening on port 8081
                        2014-09-04 14:52:31.006  - info: hm-rega.0 starting
                        2014-09-04 14:52:31.025  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                        2014-09-04 14:52:35.323  - info: controller instance system.adapter.hm-rpc.0 started with pid 2453
                        2014-09-04 14:52:38.251  - info: admin.0 received all states
                        2014-09-04 14:52:39.323  - info: controller instance system.adapter.hm-rpc.1 started with pid 2459
                        2014-09-04 14:52:38.714  - info: hm-rega.1 starting
                        2014-09-04 14:52:38.764  - info: hm-rega.1 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                        2014-09-04 14:52:43.652  - info: admin.0 received all objects
                        2014-09-04 14:52:44.033  - info: hm-rpc.0 starting
                        2014-09-04 14:52:44.872  - info: hm-rpc.0 xmlrpc server listening on undefined:2000
                        2014-09-04 14:52:44.877  - info: hm-rpc.0 xmlrpc -> undefined:undefined init ["http://undefined:2000","hm-rpc.0"]
                        2014-09-04 14:52:46.106  - info: hm-rpc.1 starting
                        2014-09-04 14:52:46.683  - info: hm-rpc.1 xmlrpc server listening on undefined:2001
                        2014-09-04 14:52:46.688  - info: hm-rpc.1 xmlrpc -> undefined:undefined init ["http://undefined:2001","hm-rpc.1"]
                        Die Einstellungen in der Couchdb für die IPs der beiden lxccu sind korrekt.
                        undefined sollte da nichts sein und beim rpc.0 sollte der port eigentlich auch 2001 sein, oder?
                        Rainer
                          bei einer erneuten Installation kommt es nun zu einem Code8-Fehler.
                          download https://github.com/ioBroker/ioBroker.hm-rpc/archive/master.zip
                          unzip /opt/iobroker/tmp/hm-rpc.zip
                          copying /opt/iobroker/tmp/ioBroker.hm-rpc-master to /opt/iobroker/adapter/hm-rpc
                          delete /opt/iobroker/tmp/hm-rpc.zip
                          delete /opt/iobroker/tmp/ioBroker.hm-rpc-master
                          install adapter hm-rpc
                          npm install "/opt/iobroker/adapter/hm-rpc" --production --prefix "/opt/iobroker/adapter/hm-rpc"
                          npm ERR! install Couldn't read dependencies
                          npm ERR! Failed to parse json
                          npm ERR! Unexpected token }
                          npm ERR! File: /opt/iobroker/adapter/hm-rpc/package.json
                          npm ERR! Failed to parse package.json data.
                          npm ERR! package.json must be actual JSON, not just JavaScript.
                          npm ERR!
                          npm ERR! This is not a bug in npm.
                          npm ERR! Tell the package author to fix their package.json file. JSON.parse
                          npm ERR! System Linux 3.4.101-sun7i+
                          npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "/opt/iobroker/adapter/hm-rpc" "--production" "--prefix" "/opt/iobroker/adapter/hm-rpc"
                          npm ERR! cwd /opt/iobroker
                          npm ERR! node -v v0.10.22
                          npm ERR! npm -v 1.3.14
                          npm ERR! file /opt/iobroker/adapter/hm-rpc/package.json
                          npm ERR! code EJSONPARSE
                          npm ERR!
                          npm ERR! Additional logging details can be found in:
                          npm ERR!     /opt/iobroker/npm-debug.log
                          npm ERR! not ok code 0
                          got /opt/iobroker/adapter/hm-rpc/admin
                          upload hm-rpc.admin /opt/iobroker/adapter/hm-rpc/admin/index.html index.html text/html
                          object system.adapter.hm-rpc created
                          Ich tippe es liegt an den Errors im Rahmen der Installation.
                          Vielleicht hilft es ja 🙂
                          Viele Grüße
                          Trident
                            hobbyquaker last edited by
                            @Trident:
                            npm ERR! Failed to parse package.json data. `
                            Danke für den Hinweis - ist gefixt.
                              Habe seit einigen Tagen Probleme (s.o.)
                              Hatte auch nach einem update npm-install gemacht und bekomme folgende Fehlermeldung:
                               root@cubie:/opt/iobroker# npm install --production
                              npm WARN package.json daemonize2@0.4.2 No repository field.
                              npm http GET https://registry.npmjs.org/node-windows
                              npm http GET https://registry.npmjs.org/hiredis
                              npm http GET https://github.com/hobbyquaker/node-schedule/tarball/masternpm http 304 https://registry.npmjs.org/hiredis
                              npm http 200 https://github.com/hobbyquaker/node-schedule/tarball/masternpm http 304 https://registry.npmjs.org/node-windows
                              npm WARN optional dep failed, continuing node-windows@0.1.5
                              npm http GET https://registry.npmjs.org/bindings
                              npm http GET https://registry.npmjs.org/nan
                              npm http 304 https://registry.npmjs.org/nan
                              npm http 304 https://registry.npmjs.org/bindings
                              > hiredis@0.1.17 install /opt/iobroker/node_modules/hiredis
                              > node-gyp rebuild
                              make: Entering directory `/opt/iobroker/node_modules/hiredis/build'
                                CC(target) Release/obj.target/hiredis/deps/hiredis/hiredis.o
                                CC(target) Release/obj.target/hiredis/deps/hiredis/net.o
                                CC(target) Release/obj.target/hiredis/deps/hiredis/sds.o
                                CC(target) Release/obj.target/hiredis/deps/hiredis/async.o
                                AR(target) Release/obj.target/deps/hiredis.a
                                COPY Release/hiredis.a
                                CXX(target) Release/obj.target/hiredis/src/hiredis.o
                              make: g++: Command not found
                              make: *** [Release/obj.target/hiredis/src/hiredis.o] Error 127
                              make: Leaving directory `/opt/iobroker/node_modules/hiredis/build'
                              gyp ERR! build error
                              gyp ERR! stack Error: `make` failed with exit code: 2
                              gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
                              gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
                              gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
                              gyp ERR! System Linux 3.4.101-sun7i+
                              gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              gyp ERR! cwd /opt/iobroker/node_modules/hiredis
                              gyp ERR! node -v v0.10.22
                              gyp ERR! node-gyp -v v0.11.0
                              gyp ERR! not ok
                              npm WARN optional dep failed, continuing hiredis@0.1.17
                              Notfalls bau ich es auch nochmal komplett neu auf [emoji4]
                              Rainer
                              Gesendet von meinem Cynus T7 mit Tapatalk
                                wenn das Bauen von hiredis und/oder node-windows fehlschlägt sollte das kein Problem sein, die Pakete sind optional.
                                Node-Windows wird (logischerweise) auf einem Linux-System immer zu einer Fehlermeldung führen, die Hiredis Fehler kannst Du vermutlich loswerden indem Du mal````
                                sudo apt-get install gcc g++ make
                                  Make war installiert, entsprechend hat mir das apt-get auch jetzt mitgeteilt, dass es die neueste Version sei.
                                  Leider bleibt es nach einem neustart bei dem Fehler vor n post #55
                                  Rainer, der sich freut mal wieder was von dir zu hören
                                    Hi zusammen,
                                    jetzt klappt die Installation auch wieder! Klasse! Macht wirklich Spaß die Fortschritte zu beobachten!
                                    Ich habe mal die Installation der Adapter aus dem Admin-Interface getestet. Bei der Installation des HM-Rega Adapters kommt folgende Fehlermeldung:
                                    2014-09-07 14:56:49.973  - info: admin.0 iobroker npm
                                    2014-09-07 14:56:49.978  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/boom
                                    2014-09-07 14:56:50.013  - info: admin.0 iobroker npm
                                    2014-09-07 14:56:50.018  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/cryptiles
                                    2014-09-07 14:56:50.728  - info: admin.0 iobroker npm
                                    2014-09-07 14:56:50.733  - info: admin.0 iobroker  http
                                    2014-09-07 14:56:50.738  - info: admin.0 iobroker 304 https://registry.npmjs.org/punycode
                                    2014-09-07 14:56:57.522  - info: admin.0 iobroker got /opt/iobroker/adapter/hm-rega/admin
                                    2014-09-07 14:56:57.559  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/index.html index.html text/html
                                    2014-09-07 14:56:58.191  - info: admin.0 iobroker object system.adapter.hm-rega created
                                    2014-09-07 14:56:58.343  - error: admin.0 iobroker
                                    2014-09-07 14:56:58.366  - error: admin.0 iobroker TypeError: Cannot read property 'name' of undefined    at /opt/iobroker/setup.js:660:48
                                        at /opt/iobroker/lib/couch.js:91:13
                                        at Request._callback (/opt/iobroker/node_modules/nano/nano.js:303:11)
                                        at Request.self.callback (/opt/iobroker/node_modules/nano/node_modules/request/request.js:122:22)
                                        at Request.EventEmitter.emit (events.js:98:17)
                                        at Request. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:888:14)
                                        at Request.EventEmitter.emit (events.js:117:20)
                                        at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:839:12)
                                        at IncomingMessage.EventEmitter.emit (events.js:117:20)
                                        at _stream_readable.js:920:16
                                    2014-09-07 14:56:58.392  - info: admin.0 iobroker exit 8</anonymous></anonymous>
                                    Ich freu mich auf die weitere Entwicklung! Es sieht jetzt schon richtig gut aus!
                                    Viele Grüße
                                    Trident
                                      Ja, ich glaube wir haben bald einen Stand erreicht der die Versionsnummer 0.1.x verdient 😉
                                      Dann kommt ein großer Brocken Arbeit: die Portierung von DashUI (das in Zukunft "ioBroker.vis" heissen wird).
                                        Ich bin ja so bescheuert….. :evil:
                                        ich hatte wegen des hängenden logs das WebUI gar nicht mehr aufgemacht - bis eben!
                                        Da hat sich ja ne ganze menge getan:
                                        Die Updates der Adapter (admin, hm-rega und hm-rpc) über das WebUI laufen jetzt einwandfrei.
                                        Unter Instances sind die von mir installierten adapter auch drin - lediglich bei den Konfigurationsdaten, die ich über die couchDB eingegeben haben (IP-Adresse und Port) fehlen hier IP und port
                                        Daher rührt dann wahrscheinlich auch der Error aus post #55
                                        Ist diese Info nicht "bidirektional"?
                                        Übernimmt ioBroker sie nicht, wenn ich sie in couchDB eintrage.
                                        Was passiert, wenn ich sie im WebUI auch nochmal eintrage - und dann womöglich hm-rega.0 und hm-rega.1 vertausche?
                                        Rainer
                                          Hallo HQ,
                                          @hobbyquaker:
                                          Dann kommt ein großer Brocken Arbeit: die Portierung von DashUI (das in Zukunft "ioBroker.vis" heissen wird). `
                                          Glückwunsch zur 0.1.0!!! 😛
                                          Und viel Erfolg mit dem nächsten Schritt
                                          Ich hatte gehofft mit dem legacy-Adapter so etwas hinzubekommen. Leider stürzt mir dann dieser dauernd ab.
                                          Rainer
                                            @Homoran:
                                            Übernimmt ioBroker sie nicht, wenn ich sie in couchDB eintrage. `
                                            Doch, es "sollte" eigentlich egal sein ob Du das im ioBroker.admin oder direkt in CouchDB-Futon machst. Wobei sowohl hm-rpc als auch hm-rega mittlerweile auch schon ein Konfigurations-UI haben (der Button rechts im Reiter instances)
                                            @Homoran:
                                            hm-rega.0 und hm-rega.1 `
                                            Ich glaube da liegt noch ein Missverständnis vor. Du brauchst für eine CCU auch nur eine Instanz des hm-rega Adapters. Nur der hm-rpc ist unter Umständen (falls Du wired nutzt) 2x notwendig.
                                            @Homoran:
                                            Ich hätte versucht mit dem legacy-Adapter so etwas hinzubekommen. Leider stürzt mir dann dieser dauernd ab. `
                                            Ja, an dem hab ich nicht mehr weitergemacht. Ich glaube ich schmeiss den wieder raus, die ursprüngliche Idee hier eine CCU.IO-kompatible Umgebung zu schaffen in der man einfach ein unverändertes DashUI/yahui laufen lassen kann ist wesentlich schwieriger zu verwirklichen als ich dachte…
                                            176
                                            39514
