    4. Installation ioBroker auf Cubietruck
      Habe eben auf dem Tablet mit juicessh ein iobroker update gezogen.
      Leider ist die schrift fast nicht zu lesen.
      Es schien aber ein update für Admin und rpc zu geben.
      Da sich die webui weiter aufhängt. Habe ich mit ioBroker upgrade die Adapter auf den neuesten Stand gebracht.
      Leider hängt die webui immer noch.
      2014-09-28 21:09:26.088  - info: hm-rega.0 got 58 variables
      2014-09-28 21:09:27.357  - info: hm-rega.0 added/updated 58 variables
      2014-09-28 21:09:27.360  - info: hm-rega.0 deleted 0 variables
      2014-09-28 21:09:27.363  - info: hm-rega.0 request state values
      2014-09-28 21:09:31.349  - info: hm-rega.0 got state values
      2014-09-28 21:09:33.690  - info: controller instance system.adapter.hm-rpc.0 started with pid 2467
      2014-09-28 21:09:41.983  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
      2014-09-28 21:09:48.145  - info: history.0 enabled logging of hm-rega.0.2042
      2014-09-28 21:09:50.071  - info: history.0 disabled logging of hm-rega.0.12885
      2014-09-28 21:09:50.138  - info: history.0 enabled logging of hm-rega.0.12886
      2014-09-28 21:10:12.016  - info: controller instance system.adapter.hm-rpc.0 started with pid 2472
      2014-09-28 21:10:15.177  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
      2014-09-28 21:10:45.214  - info: controller instance system.adapter.hm-rpc.0 started with pid 2474
      2014-09-28 21:10:48.095  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
      2014-09-28 21:11:18.133  - info: controller instance system.adapter.hm-rpc.0 started with pid 2479
      2014-09-28 21:11:21.114  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
      2014-09-28 21:11:51.144  - info: controller instance system.adapter.hm-rpc.0 started with pid 2481
      2014-09-28 21:11:54.944  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
      2014-09-28 21:12:24.975  - info: controller instance system.adapter.hm-rpc.0 started with pid 2487
      2014-09-28 21:12:28.056  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
      2014-09-28 21:12:58.090  - info: controller instance system.adapter.hm-rpc.0 started with pid 2489
      2014-09-28 21:13:01.172  - error: controller instance system.adapter.hm-rpc.0 terminated with code 7
      Ganz zu Beginn kam noch ein error
      2014-09-28 21:16:05.445  - info: controller instance system.adapter.admin.0 started with pid 2615
      2014-09-28 21:16:09.442  - info: controller instance system.adapter.history.0 started with pid 2618
      2014-09-28 21:16:11.636  - error: admin.0 : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
      2014-09-28 21:16:11.651  - info: admin.0 starting
      2014-09-28 21:16:13.447  - info: controller instance system.adapter.hm-rega.0 started with pid 2626
      2014-09-28 21:16:14.888  - info: history.0 starting
      2014-09-28 21:16:15.573  - info: admin.0 received all states
      Ich hoffe ich habe beim upgrade alles richtig gemacht. Bei ioBroker update bin ich jedenfalls up to date.
      Rainer
      Gesendet von meinem LIFETAB_E10320 mit Tapatalk
        Neues Spiel neues Glück 😄
        heute war sowohl mit git pull neues da, als auch mit iobroker update eine neue admin - version.
        Der eine Error weg - ein anderer da:
        2014-10-01 19:38:17.359  - info: hm-rega.0 got 60 programs
        2014-10-01 19:38:18.420  - info: hm-rega.0 added/updated 62 programs
        2014-10-01 19:38:18.605  - error: uncaught exception: Cannot find module 'homematic-xmlrpc'
        2014-10-01 19:38:18.423  - info: hm-rega.0 deleted 0 programs
        2014-10-01 19:38:19.068  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1
        2014-10-01 19:38:22.152  - info: hm-rega.0 got 58 variables
        2014-10-01 19:38:23.347  - info: hm-rega.0 added/updated 58 variables
        2014-10-01 19:38:23.349  - info: hm-rega.0 deleted 0 variables
        2014-10-01 19:38:23.353  - info: hm-rega.0 request state values
        2014-10-01 19:38:24.951  - info: hm-rega.0 got state values
        2014-10-01 19:38:42.057  - info: history.0 enabled logging of hm-rega.0.2042
        2014-10-01 19:38:43.623  - info: history.0 disabled logging of hm-rega.0.12885
        2014-10-01 19:38:43.653  - info: history.0 enabled logging of hm-rega.0.12886
        2014-10-01 19:38:49.102  - info: controller instance system.adapter.hm-rpc.0 started with pid 17033
        2014-10-01 19:38:52.250  - error: uncaught exception: Cannot find module 'homematic-xmlrpc'
        2014-10-01 19:38:52.275  - error: Error: Cannot find module 'homematic-xmlrpc'
            at Function.Module._resolveFilename (module.js:338:15)
            at Function.Module._load (module.js:280:25)
            at Module.require (module.js:364:17)
            at require (module.js:380:17)
            at Object. <anonymous>(/opt/iobroker/adapter/hm-rpc/hm-rpc.js:96:14)
            at Module._compile (module.js:456:26)
            at Object.Module._extensions..js (module.js:474:10)
            at Module.load (module.js:356:32)
            at Function.Module._load (module.js:312:12)
            at Function.Module.runMain (module.js:497:10)
        2014-10-01 19:38:52.515  - info: hm-rpc.0 starting
        2014-10-01 19:38:52.535  - error: uncaught exception: Cannot call method 'createClient' of undefined
        2014-10-01 19:38:52.545  - error: TypeError: Cannot call method 'createClient' of undefined
            at main (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:106:21)
            at Object.require.ready (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:7:9)
            at initAdapter (/opt/iobroker/lib/adapter.js:1241:58)
            at /opt/iobroker/lib/adapter.js:137:29
            at /opt/iobroker/lib/couch.js:153:13
            at Request._callback (/opt/iobroker/node_modules/nano/nano.js:303:11)
            at Request.self.callback (/opt/iobroker/node_modules/nano/node_modules/request/request.js:122:22)
            at Request.EventEmitter.emit (events.js:98:17)
            at Request. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:888:14)
            at Request.EventEmitter.emit (events.js:117:20)
        2014-10-01 19:38:52.595  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1</anonymous></anonymous>
        Ich bin mit der lxccu auf meinen bananapi umgezogen und musste im rega und rpc.o noch die IP-Adressen ändern.
        Danach hat iobroker die Datenpunkte eingelesen und die obige Fehlermeldung gezeigt.
        Kann aber sein, dass ich die Konfig noch nicht ganz sauber habe
        gruß
        Rainer
        • Bluefox
          Bluefox last edited by
          @Homoran: gehe zu adapter/hm-rpc in der console und starte "npm install"
            @Bluefox:
            @Homoran: gehe zu adapter/hm-rpc in der console und starte "npm install" `
            Danke,
            Ist jetzt durchgestartet.
            Der Fehler
            2014-10-02 14:43:18.279  - info: controller starting 4 instances
            2014-10-02 14:43:18.357  - info: controller instance system.adapter.admin.0 started with pid 971
            2014-10-02 14:43:22.299  - info: controller instance system.adapter.history.0 started with pid 975
            2014-10-02 14:43:24.829  - error: admin.0 : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
            2014-10-02 14:43:24.839  - info: admin.0 starting
            Existiert noch.
            Und
            2014-10-02 14:44:30.076  - info: hm-rega.0 renamed hm-rpc.0.JEQ0112571 to "Markise"
            2014-10-02 14:44:30.163  - error: hm-rpc.0 object hm-rpc.0.JEQ0112571:0 extend: Error: Document update conflict.
            2014-10-02 14:44:30.267  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.STOP extended
            2014-10-02 14:44:30.274  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.INHIBIT extended
            2014-10-02 14:44:30.291  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.LEVEL extended
            2014-10-02 14:44:30.301  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.INSTALL_TEST extended
            2014-10-02 14:44:30.310  - info: hm-rpc.0 object hm-rpc.0.JEQ0112571:1.WORKING extended
            2014-10-02 14:44:30.479  - error: hm-rpc.0 object hm-rpc.0.JEQ0112571:1 extend: Error: Document update conflict.
            2014-10-02 14:44:31.280  - info: hm-rpc.0 xmlrpc -> getParamsetDescription ["JEQ0140901:1","VALUES"]
            Rainer
            Gesendet von meinem Cynus T7 mit Tapatalk
              Trident last edited by
              Hi zusammen,
              nochmal ein kurzes Feedback von meiner Seite:
              Nach längerer "Pause" habe ich heute mal eine komplette Neuinstallation durchgeführt. Dabei kam beim Schritt "iobroker update" die folgende Fehlermeldung:
              ` > root@cubie:/opt/iobroker# ./iobroker update
              /conf/sources.json does not exits - ignore
              Cannot get version of "virtual".
              Cannot get version of "socketio".
              Cannot get version of "geofency".
              update done
              Adapter "yr" : 0.0.4
              Adapter "websocket" : 0.0.1
              Adapter "web" : 0.0.1
              /opt/iobroker/setup.js:1175
              text += ': ' + sources[name].version + ((sources[name].version.length <
              TypeError: Cannot read property 'length' of undefined
              at /opt/iobroker/setup.js:1175:75
              at download [as _onTimeout] (/opt/iobroker/setup.js:1136:27)
              at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
              root@cubie:/opt/iobroker# `
              Habt ihr da was umgestellt? Der Rest scheint zu funktionieren - Bei Bedarf eventuell mal die Anleitung aktualisieren. (Falls Ihr Zeit habt :))
              Viele Grüße
              Trident
                Was die ersten Fehlermeldungen angeht würde ich mir keine Sorge machen.
                Die erwähnten Adapter haben z.Zt. keine Versionsnummer:
                Ansonsten ist es das selbe was John schon mit dem RasPi festgestellt hat:
                http://forum.iobroker.org/viewtopic.php … 1046#p1046
                Rainer
                  John92648 last edited by
                  Hallo Trident, hab den gleichen Effekt im Raspi part auch gepostet. Seitdem kann man auch die instances nicht mehr aus dem Admin starten.
                  Gruss John.
                  Gesendet von iPhone
                    Sorry, meinte Instances installieren…..
                    Gesendet von iPhone
                    • Bluefox
                      @John92648:
                      Gesendet von iPhone `
                      Hm.. Ich kann das Verhalten nicht reproduzieren.
                      Aber es steht auch ein PullRequest da. HQ: kannst du denn mergen?
                        Habe gestern git pull durchgeführt.
                        Folgender Fehler tritt jetzt auf:
                        014-10-18 22:45:34.544  - info: hm-rega.0 renamed hm-rpc.0.LEQ0242152:0 to "Steckdose_Stube_hinten_links:0"
                        2014-10-18 22:45:34.729  - info: hm-rpc.0 xmlrpc -> 283 devices
                        2014-10-18 22:45:35.370  - error: uncaught exception: log is not defined
                        2014-10-18 22:45:35.433  - info: hm-rega.0 renamed hm-rpc.0.LEQ0242152 to "Steckdose_Stube_hinten_links"
                        2014-10-18 22:45:35.427  - error: ReferenceError: log is not defined
                            at Object.methods.event (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:240:9)
                            at Server. <anonymous>(/opt/iobroker/adapter/hm-rpc/hm-rpc.js:185:67)
                            at Server.EventEmitter.emit (events.js:106:17)
                            at /opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                            at callback (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                            at Deserializer.onDone (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                            at SAXStream.EventEmitter.emit (events.js:92:17)
                            at Object.SAXStream._parser.onend (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                            at emit (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                            at end (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:363:3)
                        2014-10-18 22:45:35.776  - info: hm-rega.0 renamed hm-rpc.0.KEQ0966548:6 to "Steckdose_Mitte:6"
                        2014-10-18 22:45:35.880  - error: controller instance system.adapter.hm-rpc.0 terminated with code 1</anonymous>
                        Rainer
                        • Bluefox
                          @Homoran:
                          Rainer
                          Gesendet von meinem LIFETAB_E10320 mit Tapatalk `
                          Danke!
                          Muss jetzt wieder funktionieren.
                            Hallo Bluefox
                            Läuft soweit wieder durch, lediglich der alte "error"
                            2014-10-20 20:52:26.081  - error: admin.0 : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
                            2014-10-20 20:52:26.092  - info: admin.0 starting
                            existiert noch.
                            EDIT:
                            leider doch nicht
                            2014-10-20 20:54:23.900  - error: ReferenceError: log is not defined
                            2014-10-20 20:54:23.922  - error: uncaught exception: log is not defined
                            2014-10-20 20:54:23.927  - error: ReferenceError: log is not defined
                                at end (/opt/iobroker/adapter/hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:363:3)</anonymous></anonymous>
                            ist noch da 😞
                            Außerdem ist kein ioBroker update mehr möglich:
                            Error: no repositories found in the "system.config
                            Rainer
                            • Bluefox
                              @Homoran:
                              Hallo Bluefox
                              existiert noch.
                              EDIT:
                              leider doch nicht
                              ist noch da 😞
                              Rainer
                              Ich befürchte, dass man alles von "null" installieren muss. Zu viele Änderungen letzte Zeit, was "update" angeht.
                              Es gibt jetzt "legacy" adapter. Kannst du denn auch anschauen? (Nach der Neuinstallation) 😄
                                @Bluefox:
                                Ich befürchte, dass man alles von "null" installieren muss. Zu viele Änderungen letzte Zeit, was "update" angeht. `
                                Mache ich gerne.
                                @Bluefox:
                                Es gibt jetzt "legacy" adapter. Kannst du denn auch anschauen? (Nach der Neuinstallation) `
                                den gab's doch schon mal - der hat mein System immer zum Absturz gebracht - ich wollte damals versuchen dashui damit ans Laufen zu bekommen.
                                Na dann bis später
                                Rainer
                                  Ihr seid wahnsinnig 😛
                                  Die Installation lief ohne einen einzigen Fehler durch!!!!
                                  Habe erst einmal HM-rpc installiert - ist ja Bedingung für HM-REGA.
                                  Dann HM-REGA und schwupps war da ein zweiter hm-rpc :?:
                                  Muss man jetzt nicht mehr HM-rpc installieren bevor man HM-Rega installiert?
                                  dann habe ich Legacy installiert.
                                  Dabei habe ich mir den Log angesehen und weiß jetzt, was ihr die letzten Wochen gemacht habt 8-)
                                  Alleine das Herunterladen der Daten zu dem Legacy-Adapter hat 16 Minuten gedauert!!!
                                  Dann den Adapter konfiguriert (nur den Port) und aufgerufen:
                                  das einzige, was ich zu sehen bekomme ist:
                                  Cannot GET /
                                  Im Log ist nichts negatives zu sehen
                                  EDIT: Hatte erst nur <ipdescubie>:Port eingegeben,
                                  Mit <ipdescubie>:Port/dashui klappt es!!!!! Wahnsinn!!!
                                  Wie schon im Log gesehen sind die Legacy IDs nicht identisch mit den ccu.io IDs, das sieht man im importierten View:
                                  und im Log:
                                  2014-10-21 19:07:35.124  - info: legacy.0 socket.io <-- writeFile created /opt/iobroker/adapter/legacy/datastore/dashui-views.json.bak
                                  2014-10-21 19:07:36.410  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.414  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.416  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.418  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.475  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property '1' of undefined
                                  2014-10-21 19:07:36.644  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.647  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.649  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.652  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.662  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.663  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:36.665  - info: legacy.0 socket.io: transport end (undefined)
                                  2014-10-21 19:07:36.669  - info: legacy.0 socket.io <-- 192.168.2.116:54037 websocket disconnected
                                  2014-10-21 19:07:37.416  - info: legacy.0 socket.io: handshake authorized
                                  2014-10-21 19:07:37.524  - info: legacy.0 socket.io <-- 192.168.2.116:54037 websocket connected
                                  2014-10-21 19:07:37.537  - info: legacy.0 socket.io <-- getData
                                  2014-10-21 19:07:37.565  - info: legacy.0 socket.io <-- touchFile www/dashui/css/dashui-user.css
                                  2014-10-21 19:07:39.591  - info: legacy.0 socket.io <-- getObjects
                                  2014-10-21 19:07:39.873  - info: legacy.0 socket.io <-- getIndex
                                  2014-10-21 19:07:39.881  - info: legacy.0 socket.io <-- readFile dashui-views.json
                                  2014-10-21 19:07:43.321  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.325  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.327  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.329  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.357  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property '1' of undefined
                                  2014-10-21 19:07:43.463  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.466  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.468  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.470  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.472  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  2014-10-21 19:07:43.474  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                  Rainer</ipdescubie></ipdescubie>
                                    @Bluefox:
                                    Du hast es nicht anders gewollt :shock:
                                    Ich habe jetzt mit dem dashui einige Zeit gespielt.
                                    Zuerst das positive:
                                    Bei dem Import von meinen Views gab es nur zwei gemeldete Errors:
                                    Ähnliches mit dem Widget jq ctrl input.
                                    Da einiges andere nicht lief habe ich erst einmal alle diese widgets gelöscht. Die anderen Fehler blieben.
                                    Folgende widgets scheinen ohne Probleme zu sein:
                                    • RGRaph Thermometer
                                    • RGraph Gauge
                                    • hq widgets IpCamera
                                    • bars views_bar
                                    • basic val - number
                                    • time_and_weather htcWeather
                                    bei folgenden kommt es zu Problemen:
                                    • hq widgets on_off
                                    beim Anklicken des widgets kommt es zu dieser Meldung:
                                    1. Beispiel: Entfeuchter in der Werkstatt
                                    2014-10-21 20:40:45.003 - error: pmessage hm-rpc.0.JEQ0646431:3{"val":true,"ack":false,"ts":1413916845,"from":"system.adapter.legacy.0","lc":1413916845} Cannot read property 'TYPE' of undefined
                                    2014-10-21 20:40:45.038 - error: TypeError: Cannot read property 'TYPE' of undefined
                                    at Object.require.stateChange (/opt/iobroker/adapter/hm-rpc/hm-rpc.js:19:32)
                                    at that.states.StatesRedis.change (/opt/iobroker/lib/adapter.js:888:80)
                                    at RedisClient. <anonymous>(/opt/iobroker/lib/redis.js:48:21)
                                    at RedisClient.EventEmitter.emit (events.js:106:17)
                                    at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:672:22)
                                    at HiredisReplyParser. <anonymous>(/opt/iobroker/node_modules/redis/index.js:309:14)
                                    at HiredisReplyParser.EventEmitter.emit (events.js:95:17)
                                    at HiredisReplyParser.execute (/opt/iobroker/node_modules/redis/lib/parser/hiredis.js:43:18)
                                    at RedisClient.on_data (/opt/iobroker/node_modules/redis/index.js:534:27)
                                    at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:91:14)
                                    2. Beleuchtung im Schlafzimmer
                                    2014-10-21 20:42:10.327 - error: pmessage hm-rpc.0.JEQ0175818:1{"val":true,"ack":false,"ts":1413916930,"from":"system.adapter.legacy.0","lc":1413916930} Cannot read property 'TYPE' of undefined
                                    2014-10-21 20:42:10.353 - error: TypeError: Cannot read property 'TYPE' of undefined
                                    • hq widgets gauge
                                    keine Anzeige (getestet mit Variable)
                                    • hq widgets temperature
                                    keine Anzeige (getestet mit Sensorwert)
                                    • hq widgets info
                                    • hq widgets windows & shutter
                                    keine Anzeige Drehgriff und Rolladen
                                    • hq widgets Motion Detector
                                    keine Anzeige
                                    Soweit meine erste Analyse.
                                    Ihr tut mir richtig leid - ernsthaft!
                                    Wenn ich euch noch weiter helfen kann sagt bitte wie!
                                    Rainer</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                                    • Bluefox
                                      Danke Homoran. Jetzt haben noch was zu tun.
                                      Melde mich, wenn irgendwas neues geht. 😄
                                        @Bluefox:
                                        Melde mich, wenn irgendwas neues geht. `
                                        Hast du aber nicht getan 😞
                                        Schlaft ihr eigentlich irgendwann einmal?
                                        Habe eben schon das nächste update vom legacy heruntergeladen.
                                        Es scheint einiges mehr zu funktionieren!!
                                        Allerdings sieht es auf den ersten Blick so aus, als ob sich die IDs verschoben haben.
                                        Kann das sein?
                                        Ich werde nachher nochmal meine ccu.io views komplett importieren und die IDs anpassen.
                                        Melde mich dann nochmal.
                                        EDIT (18:33) - Ich melde mich:
                                        Status des Updates:
                                        folgende Widgets scheinen ohne Probleme zu laufen:
                                        • RGraph Gauge
                                        • bars views_bar
                                        • hq widgets gauge
                                        • hq widgets info
                                        • hq widgets on/off
                                        JQ widgets werden nicht dargestellt
                                        folgende Fehlermeldungen erscheinen im ioBroker log:
                                        2014-10-22 18:31:03.440  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.442  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.444  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.445  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.446  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.448  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.449  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.450  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.451  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.453  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:31:03.454  - error: legacy.0 Addon DashUI  Cannot render widget jqplot: TypeError: Cannot read property 'Value' of undefined
                                        2014-10-22 18:33:10.183  - error: legacy.0 Addon DashUI  Error: can't render tplHqShutter w00096 (TypeError: undefined is not a function)
                                        2014-10-22 18:33:10.632  - error: legacy.0 Addon DashUI  Error: can't render tplHqMotion w00114 (TypeError: undefined is not a function)
                                        2014-10-22 18:33:10.732  - error: legacy.0 Addon DashUI  Error: can't render tplHqGauge w00122 (TypeError: undefined is not a function)
                                        2014-10-22 18:33:10.742  - error: legacy.0 Addon DashUI  Error: can't render tplHqGauge w00123 (TypeError: undefined is not a function)
                                        2014-10-22 18:33:10.931  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00133 (TypeError: Cannot read property 'Value' of undefined)
                                        2014-10-22 18:33:11.035  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00144 (TypeError: Cannot read property 'Value' of undefined)
                                        2014-10-22 18:33:11.040  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00146 (TypeError: Cannot read property 'Value' of undefined)
                                        2014-10-22 18:33:11.048  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00148 (TypeError: Cannot read property 'Value' of undefined)
                                        2014-10-22 18:33:11.374  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00167 (TypeError: Cannot read property 'Value' of undefined)
                                        2014-10-22 18:33:11.383  - error: legacy.0 Addon DashUI  Error: can't render tplHqInfo w00168 (TypeError: undefined is not a function)
                                        2014-10-22 18:33:11.394  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00170 (TypeError: Cannot read property 'Value' of undefined)
                                        2014-10-22 18:33:11.398  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00171 (TypeError: Cannot read property 'Value' of undefined)
                                        2014-10-22 18:33:11.402  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00172 (TypeError: Cannot read property 'Value' of undefined)
                                        2014-10-22 18:33:11.405  - error: legacy.0 Addon DashUI  Error: can't render tplJquiInput w00173 (TypeError: Cannot read property 'Value' of undefined)
                                        UND:
                                        alle Variablen sind doppelt :!: :!: (zumindest in dem Datenpunktauswahl-Popup)
                                        Rainer
                                        PS würde es nicht Sinn machen jetzt schon für jeden Adapter einen Thread aufzumachen, ohne euch zu sehr unter Druck setzen zu wollen?
                                        • Bluefox
                                          Jetzt sollte viel mehr gehen.
                                            @Bluefox:
                                            Jetzt sollte viel mehr gehen. `
                                            Noch mehr?? seit 17:30 ???
                                            Es läuft doch fast alles!
                                            Leider habe ich sehr viele widgets, die bei ccu.io die Werte von Adaptern anzeigen.
                                            Die gibt es in ioBroker noch nicht (ping, cubie, Highcharts, sprit, eventlist)
                                            Die Rolläden werden korrekt angezeigt, lassen sich auch bedienen, jedoch wird der Status nicht automatisch refresht.
                                            Die Rolläden sind bei Sonnenuntergang heruntergegangen, in ioBroker jedoch nicht, erst nach ..dashui/edit… und wieder schließen war der Status korrekt.
                                            EDIT: ok, 0.1.3 lädt gerade herunter, dann wird es wieder ne lange Nacht 😉
                                            EDIT2 (20:50): Ihr seid wirklich wahnsinnig (oder Junkies) - Es scheint jetzt alles zu laufen, sogar die JQ gauges sind da - und die Variablen sind nur noch einmal da.
                                            ok, jetzt muss ich die IDs wieder ändern, aber ich denke das klappt.
                                            Morgen gibt's ein Update - jetzt geht auch mal früher ins Bett 8-)
                                            Rainer
                                            176
                                            39519
