    4. Installation ioBroker auf Cubietruck
      Neues Spiel neues Glück 😄
      heute war sowohl mit git pull neues da, als auch mit iobroker update eine neue admin - version.
      Der eine Error weg - ein anderer da:
      2014-10-01 19:38:17.359  - info: hm-rega.0 got 60 programs
      2014-10-01 19:38:18.420  - info: hm-rega.0 added/updated 62 programs
      2014-10-01 19:38:18.605  - error: uncaught exception: Cannot find module 'homematic-xmlrpc'
      2014-10-01 19:38:18.423  - info: hm-rega.0 deleted 0 programs
      2014-10-01 19:38:19.068  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
      2014-10-01 19:38:22.152  - info: hm-rega.0 got 58 variables
      2014-10-01 19:38:23.347  - info: hm-rega.0 added/updated 58 variables
      2014-10-01 19:38:23.349  - info: hm-rega.0 deleted 0 variables
      2014-10-01 19:38:23.353  - info: hm-rega.0 request state values
      2014-10-01 19:38:24.951  - info: hm-rega.0 got state values
      2014-10-01 19:38:42.057  - info: history.0 enabled logging of hm-rega.0.2042
      2014-10-01 19:38:43.623  - info: history.0 disabled logging of hm-rega.0.12885
      2014-10-01 19:38:43.653  - info: history.0 enabled logging of hm-rega.0.12886
      2014-10-01 19:38:49.102  - info: controller instance system.adapter.hm-rpc.0 started with pid 17033
      2014-10-01 19:38:52.250  - error: uncaught exception: Cannot find module 'homematic-xmlrpc'
      2014-10-01 19:38:52.275  - error: Error: Cannot find module 'homematic-xmlrpc'
          at Function.Module._resolveFilename (module.js:338:15)
          at Function.Module._load (module.js:280:25)
          at Module.require (module.js:364:17)
          at require (module.js:380:17)
          at Object. <anonymous>(/opt/iobroker/adapter/hm-rpc/hm-rpc.js:96:14)
          at Module._compile (module.js:456:26)
          at Object.Module._extensions..js (module.js:474:10)
          at Module.load (module.js:356:32)
          at Function.Module._load (module.js:312:12)
          at Function.Module.runMain (module.js:497:10)
      2014-10-01 19:38:52.515  - info: hm-rpc.0 starting
      2014-10-01 19:38:52.535  - error: uncaught exception: Cannot call method 'createClient' of undefined
      2014-10-01 19:38:52.545  - error: TypeError: Cannot call method 'createClient' of undefined
          at main (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:106:21)
          at Object.require.ready (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:7:9)
          at initAdapter (/opt/iobroker/lib/adapter.js:1241:58)
          at /opt/iobroker/lib/adapter.js:137:29
          at /opt/iobroker/lib/couch.js:153:13
          at Request._callback (/opt/iobroker/node_modules/nano/nano.js:303:11)
          at Request.self.callback (/opt/iobroker/node_modules/nano/node_modules/request/request.js:122:22)
          at Request.EventEmitter.emit (events.js:98:17)
          at Request. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:888:14)
          at Request.EventEmitter.emit (events.js:117:20)
      2014-10-01 19:38:52.595  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1</anonymous></anonymous>
      Ich bin mit der lxccu auf meinen bananapi umgezogen und musste im rega und rpc.o noch die IP-Adressen ändern.
      Danach hat iobroker die Datenpunkte eingelesen und die obige Fehlermeldung gezeigt.
      Kann aber sein, dass ich die Konfig noch nicht ganz sauber habe
      gruß
      Rainer
      • Bluefox
        Bluefox last edited by
        @Homoran: gehe zu adapter/hm-rpc in der console und starte "npm install"
          @Bluefox:
          @Homoran: gehe zu adapter/hm-rpc in der console und starte "npm install" `
          Danke,
          Ist jetzt durchgestartet.
          Der Fehler
          2014-10-02 14:43:18.279  - info: controller starting 4 instances
          2014-10-02 14:43:18.357  - info: controller instance system.adapter.admin.0 started with pid 971
          2014-10-02 14:43:22.299  - info: controller instance system.adapter.history.0 started with pid 975
          2014-10-02 14:43:24.829  - error: admin.0 : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
          2014-10-02 14:43:24.839  - info: admin.0 starting
          Existiert noch.
          Und
          2014-10-02 14:44:30.076  - info: hm-rega.0 renamed hm-rpc.0.JEQ0112571 to "Markise"
          2014-10-02 14:44:30.163  - error: hm-rpc.0 object hm-rpc.0.JEQ0112571:0 extend: Error: Document update conflict.
          2014-10-02 14:44:30.267  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.STOP extended
          2014-10-02 14:44:30.274  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.INHIBIT extended
          2014-10-02 14:44:30.291  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.LEVEL extended
          2014-10-02 14:44:30.301  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.INSTALL_TEST extended
          2014-10-02 14:44:30.310  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.WORKING extended
          2014-10-02 14:44:30.479  - error: hm-rpc.0 object hm-rpc.0.JEQ0112571:1 extend: Error: Document update conflict.
          2014-10-02 14:44:31.280  - info: hm-rpc.0 xmlrpc -> getParamsetDescription ["JEQ0140901:1","VALUES"]
          Rainer
          Gesendet von meinem Cynus T7 mit Tapatalk
            Trident last edited by
            Hi zusammen,
            nochmal ein kurzes Feedback von meiner Seite:
            Nach längerer "Pause" habe ich heute mal eine komplette Neuinstallation durchgeführt. Dabei kam beim Schritt "iobroker update" die folgende Fehlermeldung:
            ` > root@cubie:/opt/iobroker# ./iobroker update
            /conf/sources.json does not exits - ignore
            Cannot get version of "virtual".
            Cannot get version of "socketio".
            Cannot get version of "geofency".
            update done
            Adapter "yr" : 0.0.4
            Adapter "websocket" : 0.0.1
            Adapter "web" : 0.0.1
            /opt/iobroker/setup.js:1175
            text += ': ' + sources[name].version + ((sources[name].version.length <
            TypeError: Cannot read property 'length' of undefined
            at /opt/iobroker/setup.js:1175:75
            at download [as _onTimeout] (/opt/iobroker/setup.js:1136:27)
            at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
            root@cubie:/opt/iobroker# `
            Habt ihr da was umgestellt? Der Rest scheint zu funktionieren - Bei Bedarf eventuell mal die Anleitung aktualisieren. (Falls Ihr Zeit habt :))
            Viele Grüße
            Trident
              Was die ersten Fehlermeldungen angeht würde ich mir keine Sorge machen.
              Die erwähnten Adapter haben z.Zt. keine Versionsnummer:
              Ansonsten ist es das selbe was John schon mit dem RasPi festgestellt hat:
              http://forum.iobroker.org/viewtopic.php … 1046#p1046
              Rainer
                John92648 last edited by
                Hallo Trident, hab den gleichen Effekt im Raspi part auch gepostet. Seitdem kann man auch die instances nicht mehr aus dem Admin starten.
                Gruss John.
                Gesendet von iPhone
                  Sorry, meinte Instances installieren…..
                  Gesendet von iPhone
                  • Bluefox
                    @John92648:
                    Gesendet von iPhone `
                    Hm.. Ich kann das Verhalten nicht reproduzieren.
                    Aber es steht auch ein PullRequest da. HQ: kannst du denn mergen?
                      Habe gestern git pull durchgeführt.
                      Folgender Fehler tritt jetzt auf:
                      014-10-18 22:45:34.544  - info: hm-rega.0 renamed hm-rpc.0.LEQ0242152:0 to "Steckdose_Stube_hinten_links:0"
                      2014-10-18 22:45:34.729  - info: hm-rpc.0 xmlrpc -> 283 devices
                      2014-10-18 22:45:35.370  - error: uncaught exception: log is not defined
                      2014-10-18 22:45:35.433  - info: hm-rega.0 renamed hm-rpc.0.LEQ0242152 to "Steckdose_Stube_hinten_links"
                      2014-10-18 22:45:35.427  - error: ReferenceError: log is not defined
                          at Object.methods.event (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:240:9)
                          at Server. <anonymous>(/opt/iobroker/adapter/hm-rpc/hm-rpc.js:185:67)
                          at Server.EventEmitter.emit (events.js:106:17)
                          at /opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                          at callback (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                          at Deserializer.onDone (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                          at SAXStream.EventEmitter.emit (events.js:92:17)
                          at Object.SAXStream._parser.onend (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                          at emit (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                          at end (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:363:3)
                      2014-10-18 22:45:35.776  - info: hm-rega.0 renamed hm-rpc.0.KEQ0966548:6 to "Steckdose_Mitte:6"
                      2014-10-18 22:45:35.880  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1</anonymous>
                      Rainer
                      Gesendet von meinem LIFETAB_E10320 mit Tapatalk
                      • Bluefox
                        @Homoran:
                        Rainer
                        Gesendet von meinem LIFETAB_E10320 mit Tapatalk `
                        Danke!
                        Muss jetzt wieder funktionieren.
                          Hallo Bluefox
                          Läuft soweit wieder durch, lediglich der alte "error"
                          2014-10-20 20:52:26.081  - error: admin.0 : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
                          2014-10-20 20:52:26.092  - info: admin.0 starting
                          existiert noch.
                          EDIT:
                          leider doch nicht
                          2014-10-20 20:54:23.900  - error: ReferenceError: log is not defined
                          2014-10-20 20:54:23.922  - error: uncaught exception: log is not defined
                          2014-10-20 20:54:23.927  - error: ReferenceError: log is not defined
                              at end (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:363:3)</anonymous></anonymous>
                          ist noch da 😞
                          Außerdem ist kein ioBroker update mehr möglich:
                          Error: no repositories found in the "system.config
                          Rainer
                          • Bluefox
                            @Homoran:
                            Hallo Bluefox
                            existiert noch.
                            EDIT:
                            leider doch nicht
                            ist noch da 😞
                            Rainer
                            Ich befürchte, dass man alles von "null" installieren muss. Zu viele Änderungen letzte Zeit, was "update" angeht.
                            Es gibt jetzt "legacy" adapter. Kannst du denn auch anschauen? (Nach der Neuinstallation) 😄
                              @Bluefox:
                              Ich befürchte, dass man alles von "null" installieren muss. Zu viele Änderungen letzte Zeit, was "update" angeht. `
                              Mache ich gerne.
                              @Bluefox:
                              Es gibt jetzt "legacy" adapter. Kannst du denn auch anschauen? (Nach der Neuinstallation) `
                              den gab's doch schon mal - der hat mein System immer zum Absturz gebracht - ich wollte damals versuchen dashui damit ans Laufen zu bekommen.
                              Na dann bis später
                              Rainer
                                Ihr seid wahnsinnig 😛
                                Die Installation lief ohne einen einzigen Fehler durch!!!!
                                Habe erst einmal HM-rpc installiert - ist ja Bedingung für HM-REGA.
                                Dann HM-REGA und schwupps war da ein zweiter hm-rpc :?:
                                Muss man jetzt nicht mehr HM-rpc installieren bevor man HM-Rega installiert?
                                dann habe ich Legacy installiert.
                                Dabei habe ich mir den Log angesehen und weiß jetzt, was ihr die letzten Wochen gemacht habt 8-)
                                Alleine das Herunterladen der Daten zu dem Legacy-Adapter hat 16 Minuten gedauert!!!
                                Dann den Adapter konfiguriert (nur den Port) und aufgerufen:
                                das einzige, was ich zu sehen bekomme ist:
                                Cannot GET /
                                Im Log ist nichts negatives zu sehen
                                EDIT: Hatte erst nur <ipdescubie>:Port eingegeben,
                                Mit <ipdescubie>:Port/dashui klappt es!!!!! Wahnsinn!!!
                                Wie schon im Log gesehen sind die Legacy IDs nicht identisch mit den ccu.io IDs, das sieht man im importierten View:
                                und im Log:
                                2014-10-21 19:07:35.124  - info: legacy.0 socket.io <-- writeFile created /opt/iobroker/adapter/legacy/datastore/dashui-views.json.bak
                                2014-10-21 19:07:36.410  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.414  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.416  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.418  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.475  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property '1' of undefined
                                2014-10-21 19:07:36.644  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.647  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.649  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.652  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.662  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.663  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:36.665  - info: legacy.0 socket.io: transport end (undefined)
                                2014-10-21 19:07:36.669  - info: legacy.0 socket.io <-- 192.168.2.116:54037 websocket disconnected
                                2014-10-21 19:07:37.416  - info: legacy.0 socket.io: handshake authorized
                                2014-10-21 19:07:37.524  - info: legacy.0 socket.io <-- 192.168.2.116:54037 websocket connected
                                2014-10-21 19:07:37.537  - info: legacy.0 socket.io <-- getData
                                2014-10-21 19:07:37.565  - info: legacy.0 socket.io <-- touchFile www/dashui/css/dashui-user.css
                                2014-10-21 19:07:39.591  - info: legacy.0 socket.io <-- getObjects
                                2014-10-21 19:07:39.873  - info: legacy.0 socket.io <-- getIndex
                                2014-10-21 19:07:39.881  - info: legacy.0 socket.io <-- readFile dashui-views.json
                                2014-10-21 19:07:43.321  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.325  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.327  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.329  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.357  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property '1' of undefined
                                2014-10-21 19:07:43.463  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.466  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.468  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.470  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.472  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                2014-10-21 19:07:43.474  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                Rainer</ipdescubie></ipdescubie>
                                  @Bluefox:
                                  Du hast es nicht anders gewollt :shock:
                                  Ich habe jetzt mit dem dashui einige Zeit gespielt.
                                  Zuerst das positive:
                                  Bei dem Import von meinen Views gab es nur zwei gemeldete Errors:
                                  Ähnliches mit dem Widget jq ctrl input.
                                  Da einiges andere nicht lief habe ich erst einmal alle diese widgets gelöscht. Die anderen Fehler blieben.
                                  Folgende widgets scheinen ohne Probleme zu sein:
                                  • RGRaph Thermometer
                                  • RGraph Gauge
                                  • hq widgets IpCamera
                                  • bars views_bar
                                  • basic val - number
                                  • time_and_weather htcWeather
                                  bei folgenden kommt es zu Problemen:
                                  • hq widgets on_off
                                  beim Anklicken des widgets kommt es zu dieser Meldung:
                                  1. Beispiel: Entfeuchter in der Werkstatt
                                  2014-10-21 20:40:45.003 - error: pmessage hm-rpc.0.JEQ0646431:3{"val":true,"ack":false,"ts":1413916845,"from":"system.adapter.legacy.0","lc":1413916845} Cannot read property 'TYPE' of undefined
                                  2014-10-21 20:40:45.038 - error: TypeError: Cannot read property 'TYPE' of undefined
                                  at Object.require.stateChange (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:19:32)
                                  at that.states.StatesRedis.change (/opt/iobroker/lib/adapter.js:888:80)
                                  at RedisClient. <anonymous>(/opt/iobroker/lib/redis.js:48:21)
                                  at RedisClient.EventEmitter.emit (events.js:106:17)
                                  at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:672:22)
                                  at HiredisReplyParser. <anonymous>(/opt/iobroker/node_modules/redis/index.js:309:14)
                                  at HiredisReplyParser.EventEmitter.emit (events.js:95:17)
                                  at HiredisReplyParser.execute (/opt/iobroker/node_modules/redis/lib/parser/hiredis.js:43:18)
                                  at RedisClient.on_data (/opt/iobroker/node_modules/redis/index.js:534:27)
                                  at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:91:14)
                                  2. Beleuchtung im Schlafzimmer
                                  2014-10-21 20:42:10.327 - error: pmessage hm-rpc.0.JEQ0175818:1{"val":true,"ack":false,"ts":1413916930,"from":"system.adapter.legacy.0","lc":1413916930} Cannot read property 'TYPE' of undefined
                                  2014-10-21 20:42:10.353 - error: TypeError: Cannot read property 'TYPE' of undefined
                                  • hq widgets gauge
                                  keine Anzeige (getestet mit Variable)
                                  • hq widgets temperature
                                  keine Anzeige (getestet mit Sensorwert)
                                  • hq widgets info
                                  • hq widgets windows & shutter
                                  keine Anzeige Drehgriff und Rolladen
                                  • hq widgets Motion Detector
                                  keine Anzeige
                                  Soweit meine erste Analyse.
                                  Ihr tut mir richtig leid - ernsthaft!
                                  Wenn ich euch noch weiter helfen kann sagt bitte wie!
                                  Rainer</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                                  • Bluefox
                                    Danke Homoran. Jetzt haben noch was zu tun.
                                    Melde mich, wenn irgendwas neues geht. 😄
                                      @Bluefox:
                                      Melde mich, wenn irgendwas neues geht. `
                                      Hast du aber nicht getan 😞
                                      Schlaft ihr eigentlich irgendwann einmal?
                                      Habe eben schon das nächste update vom legacy heruntergeladen.
                                      Es scheint einiges mehr zu funktionieren!!
                                      Allerdings sieht es auf den ersten Blick so aus, als ob sich die IDs verschoben haben.
                                      Kann das sein?
                                      Ich werde nachher nochmal meine ccu.io views komplett importieren und die IDs anpassen.
                                      Melde mich dann nochmal.
                                      EDIT (18:33) - Ich melde mich:
                                      Status des Updates:
                                      folgende Widgets scheinen ohne Probleme zu laufen:
                                      • RGraph Gauge
                                      • bars views_bar
                                      • hq widgets gauge
                                      • hq widgets info
                                      • hq widgets on/off
                                      JQ widgets werden nicht dargestellt
                                      folgende Fehlermeldungen erscheinen im ioBroker log:
                                      2014-10-22 18:31:03.440  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.442  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.444  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.445  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.446  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.448  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.449  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.450  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.451  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.453  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:31:03.454  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                      2014-10-22 18:33:10.183  - error: legacy.0 Addon DashUI  Error: can't render tplHqShutter w00096 (TypeError: undefined is not a function)
                                      2014-10-22 18:33:10.632  - error: legacy.0 Addon DashUI  Error: can't render tplHqMotion w00114 (TypeError: undefined is not a function)
                                      2014-10-22 18:33:10.732  - error: legacy.0 Addon DashUI  Error: can't render tplHqGauge w00122 (TypeError: undefined is not a function)
                                      2014-10-22 18:33:10.742  - error: legacy.0 Addon DashUI  Error: can't render tplHqGauge w00123 (TypeError: undefined is not a function)
                                      2014-10-22 18:33:10.931  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00133 (TypeError: Cannot read property 'Value' of undefined)
                                      2014-10-22 18:33:11.035  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00144 (TypeError: Cannot read property 'Value' of undefined)
                                      2014-10-22 18:33:11.040  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00146 (TypeError: Cannot read property 'Value' of undefined)
                                      2014-10-22 18:33:11.048  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00148 (TypeError: Cannot read property 'Value' of undefined)
                                      2014-10-22 18:33:11.374  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00167 (TypeError: Cannot read property 'Value' of undefined)
                                      2014-10-22 18:33:11.383  - error: legacy.0 Addon DashUI  Error: can't render tplHqInfo w00168 (TypeError: undefined is not a function)
                                      2014-10-22 18:33:11.394  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00170 (TypeError: Cannot read property 'Value' of undefined)
                                      2014-10-22 18:33:11.398  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00171 (TypeError: Cannot read property 'Value' of undefined)
                                      2014-10-22 18:33:11.402  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00172 (TypeError: Cannot read property 'Value' of undefined)
                                      2014-10-22 18:33:11.405  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00173 (TypeError: Cannot read property 'Value' of undefined)
                                      UND:
                                      alle Variablen sind doppelt :!: :!: (zumindest in dem Datenpunktauswahl-Popup)
                                      Rainer
                                      PS würde es nicht Sinn machen jetzt schon für jeden Adapter einen Thread aufzumachen, ohne euch zu sehr unter Druck setzen zu wollen?
                                      • Bluefox
                                        Jetzt sollte viel mehr gehen.
                                          @Bluefox:
                                          Jetzt sollte viel mehr gehen. `
                                          Noch mehr?? seit 17:30 ???
                                          Es läuft doch fast alles!
                                          Leider habe ich sehr viele widgets, die bei ccu.io die Werte von Adaptern anzeigen.
                                          Die gibt es in ioBroker noch nicht (ping, cubie, Highcharts, sprit, eventlist)
                                          Die Rolläden werden korrekt angezeigt, lassen sich auch bedienen, jedoch wird der Status nicht automatisch refresht.
                                          Die Rolläden sind bei Sonnenuntergang heruntergegangen, in ioBroker jedoch nicht, erst nach ..dashui/edit… und wieder schließen war der Status korrekt.
                                          EDIT: ok, 0.1.3 lädt gerade herunter, dann wird es wieder ne lange Nacht 😉
                                          EDIT2 (20:50): Ihr seid wirklich wahnsinnig (oder Junkies) - Es scheint jetzt alles zu laufen, sogar die JQ gauges sind da - und die Variablen sind nur noch einmal da.
                                          ok, jetzt muss ich die IDs wieder ändern, aber ich denke das klappt.
                                          Morgen gibt's ein Update - jetzt geht auch mal früher ins Bett 8-)
                                          Rainer
                                            mimquadrat last edited by
                                            Hi Leute,
                                            muss den Broker nochmal komplett neu aufsetzen da nur noch das Zahnrad kommt.
                                            Wahrscheinlich durch die vielen vielen Änderungen.
                                            Könnte mir bitte kurz mal jemand nur stichpunktartig beschreiben wie ich JETZT vorgehen soll?
                                            Also welches NODE Paket von wo usw…
                                            Vielen Dank!
                                            M²
                                            176
                                            39520
