    4. Installation ioBroker auf Cubietruck
      John92648 last edited by
      Hallo Trident, hab den gleichen Effekt im Raspi part auch gepostet. Seitdem kann man auch die instances nicht mehr aus dem Admin starten.
      Gruss John.
      Gesendet von iPhone
        Sorry, meinte Instances installieren…..
        Gesendet von iPhone
        • Bluefox
          Bluefox last edited by
          @John92648:
          Gesendet von iPhone `
          Hm.. Ich kann das Verhalten nicht reproduzieren.
          Aber es steht auch ein PullRequest da. HQ: kannst du denn mergen?
            Habe gestern git pull durchgeführt.
            Folgender Fehler tritt jetzt auf:
            014-10-18 22:45:34.544  - info: hm-rega.0 renamed hm-rpc.0.LEQ0242152:0 to "Steckdose_Stube_hinten_links:0"
            2014-10-18 22:45:34.729  - info: hm-rpc.0 xmlrpc -> 283 devices
            2014-10-18 22:45:35.370  - error: uncaught exception: log is not defined
            2014-10-18 22:45:35.433  - info: hm-rega.0 renamed hm-rpc.0.LEQ0242152 to "Steckdose_Stube_hinten_links"
            2014-10-18 22:45:35.427  - error: ReferenceError: log is not defined
                at Object.methods.event (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:240:9)
                at Server. <anonymous>(/opt/iobroker/adapter/hm-rpc/hm-rpc.js:185:67)
                at Server.EventEmitter.emit (events.js:106:17)
                at /opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                at callback (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                at Deserializer.onDone (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                at SAXStream.EventEmitter.emit (events.js:92:17)
                at Object.SAXStream._parser.onend (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                at emit (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                at end (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:363:3)
            2014-10-18 22:45:35.776  - info: hm-rega.0 renamed hm-rpc.0.KEQ0966548:6 to "Steckdose_Mitte:6"
            2014-10-18 22:45:35.880  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1</anonymous>
            Rainer
            Gesendet von meinem LIFETAB_E10320 mit Tapatalk
            • Bluefox
              @Homoran:
              Rainer
              Gesendet von meinem LIFETAB_E10320 mit Tapatalk `
              Danke!
              Muss jetzt wieder funktionieren.
                Hallo Bluefox
                Läuft soweit wieder durch, lediglich der alte "error"
                2014-10-20 20:52:26.081  - error: admin.0 : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
                2014-10-20 20:52:26.092  - info: admin.0 starting
                existiert noch.
                EDIT:
                leider doch nicht
                2014-10-20 20:54:23.900  - error: ReferenceError: log is not defined
                2014-10-20 20:54:23.922  - error: uncaught exception: log is not defined
                2014-10-20 20:54:23.927  - error: ReferenceError: log is not defined
                    at end (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:363:3)</anonymous></anonymous>
                ist noch da 😞
                Außerdem ist kein ioBroker update mehr möglich:
                root@cubie:/opt/iobroker# ./iobroker update
                Error: no repositories found in the "system.config
                Rainer
                • Bluefox
                  @Homoran:
                  Hallo Bluefox
                  existiert noch.
                  EDIT:
                  leider doch nicht
                  ist noch da 😞
                  Rainer
                  Ich befürchte, dass man alles von "null" installieren muss. Zu viele Änderungen letzte Zeit, was "update" angeht.
                  Es gibt jetzt "legacy" adapter. Kannst du denn auch anschauen? (Nach der Neuinstallation) 😄
                    @Bluefox:
                    Ich befürchte, dass man alles von "null" installieren muss. Zu viele Änderungen letzte Zeit, was "update" angeht. `
                    Mache ich gerne.
                    @Bluefox:
                    Es gibt jetzt "legacy" adapter. Kannst du denn auch anschauen? (Nach der Neuinstallation) `
                    den gab's doch schon mal - der hat mein System immer zum Absturz gebracht - ich wollte damals versuchen dashui damit ans Laufen zu bekommen.
                    Na dann bis später
                    Rainer
                      Ihr seid wahnsinnig 😛
                      Die Installation lief ohne einen einzigen Fehler durch!!!!
                      Habe erst einmal HM-rpc installiert - ist ja Bedingung für HM-REGA.
                      Dann HM-REGA und schwupps war da ein zweiter hm-rpc :?:
                      Muss man jetzt nicht mehr HM-rpc installieren bevor man HM-Rega installiert?
                      dann habe ich Legacy installiert.
                      Dabei habe ich mir den Log angesehen und weiß jetzt, was ihr die letzten Wochen gemacht habt 8-)
                      Alleine das Herunterladen der Daten zu dem Legacy-Adapter hat 16 Minuten gedauert!!!
                      Dann den Adapter konfiguriert (nur den Port) und aufgerufen:
                      das einzige, was ich zu sehen bekomme ist:
                      Cannot GET /
                      Im Log ist nichts negatives zu sehen
                      EDIT: Hatte erst nur <ipdescubie>:Port eingegeben,
                      Mit <ipdescubie>:Port/dashui klappt es!!!!! Wahnsinn!!!
                      Wie schon im Log gesehen sind die Legacy IDs nicht identisch mit den ccu.io IDs, das sieht man im importierten View:
                      und im Log:
                      2014-10-21 19:07:35.124  - info: legacy.0 socket.io <-- writeFile created /opt/iobroker/adapter/legacy/datastore/dashui-views.json.bak
                      2014-10-21 19:07:36.410  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.414  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.416  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.418  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.475  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property '1' of undefined
                      2014-10-21 19:07:36.644  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.647  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.649  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.652  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.662  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.663  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:36.665  - info: legacy.0 socket.io: transport end (undefined)
                      2014-10-21 19:07:36.669  - info: legacy.0 socket.io <-- 192.168.2.116:54037 websocket disconnected
                      2014-10-21 19:07:37.416  - info: legacy.0 socket.io: handshake authorized
                      2014-10-21 19:07:37.524  - info: legacy.0 socket.io <-- 192.168.2.116:54037 websocket connected
                      2014-10-21 19:07:37.537  - info: legacy.0 socket.io <-- getData
                      2014-10-21 19:07:37.565  - info: legacy.0 socket.io <-- touchFile www/dashui/css/dashui-user.css
                      2014-10-21 19:07:39.591  - info: legacy.0 socket.io <-- getObjects
                      2014-10-21 19:07:39.873  - info: legacy.0 socket.io <-- getIndex
                      2014-10-21 19:07:39.881  - info: legacy.0 socket.io <-- readFile dashui-views.json
                      2014-10-21 19:07:43.321  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.325  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.327  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.329  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.357  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property '1' of undefined
                      2014-10-21 19:07:43.463  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.466  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.468  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.470  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.472  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      2014-10-21 19:07:43.474  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                      Rainer</ipdescubie></ipdescubie>
                        @Bluefox:
                        Du hast es nicht anders gewollt :shock:
                        Ich habe jetzt mit dem dashui einige Zeit gespielt.
                        Zuerst das positive:
                        Bei dem Import von meinen Views gab es nur zwei gemeldete Errors:
                        Ähnliches mit dem Widget jq ctrl input.
                        Da einiges andere nicht lief habe ich erst einmal alle diese widgets gelöscht. Die anderen Fehler blieben.
                        Folgende widgets scheinen ohne Probleme zu sein:
                        • RGRaph Thermometer
                        • RGraph Gauge
                        • hq widgets IpCamera
                        • bars views_bar
                        • basic val - number
                        • time_and_weather htcWeather
                        bei folgenden kommt es zu Problemen:
                        • hq widgets on_off
                        beim Anklicken des widgets kommt es zu dieser Meldung:
                        1. Beispiel: Entfeuchter in der Werkstatt
                        2014-10-21 20:40:45.003 - error: pmessage hm-rpc.0.JEQ0646431:3{"val":true,"ack":false,"ts":1413916845,"from":"system.adapter.legacy.0","lc":1413916845} Cannot read property 'TYPE' of undefined
                        2014-10-21 20:40:45.038 - error: TypeError: Cannot read property 'TYPE' of undefined
                        at Object.require.stateChange (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:19:32)
                        at that.states.StatesRedis.change (/opt/iobroker/lib/adapter.js:888:80)
                        at RedisClient. <anonymous>(/opt/iobroker/lib/redis.js:48:21)
                        at RedisClient.EventEmitter.emit (events.js:106:17)
                        at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:672:22)
                        at HiredisReplyParser. <anonymous>(/opt/iobroker/node_modules/redis/index.js:309:14)
                        at HiredisReplyParser.EventEmitter.emit (events.js:95:17)
                        at HiredisReplyParser.execute (/opt/iobroker/node_modules/redis/lib/parser/hiredis.js:43:18)
                        at RedisClient.on_data (/opt/iobroker/node_modules/redis/index.js:534:27)
                        at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:91:14)
                        2. Beleuchtung im Schlafzimmer
                        2014-10-21 20:42:10.327 - error: pmessage hm-rpc.0.JEQ0175818:1{"val":true,"ack":false,"ts":1413916930,"from":"system.adapter.legacy.0","lc":1413916930} Cannot read property 'TYPE' of undefined
                        2014-10-21 20:42:10.353 - error: TypeError: Cannot read property 'TYPE' of undefined
                        • hq widgets gauge
                        keine Anzeige (getestet mit Variable)
                        • hq widgets temperature
                        keine Anzeige (getestet mit Sensorwert)
                        • hq widgets info
                        • hq widgets windows & shutter
                        keine Anzeige Drehgriff und Rolladen
                        • hq widgets Motion Detector
                        keine Anzeige
                        Soweit meine erste Analyse.
                        Ihr tut mir richtig leid - ernsthaft!
                        Wenn ich euch noch weiter helfen kann sagt bitte wie!
                        Rainer</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                        • Bluefox
                          Danke Homoran. Jetzt haben noch was zu tun.
                          Melde mich, wenn irgendwas neues geht. 😄
                            @Bluefox:
                            Melde mich, wenn irgendwas neues geht. `
                            Hast du aber nicht getan 😞
                            Schlaft ihr eigentlich irgendwann einmal?
                            Habe eben schon das nächste update vom legacy heruntergeladen.
                            Es scheint einiges mehr zu funktionieren!!
                            Allerdings sieht es auf den ersten Blick so aus, als ob sich die IDs verschoben haben.
                            Kann das sein?
                            Ich werde nachher nochmal meine ccu.io views komplett importieren und die IDs anpassen.
                            Melde mich dann nochmal.
                            EDIT (18:33) - Ich melde mich:
                            Status des Updates:
                            folgende Widgets scheinen ohne Probleme zu laufen:
                            • RGraph Gauge
                            • bars views_bar
                            • hq widgets gauge
                            • hq widgets info
                            • hq widgets on/off
                            JQ widgets werden nicht dargestellt
                            folgende Fehlermeldungen erscheinen im ioBroker log:
                            2014-10-22 18:31:03.440  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.442  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.444  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.445  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.446  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.448  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.449  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.450  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.451  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.453  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:31:03.454  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                            2014-10-22 18:33:10.183  - error: legacy.0 Addon DashUI  Error: can't render tplHqShutter w00096 (TypeError: undefined is not a function)
                            2014-10-22 18:33:10.632  - error: legacy.0 Addon DashUI  Error: can't render tplHqMotion w00114 (TypeError: undefined is not a function)
                            2014-10-22 18:33:10.732  - error: legacy.0 Addon DashUI  Error: can't render tplHqGauge w00122 (TypeError: undefined is not a function)
                            2014-10-22 18:33:10.742  - error: legacy.0 Addon DashUI  Error: can't render tplHqGauge w00123 (TypeError: undefined is not a function)
                            2014-10-22 18:33:10.931  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00133 (TypeError: Cannot read property 'Value' of undefined)
                            2014-10-22 18:33:11.035  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00144 (TypeError: Cannot read property 'Value' of undefined)
                            2014-10-22 18:33:11.040  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00146 (TypeError: Cannot read property 'Value' of undefined)
                            2014-10-22 18:33:11.048  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00148 (TypeError: Cannot read property 'Value' of undefined)
                            2014-10-22 18:33:11.374  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00167 (TypeError: Cannot read property 'Value' of undefined)
                            2014-10-22 18:33:11.383  - error: legacy.0 Addon DashUI  Error: can't render tplHqInfo w00168 (TypeError: undefined is not a function)
                            2014-10-22 18:33:11.394  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00170 (TypeError: Cannot read property 'Value' of undefined)
                            2014-10-22 18:33:11.398  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00171 (TypeError: Cannot read property 'Value' of undefined)
                            2014-10-22 18:33:11.402  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00172 (TypeError: Cannot read property 'Value' of undefined)
                            2014-10-22 18:33:11.405  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00173 (TypeError: Cannot read property 'Value' of undefined)
                            UND:
                            alle Variablen sind doppelt :!: :!: (zumindest in dem Datenpunktauswahl-Popup)
                            Rainer
                            PS würde es nicht Sinn machen jetzt schon für jeden Adapter einen Thread aufzumachen, ohne euch zu sehr unter Druck setzen zu wollen?
                            • Bluefox
                              Jetzt sollte viel mehr gehen.
                                @Bluefox:
                                Jetzt sollte viel mehr gehen. `
                                Noch mehr?? seit 17:30 ???
                                Es läuft doch fast alles!
                                Leider habe ich sehr viele widgets, die bei ccu.io die Werte von Adaptern anzeigen.
                                Die gibt es in ioBroker noch nicht (ping, cubie, Highcharts, sprit, eventlist)
                                Die Rolläden werden korrekt angezeigt, lassen sich auch bedienen, jedoch wird der Status nicht automatisch refresht.
                                Die Rolläden sind bei Sonnenuntergang heruntergegangen, in ioBroker jedoch nicht, erst nach ..dashui/edit… und wieder schließen war der Status korrekt.
                                EDIT: ok, 0.1.3 lädt gerade herunter, dann wird es wieder ne lange Nacht 😉
                                EDIT2 (20:50): Ihr seid wirklich wahnsinnig (oder Junkies) - Es scheint jetzt alles zu laufen, sogar die JQ gauges sind da - und die Variablen sind nur noch einmal da.
                                ok, jetzt muss ich die IDs wieder ändern, aber ich denke das klappt.
                                Morgen gibt's ein Update - jetzt geht auch mal früher ins Bett 8-)
                                Rainer
                                  mimquadrat last edited by
                                  Hi Leute,
                                  muss den Broker nochmal komplett neu aufsetzen da nur noch das Zahnrad kommt.
                                  Wahrscheinlich durch die vielen vielen Änderungen.
                                  Könnte mir bitte kurz mal jemand nur stichpunktartig beschreiben wie ich JETZT vorgehen soll?
                                  Also welches NODE Paket von wo usw…
                                  Vielen Dank!
                                  M²
                                    lies mal hier:
                                    https://github.com/ioBroker/ioBroker.nodejs
                                    Rainer
                                      Hallo bluefox
                                      @Bluefox:
                                      habe gestern abend alle dashui-views von ccu.io nach ioBroker importiert und die legacy Ids angepasst.
                                      Ich denke alles lief soweit.
                                      Da ioBroker ja noch nicht die Programme von der ccu runterlädt, konnte ich auch das widget "jquiControl Button ProgramExecute" natürlich nicht zuordnen.
                                      und da dies ja wohl eine 1:1 Portierung des ccu.io dashui ist, sind leider auch die noch nichtbehobenen Fehler des dashui mit dabei: Bei wechsel des Views erscheinen einige Widgets erst nach Drücken von F5, runde widgets werden beim Anklicken eckig.. Aber das ist erst einmal unwichtig.
                                      Schlimmer war es, dass heute nach dem nächsten Update wieder die Legacy IDs hätten angepasst werden müssen - da hatte ich dann keine Lust zu.
                                      Außerdem scheint das HQ-Widget on/off nicht zu funktionieren, es wechselt zwar die Farbe, aber das busy-Zeichen bleibt an. Und beim Schalten über ccu.io ändert sich das Widget auch nicht in Legacy.
                                      Weiterhin waren einige Settings verschwunden. gemerkt habe ich das bisher bei der IP meiner CCU und dem Crontab beim DWD-Adapter
                                      Soweit der aktuelle Status
                                      Rainer
                                        Irgendwas ist schiefgegangen 😞
                                        Ich habe gerade den History-Adapter aktiviert und dabei fallen mir erst einige Werte, und darufhin die Timestamps auf: waren alle gegen 08:45 oder früher.
                                        Habe zuerst gedacht: nach update iobroker nicht neu gestartet.
                                        Also ./iobroker start - wars nicht: "already running"
                                        daraufhin stop - start - im log keinerlei Fehler - jetzt kommen langsam wieder aktuelle Werte.
                                        Bei der Betrachtung des logs sah ich dann:
                                        2014-10-24 21:46:30.807  - info: legacy.0 setting system.host.cubie.alive legacy id to 526054
                                        2014-10-24 21:46:30.819  - info: legacy.0 setting system.host.cubie legacy id to 526055
                                        2014-10-24 21:46:30.865  - info: legacy.0 setting system.host.cubie.load legacy id to 526056
                                        2014-10-24 21:46:30.912  - info: legacy.0 setting system.host.cubie.mem legacy id to 526057
                                        2014-10-24 21:46:30.936  - info: legacy.0 requesting all states
                                        Habe dann noch ein wenig rumgespielt und versucht die Werte im dashui anzuzeigen.
                                        In der Auswahl waren sie nicht, und manuell den Datenpunkt 526056 bei Cubie.load einzutragen hat auch nicht geklappt 😞
                                        Rainer
                                          Habe eben ein iobroker update gefahren.
                                          Da war dann u.a. ein update des admin-adapters dabei - das wurde jedoch nicht - wie üblich beendet (mit code 0)
                                          EDIT 22:25 neues update - bleibt dabei:
                                          $ ./iobroker upgrade admin
                                          download https://github.com/ioBroker/ioBroker.admin/archive/master.zip
                                          unzip /opt/iobroker/lib/../tmp/admin.zip
                                          downloaded /opt/iobroker/lib/../tmp/admin.zip
                                          copying /opt/iobroker/tmp/admin/ioBroker.admin-master to /opt/iobroker/adapter/admin(Version: 0.1.4)
                                          delete /opt/iobroker/tmp/admin
                                          npm install "/opt/iobroker/adapter/admin" --production --prefix "/opt/iobroker/adapter/admin"
                                          got /opt/iobroker/adapter/admin/admin
                                          upload admin.admin /opt/iobroker/adapter/admin/admin/index.html index.html text/html
                                          upload admin.admin /opt/iobroker/adapter/admin/admin/admin.png admin.png image/png
                                          Adapter "admin" updated
                                          außerdem noch ein update für den js-controller.
                                          danach waren dann die Rechte für ioBroker futsch.
                                          mussten wieder mit:
                                          chmod +x iobroker
                                          freigegeben werden 😉
                                          Rainer
                                          • Bluefox
                                            @Homoran:
                                            Da war dann u.a. ein update des admin-adapters dabei - das wurde jedoch nicht - wie üblich beendet (mit code 0) `
                                            Auf dem Rechner habe ich das nie beobachtet. Vorgestern konnte ich aber denselben Effekt auf Odroid sehen…
                                            In der nächste Version (noch nicht da) von js-controller versuche ich zwei Mal zu senden.
                                            176
                                            39527
