    4. Shelly™ 2 Double Relay Switch Erfahrungen?
      poldi last edited by
      Moin bei mir hatte der neue Shelly Adapter heute morgen etwas Husten 4x die folgende Meldung im Log:
      2018-12-23 06:18:54.949 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
      2018-12-23 06:18:54.951 - info: shelly.0 terminating
      2018-12-23 06:18:54.955 - error: Caught by controller[0]: TypeError: Cannot read property 'startsWith' of undefined
      2018-12-23 06:18:54.955 - error: Caught by controller[0]: at createShellyStates (/opt/iobroker/node_modules/iobroker.shelly/shelly.js:198:16)
      2018-12-23 06:18:54.955 - error: Caught by controller[0]: at shelly.getDeviceDescription (/opt/iobroker/node_modules/iobroker.shelly/shelly.js:1016:9)
      2018-12-23 06:18:54.955 - error: Caught by controller[0]: at ShellyIot.getDeviceDescription (/opt/iobroker/node_modules/shelly-iot/index.js:198:32)
      2018-12-23 06:18:54.955 - error: Caught by controller[0]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/shelly-iot/index.js:218:22)
      2018-12-23 06:18:54.955 - error: Caught by controller[0]: at ontimeout (timers.js:498:11)
      2018-12-23 06:18:54.955 - error: Caught by controller[0]: at tryOnTimeout (timers.js:323:5)
      2018-12-23 06:18:54.955 - error: Caught by controller[0]: at Timer.listOnTimeout (timers.js:290:5)
      2018-12-23 06:18:54.955 - error: host.debian instance system.adapter.shelly.0 terminated with code 0 (OK)
      2018-12-23 06:18:54.955 - info: host.debian Restart adapter system.adapter.shelly.0 because enabled
      2018-12-23 06:19:00.320 - info: javascript.0 script.js.Stromzaehler.Abfrage_aktueller_Verbrauch: 585.4
      2018-12-23 06:19:24.965 - info: host.debian instance system.adapter.shelly.0 started with pid 23560
      2018-12-23 06:19:25.247 - info: shelly.0 starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.12.0
      2018-12-23 06:19:25.277 - info: shelly.0 Listening for Shelly packets in the network
      2018-12-23 06:19:38.847 - error: shelly.0 uncaught exception: Cannot read property 'startsWith' of undefined
      2018-12-23 06:19:38.847 - error: shelly.0 TypeError: Cannot read property 'startsWith' of undefined
      Hat sich dann 4 mal neu gestartet und jetzt ist wieder alles OK.
      • Stuebi
        Stuebi last edited by
        In der aktuellen Version 2.0.1 sollte das Problem behoben sein. Adapter bitte einmal updaten.
          monarc last edited by
          Guten Morgen,
          also mein Problem besteht leider weiterhin.
          VG Marc
          • Stuebi
            @monarc:
            Guten Morgen,
            VG Marc `
            Ab der Version 2.0.1 kannst du auch die Rollläden über das Objekt shelly.0.SHSW-21#xxxxxxx#1.Shutter.state mit open, close und stop steuern. Funktioniert das?
              @tstueben:
              Ab der Version 2.0.1 kannst du auch die Rollläden über das Objekt shelly.0.SHSW-21#xxxxxxx#1.Shutter.state mit open, close und stop steuern. Funktioniert das? `
              Funktioniert leider auch nicht….
              • Stuebi
                @monarc:
                @tstueben:
                Funktioniert leider auch nicht…. `
                Okay, weicher Modus wird dir unter ioBroker für das Shelly2 Service angezeigt (Bucht Modus in App). Hast du ein Passwort für den Shelly vergeben? Werden dir Statusänderungen in ioBroker wenn du Werte in der App änderst angezeigt?
                  Oh mann, das ist schon ein bisschen peinlich. :oops: Hatte den Benutzernamen falsch im ioBroker hinterlegt, Klein- anstatt Großbuchstabe am Anfang. Manchmal hilft es drüber zu sprechen/schreiben. Ich gehe davon aus, das mein Roborock ein ähnliches Problem hat. Muss ich mir später auch nochmal anschauen.
                  Vielen Dank schon mal und einen schönen vierten Advent.
                    reelfan last edited by
                    Nabend,
                    ich habe heute 2 shelly 2 verbaut und die aktuelle Version des Adapters im Einsatz, soweit funktioniert auch alles.
                    Bei einem Shelly 2 wird im iobroker Webinterface wir im Ruhezustand der Verbrauch mit 0 Watt angezeigt. Beim zweiten Shelly 2 zwei springt die Anzeige von 0 Watt auf 1 Watt bzw. bis zu 1.24 Watt. Ist das Normal bzw. konnte das noch irgendwer beobachten ?
                      davincino last edited by
                      Bei mir springt es auch zwischen 0 und ca. 1,2 Watt. Denke das ist normal.
                      • Diginix
                        Diginix last edited by
                        Meine Shelly2 liefern dauerhaft 0 Watt wenn kein Relais geschlossen ist.
                          Danke, dann bin ich erstmal beruhigt, ich war nur irritiert, da bei einem der Shelly 2 der Verbrauch im Idle mit 0 Watt konstant angegeben wird.
                          Grundsätzlich muss da ja ein Verbrauch sein (WLAN/ESP)
                            Hab nochmal ein wenig getestet, Werksreset und neu verbunden, mal via DHCP und mal mit fixer IP.
                            Der Shelly 2 mit der Verbauchsanzeige hat eine sehr schlechte WLAN Verbindung (1Mbit). Im Haus ist eine Firtzbox 7490 sowie 2 1750e Repeater (MESH) im Einsatz. Auch das Ping verhalten ist nicht gut:
                            Ping wird ausgeführt für 192.168.178.114 mit 32 Bytes Daten:
                            Antwort von 192.168.178.114: Bytes=32 Zeit=222ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=68ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=227ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=209ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=67ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=12ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=75ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=74ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=41ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=139ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=5ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=73ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=158ms TTL=128
                            Zeitüberschreitung der Anforderung.
                            Antwort von 192.168.178.114: Bytes=32 Zeit=89ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=179ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=156ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=4ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=175ms TTL=128
                            Antwort von 192.168.178.114: Bytes=32 Zeit=345ms TTL=128
                            Die anderen Shellys (1er und 2er) haben dieses Problem nicht, WLAN ist an dem Standort gut verfügbar.
                              @reelfan:
                              Die anderen Shellys (1er und 2er) haben dieses Problem nicht, WLAN ist an dem Standort gut verfügbar. `
                              Also ich glaube das die Shelly Jungs ein Problem mit der Qualität der Hardware haben. Habe insgesamt 12 Stück Shelly2 für meine Rollos verbaut und alle auf die letze Version 1.4.2. geflasht. Bei mir wird zwischen 24.00h und 6.00h das WLAN von der Fritzbox abgeschaltet. Von den 12 Shellys sind dann am nächsten Morgen nur noch 10 erreichbar. Reset geht dann leider nur per Sicherung, was mir den Unmut der Frau beschert. Überwache die Geräte jetzt mit dem Ping Adapter von iobroker. Und siehe da die beiden Kumpels haben öfters Probleme mit dem Wifi. Empfang an der Stelle sollte eigentlich gut sein (Nur 4m von Fritzbox bzw. Repater 1750E entfernt).
                              Werte für ping.0.debian.192_168_x_x
                              true	true		2018-12-26 07:44:27.616
                              false	true		2018-12-26 07:43:11.331
                              false	true		2018-12-26 06:03:59.882
                              true	true		2018-12-26 06:02:44.446
                              true	true		2018-12-26 06:01:29.706
                              false	true		2018-12-26 06:00:09.954
                              false	true		2018-12-25 23:59:47.226
                              true	true		2018-12-25 23:58:30.936
                              true	true		2018-12-25 23:53:32.456
                              false	true		2018-12-25 23:52:19.471
                              true	true		2018-12-25 23:51:03.183
                              true	true		2018-12-25 23:03:49.079
                              false	true		2018-12-25 23:02:34.547
                              true	true		2018-12-25 23:01:18.295
                              true	true		2018-12-25 22:02:57.162
                              false	true		2018-12-25 22:01:42.869
                              true	true		2018-12-25 22:00:26.624
                              true	true		2018-12-25 21:31:59.771
                              null	true		2018-12-25 21:31:59.767
                              Werde jetzt mal bei dem einen ein Downgrade auf 1.3.0 machen und schauen, ob es besser wird.
                              So long
                              Poldi
                                Moin Poldi,
                                ich kann ähnliches beobachten, ich habe aktuell 4 Shelly's verbaut (6 warten noch auf ihren Einsatz). 3 funktionieren bisher ohne Probleme einer der Shelly 2 hat das oben beschriebene Problem. Diesen habe ich jetzt auch in der Überwachung, gestern ist der Shelly 2 nach ca. 2,5 Stunden Betrieb nicht mehr erreichbar gewesen. Neustart nur durch Trennen des L-Leiters bzw. Sicherung möglich. Am WLAN Empfang der Installation kann es nicht liegen, 30 cm vom Shelly 2 entfernt ist ein Sonoff im Einsatz ohne Probleme. Ich gehe auch stark von einem Problem bei dem besagten Shelly 2 aus.
                                  weidlix last edited by
                                  Ich habe ähnliche Probleme. Von 5 Shelly 2 ist bei 2 die WLAN Verbindung schonmal abgerissen. Neuinstallation war erforderlich
                                    @weidlix:
                                    Ich habe ähnliche Probleme. Von 5 Shelly 2 ist bei 2 die WLAN Verbindung schonmal abgerissen. Neuinstallation war erforderlich `
                                    Was bedeute "Neuinstallation"? hast du einen neuen Shelly2 verwendet, ein Factory Reset oder eine neue Firmware verwendet?
                                    Viele Grüße
                                    Poldi
                                      Ich habe jetzt die Beta Firmware auf dem Shelly 2 installiert und werde das Gerät weiter im Monitoring beobachten.
                                      Das Facebook Posing füge ich mal als Zitat mit ein:
                                      ` > We need to test one developer version regarding Wi-Fi disconnecting issue. We need more people because every Wi-Fi router and network setup is different.
                                      This version are based on 1.4.2 mean, you not loose any functionality.
                                      There is the link for firmware:
                                      –------Shelly2----------
                                      http://repo.shelly.cloud/…/wifi-dis…/sw ... 6-last.zip
                                      --------Shelly1------------
                                      http://repo.shelly.cloud/…/wifi-di…/swi ... 6-last.zip
                                      Please keep all comments under this post regarding this version.
                                      You can go back to stable versions any time.
                                      If you have fixed IP please change it back to DHCP. `
                                        Das erste Ergebnis der Beta ist etwas ernüchternd, nach ca. 1 Stunde ist das Gerät nicht mehr erreichbar.
                                          @reelfan:
                                          Das erste Ergebnis der Beta ist etwas ernüchternd, nach ca. 1 Stunde ist das Gerät nicht mehr erreichbar. `
                                          Also bei mir hat die Beat switch-esp8266-last.zip geholfen. In der Fritzbox werden jetzt 30 MBit/s anstelle von 7Mbit/s angezeigt. Habe jetzt auch nur noch die Unterbrechungen die vom abschalten des WLAN (Zeitschaltuhr) kommen.
                                          shellyswitch-KuecheFenster WLAN 192.168.x.x  2,4 GHz, 32 / 30 Mbit/s
                                          history.0
                                          Wert	Bestätigt	Quelle	Zeit	Geändert
                                          true	true		2018-12-27 06:01:32.117
                                          false	true		2018-12-27 06:00:08.859
                                          false	true		2018-12-26 23:59:18.417
                                          true	true		2018-12-26 23:57:59.992
                                          true	true		2018-12-26 22:03:23.962
                                          Werde jetzt mal alle Kandidaten die Probleme machen mit der Beta versorgen.
                                          So long
                                          Poldi
                                            Moin,
                                            hattest Du mit der installierten Beta ein Werksreset durchgeführt ?
                                            360
                                            83057
