    4. Installation ioBroker auf Cubietruck
      Habe gerade mal wieder etwas mit ioBroker gespielt.
      Updates liefen gut durch und jetzt funktionieren auch die Updatebuttons im webUI.
      Im parallel laufenden log habe ich folgende Meldung:
       2014-09-03 20:54:55.132  - info: admin.0 iobroker delete /opt/iobroker/tmp/hm-rega.zip
      2014-09-03 20:54:55.136  - info: admin.0 iobroker delete /opt/iobroker/tmp/ioBroker.hm-rega-master
      2014-09-03 20:54:55.152  - info: admin.0 iobroker copying /opt/iobroker/tmp/ioBroker.hm-rega-master to /opt/iobroker/adapter/hm-rega
      2014-09-03 20:54:55.240  - info: admin.0 iobroker delete /opt/iobroker/tmp/hm-rega.zip
      2014-09-03 20:54:55.246  - error: admin.0 iobroker
      2014-09-03 20:54:55.251  - error: admin.0 iobroker fs.js:760
      2014-09-03 20:54:55.256  - error: admin.0 iobroker   return binding.unlink(pathModule._makeLong(path));                 ^
      2014-09-03 20:54:55.278  - error: admin.0 iobroker Error: ENOENT, no such file or directory '/opt/iobroker/tmp/hm-rega.zip'    at Object.fs.unlinkSync (fs.js:760:18)
          at /opt/iobroker/setup.js:617:16
          at WriteStream.cb (/opt/iobroker/node_modules/ncp/lib/ncp.js:233:37)
          at WriteStream.g (events.js:175:14)
          at WriteStream.EventEmitter.emit (events.js:117:20)
          at finishMaybe (_stream_writable.js:354:12)
          at afterWrite (_stream_writable.js:274:5)
          at onwrite (_stream_writable.js:264:7)
          at WritableState.onwrite (_stream_writable.js:97:5)
          at fs.js:1681:5
      2014-09-03 20:54:55.297  - info: admin.0 iobroker exit 8
      2014-09-03 20:54:57.707  - info: admin.0 iobroker got /opt/iobroker/adapter/hm-rega/admin
      2014-09-03 20:54:57.751  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/index.html index.html text/html
      2014-09-03 20:54:57.933  - info: admin.0 iobroker Adapter "hm-rega" updated
      Rainer
      PS vielleicht war da noch mehr, aber mit juicessh sehe ich nicht alles
      Gesendet von meinem LIFETAB_E10320 mit Tapatalk
        Habe heute festgestellt, dass ich gestern iobroker gar nicht mehr gestartet habe.
        Nachdem ich dies heute gemacht habe, scheint er sich aufzuhängen:
        root@cubie:/opt/iobroker# ./iobroker start
        Starting ioBroker controller daemon...
        ioBroker controller daemon started. PID: 2430
        root@cubie:/opt/iobroker# tail -f log/iobroker.log
        2014-09-04 14:48:50.612  - info: hm-rpc.1 xmlrpc server listening on undefined:2001
        2014-09-04 14:48:50.615  - info: hm-rpc.1 xmlrpc -> undefined:undefined init ["http://undefined:2001","hm-rpc.1"]
        2014-09-04 14:52:20.301  - info: ioBroker.nodejs version 0.0.16 io.controller starting
        2014-09-04 14:52:20.317  - info: Copyright (c) 2014 hobbyquaker, bluefox
        2014-09-04 14:52:20.319  - info: controller hostname: cubie
        2014-09-04 14:52:20.319  - info: controller ip addresses: 192.168.xxx.yyy fe12::f:3ff:fe45:67b8
        2014-09-04 14:52:22.961  - info: controller couchdb connected
        2014-09-04 14:52:23.286  - info: controller 5 instances found
        2014-09-04 14:52:23.291  - info: controller starting 5 instances
        2014-09-04 14:52:23.336  - info: controller instance system.adapter.admin.0 started with pid 2436
        2014-09-04 14:52:27.328  - info: controller instance system.adapter.hm-rega.0 started with pid 2439
        2014-09-04 14:52:31.319  - info: controller instance system.adapter.hm-rega.1 started with pid 2445
        2014-09-04 14:52:31.522  - info: admin.0 starting
        2014-09-04 14:52:31.962  - info: admin.0 requesting all states
        2014-09-04 14:52:31.991  - info: admin.0 requesting all objects
        2014-09-04 14:52:32.078  - info: admin.0 http server listening on port 8081
        2014-09-04 14:52:31.006  - info: hm-rega.0 starting
        2014-09-04 14:52:31.025  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
        2014-09-04 14:52:35.323  - info: controller instance system.adapter.hm-rpc.0 started with pid 2453
        2014-09-04 14:52:38.251  - info: admin.0 received all states
        2014-09-04 14:52:39.323  - info: controller instance system.adapter.hm-rpc.1 started with pid 2459
        2014-09-04 14:52:38.714  - info: hm-rega.1 starting
        2014-09-04 14:52:38.764  - info: hm-rega.1 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
        2014-09-04 14:52:43.652  - info: admin.0 received all objects
        2014-09-04 14:52:44.033  - info: hm-rpc.0 starting
        2014-09-04 14:52:44.872  - info: hm-rpc.0 xmlrpc server listening on undefined:2000
        2014-09-04 14:52:44.877  - info: hm-rpc.0 xmlrpc -> undefined:undefined init ["http://undefined:2000","hm-rpc.0"]
        2014-09-04 14:52:46.106  - info: hm-rpc.1 starting
        2014-09-04 14:52:46.683  - info: hm-rpc.1 xmlrpc server listening on undefined:2001
        2014-09-04 14:52:46.688  - info: hm-rpc.1 xmlrpc -> undefined:undefined init ["http://undefined:2001","hm-rpc.1"]
        Die Einstellungen in der Couchdb für die IPs der beiden lxccu sind korrekt.
        undefined sollte da nichts sein und beim rpc.0 sollte der port eigentlich auch 2001 sein, oder?
        Rainer
          Trident last edited by
          bei einer erneuten Installation kommt es nun zu einem Code8-Fehler.
          download https://github.com/ioBroker/ioBroker.hm-rpc/archive/master.zip
          unzip /opt/iobroker/tmp/hm-rpc.zip
          copying /opt/iobroker/tmp/ioBroker.hm-rpc-master to /opt/iobroker/adapter/hm-rpc
          delete /opt/iobroker/tmp/hm-rpc.zip
          delete /opt/iobroker/tmp/ioBroker.hm-rpc-master
          install adapter hm-rpc
          npm install "/opt/iobroker/adapter/hm-rpc" --production --prefix "/opt/iobroker/adapter/hm-rpc"
          npm ERR! install Couldn't read dependencies
          npm ERR! Failed to parse json
          npm ERR! Unexpected token }
          npm ERR! File: /opt/iobroker/adapter/hm-rpc/package.json
          npm ERR! Failed to parse package.json data.
          npm ERR! package.json must be actual JSON, not just JavaScript.
          npm ERR!
          npm ERR! This is not a bug in npm.
          npm ERR! Tell the package author to fix their package.json file. JSON.parse
          npm ERR! System Linux 3.4.101-sun7i+
          npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "/opt/iobroker/adapter/hm-rpc" "--production" "--prefix" "/opt/iobroker/adapter/hm-rpc"
          npm ERR! cwd /opt/iobroker
          npm ERR! node -v v0.10.22
          npm ERR! npm -v 1.3.14
          npm ERR! file /opt/iobroker/adapter/hm-rpc/package.json
          npm ERR! code EJSONPARSE
          npm ERR!
          npm ERR! Additional logging details can be found in:
          npm ERR!     /opt/iobroker/npm-debug.log
          npm ERR! not ok code 0
          got /opt/iobroker/adapter/hm-rpc/admin
          upload hm-rpc.admin /opt/iobroker/adapter/hm-rpc/admin/index.html index.html text/html
          object system.adapter.hm-rpc created
          Ich tippe es liegt an den Errors im Rahmen der Installation.
          Vielleicht hilft es ja 🙂
          Viele Grüße
          Trident
            hobbyquaker last edited by
            @Trident:
            npm ERR! Failed to parse package.json data. `
            Danke für den Hinweis - ist gefixt.
              Habe seit einigen Tagen Probleme (s.o.)
              Hatte auch nach einem update npm-install gemacht und bekomme folgende Fehlermeldung:
               root@cubie:/opt/iobroker# npm install --production
              npm WARN package.json daemonize2@0.4.2 No repository field.
              npm http GET https://registry.npmjs.org/node-windows
              npm http GET https://registry.npmjs.org/hiredis
              npm http GET https://github.com/hobbyquaker/node-schedule/tarball/masternpm http 304 https://registry.npmjs.org/hiredis
              npm http 200 https://github.com/hobbyquaker/node-schedule/tarball/masternpm http 304 https://registry.npmjs.org/node-windows
              npm WARN optional dep failed, continuing node-windows@0.1.5
              npm http GET https://registry.npmjs.org/bindings
              npm http GET https://registry.npmjs.org/nan
              npm http 304 https://registry.npmjs.org/nan
              npm http 304 https://registry.npmjs.org/bindings
              > hiredis@0.1.17 install /opt/iobroker/node_modules/hiredis
              > node-gyp rebuild
              make: Entering directory `/opt/iobroker/node_modules/hiredis/build'
                CC(target) Release/obj.target/hiredis/deps/hiredis/hiredis.o
                CC(target) Release/obj.target/hiredis/deps/hiredis/net.o
                CC(target) Release/obj.target/hiredis/deps/hiredis/sds.o
                CC(target) Release/obj.target/hiredis/deps/hiredis/async.o
                AR(target) Release/obj.target/deps/hiredis.a
                COPY Release/hiredis.a
                CXX(target) Release/obj.target/hiredis/src/hiredis.o
              make: g++: Command not found
              make: *** [Release/obj.target/hiredis/src/hiredis.o] Error 127
              make: Leaving directory `/opt/iobroker/node_modules/hiredis/build'
              gyp ERR! build error
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
              gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
              gyp ERR! System Linux 3.4.101-sun7i+
              gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/hiredis
              gyp ERR! node -v v0.10.22
              gyp ERR! node-gyp -v v0.11.0
              gyp ERR! not ok
              npm WARN optional dep failed, continuing hiredis@0.1.17
              Notfalls bau ich es auch nochmal komplett neu auf [emoji4]
              Rainer
              Gesendet von meinem Cynus T7 mit Tapatalk
                wenn das Bauen von hiredis und/oder node-windows fehlschlägt sollte das kein Problem sein, die Pakete sind optional.
                Node-Windows wird (logischerweise) auf einem Linux-System immer zu einer Fehlermeldung führen, die Hiredis Fehler kannst Du vermutlich loswerden indem Du mal````
                sudo apt-get install gcc g++ make
                  Make war installiert, entsprechend hat mir das apt-get auch jetzt mitgeteilt, dass es die neueste Version sei.
                  Leider bleibt es nach einem neustart bei dem Fehler vor n post #55
                  Rainer, der sich freut mal wieder was von dir zu hören
                    Hi zusammen,
                    jetzt klappt die Installation auch wieder! Klasse! Macht wirklich Spaß die Fortschritte zu beobachten!
                    Ich habe mal die Installation der Adapter aus dem Admin-Interface getestet. Bei der Installation des HM-Rega Adapters kommt folgende Fehlermeldung:
                    2014-09-07 14:56:49.973  - info: admin.0 iobroker npm
                    2014-09-07 14:56:49.978  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/boom
                    2014-09-07 14:56:50.013  - info: admin.0 iobroker npm
                    2014-09-07 14:56:50.018  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/cryptiles
                    2014-09-07 14:56:50.728  - info: admin.0 iobroker npm
                    2014-09-07 14:56:50.733  - info: admin.0 iobroker  http
                    2014-09-07 14:56:50.738  - info: admin.0 iobroker 304 https://registry.npmjs.org/punycode
                    2014-09-07 14:56:57.522  - info: admin.0 iobroker got /opt/iobroker/adapter/hm-rega/admin
                    2014-09-07 14:56:57.559  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/index.html index.html text/html
                    2014-09-07 14:56:58.191  - info: admin.0 iobroker object system.adapter.hm-rega created
                    2014-09-07 14:56:58.343  - error: admin.0 iobroker
                    2014-09-07 14:56:58.366  - error: admin.0 iobroker TypeError: Cannot read property 'name' of undefined    at /opt/iobroker/setup.js:660:48
                        at /opt/iobroker/lib/couch.js:91:13
                        at Request._callback (/opt/iobroker/node_modules/nano/nano.js:303:11)
                        at Request.self.callback (/opt/iobroker/node_modules/nano/node_modules/request/request.js:122:22)
                        at Request.EventEmitter.emit (events.js:98:17)
                        at Request. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:888:14)
                        at Request.EventEmitter.emit (events.js:117:20)
                        at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:839:12)
                        at IncomingMessage.EventEmitter.emit (events.js:117:20)
                        at _stream_readable.js:920:16
                    2014-09-07 14:56:58.392  - info: admin.0 iobroker exit 8</anonymous></anonymous>
                    Ich freu mich auf die weitere Entwicklung! Es sieht jetzt schon richtig gut aus!
                    Viele Grüße
                    Trident
                      Ja, ich glaube wir haben bald einen Stand erreicht der die Versionsnummer 0.1.x verdient 😉
                      Dann kommt ein großer Brocken Arbeit: die Portierung von DashUI (das in Zukunft "ioBroker.vis" heissen wird).
                        Ich bin ja so bescheuert….. :evil:
                        ich hatte wegen des hängenden logs das WebUI gar nicht mehr aufgemacht - bis eben!
                        Da hat sich ja ne ganze menge getan:
                        Die Updates der Adapter (admin, hm-rega und hm-rpc) über das WebUI laufen jetzt einwandfrei.
                        Unter Instances sind die von mir installierten adapter auch drin - lediglich bei den Konfigurationsdaten, die ich über die couchDB eingegeben haben (IP-Adresse und Port) fehlen hier IP und port
                        Daher rührt dann wahrscheinlich auch der Error aus post #55
                        Ist diese Info nicht "bidirektional"?
                        Übernimmt ioBroker sie nicht, wenn ich sie in couchDB eintrage.
                        Was passiert, wenn ich sie im WebUI auch nochmal eintrage - und dann womöglich hm-rega.0 und hm-rega.1 vertausche?
                        Rainer
                          Hallo HQ,
                          @hobbyquaker:
                          Dann kommt ein großer Brocken Arbeit: die Portierung von DashUI (das in Zukunft "ioBroker.vis" heissen wird). `
                          Glückwunsch zur 0.1.0!!! 😛
                          Und viel Erfolg mit dem nächsten Schritt
                          Ich hatte gehofft mit dem legacy-Adapter so etwas hinzubekommen. Leider stürzt mir dann dieser dauernd ab.
                          Rainer
                            @Homoran:
                            Übernimmt ioBroker sie nicht, wenn ich sie in couchDB eintrage. `
                            Doch, es "sollte" eigentlich egal sein ob Du das im ioBroker.admin oder direkt in CouchDB-Futon machst. Wobei sowohl hm-rpc als auch hm-rega mittlerweile auch schon ein Konfigurations-UI haben (der Button rechts im Reiter instances)
                            @Homoran:
                            hm-rega.0 und hm-rega.1 `
                            Ich glaube da liegt noch ein Missverständnis vor. Du brauchst für eine CCU auch nur eine Instanz des hm-rega Adapters. Nur der hm-rpc ist unter Umständen (falls Du wired nutzt) 2x notwendig.
                            @Homoran:
                            Ich hätte versucht mit dem legacy-Adapter so etwas hinzubekommen. Leider stürzt mir dann dieser dauernd ab. `
                            Ja, an dem hab ich nicht mehr weitergemacht. Ich glaube ich schmeiss den wieder raus, die ursprüngliche Idee hier eine CCU.IO-kompatible Umgebung zu schaffen in der man einfach ein unverändertes DashUI/yahui laufen lassen kann ist wesentlich schwieriger zu verwirklichen als ich dachte…
                              Danke für die schnelle Antwort.
                              Damit es nicht zu Mißverständnissen kommt:
                              Ich hatte die IP-Adresse meiner CCU damals direkt in der couch-dB eingetragen.
                              …und da ich irrtümlich 2 Adapter angelegt habe - habe ich die IP-Adressen von 2 verschiedenen lxccu (eine produktiv - eine zum Testen) eingegeben - läuft prima!!!!!! 😄
                              Jetzt habe ich bei dem Button "Konfiguration" in der WebUI gesehen, dass da jetzt Daten hinterlegt sind - aber leider nicht die IP und der Port ( die sind leer)
                              @hobbyquaker:
                              Ja, an dem hab ich nicht mehr weitergemacht. Ich glaube ich schmeiss den wieder raus, die ursprüngliche Idee hier eine CCU.IO-kompatible Umgebung zu schaffen in der man einfach ein unverändertes DashUI/yahui laufen lassen kann ist wesentlich schwieriger zu verwirklichen als ich dachte… `
                              Dann erst recht "VIEL GLÜCK!"
                              Rainer
                                ich habe das Gefühl, dass die Installation noch etwas anfällig ist. Bei dem Versuch den hm-rega Adapter über das Admin-Interface zu installieren kam es zum oben genannten Fehler. Danach waren jedoch auf einmal alle anderen Instanzen (admin + hm-rpc) weg. Ist da eventuell was in der CouchDB im Datenmodell zerstört worden?
                                Bei einer Neuinstallation lösche ich derzeit immer alle Einträge der CouchDB und Redis-DB! Sollte in meinem Verständnis notwendig sein, damit keine "alten" Einträge die neue Installation stören, oder?
                                Bitte nicht missverstehen! Ich will nicht meckern oder so - bei dem aktuellen Stand der Software sind solche Macken normal! Ist wie immer nur ein Hinweis. Vielleicht liegt es ja auch an meiner Installation… Falls nicht, hilft es vielleicht bei der Bug-Suche.
                                Freu mich schon auf iobroker.vis 🙂
                                Viele Grüße
                                Trident
                                  noch ein kurzer Hinweis: Bei der Installation des hm-rega Adapters kommt es zu einer Fehlermeldung (sowohl übers Terminal, als auch übers admin-interface):
                                  npm http 304 https://registry.npmjs.org/boom
                                  upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/homematic.png homematic.png image/png
                                      at _stream_readable.js:920:16</anonymous></anonymous>
                                  Viele Grüße
                                  Trident
                                    Habe jetzt auch den history adapter installiert und auf true gesetzt - meine Daten, die ich loggen wollte füllen sich jedoch nicht.
                                    Dann habe ich die Timestamps der Datenpunkte angesehen.
                                    Die stammen alee vom 03.09. 😞
                                    Seit diesem Datum habe ich das Problem, dass rpc hängen bleibt.
                                    Rainer
                                      akamia last edited by
                                      Hi ,
                                      HQ und BF haben ganze Arbeit geleistet. Habe nur die Schritte der manuellen Installation nachvollzogen und es hat alles auf Anhieb geklappt mit Copy & Paste. Die Versionen sind jetzt auch in Farbe für einen informativen Überblick. Das Fundament macht schon einen guten Eindruck.
                                      Danke an Rainer, Trident und John dafür, dass Ihr die größten Stolpersteine beseitigt habt. Bin heute auch von RasPi auf CubieTruck umgestiegen. Jetzt laufen CCU.IO und ioBroker parallel - fehlt nur noch LXCCU.
                                      Gruß akamia
                                        @akamia:
                                        Danke an Rainer, Trident und John dafür, dass Ihr die größten Stolpersteine beseitigt habt. `
                                        Die Stolpersteine beseitigen HQ und Bluefox - nicht ich.
                                        Ich hab jetzt meine Installation mal platt gemacht, nachdem mein rpc-Adapter die Daten seit dem 03.09. nicht mehr updatete.
                                        jetzt gab es andere Probleme.
                                        Installation lief schön durch. Ohne ERROR-Meldungen.
                                        Ich habe auch jetzt die schönen "bunten" Administrationsseiten, und die Einstellungen im WebUI werden auch in die CouchDB übernommen - zumindest fast alle.
                                        Ich habe erst einmal einen hm-rega, einen hm-rpc und den history-Adapter angelegt.
                                        leider erscheint der hm-rega weder unter instances:
                                        noch in der couchDB:
                                        der log auf dem Cubie sah so aus:
                                        2014-09-14 12:33:36.568  - info: admin.0 iobroker add hm-rega
                                        2014-09-14 12:33:38.475  - info: admin.0 iobroker download https://github.com/ioBroker/ioBroker.hm-rega/archive/master.zip
                                        2014-09-14 12:33:40.135  - info: admin.0 iobroker unzip /opt/iobroker/tmp/hm-rega.zip
                                        2014-09-14 12:33:40.524  - info: admin.0 iobroker copying /opt/iobroker/tmp/ioBroker.hm-rega-master to /opt/iobroker/adapter/hm-rega
                                        2014-09-14 12:33:40.629  - info: admin.0 iobroker delete /opt/iobroker/tmp/hm-rega.zip
                                        2014-09-14 12:33:40.632  - info: admin.0 iobroker delete /opt/iobroker/tmp/ioBroker.hm-rega-master
                                        2014-09-14 12:33:42.519  - info: admin.0 iobroker install adapter hm-rega
                                        2014-09-14 12:33:42.537  - info: admin.0 iobroker npm install "/opt/iobroker/adapter/hm-rega" --production --prefix "/opt/iobroker/adapter/hm-rega"
                                        2014-09-14 12:33:45.815  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:45.844  - info: admin.0 iobroker
                                        2014-09-14 12:33:45.850  - info: admin.0 iobroker http
                                        2014-09-14 12:33:45.856  - info: admin.0 iobroker
                                        2014-09-14 12:33:45.870  - info: admin.0 iobroker GET https://registry.npmjs.org/request
                                        2014-09-14 12:33:46.149  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:46.152  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:46.155  - info: admin.0 iobroker  GET
                                        2014-09-14 12:33:46.158  - info: admin.0 iobroker  https://registry.npmjs.org/xml2js
                                        2014-09-14 12:33:46.206  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:46.210  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:46.216  - info: admin.0 iobroker  GET
                                        2014-09-14 12:33:46.220  - info: admin.0 iobroker  https://registry.npmjs.org/iconv-lite
                                        2014-09-14 12:33:46.243  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:46.247  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:46.250  - info: admin.0 iobroker  GET
                                        2014-09-14 12:33:46.254  - info: admin.0 iobroker  https://registry.npmjs.org/extend
                                        2014-09-14 12:33:46.756  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:46.761  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:46.766  - info: admin.0 iobroker 304 https://registry.npmjs.org/request
                                        2014-09-14 12:33:47.015  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:47.019  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:47.027  - info: admin.0 iobroker  200 https://registry.npmjs.org/xml2js
                                        2014-09-14 12:33:47.104  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:47.108  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:47.113  - info: admin.0 iobroker
                                        2014-09-14 12:33:47.119  - info: admin.0 iobroker 200 https://registry.npmjs.org/iconv-lite
                                        2014-09-14 12:33:47.262  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:47.266  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:47.270  - info: admin.0 iobroker  200
                                        2014-09-14 12:33:47.275  - info: admin.0 iobroker  https://registry.npmjs.org/extend
                                        2014-09-14 12:33:49.353  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.362  - info: admin.0 iobroker
                                        2014-09-14 12:33:49.366  - info: admin.0 iobroker http
                                        2014-09-14 12:33:49.371  - info: admin.0 iobroker GET https://registry.npmjs.org/forever-agent
                                        2014-09-14 12:33:49.403  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.407  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:49.411  - info: admin.0 iobroker GET https://registry.npmjs.org/form-data
                                        2014-09-14 12:33:49.438  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.442  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:49.447  - info: admin.0 iobroker  GET
                                        2014-09-14 12:33:49.451  - info: admin.0 iobroker  https://registry.npmjs.org/node-uuid
                                        2014-09-14 12:33:49.477  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.481  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:49.487  - info: admin.0 iobroker  GET https://registry.npmjs.org/tunnel-agent
                                        2014-09-14 12:33:49.531  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.536  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:49.540  - info: admin.0 iobroker GET
                                        2014-09-14 12:33:49.546  - info: admin.0 iobroker  https://registry.npmjs.org/tough-cookie
                                        2014-09-14 12:33:49.594  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.615  - info: admin.0 iobroker  http GET https://registry.npmjs.org/http-signaturenpm http GET https://registry.npmjs.org/oauth-sign
                                        2014-09-14 12:33:49.637  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.660  - info: admin.0 iobroker  http GET https://registry.npmjs.org/hawk
                                        2014-09-14 12:33:49.668  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.673  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:49.678  - info: admin.0 iobroker
                                        2014-09-14 12:33:49.683  - info: admin.0 iobroker GET https://registry.npmjs.org/aws-sign2
                                        2014-09-14 12:33:49.694  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.699  - info: admin.0 iobroker  http GET
                                        2014-09-14 12:33:49.704  - info: admin.0 iobroker  https://registry.npmjs.org/qs
                                        2014-09-14 12:33:49.712  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.718  - info: admin.0 iobroker  http GET https://registry.npmjs.org/json-stringify-safe
                                        2014-09-14 12:33:49.730  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:49.737  - info: admin.0 iobroker  http GET
                                        2014-09-14 12:33:49.742  - info: admin.0 iobroker  https://registry.npmjs.org/mime
                                        2014-09-14 12:33:50.053  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.058  - info: admin.0 iobroker  http GET
                                        2014-09-14 12:33:50.064  - info: admin.0 iobroker  https://registry.npmjs.org/sax
                                        2014-09-14 12:33:50.076  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.081  - info: admin.0 iobroker
                                        2014-09-14 12:33:50.086  - info: admin.0 iobroker http
                                        2014-09-14 12:33:50.091  - info: admin.0 iobroker  304 https://registry.npmjs.org/tough-cookie
                                        2014-09-14 12:33:50.109  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.113  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:50.118  - info: admin.0 iobroker GET https://registry.npmjs.org/xmlbuilder
                                        2014-09-14 12:33:50.197  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.203  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:50.207  - info: admin.0 iobroker  304 https://registry.npmjs.org/http-signature
                                        2014-09-14 12:33:50.273  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.278  - info: admin.0 iobroker  http 304
                                        2014-09-14 12:33:50.299  - info: admin.0 iobroker  https://registry.npmjs.org/node-uuid
                                        2014-09-14 12:33:50.317  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.321  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:50.332  - info: admin.0 iobroker 304 https://registry.npmjs.org/tunnel-agent
                                        2014-09-14 12:33:50.423  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.428  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:50.432  - info: admin.0 iobroker 304 https://registry.npmjs.org/aws-sign2
                                        2014-09-14 12:33:50.490  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.496  - info: admin.0 iobroker
                                        2014-09-14 12:33:50.503  - info: admin.0 iobroker http 304 https://registry.npmjs.org/forever-agent
                                        2014-09-14 12:33:50.529  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.534  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:50.545  - info: admin.0 iobroker 304 https://registry.npmjs.org/oauth-sign
                                        2014-09-14 12:33:50.587  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.592  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/json-stringify-safe
                                        2014-09-14 12:33:50.622  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.628  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:50.637  - info: admin.0 iobroker 304 https://registry.npmjs.org/hawk
                                        2014-09-14 12:33:50.648  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.656  - info: admin.0 iobroker http 304 https://registry.npmjs.org/mime
                                        2014-09-14 12:33:50.980  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:50.985  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:50.992  - info: admin.0 iobroker  304 https://registry.npmjs.org/form-data
                                        2014-09-14 12:33:51.003  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:51.010  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/qs
                                        2014-09-14 12:33:51.081  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:51.086  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:51.091  - info: admin.0 iobroker 200 https://registry.npmjs.org/xmlbuilder
                                        2014-09-14 12:33:51.418  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:51.422  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:51.434  - info: admin.0 iobroker GET https://registry.npmjs.org/xmlbuilder/-/xmlbuilder-2.4.4.tgz
                                        2014-09-14 12:33:52.095  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:52.098  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:52.102  - info: admin.0 iobroker  200 https://registry.npmjs.org/xmlbuilder/-/xmlbuilder-2.4.4.tgz
                                        2014-09-14 12:33:53.267  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:53.272  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:53.292  - info: admin.0 iobroker GET https://registry.npmjs.org/combined-stream
                                        2014-09-14 12:33:53.324  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:53.336  - info: admin.0 iobroker  http GET https://registry.npmjs.org/async
                                        2014-09-14 12:33:53.597  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:53.602  - info: admin.0 iobroker  http 304
                                        2014-09-14 12:33:53.608  - info: admin.0 iobroker  https://registry.npmjs.org/async
                                        2014-09-14 12:33:53.676  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:53.680  - info: admin.0 iobroker  http 200 https://registry.npmjs.org/sax
                                        2014-09-14 12:33:53.845  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:53.850  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/combined-stream
                                        2014-09-14 12:33:54.293  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:54.298  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:54.305  - info: admin.0 iobroker GET https://registry.npmjs.org/assert-plus/0.1.2
                                        2014-09-14 12:33:54.326  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:54.331  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:54.335  - info: admin.0 iobroker GET https://registry.npmjs.org/asn1/0.1.11
                                        2014-09-14 12:33:54.355  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:54.360  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:54.366  - info: admin.0 iobroker GET https://registry.npmjs.org/ctype/0.5.2
                                        2014-09-14 12:33:54.629  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:54.632  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:54.638  - info: admin.0 iobroker  304 https://registry.npmjs.org/assert-plus/0.1.2
                                        2014-09-14 12:33:54.672  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:54.675  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:54.686  - info: admin.0 iobroker  304 https://registry.npmjs.org/ctype/0.5.2
                                        2014-09-14 12:33:54.945  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:54.951  - info: admin.0 iobroker  http GET
                                        2014-09-14 12:33:54.956  - info: admin.0 iobroker  https://registry.npmjs.org/delayed-stream/0.0.5
                                        2014-09-14 12:33:55.428  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:55.432  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:55.436  - info: admin.0 iobroker  304 https://registry.npmjs.org/delayed-stream/0.0.5
                                        2014-09-14 12:33:56.022  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:56.026  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:56.031  - info: admin.0 iobroker 304 https://registry.npmjs.org/asn1/0.1.11
                                        2014-09-14 12:33:57.632  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:57.635  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:57.654  - info: admin.0 iobroker  GET https://registry.npmjs.org/punycode
                                        2014-09-14 12:33:57.926  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:57.930  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:57.934  - info: admin.0 iobroker  304 https://registry.npmjs.org/punycode
                                        2014-09-14 12:33:57.987  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:57.992  - info: admin.0 iobroker  http GET
                                        2014-09-14 12:33:57.996  - info: admin.0 iobroker  https://registry.npmjs.org/boom
                                        2014-09-14 12:33:58.014  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:58.022  - info: admin.0 iobroker  http GET https://registry.npmjs.org/cryptiles
                                        2014-09-14 12:33:58.042  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:58.047  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:58.051  - info: admin.0 iobroker GET https://registry.npmjs.org/sntp
                                        2014-09-14 12:33:58.084  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:58.088  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:58.093  - info: admin.0 iobroker GET https://registry.npmjs.org/hoek
                                        2014-09-14 12:33:58.318  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:58.322  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:58.327  - info: admin.0 iobroker 304 https://registry.npmjs.org/boom
                                        2014-09-14 12:33:58.438  - info: admin.0 iobroker npm
                                        2014-09-14 12:33:58.443  - info: admin.0 iobroker  http
                                        2014-09-14 12:33:58.450  - info: admin.0 iobroker  304 https://registry.npmjs.org/hoek
                                        2014-09-14 12:33:58.774  - info: admin.0 iobroker npm http 304 https://registry.npmjs.org/cryptiles
                                        2014-09-14 12:33:59.511  - info: admin.0 iobroker npm http
                                        2014-09-14 12:33:59.519  - info: admin.0 iobroker GET https://registry.npmjs.org/lodash-node
                                        2014-09-14 12:33:59.671  - info: admin.0 iobroker npm http 304 https://registry.npmjs.org/sntp
                                        2014-09-14 12:34:00.864  - info: admin.0 iobroker npm http 200
                                        2014-09-14 12:34:00.878  - info: admin.0 iobroker  https://registry.npmjs.org/lodash-node
                                        2014-09-14 12:34:07.079  - info: admin.0 iobroker got /opt/iobroker/adapter/hm-rega/admin
                                        2014-09-14 12:34:07.125  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/index.html index.html text/html
                                        2014-09-14 12:34:07.263  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/homematic.png homematic.png image/pn                         g
                                        2014-09-14 12:34:07.625  - info: admin.0 iobroker object system.adapter.hm-rega created
                                        Rainer
                                          John92648 last edited by
                                          Hallo Reiner,
                                          bzgl. des fehlenden HM_Rega muss erst der RPC komplett laufen und dann den Rega istallieren.
                                          Hat zumindest so bei mir funktioniert und so denke ich auch ist es beschrieben.
                                          Gruß John
                                            ok, dann muss ich es wohl nochmal neu machen, da mir jetzt alles abgeschmiert ist.
                                            Ich war über die Konsole rein und wollte mit ./iobroker del hm-rega den Adapter entfernen, um ihn neu zu installieren und bekam folgendes:
                                            root@cubie:/opt/iobroker# ./iobroker del hm-rega
                                            Deleted 0 states (hm-rega.*) from redis
                                            Deleted 0 states (system.adapter.hm-rega.*) from redis
                                            no devices hm-rega found
                                            deleted 3 instances of hm-rega
                                            deleted 0 states of hm-rega
                                            no channels hm-rega found
                                            delete /opt/iobroker/adapter/hm-rega
                                            deleted 24 adapters for hm-rega
                                            object hm-rega deleted
                                            object hm-rega.admin deleted
                                            Zeitgleich verschwanden fast alle Adapter aus der Installation.
                                            Nach dem Motto reboot tut gut neu gestartet - jetzt komme ich gar nicht mehr auf die WebUI drauf.
                                            Sei's drum: Auf ein neues 😉
                                            Rainer
                                            176
                                            39515
