    4. Installation ioBroker auf Cubietruck
      Trident last edited by
      Hi zusammen,
      jetzt klappt die Installation auch wieder! Klasse! Macht wirklich Spaß die Fortschritte zu beobachten!
      Ich habe mal die Installation der Adapter aus dem Admin-Interface getestet. Bei der Installation des HM-Rega Adapters kommt folgende Fehlermeldung:
      2014-09-07 14:56:49.973  - info: admin.0 iobroker npm
      2014-09-07 14:56:49.978  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/boom
      2014-09-07 14:56:50.013  - info: admin.0 iobroker npm
      2014-09-07 14:56:50.018  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/cryptiles
      2014-09-07 14:56:50.728  - info: admin.0 iobroker npm
      2014-09-07 14:56:50.733  - info: admin.0 iobroker  http
      2014-09-07 14:56:50.738  - info: admin.0 iobroker 304 https://registry.npmjs.org/punycode
      2014-09-07 14:56:57.522  - info: admin.0 iobroker got /opt/iobroker/adapter/hm-rega/admin
      2014-09-07 14:56:57.559  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/index.html index.html text/html
      2014-09-07 14:56:58.191  - info: admin.0 iobroker object system.adapter.hm-rega created
      2014-09-07 14:56:58.343  - error: admin.0 iobroker
      2014-09-07 14:56:58.366  - error: admin.0 iobroker TypeError: Cannot read property 'name' of undefined    at /opt/iobroker/setup.js:660:48
          at /opt/iobroker/lib/couch.js:91:13
          at Request._callback (/opt/iobroker/node_modules/nano/nano.js:303:11)
          at Request.self.callback (/opt/iobroker/node_modules/nano/node_modules/request/request.js:122:22)
          at Request.EventEmitter.emit (events.js:98:17)
          at Request. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:888:14)
          at Request.EventEmitter.emit (events.js:117:20)
          at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:839:12)
          at IncomingMessage.EventEmitter.emit (events.js:117:20)
          at _stream_readable.js:920:16
      2014-09-07 14:56:58.392  - info: admin.0 iobroker exit 8</anonymous></anonymous>
      Ich freu mich auf die weitere Entwicklung! Es sieht jetzt schon richtig gut aus!
      Viele Grüße
      Trident
        hobbyquaker last edited by
        Ja, ich glaube wir haben bald einen Stand erreicht der die Versionsnummer 0.1.x verdient 😉
        Dann kommt ein großer Brocken Arbeit: die Portierung von DashUI (das in Zukunft "ioBroker.vis" heissen wird).
          Ich bin ja so bescheuert….. :evil:
          ich hatte wegen des hängenden logs das WebUI gar nicht mehr aufgemacht - bis eben!
          Da hat sich ja ne ganze menge getan:
          Die Updates der Adapter (admin, hm-rega und hm-rpc) über das WebUI laufen jetzt einwandfrei.
          Unter Instances sind die von mir installierten adapter auch drin - lediglich bei den Konfigurationsdaten, die ich über die couchDB eingegeben haben (IP-Adresse und Port) fehlen hier IP und port
          Daher rührt dann wahrscheinlich auch der Error aus post #55
          Ist diese Info nicht "bidirektional"?
          Übernimmt ioBroker sie nicht, wenn ich sie in couchDB eintrage.
          Was passiert, wenn ich sie im WebUI auch nochmal eintrage - und dann womöglich hm-rega.0 und hm-rega.1 vertausche?
          Rainer
            Hallo HQ,
            @hobbyquaker:
            Dann kommt ein großer Brocken Arbeit: die Portierung von DashUI (das in Zukunft "ioBroker.vis" heissen wird). `
            Glückwunsch zur 0.1.0!!! 😛
            Und viel Erfolg mit dem nächsten Schritt
            Ich hatte gehofft mit dem legacy-Adapter so etwas hinzubekommen. Leider stürzt mir dann dieser dauernd ab.
            Rainer
              @Homoran:
              Übernimmt ioBroker sie nicht, wenn ich sie in couchDB eintrage. `
              Doch, es "sollte" eigentlich egal sein ob Du das im ioBroker.admin oder direkt in CouchDB-Futon machst. Wobei sowohl hm-rpc als auch hm-rega mittlerweile auch schon ein Konfigurations-UI haben (der Button rechts im Reiter instances)
              @Homoran:
              hm-rega.0 und hm-rega.1 `
              Ich glaube da liegt noch ein Missverständnis vor. Du brauchst für eine CCU auch nur eine Instanz des hm-rega Adapters. Nur der hm-rpc ist unter Umständen (falls Du wired nutzt) 2x notwendig.
              @Homoran:
              Ich hätte versucht mit dem legacy-Adapter so etwas hinzubekommen. Leider stürzt mir dann dieser dauernd ab. `
              Ja, an dem hab ich nicht mehr weitergemacht. Ich glaube ich schmeiss den wieder raus, die ursprüngliche Idee hier eine CCU.IO-kompatible Umgebung zu schaffen in der man einfach ein unverändertes DashUI/yahui laufen lassen kann ist wesentlich schwieriger zu verwirklichen als ich dachte…
                Danke für die schnelle Antwort.
                Damit es nicht zu Mißverständnissen kommt:
                Ich hatte die IP-Adresse meiner CCU damals direkt in der couch-dB eingetragen.
                …und da ich irrtümlich 2 Adapter angelegt habe - habe ich die IP-Adressen von 2 verschiedenen lxccu (eine produktiv - eine zum Testen) eingegeben - läuft prima!!!!!! 😄
                Jetzt habe ich bei dem Button "Konfiguration" in der WebUI gesehen, dass da jetzt Daten hinterlegt sind - aber leider nicht die IP und der Port ( die sind leer)
                @hobbyquaker:
                Ja, an dem hab ich nicht mehr weitergemacht. Ich glaube ich schmeiss den wieder raus, die ursprüngliche Idee hier eine CCU.IO-kompatible Umgebung zu schaffen in der man einfach ein unverändertes DashUI/yahui laufen lassen kann ist wesentlich schwieriger zu verwirklichen als ich dachte… `
                Dann erst recht "VIEL GLÜCK!"
                Rainer
                  ich habe das Gefühl, dass die Installation noch etwas anfällig ist. Bei dem Versuch den hm-rega Adapter über das Admin-Interface zu installieren kam es zum oben genannten Fehler. Danach waren jedoch auf einmal alle anderen Instanzen (admin + hm-rpc) weg. Ist da eventuell was in der CouchDB im Datenmodell zerstört worden?
                  Bei einer Neuinstallation lösche ich derzeit immer alle Einträge der CouchDB und Redis-DB! Sollte in meinem Verständnis notwendig sein, damit keine "alten" Einträge die neue Installation stören, oder?
                  Bitte nicht missverstehen! Ich will nicht meckern oder so - bei dem aktuellen Stand der Software sind solche Macken normal! Ist wie immer nur ein Hinweis. Vielleicht liegt es ja auch an meiner Installation… Falls nicht, hilft es vielleicht bei der Bug-Suche.
                  Freu mich schon auf iobroker.vis 🙂
                  Viele Grüße
                  Trident
                    noch ein kurzer Hinweis: Bei der Installation des hm-rega Adapters kommt es zu einer Fehlermeldung (sowohl übers Terminal, als auch übers admin-interface):
                    npm http 304 https://registry.npmjs.org/boom
                    upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/homematic.png homematic.png image/png
                        at _stream_readable.js:920:16</anonymous></anonymous>
                    Viele Grüße
                    Trident
                      Habe jetzt auch den history adapter installiert und auf true gesetzt - meine Daten, die ich loggen wollte füllen sich jedoch nicht.
                      Dann habe ich die Timestamps der Datenpunkte angesehen.
                      Die stammen alee vom 03.09. 😞
                      Seit diesem Datum habe ich das Problem, dass rpc hängen bleibt.
                      Rainer
                        akamia last edited by
                        Hi ,
                        HQ und BF haben ganze Arbeit geleistet. Habe nur die Schritte der manuellen Installation nachvollzogen und es hat alles auf Anhieb geklappt mit Copy & Paste. Die Versionen sind jetzt auch in Farbe für einen informativen Überblick. Das Fundament macht schon einen guten Eindruck.
                        Danke an Rainer, Trident und John dafür, dass Ihr die größten Stolpersteine beseitigt habt. Bin heute auch von RasPi auf CubieTruck umgestiegen. Jetzt laufen CCU.IO und ioBroker parallel - fehlt nur noch LXCCU.
                        Gruß akamia
                          @akamia:
                          Danke an Rainer, Trident und John dafür, dass Ihr die größten Stolpersteine beseitigt habt. `
                          Die Stolpersteine beseitigen HQ und Bluefox - nicht ich.
                          Ich hab jetzt meine Installation mal platt gemacht, nachdem mein rpc-Adapter die Daten seit dem 03.09. nicht mehr updatete.
                          jetzt gab es andere Probleme.
                          Installation lief schön durch. Ohne ERROR-Meldungen.
                          Ich habe auch jetzt die schönen "bunten" Administrationsseiten, und die Einstellungen im WebUI werden auch in die CouchDB übernommen - zumindest fast alle.
                          Ich habe erst einmal einen hm-rega, einen hm-rpc und den history-Adapter angelegt.
                          leider erscheint der hm-rega weder unter instances:
                          noch in der couchDB:
                          der log auf dem Cubie sah so aus:
                          2014-09-14 12:33:36.568  - info: admin.0 iobroker add hm-rega
                          2014-09-14 12:33:38.475  - info: admin.0 iobroker download https://github.com/ioBroker/ioBroker.hm-rega/archive/master.zip
                          2014-09-14 12:33:40.135  - info: admin.0 iobroker unzip /opt/iobroker/tmp/hm-rega.zip
                          2014-09-14 12:33:40.524  - info: admin.0 iobroker copying /opt/iobroker/tmp/ioBroker.hm-rega-master to /opt/iobroker/adapter/hm-rega
                          2014-09-14 12:33:40.629  - info: admin.0 iobroker delete /opt/iobroker/tmp/hm-rega.zip
                          2014-09-14 12:33:40.632  - info: admin.0 iobroker delete /opt/iobroker/tmp/ioBroker.hm-rega-master
                          2014-09-14 12:33:42.519  - info: admin.0 iobroker install adapter hm-rega
                          2014-09-14 12:33:42.537  - info: admin.0 iobroker npm install "/opt/iobroker/adapter/hm-rega" --production --prefix "/opt/iobroker/adapter/hm-rega"
                          2014-09-14 12:33:45.815  - info: admin.0 iobroker npm
                          2014-09-14 12:33:45.844  - info: admin.0 iobroker
                          2014-09-14 12:33:45.850  - info: admin.0 iobroker http
                          2014-09-14 12:33:45.856  - info: admin.0 iobroker
                          2014-09-14 12:33:45.870  - info: admin.0 iobroker GET https://registry.npmjs.org/request
                          2014-09-14 12:33:46.149  - info: admin.0 iobroker npm
                          2014-09-14 12:33:46.152  - info: admin.0 iobroker  http
                          2014-09-14 12:33:46.155  - info: admin.0 iobroker  GET
                          2014-09-14 12:33:46.158  - info: admin.0 iobroker  https://registry.npmjs.org/xml2js
                          2014-09-14 12:33:46.206  - info: admin.0 iobroker npm
                          2014-09-14 12:33:46.210  - info: admin.0 iobroker  http
                          2014-09-14 12:33:46.216  - info: admin.0 iobroker  GET
                          2014-09-14 12:33:46.220  - info: admin.0 iobroker  https://registry.npmjs.org/iconv-lite
                          2014-09-14 12:33:46.243  - info: admin.0 iobroker npm
                          2014-09-14 12:33:46.247  - info: admin.0 iobroker  http
                          2014-09-14 12:33:46.250  - info: admin.0 iobroker  GET
                          2014-09-14 12:33:46.254  - info: admin.0 iobroker  https://registry.npmjs.org/extend
                          2014-09-14 12:33:46.756  - info: admin.0 iobroker npm
                          2014-09-14 12:33:46.761  - info: admin.0 iobroker  http
                          2014-09-14 12:33:46.766  - info: admin.0 iobroker 304 https://registry.npmjs.org/request
                          2014-09-14 12:33:47.015  - info: admin.0 iobroker npm
                          2014-09-14 12:33:47.019  - info: admin.0 iobroker  http
                          2014-09-14 12:33:47.027  - info: admin.0 iobroker  200 https://registry.npmjs.org/xml2js
                          2014-09-14 12:33:47.104  - info: admin.0 iobroker npm
                          2014-09-14 12:33:47.108  - info: admin.0 iobroker  http
                          2014-09-14 12:33:47.113  - info: admin.0 iobroker
                          2014-09-14 12:33:47.119  - info: admin.0 iobroker 200 https://registry.npmjs.org/iconv-lite
                          2014-09-14 12:33:47.262  - info: admin.0 iobroker npm
                          2014-09-14 12:33:47.266  - info: admin.0 iobroker  http
                          2014-09-14 12:33:47.270  - info: admin.0 iobroker  200
                          2014-09-14 12:33:47.275  - info: admin.0 iobroker  https://registry.npmjs.org/extend
                          2014-09-14 12:33:49.353  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.362  - info: admin.0 iobroker
                          2014-09-14 12:33:49.366  - info: admin.0 iobroker http
                          2014-09-14 12:33:49.371  - info: admin.0 iobroker GET https://registry.npmjs.org/forever-agent
                          2014-09-14 12:33:49.403  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.407  - info: admin.0 iobroker  http
                          2014-09-14 12:33:49.411  - info: admin.0 iobroker GET https://registry.npmjs.org/form-data
                          2014-09-14 12:33:49.438  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.442  - info: admin.0 iobroker  http
                          2014-09-14 12:33:49.447  - info: admin.0 iobroker  GET
                          2014-09-14 12:33:49.451  - info: admin.0 iobroker  https://registry.npmjs.org/node-uuid
                          2014-09-14 12:33:49.477  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.481  - info: admin.0 iobroker  http
                          2014-09-14 12:33:49.487  - info: admin.0 iobroker  GET https://registry.npmjs.org/tunnel-agent
                          2014-09-14 12:33:49.531  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.536  - info: admin.0 iobroker  http
                          2014-09-14 12:33:49.540  - info: admin.0 iobroker GET
                          2014-09-14 12:33:49.546  - info: admin.0 iobroker  https://registry.npmjs.org/tough-cookie
                          2014-09-14 12:33:49.594  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.615  - info: admin.0 iobroker  http GET https://registry.npmjs.org/http-signaturenpm http GET https://registry.npmjs.org/oauth-sign
                          2014-09-14 12:33:49.637  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.660  - info: admin.0 iobroker  http GET https://registry.npmjs.org/hawk
                          2014-09-14 12:33:49.668  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.673  - info: admin.0 iobroker  http
                          2014-09-14 12:33:49.678  - info: admin.0 iobroker
                          2014-09-14 12:33:49.683  - info: admin.0 iobroker GET https://registry.npmjs.org/aws-sign2
                          2014-09-14 12:33:49.694  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.699  - info: admin.0 iobroker  http GET
                          2014-09-14 12:33:49.704  - info: admin.0 iobroker  https://registry.npmjs.org/qs
                          2014-09-14 12:33:49.712  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.718  - info: admin.0 iobroker  http GET https://registry.npmjs.org/json-stringify-safe
                          2014-09-14 12:33:49.730  - info: admin.0 iobroker npm
                          2014-09-14 12:33:49.737  - info: admin.0 iobroker  http GET
                          2014-09-14 12:33:49.742  - info: admin.0 iobroker  https://registry.npmjs.org/mime
                          2014-09-14 12:33:50.053  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.058  - info: admin.0 iobroker  http GET
                          2014-09-14 12:33:50.064  - info: admin.0 iobroker  https://registry.npmjs.org/sax
                          2014-09-14 12:33:50.076  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.081  - info: admin.0 iobroker
                          2014-09-14 12:33:50.086  - info: admin.0 iobroker http
                          2014-09-14 12:33:50.091  - info: admin.0 iobroker  304 https://registry.npmjs.org/tough-cookie
                          2014-09-14 12:33:50.109  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.113  - info: admin.0 iobroker  http
                          2014-09-14 12:33:50.118  - info: admin.0 iobroker GET https://registry.npmjs.org/xmlbuilder
                          2014-09-14 12:33:50.197  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.203  - info: admin.0 iobroker  http
                          2014-09-14 12:33:50.207  - info: admin.0 iobroker  304 https://registry.npmjs.org/http-signature
                          2014-09-14 12:33:50.273  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.278  - info: admin.0 iobroker  http 304
                          2014-09-14 12:33:50.299  - info: admin.0 iobroker  https://registry.npmjs.org/node-uuid
                          2014-09-14 12:33:50.317  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.321  - info: admin.0 iobroker  http
                          2014-09-14 12:33:50.332  - info: admin.0 iobroker 304 https://registry.npmjs.org/tunnel-agent
                          2014-09-14 12:33:50.423  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.428  - info: admin.0 iobroker  http
                          2014-09-14 12:33:50.432  - info: admin.0 iobroker 304 https://registry.npmjs.org/aws-sign2
                          2014-09-14 12:33:50.490  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.496  - info: admin.0 iobroker
                          2014-09-14 12:33:50.503  - info: admin.0 iobroker http 304 https://registry.npmjs.org/forever-agent
                          2014-09-14 12:33:50.529  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.534  - info: admin.0 iobroker  http
                          2014-09-14 12:33:50.545  - info: admin.0 iobroker 304 https://registry.npmjs.org/oauth-sign
                          2014-09-14 12:33:50.587  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.592  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/json-stringify-safe
                          2014-09-14 12:33:50.622  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.628  - info: admin.0 iobroker  http
                          2014-09-14 12:33:50.637  - info: admin.0 iobroker 304 https://registry.npmjs.org/hawk
                          2014-09-14 12:33:50.648  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.656  - info: admin.0 iobroker http 304 https://registry.npmjs.org/mime
                          2014-09-14 12:33:50.980  - info: admin.0 iobroker npm
                          2014-09-14 12:33:50.985  - info: admin.0 iobroker  http
                          2014-09-14 12:33:50.992  - info: admin.0 iobroker  304 https://registry.npmjs.org/form-data
                          2014-09-14 12:33:51.003  - info: admin.0 iobroker npm
                          2014-09-14 12:33:51.010  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/qs
                          2014-09-14 12:33:51.081  - info: admin.0 iobroker npm
                          2014-09-14 12:33:51.086  - info: admin.0 iobroker  http
                          2014-09-14 12:33:51.091  - info: admin.0 iobroker 200 https://registry.npmjs.org/xmlbuilder
                          2014-09-14 12:33:51.418  - info: admin.0 iobroker npm
                          2014-09-14 12:33:51.422  - info: admin.0 iobroker  http
                          2014-09-14 12:33:51.434  - info: admin.0 iobroker GET https://registry.npmjs.org/xmlbuilder/-/xmlbuilder-2.4.4.tgz
                          2014-09-14 12:33:52.095  - info: admin.0 iobroker npm
                          2014-09-14 12:33:52.098  - info: admin.0 iobroker  http
                          2014-09-14 12:33:52.102  - info: admin.0 iobroker  200 https://registry.npmjs.org/xmlbuilder/-/xmlbuilder-2.4.4.tgz
                          2014-09-14 12:33:53.267  - info: admin.0 iobroker npm
                          2014-09-14 12:33:53.272  - info: admin.0 iobroker  http
                          2014-09-14 12:33:53.292  - info: admin.0 iobroker GET https://registry.npmjs.org/combined-stream
                          2014-09-14 12:33:53.324  - info: admin.0 iobroker npm
                          2014-09-14 12:33:53.336  - info: admin.0 iobroker  http GET https://registry.npmjs.org/async
                          2014-09-14 12:33:53.597  - info: admin.0 iobroker npm
                          2014-09-14 12:33:53.602  - info: admin.0 iobroker  http 304
                          2014-09-14 12:33:53.608  - info: admin.0 iobroker  https://registry.npmjs.org/async
                          2014-09-14 12:33:53.676  - info: admin.0 iobroker npm
                          2014-09-14 12:33:53.680  - info: admin.0 iobroker  http 200 https://registry.npmjs.org/sax
                          2014-09-14 12:33:53.845  - info: admin.0 iobroker npm
                          2014-09-14 12:33:53.850  - info: admin.0 iobroker  http 304 https://registry.npmjs.org/combined-stream
                          2014-09-14 12:33:54.293  - info: admin.0 iobroker npm
                          2014-09-14 12:33:54.298  - info: admin.0 iobroker  http
                          2014-09-14 12:33:54.305  - info: admin.0 iobroker GET https://registry.npmjs.org/assert-plus/0.1.2
                          2014-09-14 12:33:54.326  - info: admin.0 iobroker npm
                          2014-09-14 12:33:54.331  - info: admin.0 iobroker  http
                          2014-09-14 12:33:54.335  - info: admin.0 iobroker GET https://registry.npmjs.org/asn1/0.1.11
                          2014-09-14 12:33:54.355  - info: admin.0 iobroker npm
                          2014-09-14 12:33:54.360  - info: admin.0 iobroker  http
                          2014-09-14 12:33:54.366  - info: admin.0 iobroker GET https://registry.npmjs.org/ctype/0.5.2
                          2014-09-14 12:33:54.629  - info: admin.0 iobroker npm
                          2014-09-14 12:33:54.632  - info: admin.0 iobroker  http
                          2014-09-14 12:33:54.638  - info: admin.0 iobroker  304 https://registry.npmjs.org/assert-plus/0.1.2
                          2014-09-14 12:33:54.672  - info: admin.0 iobroker npm
                          2014-09-14 12:33:54.675  - info: admin.0 iobroker  http
                          2014-09-14 12:33:54.686  - info: admin.0 iobroker  304 https://registry.npmjs.org/ctype/0.5.2
                          2014-09-14 12:33:54.945  - info: admin.0 iobroker npm
                          2014-09-14 12:33:54.951  - info: admin.0 iobroker  http GET
                          2014-09-14 12:33:54.956  - info: admin.0 iobroker  https://registry.npmjs.org/delayed-stream/0.0.5
                          2014-09-14 12:33:55.428  - info: admin.0 iobroker npm
                          2014-09-14 12:33:55.432  - info: admin.0 iobroker  http
                          2014-09-14 12:33:55.436  - info: admin.0 iobroker  304 https://registry.npmjs.org/delayed-stream/0.0.5
                          2014-09-14 12:33:56.022  - info: admin.0 iobroker npm
                          2014-09-14 12:33:56.026  - info: admin.0 iobroker  http
                          2014-09-14 12:33:56.031  - info: admin.0 iobroker 304 https://registry.npmjs.org/asn1/0.1.11
                          2014-09-14 12:33:57.632  - info: admin.0 iobroker npm
                          2014-09-14 12:33:57.635  - info: admin.0 iobroker  http
                          2014-09-14 12:33:57.654  - info: admin.0 iobroker  GET https://registry.npmjs.org/punycode
                          2014-09-14 12:33:57.926  - info: admin.0 iobroker npm
                          2014-09-14 12:33:57.930  - info: admin.0 iobroker  http
                          2014-09-14 12:33:57.934  - info: admin.0 iobroker  304 https://registry.npmjs.org/punycode
                          2014-09-14 12:33:57.987  - info: admin.0 iobroker npm
                          2014-09-14 12:33:57.992  - info: admin.0 iobroker  http GET
                          2014-09-14 12:33:57.996  - info: admin.0 iobroker  https://registry.npmjs.org/boom
                          2014-09-14 12:33:58.014  - info: admin.0 iobroker npm
                          2014-09-14 12:33:58.022  - info: admin.0 iobroker  http GET https://registry.npmjs.org/cryptiles
                          2014-09-14 12:33:58.042  - info: admin.0 iobroker npm
                          2014-09-14 12:33:58.047  - info: admin.0 iobroker  http
                          2014-09-14 12:33:58.051  - info: admin.0 iobroker GET https://registry.npmjs.org/sntp
                          2014-09-14 12:33:58.084  - info: admin.0 iobroker npm
                          2014-09-14 12:33:58.088  - info: admin.0 iobroker  http
                          2014-09-14 12:33:58.093  - info: admin.0 iobroker GET https://registry.npmjs.org/hoek
                          2014-09-14 12:33:58.318  - info: admin.0 iobroker npm
                          2014-09-14 12:33:58.322  - info: admin.0 iobroker  http
                          2014-09-14 12:33:58.327  - info: admin.0 iobroker 304 https://registry.npmjs.org/boom
                          2014-09-14 12:33:58.438  - info: admin.0 iobroker npm
                          2014-09-14 12:33:58.443  - info: admin.0 iobroker  http
                          2014-09-14 12:33:58.450  - info: admin.0 iobroker  304 https://registry.npmjs.org/hoek
                          2014-09-14 12:33:58.774  - info: admin.0 iobroker npm http 304 https://registry.npmjs.org/cryptiles
                          2014-09-14 12:33:59.511  - info: admin.0 iobroker npm http
                          2014-09-14 12:33:59.519  - info: admin.0 iobroker GET https://registry.npmjs.org/lodash-node
                          2014-09-14 12:33:59.671  - info: admin.0 iobroker npm http 304 https://registry.npmjs.org/sntp
                          2014-09-14 12:34:00.864  - info: admin.0 iobroker npm http 200
                          2014-09-14 12:34:00.878  - info: admin.0 iobroker  https://registry.npmjs.org/lodash-node
                          2014-09-14 12:34:07.079  - info: admin.0 iobroker got /opt/iobroker/adapter/hm-rega/admin
                          2014-09-14 12:34:07.125  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/index.html index.html text/html
                          2014-09-14 12:34:07.263  - info: admin.0 iobroker upload hm-rega.admin /opt/iobroker/adapter/hm-rega/admin/homematic.png homematic.png image/pn                         g
                          2014-09-14 12:34:07.625  - info: admin.0 iobroker object system.adapter.hm-rega created
                          Rainer
                            John92648 last edited by
                            Hallo Reiner,
                            bzgl. des fehlenden HM_Rega muss erst der RPC komplett laufen und dann den Rega istallieren.
                            Hat zumindest so bei mir funktioniert und so denke ich auch ist es beschrieben.
                            Gruß John
                              ok, dann muss ich es wohl nochmal neu machen, da mir jetzt alles abgeschmiert ist.
                              Ich war über die Konsole rein und wollte mit ./iobroker del hm-rega den Adapter entfernen, um ihn neu zu installieren und bekam folgendes:
                              root@cubie:/opt/iobroker# ./iobroker del hm-rega
                              Deleted 0 states (hm-rega.*) from redis
                              Deleted 0 states (system.adapter.hm-rega.*) from redis
                              no devices hm-rega found
                              deleted 3 instances of hm-rega
                              deleted 0 states of hm-rega
                              no channels hm-rega found
                              delete /opt/iobroker/adapter/hm-rega
                              deleted 24 adapters for hm-rega
                              object hm-rega deleted
                              object hm-rega.admin deleted
                              Zeitgleich verschwanden fast alle Adapter aus der Installation.
                              Nach dem Motto reboot tut gut neu gestartet - jetzt komme ich gar nicht mehr auf die WebUI drauf.
                              Sei's drum: Auf ein neues 😉
                              Rainer
                                Ok, läuft jetzt wieder
                                Habe diesmal erst einen rpc-Adapter aktiviert und dann den hm-rega-Adapter.
                                Danach hatte ich dann zwei rpc-Adapter :shock:
                                Ob das noch eine Leiche war, glaube ich nicht, da ich redis und couchdb komplett deinstalliert hatte und auch den ioBroker-Ordner gelöscht.
                                Bei der Konfig vom rega sah ich dann dass für RF, RS485 und Cux drei rpc benötigt werden. vielleicht wird automatisch ein weiterer angelegt ???
                                bei 2 CCU muss ich dann 6 rpc-Adapter haben?
                                • und 2x rega
                                Daten werden jetzt auch wieder gesammelt - sind allerdings nur noch 8 Seiten States (früher 13).
                                Bei der Installation nur noch sehr wenige "warn" wegen "common role missing" - aber einige sind noch da 😉 (braucht ihr noch nähere infos?)
                                Für die (ferne) Zukunft noch ein paar Wünsche zum Instances - Tab
                                Beim Aktivieren vergesse ich jedesmal nach dem Setzen des Hakens auch noch "Enter" zu drücken. dort noch einen Save-Button oder so hinzufügen ???
                                Hier oder bei Adaptern auch noch einen delete-Button für Instances.
                                Aber ihr bastelt ja schneller als man alles finden kann - Wahnsinn
                                Rainer
                                  Habe jetzt mal versucht den DWD-Adapter anzulegen.
                                  In der Konfig hatte ich die 0 * * * * als Cronjob interpretiert und zuerst irrtüblich gegen 15 * * * * (statt */15 * * * *) getauscht.
                                  es passierte natürlich zunächst nichts.
                                  Also habe ich erst einmal einen reboot gemacht. Der anschließende Log zeigte folgendes:
                                  root@cubie:/opt/iobroker# tail -f log/iobroker.log
                                  2014-09-18 18:55:48.981  - info: controller couchdb connected
                                  2014-09-18 18:55:50.459  - info: controller 6 instances found
                                  2014-09-18 18:55:50.462  - info: controller starting 5 instances
                                  2014-09-18 18:55:50.505  - info: controller instance system.adapter.admin.0 started with pid 2438
                                  2014-09-18 18:55:54.498  - info: controller instance scheduled system.adapter.dwd.0 15 * * * *
                                  2014-09-18 18:55:56.928  - info: admin.0 starting
                                  2014-09-18 18:55:57.101  - info: admin.0 requesting all states
                                  2014-09-18 18:55:57.114  - info: admin.0 requesting all objects
                                  2014-09-18 18:55:57.151  - info: admin.0 http server listening on port 8081
                                  2014-09-18 18:56:31.301  - info: hm-rpc.0 object hm-rpc.0.JEQ0466609:3.PRESS_LONG_RELEASE created
                                  2014-09-18 18:56:31.620  - info: hm-rpc.0 object hm-rpc.0.JEQ0466609:3.PRESS_LONG created
                                  2014-09-18 18:56:31.631  - info: hm-rpc.0 object hm-rpc.0.JEQ0466609:3.PRESS_SHORT created
                                  2014-09-18 18:56:31.655  - info: hm-rpc.0 object hm-rpc.0.JEQ0466609:3.PRESS_CONT created
                                  2014-09-18 18:56:31.882  - error: hm-rpc.0 object hm-rpc.0.JEQ0466609:3 extend: Error: Document update conflict.
                                  2014-09-18 18:57:05.090  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:1 to "3_fach_01:1"
                                  2014-09-18 18:57:05.286  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:0 to "3_fach_01:0"
                                  2014-09-18 18:57:10.642  - info: hm-rega.0 got 63 programs
                                  2014-09-18 18:57:11.606  - info: hm-rega.0 added/updated 60 programs
                                  2014-09-18 18:57:11.619  - info: hm-rega.0 deleted 3 programs
                                  2014-09-18 18:57:15.013  - info: hm-rega.0 got 58 variables
                                  2014-09-18 18:57:16.059  - info: hm-rega.0 added/updated 58 variables
                                  2014-09-18 18:57:16.061  - info: hm-rega.0 deleted 0 variables
                                  2014-09-18 18:57:16.069  - info: hm-rega.0 request state values
                                  2014-09-18 18:57:18.401  - info: hm-rega.0 got state values
                                  wobei die Daten im Admin (Objekte) für hm-rpc.0.JEQ0466609:3 anscheinend korrekt eingetragen sind???
                                  Um 19:15 (ich hatte 15:10 erwartet - und dann den Cronjob geändert) kamen folgende Fehlermeldungen:
                                  2014-09-18 19:15:04.196  - info: dwd.0 starting
                                  2014-09-18 19:15:04.776  - info: dwd.0 setting states
                                  2014-09-18 19:15:04.794  - error: dwd.0 uncaught exception: stop is not defined
                                  2014-09-18 19:15:04.797  - error: dwd.0 ReferenceError: stop is not defined
                                      at received (/opt/iobroker/adapter/dwd/dwd.js:187:16)
                                      at getFile (/opt/iobroker/adapter/dwd/dwd.js:85:9)
                                      at /opt/iobroker/adapter/dwd/dwd.js:70:17
                                      at /opt/iobroker/adapter/dwd/node_modules/jsftp/node_modules/parse-listing/src/parser.js:147:19
                                      at /opt/iobroker/adapter/dwd/node_modules/jsftp/node_modules/parse-listing/node_modules/async/lib/async.js:142:25
                                      at _next (/opt/iobroker/adapter/dwd/node_modules/jsftp/node_modules/parse-listing/src/parser.js:108:7)
                                      at /opt/iobroker/adapter/dwd/node_modules/jsftp/node_modules/parse-listing/src/parser.js:123:14
                                      at iterate (/opt/iobroker/adapter/dwd/node_modules/jsftp/node_modules/parse-listing/node_modules/async/lib/async.js:134:13)
                                      at /opt/iobroker/adapter/dwd/node_modules/jsftp/node_modules/parse-listing/node_modules/async/lib/async.js:145:25
                                  2014-09-18 19:15:05.124  - error: controller instance system.adapter.dwd.0 terminated with code 1
                                  dito um 19:30
                                  Die settings habe ich aus dem ccu.io Adapter übernommen (nur der Kreis wird nicht mehr angegeben)
                                  Rainer
                                    Auf einmal läuft der DWD adapter ohne Fehler:
                                    2014-09-19 16:00:00.741  - info: controller instance system.adapter.dwd.0 started with pid 7465
                                    2014-09-19 16:00:04.366  - info: dwd.0 starting
                                    2014-09-19 16:00:05.416  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919131754_OMEDES_WWEM38_KXXX.xml
                                    2014-09-19 16:00:05.568  - info: dwd.0 got weather warning
                                    2014-09-19 16:00:06.576  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919133715_OMEDES_WUEM46_KXXX.xml
                                    2014-09-19 16:00:06.712  - info: dwd.0 got weather warning
                                    2014-09-19 16:00:07.826  - info: dwd.0 setting states
                                    2014-09-19 16:00:07.842  - error: dwd.0 uncaught exception: stop is not defined
                                    2014-09-19 16:00:07.856  - error: dwd.0 ReferenceError: stop is not defined
                                        at null. <anonymous>(/opt/iobroker/adapter/dwd/dwd.js:109:17)
                                        at timer._onTimeout (timers.js:210:16)
                                        at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
                                    2014-09-19 16:00:08.183  - error: controller instance system.adapter.dwd.0 terminated with code 1
                                    2014-09-19 16:15:00.725  - info: controller instance system.adapter.dwd.0 started with pid 7520
                                    2014-09-19 16:15:04.431  - info: dwd.0 starting
                                    2014-09-19 16:15:05.120  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919131754_OMEDES_WWEM38_KXXX.xml
                                    2014-09-19 16:15:05.270  - info: dwd.0 got weather warning
                                    2014-09-19 16:15:06.276  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919133715_OMEDES_WUEM46_KXXX.xml
                                    2014-09-19 16:15:06.415  - info: dwd.0 got weather warning
                                    2014-09-19 16:15:07.419  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919140854_OMEDES_WUEM46_KXXX.xml
                                    2014-09-19 16:15:07.548  - info: dwd.0 got weather warning
                                    2014-09-19 16:15:08.688  - info: dwd.0 setting states
                                    2014-09-19 16:15:08.705  - error: dwd.0 uncaught exception: stop is not defined
                                    2014-09-19 16:15:08.720  - error: dwd.0 ReferenceError: stop is not defined
                                    2014-09-19 16:15:09.049  - error: controller instance system.adapter.dwd.0 terminated with code 1
                                    2014-09-19 16:30:00.726  - info: controller instance system.adapter.dwd.0 started with pid 7579
                                    2014-09-19 16:30:04.215  - info: dwd.0 starting
                                    2014-09-19 16:30:04.917  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919131754_OMEDES_WWEM38_KXXX.xml
                                    2014-09-19 16:34:03.986  - info: dwd.0 force terminating after 4 minutes
                                    2014-09-19 16:34:04.015  - info: controller instance system.adapter.dwd.0 terminated with code 0
                                    2014-09-19 16:42:43.652  - info: history.0 moving 481 entries to couchdb
                                    2014-09-19 16:42:44.659  - info: history.0 moved 481 history datapoints from Redis history.system.host.cubie.load to CouchDB history.system.host.cubie.load.20140919
                                    2014-09-19 16:45:00.714  - info: controller instance system.adapter.dwd.0 started with pid 7635
                                    2014-09-19 16:45:04.424  - info: dwd.0 starting
                                    2014-09-19 16:45:05.294  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919131754_OMEDES_WWEM38_KXXX.xml
                                    2014-09-19 16:45:05.450  - info: dwd.0 got weather warning
                                    2014-09-19 16:45:06.459  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919133715_OMEDES_WUEM46_KXXX.xml
                                    2014-09-19 16:45:06.594  - info: dwd.0 got weather warning
                                    2014-09-19 16:45:07.598  - info: dwd.0 getFile Z_CAP_C_EDZW_20140919140854_OMEDES_WUEM46_KXXX.xml
                                    2014-09-19 16:49:04.182  - info: dwd.0 force terminating after 4 minutes
                                    2014-09-19 16:49:04.213  - info: controller instance system.adapter.dwd.0 terminated with code 0</anonymous></anonymous>
                                    16:00, 16:15 und 16:30 noch mit ERROR, der letzte um 16:45 jdoch ohne !?
                                    Dabei habe ich bereits vor Stunden die Instanz versucht zu deaktivieren. Sie steht auch auf false, startet trotzdem immer noch jede 1/4 Stunde.
                                    Wettermeldungen sind jetzt auch in der Datenbank, aber die müssten schon älter sein
                                    Rainer
                                      Habe eben ein git pull gemacht.
                                      Danach liess sich im webui nichts mehr auswählen.
                                      Dann reboot vom cubie, ioBroker Start und log angesehen:
                                      2014-09-28 09:46:36.259  - info: hm-rega.0 renamed hm-rpc.0.KEQ1070107 to "BWM_Garage"
                                      2014-09-28 09:46:36.409  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:6 to "3_fach_01:6"
                                      2014-09-28 09:46:36.546  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:5 to "3_fach_01:5"
                                      2014-09-28 09:46:36.666  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:4 to "3_fach_01:4"
                                      2014-09-28 09:46:36.793  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:3 to "3_fach_01:3"
                                      2014-09-28 09:46:36.908  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:2 to "3_fach_01:2"
                                      2014-09-28 09:46:37.121  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:1 to "3_fach_01:1"
                                      2014-09-28 09:46:37.297  - info: hm-rega.0 renamed hm-rpc.0.KEQ0120652:0 to "3_fach_01:0"
                                      2014-09-28 09:46:45.739  - info: hm-rega.0 got 60 programs
                                      2014-09-28 09:46:46.536  - info: hm-rega.0 added/updated 60 programs
                                      2014-09-28 09:46:46.538  - info: hm-rega.0 deleted 0 programs
                                      2014-09-28 09:46:49.669  - info: controller instance system.adapter.hm-rpc.0 started with pid 2468
                                      2014-09-28 09:46:50.300  - info: hm-rega.0 got 58 variables
                                      2014-09-28 09:46:52.168  - info: hm-rega.0 added/updated 58 variables
                                      2014-09-28 09:46:52.171  - info: hm-rega.0 deleted 0 variables
                                      2014-09-28 09:46:52.175  - info: hm-rega.0 request state values
                                      2014-09-28 09:46:56.985  - info: hm-rega.0 got state values
                                      2014-09-28 09:46:57.232  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
                                      Rainer
                                      Gesendet von meinem LIFETAB_E10320 mit Tapatalk
                                        Habe eben auf dem Tablet mit juicessh ein iobroker update gezogen.
                                        Leider ist die schrift fast nicht zu lesen.
                                        Es schien aber ein update für Admin und rpc zu geben.
                                        Da sich die webui weiter aufhängt. Habe ich mit ioBroker upgrade die Adapter auf den neuesten Stand gebracht.
                                        Leider hängt die webui immer noch.
                                        2014-09-28 21:09:26.088  - info: hm-rega.0 got 58 variables
                                        2014-09-28 21:09:27.357  - info: hm-rega.0 added/updated 58 variables
                                        2014-09-28 21:09:27.360  - info: hm-rega.0 deleted 0 variables
                                        2014-09-28 21:09:27.363  - info: hm-rega.0 request state values
                                        2014-09-28 21:09:31.349  - info: hm-rega.0 got state values
                                        2014-09-28 21:09:33.690  - info: controller instance system.adapter.hm-rpc.0 started with pid 2467
                                        2014-09-28 21:09:41.983  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
                                        2014-09-28 21:09:48.145  - info: history.0 enabled logging of hm-rega.0.2042
                                        2014-09-28 21:09:50.071  - info: history.0 disabled logging of hm-rega.0.12885
                                        2014-09-28 21:09:50.138  - info: history.0 enabled logging of hm-rega.0.12886
                                        2014-09-28 21:10:12.016  - info: controller instance system.adapter.hm-rpc.0 started with pid 2472
                                        2014-09-28 21:10:15.177  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
                                        2014-09-28 21:10:45.214  - info: controller instance system.adapter.hm-rpc.0 started with pid 2474
                                        2014-09-28 21:10:48.095  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
                                        2014-09-28 21:11:18.133  - info: controller instance system.adapter.hm-rpc.0 started with pid 2479
                                        2014-09-28 21:11:21.114  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
                                        2014-09-28 21:11:51.144  - info: controller instance system.adapter.hm-rpc.0 started with pid 2481
                                        2014-09-28 21:11:54.944  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
                                        2014-09-28 21:12:24.975  - info: controller instance system.adapter.hm-rpc.0 started with pid 2487
                                        2014-09-28 21:12:28.056  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
                                        2014-09-28 21:12:58.090  - info: controller instance system.adapter.hm-rpc.0 started with pid 2489
                                        2014-09-28 21:13:01.172  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
                                        Ganz zu Beginn kam noch ein error
                                        2014-09-28 21:16:05.445  - info: controller instance system.adapter.admin.0 started with pid 2615
                                        2014-09-28 21:16:09.442  - info: controller instance system.adapter.history.0 started with pid 2618
                                        2014-09-28 21:16:11.636  - error: admin.0 : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
                                        2014-09-28 21:16:11.651  - info: admin.0 starting
                                        2014-09-28 21:16:13.447  - info: controller instance system.adapter.hm-rega.0 started with pid 2626
                                        2014-09-28 21:16:14.888  - info: history.0 starting
                                        2014-09-28 21:16:15.573  - info: admin.0 received all states
                                        Ich hoffe ich habe beim upgrade alles richtig gemacht. Bei ioBroker update bin ich jedenfalls up to date.
                                        Rainer
                                          Neues Spiel neues Glück 😄
                                          heute war sowohl mit git pull neues da, als auch mit iobroker update eine neue admin - version.
                                          Der eine Error weg - ein anderer da:
                                          2014-10-01 19:38:17.359  - info: hm-rega.0 got 60 programs
                                          2014-10-01 19:38:18.420  - info: hm-rega.0 added/updated 62 programs
                                          2014-10-01 19:38:18.605  - error: uncaught exception: Cannot find module 'homematic-xmlrpc'
                                          2014-10-01 19:38:18.423  - info: hm-rega.0 deleted 0 programs
                                          2014-10-01 19:38:19.068  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
                                          2014-10-01 19:38:22.152  - info: hm-rega.0 got 58 variables
                                          2014-10-01 19:38:23.347  - info: hm-rega.0 added/updated 58 variables
                                          2014-10-01 19:38:23.349  - info: hm-rega.0 deleted 0 variables
                                          2014-10-01 19:38:23.353  - info: hm-rega.0 request state values
                                          2014-10-01 19:38:24.951  - info: hm-rega.0 got state values
                                          2014-10-01 19:38:42.057  - info: history.0 enabled logging of hm-rega.0.2042
                                          2014-10-01 19:38:43.623  - info: history.0 disabled logging of hm-rega.0.12885
                                          2014-10-01 19:38:43.653  - info: history.0 enabled logging of hm-rega.0.12886
                                          2014-10-01 19:38:49.102  - info: controller instance system.adapter.hm-rpc.0 started with pid 17033
                                          2014-10-01 19:38:52.250  - error: uncaught exception: Cannot find module 'homematic-xmlrpc'
                                          2014-10-01 19:38:52.275  - error: Error: Cannot find module 'homematic-xmlrpc'
                                              at Function.Module._resolveFilename (module.js:338:15)
                                              at Function.Module._load (module.js:280:25)
                                              at Module.require (module.js:364:17)
                                              at require (module.js:380:17)
                                              at Object. <anonymous>(/opt/iobroker/adapter/hm-rpc/hm-rpc.js:96:14)
                                              at Module._compile (module.js:456:26)
                                              at Object.Module._extensions..js (module.js:474:10)
                                              at Module.load (module.js:356:32)
                                              at Function.Module._load (module.js:312:12)
                                              at Function.Module.runMain (module.js:497:10)
                                          2014-10-01 19:38:52.515  - info: hm-rpc.0 starting
                                          2014-10-01 19:38:52.535  - error: uncaught exception: Cannot call method 'createClient' of undefined
                                          2014-10-01 19:38:52.545  - error: TypeError: Cannot call method 'createClient' of undefined
                                              at main (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:106:21)
                                              at Object.require.ready (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:7:9)
                                              at initAdapter (/opt/iobroker/lib/adapter.js:1241:58)
                                              at /opt/iobroker/lib/adapter.js:137:29
                                              at /opt/iobroker/lib/couch.js:153:13
                                          2014-10-01 19:38:52.595  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1</anonymous></anonymous>
                                          Ich bin mit der lxccu auf meinen bananapi umgezogen und musste im rega und rpc.o noch die IP-Adressen ändern.
                                          Danach hat iobroker die Datenpunkte eingelesen und die obige Fehlermeldung gezeigt.
                                          Kann aber sein, dass ich die Konfig noch nicht ganz sauber habe
                                          gruß
                                          Rainer
                                          • Bluefox
                                            Bluefox last edited by
                                            @Homoran: gehe zu adapter/hm-rpc in der console und starte "npm install"
                                            176
                                            39517
